[PATCH] cmd: part: number: remove inconsistent 0x from returned value
From: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com
The part number sub-command returns the hexadecimal value with a leading 0x. This is inconsistent with other values in the command and U-Boot uses hexadecimal values generally.
Signed-off-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com
cmd/part.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/part.c b/cmd/part.c index 3395c17b89..56e1852c66 100644 --- a/cmd/part.c +++ b/cmd/part.c @@ -152,7 +152,7 @@ static int do_part_info(int argc, char *const argv[], enum cmd_part_info param) snprintf(buf, sizeof(buf), LBAF, info.size); break; case CMD_PART_INFO_NUMBER: - snprintf(buf, sizeof(buf), "0x%x", part); + snprintf(buf, sizeof(buf), "%x", part); break; default: printf("** Unknown cmd_part_info value: %d\n", param);
Hello Stefan,
That's to make sure that: - users have clear and unequivocal feedback that '10' returned by the command is really HEX 10, not DEC 10. - other U-Boot commands which need to take '0x10' as input will interpret it correctly, regardless of the way these other commands implement ascii-to-integer conversion.
It could be, but it is then better to fix the inconsistency in those commands/sub-commands which add the ambiguity.
The key word is "generally", but not always. Some U-Boot commands will process '10' as HEX 10 and some will process 10 as DEC 10. So, in order to avoid these games, I vote for leaving the 0x in place.
Hi Eugeniu,
Am 05.03.2021 um 12:52 schrieb Eugeniu Rosca:
Hello Stefan,
'Almost all U-Boot commands expect numbers to be entered in hexadecimal input format.' [1]
The filesystem commands use `simple_strtoul(.., 16)` and interpret the value as hexadecimal value.
The 0x suggests that a 10 will be interpreted as decimal value and this isn't true.
Normally you are right but U-Boot by design use hexadecimal values without 0x. The env_set_hex functions doesn't use 0x.
You can avoid it only if you could mark decimal numbers and that is impossible.
@Tom: Does U-Boot still expect numbers to be hexadecimal values?
[1] https://www.denx.de/wiki/DULG/UBootCommandLineInterface
On Fri, 5 Mar 2021 at 07:33, Stefan Herbrechtsmeier stefan.herbrechtsmeier-oss@weidmueller.com wrote:
Hi Eugeniu,
Hello Stefan,
I would be very surprised if 10 means 0d10 in a partition number. I agree that putting a 0x in these values is a dangerous precedent and will just cause confusion. U-Boot uses hex for addresses and most arguments
0d10 is available. People are not used to it though.
Hi Eugeniu,
Hello Stefan,
I am not a fan of this change as well, especially having spent time on some platforms that have literally 20+ partition entries. Being clear here that this is a hex value is important.
Am 06.03.2021 um 21:12 schrieb Tom Rini:
Hi Eugeniu,
Hello Stefan,
But isn't it confusing to use a 0x for a value which is treated as hexadecimal value by the commands independent of the 0x. The 0x results in the assumption that the partition is a decimal value without the 0x.
What is the correct way to convert a hexadecimal value into a decimal value on the shell? I need a value without prefix (decimal value) to pass it to the root parameter of the bootargs.
At the moment the different default numeral systems of common functions like load and test are very irritating. The load command uses hexadecimal value and doesn't support decimal value. The test command uses decimal value by default but supports hexadecimal values with a prefix. This means that the returned variable filesize of the command load couldn't be checked by test and the user have to use the itest command.
Regards Stefan
Hi Stefan,
On Mon, 8 Mar 2021 at 03:45, Stefan Herbrechtsmeier stefan.herbrechtsmeier-oss@weidmueller.com wrote:
Hi Eugeniu,
Hello Stefan,
Let's use hex where possible. I am not sure what to do with the test command, nor how often we use 'test' with addresses, but I think adding an option to 'test' to make it use hex or dec would be good. Then one day we could change the default to hex.
