[U-Boot] [PATCH v1 1/3] fastboot: OUT transaction length must be aligned to wMaxPacketSize
OUT transactions must be aligned to wMaxPacketSize for each transfer, or else transfer will not complete successfully. This patch modifies rx_bytes_expected to return a transfer length that is aligned to wMaxPacketSize.
Note that the value of ep->desc->wMaxPacketSize and ep->maxpacket may not be the same value, and it is the value of ep->desc->wMaxPacketSize that should be used for alignment.
Signed-off-by: Dileep Katta dileep.katta@linaro.org --- drivers/usb/gadget/f_fastboot.c | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index a8d8205..0d53a61 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -370,13 +370,20 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) fastboot_tx_write_str(response); }
-static unsigned int rx_bytes_expected(void) +static unsigned int rx_bytes_expected(unsigned maxpacket) { int rx_remain = download_size - download_bytes; + int rem = 0; if (rx_remain < 0) return 0; if (rx_remain > EP_BUFFER_SIZE) return EP_BUFFER_SIZE; + if (rx_remain < maxpacket) { + rx_remain = maxpacket; + } else if (rx_remain % maxpacket != 0) { + rem = rx_remain % maxpacket; + rx_remain = rx_remain + (maxpacket - rem); + } return rx_remain; }
@@ -425,7 +432,7 @@ static void rx_handler_dl_image(struct usb_ep *ep, struct usb_request *req)
printf("\ndownloading of %d bytes finished\n", download_bytes); } else { - req->length = rx_bytes_expected(); + req->length = rx_bytes_expected(ep->desc->wMaxPacketSize); if (req->length < ep->maxpacket) req->length = ep->maxpacket; } @@ -453,7 +460,7 @@ static void cb_download(struct usb_ep *ep, struct usb_request *req) } else { sprintf(response, "DATA%08x", download_size); req->complete = rx_handler_dl_image; - req->length = rx_bytes_expected(); + req->length = rx_bytes_expected(ep->desc->wMaxPacketSize); if (req->length < ep->maxpacket) req->length = ep->maxpacket; }
If the string is copied without NULL termination using strncpy(), then strncat() on the next line, may concatenate the string after some stale (or random) data, if the response string was not zero-initialized.
Signed-off-by: Dileep Katta dileep.katta@linaro.org --- common/fb_mmc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/fb_mmc.c b/common/fb_mmc.c index 3911989..73055cc 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -23,13 +23,13 @@ static char *response_str;
void fastboot_fail(const char *s) { - strncpy(response_str, "FAIL", 4); + strncpy(response_str, "FAIL\0", 5); strncat(response_str, s, RESPONSE_LEN - 4 - 1); }
void fastboot_okay(const char *s) { - strncpy(response_str, "OKAY", 4); + strncpy(response_str, "OKAY\0", 5); strncat(response_str, s, RESPONSE_LEN - 4 - 1); }
- strncpy(response_str, "OKAY\0", 5); strncat(response_str, s, RESPONSE_LEN - 4 - 1); }
THANKS!
Reviewed-by: Steve Rae srae@broadcom.com
Hi Dileep,
- strncpy(response_str, "FAIL\0", 5); strncat(response_str, s, RESPONSE_LEN - 4 - 1);
Applied to u-boot-dfu branch.
Thanks for the patch!
Configure the serial number using the serial# environment variable during the fastboot bind.
This enables "fastboot devices" to return the serial number for the attached devices.
Signed-off-by: Dileep Katta dileep.katta@linaro.org --- drivers/usb/gadget/f_fastboot.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 0d53a61..d114c07 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -136,6 +136,7 @@ static int fastboot_bind(struct usb_configuration *c, struct usb_function *f) int id; struct usb_gadget *gadget = c->cdev->gadget; struct f_fastboot *f_fb = func_to_fastboot(f); + const char *s;
/* DYNAMIC interface numbers assignments */ id = usb_interface_id(c, f); @@ -161,6 +162,10 @@ static int fastboot_bind(struct usb_configuration *c, struct usb_function *f)
hs_ep_out.bEndpointAddress = fs_ep_out.bEndpointAddress;
+ s = getenv("serial#"); + if (s) + g_dnl_set_serialnumber((char *)s); + return 0; }
const char *s;
- s = getenv("serial#");
- if (s)
- return 0; }
Acked-by: Steve Rae srae@broadcom.com
Hi Dileep,
const char *s;
@@ -161,6 +162,10 @@ static int fastboot_bind(struct usb_configuration *c, struct usb_function *f) hs_ep_out.bEndpointAddress = fs_ep_out.bEndpointAddress;
- if (s)
Note that the value of wMaxPacketSize and ep->maxpacket may not be the same value, and it is the value of wMaxPacketSize that should be used for alignment.
