[PATCH 00/13] powerpc: covert p1010, p1020 and p2020 RDB board
This patch set depends on: https://patchwork.ozlabs.org/project/uboot/list/?series=174343
Hou Zhiqiang (13): net: fsl_pq_mdio: Add the compatible "fsl,gianfar-mdio" support net: tsec: Add the compatible string "gianfar" support powerpc: mpc8xxx: Don't compile cpu_eth_init() when DM_ETH enabled fsl: p1_p2_rdb: Move vsc7835 firmware uploading to board_early_init_r() configs: p1_p2_rdb: Add the default address of vsc7385 firmware dts: powerpc: p1020rdb: Add eTSEC DT nodes powerpc: p1_p2_rdb: Don't compile board_eth_init() when DM_ETH enabled configs: P1020RDB: Enable DM_ETH config dts: powerpc: p1010rdb: Add eTSEC DT nodes powerpc: p1010rdb: Compile legacy ethernet init function when no DM_ETH configs: P1010RDB: Enable DM_ETH config dts: powerpc: p2020rdb: Add eTSEC DT nodes configs: P2020RDB: Enable DM_ETH config
arch/powerpc/cpu/mpc8xxx/cpu.c | 2 + arch/powerpc/dts/p1010rdb-pa.dts | 1 + arch/powerpc/dts/p1010rdb-pa_36b.dts | 1 + arch/powerpc/dts/p1010rdb-pb.dts | 1 + arch/powerpc/dts/p1010rdb-pb_36b.dts | 1 + arch/powerpc/dts/p1010rdb.dtsi | 71 +++++++++++++++++++ arch/powerpc/dts/p1010si-post.dtsi | 25 +++++++ arch/powerpc/dts/p1020-post.dtsi | 15 ++++ arch/powerpc/dts/p1020rdb-pc.dts | 1 + arch/powerpc/dts/p1020rdb-pc.dtsi | 55 ++++++++++++++ arch/powerpc/dts/p1020rdb-pc_36b.dts | 1 + arch/powerpc/dts/p1020rdb-pd.dts | 57 +++++++++++++++ arch/powerpc/dts/p2020-post.dtsi | 10 +++ arch/powerpc/dts/p2020rdb-pc.dts | 1 + arch/powerpc/dts/p2020rdb-pc.dtsi | 59 +++++++++++++++ arch/powerpc/dts/p2020rdb-pc_36b.dts | 1 + arch/powerpc/dts/pq3-etsec1-0.dtsi | 28 ++++++++ arch/powerpc/dts/pq3-etsec1-1.dtsi | 28 ++++++++ arch/powerpc/dts/pq3-etsec1-2.dtsi | 28 ++++++++ arch/powerpc/dts/pq3-etsec1-3.dtsi | 28 ++++++++ arch/powerpc/dts/pq3-etsec1-timer-0.dtsi | 13 ++++ arch/powerpc/dts/pq3-etsec2-0.dtsi | 35 +++++++++ arch/powerpc/dts/pq3-etsec2-1.dtsi | 35 +++++++++ arch/powerpc/dts/pq3-etsec2-2.dtsi | 35 +++++++++ arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi | 16 +++++ arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi | 16 +++++ arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi | 16 +++++ board/freescale/p1010rdb/p1010rdb.c | 2 + board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 37 +++++----- configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 2 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 2 + configs/P1010RDB-PA_NAND_defconfig | 2 + configs/P1010RDB-PA_NOR_defconfig | 2 + configs/P1010RDB-PA_SDCARD_defconfig | 2 + configs/P1010RDB-PA_SPIFLASH_defconfig | 2 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 2 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 2 + configs/P1010RDB-PB_NAND_defconfig | 2 + configs/P1010RDB-PB_NOR_defconfig | 2 + configs/P1010RDB-PB_SDCARD_defconfig | 2 + configs/P1010RDB-PB_SPIFLASH_defconfig | 2 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 3 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 3 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 3 + configs/P1020RDB-PC_36BIT_defconfig | 3 + configs/P1020RDB-PC_NAND_defconfig | 3 + configs/P1020RDB-PC_SDCARD_defconfig | 3 + configs/P1020RDB-PC_SPIFLASH_defconfig | 3 + configs/P1020RDB-PC_defconfig | 3 + configs/P1020RDB-PD_NAND_defconfig | 3 + configs/P1020RDB-PD_SDCARD_defconfig | 3 + configs/P1020RDB-PD_SPIFLASH_defconfig | 3 + configs/P1020RDB-PD_defconfig | 3 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 3 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 3 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 3 + configs/P2020RDB-PC_36BIT_defconfig | 3 + configs/P2020RDB-PC_NAND_defconfig | 3 + configs/P2020RDB-PC_SDCARD_defconfig | 3 + configs/P2020RDB-PC_SPIFLASH_defconfig | 3 + configs/P2020RDB-PC_defconfig | 3 + doc/device-tree-bindings/net/fsl-tsec-phy.txt | 5 +- drivers/net/fsl_mdio.c | 15 +++- drivers/net/tsec.c | 16 ++++- include/configs/p1_p2_rdb_pc.h | 2 + include/fsl_mdio.h | 4 ++ include/tsec.h | 4 ++ 71 files changed, 734 insertions(+), 23 deletions(-) create mode 100644 arch/powerpc/dts/p1010rdb.dtsi create mode 100644 arch/powerpc/dts/p1020rdb-pc.dtsi create mode 100644 arch/powerpc/dts/p2020rdb-pc.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-2.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-3.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-timer-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-2.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi
Add compatible string "fsl,gianfar-mdio" support and update the device-tree-bindings doc.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- doc/device-tree-bindings/net/fsl-tsec-phy.txt | 3 ++- drivers/net/fsl_mdio.c | 15 +++++++++++++-- include/fsl_mdio.h | 4 ++++ 3 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/doc/device-tree-bindings/net/fsl-tsec-phy.txt b/doc/device-tree-bindings/net/fsl-tsec-phy.txt index 8e8574bc97..a709b89a5c 100644 --- a/doc/device-tree-bindings/net/fsl-tsec-phy.txt +++ b/doc/device-tree-bindings/net/fsl-tsec-phy.txt @@ -28,7 +28,8 @@ device that exists on this bus, a PHY node should be created.
