Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function only if CONFIG_SKIP_LOWLEVEL_INIT is not defined
At present in "start.S" inside cpu\arm926ejs, cpu_init_crit is called only if "CONFIG_SKIP_LOWLEVEL_INIT" is not defined
#ifndef CONFIG_SKIP_LOWLEVEL_INIT bl cpu_init_crit #endif
But "cpu_init_crit" function doesnt have any if defs which means cpu_init_crit function will compile irrespective of "CONFIG_SKIP_LOWLEVEL_INIT". Hence the patch. The same is done in other processor files. Kindly check "cpu\arm920t\start.S"
Regards
Gururaja
________________________________
From: Dirk Behme [mailto:dirk.behme@googlemail.com] Sent: Wed 19-Dec-07 3:27 PM To: Gururaja Hebbar K R Cc: u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function only if CONFIG_SKIP_LOWLEVEL_INIT is not defined
Hebbar wrote:
This patches allows cpu_init_crit function to be compilled only if CONFIG_SKIP_LOWLEVEL_INIT is not defined. At present irrespective of CONFIG_SKIP_LOWLEVEL_INIT, cpu_init_crit is always compilled. This is for arm926ejs module.
Signed-off-by: K R Gururaja Hebbar gururajakr@sanyo.co.in
--- u-boot-1.3.1/cpu/arm926ejs/start.S 2007-12-06 01:21:19.000000000 -0800 +++ uboot/cpu/arm926ejs/start.S 2007-12-19 08:40:37.296875000 -0800 @@ -187,7 +187,7 @@ clbss_l:str r2, [r0] /* clear loop... _start_armboot: .word start_armboot
+#ifndef CONFIG_SKIP_LOWLEVEL_INIT /*
@@ -225,6 +225,9 @@ cpu_init_crit: bl lowlevel_init /* go setup pll,mux,memory */ mov lr, ip /* restore link */ mov pc, lr /* back to my caller */
+#endif /* CONFIG_SKIP_LOWLEVEL_INIT */
I welcome comments, complaints, suggestions and advices.
The reason for this is to decrease resulting binary size? If so, all lowlevel_init() should be encapsulated as well to save even more space?
Dirk
Yes, thats clear.
So the only reason that you do this is because its done in other files this way as well?
To not execute cpu_init_crit the existing ifndef is sufficent. But my point is: When you want to decrease resulting binary size by excluding unnecessary code (cpu_init_crit), then you should also exclude the then unused board specific lowlevel_init called from cpu_init_crit as well.
Dirk
*From:* Dirk Behme [mailto:dirk.behme@googlemail.com] *Sent:* Wed 19-Dec-07 3:27 PM *To:* Gururaja Hebbar K R *Cc:* u-boot-users@lists.sourceforge.net *Subject:* Re: [U-Boot-Users] [PATCH] ARM926: compile cpu_init_crit function only if CONFIG_SKIP_LOWLEVEL_INIT is not defined
clear loop...
Dirk
Dirk Behme
Gururaja Hebbar K R
