[PATCH 13/16] tools: binman: add etype file for u-boot-lzma-img
This patch adds etype u-boot-lzma-img for binman
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- tools/binman/etype/u_boot_lzma_img.py | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+) create mode 100644 tools/binman/etype/u_boot_lzma_img.py
diff --git a/tools/binman/etype/u_boot_lzma_img.py b/tools/binman/etype/u_boot_lzma_img.py new file mode 100644 index 0000000000..2bf3ea97b1 --- /dev/null +++ b/tools/binman/etype/u_boot_lzma_img.py @@ -0,0 +1,27 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for U-Boot binary +# + +from entry import Entry +from blob import Entry_blob + +class Entry_u_boot_lzma_img(Entry_blob): + """U-Boot legacy image with content LZMA compressed + + Properties / Entry arguments: + - filename: Filename of u-boot-lzma.img (default 'u-boot-lzma.img') + + This is the U-Boot binary as a packaged image, in legacy format. It has a + header which allows it to be loaded at the correct address for execution. + + You should use FIT (Flat Image Tree) instead of the legacy image for new + applications. + """ + def __init__(self, section, etype, node): + Entry_blob.__init__(self, section, etype, node) + + def GetDefaultFilename(self): + return 'u-boot-lzma.img'
Hi Weijie,
Can you please run 'binman entry-docs' to update README.entries?
Not anymore!
- """U-Boot legacy image with content LZMA compressed
- Properties / Entry arguments:
- This is the U-Boot binary as a packaged image, in legacy format. It has a
- header which allows it to be loaded at the correct address for execution.
- You should use FIT (Flat Image Tree) instead of the legacy image for new
- applications.
- def __init__(self, section, etype, node):
- def GetDefaultFilename(self):
-- 2.17.1
Weijie Gao
