[U-Boot] [PATCH v7 0/13] Enable driver model for GPIOs on Tegra and Exynos
Now that driver model is part of U-Boot, the task of converting drivers over to it begins. GPIO is one of the easiest to convert, since it already has a sandbox driver and a uclass driver.
The Tegra GPIO driver is relatively simple since it has a linear numbering and already uses the generic GPIO framework. Each GPIO bank has a separate device. Some arguments have been made that a single device should support all the GPIO banks, but currently the driver model uclass does not work that way and it would require a second-level data structure to handle the bank feature.
This driver has been tested on:
- Seaboard (Tegra 20) - Beaver (Tegra 30) - Jetson-TK1 (Tegra 124).
I don't have a Tegra 114 board (Dalmore seems to be the only one with U-Boot support) but I am quite confident that it works.
For exynos, the pinctrl device tree files are brought in from the kernel and cut down to remove the groupings which we don't yet use. Very small additions are made to avoid replicating the awful tables that Linux has for every exynos SoC. This series sits on top of the exynos refactors.
The 'gpio' command is updated to support display of only the allocated GPIOs. This is much more friendly than displaying a large table.
A few related clean-ups are provided as well.
This series is available at u-boot-dm.git, branch working.
Changes in v7: - Add new patch to init driver model before board_early_init_f() - Add new patch to enable pre-reloc malloc() for tegra - Set up pin config in tegra_spl_gpio_direction_output() - Bring in patches from the SPI series to move post-reloc DM init earlier
Changes in v6: - Use base_gpio instead of base_port for simplicity - Add an implementation of the get_function() method - Fix typo in compatible string - Remove exynos5420.dtsi which is not used in U-Boot - Move U-Boot changes into their own file - Use exynos54xx everywhere instead of exynos5420
Changes in v5: - Put this patch before the others to avoid breaking bisectability - Add additional gpio_request() calls for other samsung boards - Use a mask instead of division in gpio_request() naming call - Remove RFC label now that build errors are fixed - Tidy up and update cover letter message - Avoid reordering functions
Changes in v4: - Rename struct device to struct udevice - Add patches for exynos GPIO support
Changes in v3: - Move dm command enable to previous patch - Use gpio number for the internal helper functions
Changes in v2: - Remove RFC status - Add exynos serial support - Split out core driver model patches into a separate set - Split out driver model changes into separate patches - Correct bugs found during testing
Simon Glass (13): dm: Move pre-reloc init earlier to cope with board_early_init_f() Set up stdio earlier when using driver model dm: Make driver model available before board_init() dm: tegra: Set up a pre-reloc malloc() tegra: Convert tegra GPIO driver to use driver model exynos: dts: Convert /include/ to #include exynos: Bring in pinctrl dts files from Linux kernel exynos: dts: Remove unused pinctrl information to save space exynos: dts: Adjust device tree files for U-Boot exynos: Tidy up GPIO headers exynos: Tidy up GPIO defines exynos: Make sure that GPIOs are requested exynos: gpio: Convert to driver model
arch/arm/cpu/armv7/exynos/pinmux.c | 5 +- arch/arm/dts/exynos4.dtsi | 9 +- arch/arm/dts/exynos4210-origen.dts | 4 +- arch/arm/dts/exynos4210-pinctrl-uboot.dtsi | 27 ++ arch/arm/dts/exynos4210-pinctrl.dtsi | 306 ++++++++++++++++++++ arch/arm/dts/exynos4210-smdkv310.dts | 2 +- arch/arm/dts/exynos4210-trats.dts | 2 +- arch/arm/dts/exynos4210-universal_c210.dts | 2 +- arch/arm/dts/exynos4210.dtsi | 155 ++++++++++ arch/arm/dts/exynos4412-trats2.dts | 2 +- arch/arm/dts/exynos4412.dtsi | 38 +++ arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi | 46 +++ arch/arm/dts/exynos4x12-pinctrl.dtsi | 346 ++++++++++++++++++++++ arch/arm/dts/exynos4x12.dtsi | 114 ++++++++ arch/arm/dts/exynos5.dtsi | 56 +++- arch/arm/dts/exynos5250-pinctrl-uboot.dtsi | 40 +++ arch/arm/dts/exynos5250-pinctrl.dtsi | 333 ++++++++++++++++++++++ arch/arm/dts/exynos5250-smdk5250.dts | 2 +- arch/arm/dts/exynos5250-snow.dts | 2 +- arch/arm/dts/exynos5250.dtsi | 40 ++- arch/arm/dts/exynos5420-peach-pit.dts | 2 +- arch/arm/dts/exynos5420-smdk5420.dts | 2 +- arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi | 52 ++++ arch/arm/dts/exynos54xx-pinctrl.dtsi | 305 ++++++++++++++++++++ arch/arm/dts/exynos54xx.dtsi | 57 +++- arch/arm/dts/s5pc1xx-goni.dts | 2 +- arch/arm/dts/s5pc1xx-smdkc100.dts | 2 +- arch/arm/include/asm/arch-exynos/gpio.h | 5 - arch/arm/include/asm/arch-s5pc1xx/gpio.h | 4 - arch/arm/include/asm/arch-tegra/gpio.h | 15 +- board/nvidia/seaboard/seaboard.c | 2 +- board/samsung/arndale/arndale.c | 4 +- board/samsung/common/board.c | 2 +- board/samsung/common/misc.c | 3 +- board/samsung/goni/goni.c | 4 +- board/samsung/origen/origen.c | 2 +- board/samsung/smdk5250/exynos5-dt.c | 7 + board/samsung/smdk5420/smdk5420.c | 6 +- board/samsung/smdkc100/smdkc100.c | 2 +- board/samsung/smdkv310/smdkv310.c | 2 +- board/samsung/trats/trats.c | 17 +- board/samsung/trats2/trats2.c | 27 +- board/samsung/universal_c210/universal.c | 4 +- common/board_f.c | 4 +- common/board_r.c | 19 +- common/stdio.c | 18 +- drivers/gpio/s5p_gpio.c | 444 +++++++++++++++++++---------- drivers/gpio/tegra_gpio.c | 327 +++++++++++++++++---- drivers/mmc/s5p_sdhci.c | 7 +- include/configs/exynos-common.h | 4 + include/configs/tegra-common.h | 2 + include/stdio_dev.h | 24 +- 52 files changed, 2641 insertions(+), 267 deletions(-) create mode 100644 arch/arm/dts/exynos4210-pinctrl-uboot.dtsi create mode 100644 arch/arm/dts/exynos4210-pinctrl.dtsi create mode 100644 arch/arm/dts/exynos4210.dtsi create mode 100644 arch/arm/dts/exynos4412.dtsi create mode 100644 arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi create mode 100644 arch/arm/dts/exynos4x12-pinctrl.dtsi create mode 100644 arch/arm/dts/exynos4x12.dtsi create mode 100644 arch/arm/dts/exynos5250-pinctrl-uboot.dtsi create mode 100644 arch/arm/dts/exynos5250-pinctrl.dtsi create mode 100644 arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi create mode 100644 arch/arm/dts/exynos54xx-pinctrl.dtsi
In order to support GPIO access in board_early_init_f() we must set up driver model before this function is called. In any case, earlier is better since driver model is (or will become) a key function for most init.
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
common/board_f.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 4ece2b6..ea33ead 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -831,6 +831,8 @@ static init_fnc_t init_sequence_f[] = { #ifdef CONFIG_OF_CONTROL fdtdec_check_fdt, #endif + initf_malloc, + initf_dm, #if defined(CONFIG_BOARD_EARLY_INIT_F) board_early_init_f, #endif @@ -866,8 +868,6 @@ static init_fnc_t init_sequence_f[] = { sdram_adjust_866, init_timebase, #endif - initf_malloc, - initf_dm, init_baud_rate, /* initialze baudrate settings */ serial_init, /* serial communications setup */ console_init_f, /* stage 1 init of console */
Applied to dm/master and now in mainline.
Since driver model registers itself with the stdio subsystem, and we want to avoid delayed registration and other complexity associated with the current serial console, move the stdio subsystem init earlier when driver model is used for serial.
This simplifies the implementation. Should there be any problems with this approach they can be dealt with as boards are converted over to use driver model for serial.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
common/board_r.c | 17 +++++++++++------ 1 file changed, 11 insertions(+), 6 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index f9647e1..64beae5 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -727,6 +727,15 @@ init_fnc_t init_sequence_r[] = { set_cpu_clk_info, /* Setup clock information */ #endif initr_reloc_global_data, + initr_barrier, + initr_malloc, + bootstage_relocate, +#ifdef CONFIG_DM_SERIAL + stdio_init, +#endif +#ifdef CONFIG_DM + initr_dm, +#endif initr_serial, initr_announce, INIT_FUNC_WATCHDOG_RESET @@ -763,12 +772,6 @@ init_fnc_t init_sequence_r[] = { #ifdef CONFIG_WINBOND_83C553 initr_w83c553f, #endif - initr_barrier, - initr_malloc, - bootstage_relocate, -#ifdef CONFIG_DM - initr_dm, -#endif #ifdef CONFIG_ARCH_EARLY_INIT_R arch_early_init_r, #endif @@ -818,7 +821,9 @@ init_fnc_t init_sequence_r[] = { */ initr_pci, #endif +#ifndef CONFIG_DM_SERIAL stdio_init, +#endif initr_jumptable, #ifdef CONFIG_API initr_api,
Applied to u-boot-dm/master and now in mainline.
For some boards board_init() will change GPIOs, so we need to have driver model available before then. Adjust the board init to arrange this, but enable it for driver model only, just to be safe.
This does create additional #ifdef logic, but it is safer than trying to make a pervasive change which may cause some boards to break.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - Remove RFC status - Add exynos serial support - Split out core driver model patches into a separate set
common/board_r.c | 24 +++++++++++------------- common/stdio.c | 18 ++++++++++++++++-- include/stdio_dev.h | 24 +++++++++++++++++++++++- 3 files changed, 50 insertions(+), 16 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index 64beae5..6ac2b7e 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -715,6 +715,15 @@ init_fnc_t init_sequence_r[] = { /* TODO: could x86/PPC have this also perhaps? */ #ifdef CONFIG_ARM initr_caches, +#endif + initr_reloc_global_data, + initr_barrier, + initr_malloc, + bootstage_relocate, +#ifdef CONFIG_DM + initr_dm, +#endif +#ifdef CONFIG_ARM board_init, /* Setup chipselects */ #endif /* @@ -726,16 +735,7 @@ init_fnc_t init_sequence_r[] = { #ifdef CONFIG_CLOCKS set_cpu_clk_info, /* Setup clock information */ #endif - initr_reloc_global_data, - initr_barrier, - initr_malloc, - bootstage_relocate, -#ifdef CONFIG_DM_SERIAL - stdio_init, -#endif -#ifdef CONFIG_DM - initr_dm, -#endif + stdio_init_tables, initr_serial, initr_announce, INIT_FUNC_WATCHDOG_RESET @@ -821,9 +821,7 @@ init_fnc_t init_sequence_r[] = { */ initr_pci, #endif -#ifndef CONFIG_DM_SERIAL - stdio_init, -#endif + stdio_add_devices, initr_jumptable, #ifdef CONFIG_API initr_api, diff --git a/common/stdio.c b/common/stdio.c index 692ca7f..c878103 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -215,7 +215,7 @@ int stdio_deregister(const char *devname) } #endif /* CONFIG_SYS_STDIO_DEREGISTER */
-int stdio_init (void) +int stdio_init_tables(void) { #if defined(CONFIG_NEEDS_MANUAL_RELOC) /* already relocated for current ARM implementation */ @@ -232,6 +232,11 @@ int stdio_init (void) /* Initialize the list */ INIT_LIST_HEAD(&(devs.list));
+ return 0; +} + +int stdio_add_devices(void) +{ #ifdef CONFIG_SYS_I2C i2c_init_all(); #else @@ -265,5 +270,14 @@ int stdio_init (void) #ifdef CONFIG_CBMEM_CONSOLE cbmemc_init(); #endif - return (0); + + return 0; +} + +int stdio_init(void) +{ + stdio_init_tables(); + stdio_add_devices(); + + return 0; } diff --git a/include/stdio_dev.h b/include/stdio_dev.h index a7d0825..268de8e 100644 --- a/include/stdio_dev.h +++ b/include/stdio_dev.h @@ -78,7 +78,29 @@ extern char *stdio_names[MAX_FILES]; */ int stdio_register (struct stdio_dev * dev); int stdio_register_dev(struct stdio_dev *dev, struct stdio_dev **devp); -int stdio_init (void); + +/** + * stdio_init_tables() - set up stdio tables ready for devices + * + * This does not add any devices, but just prepares stdio for use. + */ +int stdio_init_tables(void); + +/** + * stdio_add_devices() - Add stdio devices to the table + * + * This makes calls to all the various subsystems that use stdio, to make + * them register with stdio. + */ +int stdio_add_devices(void); + +/** + * stdio_init() - Sets up stdio ready for use + * + * This calls stdio_init_tables() and stdio_add_devices() + */ +int stdio_init(void); + void stdio_print_current_devices(void); #ifdef CONFIG_SYS_STDIO_DEREGISTER int stdio_deregister(const char *devname);
Allocate 1KB so that driver model can operate before relocation.
Changes in v7: - Add new patch to enable pre-reloc malloc() for tegra
include/configs/tegra-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index d27fceb..7852f9a 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -40,6 +40,7 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (4 << 20) /* 4MB */ +#define CONFIG_SYS_MALLOC_F_LEN (1 << 10)
/* * NS16550 Configuration
This is an implementation of GPIOs for Tegra that uses driver model. It has been tested on trimslice and also using the new iotrace feature.
The implementation uses a top-level GPIO device (which has no actual GPIOS). Under this all the banks are created as separate GPIO devices.
The GPIOs are named as per the Tegra datasheet/header files: A0..A7, B0..B7, ..., Z0..Z7, AA0..AA7, etc.
Since driver model is not yet available before relocation, or in SPL, a special function is provided for seaboard's SPL code.
Changes in v7: - Set up pin config in tegra_spl_gpio_direction_output()
Changes in v5: None Changes in v4: - Rename struct device to struct udevice
Changes in v2: - Split out driver model changes into separate patches - Correct bugs found during testing
arch/arm/include/asm/arch-tegra/gpio.h | 15 +- board/nvidia/seaboard/seaboard.c | 2 +- drivers/gpio/tegra_gpio.c | 327 +++++++++++++++++++++++++++------ include/configs/tegra-common.h | 1 + 4 files changed, 283 insertions(+), 62 deletions(-)
diff --git a/arch/arm/include/asm/arch-tegra/gpio.h b/arch/arm/include/asm/arch-tegra/gpio.h index 44cd455..7334e0c 100644 --- a/arch/arm/include/asm/arch-tegra/gpio.h +++ b/arch/arm/include/asm/arch-tegra/gpio.h @@ -6,6 +6,8 @@ #ifndef _TEGRA_GPIO_H_ #define _TEGRA_GPIO_H_
+#define TEGRA_GPIOS_PER_PORT 8 +#define TEGRA_PORTS_PER_BANK 4 #define MAX_NUM_GPIOS (TEGRA_GPIO_PORTS * TEGRA_GPIO_BANKS * 8) #define GPIO_NAME_SIZE 20 /* gpio_request max label len */
@@ -25,9 +27,14 @@ struct tegra_gpio_config { u32 init:2; };
-/* - * Tegra-specific GPIO API +/** + * tegra_spl_gpio_direction_output() - set the output value of a GPIO + * + * This function is only used from SPL on seaboard, which needs to enable a + * GPIO to get the UART running. It could be done in U-Boot rather than SPL, + * but for now, this gets it working */ +int tegra_spl_gpio_direction_output(int gpio, int value);
/** * Configure a list of GPIOs @@ -37,8 +44,4 @@ struct tegra_gpio_config { */ void gpio_config_table(const struct tegra_gpio_config *config, int len);
-void gpio_info(void); - -#define gpio_status() gpio_info() - #endif /* TEGRA_GPIO_H_ */ diff --git a/board/nvidia/seaboard/seaboard.c b/board/nvidia/seaboard/seaboard.c index ce2db40..6a243f0 100644 --- a/board/nvidia/seaboard/seaboard.c +++ b/board/nvidia/seaboard/seaboard.c @@ -22,7 +22,7 @@ void gpio_early_init_uart(void) #ifndef CONFIG_SPL_BUILD gpio_request(GPIO_PI3, NULL); #endif - gpio_direction_output(GPIO_PI3, 0); + tegra_spl_gpio_direction_output(GPIO_PI3, 0); } #endif
diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index fea9d17..1cc4abb 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -12,10 +12,17 @@ */
#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <errno.h> +#include <fdtdec.h> #include <asm/io.h> #include <asm/bitops.h> #include <asm/arch/tegra.h> #include <asm/gpio.h> +#include <dm/device-internal.h> + +DECLARE_GLOBAL_DATA_PTR;
enum { TEGRA_CMD_INFO, @@ -24,14 +31,18 @@ enum { TEGRA_CMD_INPUT, };
-static struct gpio_names { - char name[GPIO_NAME_SIZE]; -} gpio_names[MAX_NUM_GPIOS]; +struct tegra_gpio_platdata { + struct gpio_ctlr_bank *bank; + const char *port_name; /* Name of port, e.g. "B" */ + int base_gpio; /* Port number for this port (0, 1,.., n-1) */ +};
-static char *get_name(int i) -{ - return *gpio_names[i].name ? gpio_names[i].name : "UNKNOWN"; -} +/* Information about each port at run-time */ +struct tegra_port_info { + char label[TEGRA_GPIOS_PER_PORT][GPIO_NAME_SIZE]; + struct gpio_ctlr_bank *bank; + int base_gpio; /* Port number for this port (0, 1,.., n-1) */ +};
/* Return config of pin 'gpio' as GPIO (1) or SFPIO (0) */ static int get_config(unsigned gpio) @@ -121,38 +132,72 @@ static void set_level(unsigned gpio, int high) writel(u, &bank->gpio_out[GPIO_PORT(gpio)]); }
+static int check_reserved(struct udevice *dev, unsigned offset, + const char *func) +{ + struct tegra_port_info *state = dev_get_priv(dev); + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + + if (!*state->label[offset]) { + printf("tegra_gpio: %s: error: gpio %s%d not reserved\n", + func, uc_priv->bank_name, offset); + return -EBUSY; + } + + return 0; +} + +/* set GPIO pin 'gpio' as an output, with polarity 'value' */ +int tegra_spl_gpio_direction_output(int gpio, int value) +{ + /* Configure as a GPIO */ + set_config(gpio, 1); + + /* Configure GPIO output value. */ + set_level(gpio, value); + + /* Configure GPIO direction as output. */ + set_direction(gpio, 1); + + return 0; +} + /* * Generic_GPIO primitives. */
-int gpio_request(unsigned gpio, const char *label) +static int tegra_gpio_request(struct udevice *dev, unsigned offset, + const char *label) { - if (gpio >= MAX_NUM_GPIOS) - return -1; + struct tegra_port_info *state = dev_get_priv(dev);
- if (label != NULL) { - strncpy(gpio_names[gpio].name, label, GPIO_NAME_SIZE); - gpio_names[gpio].name[GPIO_NAME_SIZE - 1] = '\0'; - } + if (*state->label[offset]) + return -EBUSY; + + strncpy(state->label[offset], label, GPIO_NAME_SIZE); + state->label[offset][GPIO_NAME_SIZE - 1] = '\0';
/* Configure as a GPIO */ - set_config(gpio, 1); + set_config(state->base_gpio + offset, 1);
return 0; }
-int gpio_free(unsigned gpio) +static int tegra_gpio_free(struct udevice *dev, unsigned offset) { - if (gpio >= MAX_NUM_GPIOS) - return -1; + struct tegra_port_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + state->label[offset][0] = '\0';
- gpio_names[gpio].name[0] = '\0'; - /* Do not configure as input or change pin mux here */ return 0; }
/* read GPIO OUT value of pin 'gpio' */ -static int gpio_get_output_value(unsigned gpio) +static int tegra_gpio_get_output_value(unsigned gpio) { struct gpio_ctlr *ctlr = (struct gpio_ctlr *)NV_PA_GPIO_BASE; struct gpio_ctlr_bank *bank = &ctlr->gpio_bank[GPIO_BANK(gpio)]; @@ -166,24 +211,34 @@ static int gpio_get_output_value(unsigned gpio) return (val >> GPIO_BIT(gpio)) & 1; }
+ /* set GPIO pin 'gpio' as an input */ -int gpio_direction_input(unsigned gpio) +static int tegra_gpio_direction_input(struct udevice *dev, unsigned offset) { - debug("gpio_direction_input: pin = %d (port %d:bit %d)\n", - gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio)); + struct tegra_port_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret;
/* Configure GPIO direction as input. */ - set_direction(gpio, 0); + set_direction(state->base_gpio + offset, 0);
return 0; }
/* set GPIO pin 'gpio' as an output, with polarity 'value' */ -int gpio_direction_output(unsigned gpio, int value) +static int tegra_gpio_direction_output(struct udevice *dev, unsigned offset, + int value) { - debug("gpio_direction_output: pin = %d (port %d:bit %d) = %s\n", - gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio), - value ? "HIGH" : "LOW"); + struct tegra_port_info *state = dev_get_priv(dev); + int gpio = state->base_gpio + offset; + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret;
/* Configure GPIO output value. */ set_level(gpio, value); @@ -195,25 +250,38 @@ int gpio_direction_output(unsigned gpio, int value) }
/* read GPIO IN value of pin 'gpio' */ -int gpio_get_value(unsigned gpio) +static int tegra_gpio_get_value(struct udevice *dev, unsigned offset) { - struct gpio_ctlr *ctlr = (struct gpio_ctlr *)NV_PA_GPIO_BASE; - struct gpio_ctlr_bank *bank = &ctlr->gpio_bank[GPIO_BANK(gpio)]; + struct tegra_port_info *state = dev_get_priv(dev); + int gpio = state->base_gpio + offset; + int ret; int val;
- debug("gpio_get_value: pin = %d (port %d:bit %d)\n", - gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio)); + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + + debug("%s: pin = %d (port %d:bit %d)\n", __func__, + gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio));
- val = readl(&bank->gpio_in[GPIO_PORT(gpio)]); + val = readl(&state->bank->gpio_in[GPIO_PORT(gpio)]);
/* write GPIO OUT value to pin 'gpio' */ -int gpio_set_value(unsigned gpio, int value) +static int tegra_gpio_set_value(struct udevice *dev, unsigned offset, int value) { + struct tegra_port_info *state = dev_get_priv(dev); + int gpio = state->base_gpio + offset; + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + debug("gpio_set_value: pin = %d (port %d:bit %d), value = %d\n", - gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio), value); + gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio), value);
/* Configure GPIO output value. */ set_level(gpio, value); @@ -241,26 +309,175 @@ void gpio_config_table(const struct tegra_gpio_config *config, int len) } }
-/* - * Display Tegra GPIO information +static int tegra_gpio_get_function(struct udevice *dev, unsigned offset) +{ + struct tegra_port_info *state = dev_get_priv(dev); + int gpio = state->base_gpio + offset; + + if (!*state->label[offset]) + return GPIOF_UNUSED; + if (!get_config(gpio)) + return GPIOF_FUNC; + else if (get_direction(gpio)) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static int tegra_gpio_get_state(struct udevice *dev, unsigned int offset, + char *buf, int bufsize) +{ + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + struct tegra_port_info *state = dev_get_priv(dev); + int gpio = state->base_gpio + offset; + const char *label; + int is_output; + int is_gpio; + int size; + + label = state->label[offset]; + is_gpio = get_config(gpio); /* GPIO, not SFPIO */ + size = snprintf(buf, bufsize, "%s%d: ", + uc_priv->bank_name ? uc_priv->bank_name : "", offset); + buf += size; + bufsize -= size; + if (is_gpio) { + is_output = get_direction(gpio); + + snprintf(buf, bufsize, "%s: %d [%c]%s%s", + is_output ? "out" : " in", + is_output ? + tegra_gpio_get_output_value(gpio) : + tegra_gpio_get_value(dev, offset), + *label ? 'x' : ' ', + *label ? " " : "", + label); + } else { + snprintf(buf, bufsize, "sfpio"); + } + + return 0; +} + +static const struct dm_gpio_ops gpio_tegra_ops = { + .request = tegra_gpio_request, + .free = tegra_gpio_free, + .direction_input = tegra_gpio_direction_input, + .direction_output = tegra_gpio_direction_output, + .get_value = tegra_gpio_get_value, + .set_value = tegra_gpio_set_value, + .get_function = tegra_gpio_get_function, + .get_state = tegra_gpio_get_state, +}; + +/** + * Returns the name of a GPIO port + * + * GPIOs are named A, B, C, ..., Z, AA, BB, CC, ... + * + * @base_port: Base port number (0, 1..n-1) + * @return allocated string containing the name */ -void gpio_info(void) +static char *gpio_port_name(int base_port) { - unsigned c; - int type; + char *name, *s; + + name = malloc(3); + if (name) { + s = name; + *s++ = 'A' + (base_port % 26); + if (base_port >= 26) + *s++ = *name; + *s = '\0'; + }
- for (c = 0; c < MAX_NUM_GPIOS; c++) { - type = get_config(c); /* GPIO, not SFPIO */ - if (type) { - printf("GPIO_%d:\t%s is an %s, ", c, - get_name(c), - get_direction(c) ? "OUTPUT" : "INPUT"); - if (get_direction(c)) - printf("value = %d", gpio_get_output_value(c)); - else - printf("value = %d", gpio_get_value(c)); - printf("\n"); - } else - continue; + return name; +} + +static const struct udevice_id tegra_gpio_ids[] = { + { .compatible = "nvidia,tegra30-gpio" }, + { .compatible = "nvidia,tegra20-gpio" }, + { } +}; + +static int gpio_tegra_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + struct tegra_port_info *priv = dev->priv; + struct tegra_gpio_platdata *plat = dev->platdata; + + /* Only child devices have ports */ + if (!plat) + return 0; + + priv->bank = plat->bank; + priv->base_gpio = plat->base_gpio; + + uc_priv->gpio_count = TEGRA_GPIOS_PER_PORT; + uc_priv->bank_name = plat->port_name; + + return 0; +} + +/** + * We have a top-level GPIO device with no actual GPIOs. It has a child + * device for each Tegra port. + */ +static int gpio_tegra_bind(struct udevice *parent) +{ + struct tegra_gpio_platdata *plat = parent->platdata; + struct gpio_ctlr *ctlr; + int bank_count; + int bank; + int ret; + int len; + + /* If this is a child device, there is nothing to do here */ + if (plat) + return 0; + + /* + * This driver does not make use of interrupts, other than to figure + * out the number of GPIO banks + */ + if (!fdt_getprop(gd->fdt_blob, parent->of_offset, "interrupts", &len)) + return -EINVAL; + bank_count = len / 3 / sizeof(u32); + ctlr = (struct gpio_ctlr *)fdtdec_get_addr(gd->fdt_blob, + parent->of_offset, "reg"); + for (bank = 0; bank < bank_count; bank++) { + int port; + + for (port = 0; port < TEGRA_PORTS_PER_BANK; port++) { + struct tegra_gpio_platdata *plat; + struct udevice *dev; + int base_port; + + plat = calloc(1, sizeof(*plat)); + if (!plat) + return -ENOMEM; + plat->bank = &ctlr->gpio_bank[bank]; + base_port = bank * TEGRA_PORTS_PER_BANK + port; + plat->base_gpio = TEGRA_GPIOS_PER_PORT * base_port; + plat->port_name = gpio_port_name(base_port); + + ret = device_bind(parent, parent->driver, + plat->port_name, plat, -1, &dev); + if (ret) + return ret; + dev->of_offset = parent->of_offset; + } } + + return 0; } + +U_BOOT_DRIVER(gpio_tegra) = { + .name = "gpio_tegra", + .id = UCLASS_GPIO, + .of_match = tegra_gpio_ids, + .bind = gpio_tegra_bind, + .probe = gpio_tegra_probe, + .priv_auto_alloc_size = sizeof(struct tegra_port_info), + .ops = &gpio_tegra_ops, +}; diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 7852f9a..f1187f1 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -20,6 +20,7 @@
#define CONFIG_DM #define CONFIG_CMD_DM +#define CONFIG_DM_GPIO
#define CONFIG_SYS_TIMER_RATE 1000000 #define CONFIG_SYS_TIMER_COUNTER NV_PA_TMRUS_BASE
I've tested this series as much as I can, and in particular on Tegra 20, 30 and 124. Are there any final comments before I pull it into dm/master? I'd like to allow plenty of test time before the release.
