[U-Boot] [PATCH v3] disk: convert to Kconfig
This converts the following to Kconfig: CONFIG_PARTITIONS CONFIG_MAC_PARTITION CONFIG_DOS_PARTITION CONFIG_ISO_PARTITION CONFIG_AMIGA_PARTITION CONFIG_EFI_PARTITION CONFIG_PARTITION_UUIDS CONFIG_PARTITION_TYPE_GUID
Specific SPL config are added to reduce SPL size for some target and solve compilation issues
CONFIG_SPL_MAC_PARTITION CONFIG_SPL_DOS_PARTITION CONFIG_SPL_ISO_PARTITION CONFIG_SPL_AMIGA_PARTITION CONFIG_SPL_EFI_PARTITION
Associated test are updated to the correct CONFIG (SPL or not) by using macro CONFIG_IS_ENABLED
To update the U-Boot code I use : 0- Resync with savedefconfig /tools/moveconfig.py -s -Cy
1- update defconfig for new SPL option ./tools/moveconfig.py --spl --commit \ PARTITIONS MAC_PARTITION DOS_PARTITION \ ISO_PARTITION AMIGA_PARTITION EFI_PARTITION \ PARTITION_UUIDS PARTITION_TYPE_GUID
then replace CONFIG by CONFIG_SPL in defconfig sed -i "s/CONFIG_(DOS|EFI|ISO|MAC|AMIGA)_PARTITION/CONFIG_SPL_\1_PARTITION/" \ configs/*
2- update defconfig for existing option ./tools/moveconfig.py --commit --yes \ PARTITIONS MAC_PARTITION DOS_PARTITION \ ISO_PARTITION AMIGA_PARTITION EFI_PARTITION \ PARTITION_UUIDS PARTITION_TYPE_GUID
=> squash the 2 modifications
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay73@gmail.com --- move disk to Kconfig as proposed by Simon Glass in thread [Resend RFC PATCH v1 1/3] add support of GPT partitioning over MTD
NB: I create _SPL_ config because I have issue with size of SPL for some platform
=> list of supported partition type is not the same between SPL and U-Boot, that allow size reduction for SPL build (CONFIG are under compilation flag CONFIG_SPL_BUILD in .h)
I compile this patch on v2016.11 without issue linked to this code on all platform and this commit is rebased on master
Changes in v3: change Kconfig to reduce impact in platform defconfig after Tom Rini review - default y for all SPL config - MAC DOS ISO and EFI enable by default for some platforms - DOS enable with command FAT or USB storage
Changes in v2: - solve compilation issue for config_fallback.h (CONFIG_IS_ENABLED unknown) - rebase on master branch - default y for DOS partition as proposed by Tom Rini - removed not related changes in defconfig files
Kconfig | 6 ++ arch/arm/include/asm/arch-ls102xa/config.h | 1 - cmd/bootefi.c | 4 +- cmd/reiser.c | 2 +- cmd/zfs.c | 2 +- common/fb_mmc.c | 4 +- configs/M5253DEMO_defconfig | 1 + configs/M5253EVBE_defconfig | 1 + configs/am335x_baltos_defconfig | 2 + configs/am335x_boneblack_defconfig | 2 + configs/am335x_boneblack_vboot_defconfig | 2 + configs/am335x_evm_defconfig | 2 + configs/am335x_evm_nor_defconfig | 2 + configs/am335x_evm_norboot_defconfig | 2 + configs/am335x_evm_spiboot_defconfig | 2 + configs/am335x_evm_usbspl_defconfig | 2 + configs/am335x_igep0033_defconfig | 2 + configs/am335x_shc_defconfig | 3 + configs/am335x_shc_ict_defconfig | 3 + configs/am335x_shc_netboot_defconfig | 3 + configs/am335x_shc_prompt_defconfig | 3 + configs/am335x_shc_sdboot_defconfig | 3 + configs/am335x_shc_sdboot_prompt_defconfig | 3 + configs/am335x_sl50_defconfig | 2 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 2 + configs/am43xx_evm_ethboot_defconfig | 2 + configs/am43xx_evm_qspiboot_defconfig | 2 + configs/am43xx_evm_usbhost_boot_defconfig | 2 + configs/am43xx_hs_evm_defconfig | 2 + configs/am57xx_evm_defconfig | 2 + configs/am57xx_evm_nodt_defconfig | 2 + configs/am57xx_hs_evm_defconfig | 2 + configs/ap325rxa_defconfig | 1 + configs/arndale_defconfig | 2 + configs/bayleybay_defconfig | 3 + configs/bcm11130_defconfig | 2 + configs/bcm11130_nand_defconfig | 2 + configs/bcm23550_w1d_defconfig | 2 + configs/bcm28155_ap_defconfig | 2 + configs/bcm28155_w1d_defconfig | 2 + configs/bg0900_defconfig | 1 + configs/birdland_bav335a_defconfig | 2 + configs/birdland_bav335b_defconfig | 2 + configs/cairo_defconfig | 2 + configs/chromebit_mickey_defconfig | 2 + configs/chromebook_jerry_defconfig | 2 + configs/chromebook_link_defconfig | 3 + configs/chromebook_minnie_defconfig | 2 + configs/chromebook_samus_defconfig | 3 + configs/chromebox_panther_defconfig | 3 + configs/clearfog_defconfig | 2 + configs/cm_t335_defconfig | 2 + configs/cm_t43_defconfig | 2 + configs/cm_t54_defconfig | 2 + ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 3 + configs/conga-qeval20-qa3-e3845_defconfig | 3 + configs/coreboot-x86_defconfig | 3 + configs/cougarcanyon2_defconfig | 3 + configs/crownbay_defconfig | 3 + configs/d2net_v2_defconfig | 3 + configs/db-88f6820-amc_defconfig | 2 + configs/db-88f6820-gp_defconfig | 2 + configs/db-mv784mp-gp_defconfig | 2 + configs/dbau1000_defconfig | 1 + configs/dbau1100_defconfig | 1 + configs/dbau1500_defconfig | 1 + configs/devkit8000_defconfig | 2 + configs/dfi-bt700-q7x-151_defconfig | 3 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/dra7xx_evm_defconfig | 2 + configs/dra7xx_hs_evm_defconfig | 2 + configs/draco_defconfig | 1 + configs/dragonboard410c_defconfig | 2 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 2 + configs/ds414_defconfig | 1 + configs/duovero_defconfig | 2 + configs/edminiv2_defconfig | 1 + configs/efi-x86_defconfig | 3 + configs/etamin_defconfig | 1 + configs/evb-rk3036_defconfig | 2 + configs/evb-rk3288_defconfig | 2 + configs/evb-rk3399_defconfig | 2 + configs/fennec-rk3288_defconfig | 2 + configs/firefly-rk3288_defconfig | 2 + configs/galileo_defconfig | 3 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/gplugd_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/highbank_defconfig | 3 + configs/hikey_defconfig | 2 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/igep0020_defconfig | 2 + configs/igep0030_defconfig | 2 + configs/igep0032_defconfig | 2 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/inetspace_v2_defconfig | 3 + configs/k2e_evm_defconfig | 2 + configs/k2g_evm_defconfig | 2 + configs/k2hk_evm_defconfig | 2 + configs/k2l_evm_defconfig | 2 + configs/kc1_defconfig | 2 + configs/kylin-rk3036_defconfig | 2 + configs/ls1021aiot_qspi_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/lschlv2_defconfig | 3 + configs/lsxhl_defconfig | 3 + configs/marsboard_defconfig | 2 + configs/miniarm-rk3288_defconfig | 2 + configs/minnowmax_defconfig | 3 + configs/ms7720se_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 3 + configs/mvebu_db-88f7040_defconfig | 3 + configs/mx35pdk_defconfig | 2 + configs/mx6cuboxi_defconfig | 2 + configs/nas220_defconfig | 3 + configs/net2big_v2_defconfig | 3 + configs/netspace_lite_v2_defconfig | 3 + configs/netspace_max_v2_defconfig | 3 + configs/netspace_mini_v2_defconfig | 2 + configs/netspace_v2_defconfig | 3 + configs/novena_defconfig | 2 + configs/nsa310s_defconfig | 1 + configs/odroid-c2_defconfig | 4 + configs/odroid-xu3_defconfig | 2 + configs/odroid_defconfig | 2 + configs/omap3_beagle_defconfig | 2 + configs/omap3_evm_defconfig | 2 + configs/omap3_logic_defconfig | 2 + configs/omap3_overo_defconfig | 2 + configs/omap3_pandora_defconfig | 2 + configs/omap3_zoom1_defconfig | 2 + configs/omap4_panda_defconfig | 2 + configs/omap4_sdp4430_defconfig | 2 + configs/omap5_uevm_defconfig | 2 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/origen_defconfig | 2 + configs/pcm051_rev1_defconfig | 2 + configs/pcm051_rev3_defconfig | 2 + configs/pcm058_defconfig | 3 + configs/peach-pi_defconfig | 2 + configs/peach-pit_defconfig | 2 + configs/pengwyn_defconfig | 2 + configs/pepper_defconfig | 2 + configs/pic32mzdask_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/popmetal-rk3288_defconfig | 2 + configs/qemu-x86_defconfig | 3 + configs/qemu-x86_efi_payload32_defconfig | 3 + configs/qemu-x86_efi_payload64_defconfig | 3 + configs/r2dplus_defconfig | 1 + configs/r7780mp_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/riotboard_defconfig | 2 + configs/rock2_defconfig | 2 + configs/rpi_2_defconfig | 2 + configs/rpi_3_32b_defconfig | 2 + configs/rpi_3_defconfig | 2 + configs/rpi_defconfig | 2 + configs/s32v234evb_defconfig | 3 + configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 2 + configs/salvator-x_defconfig | 1 + configs/sandbox_defconfig | 4 + configs/sandbox_noblk_defconfig | 4 + configs/sandbox_spl_defconfig | 4 + configs/sh7752evb_defconfig | 1 + configs/sh7753evb_defconfig | 1 + configs/sh7757lcr_defconfig | 1 + configs/sheevaplug_defconfig | 1 + configs/smdk5250_defconfig | 2 + configs/smdk5420_defconfig | 2 + configs/smdkv310_defconfig | 2 + configs/sniper_defconfig | 2 + configs/snow_defconfig | 2 + configs/som-db5800-som-6867_defconfig | 3 + configs/spring_defconfig | 2 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 3 + configs/theadorable_debug_defconfig | 2 + configs/theadorable_defconfig | 2 + configs/thuban_defconfig | 1 + configs/trats2_defconfig | 2 + configs/trats_defconfig | 2 + configs/udoo_neo_defconfig | 2 + configs/usbarmory_defconfig | 2 + configs/vexpress_ca15_tc2_defconfig | 2 + configs/vexpress_ca5x2_defconfig | 2 + configs/vexpress_ca9x4_defconfig | 2 + configs/vinco_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/wandboard_defconfig | 2 + configs/warp7_defconfig | 1 + configs/warp7_secure_defconfig | 1 + configs/woodburn_defconfig | 2 + configs/woodburn_sd_defconfig | 2 + configs/work_92105_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 2 + configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 2 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 2 + configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 2 + configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 2 + configs/xilinx_zynqmp_zcu102_defconfig | 2 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 2 + configs/zc5202_defconfig | 2 + configs/zc5601_defconfig | 2 + disk/Kconfig | 97 ++++++++++++++++++++++ disk/Makefile | 12 +-- disk/part.c | 10 +-- disk/part_amiga.h | 2 +- disk/part_efi.c | 2 +- disk/part_mac.h | 2 +- include/config_defaults.h | 1 - include/config_distro_bootcmd.h | 1 - include/config_distro_defaults.h | 3 - include/config_fallbacks.h | 1 + include/configs/B4860QDS.h | 1 - include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 6 -- include/configs/C29XPCIE.h | 1 - include/configs/CPCI4052.h | 3 - include/configs/M52277EVB.h | 3 - include/configs/M5253DEMO.h | 2 - include/configs/M5253EVBE.h | 2 - include/configs/M54455EVB.h | 2 - include/configs/M5475EVB.h | 1 - include/configs/M5485EVB.h | 1 - include/configs/MIP405.h | 3 - include/configs/MPC8308RDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8349ITX.h | 1 - include/configs/MPC837XEMDS.h | 2 - include/configs/MPC837XERDB.h | 2 - include/configs/MPC8536DS.h | 5 -- include/configs/MPC8544DS.h | 1 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1010RDB.h | 3 - include/configs/P1022DS.h | 5 -- include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 3 - include/configs/PIP405.h | 3 - include/configs/PLU405.h | 3 - include/configs/PMC440.h | 3 - include/configs/T102xQDS.h | 3 - include/configs/T102xRDB.h | 2 - include/configs/T1040QDS.h | 3 - include/configs/T104xRDB.h | 3 - include/configs/T208xQDS.h | 3 - include/configs/T208xRDB.h | 3 - include/configs/T4240QDS.h | 2 - include/configs/T4240RDB.h | 4 - include/configs/TQM5200.h | 3 - include/configs/TQM823L.h | 3 - include/configs/TQM823M.h | 3 - include/configs/TQM850L.h | 3 - include/configs/TQM850M.h | 3 - include/configs/TQM855L.h | 3 - include/configs/TQM855M.h | 3 - include/configs/TQM860L.h | 3 - include/configs/TQM860M.h | 3 - include/configs/TQM862L.h | 3 - include/configs/TQM862M.h | 3 - include/configs/TQM866M.h | 3 - include/configs/TQM885D.h | 3 - include/configs/UCP1020.h | 5 -- include/configs/VCMA9.h | 1 - include/configs/a4m072.h | 2 - include/configs/ac14xx.h | 6 -- include/configs/acadia.h | 3 - include/configs/adp-ag101p.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/am335x_evm.h | 3 - include/configs/am335x_shc.h | 4 - include/configs/am335x_sl50.h | 3 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 2 - include/configs/am43xx_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/apf27.h | 1 - include/configs/apx4devkit.h | 1 - include/configs/aria.h | 6 -- include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9260ek.h | 3 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 4 - include/configs/at91sam9n12ek.h | 3 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 3 - include/configs/atngw100.h | 1 - include/configs/atngw100mkii.h | 1 - include/configs/atstk1002.h | 1 - include/configs/axs10x.h | 1 - include/configs/baltos.h | 4 - include/configs/bamboo.h | 3 - include/configs/bav335x.h | 3 - include/configs/bcm23550_w1d.h | 2 - include/configs/bcm28155_ap.h | 2 - include/configs/bcm_ep_board.h | 1 - include/configs/bf533-stamp.h | 1 - include/configs/bf537-stamp.h | 1 - include/configs/bfin_adi_common.h | 3 - include/configs/bg0900.h | 1 - include/configs/brppt1.h | 1 - include/configs/brxre1.h | 1 - include/configs/canyonlands.h | 3 - include/configs/clearfog.h | 2 - include/configs/cm5200.h | 3 - include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/cm_t43.h | 1 - include/configs/colibri_vf.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/corenet_ds.h | 3 - include/configs/corvus.h | 1 - include/configs/cyrus.h | 3 - include/configs/da850evm.h | 3 - include/configs/db-88f6820-amc.h | 2 - include/configs/db-88f6820-gp.h | 2 - include/configs/db-mv784mp-gp.h | 2 - include/configs/dbau1x00.h | 1 - include/configs/devkit3250.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/draco.h | 2 - include/configs/dragonboard410c.h | 1 - include/configs/ds414.h | 2 - include/configs/duovero.h | 2 - include/configs/ecovec.h | 2 - include/configs/edminiv2.h | 3 - include/configs/etamin.h | 1 - include/configs/ethernut5.h | 1 - include/configs/exynos-common.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gplugd.h | 2 - include/configs/gr_cpci_ax2000.h | 3 - include/configs/gr_ep2s60.h | 3 - include/configs/gr_xc3s_1500.h | 3 - include/configs/grsim.h | 3 - include/configs/grsim_leon2.h | 3 - include/configs/hrcon.h | 1 - include/configs/ib62x0.h | 1 - include/configs/icon.