Required properties: - compatible : Should define the compatible device type for the - mdio. Currently supported string/device is "fsl,etsec2-mdio". + mdio. Currently supported string/device is "fsl,etsec2-mdio" and + "fsl,gianfar-mdio". - reg : Offset and length of the register set for the device
Example: diff --git a/drivers/net/fsl_mdio.c b/drivers/net/fsl_mdio.c index 284508062c..ea9c37ad19 100644 --- a/drivers/net/fsl_mdio.c +++ b/drivers/net/fsl_mdio.c @@ -138,10 +138,12 @@ static int dm_fsl_pq_mdio_write(struct udevice *dev, int addr, int devad, static int fsl_pq_mdio_probe(struct udevice *dev) { struct fsl_pq_mdio_info *info = dev_get_priv(dev); + struct fsl_pq_mdio_data *data; fdt_addr_t reg;
+ data = (struct fsl_pq_mdio_data *)dev_get_driver_data(dev); reg = devfdt_get_addr(dev); - info->regs = map_physmem(reg + TSEC_MDIO_REGS_OFFSET, 0, MAP_NOCACHE); + info->regs = map_physmem(reg + data->mdio_regs_off, 0, MAP_NOCACHE);
return fsl_pq_mdio_reset(info->regs); } @@ -151,8 +153,17 @@ static const struct mdio_ops fsl_pq_mdio_ops = { .write = dm_fsl_pq_mdio_write, };
+static struct fsl_pq_mdio_data etsec2_data = { + .mdio_regs_off = TSEC_MDIO_REGS_OFFSET, +}; + +static struct fsl_pq_mdio_data gianfar_data = { + .mdio_regs_off = 0x0, +}; + static const struct udevice_id fsl_pq_mdio_ids[] = { - { .compatible = "fsl,etsec2-mdio" }, + { .compatible = "fsl,etsec2-mdio", .data = (ulong)&etsec2_data }, + { .compatible = "fsl,gianfar-mdio", .data = (ulong)&gianfar_data }, { } };
diff --git a/include/fsl_mdio.h b/include/fsl_mdio.h index 386c477a8b..80e3100cda 100644 --- a/include/fsl_mdio.h +++ b/include/fsl_mdio.h @@ -53,6 +53,10 @@ int memac_mdio_read(struct mii_dev *bus, int port_addr, int dev_addr, int regnum); int memac_mdio_reset(struct mii_dev *bus);
+struct fsl_pq_mdio_data { + u32 mdio_regs_off; +}; + struct fsl_pq_mdio_info { struct tsec_mii_mng __iomem *regs; char *name;
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Zhiqiang Hou Sent: Tuesday, May 5, 2020 5:08 PM To: u-boot@lists.denx.de; bmeng.cn@gmail.com; olteanv@gmail.com; Priyanka Jain priyanka.jain@nxp.com Cc: Z.q. Hou zhiqiang.hou@nxp.com Subject: [PATCH 01/13] net: fsl_pq_mdio: Add the compatible "fsl, gianfar- mdio" support
Add compatible string "fsl,gianfar-mdio" support and update the device-tree- bindings doc.
<snip>
Kindly rebase this series on top of https://gitlab.denx.de/u-boot/custodians/u-boot-mpc85xx branch:next
Regards Priyanka
Hi Priyanka,
Thanks a lot for your comments!
-----Original Message----- From: Priyanka Jain (OSS) Sent: 2020年6月3日 14:53 To: Z.q. Hou zhiqiang.hou@nxp.com; u-boot@lists.denx.de; bmeng.cn@gmail.com; olteanv@gmail.com Cc: Z.q. Hou zhiqiang.hou@nxp.com Subject: RE: [PATCH 01/13] net: fsl_pq_mdio: Add the compatible "fsl, gianfar-mdio" support
<snip>
Yes, I'll.