We should be consistent about this. The kernel has moved to #include which breaks error reporting to some extent but does allow us to include binding files.
Changes in v7: None Changes in v6: None Changes in v5: - Put this patch before the others to avoid breaking bisectability
arch/arm/dts/exynos4.dtsi | 2 +- arch/arm/dts/exynos4210-origen.dts | 4 ++-- arch/arm/dts/exynos4210-smdkv310.dts | 2 +- arch/arm/dts/exynos4210-trats.dts | 2 +- arch/arm/dts/exynos4210-universal_c210.dts | 2 +- arch/arm/dts/exynos4412-trats2.dts | 2 +- arch/arm/dts/exynos5.dtsi | 2 +- arch/arm/dts/exynos5250-smdk5250.dts | 2 +- arch/arm/dts/exynos5250-snow.dts | 2 +- arch/arm/dts/exynos5250.dtsi | 2 +- arch/arm/dts/exynos5420-peach-pit.dts | 2 +- arch/arm/dts/exynos5420-smdk5420.dts | 2 +- arch/arm/dts/exynos54xx.dtsi | 2 +- arch/arm/dts/s5pc1xx-goni.dts | 2 +- arch/arm/dts/s5pc1xx-smdkc100.dts | 2 +- 15 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi index 110eb43..6b83516 100644 --- a/arch/arm/dts/exynos4.dtsi +++ b/arch/arm/dts/exynos4.dtsi @@ -7,7 +7,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
-/include/ "skeleton.dtsi" +#include "skeleton.dtsi"
/ { serial@13800000 { diff --git a/arch/arm/dts/exynos4210-origen.dts b/arch/arm/dts/exynos4210-origen.dts index 15059d2..556a3a2 100644 --- a/arch/arm/dts/exynos4210-origen.dts +++ b/arch/arm/dts/exynos4210-origen.dts @@ -8,8 +8,8 @@ */
/dts-v1/; -/include/ "skeleton.dtsi" -/include/ "exynos4.dtsi" +#include "skeleton.dtsi" +#include "exynos4.dtsi"
/ { model = "Insignal Origen evaluation board based on Exynos4210"; diff --git a/arch/arm/dts/exynos4210-smdkv310.dts b/arch/arm/dts/exynos4210-smdkv310.dts index c390c8f..00cad04 100644 --- a/arch/arm/dts/exynos4210-smdkv310.dts +++ b/arch/arm/dts/exynos4210-smdkv310.dts @@ -7,7 +7,7 @@ */
/dts-v1/; -/include/ "exynos4.dtsi" +#include "exynos4.dtsi"
/ { model = "Samsung SMDKV310 on Exynos4210"; diff --git a/arch/arm/dts/exynos4210-trats.dts b/arch/arm/dts/exynos4210-trats.dts index 0ff6939..71202d0 100644 --- a/arch/arm/dts/exynos4210-trats.dts +++ b/arch/arm/dts/exynos4210-trats.dts @@ -8,7 +8,7 @@ */
/ { model = "Samsung Trats based on Exynos4210"; diff --git a/arch/arm/dts/exynos4210-universal_c210.dts b/arch/arm/dts/exynos4210-universal_c210.dts index 6941906..d30f131 100644 --- a/arch/arm/dts/exynos4210-universal_c210.dts +++ b/arch/arm/dts/exynos4210-universal_c210.dts @@ -8,7 +8,7 @@ */
/ { model = "Samsung Universal C210 based on Exynos4210 rev0"; diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts index cc58c87..9d22de7 100644 --- a/arch/arm/dts/exynos4412-trats2.dts +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -8,7 +8,7 @@ */
/ { model = "Samsung Trats2 based on Exynos4412"; diff --git a/arch/arm/dts/exynos5.dtsi b/arch/arm/dts/exynos5.dtsi index a2b533a..329a89a 100644 --- a/arch/arm/dts/exynos5.dtsi +++ b/arch/arm/dts/exynos5.dtsi @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
/ { compatible = "samsung,exynos5"; diff --git a/arch/arm/dts/exynos5250-smdk5250.dts b/arch/arm/dts/exynos5250-smdk5250.dts index 9020382..8850409 100644 --- a/arch/arm/dts/exynos5250-smdk5250.dts +++ b/arch/arm/dts/exynos5250-smdk5250.dts @@ -10,7 +10,7 @@ */
/dts-v1/; -/include/ "exynos5250.dtsi" +#include "exynos5250.dtsi"
/ { model = "SAMSUNG SMDK5250 board based on EXYNOS5250"; diff --git a/arch/arm/dts/exynos5250-snow.dts b/arch/arm/dts/exynos5250-snow.dts index ab4f2f8..2003412 100644 --- a/arch/arm/dts/exynos5250-snow.dts +++ b/arch/arm/dts/exynos5250-snow.dts @@ -10,7 +10,7 @@ */
/ { model = "Google Snow"; diff --git a/arch/arm/dts/exynos5250.dtsi b/arch/arm/dts/exynos5250.dtsi index 0c644e7..771f8d3 100644 --- a/arch/arm/dts/exynos5250.dtsi +++ b/arch/arm/dts/exynos5250.dtsi @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
-/include/ "exynos5.dtsi" +#include "exynos5.dtsi"
/ { i2c@12ca0000 { diff --git a/arch/arm/dts/exynos5420-peach-pit.dts b/arch/arm/dts/exynos5420-peach-pit.dts index 995e62b..c4c4b8e 100644 --- a/arch/arm/dts/exynos5420-peach-pit.dts +++ b/arch/arm/dts/exynos5420-peach-pit.dts @@ -8,7 +8,7 @@ */
/dts-v1/; -/include/ "exynos54xx.dtsi" +#include "exynos54xx.dtsi"
/ { model = "Samsung/Google Peach Pit board based on Exynos5420"; diff --git a/arch/arm/dts/exynos5420-smdk5420.dts b/arch/arm/dts/exynos5420-smdk5420.dts index 1bc6256..6855027 100644 --- a/arch/arm/dts/exynos5420-smdk5420.dts +++ b/arch/arm/dts/exynos5420-smdk5420.dts @@ -8,7 +8,7 @@ */
/ { model = "SAMSUNG SMDK5420 board based on EXYNOS5420"; diff --git a/arch/arm/dts/exynos54xx.dtsi b/arch/arm/dts/exynos54xx.dtsi index c21d798..7892345 100644 --- a/arch/arm/dts/exynos54xx.dtsi +++ b/arch/arm/dts/exynos54xx.dtsi @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
/ { config { diff --git a/arch/arm/dts/s5pc1xx-goni.dts b/arch/arm/dts/s5pc1xx-goni.dts index c390c8f..00cad04 100644 --- a/arch/arm/dts/s5pc1xx-goni.dts +++ b/arch/arm/dts/s5pc1xx-goni.dts @@ -7,7 +7,7 @@ */
/ { model = "Samsung SMDKV310 on Exynos4210"; diff --git a/arch/arm/dts/s5pc1xx-smdkc100.dts b/arch/arm/dts/s5pc1xx-smdkc100.dts index 409812d..e8448f4 100644 --- a/arch/arm/dts/s5pc1xx-smdkc100.dts +++ b/arch/arm/dts/s5pc1xx-smdkc100.dts @@ -7,7 +7,7 @@ */
/ { model = "Samsung SMDKC100";
Bring in required device tree files for pinctrl from Linux v3.14. These are initially unchanged and have a number of pieces not needed by U-Boot.
Note that exynos5420 is renamed to exynos54xx here since we want to support exynos5422 also.
Changes in v7: None Changes in v6: - Fix typo in compatible string - Remove exynos5420.dtsi which is not used in U-Boot
arch/arm/dts/exynos4.dtsi | 7 + arch/arm/dts/exynos4210-origen.dts | 2 +- arch/arm/dts/exynos4210-pinctrl.dtsi | 847 +++++++++++++++++++++++++ arch/arm/dts/exynos4210-trats.dts | 2 +- arch/arm/dts/exynos4210-universal_c210.dts | 2 +- arch/arm/dts/exynos4210.dtsi | 155 +++++ arch/arm/dts/exynos4412-trats2.dts | 2 +- arch/arm/dts/exynos4412.dtsi | 38 ++ arch/arm/dts/exynos4x12-pinctrl.dtsi | 956 +++++++++++++++++++++++++++++ arch/arm/dts/exynos4x12.dtsi | 214 +++++++ arch/arm/dts/exynos5.dtsi | 54 ++ arch/arm/dts/exynos5250-pinctrl.dtsi | 790 ++++++++++++++++++++++++ arch/arm/dts/exynos5250.dtsi | 38 ++ arch/arm/dts/exynos54xx-pinctrl.dtsi | 687 +++++++++++++++++++++ arch/arm/dts/exynos54xx.dtsi | 44 ++ 15 files changed, 3834 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/exynos4210-pinctrl.dtsi create mode 100644 arch/arm/dts/exynos4210.dtsi create mode 100644 arch/arm/dts/exynos4412.dtsi create mode 100644 arch/arm/dts/exynos4x12-pinctrl.dtsi create mode 100644 arch/arm/dts/exynos4x12.dtsi create mode 100644 arch/arm/dts/exynos5250-pinctrl.dtsi create mode 100644 arch/arm/dts/exynos54xx-pinctrl.dtsi
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi index 6b83516..77fad48 100644 --- a/arch/arm/dts/exynos4.dtsi +++ b/arch/arm/dts/exynos4.dtsi @@ -10,6 +10,13 @@ #include "skeleton.dtsi"
/ { + combiner: interrupt-controller@10440000 { + compatible = "samsung,exynos4210-combiner"; + #interrupt-cells = <2>; + interrupt-controller; + reg = <0x10440000 0x1000>; + }; + serial@13800000 { compatible = "samsung,exynos4210-uart"; reg = <0x13800000 0x3c>; diff --git a/arch/arm/dts/exynos4210-origen.dts b/arch/arm/dts/exynos4210-origen.dts index 556a3a2..dd2476c 100644 --- a/arch/arm/dts/exynos4210-origen.dts +++ b/arch/arm/dts/exynos4210-origen.dts @@ -9,7 +9,7 @@
/dts-v1/; #include "skeleton.dtsi" -#include "exynos4.dtsi" +#include "exynos4210.dtsi"
/ { model = "Insignal Origen evaluation board based on Exynos4210"; diff --git a/arch/arm/dts/exynos4210-pinctrl.dtsi b/arch/arm/dts/exynos4210-pinctrl.dtsi new file mode 100644 index 0000000..a7c2128 --- /dev/null +++ b/arch/arm/dts/exynos4210-pinctrl.dtsi @@ -0,0 +1,847 @@ +/* + * Samsung's Exynos4210 SoC pin-mux and pin-config device tree source + * + * Copyright (c) 2011-2012 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * Copyright (c) 2011-2012 Linaro Ltd. + * www.linaro.org + * + * Samsung's Exynos4210 SoC pin-mux and pin-config optiosn are listed as device + * tree nodes are listed in this file. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +/ { + pinctrl@11400000 { + gpa0: gpa0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpa1: gpa1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb: gpb { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc0: gpc0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc1: gpc1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpd0: gpd0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpd1: gpd1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpe0: gpe0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpe1: gpe1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpe2: gpe2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpe3: gpe3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpe4: gpe4 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf0: gpf0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf1: gpf1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf2: gpf2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf3: gpf3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + uart0_data: uart0-data { + samsung,pins = "gpa0-0", "gpa0-1"; + samsung,pin-function = <0x2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart0_fctl: uart0-fctl { + samsung,pins = "gpa0-2", "gpa0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart1_data: uart1-data { + samsung,pins = "gpa0-4", "gpa0-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart1_fctl: uart1-fctl { + samsung,pins = "gpa0-6", "gpa0-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c2_bus: i2c2-bus { + samsung,pins = "gpa0-6", "gpa0-7"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + uart2_data: uart2-data { + samsung,pins = "gpa1-0", "gpa1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart2_fctl: uart2-fctl { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart_audio_a: uart-audio-a { + samsung,pins = "gpa1-0", "gpa1-1"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c3_bus: i2c3-bus { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + uart3_data: uart3-data { + samsung,pins = "gpa1-4", "gpa1-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart_audio_b: uart-audio-b { + samsung,pins = "gpa1-4", "gpa1-5"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spi0_bus: spi0-bus { + samsung,pins = "gpb-0", "gpb-2", "gpb-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c4_bus: i2c4-bus { + samsung,pins = "gpb-2", "gpb-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + spi1_bus: spi1-bus { + samsung,pins = "gpb-4", "gpb-6", "gpb-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c5_bus: i2c5-bus { + samsung,pins = "gpb-6", "gpb-7"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2s1_bus: i2s1-bus { + samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", + "gpc0-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm1_bus: pcm1-bus { + samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", + "gpc0-4"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + ac97_bus: ac97-bus { + samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", + "gpc0-4"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2s2_bus: i2s2-bus { + samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3", + "gpc1-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm2_bus: pcm2-bus { + samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3", + "gpc1-4"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spdif_bus: spdif-bus { + samsung,pins = "gpc1-0", "gpc1-1"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c6_bus: i2c6-bus { + samsung,pins = "gpc1-3", "gpc1-4"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + spi2_bus: spi2-bus { + samsung,pins = "gpc1-1", "gpc1-2", "gpc1-3", "gpc1-4"; + samsung,pin-function = <5>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c7_bus: i2c7-bus { + samsung,pins = "gpd0-2", "gpd0-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c0_bus: i2c0-bus { + samsung,pins = "gpd1-0", "gpd1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c1_bus: i2c1-bus { + samsung,pins = "gpd1-2", "gpd1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + pwm0_out: pwm0-out { + samsung,pins = "gpd0-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pwm1_out: pwm1-out { + samsung,pins = "gpd0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pwm2_out: pwm2-out { + samsung,pins = "gpd0-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pwm3_out: pwm3-out { + samsung,pins = "gpd0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_ctrl: lcd-ctrl { + samsung,pins = "gpd0-0", "gpd0-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_sync: lcd-sync { + samsung,pins = "gpf0-0", "gpf0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_en: lcd-en { + samsung,pins = "gpe3-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_clk: lcd-clk { + samsung,pins = "gpf0-0", "gpf0-1", "gpf0-2", "gpf0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_data16: lcd-data-width16 { + samsung,pins = "gpf0-7", "gpf1-0", "gpf1-1", "gpf1-2", + "gpf1-3", "gpf1-6", "gpf1-7", "gpf2-0", + "gpf2-1", "gpf2-2", "gpf2-3", "gpf2-7", + "gpf3-0", "gpf3-1", "gpf3-2", "gpf3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_data18: lcd-data-width18 { + samsung,pins = "gpf0-6", "gpf0-7", "gpf1-0", "gpf1-1", + "gpf1-2", "gpf1-3", "gpf1-6", "gpf1-7", + "gpf2-0", "gpf2-1", "gpf2-2", "gpf2-3", + "gpf2-6", "gpf2-7", "gpf3-0", "gpf3-1", + "gpf3-2", "gpf3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_data24: lcd-data-width24 { + samsung,pins = "gpf0-4", "gpf0-5", "gpf0-6", "gpf0-7", + "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3", + "gpf1-4", "gpf1-5", "gpf1-6", "gpf1-7", + "gpf2-0", "gpf2-1", "gpf2-2", "gpf2-3", + "gpf2-4", "gpf2-5", "gpf2-6", "gpf2-7", + "gpf3-0", "gpf3-1", "gpf3-2", "gpf3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@11000000 { + gpj0: gpj0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpj1: gpj1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpk0: gpk0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpk1: gpk1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpk2: gpk2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpk3: gpk3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpl0: gpl0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpl1: gpl1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpl2: gpl2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpy0: gpy0 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy1: gpy1 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy2: gpy2 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy3: gpy3 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy4: gpy4 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy5: gpy5 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy6: gpy6 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpx0: gpx0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + interrupt-parent = <&gic>; + interrupts = <0 16 0>, <0 17 0>, <0 18 0>, <0 19 0>, + <0 20 0>, <0 21 0>, <0 22 0>, <0 23 0>; + #interrupt-cells = <2>; + }; + + gpx1: gpx1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + interrupt-parent = <&gic>; + interrupts = <0 24 0>, <0 25 0>, <0 26 0>, <0 27 0>, + <0 28 0>, <0 29 0>, <0 30 0>, <0 31 0>; + #interrupt-cells = <2>; + }; + + gpx2: gpx2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpx3: gpx3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + sd0_clk: sd0-clk { + samsung,pins = "gpk0-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd0_cmd: sd0-cmd { + samsung,pins = "gpk0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd0_cd: sd0-cd { + samsung,pins = "gpk0-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus1: sd0-bus-width1 { + samsung,pins = "gpk0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus4: sd0-bus-width4 { + samsung,pins = "gpk0-3", "gpk0-4", "gpk0-5", "gpk0-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus8: sd0-bus-width8 { + samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd4_clk: sd4-clk { + samsung,pins = "gpk0-0"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd4_cmd: sd4-cmd { + samsung,pins = "gpk0-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd4_cd: sd4-cd { + samsung,pins = "gpk0-2"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd4_bus1: sd4-bus-width1 { + samsung,pins = "gpk0-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd4_bus4: sd4-bus-width4 { + samsung,pins = "gpk0-3", "gpk0-4", "gpk0-5", "gpk0-6"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd4_bus8: sd4-bus-width8 { + samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; + samsung,pin-function = <3>; + samsung,pin-pud = <4>; + samsung,pin-drv = <3>; + }; + + sd1_clk: sd1-clk { + samsung,pins = "gpk1-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd1_cmd: sd1-cmd { + samsung,pins = "gpk1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd1_cd: sd1-cd { + samsung,pins = "gpk1-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_bus1: sd1-bus-width1 { + samsung,pins = "gpk1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_bus4: sd1-bus-width4 { + samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_clk: sd2-clk { + samsung,pins = "gpk2-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd2_cmd: sd2-cmd { + samsung,pins = "gpk2-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd2_cd: sd2-cd { + samsung,pins = "gpk2-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus1: sd2-bus-width1 { + samsung,pins = "gpk2-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus4: sd2-bus-width4 { + samsung,pins = "gpk2-3", "gpk2-4", "gpk2-5", "gpk2-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus8: sd2-bus-width8 { + samsung,pins = "gpk3-3", "gpk3-4", "gpk3-5", "gpk3-6"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_clk: sd3-clk { + samsung,pins = "gpk3-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd3_cmd: sd3-cmd { + samsung,pins = "gpk3-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd3_cd: sd3-cd { + samsung,pins = "gpk3-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_bus1: sd3-bus-width1 { + samsung,pins = "gpk3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_bus4: sd3-bus-width4 { + samsung,pins = "gpk3-3", "gpk3-4", "gpk3-5", "gpk3-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + eint0: ext-int0 { + samsung,pins = "gpx0-0"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + eint8: ext-int8 { + samsung,pins = "gpx1-0"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + eint15: ext-int15 { + samsung,pins = "gpx1-7"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + eint16: ext-int16 { + samsung,pins = "gpx2-0"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + eint31: ext-int31 { + samsung,pins = "gpx3-7"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_port_a_io: cam-port-a-io { + samsung,pins = "gpj0-0", "gpj0-1", "gpj0-2", "gpj0-3", + "gpj0-4", "gpj0-5", "gpj0-6", "gpj0-7", + "gpj1-0", "gpj1-1", "gpj1-2", "gpj1-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_port_a_clk_active: cam-port-a-clk-active { + samsung,pins = "gpj1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + cam_port_a_clk_idle: cam-port-a-clk-idle { + samsung,pins = "gpj1-3"; + samsung,pin-function = <0>; + samsung,pin-pud = <1>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@03860000 { + gpz: gpz { + gpio-controller; + #gpio-cells = <2>; + }; + + i2s0_bus: i2s0-bus { + samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", + "gpz-4", "gpz-5", "gpz-6"; + samsung,pin-function = <0x2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm0_bus: pcm0-bus { + samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", + "gpz-4"; + samsung,pin-function = <0x3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; +}; diff --git a/arch/arm/dts/exynos4210-trats.dts b/arch/arm/dts/exynos4210-trats.dts index 71202d0..81188bc 100644 --- a/arch/arm/dts/exynos4210-trats.dts +++ b/arch/arm/dts/exynos4210-trats.dts @@ -8,7 +8,7 @@ */
/dts-v1/; -#include "exynos4.dtsi" +#include "exynos4210.dtsi"
/ { model = "Samsung Trats based on Exynos4210"; diff --git a/arch/arm/dts/exynos4210-universal_c210.dts b/arch/arm/dts/exynos4210-universal_c210.dts index d30f131..cf3354f 100644 --- a/arch/arm/dts/exynos4210-universal_c210.dts +++ b/arch/arm/dts/exynos4210-universal_c210.dts @@ -8,7 +8,7 @@ */
/ { model = "Samsung Universal C210 based on Exynos4210 rev0"; diff --git a/arch/arm/dts/exynos4210.dtsi b/arch/arm/dts/exynos4210.dtsi new file mode 100644 index 0000000..48ecd7a --- /dev/null +++ b/arch/arm/dts/exynos4210.dtsi @@ -0,0 +1,155 @@ +/* + * Samsung's Exynos4210 SoC device tree source + * + * Copyright (c) 2010-2011 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * Copyright (c) 2010-2011 Linaro Ltd. + * www.linaro.org + * + * Samsung's Exynos4210 SoC device nodes are listed in this file. Exynos4210 + * based board files can include this file and provide values for board specfic + * bindings. + * + * Note: This file does not include device nodes for all the controllers in + * Exynos4210 SoC. As device tree coverage for Exynos4210 increases, additional + * nodes can be added to this file. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +#include "exynos4.dtsi" +#include "exynos4210-pinctrl.dtsi" + +/ { + compatible = "samsung,exynos4210"; + + aliases { + pinctrl0 = &pinctrl_0; + pinctrl1 = &pinctrl_1; + pinctrl2 = &pinctrl_2; + }; + + pd_lcd1: lcd1-power-domain@10023CA0 { + compatible = "samsung,exynos4210-pd"; + reg = <0x10023CA0 0x20>; + }; + + gic: interrupt-controller@10490000 { + cpu-offset = <0x8000>; + }; + + combiner: interrupt-controller@10440000 { + samsung,combiner-nr = <16>; + interrupts = <0 0 0>, <0 1 0>, <0 2 0>, <0 3 0>, + <0 4 0>, <0 5 0>, <0 6 0>, <0 7 0>, + <0 8 0>, <0 9 0>, <0 10 0>, <0 11 0>, + <0 12 0>, <0 13 0>, <0 14 0>, <0 15 0>; + }; + + mct@10050000 { + compatible = "samsung,exynos4210-mct"; + reg = <0x10050000 0x800>; + interrupt-parent = <&mct_map>; + interrupts = <0>, <1>, <2>, <3>, <4>, <5>; + clocks = <&clock 3>, <&clock 344>; + clock-names = "fin_pll", "mct"; + + mct_map: mct-map { + #interrupt-cells = <1>; + #address-cells = <0>; + #size-cells = <0>; + interrupt-map = <0 &gic 0 57 0>, + <1 &gic 0 69 0>, + <2 &combiner 12 6>, + <3 &combiner 12 7>, + <4 &gic 0 42 0>, + <5 &gic 0 48 0>; + }; + }; + + clock: clock-controller@10030000 { + compatible = "samsung,exynos4210-clock"; + reg = <0x10030000 0x20000>; + #clock-cells = <1>; + }; + + pmu { + compatible = "arm,cortex-a9-pmu"; + interrupt-parent = <&combiner>; + interrupts = <2 2>, <3 2>; + }; + + pinctrl_0: pinctrl@11400000 { + compatible = "samsung,exynos4210-pinctrl"; + reg = <0x11400000 0x1000>; + interrupts = <0 47 0>; + }; + + pinctrl_1: pinctrl@11000000 { + compatible = "samsung,exynos4210-pinctrl"; + reg = <0x11000000 0x1000>; + interrupts = <0 46 0>; + + wakup_eint: wakeup-interrupt-controller { + compatible = "samsung,exynos4210-wakeup-eint"; + interrupt-parent = <&gic>; + interrupts = <0 32 0>; + }; + }; + + pinctrl_2: pinctrl@03860000 { + compatible = "samsung,exynos4210-pinctrl"; + reg = <0x03860000 0x1000>; + }; + + tmu@100C0000 { + compatible = "samsung,exynos4210-tmu"; + interrupt-parent = <&combiner>; + reg = <0x100C0000 0x100>; + interrupts = <2 4>; + clocks = <&clock 383>; + clock-names = "tmu_apbif"; + status = "disabled"; + }; + + g2d@12800000 { + compatible = "samsung,s5pv210-g2d"; + reg = <0x12800000 0x1000>; + interrupts = <0 89 0>; + clocks = <&clock 177>, <&clock 277>; + clock-names = "sclk_fimg2d", "fimg2d"; + status = "disabled"; + }; + + camera { + clocks = <&clock 132>, <&clock 133>, <&clock 351>, <&clock 352>; + clock-names = "sclk_cam0", "sclk_cam1", "pxl_async0", "pxl_async1"; + + fimc_0: fimc@11800000 { + samsung,pix-limits = <4224 8192 1920 4224>; + samsung,mainscaler-ext; + samsung,cam-if; + }; + + fimc_1: fimc@11810000 { + samsung,pix-limits = <4224 8192 1920 4224>; + samsung,mainscaler-ext; + samsung,cam-if; + }; + + fimc_2: fimc@11820000 { + samsung,pix-limits = <4224 8192 1920 4224>; + samsung,mainscaler-ext; + samsung,lcd-wb; + }; + + fimc_3: fimc@11830000 { + samsung,pix-limits = <1920 8192 1366 1920>; + samsung,rotators = <0>; + samsung,mainscaler-ext; + samsung,lcd-wb; + }; + }; +}; diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts index 9d22de7..3b1e458 100644 --- a/arch/arm/dts/exynos4412-trats2.dts +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -8,7 +8,7 @@ */