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/inka4x0.h | 3 - include/configs/intip.h | 3 - include/configs/ipek01.h | 1 - include/configs/jupiter.h | 3 - include/configs/katmai.h | 1 - include/configs/kc1.h | 1 - include/configs/km/kmp204x-common.h | 1 - include/configs/kzm9g.h | 1 - include/configs/lacie_kw.h | 2 - include/configs/legoev3.h | 3 - include/configs/ls1012aqds.h | 2 - include/configs/ls1012ardb.h | 2 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 2 - include/configs/ls1021atwr.h | 2 - include/configs/ls1043a_common.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080a_simu.h | 1 - include/configs/ls2080aqds.h | 2 - include/configs/ls2080ardb.h | 2 - include/configs/lsxl.h | 3 - include/configs/lwmon5.h | 3 - include/configs/m28evk.h | 1 - include/configs/m53evk.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/manroland/common.h | 1 - include/configs/mcx.h | 1 - include/configs/mecp5123.h | 1 - include/configs/motionpro.h | 1 - include/configs/mpc5121ads.h | 5 -- include/configs/ms7720se.h | 1 - include/configs/mv-common.h | 2 - include/configs/mvebu_db-88f3720.h | 5 -- include/configs/mvebu_db-88f7040.h | 5 -- include/configs/mx23_olinuxino.h | 1 - include/configs/mx23evk.h | 1 - include/configs/mx25pdk.h | 2 - include/configs/mx28evk.h | 1 - include/configs/mx35pdk.h | 3 - include/configs/mx51evk.h | 1 - include/configs/mx53ard.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53smd.h | 1 - include/configs/mx6_common.h | 1 - include/configs/mx7_common.h | 1 - include/configs/nas220.h | 2 - include/configs/nokia_rx51.h | 1 - include/configs/nsa310s.h | 1 - include/configs/o2dnt-common.h | 3 - include/configs/omap3_evm.h | 2 - include/configs/omap5_uevm.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 - include/configs/p1_twr.h | 2 - include/configs/pb1x00.h | 2 - include/configs/pcm030.h | 1 - include/configs/pcm052.h | 1 - include/configs/pic32mzdask.h | 2 - include/configs/pico-imx6ul.h | 1 - include/configs/picosam9g45.h | 4 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/pxa-common.h | 1 - include/configs/qemu-mips.h | 1 - include/configs/qemu-mips64.h | 1 - include/configs/qemu-ppce500.h | 2 - include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/rastaban.h | 2 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/rk3036_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rockchip-common.h | 1 - include/configs/rpi.h | 1 - include/configs/s32v234evb.h | 1 - include/configs/s5p_goni.h | 4 - include/configs/sama5d2_ptc.h | 1 - include/configs/sama5d2_xplained.h | 4 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 4 - include/configs/sama5d4ek.h | 4 - include/configs/sandbox.h | 7 -- include/configs/sansa_fuze_plus.h | 1 - include/configs/sbc8641d.h | 1 - include/configs/sc_sps_1.h | 1 - include/configs/sequoia.h | 3 - include/configs/sh7752evb.h | 2 - include/configs/sh7753evb.h | 2 - include/configs/sh7757lcr.h | 2 - include/configs/sh7785lcr.h | 3 - include/configs/sheevaplug.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/smdk2410.h | 1 - include/configs/smdkc100.h | 2 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 2 - include/configs/sniper.h | 1 - include/configs/socfpga_arria5_socdk.h | 1 - include/configs/socfpga_cyclone5_socdk.h | 1 - include/configs/socfpga_de0_nano_soc.h | 1 - include/configs/socfpga_is1.h | 1 - include/configs/socfpga_mcvevk.h | 1 - include/configs/socfpga_sockit.h | 1 - include/configs/socfpga_socrates.h | 1 - include/configs/socfpga_sr1500.h | 1 - include/configs/socfpga_vining_fpga.h | 1 - include/configs/socrates.h | 1 - include/configs/strider.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/t4qds.h | 2 - include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/tbs2910.h | 2 - include/configs/tegra-common-post.h | 9 -- include/configs/tegra-common.h | 1 - include/configs/theadorable.h | 2 - include/configs/thuban.h | 2 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 2 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/tplink_wdr4300.h | 2 - include/configs/tricorder.h | 1 - include/configs/ts4600.h | 1 - include/configs/ts4800.h | 1 - include/configs/uniphier.h | 1 - include/configs/usb_a9263.h | 1 - include/configs/v38b.h | 2 - include/configs/vct.h | 3 - include/configs/vexpress_aemv8a.h | 1 - include/configs/vf610twr.h | 1 - include/configs/vinco.h | 6 -- include/configs/vining_2000.h | 2 - include/configs/warp7.h | 1 - include/configs/woodburn_common.h | 3 - include/configs/work_92105.h | 1 - include/configs/x600.h | 1 - include/configs/x86-common.h | 5 -- include/configs/xfi3.h | 1 - include/configs/xilinx_zynqmp.h | 5 -- include/configs/xpedite550x.h | 1 - include/configs/yosemite.h | 3 - include/configs/zipitz2.h | 1 - include/configs/zmx25.h | 1 - include/configs/zynq-common.h | 1 - include/part.h | 4 +- lib/efi_loader/efi_disk.c | 2 +- scripts/config_whitelist.txt | 8 -- 513 files changed, 541 insertions(+), 583 deletions(-) create mode 100644 disk/Kconfig
diff --git a/Kconfig b/Kconfig index 529858a..46c373e 100644 --- a/Kconfig +++ b/Kconfig @@ -68,6 +68,10 @@ config DISTRO_DEFAULTS select CMD_MII select CMD_PING select HUSH_PARSER + select DOS_PARTITION + select EFI_PARTITION + select ISO_PARTITION + select PARTITION_UUIDS help Select this to enable various options and commands which are suitable for building u-boot for booting general purpose Linux distributions. @@ -313,6 +317,8 @@ source "common/Kconfig"
source "cmd/Kconfig"
+source "disk/Kconfig" + source "dts/Kconfig"
source "net/Kconfig" diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index ec65cc0..21cfb50 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -90,7 +90,6 @@ #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_FSL_ERRATUM_A008407
#ifdef CONFIG_DDR_SPD diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 97a0fc9..91c56b0 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -321,7 +321,7 @@ void efi_set_bootdev(const char *dev, const char *devnr, const char *path) char devname[32] = { 0 }; /* dp->str is u16[32] long */ char *colon;
-#if defined(CONFIG_BLK) || defined(CONFIG_ISO_PARTITION) +#if defined(CONFIG_BLK) || CONFIG_IS_ENABLED(ISO_PARTITION) desc = blk_get_dev(dev, simple_strtol(devnr, NULL, 10)); #endif
@@ -338,7 +338,7 @@ void efi_set_bootdev(const char *dev, const char *devnr, const char *path)
colon = strchr(devname, ':');
-#ifdef CONFIG_ISO_PARTITION +#if CONFIG_IS_ENABLED(ISO_PARTITION) /* For ISOs we create partition block devices */ if (desc && (desc->type != DEV_TYPE_UNKNOWN) && (desc->part_type == PART_TYPE_ISO)) { diff --git a/cmd/reiser.c b/cmd/reiser.c index cbdad36..9c3e9e9 100644 --- a/cmd/reiser.c +++ b/cmd/reiser.c @@ -18,7 +18,7 @@ #include <reiserfs.h> #include <part.h>
-#ifndef CONFIG_DOS_PARTITION +#if !CONFIG_IS_ENABLED(DOS_PARTITION) #error DOS partition support must be selected #endif
diff --git a/cmd/zfs.c b/cmd/zfs.c index 93067a9..3ed9912 100644 --- a/cmd/zfs.c +++ b/cmd/zfs.c @@ -24,7 +24,7 @@ #include <usb.h> #endif
-#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) +#if !CONFIG_IS_ENABLED(DOS_PARTITION) && !CONFIG_IS_ENABLED(EFI_PARTITION) #error DOS or EFI partition support must be selected #endif
diff --git a/common/fb_mmc.c b/common/fb_mmc.c index 81a3bd0..6cc113d 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -112,7 +112,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, return; }
-#ifdef CONFIG_EFI_PARTITION +#if CONFIG_IS_ENABLED(EFI_PARTITION) if (strcmp(cmd, CONFIG_FASTBOOT_GPT_NAME) == 0) { printf("%s: updating MBR, Primary and Backup GPT(s)\n", __func__); @@ -133,7 +133,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, } #endif
-#ifdef CONFIG_DOS_PARTITION +#if CONFIG_IS_ENABLED(DOS_PARTITION) if (strcmp(cmd, CONFIG_FASTBOOT_MBR_NAME) == 0) { printf("%s: updating MBR\n", __func__); if (is_valid_dos_buf(download_buffer)) { diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index 621cb8f..e17ba1a 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -8,3 +8,4 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y diff --git a/configs/M5253EVBE_defconfig b/configs/M5253EVBE_defconfig index 4b81ba4..2be75d6 100644 --- a/configs/M5253EVBE_defconfig +++ b/configs/M5253EVBE_defconfig @@ -8,3 +8,4 @@ CONFIG_BOOTDELAY=5 CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_MAC_PARTITION=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index afef344..15e30ef 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -44,6 +44,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 2e5e047..492a6b4 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -36,6 +36,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_TFTP=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 07e73fe..7636b74 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -39,6 +39,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index e5a1696..92711da 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2" # CONFIG_BLK is not set diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 484286b..ad5359a 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y CONFIG_DFU_RAM=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 7b6d63b..cbeb155 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -26,6 +26,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index b239209..0b39939 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index e7dd0a7..532f613 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y CONFIG_DFU_RAM=y diff --git a/configs/am335x_igep0033_defconfig b/configs/am335x_igep0033_defconfig index 6149beb..1130e2c 100644 --- a/configs/am335x_igep0033_defconfig +++ b/configs/am335x_igep0033_defconfig @@ -38,5 +38,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 9b73f46..76aba8a 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -32,5 +32,8 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index ff70580..24cfd9b 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -32,5 +32,8 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 520d17c..18203f7 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -33,5 +33,8 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index d6cc315..3c79241 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -30,5 +30,8 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index b4e36b5..c6ade19 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -32,5 +32,8 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index b4e36b5..c6ade19 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -32,5 +32,8 @@ CONFIG_AUTOBOOT_STOP_STR="noautoboot" CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index f49407e..0d4e91c 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -41,5 +41,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 291f570..8e7c255 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_PARTITION_UUIDS=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 443e1fb..cd767e2 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 7090fd1..1095af5 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index a3f3abd..1251b99 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 6a881dd..08b7bcd 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -37,6 +37,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 1c53877..7fb697a 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -37,6 +37,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 12d9a14..9f17f89 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -46,6 +46,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am57xx-beagle-x15 am572x-idk" CONFIG_DM=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index 7e08b0a..ab46152 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -38,6 +38,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index c508b8e..cd20057 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -46,6 +46,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/ap325rxa_defconfig b/configs/ap325rxa_defconfig index 818eb41..8256eca 100644 --- a/configs/ap325rxa_defconfig +++ b/configs/ap325rxa_defconfig @@ -19,4 +19,5 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 5dd6fda..2dc8804 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_SOUND=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 1eb6142..3f135b4 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -36,6 +36,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index dd37b7e..c3584c3 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -18,6 +18,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index a013098..60198b9 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -18,6 +18,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index 8d6d28c..f152418 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index 1ceaeda..1295ab9 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index 06539fd..06107ea 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 6c14965..9282e1e 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 5e1af1c..84237ee 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -43,6 +43,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SPI_FLASH=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index f3771bb..38e059c 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -43,6 +43,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SPI_FLASH=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 67d6b61..e9ffb52 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -28,5 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index 9203f73..836083a 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 95e5f57..e70aca5 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 8407731..06642fd 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -32,6 +32,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 49cd640..a02aa23 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index e08dffc..d9ad68c 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -32,6 +32,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index f8cf92b..5400cc1 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -29,6 +29,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index d06b75c..e5a3762 