Thanks, Zhiqiang
Regards Priyanka
Add compatible string "gianfar" support and update the device-tree-bindings doc.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- doc/device-tree-bindings/net/fsl-tsec-phy.txt | 2 +- drivers/net/tsec.c | 16 ++++++++++++++-- include/tsec.h | 4 ++++ 3 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/doc/device-tree-bindings/net/fsl-tsec-phy.txt b/doc/device-tree-bindings/net/fsl-tsec-phy.txt index a709b89a5c..fae6770cbe 100644 --- a/doc/device-tree-bindings/net/fsl-tsec-phy.txt +++ b/doc/device-tree-bindings/net/fsl-tsec-phy.txt @@ -2,7 +2,7 @@
Properties:
- - compatible : Should be "fsl,etsec2" + - compatible : Should be "fsl,etsec2" or "gianfar" - reg : Offset and length of the register set for the device - phy-handle : See ethernet.txt file in the same directory. - phy-connection-type : See ethernet.txt file in the same directory. This diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 93f151a8a6..f7c70bb08d 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -804,11 +804,14 @@ int tsec_probe(struct udevice *dev) struct tsec_private *priv = dev_get_priv(dev); struct ofnode_phandle_args phandle_args; u32 tbiaddr = CONFIG_SYS_TBIPA_VALUE; + struct tsec_data *data; const char *phy_mode; fdt_addr_t reg; ofnode parent; int ret;
+ data = (struct tsec_data *)dev_get_driver_data(dev); + pdata->iobase = (phys_addr_t)dev_read_addr(dev); priv->regs = dev_remap_addr(dev);
@@ -829,7 +832,7 @@ int tsec_probe(struct udevice *dev) return -ENOENT; }
- priv->phyregs_sgmii = map_physmem(reg + TSEC_MDIO_REGS_OFFSET, + priv->phyregs_sgmii = map_physmem(reg + data->mdio_regs_off, 0, MAP_NOCACHE); }
@@ -883,8 +886,17 @@ static const struct eth_ops tsec_ops = { .mcast = tsec_mcast_addr, };
+static struct tsec_data etsec2_data = { + .mdio_regs_off = TSEC_MDIO_REGS_OFFSET, +}; + +static struct tsec_data gianfar_data = { + .mdio_regs_off = 0x0, +}; + static const struct udevice_id tsec_ids[] = { - { .compatible = "fsl,etsec2" }, + { .compatible = "fsl,etsec2", .data = (ulong)&etsec2_data }, + { .compatible = "gianfar", .data = (ulong)&gianfar_data }, { } };
diff --git a/include/tsec.h b/include/tsec.h index b17fa957df..047dd3c373 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -394,6 +394,10 @@ struct tsec {
#define TX_BUF_CNT 2
+struct tsec_data { + u32 mdio_regs_off; +}; + struct tsec_private { struct txbd8 __iomem txbd[TX_BUF_CNT]; struct rxbd8 __iomem rxbd[PKTBUFSRX];
The cpu_eth_init() is only used by the legacy ethernet driver framework.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/cpu/mpc8xxx/cpu.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index ed482a9c09..d41d6a6110 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -345,6 +345,7 @@ int fixup_cpu(void) * Initializes on-chip ethernet controllers. * to override, implement board_eth_init() */ +#ifndef CONFIG_DM_ETH int cpu_eth_init(bd_t *bis) { #if defined(CONFIG_ETHER_ON_FCC) @@ -368,3 +369,4 @@ int cpu_eth_init(bd_t *bis) #endif return 0; } +#endif
Move vsc7835 firmware uploading to board_early_init_r(), so that the switch also can work in DM eTSEC driver.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 35 +++++++++++---------- 1 file changed, 18 insertions(+), 17 deletions(-)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 71fca8ca1e..890abd76b5 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -291,6 +291,10 @@ int board_early_init_r(void) { const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; int flash_esel = find_tlb_idx((void *)flashbase, 1); +#ifdef CONFIG_VSC7385_ENET + unsigned int vscfw_addr; + char *tmp; +#endif
/* * Remap Boot flash region to caching-inhibited @@ -313,6 +317,20 @@ int board_early_init_r(void) set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, /* tlb, epn, rpn */ MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G,/* perms, wimge */ 0, flash_esel, BOOKE_PAGESZ_64M, 1);/* ts, esel, tsize, iprot */ + +#ifdef CONFIG_VSC7385_ENET + /* If a VSC7385 microcode image is present, then upload it. */ + tmp = env_get("vscfw_addr"); + if (tmp) { + vscfw_addr = simple_strtoul(tmp, NULL, 16); + printf("uploading VSC7385 microcode from %x\n", vscfw_addr); + if (vsc7385_upload_firmware((void *)vscfw_addr, + CONFIG_VSC7385_IMAGE_SIZE)) + puts("Failure uploading VSC7385 microcode.\n"); + } else { + puts("No address specified for VSC7385 microcode.\n"); + } +#endif return 0; }
@@ -323,10 +341,6 @@ int board_eth_init(bd_t *bis) ccsr_gur_t *gur __attribute__((unused)) = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); int num = 0; -#ifdef CONFIG_VSC7385_ENET - char *tmp; - unsigned int vscfw_addr; -#endif
#ifdef CONFIG_TSEC1 SET_STD_TSEC_INFO(tsec_info[num], 1); @@ -350,19 +364,6 @@ int board_eth_init(bd_t *bis) return 0; }
-#ifdef CONFIG_VSC7385_ENET - /* If a VSC7385 microcode image is present, then upload it. */ - tmp = env_get("vscfw_addr"); - if (tmp) { - vscfw_addr = simple_strtoul(tmp, NULL, 16); - printf("uploading VSC7385 microcode from %x\n", vscfw_addr); - if (vsc7385_upload_firmware((void *) vscfw_addr, - CONFIG_VSC7385_IMAGE_SIZE)) - puts("Failure uploading VSC7385 microcode.\n"); - } else - puts("No address specified for VSC7385 microcode.\n"); -#endif - mdio_info.regs = TSEC_GET_MDIO_REGS_BASE(1); mdio_info.name = DEFAULT_MII_NAME;