/dts-v1/; -#include "exynos4.dtsi" +#include "exynos4412.dtsi"
/ { model = "Samsung Trats2 based on Exynos4412"; diff --git a/arch/arm/dts/exynos4412.dtsi b/arch/arm/dts/exynos4412.dtsi new file mode 100644 index 0000000..87b339c --- /dev/null +++ b/arch/arm/dts/exynos4412.dtsi @@ -0,0 +1,38 @@ +/* + * Samsung's Exynos4412 SoC device tree source + * + * Copyright (c) 2012 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * Samsung's Exynos4412 SoC device nodes are listed in this file. Exynos4412 + * based board files can include this file and provide values for board specfic + * bindings. + * + * Note: This file does not include device nodes for all the controllers in + * Exynos4412 SoC. As device tree coverage for Exynos4412 increases, additional + * nodes can be added to this file. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +#include "exynos4x12.dtsi" + +/ { + compatible = "samsung,exynos4412"; + + gic: interrupt-controller@10490000 { + cpu-offset = <0x4000>; + }; + + interrupt-controller@10440000 { + samsung,combiner-nr = <20>; + interrupts = <0 0 0>, <0 1 0>, <0 2 0>, <0 3 0>, + <0 4 0>, <0 5 0>, <0 6 0>, <0 7 0>, + <0 8 0>, <0 9 0>, <0 10 0>, <0 11 0>, + <0 12 0>, <0 13 0>, <0 14 0>, <0 15 0>, + <0 107 0>, <0 108 0>, <0 48 0>, <0 42 0>; + }; + +}; diff --git a/arch/arm/dts/exynos4x12-pinctrl.dtsi b/arch/arm/dts/exynos4x12-pinctrl.dtsi new file mode 100644 index 0000000..99b26df --- /dev/null +++ b/arch/arm/dts/exynos4x12-pinctrl.dtsi @@ -0,0 +1,956 @@ +/* + * Samsung's Exynos4x12 SoCs pin-mux and pin-config device tree source + * + * Copyright (c) 2012 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * Samsung's Exynos4x12 SoCs pin-mux and pin-config optiosn are listed as device + * tree nodes are listed in this file. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +/ { + pinctrl@11400000 { + gpa0: gpa0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpa1: gpa1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb: gpb { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc0: gpc0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc1: gpc1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpd0: gpd0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpd1: gpd1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf0: gpf0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf1: gpf1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf2: gpf2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf3: gpf3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpj0: gpj0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpj1: gpj1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + uart0_data: uart0-data { + samsung,pins = "gpa0-0", "gpa0-1"; + samsung,pin-function = <0x2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart0_fctl: uart0-fctl { + samsung,pins = "gpa0-2", "gpa0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart1_data: uart1-data { + samsung,pins = "gpa0-4", "gpa0-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart1_fctl: uart1-fctl { + samsung,pins = "gpa0-6", "gpa0-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c2_bus: i2c2-bus { + samsung,pins = "gpa0-6", "gpa0-7"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + uart2_data: uart2-data { + samsung,pins = "gpa1-0", "gpa1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart2_fctl: uart2-fctl { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart_audio_a: uart-audio-a { + samsung,pins = "gpa1-0", "gpa1-1"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c3_bus: i2c3-bus { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + uart3_data: uart3-data { + samsung,pins = "gpa1-4", "gpa1-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart_audio_b: uart-audio-b { + samsung,pins = "gpa1-4", "gpa1-5"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spi0_bus: spi0-bus { + samsung,pins = "gpb-0", "gpb-2", "gpb-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c4_bus: i2c4-bus { + samsung,pins = "gpb-0", "gpb-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + spi1_bus: spi1-bus { + samsung,pins = "gpb-4", "gpb-6", "gpb-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c5_bus: i2c5-bus { + samsung,pins = "gpb-2", "gpb-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2s1_bus: i2s1-bus { + samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", + "gpc0-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm1_bus: pcm1-bus { + samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", + "gpc0-4"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + ac97_bus: ac97-bus { + samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", + "gpc0-4"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2s2_bus: i2s2-bus { + samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3", + "gpc1-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm2_bus: pcm2-bus { + samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3", + "gpc1-4"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spdif_bus: spdif-bus { + samsung,pins = "gpc1-0", "gpc1-1"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c6_bus: i2c6-bus { + samsung,pins = "gpc1-3", "gpc1-4"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + spi2_bus: spi2-bus { + samsung,pins = "gpc1-1", "gpc1-3", "gpc1-4"; + samsung,pin-function = <5>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + pwm0_out: pwm0-out { + samsung,pins = "gpd0-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pwm1_out: pwm1-out { + samsung,pins = "gpd0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_ctrl: lcd-ctrl { + samsung,pins = "gpd0-0", "gpd0-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c7_bus: i2c7-bus { + samsung,pins = "gpd0-2", "gpd0-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + pwm2_out: pwm2-out { + samsung,pins = "gpd0-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pwm3_out: pwm3-out { + samsung,pins = "gpd0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c0_bus: i2c0-bus { + samsung,pins = "gpd1-0", "gpd1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + mipi0_clk: mipi0-clk { + samsung,pins = "gpd1-0", "gpd1-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c1_bus: i2c1-bus { + samsung,pins = "gpd1-2", "gpd1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + mipi1_clk: mipi1-clk { + samsung,pins = "gpd1-2", "gpd1-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_clk: lcd-clk { + samsung,pins = "gpf0-0", "gpf0-1", "gpf0-2", "gpf0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_data16: lcd-data-width16 { + samsung,pins = "gpf0-7", "gpf1-0", "gpf1-1", "gpf1-2", + "gpf1-3", "gpf1-6", "gpf1-7", "gpf2-0", + "gpf2-1", "gpf2-2", "gpf2-3", "gpf2-7", + "gpf3-0", "gpf3-1", "gpf3-2", "gpf3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_data18: lcd-data-width18 { + samsung,pins = "gpf0-6", "gpf0-7", "gpf1-0", "gpf1-1", + "gpf1-2", "gpf1-3", "gpf1-6", "gpf1-7", + "gpf2-0", "gpf2-1", "gpf2-2", "gpf2-3", + "gpf2-6", "gpf2-7", "gpf3-0", "gpf3-1", + "gpf3-2", "gpf3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_data24: lcd-data-width24 { + samsung,pins = "gpf0-4", "gpf0-5", "gpf0-6", "gpf0-7", + "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3", + "gpf1-4", "gpf1-5", "gpf1-6", "gpf1-7", + "gpf2-0", "gpf2-1", "gpf2-2", "gpf2-3", + "gpf2-4", "gpf2-5", "gpf2-6", "gpf2-7", + "gpf3-0", "gpf3-1", "gpf3-2", "gpf3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + lcd_ldi: lcd-ldi { + samsung,pins = "gpf3-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_port_a_io: cam-port-a-io { + samsung,pins = "gpj0-0", "gpj0-1", "gpj0-2", "gpj0-3", + "gpj0-4", "gpj0-5", "gpj0-6", "gpj0-7", + "gpj1-0", "gpj1-1", "gpj1-2", "gpj1-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_port_a_clk_active: cam-port-a-clk-active { + samsung,pins = "gpj1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + cam_port_a_clk_idle: cam-port-a-clk-idle { + samsung,pins = "gpj1-3"; + samsung,pin-function = <0>; + samsung,pin-pud = <1>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@11000000 { + gpk0: gpk0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpk1: gpk1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpk2: gpk2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpk3: gpk3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpl0: gpl0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpl1: gpl1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpl2: gpl2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpm0: gpm0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpm1: gpm1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpm2: gpm2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpm3: gpm3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpm4: gpm4 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpy0: gpy0 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy1: gpy1 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy2: gpy2 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy3: gpy3 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy4: gpy4 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy5: gpy5 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy6: gpy6 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpx0: gpx0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + interrupt-parent = <&gic>; + interrupts = <0 16 0>, <0 17 0>, <0 18 0>, <0 19 0>, + <0 20 0>, <0 21 0>, <0 22 0>, <0 23 0>; + #interrupt-cells = <2>; + }; + + gpx1: gpx1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + interrupt-parent = <&gic>; + interrupts = <0 24 0>, <0 25 0>, <0 26 0>, <0 27 0>, + <0 28 0>, <0 29 0>, <0 30 0>, <0 31 0>; + #interrupt-cells = <2>; + }; + + gpx2: gpx2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpx3: gpx3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + sd0_clk: sd0-clk { + samsung,pins = "gpk0-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd0_cmd: sd0-cmd { + samsung,pins = "gpk0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd0_cd: sd0-cd { + samsung,pins = "gpk0-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus1: sd0-bus-width1 { + samsung,pins = "gpk0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus4: sd0-bus-width4 { + samsung,pins = "gpk0-3", "gpk0-4", "gpk0-5", "gpk0-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus8: sd0-bus-width8 { + samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd4_clk: sd4-clk { + samsung,pins = "gpk0-0"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd4_cmd: sd4-cmd { + samsung,pins = "gpk0-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd4_cd: sd4-cd { + samsung,pins = "gpk0-2"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd4_bus1: sd4-bus-width1 { + samsung,pins = "gpk0-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd4_bus4: sd4-bus-width4 { + samsung,pins = "gpk0-3", "gpk0-4", "gpk0-5", "gpk0-6"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd4_bus8: sd4-bus-width8 { + samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; + samsung,pin-function = <4>; + samsung,pin-pud = <4>; + samsung,pin-drv = <3>; + }; + + sd1_clk: sd1-clk { + samsung,pins = "gpk1-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd1_cmd: sd1-cmd { + samsung,pins = "gpk1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd1_cd: sd1-cd { + samsung,pins = "gpk1-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_bus1: sd1-bus-width1 { + samsung,pins = "gpk1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_bus4: sd1-bus-width4 { + samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_clk: sd2-clk { + samsung,pins = "gpk2-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd2_cmd: sd2-cmd { + samsung,pins = "gpk2-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd2_cd: sd2-cd { + samsung,pins = "gpk2-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus1: sd2-bus-width1 { + samsung,pins = "gpk2-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus4: sd2-bus-width4 { + samsung,pins = "gpk2-3", "gpk2-4", "gpk2-5", "gpk2-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus8: sd2-bus-width8 { + samsung,pins = "gpk3-3", "gpk3-4", "gpk3-5", "gpk3-6"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_clk: sd3-clk { + samsung,pins = "gpk3-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd3_cmd: sd3-cmd { + samsung,pins = "gpk3-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd3_cd: sd3-cd { + samsung,pins = "gpk3-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_bus1: sd3-bus-width1 { + samsung,pins = "gpk3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_bus4: sd3-bus-width4 { + samsung,pins = "gpk3-3", "gpk3-4", "gpk3-5", "gpk3-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + cam_port_b_io: cam-port-b-io { + samsung,pins = "gpm0-0", "gpm0-1", "gpm0-2", "gpm0-3", + "gpm0-4", "gpm0-5", "gpm0-6", "gpm0-7", + "gpm1-0", "gpm1-1", "gpm2-0", "gpm2-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + cam_port_b_clk_active: cam-port-b-clk-active { + samsung,pins = "gpm2-2"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + cam_port_b_clk_idle: cam-port-b-clk-idle { + samsung,pins = "gpm2-2"; + samsung,pin-function = <0>; + samsung,pin-pud = <1>; + samsung,pin-drv = <0>; + }; + + eint0: ext-int0 { + samsung,pins = "gpx0-0"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + eint8: ext-int8 { + samsung,pins = "gpx1-0"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + eint15: ext-int15 { + samsung,pins = "gpx1-7"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + eint16: ext-int16 { + samsung,pins = "gpx2-0"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + eint31: ext-int31 { + samsung,pins = "gpx3-7"; + samsung,pin-function = <0xf>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + fimc_is_i2c0: fimc-is-i2c0 { + samsung,pins = "gpm4-0", "gpm4-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + fimc_is_i2c1: fimc-is-i2c1 { + samsung,pins = "gpm4-2", "gpm4-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + fimc_is_uart: fimc-is-uart { + samsung,pins = "gpm3-5", "gpm3-7"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@03860000 { + gpz: gpz { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + i2s0_bus: i2s0-bus { + samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", + "gpz-4", "gpz-5", "gpz-6"; + samsung,pin-function = <0x2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm0_bus: pcm0-bus { + samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", + "gpz-4"; + samsung,pin-function = <0x3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@106E0000 { + gpv0: gpv0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpv1: gpv1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpv2: gpv2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpv3: gpv3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpv4: gpv4 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + c2c_bus: c2c-bus { + samsung,pins = "gpv0-0", "gpv0-1", "gpv0-2", "gpv0-3", + "gpv0-4", "gpv0-5", "gpv0-6", "gpv0-7", + "gpv1-0", "gpv1-1", "gpv1-2", "gpv1-3", + "gpv1-4", "gpv1-5", "gpv1-6", "gpv1-7", + "gpv2-0", "gpv2-1", "gpv2-2", "gpv2-3", + "gpv2-4", "gpv2-5", "gpv2-6", "gpv2-7", + "gpv3-0", "gpv3-1", "gpv3-2", "gpv3-3", + "gpv3-4", "gpv3-5", "gpv3-6", "gpv3-7", + "gpv4-0", "gpv4-1"; + samsung,pin-function = <0x2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; +}; diff --git a/arch/arm/dts/exynos4x12.dtsi b/arch/arm/dts/exynos4x12.dtsi new file mode 100644 index 0000000..6b898c2 --- /dev/null +++ b/arch/arm/dts/exynos4x12.dtsi @@ -0,0 +1,214 @@ +/* + * Samsung's Exynos4x12 SoCs device tree source + * + * Copyright (c) 2012 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * Samsung's Exynos4x12 SoCs device nodes are listed in this file. Exynos4x12 + * based board files can include this file and provide values for board specfic + * bindings. + * + * Note: This file does not include device nodes for all the controllers in + * Exynos4x12 SoC. As device tree coverage for Exynos4x12 increases, additional + * nodes can be added to this file. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as +` * published by the Free Software Foundation. +*/ + +#include "exynos4.dtsi" +#include "exynos4x12-pinctrl.dtsi" + +/ { + aliases { + pinctrl0 = &pinctrl_0; + pinctrl1 = &pinctrl_1; + pinctrl2 = &pinctrl_2; + pinctrl3 = &pinctrl_3; + fimc-lite0 = &fimc_lite_0; + fimc-lite1 = &fimc_lite_1; + mshc0 = &mshc_0; + }; + + pd_isp: isp-power-domain@10023CA0 { + compatible = "samsung,exynos4210-pd"; + reg = <0x10023CA0 0x20>; + }; + + clock: clock-controller@10030000 { + compatible = "samsung,exynos4412-clock"; + reg = <0x10030000 0x20000>; + #clock-cells = <1>; + }; + + mct@10050000 { + compatible = "samsung,exynos4412-mct"; + reg = <0x10050000 0x800>; + interrupt-parent = <&mct_map>; + interrupts = <0>, <1>, <2>, <3>, <4>; + clocks = <&clock 3>, <&clock 344>; + clock-names = "fin_pll", "mct"; + + mct_map: mct-map { + #interrupt-cells = <1>; + #address-cells = <0>; + #size-cells = <0>; + interrupt-map = <0 &gic 0 57 0>, + <1 &combiner 12 5>, + <2 &combiner 12 6>, + <3 &combiner 12 7>, + <4 &gic 1 12 0>; + }; + }; + + pinctrl_0: pinctrl@11400000 { + compatible = "samsung,exynos4x12-pinctrl"; + reg = <0x11400000 0x1000>; + interrupts = <0 47 0>; + }; + + pinctrl_1: pinctrl@11000000 { + compatible = "samsung,exynos4x12-pinctrl"; + reg = <0x11000000 0x1000>; + interrupts = <0 46 0>; + + wakup_eint: wakeup-interrupt-controller { + compatible = "samsung,exynos4210-wakeup-eint"; + interrupt-parent = <&gic>; + interrupts = <0 32 0>; + }; + }; + + pinctrl_2: pinctrl@03860000 { + compatible = "samsung,exynos4x12-pinctrl"; + reg = <0x03860000 0x1000>; + interrupt-parent = <&combiner>; + interrupts = <10 0>; + }; + + pinctrl_3: pinctrl@106E0000 { + compatible = "samsung,exynos4x12-pinctrl"; + reg = <0x106E0000 0x1000>; + interrupts = <0 72 0>; + }; + + g2d@10800000 { + compatible = "samsung,exynos4212-g2d"; + reg = <0x10800000 0x1000>; + interrupts = <0 89 0>; + clocks = <&clock 177>, <&clock 277>; + clock-names = "sclk_fimg2d", "fimg2d"; + status = "disabled"; + }; + + camera { + clocks = <&clock 132>, <&clock 133>, <&clock 351>, <&clock 352>; + clock-names = "sclk_cam0", "sclk_cam1", "pxl_async0", "pxl_async1"; + #address-cells = <1>; + #size-cells = <1>; + + fimc_0: fimc@11800000 { + compatible = "samsung,exynos4212-fimc"; + samsung,pix-limits = <4224 8192 1920 4224>; + samsung,mainscaler-ext; + samsung,isp-wb; + samsung,cam-if; + }; + + fimc_1: fimc@11810000 { + compatible = "samsung,exynos4212-fimc"; + samsung,pix-limits = <4224 8192 1920 4224>; + samsung,mainscaler-ext; + samsung,isp-wb; + samsung,cam-if; + }; + + fimc_2: fimc@11820000 { + compatible = "samsung,exynos4212-fimc"; + samsung,pix-limits = <4224 8192 1920 4224>; + samsung,mainscaler-ext; + samsung,isp-wb; + samsung,lcd-wb; + samsung,cam-if; + }; + + fimc_3: fimc@11830000 { + compatible = "samsung,exynos4212-fimc"; + samsung,pix-limits = <1920 8192 1366 1920>; + samsung,rotators = <0>; + samsung,mainscaler-ext; + samsung,isp-wb; + samsung,lcd-wb; + }; + + fimc_lite_0: fimc-lite@12390000 { + compatible = "samsung,exynos4212-fimc-lite"; + reg = <0x12390000 0x1000>; + interrupts = <0 105 0>; + samsung,power-domain = <&pd_isp>; + clocks = <&clock 353>; + clock-names = "flite"; + status = "disabled"; + }; + + fimc_lite_1: fimc-lite@123A0000 { + compatible = "samsung,exynos4212-fimc-lite"; + reg = <0x123A0000 0x1000>; + interrupts = <0 106 0>; + samsung,power-domain = <&pd_isp>; + clocks = <&clock 354>; + clock-names = "flite"; + status = "disabled"; + }; + + fimc_is: fimc-is@12000000 { + compatible = "samsung,exynos4212-fimc-is", "simple-bus"; + reg = <0x12000000 0x260000>; + interrupts = <0 90 0>, <0 95 0>; + samsung,power-domain = <&pd_isp>; + clocks = <&clock 353>, <&clock 354>, <&clock 355>, + <&clock 356>, <&clock 17>, <&clock 357>, + <&clock 358>, <&clock 359>, <&clock 360>, + <&clock 450>,<&clock 451>, <&clock 452>, + <&clock 453>, <&clock 176>, <&clock 13>, + <&clock 454>, <&clock 395>, <&clock 455>; + clock-names = "lite0", "lite1", "ppmuispx", + "ppmuispmx", "mpll", "isp", + "drc", "fd", "mcuisp", + "ispdiv0", "ispdiv1", "mcuispdiv0", + "mcuispdiv1", "uart", "aclk200", + "div_aclk200", "aclk400mcuisp", + "div_aclk400mcuisp"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + status = "disabled"; + + pmu { + reg = <0x10020000 0x3000>; + }; + + i2c1_isp: i2c-isp@12140000 { + compatible = "samsung,exynos4212-i2c-isp"; + reg = <0x12140000 0x100>; + clocks = <&clock 370>; + clock-names = "i2c_isp"; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; + + mshc_0: mmc@12550000 { + compatible = "samsung,exynos4412-dw-mshc"; + reg = <0x12550000 0x1000>; + interrupts = <0 77 0>; + #address-cells = <1>; + #size-cells = <0>; + fifo-depth = <0x80>; + clocks = <&clock 301>, <&clock 149>; + clock-names = "biu", "ciu"; + status = "disabled"; + }; +}; diff --git a/arch/arm/dts/exynos5.dtsi b/arch/arm/dts/exynos5.dtsi index 329a89a..dc5405b 100644 --- a/arch/arm/dts/exynos5.dtsi +++ b/arch/arm/dts/exynos5.dtsi @@ -10,6 +10,33 @@ / { compatible = "samsung,exynos5";
+ combiner: interrupt-controller@10440000 { + compatible = "samsung,exynos4210-combiner"; + #interrupt-cells = <2>; + interrupt-controller; + samsung,combiner-nr = <32>; + reg = <0x10440000 0x1000>; + interrupts = <0 0 0>, <0 1 0>, <0 2 0>, <0 3 0>, + <0 4 0>, <0 5 0>, <0 6 0>, <0 7 0>, + <0 8 0>, <0 9 0>, <0 10 0>, <0 11 0>, + <0 12 0>, <0 13 0>, <0 14 0>, <0 15 0>, + <0 16 0>, <0 17 0>, <0 18 0>, <0 19 0>, + <0 20 0>, <0 21 0>, <0 22 0>, <0 23 0>, + <0 24 0>, <0 25 0>, <0 26 0>, <0 27 0>, + <0 28 0>, <0 29 0>, <0 30 0>, <0 31 0>; + }; + + gic: interrupt-controller@10481000 { + compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x10481000 0x1000>, + <0x10482000 0x1000>, + <0x10484000 0x2000>, + <0x10486000 0x2000>; + interrupts = <1 9 0xf04>; + }; + sromc@12250000 { compatible = "samsung,exynos-sromc"; reg = <0x12250000 0x20>; @@ -17,6 +44,33 @@ #size-cells = <0>; };
