Re: [PATCH v7 1/8] riscv: cpu: fu740: Add support for cpu fu740
(resending to the list after subscribing)
On Thu, Apr 22, 2021 at 10:14 AM Green Wan green.wan@sifive.com wrote:
Add SiFive fu740 cpu to support RISC-V arch
Signed-off-by: Green Wan green.wan@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
arch/riscv/Kconfig | 1 + arch/riscv/cpu/fu740/Kconfig | 37 +++++++++++++++ arch/riscv/cpu/fu740/Makefile | 12 +++++ arch/riscv/cpu/fu740/cache.c | 55 +++++++++++++++++++++++ arch/riscv/cpu/fu740/cpu.c | 22 +++++++++ arch/riscv/cpu/fu740/dram.c | 38 ++++++++++++++++ arch/riscv/cpu/fu740/spl.c | 23 ++++++++++ arch/riscv/include/asm/arch-fu740/cache.h | 14 ++++++ arch/riscv/include/asm/arch-fu740/clk.h | 14 ++++++ arch/riscv/include/asm/arch-fu740/gpio.h | 38 ++++++++++++++++ arch/riscv/include/asm/arch-fu740/reset.h | 13 ++++++ arch/riscv/include/asm/arch-fu740/spl.h | 14 ++++++ arch/riscv/lib/sifive_clint.c | 1 - 13 files changed, 281 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/cpu/fu740/Kconfig create mode 100644 arch/riscv/cpu/fu740/Makefile create mode 100644 arch/riscv/cpu/fu740/cache.c create mode 100644 arch/riscv/cpu/fu740/cpu.c create mode 100644 arch/riscv/cpu/fu740/dram.c create mode 100644 arch/riscv/cpu/fu740/spl.c create mode 100644 arch/riscv/include/asm/arch-fu740/cache.h create mode 100644 arch/riscv/include/asm/arch-fu740/clk.h create mode 100644 arch/riscv/include/asm/arch-fu740/gpio.h create mode 100644 arch/riscv/include/asm/arch-fu740/reset.h create mode 100644 arch/riscv/include/asm/arch-fu740/spl.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 3f221dccdb..4177253e44 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -61,6 +61,7 @@ source "board/sipeed/maix/Kconfig" # platform-specific options below source "arch/riscv/cpu/ax25/Kconfig" source "arch/riscv/cpu/fu540/Kconfig" +source "arch/riscv/cpu/fu740/Kconfig" source "arch/riscv/cpu/generic/Kconfig"
# architecture-specific options below diff --git a/arch/riscv/cpu/fu740/Kconfig b/arch/riscv/cpu/fu740/Kconfig new file mode 100644 index 0000000000..24788beab1 --- /dev/null +++ b/arch/riscv/cpu/fu740/Kconfig @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020-2021 SiFive, Inc +# Pragnesh Patel pragnesh.patel@sifive.com
+config SIFIVE_FU740
bool
select ARCH_EARLY_INIT_R
select RAM
select SPL_RAM if SPL
imply CPU
imply CPU_RISCV
imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE)
imply SIFIVE_CLINT if (RISCV_MMODE || SPL_RISCV_MMODE)
imply CMD_CPU
imply SPL_CPU
imply SPL_OPENSBI
imply SPL_LOAD_FIT
imply SMP
imply CLK_SIFIVE
imply CLK_SIFIVE_PRCI
imply SIFIVE_SERIAL
imply MACB
imply MII
imply SPI
imply SPI_SIFIVE
imply MMC
imply MMC_SPI
imply MMC_BROKEN_CD
imply CMD_MMC
imply DM_GPIO
imply SIFIVE_GPIO
imply CMD_GPIO
imply MISC
imply SIFIVE_OTP
imply DM_PWM
imply PWM_SIFIVE
diff --git a/arch/riscv/cpu/fu740/Makefile b/arch/riscv/cpu/fu740/Makefile new file mode 100644 index 0000000000..5ef8ac18a7 --- /dev/null +++ b/arch/riscv/cpu/fu740/Makefile @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020-2021 SiFive, Inc +# Pragnesh Patel pragnesh.patel@sifive.com