Add the environment 'vscfw_addr' to assign a default address for vsc7385 firmware uploading.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/p1_p2_rdb_pc.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index c42f1a9fce..b2fdf47104 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -460,6 +460,7 @@
/* Vsc7385 switch */ #ifdef CONFIG_VSC7385_ENET +#define __VSCFW_ADDR "vscfw_addr=ef000000" #define CONFIG_SYS_VSC7385_BASE 0xffb00000
#ifdef CONFIG_PHYS_64BIT @@ -813,6 +814,7 @@ i2c mw 18 3 __SW_BOOT_MASK 1; reset "ramdisk_size=120000\0" \ "map_lowernorbank=i2c dev 1; i2c mw 18 1 02 1; i2c mw 18 3 fd 1\0" \ "map_uppernorbank=i2c dev 1; i2c mw 18 1 00 1; i2c mw 18 3 fd 1\0" \ +__stringify(__VSCFW_ADDR)"\0" \ __stringify(__NOR_RST_CMD)"\0" \ __stringify(__SPI_RST_CMD)"\0" \ __stringify(__SD_RST_CMD)"\0" \
P1020RDB implements 3 enhanced three-speed Ethernet controllers, and the connection is shown below: eTSEC1: Connected to RGMII PHY VSC7385 eTSEC2: Connected to SGMII PHY VSC8221 eTSEC3: Connected to SGMII PHY AR8021
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p1020-post.dtsi | 15 +++++++ arch/powerpc/dts/p1020rdb-pc.dts | 1 + arch/powerpc/dts/p1020rdb-pc.dtsi | 55 ++++++++++++++++++++++++ arch/powerpc/dts/p1020rdb-pc_36b.dts | 1 + arch/powerpc/dts/p1020rdb-pd.dts | 57 +++++++++++++++++++++++++ arch/powerpc/dts/pq3-etsec2-0.dtsi | 35 +++++++++++++++ arch/powerpc/dts/pq3-etsec2-1.dtsi | 35 +++++++++++++++ arch/powerpc/dts/pq3-etsec2-2.dtsi | 35 +++++++++++++++ arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi | 16 +++++++ arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi | 16 +++++++ arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi | 16 +++++++ 11 files changed, 282 insertions(+) create mode 100644 arch/powerpc/dts/p1020rdb-pc.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-2.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi
diff --git a/arch/powerpc/dts/p1020-post.dtsi b/arch/powerpc/dts/p1020-post.dtsi index 1c77702f01..d7b10a9ae9 100644 --- a/arch/powerpc/dts/p1020-post.dtsi +++ b/arch/powerpc/dts/p1020-post.dtsi @@ -44,8 +44,23 @@ clock-frequency = <0>; };
+/include/ "pq3-etsec2-0.dtsi" + enet0: enet0_grp2: ethernet@b0000 { + }; + +/include/ "pq3-etsec2-1.dtsi" + enet1: enet1_grp2: ethernet@b1000 { + }; + +/include/ "pq3-etsec2-2.dtsi" + enet2: enet2_grp2: ethernet@b2000 { + }; };
+/include/ "pq3-etsec2-grp2-0.dtsi" +/include/ "pq3-etsec2-grp2-1.dtsi" +/include/ "pq3-etsec2-grp2-2.dtsi" + /* PCIe controller base address 0x9000 */ &pci1 { compatible = "fsl,pcie-p1_p2", "fsl,pcie-fsl-qoriq"; diff --git a/arch/powerpc/dts/p1020rdb-pc.dts b/arch/powerpc/dts/p1020rdb-pc.dts index 7ebaa619df..715330dc50 100644 --- a/arch/powerpc/dts/p1020rdb-pc.dts +++ b/arch/powerpc/dts/p1020rdb-pc.dts @@ -32,4 +32,5 @@ }; };
+/include/ "p1020rdb-pc.dtsi" /include/ "p1020-post.dtsi" diff --git a/arch/powerpc/dts/p1020rdb-pc.dtsi b/arch/powerpc/dts/p1020rdb-pc.dtsi new file mode 100644 index 0000000000..6bf424fd3f --- /dev/null +++ b/arch/powerpc/dts/p1020rdb-pc.dtsi @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * P1020 RDB-PC Device Tree Source stub (no addresses or top-level ranges) + * + * Copyright 2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&soc { + mdio@24000 { + phy0: ethernet-phy@0 { + interrupt-parent = <&mpic>; + interrupts = <3 1 0 0>; + reg = <0x0>; + }; + + phy1: ethernet-phy@1 { + interrupt-parent = <&mpic>; + interrupts = <2 1 0 0>; + reg = <0x1>; + }; + + tbi0: tbi-phy@11 { + device_type = "tbi-phy"; + reg = <0x11>; + }; + }; + + mdio@25000 { + tbi1: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + enet0: ethernet@b0000 { + phy-connection-type = "rgmii-id"; + fixed-link { + speed = <1000>; + full-duplex; + }; + + }; + + enet1: ethernet@b1000 { + phy-handle = <&phy0>; + tbi-handle = <&tbi1>; + phy-connection-type = "sgmii"; + }; + + enet2: ethernet@b2000 { + phy-handle = <&phy1>; + phy-connection-type = "rgmii-id"; + }; +}; diff --git a/arch/powerpc/dts/p1020rdb-pc_36b.dts b/arch/powerpc/dts/p1020rdb-pc_36b.dts index c0e5ef4cf4..7680b7c7e1 100644 --- a/arch/powerpc/dts/p1020rdb-pc_36b.dts +++ b/arch/powerpc/dts/p1020rdb-pc_36b.dts @@ -32,4 +32,5 @@ }; };
+/include/ "p1020rdb-pc.dtsi" /include/ "p1020-post.dtsi" diff --git a/arch/powerpc/dts/p1020rdb-pd.dts b/arch/powerpc/dts/p1020rdb-pd.dts index 21174a09be..7868c9b95c 100644 --- a/arch/powerpc/dts/p1020rdb-pd.dts +++ b/arch/powerpc/dts/p1020rdb-pd.dts @@ -17,6 +17,63 @@