+ combiner: interrupt-controller@10440000 { + compatible = "samsung,exynos4210-combiner"; + #interrupt-cells = <2>; + interrupt-controller; + samsung,combiner-nr = <32>; + reg = <0x10440000 0x1000>; + interrupts = <0 0 0>, <0 1 0>, <0 2 0>, <0 3 0>, + <0 4 0>, <0 5 0>, <0 6 0>, <0 7 0>, + <0 8 0>, <0 9 0>, <0 10 0>, <0 11 0>, + <0 12 0>, <0 13 0>, <0 14 0>, <0 15 0>, + <0 16 0>, <0 17 0>, <0 18 0>, <0 19 0>, + <0 20 0>, <0 21 0>, <0 22 0>, <0 23 0>, + <0 24 0>, <0 25 0>, <0 26 0>, <0 27 0>, + <0 28 0>, <0 29 0>, <0 30 0>, <0 31 0>; + }; + + gic: interrupt-controller@10481000 { + compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x10481000 0x1000>, + <0x10482000 0x1000>, + <0x10484000 0x2000>, + <0x10486000 0x2000>; + interrupts = <1 9 0xf04>; + }; + i2c@12c60000 { #address-cells = <1>; #size-cells = <0>; diff --git a/arch/arm/dts/exynos5250-pinctrl.dtsi b/arch/arm/dts/exynos5250-pinctrl.dtsi new file mode 100644 index 0000000..9a49e68 --- /dev/null +++ b/arch/arm/dts/exynos5250-pinctrl.dtsi @@ -0,0 +1,790 @@ +/* + * Samsung's Exynos5250 SoC pin-mux and pin-config device tree source + * + * Copyright (c) 2012 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * Samsung's Exynos5250 SoC pin-mux and pin-config optiosn are listed as device + * tree nodes are listed in this file. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +/ { + pinctrl@11400000 { + gpa0: gpa0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpa1: gpa1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpa2: gpa2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb0: gpb0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb1: gpb1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb2: gpb2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb3: gpb3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc0: gpc0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc1: gpc1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc2: gpc2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc3: gpc3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpd0: gpd0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpd1: gpd1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpy0: gpy0 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy1: gpy1 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy2: gpy2 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy3: gpy3 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy4: gpy4 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy5: gpy5 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy6: gpy6 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpc4: gpc4 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpx0: gpx0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + interrupt-parent = <&combiner>; + #interrupt-cells = <2>; + interrupts = <23 0>, <24 0>, <25 0>, <25 1>, + <26 0>, <26 1>, <27 0>, <27 1>; + }; + + gpx1: gpx1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + interrupt-parent = <&combiner>; + #interrupt-cells = <2>; + interrupts = <28 0>, <28 1>, <29 0>, <29 1>, + <30 0>, <30 1>, <31 0>, <31 1>; + }; + + gpx2: gpx2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpx3: gpx3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + uart0_data: uart0-data { + samsung,pins = "gpa0-0", "gpa0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart0_fctl: uart0-fctl { + samsung,pins = "gpa0-2", "gpa0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c2_bus: i2c2-bus { + samsung,pins = "gpa0-6", "gpa0-7"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c2_hs_bus: i2c2-hs-bus { + samsung,pins = "gpa0-6", "gpa0-7"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + uart2_data: uart2-data { + samsung,pins = "gpa1-0", "gpa1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart2_fctl: uart2-fctl { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c3_bus: i2c3-bus { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c3_hs_bus: i2c3-hs-bus { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + uart3_data: uart3-data { + samsung,pins = "gpa1-4", "gpa1-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spi0_bus: spi0-bus { + samsung,pins = "gpa2-0", "gpa2-2", "gpa2-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c4_bus: i2c4-bus { + samsung,pins = "gpa2-0", "gpa2-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c5_bus: i2c5-bus { + samsung,pins = "gpa2-2", "gpa2-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + spi1_bus: spi1-bus { + samsung,pins = "gpa2-4", "gpa2-6", "gpa2-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2s1_bus: i2s1-bus { + samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", + "gpb0-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm1_bus: pcm1-bus { + samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", + "gpb0-4"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + ac97_bus: ac97-bus { + samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", + "gpb0-4"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2s2_bus: i2s2-bus { + samsung,pins = "gpb1-0", "gpb1-1", "gpb1-2", "gpb1-3", + "gpb1-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm2_bus: pcm2-bus { + samsung,pins = "gpb1-0", "gpb1-1", "gpb1-2", "gpb1-3", + "gpb1-4"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spdif_bus: spdif-bus { + samsung,pins = "gpb1-0", "gpb1-1"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spi2_bus: spi2-bus { + samsung,pins = "gpb1-1", "gpb1-3", "gpb1-4"; + samsung,pin-function = <5>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c6_bus: i2c6-bus { + samsung,pins = "gpb1-3", "gpb1-4"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c7_bus: i2c7-bus { + samsung,pins = "gpb2-2", "gpb2-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c0_bus: i2c0-bus { + samsung,pins = "gpb3-0", "gpb3-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c1_bus: i2c1-bus { + samsung,pins = "gpb3-2", "gpb3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c0_hs_bus: i2c0-hs-bus { + samsung,pins = "gpb3-0", "gpb3-1"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c1_hs_bus: i2c1-hs-bus { + samsung,pins = "gpb3-2", "gpb3-3"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + sd0_clk: sd0-clk { + samsung,pins = "gpc0-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd0_cmd: sd0-cmd { + samsung,pins = "gpc0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd0_cd: sd0-cd { + samsung,pins = "gpc0-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus1: sd0-bus-width1 { + samsung,pins = "gpc0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus4: sd0-bus-width4 { + samsung,pins = "gpc0-3", "gpc0-4", "gpc0-5", "gpc0-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus8: sd0-bus-width8 { + samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_clk: sd1-clk { + samsung,pins = "gpc2-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd1_cmd: sd1-cmd { + samsung,pins = "gpc2-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd1_cd: sd1-cd { + samsung,pins = "gpc2-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_bus1: sd1-bus-width1 { + samsung,pins = "gpc2-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_bus4: sd1-bus-width4 { + samsung,pins = "gpc2-3", "gpc2-4", "gpc2-5", "gpc2-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_clk: sd2-clk { + samsung,pins = "gpc3-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd2_cmd: sd2-cmd { + samsung,pins = "gpc3-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd2_cd: sd2-cd { + samsung,pins = "gpc3-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus1: sd2-bus-width1 { + samsung,pins = "gpc3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus4: sd2-bus-width4 { + samsung,pins = "gpc3-3", "gpc3-4", "gpc3-5", "gpc3-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus8: sd2-bus-width8 { + samsung,pins = "gpc4-3", "gpc4-4", "gpc4-5", "gpc4-6"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_clk: sd3-clk { + samsung,pins = "gpc4-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd3_cmd: sd3-cmd { + samsung,pins = "gpc4-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd3_cd: sd3-cd { + samsung,pins = "gpc4-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_bus1: sd3-bus-width1 { + samsung,pins = "gpc4-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd3_bus4: sd3-bus-width4 { + samsung,pins = "gpc4-3", "gpc4-4", "gpc4-5", "gpc4-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + uart1_data: uart1-data { + samsung,pins = "gpd0-0", "gpd0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart1_fctl: uart1-fctl { + samsung,pins = "gpd0-2", "gpd0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + dp_hpd: dp_hpd { + samsung,pins = "gpx0-7"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@13400000 { + gpe0: gpe0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpe1: gpe1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf0: gpf0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf1: gpf1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpg0: gpg0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpg1: gpg1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpg2: gpg2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gph0: gph0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gph1: gph1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + cam_gpio_a: cam-gpio-a { + samsung,pins = "gpe0-0", "gpe0-1", "gpe0-2", "gpe0-3", + "gpe0-4", "gpe0-5", "gpe0-6", "gpe0-7", + "gpe1-0", "gpe1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_gpio_b: cam-gpio-b { + samsung,pins = "gpf0-0", "gpf0-1", "gpf0-2", "gpf0-3", + "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_i2c2_bus: cam-i2c2-bus { + samsung,pins = "gpe0-6", "gpe1-0"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + cam_spi1_bus: cam-spi1-bus { + samsung,pins = "gpe0-4", "gpe0-5", "gpf0-2", "gpf0-3"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_i2c1_bus: cam-i2c1-bus { + samsung,pins = "gpf0-2", "gpf0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + cam_i2c0_bus: cam-i2c0-bus { + samsung,pins = "gpf0-0", "gpf0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + cam_spi0_bus: cam-spi0-bus { + samsung,pins = "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_bayrgb_bus: cam-bayrgb-bus { + samsung,pins = "gpg0-0", "gpg0-1", "gpg0-2", "gpg0-3", + "gpg0-4", "gpg0-5", "gpg0-6", "gpg0-7", + "gpg1-0", "gpg1-1", "gpg1-2", "gpg1-3", + "gpg1-4", "gpg1-5", "gpg1-6", "gpg1-7", + "gpg2-0", "gpg2-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_port_a: cam-port-a { + samsung,pins = "gph0-0", "gph0-1", "gph0-2", "gph0-3", + "gph1-0", "gph1-1", "gph1-2", "gph1-3", + "gph1-4", "gph1-5", "gph1-6", "gph1-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@10d10000 { + gpv0: gpv0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpv1: gpv1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpv2: gpv2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpv3: gpv3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpv4: gpv4 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + c2c_rxd: c2c-rxd { + samsung,pins = "gpv0-0", "gpv0-1", "gpv0-2", "gpv0-3", + "gpv0-4", "gpv0-5", "gpv0-6", "gpv0-7", + "gpv1-0", "gpv1-1", "gpv1-2", "gpv1-3", + "gpv1-4", "gpv1-5", "gpv1-6", "gpv1-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + c2c_txd: c2c-txd { + samsung,pins = "gpv2-0", "gpv2-1", "gpv2-2", "gpv2-3", + "gpv2-4", "gpv2-5", "gpv2-6", "gpv2-7", + "gpv3-0", "gpv3-1", "gpv3-2", "gpv3-3", + "gpv3-4", "gpv3-5", "gpv3-6", "gpv3-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@03860000 { + gpz: gpz { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + i2s0_bus: i2s0-bus { + samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", + "gpz-4", "gpz-5", "gpz-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; +}; diff --git a/arch/arm/dts/exynos5250.dtsi b/arch/arm/dts/exynos5250.dtsi index 771f8d3..16581dd 100644 --- a/arch/arm/dts/exynos5250.dtsi +++ b/arch/arm/dts/exynos5250.dtsi @@ -6,8 +6,46 @@ */
#include "exynos5.dtsi" +#include "exynos5250-pinctrl.dtsi"
/ { + aliases { + pinctrl0 = &pinctrl_0; + pinctrl1 = &pinctrl_1; + pinctrl2 = &pinctrl_2; + pinctrl3 = &pinctrl_3; + }; + + pinctrl_0: pinctrl@11400000 { + compatible = "samsung,exynos5250-pinctrl"; + reg = <0x11400000 0x1000>; + interrupts = <0 46 0>; + + wakup_eint: wakeup-interrupt-controller { + compatible = "samsung,exynos4210-wakeup-eint"; + interrupt-parent = <&gic>; + interrupts = <0 32 0>; + }; + }; + + pinctrl_1: pinctrl@13400000 { + compatible = "samsung,exynos5250-pinctrl"; + reg = <0x13400000 0x1000>; + interrupts = <0 45 0>; + }; + + pinctrl_2: pinctrl@10d10000 { + compatible = "samsung,exynos5250-pinctrl"; + reg = <0x10d10000 0x1000>; + interrupts = <0 50 0>; + }; + + pinctrl_3: pinctrl@03860000 { + compatible = "samsung,exynos5250-pinctrl"; + reg = <0x03860000 0x1000>; + interrupts = <0 47 0>; + }; + i2c@12ca0000 { #address-cells = <1>; #size-cells = <0>; diff --git a/arch/arm/dts/exynos54xx-pinctrl.dtsi b/arch/arm/dts/exynos54xx-pinctrl.dtsi new file mode 100644 index 0000000..e62c8eb --- /dev/null +++ b/arch/arm/dts/exynos54xx-pinctrl.dtsi @@ -0,0 +1,687 @@ +/* + * Samsung's Exynos5420 SoC pin-mux and pin-config device tree source + * + * Copyright (c) 2013 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * Samsung's Exynos5420 SoC pin-mux and pin-config options are listed as device + * tree nodes are listed in this file. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +/ { + pinctrl@13400000 { + gpy7: gpy7 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpx0: gpx0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + interrupt-parent = <&combiner>; + #interrupt-cells = <2>; + interrupts = <23 0>, <24 0>, <25 0>, <25 1>, + <26 0>, <26 1>, <27 0>, <27 1>; + }; + + gpx1: gpx1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + interrupt-parent = <&combiner>; + #interrupt-cells = <2>; + interrupts = <28 0>, <28 1>, <29 0>, <29 1>, + <30 0>, <30 1>, <31 0>, <31 1>; + }; + + gpx2: gpx2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpx3: gpx3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + dp_hpd: dp_hpd { + samsung,pins = "gpx0-7"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@13410000 { + gpc0: gpc0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc1: gpc1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc2: gpc2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc3: gpc3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpc4: gpc4 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpd1: gpd1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpy0: gpy0 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy1: gpy1 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy2: gpy2 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy3: gpy3 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy4: gpy4 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy5: gpy5 { + gpio-controller; + #gpio-cells = <2>; + }; + + gpy6: gpy6 { + gpio-controller; + #gpio-cells = <2>; + }; + + sd0_clk: sd0-clk { + samsung,pins = "gpc0-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd0_cmd: sd0-cmd { + samsung,pins = "gpc0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd0_cd: sd0-cd { + samsung,pins = "gpc0-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus1: sd0-bus-width1 { + samsung,pins = "gpc0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus4: sd0-bus-width4 { + samsung,pins = "gpc0-4", "gpc0-5", "gpc0-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd0_bus8: sd0-bus-width8 { + samsung,pins = "gpc3-0", "gpc3-1", "gpc3-2", "gpc3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_clk: sd1-clk { + samsung,pins = "gpc1-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd1_cmd: sd1-cmd { + samsung,pins = "gpc1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd1_cd: sd1-cd { + samsung,pins = "gpc1-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_int: sd1-int { + samsung,pins = "gpd1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + sd1_bus1: sd1-bus-width1 { + samsung,pins = "gpc1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_bus4: sd1-bus-width4 { + samsung,pins = "gpc1-4", "gpc1-5", "gpc1-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd1_bus8: sd1-bus-width8 { + samsung,pins = "gpd1-4", "gpd1-5", "gpd1-6", "gpd1-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_clk: sd2-clk { + samsung,pins = "gpc2-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd2_cmd: sd2-cmd { + samsung,pins = "gpc2-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <3>; + }; + + sd2_cd: sd2-cd { + samsung,pins = "gpc2-2"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus1: sd2-bus-width1 { + samsung,pins = "gpc2-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + + sd2_bus4: sd2-bus-width4 { + samsung,pins = "gpc2-4", "gpc2-5", "gpc2-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <3>; + }; + }; + + pinctrl@14000000 { + gpe0: gpe0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpe1: gpe1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf0: gpf0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpf1: gpf1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpg0: gpg0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpg1: gpg1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpg2: gpg2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpj4: gpj4 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + cam_gpio_a: cam-gpio-a { + samsung,pins = "gpe0-0", "gpe0-1", "gpe0-2", "gpe0-3", + "gpe0-4", "gpe0-5", "gpe0-6", "gpe0-7", + "gpe1-0", "gpe1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_gpio_b: cam-gpio-b { + samsung,pins = "gpf0-0", "gpf0-1", "gpf0-2", "gpf0-3", + "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_i2c2_bus: cam-i2c2-bus { + samsung,pins = "gpf0-4", "gpf0-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + cam_spi1_bus: cam-spi1-bus { + samsung,pins = "gpe0-4", "gpe0-5", "gpf0-2", "gpf0-3"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_i2c1_bus: cam-i2c1-bus { + samsung,pins = "gpf0-2", "gpf0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + cam_i2c0_bus: cam-i2c0-bus { + samsung,pins = "gpf0-0", "gpf0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + cam_spi0_bus: cam-spi0-bus { + samsung,pins = "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + cam_bayrgb_bus: cam-bayrgb-bus { + samsung,pins = "gpg0-0", "gpg0-1", "gpg0-2", "gpg0-3", + "gpg0-4", "gpg0-5", "gpg0-6", "gpg0-7", + "gpg1-0", "gpg1-1", "gpg1-2", "gpg1-3", + "gpg1-4", "gpg1-5", "gpg1-6", "gpg1-7", + "gpg2-0"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@14010000 { + gpa0: gpa0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpa1: gpa1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpa2: gpa2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb0: gpb0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb1: gpb1 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb2: gpb2 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb3: gpb3 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpb4: gpb4 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + gph0: gph0 { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + uart0_data: uart0-data { + samsung,pins = "gpa0-0", "gpa0-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart0_fctl: uart0-fctl { + samsung,pins = "gpa0-2", "gpa0-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart1_data: uart1-data { + samsung,pins = "gpa0-4", "gpa0-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart1_fctl: uart1-fctl { + samsung,pins = "gpa0-6", "gpa0-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c2_bus: i2c2-bus { + samsung,pins = "gpa0-6", "gpa0-7"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + uart2_data: uart2-data { + samsung,pins = "gpa1-0", "gpa1-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + uart2_fctl: uart2-fctl { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2c3_bus: i2c3-bus { + samsung,pins = "gpa1-2", "gpa1-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + uart3_data: uart3-data { + samsung,pins = "gpa1-4", "gpa1-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spi0_bus: spi0-bus { + samsung,pins = "gpa2-0", "gpa2-1", "gpa2-2", "gpa2-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + spi1_bus: spi1-bus { + samsung,pins = "gpa2-4", "gpa2-6", "gpa2-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c4_hs_bus: i2c4-hs-bus { + samsung,pins = "gpa2-0", "gpa2-1"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c5_hs_bus: i2c5-hs-bus { + samsung,pins = "gpa2-2", "gpa2-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2s1_bus: i2s1-bus { + samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", + "gpb0-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm1_bus: pcm1-bus { + samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", + "gpb0-4"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + i2s2_bus: i2s2-bus { + samsung,pins = "gpb1-0", "gpb1-1", "gpb1-2", "gpb1-3", + "gpb1-4"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + pcm2_bus: pcm2-bus { + samsung,pins = "gpb1-0", "gpb1-1", "gpb1-2", "gpb1-3", + "gpb1-4"; + samsung,pin-function = <3>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spdif_bus: spdif-bus { + samsung,pins = "gpb1-0", "gpb1-1"; + samsung,pin-function = <4>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + + spi2_bus: spi2-bus { + samsung,pins = "gpb1-1", "gpb1-3", "gpb1-4"; + samsung,pin-function = <5>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c6_hs_bus: i2c6-hs-bus { + samsung,pins = "gpb1-3", "gpb1-4"; + samsung,pin-function = <4>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c7_hs_bus: i2c7-hs-bus { + samsung,pins = "gpb2-2", "gpb2-3"; + samsung,pin-function = <3>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c0_bus: i2c0-bus { + samsung,pins = "gpb3-0", "gpb3-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c1_bus: i2c1-bus { + samsung,pins = "gpb3-2", "gpb3-3"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c8_hs_bus: i2c8-hs-bus { + samsung,pins = "gpb3-4", "gpb3-5"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c9_hs_bus: i2c9-hs-bus { + samsung,pins = "gpb3-6", "gpb3-7"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + + i2c10_hs_bus: i2c10-hs-bus { + samsung,pins = "gpb4-0", "gpb4-1"; + samsung,pin-function = <2>; + samsung,pin-pud = <3>; + samsung,pin-drv = <0>; + }; + }; + + pinctrl@03860000 { + gpz: gpz { + gpio-controller; + #gpio-cells = <2>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + i2s0_bus: i2s0-bus { + samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", + "gpz-4", "gpz-5", "gpz-6"; + samsung,pin-function = <2>; + samsung,pin-pud = <0>; + samsung,pin-drv = <0>; + }; + }; +}; diff --git a/arch/arm/dts/exynos54xx.dtsi b/arch/arm/dts/exynos54xx.dtsi index 7892345..1a765ab 100644 --- a/arch/arm/dts/exynos54xx.dtsi +++ b/arch/arm/dts/exynos54xx.dtsi @@ -8,6 +8,14 @@ #include "exynos5.dtsi"
/ { + aliases { + pinctrl0 = &pinctrl_0; + pinctrl1 = &pinctrl_1; + pinctrl2 = &pinctrl_2; + pinctrl3 = &pinctrl_3; + pinctrl4 = &pinctrl_4; + }; + config { machine-arch-id = <4151>; }; @@ -123,6 +131,42 @@ reg = <0x14680000 0x100>; };
+ pinctrl_0: pinctrl@13400000 { + compatible = "samsung,exynos5420-pinctrl"; + reg = <0x13400000 0x1000>; + interrupts = <0 45 0>; + + wakeup-interrupt-controller { + compatible = "samsung,exynos4210-wakeup-eint"; + interrupt-parent = <&gic>; + interrupts = <0 32 0>; + }; + }; + + pinctrl_1: pinctrl@13410000 { + compatible = "samsung,exynos5420-pinctrl"; + reg = <0x13410000 0x1000>; + interrupts = <0 78 0>; + }; + + pinctrl_2: pinctrl@14000000 { + compatible = "samsung,exynos5420-pinctrl"; + reg = <0x14000000 0x1000>; + interrupts = <0 46 0>; + }; + + pinctrl_3: pinctrl@14010000 { + compatible = "samsung,exynos5420-pinctrl"; + reg = <0x14010000 0x1000>; + interrupts = <0 50 0>; + }; + + pinctrl_4: pinctrl@03860000 { + compatible = "samsung,exynos5420-pinctrl"; + reg = <0x03860000 0x1000>; + interrupts = <0 47 0>; + }; + fimd@14400000 { /* sysmmu is not used in U-Boot */ samsung,disable-sysmmu;
We don't include the pinctrl functions for U-Boot as they use up quite a bit of space and are not used.