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_PCI=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 36905fd..84891c0 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -35,5 +35,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 2d78841..dd3d8cc 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -41,6 +41,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_SPI_FLASH=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index e002e1c..5717e6e 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 28f69e4..782333e 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -37,6 +37,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 2528db9..eb7bcae 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -36,6 +36,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 2195fc6..2bbd041 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -24,6 +24,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 233fe09..0a1f9c4 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -21,6 +21,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 5aa7234..77775cb 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -28,6 +28,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index eeea7e5..3b0dea3 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 90cbd48..3ba16fc 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 3547d84..e672cd8 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index b3e2e1d..9c4dd28 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/dbau1000_defconfig b/configs/dbau1000_defconfig index 996e2f7..2962bf5 100644 --- a/configs/dbau1000_defconfig +++ b/configs/dbau1000_defconfig @@ -12,3 +12,4 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_MAC_PARTITION=y diff --git a/configs/dbau1100_defconfig b/configs/dbau1100_defconfig index 2b3ccd8..67b36e8 100644 --- a/configs/dbau1100_defconfig +++ b/configs/dbau1100_defconfig @@ -12,3 +12,4 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_MAC_PARTITION=y diff --git a/configs/dbau1500_defconfig b/configs/dbau1500_defconfig index 7459c63..f447aa6 100644 --- a/configs/dbau1500_defconfig +++ b/configs/dbau1500_defconfig @@ -12,3 +12,4 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_MAC_PARTITION=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index e603310..63d43de 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -18,5 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index f657ef6..b617f92 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -35,6 +35,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 2ab31fa..681692e 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index e263c5b..b453ed4 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 18a5e7a..307e5d1 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -46,6 +46,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc" CONFIG_DM=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 838de5c..6087e0a 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -48,6 +48,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm" CONFIG_DM=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 0cb4412..2ab9359 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_UBI=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 34250c3..5c78628 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_CLK=y CONFIG_MSM_GPIO=y CONFIG_PM8916_GPIO=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index ec9ab9b..9743d14 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 34a4673..606f337 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -10,6 +10,8 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index 3950782..027d5ad 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 4fb5ed6..63e1cf8 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -28,6 +28,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_PARTITION_UUIDS=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 036935e..44a4fc1 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT2=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 1fe6142..962e021 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -21,6 +21,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM_PCI=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 8fb6ebd..9a18909 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_UBI=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index 6546db9..70b7e85 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -23,6 +23,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index e5e550c..9f1e723 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_REGMAP=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 95029d7..b6507af 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -16,6 +16,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index eff5e15..3af0df2 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_REGMAP=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 4910c80..41a53dd 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 0220357..b629c37 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -31,6 +31,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 6550c9e..03e60a3 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index 7cf1899..974745c 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 63025bc..4a13b34 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 46527e5..53efe4b 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index 59c9fdf..c9d9db2 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 765f4e7..ce1e2f6 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -16,6 +16,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_PARTITION_UUIDS=y CONFIG_OF_CONTROL=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 43127de..7783986 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index b4f3975..4b8eeda 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -19,4 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_LIBFDT=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 95790bf..851b20f 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -17,5 +17,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 4260245..1341753 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index 5b570b7..13beedf 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index c25b6b8..ab6dfde 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index edc7520..ba299c3 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 81d05d4..5a5fd35 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index c7843c1..2260b92 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_DOS_PARTITION=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set CONFIG_NAND_MXS=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index ba7f959..59870d0 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index ffa1c4a..196e507 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 97f7187..7ffa225 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 8b0e00f..4b44bb8 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 6424ec7..8a94fee 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index 76226e9..1fa61a5 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -23,6 +23,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index a4281c9..c2ca37c 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index 21464cb..dcc683e 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AIOT=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" +CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 1369fe6..6531aee 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SPL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 +CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 6a8e690..a83b750 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -21,6 +21,9 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index e64325a..8d87b4f 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -21,6 +21,9 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 863fd7e..93a4c8b 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/miniarm-rk3288_defconfig b/configs/miniarm-rk3288_defconfig index 1e273a6..17df565 100644 --- a/configs/miniarm-rk3288_defconfig +++ b/configs/miniarm-rk3288_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_REGMAP=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 45d8a87..de126d1 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -36,6 +36,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/ms7720se_defconfig b/configs/ms7720se_defconfig index a02760a..c19c56b 100644 --- a/configs/ms7720se_defconfig +++ b/configs/ms7720se_defconfig @@ -23,4 +23,5 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index b7a1645..acdb395 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -26,6 +26,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y diff --git a/configs/mvebu_db-88f7040_defconfig b/configs/mvebu_db-88f7040_defconfig index 81152cd..ae8c903 100644 --- a/configs/mvebu_db-88f7040_defconfig +++ b/configs/mvebu_db-88f7040_defconfig @@ -26,6 +26,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index c44681f..a65fd7a 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -15,6 +15,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index d10c2ca..28f8682 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 3000d72..f5db6d4 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -17,6 +17,9 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 802879b..ec8521e 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index f42c49a..79f6fea 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 3ec5e63..a21606f 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 11e453c..c941c97 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -18,6 +18,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index b8ccecd..25b59e2 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -19,6 +19,9 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 4a3e266..e7b389f 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -36,6 +36,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_PCI=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index add5e07..dc8a265 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 9db718c..296ecad 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -14,6 +14,10 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_ETH=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 1b67495..1af848b 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_ADC=y CONFIG_ADC_EXYNOS=y CONFIG_DFU_MMC=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index f3ddc74..07d5f95 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_DM_I2C=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 7a1fd44..6631736 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -26,6 +26,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 6ca7e2c..e4e3a08 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -19,6 +19,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index ac1a6a3..d8e8d2d 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index b902283..877b851 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index 70a9299..43f9aec 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -29,5 +29,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index e7f8fd0..436a28e 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -24,5 +24,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index a5fbf9a..6abd709 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 92cc9f0..6807c52 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -28,5 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 3005ffd..dd91d0d 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -26,6 +26,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SYS_NS16550=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 0168579..067ddbc 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 84fa149..b90ead1 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 026204d..2bc8ace 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 0d91ec1..9037d4c 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_USB=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index bc6e92d..3ffbbb3 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -42,6 +42,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index acdf192..7721509 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -42,6 +42,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index b2f70ea..8a268d4 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -36,6 +36,9 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_DM=y CONFIG_MTD=y CONFIG_SPI_FLASH=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index adecb40..44cccc9 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index f8e987f..ec94100 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 2da2126..e3d249c 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -42,6 +42,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 0592ed9..fa139ea 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -34,5 +34,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index 68eee4d..76346d6 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_PARTITION_UUIDS=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_BLK is not set diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 1882995..df58361 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 663724e..e2b7eb4 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_REGMAP=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 4566d37..db88be3 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -28,6 +28,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index f580d45..a96a0ad 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -25,6 +25,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 975714b..6bfc479 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -26,6 +26,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index f4dc68e..9a5ebde 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -5,5 +5,6 @@ CONFIG_BOOTDELAY=-1 CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_PCI=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 77d9c06..fccaf05 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -20,5 +20,6 @@ CONFIG_BOOTDELAY=3 CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_PCI=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index d3ac645..76e84b7 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_UBI=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index a29c238..9d36480 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 9e332bc..986a970 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent" CONFIG_REGMAP=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 9287bec..90d44f2 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_EMBED=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index e6fe836..8e3eb19 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -22,6 +22,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_EMBED=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 446f044..1396f7b 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_EMBED=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index dfd0cc7..54fd03b 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -21,6 +21,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_EMBED=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/s32v234evb_defconfig b/configs/s32v234evb_defconfig index dfedf82..f549efd 100644 --- a/configs/s32v234evb_defconfig +++ b/configs/s32v234evb_defconfig @@ -4,4 +4,7 @@ CONFIG_SYS_MALLOC_F=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/s32v234evb/s32v234evb.cfg" CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_LIBFDT=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 4cbf022..a0ab1dc 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y CONFIG_DFU_MMC=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index f1bbdd9..ba16b6a 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_USB=y diff --git a/configs/salvator-x_defconfig b/configs/salvator-x_defconfig index 9df4867..78da265 100644 --- a/configs/salvator-x_defconfig +++ b/configs/salvator-x_defconfig @@ -11,3 +11,4 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_DOS_PARTITION=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 380d4fe..1ea211c 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -58,6 +58,10 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_AMIGA_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y CONFIG_NETCONSOLE=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index 833caf1..1192e54 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -56,6 +56,10 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_AMIGA_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y CONFIG_NETCONSOLE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 84c32e9..c5609a6 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -65,6 +65,10 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_AMIGA_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_HOSTFILE=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index 73b1ac6..61b34fb 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index e0037a6..5625409 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index a80c10c..3a683b7 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y +CONFIG_DOS_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index e15355d..63973eb 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 4189475..c3b59e9 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_SPI_FLASH=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 8715ec3..588ca53 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_SPI_FLASH=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index c8c182b..9bbef7a 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -22,5 +22,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 6f55503..37569da 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index d654311..1176daf 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_LDO=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index a3ba8c1..24a60eb 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -34,6 +34,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 2a2b071..53903b1 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_LDO=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 9fefa5f..2b3edd1 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y CONFIG_DM=y CONFIG_PCI=y CONFIG_DM_THERMAL=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 135c904..95e757d 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -35,6 +35,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index e642475..0dc6146 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -37,6 +37,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_GPIO=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index a063047..8e79ba6 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -32,6 +32,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_GPIO=y CONFIG_SPI_FLASH=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 7e1b63b..bffa231 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_UBI=y +# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DFU_NAND=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index db1ebe9..4a14358 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_USB=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index b25c1c4..1ac7e12 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DFU_MMC=y CONFIG_USB=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 98679cf..1bf96c9 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -26,4 +26,6 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_LIBFDT=y diff --git a/configs/usbarmory_defconfig b/configs/usbarmory_defconfig index 16f4293..709161b 100644 --- a/configs/usbarmory_defconfig +++ b/configs/usbarmory_defconfig @@ -16,6 +16,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index d795279..ec49026 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -26,4 +26,6 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index 38d691e..3b0e02f 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -25,4 +25,6 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index ebca526..3064a81 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -25,4 +25,6 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_OF_LIBFDT=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 34a02bd..f8e605d 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 9410703..95415a8 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_EFI_PARTITION=y CONFIG_PCI=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index d338ffc..72744aa 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 0f0ec99..beca3df 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_PARTITION_UUIDS=y CONFIG_DFU_MMC=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/warp7_secure_defconfig b/configs/warp7_secure_defconfig index c12fc01..06972de 100644 --- a/configs/warp7_secure_defconfig +++ b/configs/warp7_secure_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_PARTITION_UUIDS=y CONFIG_DFU_MMC=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index aa5d587..55370cc 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -15,3 +15,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 085c2df..23bba19 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -25,3 +25,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +# CONFIG_PARTITION_UUIDS is not set diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index ca3b731..27d5ffb 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_DOS_PARTITION=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_GPIO=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index f3cdf90..d9bd41e 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -44,6 +44,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 049db51..97137d9 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -35,6 +35,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index e8a587f..4d72f7f 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -38,6 +38,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 62e3814..206fe01 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index ef92932..1ac5501 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_zcu102_defconfig b/configs/xilinx_zynqmp_zcu102_defconfig index fa6d669..5699ae3 100644 --- a/configs/xilinx_zynqmp_zcu102_defconfig +++ b/configs/xilinx_zynqmp_zcu102_defconfig @@ -36,6 +36,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index a4af802..22cf4da 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -36,6 +36,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index ee1da69..cd6bde1 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PCI=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index 746ec70..20170d6 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/disk/Kconfig b/disk/Kconfig new file mode 100644 index 0000000..3070945 --- /dev/null +++ b/disk/Kconfig @@ -0,0 +1,97 @@ + +menu "Partition Types" + +config PARTITIONS + bool "Enable Partition Labels (disklabels) support" + default y + help + Partition Labels (disklabels) Supported: + Zero or more of the following: + - CONFIG_MAC_PARTITION Apple's MacOS partition table. + - CONFIG_DOS_PARTITION MS Dos partition table, traditional on the + Intel architecture, USB sticks, etc. + - CONFIG_ISO_PARTITION ISO partition table, used on CDROM etc. + - CONFIG_EFI_PARTITION GPT partition table, common when EFI is the + bootloader. Note 2TB partition limit; see + disk/part_efi.c + - CONFIG_MTD_PARTITIONS Memory Technology Device partition table. + If IDE or SCSI support is enabled (CONFIG_CMD_IDE or CONFIG_SCSI) + you must configure support for at least one non-MTD partition type + as well. + +config MAC_PARTITION + bool "Enable Apple's MacOS partition table" + depends on PARTITIONS + default y if PPC || x86 || SPARC || SH + help + Say Y here if you would like to use device under U-Boot which + were partitioned on a Macintosh. + +config SPL_MAC_PARTITION + bool "Enable Apple's MacOS partition table for SPL" + depends on SPL && PARTITIONS + default y if MAC_PARTITION + +config DOS_PARTITION + bool "Enable MS Dos partition table" + depends on PARTITIONS + default y if PPC || x86 || SPARC || CMD_FAT || USB_STORAGE + help + traditional on the Intel architecture, USB sticks, etc. + +config SPL_DOS_PARTITION + bool "Enable MS Dos partition table for SPL" + depends on SPL && PARTITIONS + default y if DOS_PARTITION + +config ISO_PARTITION + bool "Enable ISO partition table" + default y if M68K || PPC || SPARC || MIPS || TEGRA + depends on PARTITIONS + +config SPL_ISO_PARTITION + bool "Enable ISO partition table for SPL" + depends on SPL && PARTITIONS + default y if ISO_PARTITION + +config AMIGA_PARTITION + bool "Enable AMIGA partition table" + depends on PARTITIONS + help + Say Y here if you would like to use device under U-Boot which + were partitioned under AmigaOS. + +config SPL_AMIGA_PARTITION + bool "Enable AMIGA partition table for SPL" + depends on SPL && PARTITIONS + default y if AMIGA_PARTITION + +config EFI_PARTITION + bool "Enable EFI GPT partition table" + depends on PARTITIONS + default y if TEGRA + help + Say Y here if you would like to use device under U-Boot which + were partitioned using EFI GPT. + common when EFI is the bootloader. Note 2TB partition limit; + see disk/part_efi.c + +config SPL_EFI_PARTITION + bool "Enable EFI GPT partition table for SPL" + depends on PARTITIONS + default y if EFI_PARTITION + +config PARTITION_UUIDS + bool "Enable support of UUID for partition" + default y if EFI_PARTITION + help + Activate the configuration of UUID for partition + +config PARTITION_TYPE_GUID + bool "Enable support of GUID for partition type" + depends on EFI_PARTITION + help + Activate the configuration of GUID type + for EFI partition + +endmenu diff --git a/disk/Makefile b/disk/Makefile index 6970cec..523e34d 100644 --- a/disk/Makefile +++ b/disk/Makefile @@ -7,9 +7,9 @@
#ccflags-y += -DET_DEBUG -DDEBUG
-obj-$(CONFIG_PARTITIONS) += part.o -obj-$(CONFIG_MAC_PARTITION) += part_mac.o -obj-$(CONFIG_DOS_PARTITION) += part_dos.o -obj-$(CONFIG_ISO_PARTITION) += part_iso.o -obj-$(CONFIG_AMIGA_PARTITION) += part_amiga.o -obj-$(CONFIG_EFI_PARTITION) += part_efi.o +obj-$(CONFIG_PARTITIONS) += part.o +obj-$(CONFIG_$(SPL_)MAC_PARTITION) += part_mac.o +obj-$(CONFIG_$(SPL_)DOS_PARTITION) += part_dos.o +obj-$(CONFIG_$(SPL_)ISO_PARTITION) += part_iso.o +obj-$(CONFIG_$(SPL_)AMIGA_PARTITION) += part_amiga.o +obj-$(CONFIG_$(SPL_)EFI_PARTITION) += part_efi.o diff --git a/disk/part.c b/disk/part.c index 9f51a07..f0ac1c3 100644 --- a/disk/part.c +++ b/disk/part.c @@ -234,11 +234,11 @@ void part_init(struct blk_desc *dev_desc)
static void print_part_header(const char *type, struct blk_desc *dev_desc) { -#if defined(CONFIG_MAC_PARTITION) || \ - defined(CONFIG_DOS_PARTITION) || \ - defined(CONFIG_ISO_PARTITION) || \ - defined(CONFIG_AMIGA_PARTITION) || \ - defined(CONFIG_EFI_PARTITION) +#if CONFIG_IS_ENABLED(MAC_PARTITION) || \ + CONFIG_IS_ENABLED(DOS_PARTITION) || \ + CONFIG_IS_ENABLED(ISO_PARTITION) || \ + CONFIG_IS_ENABLED(AMIGA_PARTITION) || \ + CONFIG_IS_ENABLED(EFI_PARTITION) puts ("\nPartition Map for "); switch (dev_desc->if_type) { case IF_TYPE_IDE: diff --git a/disk/part_amiga.h b/disk/part_amiga.h index 0f04e97..a3fe1a9 100644 --- a/disk/part_amiga.h +++ b/disk/part_amiga.h @@ -10,7 +10,7 @@ #define _DISK_PART_AMIGA_H #include <common.h>
-#ifdef CONFIG_ISO_PARTITION +#if CONFIG_IS_ENABLED(ISO_PARTITION) /* Make the buffers bigger if ISO partition support is enabled -- CD-ROMS have 2048 byte blocks */ #define DEFAULT_SECTOR_SIZE 2048 diff --git a/disk/part_efi.c b/disk/part_efi.c index 1924338..f1b7116 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -171,7 +171,7 @@ static void prepare_backup_gpt_header(gpt_header *gpt_h) gpt_h->header_crc32 = cpu_to_le32(calc_crc32); }
-#ifdef CONFIG_EFI_PARTITION +#if CONFIG_IS_ENABLED(EFI_PARTITION) /* * Public Functions (include/part.h) */ diff --git a/disk/part_mac.h b/disk/part_mac.h index 7b754e1..6735144 100644 --- a/disk/part_mac.h +++ b/disk/part_mac.h @@ -73,7 +73,7 @@ typedef struct mac_partition { __u32 boot_cksum; /* boot code checksum */ uchar processor[16]; /* Type of Processor */ __u16 part_pad[188]; /* reserved */ -#ifdef CONFIG_ISO_PARTITION +#if CONFIG_IS_ENABLED(ISO_PARTITION) uchar iso_dummy[2048];/* Reservere enough room for an ISO partition block to fit */ #endif } mac_partition_t; diff --git a/include/config_defaults.h b/include/config_defaults.h index ad08c1d..7ef928b 100644 --- a/include/config_defaults.h +++ b/include/config_defaults.h @@ -18,6 +18,5 @@
