[U-Boot] [PATCH 0/4] mtd: spi: spi-nor-core: Add Microchip SFDP parser
Parse manufacturer specific SFDP table. The Microchip SFDP table contains pre-programmed globally unique MAC addresses. Retrieve the MAC address from the SPI NOR flash and set it in ethaddr in env.
This can go through Eugen's tree if no obiections. Otherwise Eugen should take care to apply the Microchip specific code after Jagan's/Vignesh's tree gets merged.
Tudor Ambarus (4): mtd: spi: spi-nor-core: Add Microchip SFDP parser board: atmel: sama5d27_wlsom1_ek: Set ethaddr from spi-nor flash configs: sama5d27_wlsom1_ek: qspiflash: Enable SPI NOR ethaddr retrieval configs: sama5d27_wlsom1_ek: mmc: Enable SPI NOR ethaddr retrieval
arch/arm/mach-at91/include/mach/at91_common.h | 1 + board/atmel/common/Makefile | 1 + board/atmel/common/mac-spi-nor.c | 127 +++++++++++++++++++++ .../atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 3 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 7 +- configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 3 +- drivers/mtd/spi/spi-nor-core.c | 35 ++++++ include/linux/mtd/spi-nor.h | 2 + 8 files changed, 177 insertions(+), 2 deletions(-) create mode 100644 board/atmel/common/mac-spi-nor.c
JESD216 allow vendors to define their own SFDP tables.
Add Microchip SFDP parser. The vendor table is allocated using resource-managed kmalloc - the table will be freed on driver detach. It will be accessible by getting the UCLASS_SPI_FLASH's private data.
The Michrochip's SFDP table is particularly of interest because contains pre-programmed globally unique EUI-48 and EUI-64 identifiers.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- drivers/mtd/spi/spi-nor-core.c | 35 +++++++++++++++++++++++++++++++++++ include/linux/mtd/spi-nor.h | 2 ++ 2 files changed, 37 insertions(+)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 1acff745d1a2..bade7d8a9f79 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -1417,6 +1417,7 @@ struct sfdp_parameter_header {
#define SFDP_BFPT_ID 0xff00 /* Basic Flash Parameter Table */ #define SFDP_SECTOR_MAP_ID 0xff81 /* Sector Map Table */ +#define SFDP_MICROCHIP_ID 0x01bf /* Manufacturer specific Table */
#define SFDP_SIGNATURE 0x50444653U #define SFDP_JESD216_MAJOR 1 @@ -1797,6 +1798,34 @@ static int spi_nor_parse_bfpt(struct spi_nor *nor, }
/** + * spi_nor_parse_microchip_sfdp() - parse the Microchip manufacturer specific + * SFDP table. + * @nor: pointer to a 'struct spi_nor'. + * @param_header: pointer to the SFDP parameter header. + * + * Return: 0 on success, -errno otherwise. + */ +static int +spi_nor_parse_microchip_sfdp(struct spi_nor *nor, + const struct sfdp_parameter_header *param_header) +{ + size_t size; + u32 addr; + int ret; + + size = param_header->length * sizeof(u32); + addr = SFDP_PARAM_HEADER_PTP(param_header); + + nor->manufacturer_sfdp = devm_kmalloc(nor->dev, size, GFP_KERNEL); + if (!nor->manufacturer_sfdp) + return -ENOMEM; + + ret = spi_nor_read_sfdp(nor, addr, size, nor->manufacturer_sfdp); + + return ret; +} + +/** * spi_nor_parse_sfdp() - parse the Serial Flash Discoverable Parameters. * @nor: pointer to a 'struct spi_nor' * @params: pointer to the 'struct spi_nor_flash_parameter' to be @@ -1892,6 +1921,12 @@ static int spi_nor_parse_sfdp(struct spi_nor *nor, dev_info(dev, "non-uniform erase sector maps are not supported yet.\n"); break;
+ case SFDP_MICROCHIP_ID: + err = spi_nor_parse_microchip_sfdp(nor, param_header); + if (err) + goto exit; + break; + default: break; } diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h index 88e80af57941..836a50178925 100644 --- a/include/linux/mtd/spi-nor.h +++ b/include/linux/mtd/spi-nor.h @@ -251,6 +251,7 @@ struct flash_info; * @lock: the lock for the read/write/erase/lock/unlock operations * @dev: point to a spi device, or a spi nor controller device. * @info: spi-nor part JDEC MFR id and other info + * @manufacturer_sfdp: manufacturer specific SFDP table * @page_size: the page size of the SPI NOR * @addr_width: number of address bytes * @erase_opcode: the opcode for erasing a sector @@ -289,6 +290,7 @@ struct spi_nor { struct udevice *dev; struct spi_slave *spi; const struct flash_info *info; + u8 *manufacturer_sfdp; u32 page_size; u8 addr_width; u8 erase_opcode;
Hello Jagan and Vignesh,
This patch touches the spi nor core, to take it through atmel tree would need your Review/Ack when you have the chance. If you feel otherwise, reassign in patchwork and review through spi tree.