We could instead perhaps eliminate this material with fdtgrep, but so far this tool has not made it to upstream.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
arch/arm/dts/exynos4210-pinctrl.dtsi | 543 ------------------------------- arch/arm/dts/exynos4x12-pinctrl.dtsi | 612 ----------------------------------- arch/arm/dts/exynos4x12.dtsi | 100 ------ arch/arm/dts/exynos5250-pinctrl.dtsi | 459 -------------------------- arch/arm/dts/exynos54xx-pinctrl.dtsi | 384 ---------------------- 5 files changed, 2098 deletions(-)
diff --git a/arch/arm/dts/exynos4210-pinctrl.dtsi b/arch/arm/dts/exynos4210-pinctrl.dtsi index a7c2128..bda17f7 100644 --- a/arch/arm/dts/exynos4210-pinctrl.dtsi +++ b/arch/arm/dts/exynos4210-pinctrl.dtsi @@ -144,281 +144,6 @@ #interrupt-cells = <2>; };
- uart0_data: uart0-data { - samsung,pins = "gpa0-0", "gpa0-1"; - samsung,pin-function = <0x2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart0_fctl: uart0-fctl { - samsung,pins = "gpa0-2", "gpa0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart1_data: uart1-data { - samsung,pins = "gpa0-4", "gpa0-5"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart1_fctl: uart1-fctl { - samsung,pins = "gpa0-6", "gpa0-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c2_bus: i2c2-bus { - samsung,pins = "gpa0-6", "gpa0-7"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - uart2_data: uart2-data { - samsung,pins = "gpa1-0", "gpa1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart2_fctl: uart2-fctl { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart_audio_a: uart-audio-a { - samsung,pins = "gpa1-0", "gpa1-1"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c3_bus: i2c3-bus { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - uart3_data: uart3-data { - samsung,pins = "gpa1-4", "gpa1-5"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart_audio_b: uart-audio-b { - samsung,pins = "gpa1-4", "gpa1-5"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spi0_bus: spi0-bus { - samsung,pins = "gpb-0", "gpb-2", "gpb-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c4_bus: i2c4-bus { - samsung,pins = "gpb-2", "gpb-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - spi1_bus: spi1-bus { - samsung,pins = "gpb-4", "gpb-6", "gpb-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c5_bus: i2c5-bus { - samsung,pins = "gpb-6", "gpb-7"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2s1_bus: i2s1-bus { - samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", - "gpc0-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm1_bus: pcm1-bus { - samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", - "gpc0-4"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - ac97_bus: ac97-bus { - samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", - "gpc0-4"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2s2_bus: i2s2-bus { - samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3", - "gpc1-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm2_bus: pcm2-bus { - samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3", - "gpc1-4"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spdif_bus: spdif-bus { - samsung,pins = "gpc1-0", "gpc1-1"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c6_bus: i2c6-bus { - samsung,pins = "gpc1-3", "gpc1-4"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - spi2_bus: spi2-bus { - samsung,pins = "gpc1-1", "gpc1-2", "gpc1-3", "gpc1-4"; - samsung,pin-function = <5>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c7_bus: i2c7-bus { - samsung,pins = "gpd0-2", "gpd0-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c0_bus: i2c0-bus { - samsung,pins = "gpd1-0", "gpd1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c1_bus: i2c1-bus { - samsung,pins = "gpd1-2", "gpd1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - pwm0_out: pwm0-out { - samsung,pins = "gpd0-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pwm1_out: pwm1-out { - samsung,pins = "gpd0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pwm2_out: pwm2-out { - samsung,pins = "gpd0-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pwm3_out: pwm3-out { - samsung,pins = "gpd0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_ctrl: lcd-ctrl { - samsung,pins = "gpd0-0", "gpd0-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_sync: lcd-sync { - samsung,pins = "gpf0-0", "gpf0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_en: lcd-en { - samsung,pins = "gpe3-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_clk: lcd-clk { - samsung,pins = "gpf0-0", "gpf0-1", "gpf0-2", "gpf0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_data16: lcd-data-width16 { - samsung,pins = "gpf0-7", "gpf1-0", "gpf1-1", "gpf1-2", - "gpf1-3", "gpf1-6", "gpf1-7", "gpf2-0", - "gpf2-1", "gpf2-2", "gpf2-3", "gpf2-7", - "gpf3-0", "gpf3-1", "gpf3-2", "gpf3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_data18: lcd-data-width18 { - samsung,pins = "gpf0-6", "gpf0-7", "gpf1-0", "gpf1-1", - "gpf1-2", "gpf1-3", "gpf1-6", "gpf1-7", - "gpf2-0", "gpf2-1", "gpf2-2", "gpf2-3", - "gpf2-6", "gpf2-7", "gpf3-0", "gpf3-1", - "gpf3-2", "gpf3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_data24: lcd-data-width24 { - samsung,pins = "gpf0-4", "gpf0-5", "gpf0-6", "gpf0-7", - "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3", - "gpf1-4", "gpf1-5", "gpf1-6", "gpf1-7", - "gpf2-0", "gpf2-1", "gpf2-2", "gpf2-3", - "gpf2-4", "gpf2-5", "gpf2-6", "gpf2-7", - "gpf3-0", "gpf3-1", "gpf3-2", "gpf3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; };
pinctrl@11000000 { @@ -567,259 +292,6 @@ #interrupt-cells = <2>; };
- sd0_clk: sd0-clk { - samsung,pins = "gpk0-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd0_cmd: sd0-cmd { - samsung,pins = "gpk0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd0_cd: sd0-cd { - samsung,pins = "gpk0-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus1: sd0-bus-width1 { - samsung,pins = "gpk0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus4: sd0-bus-width4 { - samsung,pins = "gpk0-3", "gpk0-4", "gpk0-5", "gpk0-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus8: sd0-bus-width8 { - samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd4_clk: sd4-clk { - samsung,pins = "gpk0-0"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd4_cmd: sd4-cmd { - samsung,pins = "gpk0-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd4_cd: sd4-cd { - samsung,pins = "gpk0-2"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd4_bus1: sd4-bus-width1 { - samsung,pins = "gpk0-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd4_bus4: sd4-bus-width4 { - samsung,pins = "gpk0-3", "gpk0-4", "gpk0-5", "gpk0-6"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd4_bus8: sd4-bus-width8 { - samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; - samsung,pin-function = <3>; - samsung,pin-pud = <4>; - samsung,pin-drv = <3>; - }; - - sd1_clk: sd1-clk { - samsung,pins = "gpk1-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd1_cmd: sd1-cmd { - samsung,pins = "gpk1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd1_cd: sd1-cd { - samsung,pins = "gpk1-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_bus1: sd1-bus-width1 { - samsung,pins = "gpk1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_bus4: sd1-bus-width4 { - samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_clk: sd2-clk { - samsung,pins = "gpk2-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd2_cmd: sd2-cmd { - samsung,pins = "gpk2-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd2_cd: sd2-cd { - samsung,pins = "gpk2-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus1: sd2-bus-width1 { - samsung,pins = "gpk2-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus4: sd2-bus-width4 { - samsung,pins = "gpk2-3", "gpk2-4", "gpk2-5", "gpk2-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus8: sd2-bus-width8 { - samsung,pins = "gpk3-3", "gpk3-4", "gpk3-5", "gpk3-6"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_clk: sd3-clk { - samsung,pins = "gpk3-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd3_cmd: sd3-cmd { - samsung,pins = "gpk3-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd3_cd: sd3-cd { - samsung,pins = "gpk3-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_bus1: sd3-bus-width1 { - samsung,pins = "gpk3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_bus4: sd3-bus-width4 { - samsung,pins = "gpk3-3", "gpk3-4", "gpk3-5", "gpk3-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - eint0: ext-int0 { - samsung,pins = "gpx0-0"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - eint8: ext-int8 { - samsung,pins = "gpx1-0"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - eint15: ext-int15 { - samsung,pins = "gpx1-7"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - eint16: ext-int16 { - samsung,pins = "gpx2-0"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - eint31: ext-int31 { - samsung,pins = "gpx3-7"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_port_a_io: cam-port-a-io { - samsung,pins = "gpj0-0", "gpj0-1", "gpj0-2", "gpj0-3", - "gpj0-4", "gpj0-5", "gpj0-6", "gpj0-7", - "gpj1-0", "gpj1-1", "gpj1-2", "gpj1-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_port_a_clk_active: cam-port-a-clk-active { - samsung,pins = "gpj1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - cam_port_a_clk_idle: cam-port-a-clk-idle { - samsung,pins = "gpj1-3"; - samsung,pin-function = <0>; - samsung,pin-pud = <1>; - samsung,pin-drv = <0>; - }; };
pinctrl@03860000 { @@ -828,20 +300,5 @@ #gpio-cells = <2>; };
- i2s0_bus: i2s0-bus { - samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", - "gpz-4", "gpz-5", "gpz-6"; - samsung,pin-function = <0x2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm0_bus: pcm0-bus { - samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", - "gpz-4"; - samsung,pin-function = <0x3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; }; }; diff --git a/arch/arm/dts/exynos4x12-pinctrl.dtsi b/arch/arm/dts/exynos4x12-pinctrl.dtsi index 99b26df..93f3998 100644 --- a/arch/arm/dts/exynos4x12-pinctrl.dtsi +++ b/arch/arm/dts/exynos4x12-pinctrl.dtsi @@ -117,312 +117,6 @@ interrupt-controller; #interrupt-cells = <2>; }; - - uart0_data: uart0-data { - samsung,pins = "gpa0-0", "gpa0-1"; - samsung,pin-function = <0x2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart0_fctl: uart0-fctl { - samsung,pins = "gpa0-2", "gpa0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart1_data: uart1-data { - samsung,pins = "gpa0-4", "gpa0-5"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart1_fctl: uart1-fctl { - samsung,pins = "gpa0-6", "gpa0-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c2_bus: i2c2-bus { - samsung,pins = "gpa0-6", "gpa0-7"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - uart2_data: uart2-data { - samsung,pins = "gpa1-0", "gpa1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart2_fctl: uart2-fctl { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart_audio_a: uart-audio-a { - samsung,pins = "gpa1-0", "gpa1-1"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c3_bus: i2c3-bus { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - uart3_data: uart3-data { - samsung,pins = "gpa1-4", "gpa1-5"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart_audio_b: uart-audio-b { - samsung,pins = "gpa1-4", "gpa1-5"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spi0_bus: spi0-bus { - samsung,pins = "gpb-0", "gpb-2", "gpb-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c4_bus: i2c4-bus { - samsung,pins = "gpb-0", "gpb-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - spi1_bus: spi1-bus { - samsung,pins = "gpb-4", "gpb-6", "gpb-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c5_bus: i2c5-bus { - samsung,pins = "gpb-2", "gpb-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2s1_bus: i2s1-bus { - samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", - "gpc0-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm1_bus: pcm1-bus { - samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", - "gpc0-4"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - ac97_bus: ac97-bus { - samsung,pins = "gpc0-0", "gpc0-1", "gpc0-2", "gpc0-3", - "gpc0-4"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2s2_bus: i2s2-bus { - samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3", - "gpc1-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm2_bus: pcm2-bus { - samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3", - "gpc1-4"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spdif_bus: spdif-bus { - samsung,pins = "gpc1-0", "gpc1-1"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c6_bus: i2c6-bus { - samsung,pins = "gpc1-3", "gpc1-4"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - spi2_bus: spi2-bus { - samsung,pins = "gpc1-1", "gpc1-3", "gpc1-4"; - samsung,pin-function = <5>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - pwm0_out: pwm0-out { - samsung,pins = "gpd0-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pwm1_out: pwm1-out { - samsung,pins = "gpd0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_ctrl: lcd-ctrl { - samsung,pins = "gpd0-0", "gpd0-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c7_bus: i2c7-bus { - samsung,pins = "gpd0-2", "gpd0-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - pwm2_out: pwm2-out { - samsung,pins = "gpd0-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pwm3_out: pwm3-out { - samsung,pins = "gpd0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c0_bus: i2c0-bus { - samsung,pins = "gpd1-0", "gpd1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - mipi0_clk: mipi0-clk { - samsung,pins = "gpd1-0", "gpd1-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c1_bus: i2c1-bus { - samsung,pins = "gpd1-2", "gpd1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - mipi1_clk: mipi1-clk { - samsung,pins = "gpd1-2", "gpd1-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_clk: lcd-clk { - samsung,pins = "gpf0-0", "gpf0-1", "gpf0-2", "gpf0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_data16: lcd-data-width16 { - samsung,pins = "gpf0-7", "gpf1-0", "gpf1-1", "gpf1-2", - "gpf1-3", "gpf1-6", "gpf1-7", "gpf2-0", - "gpf2-1", "gpf2-2", "gpf2-3", "gpf2-7", - "gpf3-0", "gpf3-1", "gpf3-2", "gpf3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_data18: lcd-data-width18 { - samsung,pins = "gpf0-6", "gpf0-7", "gpf1-0", "gpf1-1", - "gpf1-2", "gpf1-3", "gpf1-6", "gpf1-7", - "gpf2-0", "gpf2-1", "gpf2-2", "gpf2-3", - "gpf2-6", "gpf2-7", "gpf3-0", "gpf3-1", - "gpf3-2", "gpf3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_data24: lcd-data-width24 { - samsung,pins = "gpf0-4", "gpf0-5", "gpf0-6", "gpf0-7", - "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3", - "gpf1-4", "gpf1-5", "gpf1-6", "gpf1-7", - "gpf2-0", "gpf2-1", "gpf2-2", "gpf2-3", - "gpf2-4", "gpf2-5", "gpf2-6", "gpf2-7", - "gpf3-0", "gpf3-1", "gpf3-2", "gpf3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - lcd_ldi: lcd-ldi { - samsung,pins = "gpf3-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_port_a_io: cam-port-a-io { - samsung,pins = "gpj0-0", "gpj0-1", "gpj0-2", "gpj0-3", - "gpj0-4", "gpj0-5", "gpj0-6", "gpj0-7", - "gpj1-0", "gpj1-1", "gpj1-2", "gpj1-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_port_a_clk_active: cam-port-a-clk-active { - samsung,pins = "gpj1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - cam_port_a_clk_idle: cam-port-a-clk-idle { - samsung,pins = "gpj1-3"; - samsung,pin-function = <0>; - samsung,pin-pud = <1>; - samsung,pin-drv = <0>; - }; };
pinctrl@11000000 { @@ -594,281 +288,6 @@ interrupt-controller; #interrupt-cells = <2>; }; - - sd0_clk: sd0-clk { - samsung,pins = "gpk0-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd0_cmd: sd0-cmd { - samsung,pins = "gpk0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd0_cd: sd0-cd { - samsung,pins = "gpk0-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus1: sd0-bus-width1 { - samsung,pins = "gpk0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus4: sd0-bus-width4 { - samsung,pins = "gpk0-3", "gpk0-4", "gpk0-5", "gpk0-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus8: sd0-bus-width8 { - samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd4_clk: sd4-clk { - samsung,pins = "gpk0-0"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd4_cmd: sd4-cmd { - samsung,pins = "gpk0-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd4_cd: sd4-cd { - samsung,pins = "gpk0-2"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd4_bus1: sd4-bus-width1 { - samsung,pins = "gpk0-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd4_bus4: sd4-bus-width4 { - samsung,pins = "gpk0-3", "gpk0-4", "gpk0-5", "gpk0-6"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd4_bus8: sd4-bus-width8 { - samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; - samsung,pin-function = <4>; - samsung,pin-pud = <4>; - samsung,pin-drv = <3>; - }; - - sd1_clk: sd1-clk { - samsung,pins = "gpk1-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd1_cmd: sd1-cmd { - samsung,pins = "gpk1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd1_cd: sd1-cd { - samsung,pins = "gpk1-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_bus1: sd1-bus-width1 { - samsung,pins = "gpk1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_bus4: sd1-bus-width4 { - samsung,pins = "gpk1-3", "gpk1-4", "gpk1-5", "gpk1-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_clk: sd2-clk { - samsung,pins = "gpk2-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd2_cmd: sd2-cmd { - samsung,pins = "gpk2-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd2_cd: sd2-cd { - samsung,pins = "gpk2-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus1: sd2-bus-width1 { - samsung,pins = "gpk2-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus4: sd2-bus-width4 { - samsung,pins = "gpk2-3", "gpk2-4", "gpk2-5", "gpk2-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus8: sd2-bus-width8 { - samsung,pins = "gpk3-3", "gpk3-4", "gpk3-5", "gpk3-6"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_clk: sd3-clk { - samsung,pins = "gpk3-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd3_cmd: sd3-cmd { - samsung,pins = "gpk3-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd3_cd: sd3-cd { - samsung,pins = "gpk3-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_bus1: sd3-bus-width1 { - samsung,pins = "gpk3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_bus4: sd3-bus-width4 { - samsung,pins = "gpk3-3", "gpk3-4", "gpk3-5", "gpk3-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - cam_port_b_io: cam-port-b-io { - samsung,pins = "gpm0-0", "gpm0-1", "gpm0-2", "gpm0-3", - "gpm0-4", "gpm0-5", "gpm0-6", "gpm0-7", - "gpm1-0", "gpm1-1", "gpm2-0", "gpm2-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - cam_port_b_clk_active: cam-port-b-clk-active { - samsung,pins = "gpm2-2"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - cam_port_b_clk_idle: cam-port-b-clk-idle { - samsung,pins = "gpm2-2"; - samsung,pin-function = <0>; - samsung,pin-pud = <1>; - samsung,pin-drv = <0>; - }; - - eint0: ext-int0 { - samsung,pins = "gpx0-0"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - eint8: ext-int8 { - samsung,pins = "gpx1-0"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - eint15: ext-int15 { - samsung,pins = "gpx1-7"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - eint16: ext-int16 { - samsung,pins = "gpx2-0"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - eint31: ext-int31 { - samsung,pins = "gpx3-7"; - samsung,pin-function = <0xf>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - fimc_is_i2c0: fimc-is-i2c0 { - samsung,pins = "gpm4-0", "gpm4-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - fimc_is_i2c1: fimc-is-i2c1 { - samsung,pins = "gpm4-2", "gpm4-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - fimc_is_uart: fimc-is-uart { - samsung,pins = "gpm3-5", "gpm3-7"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; };
