[U-Boot] [PATCH] vf610twr: Fix typo in DRAM init
This commit fixes a typo in vf610twr DRAM init that was causing a hang in U-Boot for the Vybrid Tower. This typo was introduced in commit 3f353cecc (vf610: refactor DDRMC code).
Signed-off-by: Anthony Felice tony.felice@timesys.com --- board/freescale/vf610twr/vf610twr.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index a78e9e6..fa0075c 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -108,7 +108,7 @@ int dram_init(void) .trcd_int = 6, .tras_lockout = 0, .tdal = 12, - .bstlen = 0, + .bstlen = 3, .tdll = 512, .trp_ab = 6, .tref = 3120,
On Fri, Oct 9, 2015 at 5:38 PM, Anthony Felice tony.felice@timesys.com wrote:
Seems fine for me. Stefano?
Reviewed-by: Fabio Estevam fabio.estevam@freescale.com
Also, adding the author of 3f353cecc ("vf610: refactor DDRMC code") and the i.MX/Vybrid maintainer.
Thanks
Bonjour Fabio,
Thanks
Thanks to Anthony for spotting and fixing this!
Cordialement, Albert ARIBAUD 3ADEV
Hi Stefano,
On Tue, Oct 13, 2015 at 5:12 PM, Albert ARIBAUD albert.aribaud@3adev.fr wrote:
This one fixes a regression. Please consider applying it to 2015.10.
Thanks
Hi Anthony,
Tested on a Tower, works for me.
Can you also fix the Colibri VF board? It seems to suffer the same issue, introduced by the same commit...
-- Stefan
.bstlen = 0,
.tdll = 512, .trp_ab = 6, .tref = 3120,.bstlen = 3,
Hi Stefan,
Yes, I can submit the fix for the Colibri VF board as well - although I don't have the Colibri board to boot test on. I will be out of the office the next few days so I will submit next week.
Thanks,
Tony
On Tue, Oct 13, 2015 at 10:47 PM, Stefan Agner stefan@agner.ch wrote:
Hi Anthony,
-- Stefan
.bstlen = 0,
Hi Tony,
I then realized that we are close to the release and submitted an individual patch right away. So you don't need to create a patch. Thanks for uncovering the bug and the offer.
Patch, see: https://patchwork.ozlabs.org/patch/529985/
-- Stefan
On 2015-10-14 16:29, Tony Felice wrote:
Hi Stefan,
Thanks,
Tony
Hi Anthony,
-- Stefan
- .bstlen = 0,
- .bstlen = 3,
Tony Felice Vybrid Technical Lead Timesys Corporation
Hi Stefano,
This patch did not make it into the git tree, however my patch which followed that one (and which fixed the same issue on colibri_vf only), did make it...
Sorry, my comment below was somewhat confusing. I descided afterwards to just send a seperate one for colibri_vf.
Could you also merge this one into 2015.10?
-- Stefan
On 2015-10-14 16:54, Stefan Agner wrote:
Hi Tony,
-- Stefan
Hi Stefan,
Thanks,
Tony
Hi Anthony,
-- Stefan
- .bstlen = 0,
- .bstlen = 3,
Hi Stefan,
On 16/10/2015 08:32, Stefan Agner wrote:
Hi Stefano,
Yes, I was quite confused. I have seen more patches (from you, Anthony and Fabio) fixing the same issue, and I missed that only two of them overlap. Fabio's patch (already merged) fixes the same issue on colibri_vf, vf610twr is still broken.
I merge it and I ask Tom how to proceed. Maybe he prefer to pick it up himself.
Best regards, Stefano
Signed-off-by: Anthony Felice tony.felice@timesys.com Reviewed-by: Fabio Estevam fabio.estevam@freescale.com
participants (8)
Albert ARIBAUD
Anthony Felice
Fabio Estevam
Otavio Salvador
Stefan Agner
Stefano Babic
Tony Felice
