[U-Boot-Users] Booting ELDK 4.0 kernel on MPC8548CDS
I'm using a MPC8548CDS eval system with u-boot 1.1.6 running on it. When trying to boot an ELDK 4.0 kernel, the board hangs immediately after decompression of the kernel. I've set the disable_of environment variable to avoid usage of the flat device tree.
The same kernel boots properly when using u-boot 1.1.3 which is delivered with the eval system.
Any hints would be appreciated.
Thomas Schafer
____________________________________
Kontron Modular Computers GmbH
Heinrich-Barth-Str. 1a 66115 Saarbrucken
Tel.: + 49 (0)681 / 95916 - 203 Fax: + 49 (0)681 / 95916 - 100 E-mail: thomas.schaefer@kontron.com
Hi Thoomas,
I see a similar problem when using of-tree. My debugging shows that the of-tree address given to the kernel is outside the memory region that can be accessed by the kernel at start-up (defined by CFG_BOOTMAPSZ), thus the kernel crashes very early without any output. (IMHO this is a bug.) If you are using CONFIG_OF_FLAT_TREE _and_ "disable_of" ist likely that you see the same behaviour, because in that case the "bootm" code still uses the of-tree address (char *of_flat_tree), after copying the standard bd_info data to that address. You could check the pointer that is given to the kernel for the board info data (line 967, parameter 1 of (*kernel) (...)) (or change (*kernel) ((bd_t *)of_flat_tree,... to (*kernel) (kbd,...)
Regards, Torsten
-----Original Message----- From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of Thomas Schafer Sent: Mittwoch, 22. November 2006 19:56 To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] Booting ELDK 4.0 kernel on MPC8548CDS
Thomas Schafer
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's Techsay panel and you'll get the chance to share your opinions on IT & business topics through brief surveys - and earn cash http://www.techsay.com/default.php?page=join.php&p=sourceforge
&CID=DEVDEV
U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
On Nov 23, 2006, at 2:01 AM, Demke Torsten-atd012 wrote:
Hi Thoomas,
Regards, Torsten
This seems like a bug.
Looking at the code I'm confused how this works at all. I dont see of_flat_tree getting setting to anything at all.
Can you guys try out Grant's patch "[PATCH] Allow CONFIG_OF_FLAT_TREE to boot a non-arch/powerpc kernel" and see if that fixes the issue when building w/CONFIG_OF_FLAT_TREE enabled. His patch should make it so that a bootm w/1 or 2 args that aren't a multiimage should boot arch/ppc style.
- k
Thomas Schafer
&CID=DEVDEV
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's Techsay panel and you'll get the chance to share your opinions on IT & business topics through brief surveys - and earn cash http://www.techsay.com/default.php? page=join.php&p=sourceforge&CID=DEVDEV _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Kumar Gala wrote:
[snip]
- k
I was having a similar problem on my MPC8555CDS, this patch fixes the problem for me as well.
I was also having a problem with ethernet on this board. The TSEC driver in u-boot 1.1.6 seems to be broken (for this board anyway). I moved the PHY reset a bit earlier and it fixed it for me. I'll submit a patch in a moment.
cheers, Dan
Wolfgang,
Can you pickup and push Grant's patch "[PATCH] Allow CONFIG_OF_FLAT_TREE to boot a non-arch/powerpc kernel". It fixes an obvious bug with trying to boot use the old style boot mechanism that got broken with the mass of flat device tree patches.
- k
On Nov 23, 2006, at 1:38 PM, Dan wrote:
Kumar Gala wrote:
[snip]
- k
cheers, Dan
On Fri, 2006-11-24 at 09:19, Kumar Gala wrote:
Wolfgang,
- k
Yeah, that's the patch that I ACK'ed on 2-Nov-06 as well.
Thanks, jdl
participants (5)
Dan
Jon Loeliger
Kumar Gala
Thomas Schafer