pinctrl@03860000 { @@ -879,22 +298,6 @@ interrupt-controller; #interrupt-cells = <2>; }; - - i2s0_bus: i2s0-bus { - samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", - "gpz-4", "gpz-5", "gpz-6"; - samsung,pin-function = <0x2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm0_bus: pcm0-bus { - samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", - "gpz-4"; - samsung,pin-function = <0x3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; };
pinctrl@106E0000 { @@ -937,20 +340,5 @@ interrupt-controller; #interrupt-cells = <2>; }; - - c2c_bus: c2c-bus { - samsung,pins = "gpv0-0", "gpv0-1", "gpv0-2", "gpv0-3", - "gpv0-4", "gpv0-5", "gpv0-6", "gpv0-7", - "gpv1-0", "gpv1-1", "gpv1-2", "gpv1-3", - "gpv1-4", "gpv1-5", "gpv1-6", "gpv1-7", - "gpv2-0", "gpv2-1", "gpv2-2", "gpv2-3", - "gpv2-4", "gpv2-5", "gpv2-6", "gpv2-7", - "gpv3-0", "gpv3-1", "gpv3-2", "gpv3-3", - "gpv3-4", "gpv3-5", "gpv3-6", "gpv3-7", - "gpv4-0", "gpv4-1"; - samsung,pin-function = <0x2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; }; }; diff --git a/arch/arm/dts/exynos4x12.dtsi b/arch/arm/dts/exynos4x12.dtsi index 6b898c2..5bc8f31 100644 --- a/arch/arm/dts/exynos4x12.dtsi +++ b/arch/arm/dts/exynos4x12.dtsi @@ -26,8 +26,6 @@ pinctrl1 = &pinctrl_1; pinctrl2 = &pinctrl_2; pinctrl3 = &pinctrl_3; - fimc-lite0 = &fimc_lite_0; - fimc-lite1 = &fimc_lite_1; mshc0 = &mshc_0; };
@@ -102,104 +100,6 @@ status = "disabled"; };
- camera { - clocks = <&clock 132>, <&clock 133>, <&clock 351>, <&clock 352>; - clock-names = "sclk_cam0", "sclk_cam1", "pxl_async0", "pxl_async1"; - #address-cells = <1>; - #size-cells = <1>; - - fimc_0: fimc@11800000 { - compatible = "samsung,exynos4212-fimc"; - samsung,pix-limits = <4224 8192 1920 4224>; - samsung,mainscaler-ext; - samsung,isp-wb; - samsung,cam-if; - }; - - fimc_1: fimc@11810000 { - compatible = "samsung,exynos4212-fimc"; - samsung,pix-limits = <4224 8192 1920 4224>; - samsung,mainscaler-ext; - samsung,isp-wb; - samsung,cam-if; - }; - - fimc_2: fimc@11820000 { - compatible = "samsung,exynos4212-fimc"; - samsung,pix-limits = <4224 8192 1920 4224>; - samsung,mainscaler-ext; - samsung,isp-wb; - samsung,lcd-wb; - samsung,cam-if; - }; - - fimc_3: fimc@11830000 { - compatible = "samsung,exynos4212-fimc"; - samsung,pix-limits = <1920 8192 1366 1920>; - samsung,rotators = <0>; - samsung,mainscaler-ext; - samsung,isp-wb; - samsung,lcd-wb; - }; - - fimc_lite_0: fimc-lite@12390000 { - compatible = "samsung,exynos4212-fimc-lite"; - reg = <0x12390000 0x1000>; - interrupts = <0 105 0>; - samsung,power-domain = <&pd_isp>; - clocks = <&clock 353>; - clock-names = "flite"; - status = "disabled"; - }; - - fimc_lite_1: fimc-lite@123A0000 { - compatible = "samsung,exynos4212-fimc-lite"; - reg = <0x123A0000 0x1000>; - interrupts = <0 106 0>; - samsung,power-domain = <&pd_isp>; - clocks = <&clock 354>; - clock-names = "flite"; - status = "disabled"; - }; - - fimc_is: fimc-is@12000000 { - compatible = "samsung,exynos4212-fimc-is", "simple-bus"; - reg = <0x12000000 0x260000>; - interrupts = <0 90 0>, <0 95 0>; - samsung,power-domain = <&pd_isp>; - clocks = <&clock 353>, <&clock 354>, <&clock 355>, - <&clock 356>, <&clock 17>, <&clock 357>, - <&clock 358>, <&clock 359>, <&clock 360>, - <&clock 450>,<&clock 451>, <&clock 452>, - <&clock 453>, <&clock 176>, <&clock 13>, - <&clock 454>, <&clock 395>, <&clock 455>; - clock-names = "lite0", "lite1", "ppmuispx", - "ppmuispmx", "mpll", "isp", - "drc", "fd", "mcuisp", - "ispdiv0", "ispdiv1", "mcuispdiv0", - "mcuispdiv1", "uart", "aclk200", - "div_aclk200", "aclk400mcuisp", - "div_aclk400mcuisp"; - #address-cells = <1>; - #size-cells = <1>; - ranges; - status = "disabled"; - - pmu { - reg = <0x10020000 0x3000>; - }; - - i2c1_isp: i2c-isp@12140000 { - compatible = "samsung,exynos4212-i2c-isp"; - reg = <0x12140000 0x100>; - clocks = <&clock 370>; - clock-names = "i2c_isp"; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - }; - mshc_0: mmc@12550000 { compatible = "samsung,exynos4412-dw-mshc"; reg = <0x12550000 0x1000>; diff --git a/arch/arm/dts/exynos5250-pinctrl.dtsi b/arch/arm/dts/exynos5250-pinctrl.dtsi index 9a49e68..67755a1 100644 --- a/arch/arm/dts/exynos5250-pinctrl.dtsi +++ b/arch/arm/dts/exynos5250-pinctrl.dtsi @@ -198,368 +198,6 @@ interrupt-controller; #interrupt-cells = <2>; }; - - uart0_data: uart0-data { - samsung,pins = "gpa0-0", "gpa0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart0_fctl: uart0-fctl { - samsung,pins = "gpa0-2", "gpa0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c2_bus: i2c2-bus { - samsung,pins = "gpa0-6", "gpa0-7"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c2_hs_bus: i2c2-hs-bus { - samsung,pins = "gpa0-6", "gpa0-7"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - uart2_data: uart2-data { - samsung,pins = "gpa1-0", "gpa1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart2_fctl: uart2-fctl { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c3_bus: i2c3-bus { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c3_hs_bus: i2c3-hs-bus { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - uart3_data: uart3-data { - samsung,pins = "gpa1-4", "gpa1-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spi0_bus: spi0-bus { - samsung,pins = "gpa2-0", "gpa2-2", "gpa2-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c4_bus: i2c4-bus { - samsung,pins = "gpa2-0", "gpa2-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c5_bus: i2c5-bus { - samsung,pins = "gpa2-2", "gpa2-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - spi1_bus: spi1-bus { - samsung,pins = "gpa2-4", "gpa2-6", "gpa2-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2s1_bus: i2s1-bus { - samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", - "gpb0-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm1_bus: pcm1-bus { - samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", - "gpb0-4"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - ac97_bus: ac97-bus { - samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", - "gpb0-4"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2s2_bus: i2s2-bus { - samsung,pins = "gpb1-0", "gpb1-1", "gpb1-2", "gpb1-3", - "gpb1-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm2_bus: pcm2-bus { - samsung,pins = "gpb1-0", "gpb1-1", "gpb1-2", "gpb1-3", - "gpb1-4"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spdif_bus: spdif-bus { - samsung,pins = "gpb1-0", "gpb1-1"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spi2_bus: spi2-bus { - samsung,pins = "gpb1-1", "gpb1-3", "gpb1-4"; - samsung,pin-function = <5>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c6_bus: i2c6-bus { - samsung,pins = "gpb1-3", "gpb1-4"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c7_bus: i2c7-bus { - samsung,pins = "gpb2-2", "gpb2-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c0_bus: i2c0-bus { - samsung,pins = "gpb3-0", "gpb3-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c1_bus: i2c1-bus { - samsung,pins = "gpb3-2", "gpb3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c0_hs_bus: i2c0-hs-bus { - samsung,pins = "gpb3-0", "gpb3-1"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c1_hs_bus: i2c1-hs-bus { - samsung,pins = "gpb3-2", "gpb3-3"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - sd0_clk: sd0-clk { - samsung,pins = "gpc0-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd0_cmd: sd0-cmd { - samsung,pins = "gpc0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd0_cd: sd0-cd { - samsung,pins = "gpc0-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus1: sd0-bus-width1 { - samsung,pins = "gpc0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus4: sd0-bus-width4 { - samsung,pins = "gpc0-3", "gpc0-4", "gpc0-5", "gpc0-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus8: sd0-bus-width8 { - samsung,pins = "gpc1-0", "gpc1-1", "gpc1-2", "gpc1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_clk: sd1-clk { - samsung,pins = "gpc2-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd1_cmd: sd1-cmd { - samsung,pins = "gpc2-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd1_cd: sd1-cd { - samsung,pins = "gpc2-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_bus1: sd1-bus-width1 { - samsung,pins = "gpc2-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_bus4: sd1-bus-width4 { - samsung,pins = "gpc2-3", "gpc2-4", "gpc2-5", "gpc2-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_clk: sd2-clk { - samsung,pins = "gpc3-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd2_cmd: sd2-cmd { - samsung,pins = "gpc3-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd2_cd: sd2-cd { - samsung,pins = "gpc3-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus1: sd2-bus-width1 { - samsung,pins = "gpc3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus4: sd2-bus-width4 { - samsung,pins = "gpc3-3", "gpc3-4", "gpc3-5", "gpc3-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus8: sd2-bus-width8 { - samsung,pins = "gpc4-3", "gpc4-4", "gpc4-5", "gpc4-6"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_clk: sd3-clk { - samsung,pins = "gpc4-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd3_cmd: sd3-cmd { - samsung,pins = "gpc4-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd3_cd: sd3-cd { - samsung,pins = "gpc4-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_bus1: sd3-bus-width1 { - samsung,pins = "gpc4-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd3_bus4: sd3-bus-width4 { - samsung,pins = "gpc4-3", "gpc4-4", "gpc4-5", "gpc4-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - uart1_data: uart1-data { - samsung,pins = "gpd0-0", "gpd0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart1_fctl: uart1-fctl { - samsung,pins = "gpd0-2", "gpd0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - dp_hpd: dp_hpd { - samsung,pins = "gpx0-7"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; };
pinctrl@13400000 { @@ -635,77 +273,6 @@ #interrupt-cells = <2>; };
- cam_gpio_a: cam-gpio-a { - samsung,pins = "gpe0-0", "gpe0-1", "gpe0-2", "gpe0-3", - "gpe0-4", "gpe0-5", "gpe0-6", "gpe0-7", - "gpe1-0", "gpe1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_gpio_b: cam-gpio-b { - samsung,pins = "gpf0-0", "gpf0-1", "gpf0-2", "gpf0-3", - "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_i2c2_bus: cam-i2c2-bus { - samsung,pins = "gpe0-6", "gpe1-0"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - cam_spi1_bus: cam-spi1-bus { - samsung,pins = "gpe0-4", "gpe0-5", "gpf0-2", "gpf0-3"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_i2c1_bus: cam-i2c1-bus { - samsung,pins = "gpf0-2", "gpf0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - cam_i2c0_bus: cam-i2c0-bus { - samsung,pins = "gpf0-0", "gpf0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - cam_spi0_bus: cam-spi0-bus { - samsung,pins = "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_bayrgb_bus: cam-bayrgb-bus { - samsung,pins = "gpg0-0", "gpg0-1", "gpg0-2", "gpg0-3", - "gpg0-4", "gpg0-5", "gpg0-6", "gpg0-7", - "gpg1-0", "gpg1-1", "gpg1-2", "gpg1-3", - "gpg1-4", "gpg1-5", "gpg1-6", "gpg1-7", - "gpg2-0", "gpg2-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_port_a: cam-port-a { - samsung,pins = "gph0-0", "gph0-1", "gph0-2", "gph0-3", - "gph1-0", "gph1-1", "gph1-2", "gph1-3", - "gph1-4", "gph1-5", "gph1-6", "gph1-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; };
pinctrl@10d10000 { @@ -749,25 +316,6 @@ #interrupt-cells = <2>; };
- c2c_rxd: c2c-rxd { - samsung,pins = "gpv0-0", "gpv0-1", "gpv0-2", "gpv0-3", - "gpv0-4", "gpv0-5", "gpv0-6", "gpv0-7", - "gpv1-0", "gpv1-1", "gpv1-2", "gpv1-3", - "gpv1-4", "gpv1-5", "gpv1-6", "gpv1-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - c2c_txd: c2c-txd { - samsung,pins = "gpv2-0", "gpv2-1", "gpv2-2", "gpv2-3", - "gpv2-4", "gpv2-5", "gpv2-6", "gpv2-7", - "gpv3-0", "gpv3-1", "gpv3-2", "gpv3-3", - "gpv3-4", "gpv3-5", "gpv3-6", "gpv3-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; };
pinctrl@03860000 { @@ -779,12 +327,5 @@ #interrupt-cells = <2>; };
- i2s0_bus: i2s0-bus { - samsung,pins = "gpz-0", "gpz-1", "gpz-2", "gpz-3", - "gpz-4", "gpz-5", "gpz-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; }; }; diff --git a/arch/arm/dts/exynos54xx-pinctrl.dtsi b/arch/arm/dts/exynos54xx-pinctrl.dtsi index e62c8eb..b3e63d1 100644 --- a/arch/arm/dts/exynos54xx-pinctrl.dtsi +++ b/arch/arm/dts/exynos54xx-pinctrl.dtsi @@ -60,12 +60,6 @@ #interrupt-cells = <2>; };
pinctrl@13410000 { @@ -152,131 +146,6 @@ #gpio-cells = <2>; };
- sd0_clk: sd0-clk { - samsung,pins = "gpc0-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd0_cmd: sd0-cmd { - samsung,pins = "gpc0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd0_cd: sd0-cd { - samsung,pins = "gpc0-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus1: sd0-bus-width1 { - samsung,pins = "gpc0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus4: sd0-bus-width4 { - samsung,pins = "gpc0-4", "gpc0-5", "gpc0-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd0_bus8: sd0-bus-width8 { - samsung,pins = "gpc3-0", "gpc3-1", "gpc3-2", "gpc3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_clk: sd1-clk { - samsung,pins = "gpc1-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd1_cmd: sd1-cmd { - samsung,pins = "gpc1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd1_cd: sd1-cd { - samsung,pins = "gpc1-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_int: sd1-int { - samsung,pins = "gpd1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - sd1_bus1: sd1-bus-width1 { - samsung,pins = "gpc1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_bus4: sd1-bus-width4 { - samsung,pins = "gpc1-4", "gpc1-5", "gpc1-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd1_bus8: sd1-bus-width8 { - samsung,pins = "gpd1-4", "gpd1-5", "gpd1-6", "gpd1-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_clk: sd2-clk { - samsung,pins = "gpc2-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd2_cmd: sd2-cmd { - samsung,pins = "gpc2-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <3>; - }; - - sd2_cd: sd2-cd { - samsung,pins = "gpc2-2"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus1: sd2-bus-width1 { - samsung,pins = "gpc2-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; - - sd2_bus4: sd2-bus-width4 { - samsung,pins = "gpc2-4", "gpc2-5", "gpc2-6"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <3>; - }; };
pinctrl@14000000 { @@ -344,67 +213,6 @@ #interrupt-cells = <2>; };
- cam_gpio_a: cam-gpio-a { - samsung,pins = "gpe0-0", "gpe0-1", "gpe0-2", "gpe0-3", - "gpe0-4", "gpe0-5", "gpe0-6", "gpe0-7", - "gpe1-0", "gpe1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_gpio_b: cam-gpio-b { - samsung,pins = "gpf0-0", "gpf0-1", "gpf0-2", "gpf0-3", - "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_i2c2_bus: cam-i2c2-bus { - samsung,pins = "gpf0-4", "gpf0-5"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - cam_spi1_bus: cam-spi1-bus { - samsung,pins = "gpe0-4", "gpe0-5", "gpf0-2", "gpf0-3"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_i2c1_bus: cam-i2c1-bus { - samsung,pins = "gpf0-2", "gpf0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - cam_i2c0_bus: cam-i2c0-bus { - samsung,pins = "gpf0-0", "gpf0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - cam_spi0_bus: cam-spi0-bus { - samsung,pins = "gpf1-0", "gpf1-1", "gpf1-2", "gpf1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - cam_bayrgb_bus: cam-bayrgb-bus { - samsung,pins = "gpg0-0", "gpg0-1", "gpg0-2", "gpg0-3", - "gpg0-4", "gpg0-5", "gpg0-6", "gpg0-7", - "gpg1-0", "gpg1-1", "gpg1-2", "gpg1-3", - "gpg1-4", "gpg1-5", "gpg1-6", "gpg1-7", - "gpg2-0"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; };
pinctrl@14010000 { @@ -480,191 +288,6 @@ #interrupt-cells = <2>; };
- uart0_data: uart0-data { - samsung,pins = "gpa0-0", "gpa0-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart0_fctl: uart0-fctl { - samsung,pins = "gpa0-2", "gpa0-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart1_data: uart1-data { - samsung,pins = "gpa0-4", "gpa0-5"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart1_fctl: uart1-fctl { - samsung,pins = "gpa0-6", "gpa0-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c2_bus: i2c2-bus { - samsung,pins = "gpa0-6", "gpa0-7"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - uart2_data: uart2-data { - samsung,pins = "gpa1-0", "gpa1-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - uart2_fctl: uart2-fctl { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2c3_bus: i2c3-bus { - samsung,pins = "gpa1-2", "gpa1-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - uart3_data: uart3-data { - samsung,pins = "gpa1-4", "gpa1-5"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spi0_bus: spi0-bus { - samsung,pins = "gpa2-0", "gpa2-1", "gpa2-2", "gpa2-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - spi1_bus: spi1-bus { - samsung,pins = "gpa2-4", "gpa2-6", "gpa2-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c4_hs_bus: i2c4-hs-bus { - samsung,pins = "gpa2-0", "gpa2-1"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c5_hs_bus: i2c5-hs-bus { - samsung,pins = "gpa2-2", "gpa2-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2s1_bus: i2s1-bus { - samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", - "gpb0-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm1_bus: pcm1-bus { - samsung,pins = "gpb0-0", "gpb0-1", "gpb0-2", "gpb0-3", - "gpb0-4"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - i2s2_bus: i2s2-bus { - samsung,pins = "gpb1-0", "gpb1-1", "gpb1-2", "gpb1-3", - "gpb1-4"; - samsung,pin-function = <2>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - pcm2_bus: pcm2-bus { - samsung,pins = "gpb1-0", "gpb1-1", "gpb1-2", "gpb1-3", - "gpb1-4"; - samsung,pin-function = <3>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spdif_bus: spdif-bus { - samsung,pins = "gpb1-0", "gpb1-1"; - samsung,pin-function = <4>; - samsung,pin-pud = <0>; - samsung,pin-drv = <0>; - }; - - spi2_bus: spi2-bus { - samsung,pins = "gpb1-1", "gpb1-3", "gpb1-4"; - samsung,pin-function = <5>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c6_hs_bus: i2c6-hs-bus { - samsung,pins = "gpb1-3", "gpb1-4"; - samsung,pin-function = <4>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c7_hs_bus: i2c7-hs-bus { - samsung,pins = "gpb2-2", "gpb2-3"; - samsung,pin-function = <3>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c0_bus: i2c0-bus { - samsung,pins = "gpb3-0", "gpb3-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c1_bus: i2c1-bus { - samsung,pins = "gpb3-2", "gpb3-3"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c8_hs_bus: i2c8-hs-bus { - samsung,pins = "gpb3-4", "gpb3-5"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c9_hs_bus: i2c9-hs-bus { - samsung,pins = "gpb3-6", "gpb3-7"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; - - i2c10_hs_bus: i2c10-hs-bus { - samsung,pins = "gpb4-0", "gpb4-1"; - samsung,pin-function = <2>; - samsung,pin-pud = <3>; - samsung,pin-drv = <0>; - }; };
pinctrl@03860000 { @@ -676,12 +299,5 @@ #interrupt-cells = <2>; };
The pinctrl bindings used by Linux are an incomplete description of the hardware. It is possible in most cases to determine the register address of each, but not in all cases. By adding an additional property we can fix this, and avoid adding a table to U-Boot for every single Exynos SOC.