Hi Simon,
Am 12.03.2021 um 05:45 schrieb Simon Glass:
Hi Stefan,
Hi Eugeniu,
Hello Stefan,
On Fri, Mar 05, 2021 at 07:39:04AM +0000, Stefan Herbrechtsmeier wrote: > From: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com > > The part number sub-command returns the hexadecimal value with a leading > 0x.
> > Signed-off-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com > > --- > > cmd/part.c | 2 +- > 1 file changed, 1 insertion(+), 1 deletion(-) > > diff --git a/cmd/part.c b/cmd/part.c > index 3395c17b89..56e1852c66 100644 > --- a/cmd/part.c > +++ b/cmd/part.c > @@ -152,7 +152,7 @@ static int do_part_info(int argc, char *const argv[], enum cmd_part_info param) > snprintf(buf, sizeof(buf), LBAF, info.size); > break; > case CMD_PART_INFO_NUMBER: > - snprintf(buf, sizeof(buf), "0x%x", part); > + snprintf(buf, sizeof(buf), "%x", part);
But what is the difference to test vs itest?
Is this possible? This would be a breaking change.
I think the main problem is the unclear default numeral system. It would be much easy if every number without a prefix have the same numeral system. This would mean that a `simple_strtoul(.., 0)` would fall back to the default numeral system if the value hasn't any prefix (0x or 0d). At the moment `simple_strtoul(.., 0)` fall back to decimal and many commands use different numeral systems (`simple_strtoul(.., 10)` or `simple_strtoul(.., 16)`).
Independent of this problem I need a command to convert a value to decimal without any prefix. Can you recommend any command or should I add a printf command?
Regards Stefan
Hi Stefan,
On Thu, 11 Mar 2021 at 23:58, Stefan Herbrechtsmeier stefan.herbrechtsmeier-oss@weidmueller.com wrote:
Hi Simon,
Hi Stefan,
Hi Eugeniu,
Am 05.03.2021 um 12:52 schrieb Eugeniu Rosca: > Hello Stefan, > > On Fri, Mar 05, 2021 at 07:39:04AM +0000, Stefan Herbrechtsmeier wrote: >> From: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com >> >> The part number sub-command returns the hexadecimal value with a leading >> 0x. > > That's to make sure that: > - users have clear and unequivocal feedback that '10' > returned by the command is really HEX 10, not DEC 10. > - other U-Boot commands which need to take '0x10' as input > will interpret it correctly, regardless of the way these > other commands implement ascii-to-integer conversion.
>> This is inconsistent with other values in the command > > It could be, but it is then better to fix the inconsistency in those > commands/sub-commands which add the ambiguity.
>> and U-Boot uses hexadecimal values generally. > > The key word is "generally", but not always. Some U-Boot commands will > process '10' as HEX 10 and some will process 10 as DEC 10. So, in order > to avoid these games, I vote for leaving the 0x in place.
>> >> Signed-off-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com >> >> --- >> >> cmd/part.c | 2 +- >> 1 file changed, 1 insertion(+), 1 deletion(-) >> >> diff --git a/cmd/part.c b/cmd/part.c >> index 3395c17b89..56e1852c66 100644 >> --- a/cmd/part.c >> +++ b/cmd/part.c >> @@ -152,7 +152,7 @@ static int do_part_info(int argc, char *const argv[], enum cmd_part_info param) >> snprintf(buf, sizeof(buf), LBAF, info.size); >> break; >> case CMD_PART_INFO_NUMBER: >> - snprintf(buf, sizeof(buf), "0x%x", part); >> + snprintf(buf, sizeof(buf), "%x", part); >
Well at present test uses decimal by default, unfortunately.
I'll see if I can do a patch.
Yes, that seems right to me. The '0' should default to hex.
I don't know of any, so a way to snprintf into an env var seems useful.
Eugeniu Rosca
