[U-Boot] [RFC PATCH 05/21] dm: core: Allocate platform data when binding a device
When using allocated platform data, allocate it when we bind the device. This makes it possible to fill in this information before the device is probed.
This fits with the platform data model (when not using device tree), since platform data exists at bind-time.
drivers/core/device-remove.c | 8 ++++---- drivers/core/device.c | 20 ++++++++++++-------- test/dm/test-fdt.c | 4 ++-- 3 files changed, 18 insertions(+), 14 deletions(-)
diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index 8fc6b71..2c82577 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -88,6 +88,10 @@ int device_unbind(struct udevice *dev) if (ret) return ret;
+ if (dev->flags & DM_FLAG_ALLOC_PDATA) { + free(dev->platdata); + dev->platdata = NULL; + } ret = uclass_unbind_device(dev); if (ret) return ret; @@ -111,10 +115,6 @@ void device_free(struct udevice *dev) free(dev->priv); dev->priv = NULL; } - if (dev->flags & DM_FLAG_ALLOC_PDATA) { - free(dev->platdata); - dev->platdata = NULL; - } size = dev->uclass->uc_drv->per_device_auto_alloc_size; if (size) { free(dev->uclass_priv); diff --git a/drivers/core/device.c b/drivers/core/device.c index eca8eda..23ee771 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -72,8 +72,14 @@ int device_bind(struct udevice *parent, struct driver *drv, const char *name, #else dev->req_seq = -1; #endif - if (!dev->platdata && drv->platdata_auto_alloc_size) + if (!dev->platdata && drv->platdata_auto_alloc_size) { dev->flags |= DM_FLAG_ALLOC_PDATA; + dev->platdata = calloc(1, drv->platdata_auto_alloc_size); + if (!dev->platdata) { + ret = -ENOMEM; + goto fail_alloc1; + } + }
/* put dev into parent's successor list */ if (parent) @@ -103,6 +109,11 @@ fail_bind: fail_uclass_bind: if (parent) list_del(&dev->sibling_node); + if (dev->flags & DM_FLAG_ALLOC_PDATA) { + free(dev->platdata); + dev->platdata = NULL; + } +fail_alloc1: free(dev);
return ret; @@ -148,13 +159,6 @@ int device_probe_child(struct udevice *dev, void *parent_priv) } } /* Allocate private data if requested */ - if (dev->flags & DM_FLAG_ALLOC_PDATA) { - dev->platdata = calloc(1, drv->platdata_auto_alloc_size); - if (!dev->platdata) { - ret = -ENOMEM; - goto fail; - } - } size = dev->uclass->uc_drv->per_device_auto_alloc_size; if (size) { dev->uclass_priv = calloc(1, size); diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index cd2c389..dc4ebf9 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -143,12 +143,12 @@ static int dm_test_fdt(struct dm_test_state *dms) /* These are num_devices compatible root-level device tree nodes */ ut_asserteq(num_devices, list_count_items(&uc->dev_head));
- /* Each should have no platdata / priv */ + /* Each should have platform data but no private data */ for (i = 0; i < num_devices; i++) { ret = uclass_find_device(UCLASS_TEST_FDT, i, &dev); ut_assert(!ret); ut_assert(!dev_get_priv(dev)); - ut_assert(!dev->platdata); + ut_assert(dev->platdata); }
ut_assertok(dm_check_devices(dms, num_devices));