Changes in v7: None Changes in v6: - Move U-Boot changes into their own file - Use exynos54xx everywhere instead of exynos5420
arch/arm/dts/exynos4210-pinctrl-uboot.dtsi | 27 ++++++++++++++++ arch/arm/dts/exynos4210-pinctrl.dtsi | 2 ++ arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi | 46 ++++++++++++++++++++++++++ arch/arm/dts/exynos4x12-pinctrl.dtsi | 2 ++ arch/arm/dts/exynos5250-pinctrl-uboot.dtsi | 40 +++++++++++++++++++++++ arch/arm/dts/exynos5250-pinctrl.dtsi | 2 ++ arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi | 52 ++++++++++++++++++++++++++++++ arch/arm/dts/exynos54xx-pinctrl.dtsi | 2 ++ arch/arm/dts/exynos54xx.dtsi | 11 +++++++ 9 files changed, 184 insertions(+) create mode 100644 arch/arm/dts/exynos4210-pinctrl-uboot.dtsi create mode 100644 arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi create mode 100644 arch/arm/dts/exynos5250-pinctrl-uboot.dtsi create mode 100644 arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi
diff --git a/arch/arm/dts/exynos4210-pinctrl-uboot.dtsi b/arch/arm/dts/exynos4210-pinctrl-uboot.dtsi new file mode 100644 index 0000000..ee071c1 --- /dev/null +++ b/arch/arm/dts/exynos4210-pinctrl-uboot.dtsi @@ -0,0 +1,27 @@ +/* + * U-Boot additions to enable a generic Exynos GPIO driver + * + * Copyright (c) 2014 Google, Inc + */ + +/{ + pinctrl_0: pinctrl@11400000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos4210-pinctrl"; + }; + + pinctrl_1: pinctrl@11000000 { + #address-cells = <1>; + #size-cells = <0>; + gpy0: gpy0 { + reg = <0xc00>; + }; + }; + + pinctrl_2: pinctrl@03860000 { + #address-cells = <1>; + #size-cells = <0>; + }; + +}; diff --git a/arch/arm/dts/exynos4210-pinctrl.dtsi b/arch/arm/dts/exynos4210-pinctrl.dtsi index bda17f7..87f162b 100644 --- a/arch/arm/dts/exynos4210-pinctrl.dtsi +++ b/arch/arm/dts/exynos4210-pinctrl.dtsi @@ -14,6 +14,8 @@ * published by the Free Software Foundation. */
+#include "exynos4210-pinctrl-uboot.dtsi" + / { pinctrl@11400000 { gpa0: gpa0 { diff --git a/arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi b/arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi new file mode 100644 index 0000000..c02796d --- /dev/null +++ b/arch/arm/dts/exynos4x12-pinctrl-uboot.dtsi @@ -0,0 +1,46 @@ +/* + * U-Boot additions to enable a generic Exynos GPIO driver + * + * Copyright (c) 2014 Google, Inc + */ + +/{ + pinctrl_0: pinctrl@11400000 { + #address-cells = <1>; + #size-cells = <0>; + gpf0: gpf0 { + reg = <0xc180>; + }; + gpj0: gpj0 { + reg = <0x240>; + }; + }; + + pinctrl_1: pinctrl@11000000 { + #address-cells = <1>; + #size-cells = <0>; + gpk0: gpk0 { + reg = <0x40>; + }; + gpm0: gpm0 { + reg = <0x260>; + }; + gpy0: gpy0 { + reg = <0x120>; + }; + gpx0: gpx0 { + reg = <0xc00>; + }; + }; + + pinctrl_2: pinctrl@03860000 { + #address-cells = <1>; + #size-cells = <0>; + }; + + pinctrl_3: pinctrl@106E0000 { + #address-cells = <1>; + #size-cells = <0>; + }; + +}; diff --git a/arch/arm/dts/exynos4x12-pinctrl.dtsi b/arch/arm/dts/exynos4x12-pinctrl.dtsi index 93f3998..f40de1f 100644 --- a/arch/arm/dts/exynos4x12-pinctrl.dtsi +++ b/arch/arm/dts/exynos4x12-pinctrl.dtsi @@ -12,6 +12,8 @@ * published by the Free Software Foundation. */
+#include "exynos4x12-pinctrl-uboot.dtsi" + / { pinctrl@11400000 { gpa0: gpa0 { diff --git a/arch/arm/dts/exynos5250-pinctrl-uboot.dtsi b/arch/arm/dts/exynos5250-pinctrl-uboot.dtsi new file mode 100644 index 0000000..7edb0ca --- /dev/null +++ b/arch/arm/dts/exynos5250-pinctrl-uboot.dtsi @@ -0,0 +1,40 @@ +/* + * U-Boot additions to enable a generic Exynos GPIO driver + * + * Copyright (c) 2014 Google, Inc + */ + +/{ + pinctrl_0: pinctrl@11400000 { + #address-cells = <1>; + #size-cells = <0>; + gpc4: gpc4 { + reg = <0x2e0>; + }; + gpx0: gpx0 { + reg = <0xc00>; + }; + }; + + pinctrl_1: pinctrl@13400000 { + #address-cells = <1>; + #size-cells = <0>; + }; + + pinctrl_2: pinctrl@10d10000 { + #address-cells = <1>; + #size-cells = <0>; + gpv2: gpv2 { + reg = <0x060>; + }; + gpv4: gpv4 { + reg = <0xc0>; + }; + }; + + pinctrl_3: pinctrl@03860000 { + #address-cells = <1>; + #size-cells = <0>; + }; + +}; diff --git a/arch/arm/dts/exynos5250-pinctrl.dtsi b/arch/arm/dts/exynos5250-pinctrl.dtsi index 67755a1..706b888 100644 --- a/arch/arm/dts/exynos5250-pinctrl.dtsi +++ b/arch/arm/dts/exynos5250-pinctrl.dtsi @@ -12,6 +12,8 @@ * published by the Free Software Foundation. */
+#include "exynos5250-pinctrl-uboot.dtsi" + / { pinctrl@11400000 { gpa0: gpa0 { diff --git a/arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi b/arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi new file mode 100644 index 0000000..197eb13 --- /dev/null +++ b/arch/arm/dts/exynos54xx-pinctrl-uboot.dtsi @@ -0,0 +1,52 @@ +/* + * U-Boot additions to enable a generic Exynos GPIO driver + * + * Copyright (c) 2014 Google, Inc + */ + +/{ + /* + * Replicate the ordering of arch/arm/include/asm/arch-exynos/gpio.h + * TODO(sjg@chromium.org): Remove this once GPIO numbers are not + * needed in U-Boot for exynos. + */ + pinctrl@14010000 { + }; + pinctrl@13400000 { + }; + pinctrl@13410000 { + }; + pinctrl@14000000 { + }; + pinctrl@03860000 { + }; + + pinctrl@13400000 { + #address-cells = <1>; + #size-cells = <0>; + gpx0: gpx0 { + reg = <0xc00>; + }; + }; + + pinctrl@13410000 { + #address-cells = <1>; + #size-cells = <0>; + }; + + pinctrl@14000000 { + #address-cells = <1>; + #size-cells = <0>; + }; + + pinctrl@14010000 { + #address-cells = <1>; + #size-cells = <0>; + }; + + pinctrl@03860000 { + #address-cells = <1>; + #size-cells = <0>; + }; + +}; diff --git a/arch/arm/dts/exynos54xx-pinctrl.dtsi b/arch/arm/dts/exynos54xx-pinctrl.dtsi index b3e63d1..775d956 100644 --- a/arch/arm/dts/exynos54xx-pinctrl.dtsi +++ b/arch/arm/dts/exynos54xx-pinctrl.dtsi @@ -12,6 +12,8 @@ * published by the Free Software Foundation. */
+#include "exynos54xx-pinctrl-uboot.dtsi" + / { pinctrl@13400000 { gpy7: gpy7 { diff --git a/arch/arm/dts/exynos54xx.dtsi b/arch/arm/dts/exynos54xx.dtsi index 1a765ab..22792e3 100644 --- a/arch/arm/dts/exynos54xx.dtsi +++ b/arch/arm/dts/exynos54xx.dtsi @@ -6,6 +6,7 @@ */
#include "exynos5.dtsi" +#include "exynos54xx-pinctrl.dtsi"
/ { aliases { @@ -132,6 +133,8 @@ };
pinctrl_0: pinctrl@13400000 { + #address-cells = <1>; + #size-cells = <0>; compatible = "samsung,exynos5420-pinctrl"; reg = <0x13400000 0x1000>; interrupts = <0 45 0>; @@ -144,24 +147,32 @@ };
pinctrl_1: pinctrl@13410000 { + #address-cells = <1>; + #size-cells = <0>; compatible = "samsung,exynos5420-pinctrl"; reg = <0x13410000 0x1000>; interrupts = <0 78 0>; };
pinctrl_2: pinctrl@14000000 { + #address-cells = <1>; + #size-cells = <0>; compatible = "samsung,exynos5420-pinctrl"; reg = <0x14000000 0x1000>; interrupts = <0 46 0>; };
pinctrl_3: pinctrl@14010000 { + #address-cells = <1>; + #size-cells = <0>; compatible = "samsung,exynos5420-pinctrl"; reg = <0x14010000 0x1000>; interrupts = <0 50 0>; };
pinctrl_4: pinctrl@03860000 { + #address-cells = <1>; + #size-cells = <0>; compatible = "samsung,exynos5420-pinctrl"; reg = <0x03860000 0x1000>; interrupts = <0 47 0>;
The wrong header is being included, thus requiring the code to re-declare the generic GPIO interface in each GPIO header.
Fix this.
arch/arm/cpu/armv7/exynos/pinmux.c | 2 +- arch/arm/include/asm/arch-exynos/gpio.h | 5 ----- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 4 ---- board/samsung/arndale/arndale.c | 2 +- board/samsung/common/board.c | 2 +- board/samsung/common/misc.c | 1 - board/samsung/goni/goni.c | 2 +- board/samsung/origen/origen.c | 2 +- board/samsung/smdk5420/smdk5420.c | 2 +- board/samsung/smdkc100/smdkc100.c | 2 +- board/samsung/smdkv310/smdkv310.c | 2 +- board/samsung/trats/trats.c | 2 +- board/samsung/trats2/trats2.c | 1 + board/samsung/universal_c210/universal.c | 1 - drivers/gpio/s5p_gpio.c | 3 +-- 15 files changed, 11 insertions(+), 22 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 86a0c75..8cc4e9c 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -7,7 +7,7 @@
#include <common.h> #include <fdtdec.h> -#include <asm/arch/gpio.h> +#include <asm/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/sromc.h>
diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index 8fb5c23..ba169b9 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -1504,12 +1504,7 @@ static const struct gpio_name_num_table exynos5420_gpio_table[] = { void gpio_cfg_pin(int gpio, int cfg); void gpio_set_pull(int gpio, int mode); void gpio_set_drv(int gpio, int mode); -int gpio_direction_input(unsigned gpio); -int gpio_direction_output(unsigned gpio, int value); -int gpio_set_value(unsigned gpio, int value); -int gpio_get_value(unsigned gpio); void gpio_set_rate(int gpio, int mode); -struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned gpio); int s5p_gpio_get_pin(unsigned gpio); #endif
diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index d5dbc22..bd6f2d2 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -815,11 +815,7 @@ static const struct gpio_name_num_table s5pc110_gpio_table[] = { void gpio_cfg_pin(int gpio, int cfg); void gpio_set_pull(int gpio, int mode); void gpio_set_drv(int gpio, int mode); -int gpio_direction_output(unsigned gpio, int value); -int gpio_set_value(unsigned gpio, int value); -int gpio_get_value(unsigned gpio); void gpio_set_rate(int gpio, int mode); -struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned gpio); int s5p_gpio_get_pin(unsigned gpio);
/* GPIO pins per bank */ diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index 83fd3bd..e39795d 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -6,9 +6,9 @@
#include <common.h> #include <usb.h> +#include <asm/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/dwmmc.h> -#include <asm/arch/gpio.h> #include <asm/arch/power.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 1f6f0a0..82595d1 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -13,10 +13,10 @@ #include <tmu.h> #include <netdev.h> #include <asm/io.h> +#include <asm/gpio.h> #include <asm/arch/board.h> #include <asm/arch/cpu.h> #include <asm/arch/dwmmc.h> -#include <asm/arch/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/power.h> diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index 03106fd..a79119a 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -13,7 +13,6 @@ #include <version.h> #include <linux/sizes.h> #include <asm/arch/cpu.h> -#include <asm/arch/gpio.h> #include <asm/gpio.h> #include <linux/input.h> #include <power/pmic.h> diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index eb0f9bf..01be714 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -7,7 +7,7 @@ */
#include <common.h> -#include <asm/arch/gpio.h> +#include <asm/gpio.h> #include <asm/arch/mmc.h> #include <power/pmic.h> #include <usb/s3c_udc.h> diff --git a/board/samsung/origen/origen.c b/board/samsung/origen/origen.c index a539267..99a2fac 100644 --- a/board/samsung/origen/origen.c +++ b/board/samsung/origen/origen.c @@ -6,8 +6,8 @@
#include <common.h> #include <asm/io.h> +#include <asm/gpio.h> #include <asm/arch/cpu.h> -#include <asm/arch/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/periph.h> #include <asm/arch/pinmux.h> diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index 270ee83..47998ab 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -11,9 +11,9 @@ #include <lcd.h> #include <spi.h> #include <errno.h> +#include <asm/gpio.h> #include <asm/arch/board.h> #include <asm/arch/cpu.h> -#include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/system.h> #include <asm/arch/dp_info.h> diff --git a/board/samsung/smdkc100/smdkc100.c b/board/samsung/smdkc100/smdkc100.c index e009564..66b6a98 100644 --- a/board/samsung/smdkc100/smdkc100.c +++ b/board/samsung/smdkc100/smdkc100.c @@ -7,9 +7,9 @@ */
#include <common.h> +#include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/sromc.h> -#include <asm/arch/gpio.h> #include <netdev.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index 8eca358..cb7f9b0 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -5,10 +5,10 @@ */
#include <common.h> +#include <asm/gpio.h> #include <asm/io.h> #include <netdev.h> #include <asm/arch/cpu.h> -#include <asm/arch/gpio.h> #include <asm/arch/mmc.h> #include <asm/arch/periph.h> #include <asm/arch/pinmux.h> diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 3dd340b..9e76b5d 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -10,8 +10,8 @@ #include <common.h> #include <lcd.h> #include <asm/io.h> +#include <asm/gpio.h> #include <asm/arch/cpu.h> -#include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/clock.h> #include <asm/arch/mipi_dsim.h> diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index fa26e61..2924ee6 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -8,6 +8,7 @@
#include <common.h> #include <lcd.h> +#include <asm/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/power.h> #include <asm/arch/mipi_dsim.h> diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 47e7f53..f9d3325 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -12,7 +12,6 @@ #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/adc.h> -#include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/watchdog.h> #include <ld9040.h> diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index db7b673..aa60188 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -8,7 +8,6 @@ #include <common.h> #include <asm/io.h> #include <asm/gpio.h> -#include <asm/arch/gpio.h>
#define S5P_GPIO_GET_PIN(x) (x % GPIO_PER_BANK)
@@ -222,7 +221,7 @@ static void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) writel(value, &bank->drv); }
-struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned int gpio) +static struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned int gpio) { const struct gpio_info *data; unsigned int upto;
The defines at the top of the GPIO driver use single-character names for parameters which are not very descriptive.
Improve these to use descriptive parameter names.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
drivers/gpio/s5p_gpio.c | 21 +++++++++++---------- 1 file changed, 11 insertions(+), 10 deletions(-)
diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index aa60188..99f2dd8 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -11,19 +11,20 @@
-#define CON_MASK(x) (0xf << ((x) << 2)) -#define CON_SFR(x, v) ((v) << ((x) << 2)) +#define CON_MASK(val) (0xf << ((val) << 2)) +#define CON_SFR(gpio, cfg) ((cfg) << ((gpio) << 2)) +#define CON_SFR_UNSHIFT(val, gpio) ((val) >> ((gpio) << 2))
-#define DAT_MASK(x) (0x1 << (x)) -#define DAT_SET(x) (0x1 << (x)) +#define DAT_MASK(gpio) (0x1 << (gpio)) +#define DAT_SET(gpio) (0x1 << (gpio))
-#define PULL_MASK(x) (0x3 << ((x) << 1)) -#define PULL_MODE(x, v) ((v) << ((x) << 1)) +#define PULL_MASK(gpio) (0x3 << ((gpio) << 1)) +#define PULL_MODE(gpio, pull) ((pull) << ((gpio) << 1))
-#define DRV_MASK(x) (0x3 << ((x) << 1)) -#define DRV_SET(x, m) ((m) << ((x) << 1)) -#define RATE_MASK(x) (0x1 << (x + 16)) -#define RATE_SET(x) (0x1 << (x + 16)) +#define DRV_MASK(gpio) (0x3 << ((gpio) << 1)) +#define DRV_SET(gpio, mode) ((mode) << ((gpio) << 1)) +#define RATE_MASK(gpio) (0x1 << (gpio + 16)) +#define RATE_SET(gpio) (0x1 << (gpio + 16))
#define name_to_gpio(n) s5p_name_to_gpio(n) static inline int s5p_name_to_gpio(const char *name)
With driver model GPIOs must be requested before use. Make sure this is done correctly.
(Note that the soft SPI part of universal is omitted, since this driver is about to be replaced with a driver-model-aware version)
Changes in v7: None Changes in v6: None Changes in v5: - Add additional gpio_request() calls for other samsung boards - Use a mask instead of division in gpio_request() naming call
arch/arm/cpu/armv7/exynos/pinmux.c | 3 +++ board/samsung/arndale/arndale.c | 2 ++ board/samsung/common/misc.c | 2 ++ board/samsung/goni/goni.c | 2 ++ board/samsung/smdk5250/exynos5-dt.c | 7 +++++++ board/samsung/smdk5420/smdk5420.c | 4 ++++ board/samsung/trats/trats.c | 15 ++++++++++++--- board/samsung/trats2/trats2.c | 26 +++++++++++++++++++++----- board/samsung/universal_c210/universal.c | 3 +++ drivers/mmc/s5p_sdhci.c | 7 ++++++- 10 files changed, 62 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 8cc4e9c..fb1375d 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -172,6 +172,9 @@ static int exynos5420_mmc_config(int peripheral, int flags) * this same assumption. */ if ((peripheral == PERIPH_ID_SDMMC0) && (i == (start + 2))) { +#ifndef CONFIG_SPL_BUILD + gpio_request(i, "sdmmc0_vdden"); +#endif gpio_set_value(i, 1); gpio_cfg_pin(i, S5P_GPIO_OUTPUT); } else { diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index e39795d..881d080 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -19,6 +19,8 @@ int board_usb_init(int index, enum usb_init_type init) /* Configure gpios for usb 3503 hub: * disconnect, toggle reset and connect */ + gpio_request(EXYNOS5_GPIO_D17, "usb_connect"); + gpio_request(EXYNOS5_GPIO_X35, "usb_reset"); gpio_direction_output(EXYNOS5_GPIO_D17, 0); gpio_direction_output(EXYNOS5_GPIO_X35, 0);
diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index a79119a..d274eb6 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -362,6 +362,8 @@ void check_boot_mode(void) void keys_init(void) { /* Set direction to input */ + gpio_request(KEY_VOL_UP_GPIO, "volume-up"); + gpio_request(KEY_VOL_DOWN_GPIO, "volume-down"); gpio_direction_input(KEY_VOL_UP_GPIO); gpio_direction_input(KEY_VOL_DOWN_GPIO); } diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 01be714..22f4995 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -80,6 +80,7 @@ int board_mmc_init(bd_t *bis) int i, ret, ret_sd = 0;
/* MASSMEMORY_EN: XMSMDATA7: GPJ2[7] output high */ + gpio_request(S5PC110_GPIO_J27, "massmemory_en"); gpio_direction_output(S5PC110_GPIO_J27, 1);
/* @@ -108,6 +109,7 @@ int board_mmc_init(bd_t *bis) * SD card (T_FLASH) detect and init * T_FLASH_DETECT: EINT28: GPH3[4] input mode */ + gpio_request(S5PC110_GPIO_H34, "t_flash_detect"); gpio_cfg_pin(S5PC110_GPIO_H34, S5P_GPIO_INPUT); gpio_set_pull(S5PC110_GPIO_H34, S5P_GPIO_PULL_UP);
diff --git a/board/samsung/smdk5250/exynos5-dt.c b/board/samsung/smdk5250/exynos5-dt.c index d6ce133..53ff706 100644 --- a/board/samsung/smdk5250/exynos5-dt.c +++ b/board/samsung/smdk5250/exynos5-dt.c @@ -29,6 +29,7 @@ DECLARE_GLOBAL_DATA_PTR; static void board_enable_audio_codec(void) { /* Enable MAX98095 Codec */ + gpio_request(EXYNOS5_GPIO_X17, "max98095_enable"); gpio_direction_output(EXYNOS5_GPIO_X17, 1); gpio_set_pull(EXYNOS5_GPIO_X17, S5P_GPIO_PULL_NONE); } @@ -199,16 +200,19 @@ static int board_dp_bridge_setup(void) /* Setup the GPIOs */
/* PD is ACTIVE_LOW, and initially de-asserted */ + gpio_request(EXYNOS5_GPIO_Y25, "dp_bridge_pd"); gpio_set_pull(EXYNOS5_GPIO_Y25, S5P_GPIO_PULL_NONE); gpio_direction_output(EXYNOS5_GPIO_Y25, 1);
/* Reset is ACTIVE_LOW */ + gpio_request(EXYNOS5_GPIO_X15, "dp_bridge_reset"); gpio_set_pull(EXYNOS5_GPIO_X15, S5P_GPIO_PULL_NONE); gpio_direction_output(EXYNOS5_GPIO_X15, 0);
udelay(10); gpio_set_value(EXYNOS5_GPIO_X15, 1);
+ gpio_request(EXYNOS5_GPIO_X07, "dp_bridge_hpd"); gpio_direction_input(EXYNOS5_GPIO_X07);
/* @@ -236,10 +240,12 @@ static int board_dp_bridge_setup(void) void exynos_cfg_lcd_gpio(void) { /* For Backlight */ + gpio_request(EXYNOS5_GPIO_B20, "lcd_backlight"); gpio_cfg_pin(EXYNOS5_GPIO_B20, S5P_GPIO_OUTPUT); gpio_set_value(EXYNOS5_GPIO_B20, 1);
/* LCD power on */ + gpio_request(EXYNOS5_GPIO_X15, "lcd_power"); gpio_cfg_pin(EXYNOS5_GPIO_X15, S5P_GPIO_OUTPUT); gpio_set_value(EXYNOS5_GPIO_X15, 1);
@@ -276,6 +282,7 @@ void exynos_backlight_on(unsigned int on) mdelay(10);
/* board_dp_backlight_en */ + gpio_request(EXYNOS5_GPIO_X30, "board_dp_backlight_en"); gpio_direction_output(EXYNOS5_GPIO_X30, 1); #endif } diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index 47998ab..a691222 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -74,9 +74,12 @@ void exynos_lcd_power_on(void) mdelay(5);
/* TODO(ajaykumar.rs@samsung.com): Use device tree */ + gpio_request(EXYNOS5420_GPIO_X35, "edp_slp#"); gpio_direction_output(EXYNOS5420_GPIO_X35, 1); /* EDP_SLP# */ mdelay(10); + gpio_request(EXYNOS5420_GPIO_Y77, "edp_rst#"); gpio_direction_output(EXYNOS5420_GPIO_Y77, 1); /* EDP_RST# */ + gpio_request(EXYNOS5420_GPIO_X26, "edp_hpd"); gpio_direction_input(EXYNOS5420_GPIO_X26); /* EDP_HPD */ gpio_set_pull(EXYNOS5420_GPIO_X26, S5P_GPIO_PULL_NONE);
@@ -88,6 +91,7 @@ void exynos_lcd_power_on(void) void exynos_backlight_on(unsigned int onoff) { /* For PWM */ + gpio_request(EXYNOS5420_GPIO_B20, "backlight_on"); gpio_cfg_pin(EXYNOS5420_GPIO_B20, S5P_GPIO_FUNC(0x1)); gpio_set_value(EXYNOS5420_GPIO_B20, 1);
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 9e76b5d..e163e45 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -63,6 +63,8 @@ void i2c_init_board(void) }
/* I2C_8 -> FG */ + gpio_request(EXYNOS4_GPIO_Y40, "i2c_clk"); + gpio_request(EXYNOS4_GPIO_Y41, "i2c_data"); gpio_direction_output(EXYNOS4_GPIO_Y40, 1); gpio_direction_output(EXYNOS4_GPIO_Y41, 1); } @@ -346,12 +348,17 @@ int exynos_power_init(void) static unsigned int get_hw_revision(void) { int hwrev = 0; + char str[10]; int i;
/* hw_rev[3:0] == GPE1[3:0] */ - for (i = EXYNOS4_GPIO_E10; i < EXYNOS4_GPIO_E14; i++) { - gpio_cfg_pin(i, S5P_GPIO_INPUT); - gpio_set_pull(i, S5P_GPIO_PULL_NONE); + for (i = 0; i < 4; i++) { + int pin = i + EXYNOS4_GPIO_E10; + + sprintf(str, "hw_rev%d", i); + gpio_request(pin, str); + gpio_cfg_pin(pin, S5P_GPIO_INPUT); + gpio_set_pull(pin, S5P_GPIO_PULL_NONE); }
udelay(1); @@ -517,6 +524,7 @@ static void board_power_init(void) static void exynos_uart_init(void) { /* UART_SEL GPY4[7] (part2) at EXYNOS4 */ + gpio_request(EXYNOS4_GPIO_Y47, "uart_sel"); gpio_set_pull(EXYNOS4_GPIO_Y47, S5P_GPIO_PULL_UP); gpio_direction_output(EXYNOS4_GPIO_Y47, 1); } @@ -534,6 +542,7 @@ int exynos_early_init_f(void)
void exynos_reset_lcd(void) { + gpio_request(EXYNOS4_GPIO_Y45, "lcd_reset"); gpio_direction_output(EXYNOS4_GPIO_Y45, 1); udelay(10000); gpio_direction_output(EXYNOS4_GPIO_Y45, 0); diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index 2924ee6..a737749 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -33,6 +33,7 @@ static inline u32 get_model_rev(void); static void check_hw_revision(void) { int modelrev = 0; + char str[12]; int i;
/* @@ -41,13 +42,22 @@ static void check_hw_revision(void) * TRM say that it may cause unexcepted state and leakage current. * and pull-none is only for output function. */ - for (i = EXYNOS4X12_GPIO_M10; i < EXYNOS4X12_GPIO_M12; i++) - gpio_cfg_pin(i, S5P_GPIO_INPUT); + for (i = 0; i < 2; i++) { + int pin = i + EXYNOS4X12_GPIO_M10; + + sprintf(str, "model_rev%d", i); + gpio_request(pin, str); + gpio_cfg_pin(pin, S5P_GPIO_INPUT); + }
/* GPM1[5:2]: HW_REV[3:0] */ - for (i = EXYNOS4X12_GPIO_M12; i < EXYNOS4X12_GPIO_M16; i++) { - gpio_cfg_pin(i, S5P_GPIO_INPUT); - gpio_set_pull(i, S5P_GPIO_PULL_NONE); + for (i = 0; i < 4; i++) { + int pin = i + EXYNOS4X12_GPIO_M12; + + sprintf(str, "hw_rev%d", i); + gpio_request(pin, str); + gpio_cfg_pin(pin, S5P_GPIO_INPUT); + gpio_set_pull(pin, S5P_GPIO_PULL_NONE); }
/* GPM1[1:0]: MODEL_REV[1:0] */ @@ -103,10 +113,14 @@ static void board_init_i2c(void) }
/* I2C_8 */ + gpio_request(EXYNOS4X12_GPIO_F14, "i2c8_clk"); + gpio_request(EXYNOS4X12_GPIO_F15, "i2c8_data"); gpio_direction_output(EXYNOS4X12_GPIO_F14, 1); gpio_direction_output(EXYNOS4X12_GPIO_F15, 1);
/* I2C_9 */ + gpio_request(EXYNOS4X12_GPIO_M21, "i2c9_clk"); + gpio_request(EXYNOS4X12_GPIO_M20, "i2c9_data"); gpio_direction_output(EXYNOS4X12_GPIO_M21, 1); gpio_direction_output(EXYNOS4X12_GPIO_M20, 1); } @@ -388,6 +402,7 @@ void exynos_lcd_power_on(void) struct pmic *p = pmic_get("MAX77686_PMIC");
/* LCD_2.2V_EN: GPC0[1] */ + gpio_request(EXYNOS4X12_GPIO_C01, "lcd_2v2_en"); gpio_set_pull(EXYNOS4X12_GPIO_C01, S5P_GPIO_PULL_UP); gpio_direction_output(EXYNOS4X12_GPIO_C01, 1);
@@ -400,6 +415,7 @@ void exynos_lcd_power_on(void) void exynos_reset_lcd(void) { /* reset lcd */ + gpio_request(EXYNOS4X12_GPIO_F21, "lcd_reset"); gpio_direction_output(EXYNOS4X12_GPIO_F21, 0); udelay(10); gpio_set_value(EXYNOS4X12_GPIO_F21, 1); diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index f9d3325..c04f48c 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -330,6 +330,7 @@ void exynos_cfg_lcd_gpio(void) }
/* gpio pad configuration for LCD reset. */ + gpio_request(EXYNOS4_GPIO_Y45, "lcd_reset"); gpio_cfg_pin(EXYNOS4_GPIO_Y45, S5P_GPIO_OUTPUT);
spi_init(); @@ -386,6 +387,7 @@ int exynos_init(void) * you should set it HIGH since it removes the inverter */ /* MASSMEMORY_EN: XMDMDATA_6: GPE3[6] */ + gpio_request(EXYNOS4_GPIO_E36, "ldo_en"); gpio_direction_output(EXYNOS4_GPIO_E36, 0); break; default: @@ -394,6 +396,7 @@ int exynos_init(void) * But set it as HIGH to ensure */ /* MASSMEMORY_EN: XMDMADDR_3: GPE1[3] */ + gpio_request(EXYNOS4_GPIO_E13, "massmemory_en"); gpio_direction_output(EXYNOS4_GPIO_E13, 1); break; } diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 637dd97..0dea45d 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -102,6 +102,7 @@ struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS];
static int do_sdhci_init(struct sdhci_host *host) { + char str[20]; int dev_id, flag; int err = 0;
@@ -109,6 +110,8 @@ static int do_sdhci_init(struct sdhci_host *host) dev_id = host->index + PERIPH_ID_SDMMC0;
if (fdt_gpio_isvalid(&host->pwr_gpio)) { + sprintf(str, "sdhci%d_power", host->index & 0xf); + gpio_request(host->pwr_gpio.gpio, str); gpio_direction_output(host->pwr_gpio.gpio, 1); err = exynos_pinmux_config(dev_id, flag); if (err) { @@ -118,7 +121,9 @@ static int do_sdhci_init(struct sdhci_host *host) }
if (fdt_gpio_isvalid(&host->cd_gpio)) { - gpio_direction_output(host->cd_gpio.gpio, 0xf); + sprintf(str, "sdhci%d_cd", host->index & 0xf); + gpio_request(host->cd_gpio.gpio, str); + gpio_direction_output(host->cd_gpio.gpio, 1); if (gpio_get_value(host->cd_gpio.gpio)) return -ENODEV;
Convert the exynos GPIO driver to driver model. This implements the generic GPIO interface but not the extra Exynos-specific functions.