Signed-off-by: Dileep Katta dileep.katta@linaro.org --- Changes from v1: - Corrected source of wMaxPacketSize drivers/usb/gadget/f_fastboot.c | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index a8d8205..b18452e 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -370,13 +370,20 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) fastboot_tx_write_str(response); }
printf("\ndownloading of %d bytes finished\n", download_bytes); } else { - req->length = rx_bytes_expected(); + req->length = rx_bytes_expected(fs_ep_out.wMaxPacketSize); if (req->length < ep->maxpacket) req->length = ep->maxpacket; } @@ -453,7 +460,7 @@ static void cb_download(struct usb_ep *ep, struct usb_request *req) } else { sprintf(response, "DATA%08x", download_size); req->complete = rx_handler_dl_image; - req->length = rx_bytes_expected(); + req->length = rx_bytes_expected(fs_ep_out.wMaxPacketSize); if (req->length < ep->maxpacket) req->length = ep->maxpacket; }
Hi Dileep,
-----Original Message----- From: Dileep Katta [mailto:dileep.katta@linaro.org] Sent: Friday, February 13, 2015 11:59 AM To: u-boot@lists.denx.de; robherring2@gmail.com; Rini, Tom; rob.herring@linaro.org; srae@broadcom.com; l.majewski@samsung.com; Stegmaier, Angela Cc: Dileep Katta Subject: [U-Boot][PATCH v2 1/3] fastboot: OUT transaction length must be aligned to wMaxPacketSize
Changes from v1:
- int rem = 0; if (rx_remain < 0) return 0; if (rx_remain > EP_BUFFER_SIZE) return EP_BUFFER_SIZE;
- if (rx_remain < maxpacket) {
- } else if (rx_remain % maxpacket != 0) {
- } return rx_remain;
req->length =
This will not be the correct value in the case of HS connections.
Thanks, Angela
req->length =
rx_bytes_expected(fs_ep_out.wMaxPacketSize); if (req->length < ep->maxpacket) req->length = ep->maxpacket; } -- 1.8.3.2
Note that the value of wMaxPacketSize and ep->maxpacket may not be the same value, and it is the value of wMaxPacketSize that should be used for alignment. wMaxPacketSize is passed depending on the speed of connection.
Signed-off-by: Dileep Katta dileep.katta@linaro.org --- Changes in v2: - Corrected source of wMaxPacketSize Changes in v3: - Corrected the logic to accomodate both HS and FS speeds
drivers/usb/gadget/f_fastboot.c | 27 ++++++++++++++++++++++----- 1 file changed, 22 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index a8d8205..2793590 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -55,6 +55,7 @@ static inline struct f_fastboot *func_to_fastboot(struct usb_function *f) static struct f_fastboot *fastboot_func; static unsigned int download_size; static unsigned int download_bytes; +static bool is_high_speed;
static struct usb_endpoint_descriptor fs_ep_in = { .bLength = USB_DT_ENDPOINT_SIZE, @@ -219,10 +220,13 @@ static int fastboot_set_alt(struct usb_function *f, __func__, f->name, interface, alt);
/* make sure we don't enable the ep twice */ - if (gadget->speed == USB_SPEED_HIGH) + if (gadget->speed == USB_SPEED_HIGH) { ret = usb_ep_enable(f_fb->out_ep, &hs_ep_out); - else + is_high_speed = true; + } else { ret = usb_ep_enable(f_fb->out_ep, &fs_ep_out); + is_high_speed = false; + } if (ret) { puts("failed to enable out ep\n"); return ret; @@ -370,13 +374,20 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) fastboot_tx_write_str(response); }
-static unsigned int rx_bytes_expected(void) +static unsigned int rx_bytes_expected(unsigned int maxpacket) { int rx_remain = download_size - download_bytes; + int rem = 0; if (rx_remain < 0) return 0; if (rx_remain > EP_BUFFER_SIZE) return EP_BUFFER_SIZE; + if (rx_remain < maxpacket) { + rx_remain = maxpacket; + } else if (rx_remain % maxpacket != 0) { + rem = rx_remain % maxpacket; + rx_remain = rx_remain + (maxpacket - rem); + } return rx_remain; }
@@ -388,6 +399,7 @@ static void rx_handler_dl_image(struct usb_ep *ep, struct usb_request *req) const unsigned char *buffer = req->buf; unsigned int buffer_size = req->actual; unsigned int pre_dot_num, now_dot_num; + unsigned int max;