+ifeq ($(CONFIG_SPL_BUILD),y) +obj-y += spl.o +else +obj-y += dram.o +obj-y += cpu.o +obj-y += cache.o +endif diff --git a/arch/riscv/cpu/fu740/cache.c b/arch/riscv/cpu/fu740/cache.c new file mode 100644 index 0000000000..680955c9e3 --- /dev/null +++ b/arch/riscv/cpu/fu740/cache.c @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2020-2021 SiFive, Inc
- Authors:
- Pragnesh Patel pragnesh.patel@sifive.com
+#include <common.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <asm/global_data.h>
+/* Register offsets */ +#define L2_CACHE_CONFIG 0x000 +#define L2_CACHE_ENABLE 0x008
+#define MASK_NUM_WAYS GENMASK(15, 8) +#define NUM_WAYS_SHIFT 8
+DECLARE_GLOBAL_DATA_PTR;
+int cache_enable_ways(void) +{
const void *blob = gd->fdt_blob;
int node;
fdt_addr_t base;
u32 config;
u32 ways;
volatile u32 *enable;
node = fdt_node_offset_by_compatible(blob, -1,
"sifive,fu740-c000-ccache");
if (node < 0)
return node;
base = fdtdec_get_addr_size_auto_parent(blob, 0, node, "reg", 0,
NULL, false);
if (base == FDT_ADDR_T_NONE)
return FDT_ADDR_T_NONE;
config = readl((volatile u32 *)base + L2_CACHE_CONFIG);
ways = (config & MASK_NUM_WAYS) >> NUM_WAYS_SHIFT;
enable = (volatile u32 *)(base + L2_CACHE_ENABLE);
/* memory barrier */
mb();
(*enable) = ways - 1;
mb();
+} diff --git a/arch/riscv/cpu/fu740/cpu.c b/arch/riscv/cpu/fu740/cpu.c new file mode 100644 index 0000000000..f13c18942f --- /dev/null +++ b/arch/riscv/cpu/fu740/cpu.c @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com
+#include <irq_func.h> +#include <asm/cache.h>
- cleanup_before_linux() is called just before we call linux
- it prepares the processor for linux
- we disable interrupt and caches.
+int cleanup_before_linux(void) +{
disable_interrupts();
cache_flush();
+} diff --git a/arch/riscv/cpu/fu740/dram.c b/arch/riscv/cpu/fu740/dram.c new file mode 100644 index 0000000000..1dc77efeca --- /dev/null +++ b/arch/riscv/cpu/fu740/dram.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <fdtdec.h> +#include <init.h> +#include <linux/sizes.h>
+int dram_init(void) +{
return fdtdec_setup_mem_size_base();
+int dram_init_banksize(void) +{
return fdtdec_setup_memory_banksize();
+ulong board_get_usable_ram_top(ulong total_size) +{ +#ifdef CONFIG_64BIT
* Ensure that we run from first 4GB so that all
* addresses used by U-Boot are 32bit addresses.
* This in-turn ensures that 32bit DMA capable
* devices work fine because DMA mapping APIs will
* provide 32bit DMA addresses only.
if (gd->ram_top > SZ_4G)
return SZ_4G;
return gd->ram_top;
+} diff --git a/arch/riscv/cpu/fu740/spl.c b/arch/riscv/cpu/fu740/spl.c new file mode 100644 index 0000000000..ea0b2283a2 --- /dev/null +++ b/arch/riscv/cpu/fu740/spl.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2020-201 SiFive, Inc
+#include <dm.h> +#include <log.h>
+int spl_soc_init(void) +{
int ret;
struct udevice *dev;
/* DDR init */
ret = uclass_get_device(UCLASS_RAM, 0, &dev);
if (ret) {
debug("DRAM init failed: %d\n", ret);
return ret;
+} diff --git a/arch/riscv/include/asm/arch-fu740/cache.h b/arch/riscv/include/asm/arch-fu740/cache.h new file mode 100644 index 0000000000..7d4fe9942b --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/cache.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Copyright (C) 2020-2021 SiFive, Inc.