Changes in v7: - Bring in patches from the SPI series to move post-reloc DM init earlier
Changes in v6: None Changes in v5: - Remove RFC label now that build errors are fixed - Tidy up and update cover letter message - Avoid reordering functions
Changes in v4: - Add patches for exynos GPIO support
drivers/gpio/s5p_gpio.c | 422 +++++++++++++++++++++++++++------------- include/configs/exynos-common.h | 4 + 2 files changed, 290 insertions(+), 136 deletions(-)
diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 99f2dd8..38ef14d 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -6,8 +6,15 @@ */
#include <common.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <malloc.h> #include <asm/io.h> #include <asm/gpio.h> +#include <dm/device-internal.h> + +DECLARE_GLOBAL_DATA_PTR;
@@ -26,100 +33,45 @@ #define RATE_MASK(gpio) (0x1 << (gpio + 16)) #define RATE_SET(gpio) (0x1 << (gpio + 16))
-#define name_to_gpio(n) s5p_name_to_gpio(n) -static inline int s5p_name_to_gpio(const char *name) +#define GPIO_NAME_SIZE 20 + +/* Platform data for each bank */ +struct exynos_gpio_platdata { + struct s5p_gpio_bank *bank; + const char *bank_name; /* Name of port, e.g. 'gpa0" */ +}; + +/* Information about each bank at run-time */ +struct exynos_bank_info { + char label[GPIO_PER_BANK][GPIO_NAME_SIZE]; + struct s5p_gpio_bank *bank; +}; + +static struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned int gpio) { - unsigned num, irregular_set_number, irregular_bank_base; - const struct gpio_name_num_table *tabp; - char this_bank, bank_name, irregular_bank_name; - char *endp; - - /* - * The gpio name starts with either 'g' or 'gp' followed by the bank - * name character. Skip one or two characters depending on the prefix. - */ - if (name[0] == 'g' && name[1] == 'p') - name += 2; - else if (name[0] == 'g') - name++; - else - return -1; /* Name must start with 'g' */ - - bank_name = *name++; - if (!*name) - return -1; /* At least one digit is required/expected. */ - - /* - * On both exynos5 and exynos5420 architectures there is a bank of - * GPIOs which does not fall into the regular address pattern. Those - * banks are c4 on Exynos5 and y7 on Exynos5420. The rest of the below - * assignments help to handle these irregularities. - */ -#if defined(CONFIG_EXYNOS4) || defined(CONFIG_EXYNOS5) - if (cpu_is_exynos5()) { - if (proid_is_exynos5420()) { - tabp = exynos5420_gpio_table; - irregular_bank_name = 'y'; - irregular_set_number = '7'; - irregular_bank_base = EXYNOS5420_GPIO_Y70; - } else { - tabp = exynos5_gpio_table; - irregular_bank_name = 'c'; - irregular_set_number = '4'; - irregular_bank_base = EXYNOS5_GPIO_C40; - } - } else { - if (proid_is_exynos4412()) - tabp = exynos4x12_gpio_table; - else - tabp = exynos4_gpio_table; - irregular_bank_name = 0; - irregular_set_number = 0; - irregular_bank_base = 0; - } -#else - if (cpu_is_s5pc110()) - tabp = s5pc110_gpio_table; - else - tabp = s5pc100_gpio_table; - irregular_bank_name = 0; - irregular_set_number = 0; - irregular_bank_base = 0; -#endif + const struct gpio_info *data; + unsigned int upto; + int i, count;
- this_bank = tabp->bank; - do { - if (bank_name == this_bank) { - unsigned pin_index; /* pin number within the bank */ - if ((bank_name == irregular_bank_name) && - (name[0] == irregular_set_number)) { - pin_index = name[1] - '0'; - /* Irregular sets have 8 pins. */ - if (pin_index >= GPIO_PER_BANK) - return -1; - num = irregular_bank_base + pin_index; - } else { - pin_index = simple_strtoul(name, &endp, 8); - pin_index -= tabp->bank_offset; - /* - * Sanity check: bunk 'z' has no set number, - * for all other banks there must be exactly - * two octal digits, and the resulting number - * should not exceed the number of pins in the - * bank. - */ - if (((bank_name != 'z') && !name[1]) || - *endp || - (pin_index >= tabp->bank_size)) - return -1; - num = tabp->base + pin_index; - } - return num; + data = get_gpio_data(); + count = get_bank_num(); + upto = 0; + + for (i = 0; i < count; i++) { + debug("i=%d, upto=%d\n", i, upto); + if (gpio < data->max_gpio) { + struct s5p_gpio_bank *bank; + bank = (struct s5p_gpio_bank *)data->reg_addr; + bank += (gpio - upto) / GPIO_PER_BANK; + debug("gpio=%d, bank=%p\n", gpio, bank); + return bank; } - this_bank = (++tabp)->bank; - } while (this_bank);
- return -1; + upto = data->max_gpio; + data++; + } + + return NULL; }
static void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) @@ -143,16 +95,23 @@ static void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) writel(value, &bank->dat); }
-static void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, - int gpio, int en) +#ifdef CONFIG_SPL_BUILD +/* Common GPIO API - SPL does not support driver model yet */ +int gpio_set_value(unsigned gpio, int value) { - s5p_gpio_cfg_pin(bank, gpio, S5P_GPIO_OUTPUT); - s5p_gpio_set_value(bank, gpio, en); -} + s5p_gpio_set_value(s5p_gpio_get_bank(gpio), + s5p_gpio_get_pin(gpio), value);
-static void s5p_gpio_direction_input(struct s5p_gpio_bank *bank, int gpio) + return 0; +} +#else +static int s5p_gpio_get_cfg_pin(struct s5p_gpio_bank *bank, int gpio) { - s5p_gpio_cfg_pin(bank, gpio, S5P_GPIO_INPUT); + unsigned int value; + + value = readl(&bank->con); + value &= CON_MASK(gpio); + return CON_SFR_UNSHIFT(value, gpio); }
static unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio) @@ -162,6 +121,7 @@ static unsigned int s5p_gpio_get_value(struct s5p_gpio_bank *bank, int gpio) value = readl(&bank->dat); return !!(value & DAT_MASK(gpio)); } +#endif /* CONFIG_SPL_BUILD */
static void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) { @@ -222,78 +182,156 @@ static void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) writel(value, &bank->drv); }
-static struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned int gpio) +int s5p_gpio_get_pin(unsigned gpio) { - const struct gpio_info *data; - unsigned int upto; - int i, count; + return S5P_GPIO_GET_PIN(gpio); +}
- data = get_gpio_data(); - count = get_bank_num(); - upto = 0; +/* Driver model interface */ +#ifndef CONFIG_SPL_BUILD +static int exynos_gpio_get_state(struct udevice *dev, unsigned int offset, + char *buf, int bufsize) +{ + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + struct exynos_bank_info *state = dev_get_priv(dev); + const char *label; + bool is_output; + int size; + int cfg; + + label = state->label[offset]; + cfg = s5p_gpio_get_cfg_pin(state->bank, offset); + is_output = cfg == S5P_GPIO_OUTPUT; + size = snprintf(buf, bufsize, "%s%d: ", + uc_priv->bank_name ? uc_priv->bank_name : "", offset); + buf += size; + bufsize -= size; + if (is_output || cfg == S5P_GPIO_INPUT) { + snprintf(buf, bufsize, "%s: %d [%c]%s%s", + is_output ? "out" : " in", + s5p_gpio_get_value(state->bank, offset), + *label ? 'x' : ' ', + *label ? " " : "", + label); + } else { + snprintf(buf, bufsize, "sfpio"); + }
- for (i = 0; i < count; i++) { - debug("i=%d, upto=%d\n", i, upto); - if (gpio < data->max_gpio) { - struct s5p_gpio_bank *bank; - bank = (struct s5p_gpio_bank *)data->reg_addr; - bank += (gpio - upto) / GPIO_PER_BANK; - debug("gpio=%d, bank=%p\n", gpio, bank); - return bank; - } + return 0; +}
- upto = data->max_gpio; - data++; +static int check_reserved(struct udevice *dev, unsigned offset, + const char *func) +{ + struct exynos_bank_info *state = dev_get_priv(dev); + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + + if (!*state->label[offset]) { + printf("exynos_gpio: %s: error: gpio %s%d not reserved\n", + func, uc_priv->bank_name, offset); + return -EPERM; }
- return NULL; + return 0; }
-int s5p_gpio_get_pin(unsigned gpio) +/* set GPIO pin 'gpio' as an input */ +static int exynos_gpio_direction_input(struct udevice *dev, unsigned offset) { - return S5P_GPIO_GET_PIN(gpio); -} + struct exynos_bank_info *state = dev_get_priv(dev); + int ret;
-/* Common GPIO API */ + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + + /* Configure GPIO direction as input. */ + s5p_gpio_cfg_pin(state->bank, offset, S5P_GPIO_INPUT);
-int gpio_request(unsigned gpio, const char *label) -{ return 0; }
-int gpio_free(unsigned gpio) +/* set GPIO pin 'gpio' as an output, with polarity 'value' */ +static int exynos_gpio_direction_output(struct udevice *dev, unsigned offset, + int value) { + struct exynos_bank_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + + /* Configure GPIO output value. */ + s5p_gpio_set_value(state->bank, offset, value); + + /* Configure GPIO direction as output. */ + s5p_gpio_cfg_pin(state->bank, offset, S5P_GPIO_OUTPUT); + return 0; }
-int gpio_direction_input(unsigned gpio) +/* read GPIO IN value of pin 'gpio' */ +static int exynos_gpio_get_value(struct udevice *dev, unsigned offset) { - s5p_gpio_direction_input(s5p_gpio_get_bank(gpio), - s5p_gpio_get_pin(gpio)); - return 0; + struct exynos_bank_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + + return s5p_gpio_get_value(state->bank, offset); }
-int gpio_direction_output(unsigned gpio, int value) +/* write GPIO OUT value to pin 'gpio' */ +static int exynos_gpio_set_value(struct udevice *dev, unsigned offset, + int value) { - s5p_gpio_direction_output(s5p_gpio_get_bank(gpio), - s5p_gpio_get_pin(gpio), value); + struct exynos_bank_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + + s5p_gpio_set_value(state->bank, offset, value); + return 0; }
-int gpio_get_value(unsigned gpio) +static int exynos_gpio_request(struct udevice *dev, unsigned offset, + const char *label) { - return (int) s5p_gpio_get_value(s5p_gpio_get_bank(gpio), - s5p_gpio_get_pin(gpio)); + struct exynos_bank_info *state = dev_get_priv(dev); + + if (*state->label[offset]) + return -EBUSY; + + strncpy(state->label[offset], label, GPIO_NAME_SIZE); + state->label[offset][GPIO_NAME_SIZE - 1] = '\0'; + + return 0; }
-int gpio_set_value(unsigned gpio, int value) +static int exynos_gpio_free(struct udevice *dev, unsigned offset) { - s5p_gpio_set_value(s5p_gpio_get_bank(gpio), - s5p_gpio_get_pin(gpio), value); + struct exynos_bank_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + state->label[offset][0] = '\0';
return 0; } +#endif /* nCONFIG_SPL_BUILD */
+/* + * There is no common GPIO API for pull, drv, pin, rate (yet). These + * functions are kept here to preserve function ordering for review. + */ void gpio_set_pull(int gpio, int mode) { s5p_gpio_set_pull(s5p_gpio_get_bank(gpio), @@ -317,3 +355,115 @@ void gpio_set_rate(int gpio, int mode) s5p_gpio_set_rate(s5p_gpio_get_bank(gpio), s5p_gpio_get_pin(gpio), mode); } + +#ifndef CONFIG_SPL_BUILD +static int exynos_gpio_get_function(struct udevice *dev, unsigned offset) +{ + struct exynos_bank_info *state = dev_get_priv(dev); + int cfg; + + if (!*state->label[offset]) + return GPIOF_UNUSED; + cfg = s5p_gpio_get_cfg_pin(state->bank, offset); + if (cfg == S5P_GPIO_OUTPUT) + return GPIOF_OUTPUT; + else if (cfg == S5P_GPIO_INPUT) + return GPIOF_INPUT; + else + return GPIOF_FUNC; +} + +static const struct dm_gpio_ops gpio_exynos_ops = { + .request = exynos_gpio_request, + .free = exynos_gpio_free, + .direction_input = exynos_gpio_direction_input, + .direction_output = exynos_gpio_direction_output, + .get_value = exynos_gpio_get_value, + .set_value = exynos_gpio_set_value, + .get_function = exynos_gpio_get_function, + .get_state = exynos_gpio_get_state, +}; + +static int gpio_exynos_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + struct exynos_bank_info *priv = dev->priv; + struct exynos_gpio_platdata *plat = dev->platdata; + + /* Only child devices have ports */ + if (!plat) + return 0; + + priv->bank = plat->bank; + + uc_priv->gpio_count = GPIO_PER_BANK; + uc_priv->bank_name = plat->bank_name; + + return 0; +} + +/** + * We have a top-level GPIO device with no actual GPIOs. It has a child + * device for each Exynos GPIO bank. + */ +static int gpio_exynos_bind(struct udevice *parent) +{ + struct exynos_gpio_platdata *plat = parent->platdata; + struct s5p_gpio_bank *bank, *base; + const void *blob = gd->fdt_blob; + int node; + + /* If this is a child device, there is nothing to do here */ + if (plat) + return 0; + + base = (struct s5p_gpio_bank *)fdtdec_get_addr(gd->fdt_blob, + parent->of_offset, "reg"); + for (node = fdt_first_subnode(blob, parent->of_offset), bank = base; + node > 0; + node = fdt_next_subnode(blob, node), bank++) { + struct exynos_gpio_platdata *plat; + struct udevice *dev; + fdt_addr_t reg; + int ret; + + if (!fdtdec_get_bool(blob, node, "gpio-controller")) + continue; + plat = calloc(1, sizeof(*plat)); + if (!plat) + return -ENOMEM; + reg = fdtdec_get_addr(blob, node, "reg"); + if (reg != FDT_ADDR_T_NONE) + bank = (struct s5p_gpio_bank *)((ulong)base + reg); + plat->bank = bank; + plat->bank_name = fdt_get_name(blob, node, NULL); + debug("dev at %p: %s\n", bank, plat->bank_name); + + ret = device_bind(parent, parent->driver, + plat->bank_name, plat, -1, &dev); + if (ret) + return ret; + dev->of_offset = parent->of_offset; + } + + return 0; +} + +static const struct udevice_id exynos_gpio_ids[] = { + { .compatible = "samsung,exynos4210-pinctrl" }, + { .compatible = "samsung,exynos4x12-pinctrl" }, + { .compatible = "samsung,exynos5250-pinctrl" }, + { .compatible = "samsung,exynos5420-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(gpio_exynos) = { + .name = "gpio_exynos", + .id = UCLASS_GPIO, + .of_match = exynos_gpio_ids, + .bind = gpio_exynos_bind, + .probe = gpio_exynos_probe, + .priv_auto_alloc_size = sizeof(struct exynos_bank_info), + .ops = &gpio_exynos_ops, +}; +#endif diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 7be7d12..79dd9dc 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -17,6 +17,10 @@ #include <linux/sizes.h>
#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DM +#define CONFIG_CMD_DM +#define CONFIG_DM_GPIO + #define CONFIG_ARCH_CPU_INIT #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
On 3 September 2014 17:36, Simon Glass sjg@chromium.org wrote:
Now that driver model is part of U-Boot, the task of converting drivers over to it begins. GPIO is one of the easiest to convert, since it already has a sandbox driver and a uclass driver.
The Tegra GPIO driver is relatively simple since it has a linear numbering and already uses the generic GPIO framework. Each GPIO bank has a separate device. Some arguments have been made that a single device should support all the GPIO banks, but currently the driver model uclass does not work that way and it would require a second-level data structure to handle the bank feature.
This driver has been tested on:
- Seaboard (Tegra 20)
- Beaver (Tegra 30)
- Jetson-TK1 (Tegra 124).
I don't have a Tegra 114 board (Dalmore seems to be the only one with U-Boot support) but I am quite confident that it works.
For exynos, the pinctrl device tree files are brought in from the kernel and cut down to remove the groupings which we don't yet use. Very small additions are made to avoid replicating the awful tables that Linux has for every exynos SoC. This series sits on top of the exynos refactors.
The 'gpio' command is updated to support display of only the allocated GPIOs. This is much more friendly than displaying a large table.
A few related clean-ups are provided as well.
This series is available at u-boot-dm.git, branch working.
Are there any final comments on this series please?
I plan to apply the non-exynos portions to dm/master early next week.
Changes in v7:
- Add new patch to init driver model before board_early_init_f()
- Add new patch to enable pre-reloc malloc() for tegra
- Set up pin config in tegra_spl_gpio_direction_output()
Changes in v6:
- Use base_gpio instead of base_port for simplicity
- Add an implementation of the get_function() method
- Fix typo in compatible string
- Remove exynos5420.dtsi which is not used in U-Boot
Changes in v5:
- Put this patch before the others to avoid breaking bisectability
Changes in v4:
- Rename struct device to struct udevice
Changes in v3:
- Move dm command enable to previous patch
- Use gpio number for the internal helper functions
Changes in v2:
- Remove RFC status
- Add exynos serial support
- Split out core driver model patches into a separate set
- Split out driver model changes into separate patches
- Correct bugs found during testing
Simon Glass (13): dm: Move pre-reloc init earlier to cope with board_early_init_f() Set up stdio earlier when using driver model dm: Make driver model available before board_init() dm: tegra: Set up a pre-reloc malloc() tegra: Convert tegra GPIO driver to use driver model exynos: dts: Convert /include/ to #include exynos: Bring in pinctrl dts files from Linux kernel exynos: dts: Remove unused pinctrl information to save space exynos: dts: Adjust device tree files for U-Boot exynos: Tidy up GPIO headers exynos: Tidy up GPIO defines exynos: Make sure that GPIOs are requested exynos: gpio: Convert to driver model