Thanks, Eugen
- spi_nor_parse_microchip_sfdp() - parse the Microchip manufacturer specific
- SFDP table.
- @nor: pointer to a 'struct spi_nor'.
- @param_header: pointer to the SFDP parameter header.
- Return: 0 on success, -errno otherwise.
- size_t size;
- u32 addr;
- int ret;
- size = param_header->length * sizeof(u32);
- addr = SFDP_PARAM_HEADER_PTP(param_header);
- nor->manufacturer_sfdp = devm_kmalloc(nor->dev, size, GFP_KERNEL);
- if (!nor->manufacturer_sfdp)
return -ENOMEM;
- ret = spi_nor_read_sfdp(nor, addr, size, nor->manufacturer_sfdp);
- return ret;
- spi_nor_parse_sfdp() - parse the Serial Flash Discoverable Parameters.
- @params: pointer to the 'struct spi_nor_flash_parameter' to be
if (err)
goto exit;
break;
- default: break; }
- @lock: the lock for the read/write/erase/lock/unlock operations
- @dev: point to a spi device, or a spi nor controller device.
- @info: spi-nor part JDEC MFR id and other info
- @manufacturer_sfdp: manufacturer specific SFDP table
- @page_size: the page size of the SPI NOR
- @addr_width: number of address bytes
- @erase_opcode: the opcode for erasing a sector
- u8 *manufacturer_sfdp; u32 page_size; u8 addr_width; u8 erase_opcode;
Hi Tudor,
Is this ID unique enough such that no other vendor will use the same? I recall that MSB byte should be assigned to Vendor and 0x01 does not seem to be Microchip specific? Or did I miss something?
Regards Vignesh
- SFDP table.
- size_t size;
- u32 addr;
- int ret;
return -ENOMEM;
- return ret;
if (err)
goto exit;
break;
- default: break; }
Hi, Vignesh,
On 10/09/2019 03:04 PM, Vignesh Raghavendra wrote:
External E-Mail
Hi Tudor,
It is unique.
Quoting form JESD216 rev D, section "6.3.3 Definition of Parameter ID Field": "The original JESD216 specification used only a one byte ID field to identify the parameter table owner. JESD216 revision A expanded the ID field to two bytes, MSB and LSB, because a single byte is insufficient to uniquely identify all manufacturers ( vendors). The original single byte parameter ID is now referred to as the parameter ID LSB."
In the Microchip's case, 01h is the Parameter ID MSB (respects the 01h-7fh interval) and bfh is the Parameter ID LSB (has odd parity, which is correct). Now I'm looking in the JEP106AZ standard (Standard Manufacturer’s Identification Code): 01h MSB indicates the bank number (one), and bfh LSB indicates the Manufacturer Identification code (which is bfh for SST).
Cheers, ta
On 09-Oct-19 9:20 PM, Tudor.Ambarus@microchip.com wrote:
Hi, Vignesh,
External E-Mail
Hi Tudor,
It is unique.
Ah, thanks for the explanation! I was confused with bank number initially. Was also confused by the fact that there is an entry for Microchip Technology in JEP106AZ that reads 29. May be rename the macro to indicate SFDP_SST_ID?