soc: soc@ffe00000 { ranges = <0x0 0x0 0xffe00000 0x100000>; + + mdio@24000 { + phy0: ethernet-phy@0 { + interrupts = <3 1 0 0>; + reg = <0x0>; + }; + + phy1: ethernet-phy@1 { + interrupts = <2 1 0 0>; + reg = <0x1>; + }; + }; + + mdio@25000 { + tbi1: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + mdio@26000 { + tbi2: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + ptp_clock@b0e00 { + compatible = "fsl,etsec-ptp"; + reg = <0xb0e00 0xb0>; + interrupts = <68 2 0 0 69 2 0 0>; + fsl,tclk-period = <10>; + fsl,tmr-prsc = <2>; + fsl,tmr-add = <0x80000016>; + fsl,tmr-fiper1 = <999999990>; + fsl,tmr-fiper2 = <99990>; + fsl,max-adj = <199999999>; + }; + + enet0: ethernet@b0000 { + phy-connection-type = "rgmii-id"; + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + + enet1: ethernet@b1000 { + phy-handle = <&phy0>; + tbi-handle = <&tbi1>; + phy-connection-type = "sgmii"; + }; + + enet2: ethernet@b2000 { + phy-handle = <&phy1>; + phy-connection-type = "rgmii-id"; + }; };
pci1: pcie@ffe09000 { diff --git a/arch/powerpc/dts/pq3-etsec2-0.dtsi b/arch/powerpc/dts/pq3-etsec2-0.dtsi new file mode 100644 index 0000000000..f9d3d04650 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-0.dtsi @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 device tree stub [ @ offsets 0x24000/0xb0000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +mdio@24000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,etsec2-mdio"; + reg = <0x24000 0x1000 0xb0030 0x4>; +}; + +ethernet@b0000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "fsl,etsec2"; + reg = <0xb0000 0x1000>; + fsl,num_rx_queues = <0x8>; + fsl,num_tx_queues = <0x8>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + ranges; + + queue-group@b0000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb0000 0x1000>; + interrupts = <29 2 0 0 30 2 0 0 34 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-1.dtsi b/arch/powerpc/dts/pq3-etsec2-1.dtsi new file mode 100644 index 0000000000..6c01481909 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-1.dtsi @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 device tree stub [ @ offsets 0x25000/0xb1000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +mdio@25000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,etsec2-tbi"; + reg = <0x25000 0x1000 0xb1030 0x4>; +}; + +ethernet@b1000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "fsl,etsec2"; + reg = <0xb1000 0x1000>; + fsl,num_rx_queues = <0x8>; + fsl,num_tx_queues = <0x8>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + ranges; + + queue-group@b1000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb1000 0x1000>; + interrupts = <35 2 0 0 36 2 0 0 40 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-2.dtsi b/arch/powerpc/dts/pq3-etsec2-2.dtsi new file mode 100644 index 0000000000..2a597c0db6 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-2.dtsi @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 device tree stub [ @ offsets 0x26000/0xb2000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +mdio@26000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,etsec2-tbi"; + reg = <0x26000 0x1000 0xb1030 0x4>; +}; + +ethernet@b2000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "fsl,etsec2"; + reg = <0xb2000 0x1000>; + fsl,num_rx_queues = <0x8>; + fsl,num_tx_queues = <0x8>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + ranges; + + queue-group@b2000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb2000 0x1000>; + interrupts = <31 2 0 0 32 2 0 0 33 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi b/arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi new file mode 100644 index 0000000000..16752a7c45 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 Group 2 device tree stub [ @ offsets 0xb4000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&enet0_grp2 { + queue-group@b4000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb4000 0x1000>; + interrupts = <17 2 0 0 18 2 0 0 24 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi b/arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi new file mode 100644 index 0000000000..0464938424 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 Group 2 device tree stub [ @ offsets 0xb5000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&enet1_grp2 { + queue-group@b5000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb5000 0x1000>; + interrupts = <51 2 0 0 52 2 0 0 67 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi b/arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi new file mode 100644 index 0000000000..fe8003c44a --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 Group 2 device tree stub [ @ offsets 0xb6000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&enet2_grp2 { + queue-group@b6000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb6000 0x1000>; + interrupts = <25 2 0 0 26 2 0 0 27 2 0 0>; + }; +};
The board_eth_init() is only used by legacy ethernet driver framework, so do not compile it when DM_ETH config has been selected.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 890abd76b5..5349df5910 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -334,6 +334,7 @@ int board_early_init_r(void) return 0; }
+#ifndef CONFIG_DM_ETH int board_eth_init(bd_t *bis) { struct fsl_pq_mdio_info mdio_info; @@ -381,6 +382,7 @@ int board_eth_init(bd_t *bis)
return pci_eth_init(bis); } +#endif
#if defined(CONFIG_QE) && \ (defined(CONFIG_TARGET_P1025RDB) || defined(CONFIG_TARGET_P1021RDB))
Enable the DM_ETH and DM_MDIO config.
