[U-Boot] [PATCH] bmips: swapping IO space isn't required
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- arch/mips/mach-bmips/Kconfig | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/arch/mips/mach-bmips/Kconfig b/arch/mips/mach-bmips/Kconfig index 521996599e..b259a931c9 100644 --- a/arch/mips/mach-bmips/Kconfig +++ b/arch/mips/mach-bmips/Kconfig @@ -25,7 +25,6 @@ config SOC_BMIPS_BCM3380 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_WATCHDOG help This supports BMIPS BCM3380 family. @@ -36,7 +35,6 @@ config SOC_BMIPS_BCM6318 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_SYSCON help This supports BMIPS BCM6318 family. @@ -47,7 +45,6 @@ config SOC_BMIPS_BCM6328 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_SYSCON help This supports BMIPS BCM6328 family including BCM63281 and BCM63283. @@ -58,7 +55,6 @@ config SOC_BMIPS_BCM6338 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_SYSCON help This supports BMIPS BCM6338 family. @@ -69,7 +65,6 @@ config SOC_BMIPS_BCM6348 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_WATCHDOG help This supports BMIPS BCM6348 family. @@ -80,7 +75,6 @@ config SOC_BMIPS_BCM6358 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_SYSCON help This supports BMIPS BCM6358 family including BCM6358 and BCM6359. @@ -91,7 +85,6 @@ config SOC_BMIPS_BCM6368 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_SYSCON help This supports BMIPS BCM6368 family including BCM6368 and BCM6369. @@ -102,7 +95,6 @@ config SOC_BMIPS_BCM6362 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_SYSCON help This supports BMIPS BCM6362 family including BCM6361 and BCM6362. @@ -113,7 +105,6 @@ config SOC_BMIPS_BCM63268 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_SYSCON help This supports BMIPS BCM63268 family including BCM63168, BCM63169, @@ -125,7 +116,6 @@ config SOC_BMIPS_BCM6838 select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select SWAP_IO_SPACE select SYSRESET_SYSCON help This supports BMIPS BCM6838 family including BCM68380, BCM68381,
Am 09.12.18 um 10:41 schrieb Álvaro Fernández Rojas:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
I guess this is related to your recent series "serial: bcm6345: switch to raw I/O functions"? As Tom already applied this series, this patch should go in 2019.01 too?
Hi Daniel,
Yes, I completely forgot I had copied SWAP_IO_SPACE from linux target without really needing it.
Without this patch serial driver isn't working for bmips boards, so yeah this should go in 2019.01.
applied to u-boot-mips/fixes, thanks.
Daniel Schwierzeck