- Authors:
- Pragnesh Patel pragnesh.patel@sifve.com
+#ifndef _CACHE_SIFIVE_H +#define _CACHE_SIFIVE_H
+int cache_enable_ways(void);
+#endif /* _CACHE_SIFIVE_H */ diff --git a/arch/riscv/include/asm/arch-fu740/clk.h b/arch/riscv/include/asm/arch-fu740/clk.h new file mode 100644 index 0000000000..9f883616b2 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/clk.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Copyright (c) 2020-2021 SiFive Inc
- Authors:
+#ifndef __CLK_SIFIVE_H +#define __CLK_SIFIVE_H
+/* Note: This is a placeholder header for driver compilation. */
+#endif diff --git a/arch/riscv/include/asm/arch-fu740/gpio.h b/arch/riscv/include/asm/arch-fu740/gpio.h new file mode 100644 index 0000000000..908e2e5563 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/gpio.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef _GPIO_SIFIVE_H +#define _GPIO_SIFIVE_H
+#define GPIO_INPUT_VAL 0x00 +#define GPIO_INPUT_EN 0x04 +#define GPIO_OUTPUT_EN 0x08 +#define GPIO_OUTPUT_VAL 0x0C +#define GPIO_RISE_IE 0x18 +#define GPIO_RISE_IP 0x1C +#define GPIO_FALL_IE 0x20 +#define GPIO_FALL_IP 0x24 +#define GPIO_HIGH_IE 0x28 +#define GPIO_HIGH_IP 0x2C +#define GPIO_LOW_IE 0x30 +#define GPIO_LOW_IP 0x34 +#define GPIO_OUTPUT_XOR 0x40
+#define NR_GPIOS 16
+enum gpio_state {
LOW,
HIGH
+/* Details about a GPIO bank */ +struct sifive_gpio_plat {
void *base; /* address of registers in physical memory */
+#define SIFIVE_GENERIC_GPIO_NR(port, index) \
(((port) * NR_GPIOS) + ((index) & (NR_GPIOS - 1)))
+#endif /* _GPIO_SIFIVE_H */ diff --git a/arch/riscv/include/asm/arch-fu740/reset.h b/arch/riscv/include/asm/arch-fu740/reset.h new file mode 100644 index 0000000000..538ef87410 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/reset.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Copyright (c) 2020-2021 SiFive, Inc.
- Author: Sagar Kadam sagar.kadam@sifive.com
+#ifndef __RESET_SIFIVE_H +#define __RESET_SIFIVE_H
+int sifive_reset_bind(struct udevice *dev, ulong count);
+#endif diff --git a/arch/riscv/include/asm/arch-fu740/spl.h b/arch/riscv/include/asm/arch-fu740/spl.h new file mode 100644 index 0000000000..15ad9e7c8b --- /dev/null +++ b/arch/riscv/include/asm/arch-fu740/spl.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Authors:
+#ifndef _SPL_SIFIVE_H +#define _SPL_SIFIVE_H
+int spl_soc_init(void);
+#endif /* _SPL_SIFIVE_H */ diff --git a/arch/riscv/lib/sifive_clint.c b/arch/riscv/lib/sifive_clint.c index ab22395c55..cfa288a01a 100644 --- a/arch/riscv/lib/sifive_clint.c +++ b/arch/riscv/lib/sifive_clint.c @@ -10,7 +10,6 @@
#include <common.h> #include <dm.h> -#include <asm/global_data.h> #include <asm/io.h> #include <asm/smp.h> #include <linux/err.h>
Why is this include being removed? As far as I can tell the file does use things from asm/global_data.h i.e. a little further down it does
... DECLARE_GLOBAL_DATA_PTR; ... gd->arch.clint
Which come from asm/global_data.h header. Am I missing something?
-- Regards,
Dimitri.
Dimitri John Ledkov