#define CONFIG_GZIP 1 #define CONFIG_ZLIB 1 -#define CONFIG_PARTITIONS 1
#endif diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 9ecaf38..e946d10 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -27,7 +27,6 @@ */
/* We need the part command */ -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
#define BOOTENV_SHARED_BLKDEV_BODY(devtypel) \ diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index b5efab5..84f030d 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -26,9 +26,6 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_LONGHELP #define CONFIG_MENU -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_RAW_INITRD #define CONFIG_ENV_VARS_UBOOT_CONFIG
diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 2ad54b7..91327a7 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -57,6 +57,7 @@
#if (defined(CONFIG_PARTITION_UUIDS) || \ defined(CONFIG_EFI_PARTITION) || \ + defined(CONFIG_SPL_EFI_PARTITION) || \ defined(CONFIG_RANDOM_UUID) || \ defined(CONFIG_CMD_UUID) || \ defined(CONFIG_BOOTP_PXE)) && \ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index cd4333f..3d42165 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -683,7 +683,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCI_INDIRECT_BRIDGE
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #endif /* CONFIG_PCI */
#ifdef CONFIG_FMAN_ENET diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index aaf7106..d7be40a 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -306,7 +306,6 @@ extern unsigned long get_sdram_size(void); */ #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_DOS_PARTITION #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 8eee738..fc13eac 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -100,7 +100,6 @@ #define CONFIG_SYS_PCIE1_IO_PHYS 0xC0010000
#define CONFIG_FSL_LAW /* Use common FSL init code */ @@ -485,7 +484,6 @@ combinations. this should be removed later
#define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR @@ -542,10 +540,6 @@ combinations. this should be removed later #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
-#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) -#define CONFIG_DOS_PARTITION -#endif - /* Hash command with SHA acceleration supported in hardware */ #ifdef CONFIG_FSL_CAAM #define CONFIG_CMD_HASH diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 39eefb4..d74dfea 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -99,7 +99,6 @@ #define CONFIG_SYS_PCIE1_IO_PHYS 0xfffc00000ull
#define CONFIG_FSL_LAW /* Use common FSL init code */ diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index fb6e0ef..e9ca80f 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -70,9 +70,6 @@ #define CONFIG_CMD_BSP #define CONFIG_CMD_EEPROM
-#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - #define CONFIG_SUPPORT_VFAT
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 6230948..98ccbe3 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -92,9 +92,6 @@ /* USB */ #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SYS_USB_EHCI_REGS_BASE 0xFC0B0000 #define CONFIG_SYS_USB_EHCI_CPU_INIT #endif diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 6c90700..2733457 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -42,8 +42,6 @@
#ifdef CONFIG_CMD_IDE /* ATA */ -# define CONFIG_DOS_PARTITION -# define CONFIG_MAC_PARTITION # define CONFIG_IDE_RESET 1 # define CONFIG_IDE_PREINIT 1 # define CONFIG_ATAPI diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index faad970..5cba541 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -50,8 +50,6 @@ #define CONFIG_CMD_IDE
/* ATA */ -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION #define CONFIG_IDE_RESET 1 #define CONFIG_IDE_PREINIT 1 #define CONFIG_ATAPI diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index abec373..0eed59e 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -119,8 +119,6 @@ #endif
/* ATA configuration */ -#define CONFIG_ISO_PARTITION -#define CONFIG_DOS_PARTITION #define CONFIG_IDE_RESET 1 #define CONFIG_IDE_PREINIT 1 #define CONFIG_ATAPI diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index 3b40cd0..f10c3f0 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -75,7 +75,6 @@ # define CONFIG_CMD_PCI # endif # define CONFIG_PCI_OHCI -# define CONFIG_DOS_PARTITION
# undef CONFIG_SYS_USB_OHCI_BOARD_INIT # undef CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 2c18e98..2ae8d25 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -69,7 +69,6 @@ #endif
#ifdef CONFIG_CMD_USB -# define CONFIG_DOS_PARTITION # define CONFIG_USB_OHCI_NEW # ifndef CONFIG_CMD_PCI # define CONFIG_CMD_PCI diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index f7fc652..952ee4a 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -327,9 +327,6 @@ /************************************************************ * DISK Partition support ************************************************************/ -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION /* Experimental */
/************************************************************ * Video support diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 6335c55..a5cdcb6 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_FSL_ESDHC_USE_PIO
#define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index bd25c0b..1d6be41 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -418,7 +418,6 @@ #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 5f7eca0..fcc1a73 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -487,7 +487,6 @@ boards, we say we have two, but don't display a message if we find only one. */
#if defined(CONFIG_COMPACT_FLASH) || defined(CONFIG_SATA_SIL3114) \ || defined(CONFIG_USB_STORAGE) - #define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #endif
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index adc3193..2a66fa0 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -439,7 +439,6 @@ extern int board_pci_host_broken(void); #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -490,7 +489,6 @@ extern int board_pci_host_broken(void); #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 48e06af..6ad065d 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -451,7 +451,6 @@ #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -502,7 +501,6 @@ #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 446303d..24290b5 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -533,7 +533,6 @@ #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
#if defined(CONFIG_TSEC_ENET) @@ -631,10 +630,6 @@ #endif #endif
-#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) -#define CONFIG_DOS_PARTITION -#endif - /* * Miscellaneous configurable options */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 6c17a3b..01df469 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -290,7 +290,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #define CONFIG_SCSI_AHCI
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 91f0104..c537805 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -474,7 +474,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_FSL_ESDHC_PIN_MUX #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index e134560..638dea8 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -477,7 +477,6 @@ #endif
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 75693a0..fd1dd16 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -290,7 +290,6 @@ #define PCI_IDSEL_NUMBER 0x0c /* slot0->3(IDSEL)=12->15 */ #endif
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index c94b329..f2ffb63 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -378,7 +378,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 3ced88d..6573ae1 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -198,7 +198,6 @@ #endif
#define CONFIG_FSL_LAW /* Use common FSL init code */ @@ -678,7 +677,6 @@ extern unsigned long get_sdram_size(void);
#define CONFIG_MMC #ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR @@ -753,7 +751,6 @@ extern unsigned long get_sdram_size(void);
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) \ || defined(CONFIG_FSL_SATA) -#define CONFIG_DOS_PARTITION #endif
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 6f07080..1c7e759 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -509,7 +509,6 @@ #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
#define CONFIG_MMC @@ -519,10 +518,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #endif
-#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) -#define CONFIG_DOS_PARTITION -#endif - #define CONFIG_TSEC_ENET #ifdef CONFIG_TSEC_ENET
diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 5061286..279fcc4 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -264,7 +264,6 @@ extern unsigned long get_clock_freq(void); #ifdef CONFIG_USB_EHCI #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL -#define CONFIG_DOS_PARTITION #endif #endif
diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 417bfd3..f16175d 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -540,7 +540,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_PCI_INDIRECT_BRIDGE
/* SATA */ @@ -560,7 +559,6 @@ unsigned long get_board_sys_clk(unsigned long dummy);
#ifdef CONFIG_FMAN_ENET @@ -618,7 +616,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 3dcb6ac..f14ab47 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -287,9 +287,6 @@ /************************************************************ * DISK Partition support ************************************************************/ -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION /* Experimental */
/************************************************************ * Video support diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 0967577..6797f18 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -64,9 +64,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_EEPROM
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index 2e7f6e4..731560f 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -259,9 +259,6 @@ #define USB_2_0_DEVICE
/* Partitions */ -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION
#define CONFIG_CMD_BSP #define CONFIG_CMD_DATE diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 3c0a0c9..0ce28e0 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -631,7 +631,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* @@ -647,7 +646,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -669,7 +667,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index e2aea8b..5de79d6 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -649,7 +649,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* @@ -671,7 +670,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index ba1c38b..ff98c05 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -517,7 +517,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* SATA */ @@ -536,7 +535,6 @@ unsigned long get_board_ddr_clk(void);
/* @@ -560,7 +558,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC_ADAPTER_IDENT #endif
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index ed568f3..2585d1d 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -631,7 +631,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #endif
/* SATA */ @@ -647,7 +646,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
/* @@ -670,7 +668,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 17176f4..8d95fc2 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -600,7 +600,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ @@ -711,7 +710,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -733,7 +731,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FSL_ESDHC_ADAPTER_IDENT #endif
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index bca6a5b..a26913c 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -537,7 +537,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata LSZ ADD */ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #endif
/* Qman/Bman */ @@ -660,7 +659,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA #define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
/* @@ -681,7 +679,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 1d18316..da07e26 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -494,7 +494,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FMAN_ENET @@ -524,7 +523,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_ESDHC_DETECT_QUIRK \ (!(readb(QIXIS_BASE + QIXIS_BRDCFG5) & QIXIS_MUX_SDHC) || \ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 6c743e3..98e0e2e 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -249,7 +249,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE
/* SATA */ @@ -267,7 +266,6 @@
#ifdef CONFIG_FMAN_ENET @@ -689,7 +687,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FMAN_ENET @@ -713,7 +710,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #endif
diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 708eb76..6d30268 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -108,9 +108,6 @@ #endif /* #ifndef CONFIG_TQM5200S */
/* USB */ #if defined(CONFIG_CHARON) || defined(CONFIG_FO300) || \ diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 2fd5fa3..5f21338 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -93,9 +93,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
-#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - #define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */
/* diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 11bba09..46518a1 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -91,9 +91,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 548f1bc..114b63a 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -82,9 +82,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 582b934..e51f145 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -82,9 +82,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index 814290f..04a58d5 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -84,9 +84,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index 4a657ff..e121052 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -113,9 +113,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index bdfe509..3af079f 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -84,9 +84,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index ce6b404..3f566a6 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -84,9 +84,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index 66dbcb6..3e40107 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -87,9 +87,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index 478f16b..b66b7f0 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -87,9 +87,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
/* diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 5501622..89e109c 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -125,9 +125,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
-#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - #undef CONFIG_RTC_MPC8xx /* MPC866 does not support RTC */
#define CONFIG_TIMESTAMP /* but print image timestmps */ diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index b246926..f12b4bf 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -121,9 +121,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
-#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - #undef CONFIG_RTC_MPC8xx /* MPC885 does not support RTC */
#define CONFIG_TIMESTAMP /* but print image timestmps */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 1163b0d..c61c3c8 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -391,7 +391,6 @@ #define CONFIG_CMD_PCI
/* @@ -490,10 +489,6 @@ #define CONFIG_GENERIC_MMC #endif
-#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) || defined(CONFIG_FSL_SATA) -#define CONFIG_DOS_PARTITION -#endif - /* Misc Extra Settings */ #undef CONFIG_WATCHDOG /* watchdog disabled */
diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index bb26261..aff33ae 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -100,7 +100,6 @@ /* USB support (currently only works with D-cache off) */ #define CONFIG_USB_OHCI #define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_DOS_PARTITION
/* Enable needed helper functions */
diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index b41ebe0..bf848c6 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -61,8 +61,6 @@ #undef CONFIG_EEPRO100
/* USB */ #define CONFIG_USB_OHCI_NEW diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index 2d1c099..a7a6bfe 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -396,12 +396,6 @@ #define CONFIG_CMD_PCI #endif
-#if defined(CONFIG_CMD_IDE) || defined(CONFIG_CMD_EXT2) -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION -#endif /* defined(CONFIG_CMD_IDE) */ - /* * Miscellaneous configurable options */ diff --git a/include/configs/acadia.h b/include/configs/acadia.h index c10c646..39121ed 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -155,9 +155,6 @@ #define CONFIG_USB_OHCI
diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 5cb79f1..7f62825 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -102,7 +102,6 @@ */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_FTSDC010 #define CONFIG_FTSDC010_NUMBER 1 #define CONFIG_FTSDC010_SDIO diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 3626636..03e5833 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -58,7 +58,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER -#define CONFIG_DOS_PARTITION
/* USB Configs */ #define CONFIG_USB_EHCI diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 8fa8e39..125fdec 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -41,7 +41,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION
#ifdef CONFIG_NAND #define NANDARGS \ @@ -324,8 +323,6 @@ #undef CONFIG_ENV_IS_IN_NAND /* disable host part of MUSB in SPL */ /* disable EFI partitions and partition UUID support */ -#undef CONFIG_PARTITION_UUIDS -#undef CONFIG_EFI_PARTITION #endif
/* USB Device Firmware Update support */ diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index 48353e9..5986f13 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -86,10 +86,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION -#ifdef CONFIG_SPL_BUILD -#undef CONFIG_ISO_PARTITION -#endif #ifndef CONFIG_SHC_ICT /* * In builds other than ICT, reset to retry after timeout diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index ca5bb1a..14238cc 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -30,7 +30,6 @@
#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
@@ -99,8 +98,6 @@ /* disable host part of MUSB in SPL */ #undef CONFIG_MUSB_HOST /* disable EFI partitions and partition UUID support */ -#undef CONFIG_PARTITION_UUIDS -#undef CONFIG_EFI_PARTITION #endif
#if defined(CONFIG_EMMC_BOOT) diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 07ef9e9..970b956 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -78,7 +78,6 @@ #define CONFIG_GENERIC_MMC 1 #define CONFIG_MMC 1 #define CONFIG_OMAP_HSMMC 1 -#define CONFIG_DOS_PARTITION 1
/* * USB configuration diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index ad56d24..5d5357d 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -80,7 +80,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* * USB configuration @@ -261,7 +260,6 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP -#define CONFIG_PARTITION_UUIDS
/* We set the max number of command args high to avoid HUSH bugs. */ #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 0a6c06a..73d7f86 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -200,7 +200,6 @@
#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index d009900..fef2047 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -63,7 +63,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION #define CONFIG_RANDOM_UUID #define CONFIG_HSMMC2_8BIT
diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 9a4d2c9..b2749a9 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -16,7 +16,6 @@
#define CONFIG_CMD_SDRAM #define CONFIG_CMD_IDE -#define CONFIG_DOS_PARTITION
#define CONFIG_BAUDRATE 38400 #define CONFIG_BOOTARGS "console=ttySC2,38400" diff --git a/include/configs/apf27.h b/include/configs/apf27.h index b903ba5..13cb7c9 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -241,7 +241,6 @@ */ #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT
/* diff --git a/include/configs/apx4devkit.h b/include/configs/apx4devkit.h index babaf26..3252aea 100644 --- a/include/configs/apx4devkit.h +++ b/include/configs/apx4devkit.h @@ -21,7 +21,6 @@
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION
#define CONFIG_CMD_DATE #define CONFIG_CMD_NAND diff --git a/include/configs/aria.h b/include/configs/aria.h index f385852..d408d54 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -403,12 +403,6 @@ #define CONFIG_CMD_PCI #endif
-#if defined(CONFIG_CMD_IDE) || defined(CONFIG_CMD_EXT2) -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION -#endif /* defined(CONFIG_CMD_IDE) */ - /* * Dynamic MTD partition support */ diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index ed0daf5..a02e9cc 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -144,7 +144,6 @@ #define CONFIG_USB_ATMEL 1 #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1
#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_USB_HOST_BASE diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index e1f934c..e6a2303 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -152,9 +152,6 @@ #endif
/* FAT */ -#ifdef CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#endif
/* NOR flash - no real flash on this board */ #define CONFIG_SYS_NO_FLASH 1 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index cc37236..67a721b 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -127,7 +127,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9261_UHP_BASE */ #ifdef CONFIG_AT91SAM9G10EK diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index cc1695e..fdaa599 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -268,7 +268,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index fd0504d..1501729 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -104,10 +104,6 @@ #define CONFIG_GENERIC_ATMEL_MCI #endif
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index b825464..566e3a3 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -129,9 +129,6 @@ #endif
/* Ethernet */ #define CONFIG_KS8851_MLL diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 23184ce..5789197 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -109,7 +109,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_GENERIC_ATMEL_MCI -#define CONFIG_DOS_PARTITION #endif
/* Ethernet - not present */ diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 843f03a..1048145 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -117,9 +117,6 @@ #endif
/* Ethernet */ #define CONFIG_MACB diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index a0f451b..fcb1cfd 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -48,7 +48,6 @@ #define CONFIG_USART_BASE ATMEL_BASE_USART1 #define CONFIG_USART_ID 1 /* User serviceable stuff */ -#define CONFIG_DOS_PARTITION
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index 4d9282a..204b0c4 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -67,7 +67,6 @@ #define CONFIG_USART_ID 1
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 9ddfff2..a8e2398 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -64,7 +64,6 @@ #define CONFIG_USART_ID 1
#define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index b99248e..9e68001 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -88,7 +88,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_DWMMC -#define CONFIG_DOS_PARTITION
/* * Ethernet PHY configuration diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 8efd513..6f34558 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -35,8 +35,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
/* FIT support */ @@ -278,8 +276,6 @@ #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* disable host part of MUSB in SPL */ /* disable EFI partitions and partition UUID support */ -#undef CONFIG_PARTITION_UUIDS -#undef CONFIG_EFI_PARTITION /* * Disable CPSW SPL support so we fit within the 101KiB limit. */ diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index 1b22a37..8d31a97 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -194,9 +194,6 @@ #define CONFIG_SUPPORT_VFAT
/*----------------------------------------------------------------------- * PCI stuff diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 2f51e2c..cd844df 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -45,7 +45,6 @@
#ifdef CONFIG_NAND #define NANDARGS \ @@ -457,8 +456,6 @@ DEFAULT_LINUX_BOOT_ENV \ #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* disable host part of MUSB in SPL */ /* disable EFI partitions and partition UUID support */ -#undef CONFIG_PARTITION_UUIDS -#undef CONFIG_EFI_PARTITION #endif
/* USB Device Firmware Update support */ diff --git a/include/configs/bcm23550_w1d.h b/include/configs/bcm23550_w1d.h index eb4c497..d824e83 100644 --- a/include/configs/bcm23550_w1d.h +++ b/include/configs/bcm23550_w1d.h @@ -109,8 +109,6 @@ * This is necessary for the fatls command to work on an SD card * for example. */ -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION
/* version string, parser, etc */ #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index 7a75fdb..4c06527 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -108,8 +108,6 @@ * This is necessary for the fatls command to work on an SD card * for example. */ -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION
/* version string, parser, etc */ #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index b68fa1e..c830e37 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -65,7 +65,6 @@ * This is necessary for the fatls command to work on an SD card * for example. */ -#define CONFIG_DOS_PARTITION
/* version string, parser, etc */ #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index ec4d93c..28041a9 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -152,7 +152,6 @@ /* #define CONFIG_STAMP_CF */ #if defined(CONFIG_STAMP_CF) #define CONFIG_MISC_INIT_R -#define CONFIG_DOS_PARTITION 1 #undef CONFIG_IDE_8xx_DIRECT /* no pcmcia interface required */ #undef CONFIG_IDE_LED /* no led for ide supported */ #undef CONFIG_IDE_RESET /* no reset for ide supported */ diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 4f861aa..ceac805 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -185,7 +185,6 @@
#if defined(CONFIG_BFIN_IDE)
-#define CONFIG_DOS_PARTITION 1 /* * IDE/ATA stuff */ diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index c401b73..72099bf 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -21,10 +21,8 @@ # endif # ifdef CONFIG_LIBATA # define CONFIG_CMD_SATA -# define CONFIG_DOS_PARTITION # endif # ifdef CONFIG_MMC -# define CONFIG_DOS_PARTITION # define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 # endif # ifdef CONFIG_MMC_SPI @@ -32,7 +30,6 @@ # endif # ifdef CONFIG_USB # define CONFIG_CMD_USB_STORAGE -# define CONFIG_DOS_PARTITION # endif # if defined(CONFIG_NAND_PLAT) || defined(CONFIG_DRIVER_NAND_BFIN) # define CONFIG_CMD_NAND diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index 57a6985..fdb044d 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -11,7 +11,6 @@
#define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index a5fdbbb..1bd52a4 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -284,7 +284,6 @@ MMCARGS * enabled a number of useful commands and support. */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index a6369d6..e90b906 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -130,7 +130,6 @@ BUR_COMMON_ENV \ * enabled a number of useful commands and support. */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE #endif /* CONFIG_MMC, ... */
diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index 1d189d2..42946b6 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -396,9 +396,6 @@ #endif
/*----------------------------------------------------------------------- * PCI stuff diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index c976ec8..fbb6214 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -51,8 +51,6 @@ #define CONFIG_SYS_MMC_BASE MVEBU_SDIO_BASE
/* Partition support */ -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index b65ca3e..b3a98df 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -225,9 +225,6 @@ #define CONFIG_USB_CLOCK 0x0001BBBB #define CONFIG_USB_CONFIG 0x00001000 /* Partitions (for USB) */ -#define CONFIG_MAC_PARTITION 1 -#define CONFIG_DOS_PARTITION 1 -#define CONFIG_ISO_PARTITION 1
/* * Invoke our last_stage_init function - needed by fwupdate diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index da5a4b3..dca4e37 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -83,7 +83,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* USB */ #define CONFIG_USB_OMAP3 diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 1e2a477..3d05f64 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -90,7 +90,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* USB */ #define CONFIG_USB_MUSB_AM35X diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 9c24ba9..8bba58e 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -107,7 +107,6 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index d58145e..3accec5 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -66,7 +66,6 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#define CONFIG_RBTREE #define CONFIG_LZO diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index b824e3b..18f6598 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -382,7 +382,6 @@ #define CONFIG_HW_WATCHDOG #define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE -#define CONFIG_DOS_PARTITION
/* * For booting Linux, the board info and command line data diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 67a5034..fff34e7 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -556,7 +556,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE
/* SATA */ @@ -574,7 +573,6 @@
#ifdef CONFIG_FMAN_ENET @@ -630,7 +628,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/corvus.h b/include/configs/corvus.h index e6a52d8..c9059e4 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -103,7 +103,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_ATMEL #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#define CONFIG_DOS_PARTITION
/* USB DFU support */ #define CONFIG_CMD_MTDPARTS diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 13e4690..fa76969 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -388,7 +388,6 @@ #define CONFIG_NET_MULTI
/* SATA */ @@ -406,7 +405,6 @@
#ifdef CONFIG_FMAN_ENET @@ -453,7 +451,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 3560115..6847489 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -325,9 +325,6 @@ * Enable MMC commands only when * MMC support is present */ -#ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION -#endif
#ifndef CONFIG_DIRECT_NOR_BOOT /* defines for SPL */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 4834828..6d05776 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -41,8 +41,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index b8c5232..e29139d 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -62,8 +62,6 @@ CONFIG_SYS_SCSI_MAX_LUN)
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 26508c2..656c8c3 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -62,8 +62,6 @@ #define CONFIG_SATA_MV #define CONFIG_LIBATA #define CONFIG_LBA48 -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index 182e8ab..ad7667e 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -173,7 +173,6 @@ #define CONFIG_PCMCIA_SLOT_A
#define CONFIG_ATAPI 1 -#define CONFIG_MAC_PARTITION 1
/* We run CF in "true ide" mode or a harddrive via pcmcia */ #define CONFIG_IDE_PCMCIA 1 diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index a71f67c..e0df470 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -137,7 +137,6 @@
#define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_DOS_PARTITION
/* * Pass open firmware flat tree diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index b2120b9..3ebb47e 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -64,7 +64,6 @@ /* * Partitions */ -#define CONFIG_DOS_PARTITION #define CONFIG_BZIP2
/* diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 75a7854..2506e6f 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -149,7 +149,6 @@
diff --git a/include/configs/draco.h b/include/configs/draco.h index 7c4179d..bc85cf3 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -31,8 +31,6 @@ "led0=103,1,0\0" \ "led1=64,0,1\0"
-#undef CONFIG_DOS_PARTITION - #define CONFIG_BOARD_LATE_INIT
/* Physical Memory Map */ diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index 1b440ea..4438d4e 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -68,7 +68,6 @@
/* Partition table support */ #define HAVE_BLOCK_DEVICE /* Needed for partition commands */ -#define CONFIG_PARTITION_UUIDS
#include <config_distro_defaults.h>
diff --git a/include/configs/ds414.h b/include/configs/ds414.h index 0be8800..9d5a5f7 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -81,8 +81,6 @@ #endif
/* why is this only defined in mv-common.h if CONFIG_DM is undefined? */ -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_VFAT #define CONFIG_SYS_MVFS
diff --git a/include/configs/duovero.h b/include/configs/duovero.h index b5bd3ba..c0c8a41 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -21,8 +21,6 @@
#include <configs/ti_omap4_common.h>
-#undef CONFIG_EFI_PARTITION - #undef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS #define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index e1e3c78..308a179 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -33,8 +33,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_ENV
-#define CONFIG_DOS_PARTITION - #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC0,115200"
diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index af7b470..71f416c 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -145,7 +145,6 @@ #ifdef CONFIG_CMD_IDE #define __io #define CONFIG_IDE_PREINIT -#define CONFIG_DOS_PARTITION /* ED Mini V has an IDE-compatible SATA connector for port 1 */ #define CONFIG_MVSATA_IDE #define CONFIG_MVSATA_IDE_USE_PORT1 @@ -176,8 +175,6 @@ #define CONFIG_USB_EHCI /* Enable EHCI USB support */ #define CONFIG_USB_EHCI_MARVELL #define ORION5X_USB20_HOST_PORT_BASE ORION5X_USB20_PORT0_BASE -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_VFAT #endif /* CONFIG_CMD_USB */
diff --git a/include/configs/etamin.h b/include/configs/etamin.h index eb17d68..7c1ddb9 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -88,7 +88,6 @@ "led4=60,0,1\0" \ "led5=63,0,1\0"
-#undef CONFIG_DOS_PARTITION #undef CONFIG_CMD_FAT
#define CONFIG_BOARD_LATE_INIT diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index b4a0388..69ff99e 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -196,7 +196,6 @@ #endif #if defined(CONFIG_CMD_REISER) || defined(CONFIG_CMD_EXT2) || \ defined(CONFIG_CMD_USB) || defined(CONFIG_MMC) -#define CONFIG_DOS_PARTITION #endif #define CONFIG_LZO #define CONFIG_RBTREE diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 3b61a41..04c38ef 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -56,7 +56,6 @@ #define CONFIG_FAT_WRITE
#define CONFIG_CMD_PART -#define CONFIG_PARTITION_UUIDS
/* Miscellaneous configurable options */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 2560c88..30c0291 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -70,7 +70,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_BOUNCE_BUFFER -#define CONFIG_DOS_PARTITION
/* USB Configs */ #ifdef CONFIG_USB diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index c1b43fd..559e48d 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -106,8 +106,6 @@ #define CONFIG_EHCI_IS_TDI #endif /* CONFIG_CMD_USB */
#endif /* __CONFIG_GPLUGD_H */ diff --git a/include/configs/gr_cpci_ax2000.h b/include/configs/gr_cpci_ax2000.h index 211dc38..7f6586f 100644 --- a/include/configs/gr_cpci_ax2000.h +++ b/include/configs/gr_cpci_ax2000.h @@ -49,9 +49,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* Partitions */ -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION
/* * Supported commands diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index ad0c126..4d28a97 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -43,9 +43,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* * Supported commands diff --git a/include/configs/gr_xc3s_1500.h b/include/configs/gr_xc3s_1500.h index b0e9001..b91ab85 100644 --- a/include/configs/gr_xc3s_1500.h +++ b/include/configs/gr_xc3s_1500.h @@ -30,9 +30,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* * Supported commands diff --git a/include/configs/grsim.h b/include/configs/grsim.h index 17cac5a..8c1c8b4 100644 --- a/include/configs/grsim.h +++ b/include/configs/grsim.h @@ -41,9 +41,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* * Supported commands diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index 1642793..3651017 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -36,9 +36,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
/* * Supported commands diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 9677aab..aa56d55 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#define CONFIG_CMD_FPGAD #define CONFIG_CMD_IOLOOP diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index f686c7f..ec209a1 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -92,7 +92,6 @@ #ifdef CONFIG_CMD_IDE #define __io #define CONFIG_IDE_PREINIT -#define CONFIG_DOS_PARTITION #define CONFIG_MVSATA_IDE_USE_PORT0 #define CONFIG_MVSATA_IDE_USE_PORT1 #define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET diff --git a/include/configs/icon.h b/include/configs/icon.h index b15016b..3bf7383 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -224,7 +224,6 @@ #define CONFIG_SYSTEMACE /* Enable SystemACE support */ #define CONFIG_SYS_SYSTEMACE_WIDTH 16 /* Data bus width is 16 */ #define CONFIG_SYS_SYSTEMACE_BASE CONFIG_SYS_ACE_BASE -#define CONFIG_DOS_PARTITION
/* * External Bus Controller (EBC) Setup diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 14c43b8..ebc1a88 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -140,7 +140,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_MXC_MMC -#define CONFIG_DOS_PARTITION
/* * GPIO diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index 79a716e..b2131e8 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -61,9 +61,6 @@ #define CONFIG_SYS_XLB_PIPELINING 1
/* * BOOTP options diff --git a/include/configs/intip.h b/include/configs/intip.h index e61005b..4db067f 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -280,9 +280,6 @@ #define CONFIG_CMD_SDRAM
/* * PCI stuff diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 3bd938e..a790271 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -78,7 +78,6 @@ #define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */
/* USB */ #define CONFIG_USB_OHCI_NEW diff --git a/include/configs/jupiter.h b/include/configs/jupiter.h index e073528..4b7ea6d 100644 --- a/include/configs/jupiter.h +++ b/include/configs/jupiter.h @@ -64,9 +64,6 @@ #define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */
#define CONFIG_TIMESTAMP /* Print image info with timestamp */
diff --git a/include/configs/katmai.h b/include/configs/katmai.h index a41c127..f531381 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -238,7 +238,6 @@ #define CONFIG_SYSTEMACE 1 /* Enable SystemACE support */ #define CONFIG_SYS_SYSTEMACE_WIDTH 16 /* Data bus width is 16 */ #define CONFIG_SYS_SYSTEMACE_BASE CONFIG_SYS_ACE_BASE -#define CONFIG_DOS_PARTITION 1
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 76f2b8b..9a55fa1 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -108,7 +108,6 @@ * Partitions */
/* diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index fad8865..b88d113 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -352,7 +352,6 @@ int get_scl(void); #define CONFIG_PCI_INDIRECT_BRIDGE
/* RGMII (FM1@DTESC5) is used as debug itf, it's the only one configured */ #define CONFIG_SYS_FM1_DTSEC5_PHY_ADDR 0x11 diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 9402aca..06cf308 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -23,7 +23,6 @@ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_DOS_PARTITION
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "root=/dev/null console=ttySC4,115200" diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 4804fe0..1d9224c 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -135,8 +135,6 @@ /* * Partition support */ -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION
/* * File systems support diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index d91e75d..c5ae0c6 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -226,9 +226,6 @@ * Enable MMC commands only when * MMC support is present */ -#ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION -#endif
/* additions for new relocation code, must added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0xc0000000 diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 0cc1791..c3e1668 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -136,7 +136,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* SATA */ @@ -145,7 +144,6 @@ #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_CMD_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA AHCI_BASE_ADDR diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 15410dd..a0c35dd 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -49,7 +49,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* SATA */ @@ -58,7 +57,6 @@ #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_CMD_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA AHCI_BASE_ADDR diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 7af4bc4..13fa6d9 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -179,7 +179,6 @@ CONFIG_SYS_SCSI_MAX_LUN)