On P1020RDB, the eTSEC1 is connecting with a switch VSC7385, so also enable the fixed PHY support.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P1020RDB-PC_36BIT_NAND_defconfig | 3 +++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 3 +++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 3 +++ configs/P1020RDB-PC_36BIT_defconfig | 3 +++ configs/P1020RDB-PC_NAND_defconfig | 3 +++ configs/P1020RDB-PC_SDCARD_defconfig | 3 +++ configs/P1020RDB-PC_SPIFLASH_defconfig | 3 +++ configs/P1020RDB-PC_defconfig | 3 +++ configs/P1020RDB-PD_NAND_defconfig | 3 +++ configs/P1020RDB-PD_SDCARD_defconfig | 3 +++ configs/P1020RDB-PD_SPIFLASH_defconfig | 3 +++ configs/P1020RDB-PD_defconfig | 3 +++ 12 files changed, 36 insertions(+)
diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 2396d91011..847dad4072 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -61,6 +61,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -72,8 +73,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 745200da51..a3f8761c9b 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -56,6 +56,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -67,8 +68,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 3eadd3d83c..da3e2b3563 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -58,6 +58,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -69,8 +70,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 9b7901f5c3..5c6281ef11 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -45,6 +45,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -56,8 +57,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index e99709a2b8..78948e4a06 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -60,6 +60,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -71,8 +72,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index ef007e5fe4..0518083cd9 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -55,6 +55,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -66,8 +67,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index c8b0923cb5..284ef2c55a 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -57,6 +57,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -68,8 +69,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 1a30c97f7f..a3a4979f45 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -44,6 +44,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -55,8 +56,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index e1858e4cac..d3b7a5e23c 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -64,6 +64,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -75,8 +76,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index e24c89f726..3f28607428 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -59,6 +59,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -70,8 +71,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index c89201f978..e9fa7b8d2f 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -61,6 +61,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -72,8 +73,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index c79d599b60..856ee4f7d0 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -59,8 +60,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y
P1010RDB implements 3 enhanced three-speed Ethernet controllers, and the connection is shown below: eTSEC1: Connected to RGMII PHY AR8033 eTSEC2: Connected to SGMII PHY AR8033 eTSEC3: Connected to SGMII PHY AR8033
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p1010rdb-pa.dts | 1 + arch/powerpc/dts/p1010rdb-pa_36b.dts | 1 + arch/powerpc/dts/p1010rdb-pb.dts | 1 + arch/powerpc/dts/p1010rdb-pb_36b.dts | 1 + arch/powerpc/dts/p1010rdb.dtsi | 71 ++++++++++++++++++++++++++++ arch/powerpc/dts/p1010si-post.dtsi | 25 ++++++++++ 6 files changed, 100 insertions(+) create mode 100644 arch/powerpc/dts/p1010rdb.dtsi
diff --git a/arch/powerpc/dts/p1010rdb-pa.dts b/arch/powerpc/dts/p1010rdb-pa.dts index c66c4923ac..d46080d3ba 100644 --- a/arch/powerpc/dts/p1010rdb-pa.dts +++ b/arch/powerpc/dts/p1010rdb-pa.dts @@ -14,4 +14,5 @@ /include/ "p1010rdb_32b.dtsi" };
+/include/ "p1010rdb.dtsi" /include/ "p1010si-post.dtsi" diff --git a/arch/powerpc/dts/p1010rdb-pa_36b.dts b/arch/powerpc/dts/p1010rdb-pa_36b.dts index b943de7cbb..b9df5d46b2 100644 --- a/arch/powerpc/dts/p1010rdb-pa_36b.dts +++ b/arch/powerpc/dts/p1010rdb-pa_36b.dts @@ -14,4 +14,5 @@ /include/ "p1010rdb_36b.dtsi" };
+/include/ "p1010rdb.dtsi" /include/ "p1010si-post.dtsi" diff --git a/arch/powerpc/dts/p1010rdb-pb.dts b/arch/powerpc/dts/p1010rdb-pb.dts index 2675d5d92b..65deabd288 100644 --- a/arch/powerpc/dts/p1010rdb-pb.dts +++ b/arch/powerpc/dts/p1010rdb-pb.dts @@ -14,4 +14,5 @@ /include/ "p1010rdb_32b.dtsi" };
+/include/ "p1010rdb.dtsi" /include/ "p1010si-post.dtsi" diff --git a/arch/powerpc/dts/p1010rdb-pb_36b.dts b/arch/powerpc/dts/p1010rdb-pb_36b.dts index 45ccf91c41..1ba65a9f22 100644 --- a/arch/powerpc/dts/p1010rdb-pb_36b.dts +++ b/arch/powerpc/dts/p1010rdb-pb_36b.dts @@ -14,4 +14,5 @@ /include/ "p1010rdb_36b.dtsi" };
+/include/ "p1010rdb.dtsi" /include/ "p1010si-post.dtsi" diff --git a/arch/powerpc/dts/p1010rdb.dtsi b/arch/powerpc/dts/p1010rdb.dtsi new file mode 100644 index 0000000000..2040465bf4 --- /dev/null +++ b/arch/powerpc/dts/p1010rdb.dtsi @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * P1010 RDB Device Tree Source stub (no addresses or top-level ranges) + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&soc { + mdio@24000 { + phy0: ethernet-phy@0 { + reg = <0x1>; + }; + + phy1: ethernet-phy@1 { + reg = <0x0>; + }; + + phy2: ethernet-phy@2 { + reg = <0x2>; + }; + + tbi-phy@3 { + device_type = "tbi-phy"; + reg = <0x3>; + }; + }; + + mdio@25000 { + tbi0: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + mdio@26000 { + tbi1: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + ptp_clock@b0e00 { + compatible = "fsl,etsec-ptp"; + reg = <0xb0e00 0xb0>; + interrupts = <68 2 0 0 69 2 0 0>; + fsl,tclk-period = <10>; + fsl,tmr-prsc = <2>; + fsl,tmr-add = <0x80000016>; + fsl,tmr-fiper1 = <999999990>; + fsl,tmr-fiper2 = <99990>; + fsl,max-adj = <199999999>; + }; + + enet0: ethernet@b0000 { + phy-handle = <&phy0>; + phy-connection-type = "rgmii-id"; + }; + + enet1: ethernet@b1000 { + phy-handle = <&phy1>; + tbi-handle = <&tbi0>; + phy-connection-type = "sgmii"; + }; + + enet2: ethernet@b2000 { + phy-handle = <&phy2>; + tbi-handle = <&tbi1>; + phy-connection-type = "sgmii"; + }; +}; diff --git a/arch/powerpc/dts/p1010si-post.dtsi b/arch/powerpc/dts/p1010si-post.dtsi index e24b5e4063..10de94a2e6 100644 --- a/arch/powerpc/dts/p1010si-post.dtsi +++ b/arch/powerpc/dts/p1010si-post.dtsi @@ -23,6 +23,31 @@ single-cpu-affinity; last-interrupt-source = <255>; }; + +/include/ "pq3-etsec2-0.dtsi" + enet0: ethernet@b0000 { + queue-group@b0000 { + fsl,rx-bit-map = <0xff>; + fsl,tx-bit-map = <0xff>; + }; + }; + +/include/ "pq3-etsec2-1.dtsi" + enet1: ethernet@b1000 { + queue-group@b1000 { + fsl,rx-bit-map = <0xff>; + fsl,tx-bit-map = <0xff>; + }; + }; + +/include/ "pq3-etsec2-2.dtsi" + enet2: ethernet@b2000 { + queue-group@b2000 { + fsl,rx-bit-map = <0xff>; + fsl,tx-bit-map = <0xff>; + }; + + }; };