if (req->status != 0) { printf("Bad status: %d\n", req->status); @@ -425,7 +437,9 @@ static void rx_handler_dl_image(struct usb_ep *ep, struct usb_request *req)
printf("\ndownloading of %d bytes finished\n", download_bytes); } else { - req->length = rx_bytes_expected(); + max = is_high_speed ? hs_ep_out.wMaxPacketSize : + fs_ep_out.wMaxPacketSize; + req->length = rx_bytes_expected(max); if (req->length < ep->maxpacket) req->length = ep->maxpacket; } @@ -438,6 +452,7 @@ static void cb_download(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; char response[RESPONSE_LEN]; + unsigned int max;
strsep(&cmd, ":"); download_size = simple_strtoul(cmd, NULL, 16); @@ -453,7 +468,9 @@ static void cb_download(struct usb_ep *ep, struct usb_request *req) } else { sprintf(response, "DATA%08x", download_size); req->complete = rx_handler_dl_image; - req->length = rx_bytes_expected(); + max = is_high_speed ? hs_ep_out.wMaxPacketSize : + fs_ep_out.wMaxPacketSize; + req->length = rx_bytes_expected(max); if (req->length < ep->maxpacket) req->length = ep->maxpacket; }
Hi Dileep,
Changes in v2:
Changes in v3:
- if (gadget->speed == USB_SPEED_HIGH) { ret = usb_ep_enable(f_fb->out_ep, &hs_ep_out);
- else
- } else { ret = usb_ep_enable(f_fb->out_ep, &fs_ep_out);
- } if (ret) { puts("failed to enable out ep\n"); return ret;
unsigned int max;
@@ -425,7 +437,9 @@ static void rx_handler_dl_image(struct usb_ep *ep, struct usb_request *req) printf("\ndownloading of %d bytes finished\n", download_bytes); } else {
if (req->length < ep->maxpacket) req->length = ep->maxpacket; }req->length = rx_bytes_expected(max);
unsigned int max;
... updated the subject line, was: Re: [U-Boot][PATCH v3 1/3] fastboot: OUT transaction length must be aligned to wMaxPacketSize
On 15-02-24 02:28 AM, Lukasz Majewski wrote:
Hi Dileep,
Changes in v2:
Changes in v3:
- else
Is anyone else having problems with this code??? I need to remove these six (newly added) lines in order to get my boards to work -- otherwise, they just "hang" druing the download phase of "fastboot flash"....
Thanks in advance, Steve
return rx_remain; }
unsigned int max;
unsigned int max;
MORE INFO:
I added some logs to see what is happening:
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index f87aae7..824430f 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -427,12 +427,17 @@ static unsigned int rx_bytes_expected(unsigned int maxpacket) return 0; if (rx_remain > EP_BUFFER_SIZE) return EP_BUFFER_SIZE; +#if 1 if (rx_remain < maxpacket) { + printf("\nVALIDATE: %s: %d (%d) %d\n", __func__, rx_remain, maxpacket, maxpacket); rx_remain = maxpacket; } else if (rx_remain % maxpacket != 0) { rem = rx_remain % maxpacket; + printf("\nVALIDATE: %s: %d (%d) %d %d\n", __func__, rx_remain, maxpacket, rem, rx_remain + (maxpacket - rem)); rx_remain = rx_remain + (maxpacket - rem); } +#endif + printf("\nVALIDATE: using %d\n", rx_remain); return rx_remain; }
RESULTS:
In the case that fails, (#if 1), it reports: VALIDATE: rx_bytes_expected: 812 (512) 300 1024 VALIDATE: using 1024
In the case that works (#if 0), it reports: VALIDATE: using 812
To me, it looks like there is only 812 bytes more to be downloaded, but this code modifies that value to expect 1024 bytes; and I guess it hangs after the 812 have been received (while waiting for the rest of the 1024)....
Please advise!
Changes from v1:
- } return rx_remain; }
} else {
if (req->length < ep->maxpacket) req->length = ep->maxpacket; }req->length = rx_bytes_expected(fs_ep_out.wMaxPacketSize);
I don't understand... Why are we always limiting this to the "Full Speed" size? ( see fs_ep_out versus hs_ep_out defined previously in this file... )
Thanks, Steve
participants (5)
Dileep Katta
Lukasz Majewski
Stegmaier, Angela
Steve Rae
Steve Rae