Regards Vignesh
On 10/09/2019 07:25 PM, Vignesh Raghavendra wrote:
External E-Mail
Hi, Vignesh,
External E-Mail
Hi Tudor,
It is unique.
Ok, will do so. Thanks!
Hi, Vignesh,
if (err)
goto exit;
This can be improved though. At this point the BFPT parser succeeded, and it would be a pity if we ignore the BFPT data when the vendor specific parser fails. The goto exit should be replaced by a break and a warning message to indicate when an optional parameter table fails.
Please let me know if there are other comments, I'll send v2 if all the rest are ok.
break;
- default: break; }
The SST26VF064BEUI spi-nor flash is programmed at the factory with a globally unique address stored in the SFDP vendor parameter table and it is permanently writeprotected. Retrieve the EUI-48 address and set it as ethaddr env.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- arch/arm/mach-at91/include/mach/at91_common.h | 1 + board/atmel/common/Makefile | 1 + board/atmel/common/mac-spi-nor.c | 127 +++++++++++++++++++++ .../atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 3 + 4 files changed, 132 insertions(+) create mode 100644 board/atmel/common/mac-spi-nor.c
diff --git a/arch/arm/mach-at91/include/mach/at91_common.h b/arch/arm/mach-at91/include/mach/at91_common.h index e929b5e1d207..01e00c508a8a 100644 --- a/arch/arm/mach-at91/include/mach/at91_common.h +++ b/arch/arm/mach-at91/include/mach/at91_common.h @@ -40,6 +40,7 @@ void configure_ddrcfg_input_buffers(bool open); #endif
int at91_set_ethaddr(int offset); +void at91_spi_nor_set_ethaddr(void); int at91_video_show_board_info(void);
#endif /* AT91_COMMON_H */ diff --git a/board/atmel/common/Makefile b/board/atmel/common/Makefile index 4de0912f22e6..6bc8cabb8d6d 100644 --- a/board/atmel/common/Makefile +++ b/board/atmel/common/Makefile @@ -5,4 +5,5 @@
obj-y += board.o obj-$(CONFIG_I2C_EEPROM) += mac_eeprom.o +obj-$(CONFIG_SPI_FLASH_SFDP_SUPPORT) += mac-spi-nor.o obj-$(CONFIG_DM_VIDEO) += video_display.o diff --git a/board/atmel/common/mac-spi-nor.c b/board/atmel/common/mac-spi-nor.c new file mode 100644 index 000000000000..96343678e0b6 --- /dev/null +++ b/board/atmel/common/mac-spi-nor.c @@ -0,0 +1,127 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Microchip Technology Inc. and its subsidiaries + * + * Author: Tudor Ambarus tudor.ambarus@microchip.com + */ + +#include <common.h> +#include <dm.h> +#include <env.h> +#include <linux/mtd/spi-nor.h> +#include <netdev.h> + +#define ETH_ADDR_SIZE 6 + +#ifdef CONFIG_SPI_FLASH_SST +#define SFDP_MICROCHIP_MANUF_ID 0xbf +#define SFDP_MICROCHIP_MEM_TYPE 0x26 +#define SFDP_MICROCHIP_DEV_ID 0x43 + +#define SFDP_MICROCHIP_EUI_OFFSET 0x60 +#define SFDP_MICROCHIP_EUI48 0x30 + +struct sst26vf064beui { + u8 manufacturer_id; + u8 memory_type; + u8 device_id; + u8 reserved; +}; + +/** + * sst26vf064beui_check() - Check the validity of the EUI-48 information from + * the sst26vf064beui SPI NOR Microchip SFDP table. + * @manufacturer_sfdp: pointer to the Microchip manufacturer specific SFDP + * table. + * + * Return: 0 on success, -errno otherwise. + */ +static int sst26vf064beui_check(const u8 *manufacturer_sfdp) +{ + struct sst26vf064beui *sst26vf064beui = + (struct sst26vf064beui *)manufacturer_sfdp; + + if (sst26vf064beui->manufacturer_id != SFDP_MICROCHIP_MANUF_ID) + return -EINVAL; + + if (sst26vf064beui->memory_type != SFDP_MICROCHIP_MEM_TYPE) + return -EINVAL; + + if (sst26vf064beui->device_id != SFDP_MICROCHIP_DEV_ID) + return -EINVAL; + + /* + * Check if the EUI-48 MAC address is programmed in the next six address + * locations. + */ + if (manufacturer_sfdp[SFDP_MICROCHIP_EUI_OFFSET] != + SFDP_MICROCHIP_EUI48) + return -EINVAL; + + return 0; +} + +/** + * sst26vf064beui_get_ethaddr() - Get the ethernet address from the + * sst26vf064beui SPI NOR Microchip SFDP table. + * @manufacturer_sfdp: pointer to the Microchip manufacturer specific SFDP + * table. + * @ethaddr: pointer where to fill the ethernet address + * @size: size of the ethernet address. + * + * Return: 0 on success, -errno otherwise. + */ +static int sst26vf064beui_get_ethaddr(const u8 *manufacturer_sfdp, + u8 *ethaddr, size_t size) +{ + u64 eui_table[2]; + u64 *p = (u64 *)&manufacturer_sfdp[SFDP_MICROCHIP_EUI_OFFSET]; + int i, ret; + + ret = sst26vf064beui_check(manufacturer_sfdp); + if (ret) + return ret; + + for (i = 0; i < 2; i++) + eui_table[i] = le64_to_cpu(p[i]); + + /* Ethaddr starts at offset one. */ + memcpy(ethaddr, &((u8 *)eui_table)[1], size); + + return 0; +} +#endif + +/** + * at91_spi_nor_set_ethaddr() - Retrieve and set the ethernet address from the + * SPI NOR manufacturer specific SFDP table. + */ +void at91_spi_nor_set_ethaddr(void) +{ + struct udevice *dev; + struct spi_nor *nor; + const char *ethaddr_name = "ethaddr"; + u8 ethaddr[ETH_ADDR_SIZE] = {0}; + + if (env_get(ethaddr_name)) + return; + + if (uclass_first_device_err(UCLASS_SPI_FLASH, &dev)) + return; + + nor = dev_get_uclass_priv(dev); + if (!nor) + return; + + if (!nor->manufacturer_sfdp) + return; + +#ifdef CONFIG_SPI_FLASH_SST + if (sst26vf064beui_get_ethaddr(nor->manufacturer_sfdp, ethaddr, + ETH_ADDR_SIZE)) + return; +#endif + + if (is_valid_ethaddr(ethaddr)) + eth_env_set_enetaddr(ethaddr_name, ethaddr); +} diff --git a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c index fda06c824d53..fc563ebb7150 100644 --- a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c +++ b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c @@ -68,6 +68,9 @@ int board_init(void) #ifdef CONFIG_MISC_INIT_R int misc_init_r(void) { +#ifdef CONFIG_SPI_FLASH_SFDP_SUPPORT + at91_spi_nor_set_ethaddr(); +#endif return 0; } #endif
CONFIG_SPI_FLASH_SFDP_SUPPORT enables the SFDP Vendor parser, and for the Microchip case, the retrieval of the ethaddr from the SPI NOR flash.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index 82568e286d81..e7a9cc302d3e 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -31,8 +31,8 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_SPI_LOAD=y -CONFIG_SPL_AT91_MCK_BYPASS=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 +CONFIG_SPL_AT91_MCK_BYPASS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set @@ -80,6 +80,7 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y
Enable the SPI NOR SFDP support and the Microchip QSPI driver. CONFIG_SPI_FLASH_SFDP_SUPPORT enables the SFDP Vendor parser, and for the Microchip case, the retrieval of the ethaddr from the SPI NOR flash.
While touching the SPI NOR logic, sync with the sama5d27_wlsom1_ek_qspiflash_defconfig and enable CONFIG_SPI_FLASH_SPANSION.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- configs/sama5d27_wlsom1_ek_mmc_defconfig | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index 50a8a8e83ccb..0b2b480e338a 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -17,6 +17,7 @@ CONFIG_DEBUG_UART_CLOCK=82000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" @@ -26,7 +27,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set @@ -67,8 +67,12 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_SPEED=50000000 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_PHY_MICREL=y @@ -83,6 +87,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y
Eugen.Hristev@microchip.com
Vignesh Raghavendra