/* controller at 0x9000 */
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- board/freescale/p1010rdb/p1010rdb.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 5057eac38a..8b51d0cd75 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -327,6 +327,7 @@ int checkboard(void) return 0; }
+#ifndef CONFIG_DM_ETH int board_eth_init(bd_t *bis) { #ifdef CONFIG_TSEC_ENET @@ -367,6 +368,7 @@ int board_eth_init(bd_t *bis)
#if defined(CONFIG_OF_BOARD_SETUP) void fdt_del_flexcan(void *blob)
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PA_NAND_defconfig | 2 ++ configs/P1010RDB-PA_NOR_defconfig | 2 ++ configs/P1010RDB-PA_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NOR_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_NAND_defconfig | 2 ++ configs/P1010RDB-PB_NOR_defconfig | 2 ++ configs/P1010RDB-PB_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_SPIFLASH_defconfig | 2 ++ 16 files changed, 32 insertions(+)
diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 83de3cee2c..f597a935e0 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -71,12 +71,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 7c1a3c8ee6..2817950cbd 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -53,12 +53,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 1de064ca8d..2db103da54 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -65,12 +65,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index d23d42a8b0..b618235f03 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -67,12 +67,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index a218d143f5..375e7cf94c 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -70,12 +70,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index f1e6553030..002f9ce208 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -52,12 +52,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index 554e26febf..901e0ea794 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -64,12 +64,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 6211977901..4dbde0edfa 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -66,12 +66,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 294d344d6e..18b693a7ff 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -71,12 +71,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index bf0ae9c6c6..b12ff0e69a 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -53,12 +53,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 458cfb77f5..0439ee1859 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -65,12 +65,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 39a09746ec..9580ae6a38 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -67,12 +67,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 4219adf122..57cfb7311a 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -74,8 +74,10 @@ CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 0028017bce..cbb543d370 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -56,8 +56,10 @@ CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 69f174c84a..6ccda62029 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -64,12 +64,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 44525f452c..58686b288e 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -66,12 +66,14 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_DM=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y
P2020RDB implements 3 enhanced three-speed Ethernet controllers, and the connection is shown below: eTSEC1: Connected to RGMII PHY VSC7385 eTSEC2: Connected to SGMII PHY VSC8221 eTSEC3: Connected to SGMII PHY AR8021
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/powerpc/dts/p2020-post.dtsi | 10 ++++ arch/powerpc/dts/p2020rdb-pc.dts | 1 + arch/powerpc/dts/p2020rdb-pc.dtsi | 59 ++++++++++++++++++++++++ arch/powerpc/dts/p2020rdb-pc_36b.dts | 1 + arch/powerpc/dts/pq3-etsec1-0.dtsi | 28 +++++++++++ arch/powerpc/dts/pq3-etsec1-1.dtsi | 28 +++++++++++ arch/powerpc/dts/pq3-etsec1-2.dtsi | 28 +++++++++++ arch/powerpc/dts/pq3-etsec1-3.dtsi | 28 +++++++++++ arch/powerpc/dts/pq3-etsec1-timer-0.dtsi | 13 ++++++ 9 files changed, 196 insertions(+) create mode 100644 arch/powerpc/dts/p2020rdb-pc.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-2.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-3.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-timer-0.dtsi
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index 5bbd5c5468..5cdc1655d9 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -37,6 +37,16 @@ /* Filled in by U-Boot */ clock-frequency = <0>; }; + +/include/ "pq3-etsec1-0.dtsi" +/include/ "pq3-etsec1-timer-0.dtsi" + + ptp_clock@24e00 { + interrupts = <68 2 0 0 69 2 0 0 70 2 0 0>; + }; + +/include/ "pq3-etsec1-1.dtsi" +/include/ "pq3-etsec1-2.dtsi" };
/* PCIe controller base address 0x8000 */ diff --git a/arch/powerpc/dts/p2020rdb-pc.dts b/arch/powerpc/dts/p2020rdb-pc.dts index 08befd4c59..f3f6be1080 100644 --- a/arch/powerpc/dts/p2020rdb-pc.dts +++ b/arch/powerpc/dts/p2020rdb-pc.dts @@ -37,4 +37,5 @@ }; };
+/include/ "p2020rdb-pc.dtsi" /include/ "p2020-post.dtsi" diff --git a/arch/powerpc/dts/p2020rdb-pc.dtsi b/arch/powerpc/dts/p2020rdb-pc.dtsi new file mode 100644 index 0000000000..9abd700999 --- /dev/null +++ b/arch/powerpc/dts/p2020rdb-pc.dtsi @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * P2020 RDB-PC Device Tree Source stub (no addresses or top-level ranges) + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&soc { + mdio@24520 { + phy0: ethernet-phy@0 { + interrupts = <3 1 0 0>; + reg = <0x0>; + }; + phy1: ethernet-phy@1 { + interrupts = <2 1 0 0>; + reg = <0x1>; + }; + }; + + mdio@25520 { + tbi0: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + mdio@26520 { + status = "disabled"; + }; + + ptp_clock@24e00 { + fsl,tclk-period = <5>; + fsl,tmr-prsc = <2>; + fsl,tmr-add = <0xaaaaaaab>; + fsl,tmr-fiper1 = <999999995>; + fsl,tmr-fiper2 = <99990>; + fsl,max-adj = <299999999>; + }; + + enet0: ethernet@24000 { + phy-connection-type = "rgmii-id"; + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + + enet1: ethernet@25000 { + tbi-handle = <&tbi0>; + phy-handle = <&phy0>; + phy-connection-type = "sgmii"; + }; + + enet2: ethernet@26000 { + phy-handle = <&phy1>; + phy-connection-type = "rgmii-id"; + }; +}; diff --git a/arch/powerpc/dts/p2020rdb-pc_36b.dts b/arch/powerpc/dts/p2020rdb-pc_36b.dts index 04b2519e1a..6d983b7d71 100644 --- a/arch/powerpc/dts/p2020rdb-pc_36b.dts +++ b/arch/powerpc/dts/p2020rdb-pc_36b.dts @@ -37,4 +37,5 @@ }; };
+/include/ "p2020rdb-pc.dtsi" /include/ "p2020-post.dtsi" diff --git a/arch/powerpc/dts/pq3-etsec1-0.dtsi b/arch/powerpc/dts/pq3-etsec1-0.dtsi new file mode 100644 index 0000000000..8800243f34 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-0.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC device tree stub [ @ offsets 0x24000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ethernet@24000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <0>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar"; + reg = <0x24000 0x1000>; + ranges = <0x0 0x24000 0x1000>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <29 2 0 0 30 2 0 0 34 2 0 0>; +}; + +mdio@24520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-mdio"; + reg = <0x24520 0x20>; +}; diff --git a/arch/powerpc/dts/pq3-etsec1-1.dtsi b/arch/powerpc/dts/pq3-etsec1-1.dtsi new file mode 100644 index 0000000000..2bc62d1a57 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-1.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC device tree stub [ @ offsets 0x25000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ethernet@25000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar"; + reg = <0x25000 0x1000>; + ranges = <0x0 0x25000 0x1000>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <35 2 0 0 36 2 0 0 40 2 0 0>; +}; + +mdio@25520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-tbi"; + reg = <0x25520 0x20>; +}; diff --git a/arch/powerpc/dts/pq3-etsec1-2.dtsi b/arch/powerpc/dts/pq3-etsec1-2.dtsi new file mode 100644 index 0000000000..d45865fe03 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-2.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC device tree stub [ @ offsets 0x26000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ethernet@26000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <2>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar"; + reg = <0x26000 0x1000>; + ranges = <0x0 0x26000 0x1000>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <31 2 0 0 32 2 0 0 33 2 0 0>; +}; + +mdio@26520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-tbi"; + reg = <0x26520 0x20>; +}; diff --git a/arch/powerpc/dts/pq3-etsec1-3.dtsi b/arch/powerpc/dts/pq3-etsec1-3.dtsi new file mode 100644 index 0000000000..853a27359d --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-3.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC device tree stub [ @ offsets 0x27000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ethernet@27000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <3>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar"; + reg = <0x27000 0x1000>; + ranges = <0x0 0x27000 0x1000>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <37 2 0 0 38 2 0 0 39 2 0 0>; +}; + +mdio@27520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-tbi"; + reg = <0x27520 0x20>; +}; diff --git a/arch/powerpc/dts/pq3-etsec1-timer-0.dtsi b/arch/powerpc/dts/pq3-etsec1-timer-0.dtsi new file mode 100644 index 0000000000..19b37aca1d --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-timer-0.dtsi @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC Timer (IEEE 1588) device tree stub [ @ offsets 0x24e00 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ptp_clock@24e00 { + compatible = "fsl,etsec-ptp"; + reg = <0x24e00 0xb0>; + interrupts = <68 2 0 0 69 2 0 0>; +};
On P2020RDB, the eTSEC1 is connecting with a switch VSC7385, so also enable the fixed PHY support.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- configs/P2020RDB-PC_36BIT_NAND_defconfig | 3 +++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 3 +++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 3 +++ configs/P2020RDB-PC_36BIT_defconfig | 3 +++ configs/P2020RDB-PC_NAND_defconfig | 3 +++ configs/P2020RDB-PC_SDCARD_defconfig | 3 +++ configs/P2020RDB-PC_SPIFLASH_defconfig | 3 +++ configs/P2020RDB-PC_defconfig | 3 +++ 8 files changed, 24 insertions(+)
diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index b419367e7e..85b08c6769 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -77,8 +78,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 0afddc2ed9..c4aa0abbfd 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -61,6 +61,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -72,8 +73,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 1a700a867f..d191a6010c 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -63,6 +63,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -74,8 +75,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 8b98cb8b9a..dc8a05c2d1 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -50,6 +50,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -61,8 +62,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index b1a26af0f4..f462f23355 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -65,6 +65,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -76,8 +77,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index c76958e1f3..1cf317297f 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -60,6 +60,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -71,8 +72,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 0892596fd6..c5e027959a 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -62,6 +62,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -73,8 +74,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index e37ca66d1f..3a5fc8733e 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -49,6 +49,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -60,8 +61,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y
Priyanka Jain (OSS)
Z.q. Hou
Zhiqiang Hou