#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION
/* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 128da8a..2e4b7ca 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -397,8 +397,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC
-#define CONFIG_DOS_PARTITION - /* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) /* QSPI */ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 1458332..8ee2057 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -298,8 +298,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_GENERIC_MMC
-#define CONFIG_DOS_PARTITION - /* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) /* QSPI */ diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 7a407aa..e198819 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -154,7 +154,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* DSPI */ diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 561a05a..374bcf2 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -97,7 +97,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
/* EEPROM */ diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 849a6cb..04f6efd 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -301,7 +301,6 @@ #ifndef CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT2 #endif -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_SCSI_MAX_SCSI_ID 2 #define CONFIG_SYS_SCSI_MAX_LUN 2 diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 3887faa..479ff02 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -120,7 +120,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
#define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 29e0aa5..538e724 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -140,7 +140,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
/* EEPROM */ diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 2fe8fc1..68065b0 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -216,7 +216,6 @@ #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA AHCI_BASE_ADDR diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h index f0ec6c4..b7b0257 100644 --- a/include/configs/ls2080a_simu.h +++ b/include/configs/ls2080a_simu.h @@ -138,7 +138,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Debug Server firmware */ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 838568f..f8e6018 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -53,7 +53,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 @@ -360,7 +359,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
/* Initial environment variables */ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 31df781..c245b84 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -61,7 +61,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SCSI_AHCI #define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SCSI -#define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 @@ -304,7 +303,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #endif
#define CONFIG_MISC_INIT_R diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 0caca4c..7ec82cd 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -48,9 +48,6 @@ #define CONFIG_CMD_ENV #define CONFIG_CMD_IDE
-#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 638682f..8f38e47 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -372,9 +372,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* re-init HCD after CMD_RESET */
/* * BOOTP options diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 25884b4..51825f2 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -16,7 +16,6 @@
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE
#define CONFIG_CMD_BMP diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 7e05bfd..cd27012 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -23,7 +23,6 @@ /* * U-Boot Commands */ -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE
#define CONFIG_CMD_BMP diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 91037d6..68eca5d 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -19,7 +19,6 @@ /* * U-Boot Commands */ -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE
/* diff --git a/include/configs/manroland/common.h b/include/configs/manroland/common.h index 937febe..d97d938 100644 --- a/include/configs/manroland/common.h +++ b/include/configs/manroland/common.h @@ -16,7 +16,6 @@ #define CONFIG_BOARD_EARLY_INIT_R
/* * Command line configuration. diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 0c6b1e8..b895ae6 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -84,7 +84,6 @@ #define CONFIG_MMC #define CONFIG_OMAP_HSMMC #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION
/* EHCI */ #define CONFIG_OMAP3_GPIO_2 diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index 4f90c34..7f88b79 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -295,7 +295,6 @@ #undef CONFIG_CMD_FUSE #undef CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_DOS_PARTITION
/* * Watchdog timeout = CONFIG_SYS_WATCHDOG_VALUE * 65536 / IPS clock. diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index 917350f..6217015 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -257,7 +257,6 @@ #define CONFIG_SYS_ATA_DATA_OFFSET 0x0060 #define CONFIG_SYS_ATA_REG_OFFSET CONFIG_SYS_ATA_DATA_OFFSET #define CONFIG_SYS_ATA_STRIDE 4 -#define CONFIG_DOS_PARTITION
/* * I2C configuration diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index c36141a..77f1850 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -438,11 +438,6 @@ "mpc5121.nand:-(data)"
#if defined(CONFIG_CMD_IDE) || defined(CONFIG_CMD_EXT2) || defined(CONFIG_CMD_USB) - -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION - #define CONFIG_SUPPORT_VFAT
#endif /* defined(CONFIG_CMD_IDE) */ diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index d136726..8b79f5d 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -91,7 +91,6 @@
#define CONFIG_SYS_PIO_MODE 1 #define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_MARUBUN_IO /* base address */ #define CONFIG_SYS_ATA_IDE0_OFFSET 0x01F0 /* ide0 offste */ #define CONFIG_SYS_ATA_DATA_OFFSET 0 /* data reg offset */ diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index b28030c..e239eb0 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -125,8 +125,6 @@ */ #if defined(CONFIG_CMD_USB) && !defined(CONFIG_DM) #define CONFIG_USB_EHCI /* Enable EHCI USB support */ -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_VFAT #endif /* CONFIG_CMD_USB */
diff --git a/include/configs/mvebu_db-88f3720.h b/include/configs/mvebu_db-88f3720.h index 7ddde8c..917233f 100644 --- a/include/configs/mvebu_db-88f3720.h +++ b/include/configs/mvebu_db-88f3720.h @@ -131,12 +131,7 @@ #define CONFIG_SUPPORT_VFAT
/* DISK Partition support */ -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION /* Experimental */
#endif /* _CONFIG_MVEBU_DB_88F3720_H */ diff --git a/include/configs/mvebu_db-88f7040.h b/include/configs/mvebu_db-88f7040.h index 6feb8d7..f761a29 100644 --- a/include/configs/mvebu_db-88f7040.h +++ b/include/configs/mvebu_db-88f7040.h @@ -120,12 +120,7 @@ #define CONFIG_SUPPORT_VFAT
#endif /* _CONFIG_MVEBU_DB_88F7040_H */ diff --git a/include/configs/mx23_olinuxino.h b/include/configs/mx23_olinuxino.h index 36ff7ce..a04f7f3 100644 --- a/include/configs/mx23_olinuxino.h +++ b/include/configs/mx23_olinuxino.h @@ -12,7 +12,6 @@
#define CONFIG_CMD_LED
diff --git a/include/configs/mx23evk.h b/include/configs/mx23evk.h index ecb6e4d..4494bf6 100644 --- a/include/configs/mx23evk.h +++ b/include/configs/mx23evk.h @@ -15,7 +15,6 @@
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 81826ea..67a93fa 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -100,8 +100,6 @@ #define CONFIG_POWER_FSL_MC34704 #define CONFIG_SYS_FSL_PMIC_I2C_ADDR 0x54
-#define CONFIG_DOS_PARTITION - /* I2C Configs */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 5963d39..85ea54a 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -17,7 +17,6 @@
#define CONFIG_CMD_DATE #define CONFIG_CMD_NAND diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 3f064fd..7d7a52e 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -86,9 +86,6 @@ #define CONFIG_NET_RETRY_COUNT 100 #define CONFIG_CMD_DATE
#define CONFIG_LOADADDR 0x80800000 /* loadaddr env var */
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 3c1d53f..b17b4d0 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -70,7 +70,6 @@ #define CONFIG_MMC
/* * Eth Configs diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 27e7738..109c82a 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -55,7 +55,6 @@
/* Eth Configs */ #define CONFIG_HAS_ETH1 diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 7a896c7..ce012e9 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -54,7 +54,6 @@
/* Eth Configs */ #define CONFIG_MII diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 6cc5d9c..b65d219 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -40,7 +40,6 @@
/* Eth Configs */ #define CONFIG_MII diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index 262a913..15f624b 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -45,7 +45,6 @@
/* Eth Configs */ #define CONFIG_HAS_ETH1 diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index d28654b..f1388ca 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -64,7 +64,6 @@
/* Filesystems and image support */ #define CONFIG_SUPPORT_RAW_INITRD -#define CONFIG_DOS_PARTITION
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 0645228..50bfc99 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -40,7 +40,6 @@ #define CONFIG_BAUDRATE 115200
/* Filesystems and image support */ -#define CONFIG_DOS_PARTITION
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 7cfdacd..6ec83da 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -100,7 +100,6 @@ #define CONFIG_USB_EHCI /* Enable EHCI USB support */ #define CONFIG_USB_EHCI_KIRKWOOD /* on Kirkwood platform */ #define CONFIG_EHCI_IS_TDI -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #endif /* CONFIG_CMD_USB */
@@ -128,7 +127,6 @@ /* * EFI partition */ -#define CONFIG_EFI_PARTITION
/* * Date Time diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 4d5265f..3ecbd49 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -96,7 +96,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* USB */ #define CONFIG_USB_MUSB_UDC diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 1987164..366ee55 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -84,7 +84,6 @@ #ifdef CONFIG_CMD_IDE #define __io #define CONFIG_IDE_PREINIT -#define CONFIG_DOS_PARTITION #define CONFIG_MVSATA_IDE_USE_PORT0 #define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET #endif /* CONFIG_CMD_IDE */ diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index c51ea3d..8a414c3 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -61,9 +61,6 @@ #define CONFIG_SYS_XLB_PIPELINING 1
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 6388a9c..7b01ffb 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -56,8 +56,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
/* Partition tables */ -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION
/* USB * diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 22614fb..d98d8c4 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -77,7 +77,6 @@
/* Enhance our eMMC support / experience. */ #define CONFIG_CMD_GPT -#define CONFIG_EFI_PARTITION #define CONFIG_HSMMC2_8BIT #define CONFIG_SUPPORT_EMMC_BOOT
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 854fc47..6433b7c 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -244,7 +244,6 @@ #define CONFIG_DAVINCI_MMC
#ifdef CONFIG_MMC -#define CONFIG_DOS_PARTITION #undef CONFIG_ENV_IS_IN_MMC #endif
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 77f3d81..f2e1169 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -707,7 +707,6 @@ #define CONFIG_CMD_PCI
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION #endif /* CONFIG_PCI */
#if defined(CONFIG_TSEC_ENET) @@ -859,7 +858,6 @@
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) \ || defined(CONFIG_FSL_SATA) -#define CONFIG_DOS_PARTITION #endif
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index c122f8e..875a159 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -281,7 +281,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_CMD_PCI
#if defined(CONFIG_TSEC_ENET) @@ -423,7 +422,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index c92948f..10d39e0 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -104,7 +104,6 @@ /*---USB -------------------------------------------*/ #if 0 #define CONFIG_USB_OHCI -#define CONFIG_DOS_PARTITION #endif
/*---ATA PCMCIA ------------------------------------*/ @@ -114,7 +113,6 @@ #define CONFIG_PCMCIA_SLOT_A
/* We run CF in "true ide" mode or a harddrive via pcmcia */ #define CONFIG_IDE_PCMCIA 1 diff --git a/include/configs/pcm030.h b/include/configs/pcm030.h index 4fb9966..bd0203d 100644 --- a/include/configs/pcm030.h +++ b/include/configs/pcm030.h @@ -397,7 +397,6 @@ RTC configuration #define CONFIG_ATAPI 1
/* we enable IDE and FAT support, so we also need partition support */ -#define CONFIG_DOS_PARTITION 1
/* USB */ #define CONFIG_USB_OHCI diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index eb1944a..dd8f0fc 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -77,7 +77,6 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC_A001
#define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/pic32mzdask.h b/include/configs/pic32mzdask.h index 52b7a2a..4fa7dfb 100644 --- a/include/configs/pic32mzdask.h +++ b/include/configs/pic32mzdask.h @@ -104,8 +104,6 @@ * File System Configuration */ /* FAT FS */ -#define CONFIG_DOS_PARTITION -#define CONFIG_PARTITION_UUIDS #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_FAT #define CONFIG_FAT_WRITE diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index a214c4d..76cb314 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -39,7 +39,6 @@
#define CONFIG_MMC #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_EMMC_BOOT
/* USB Configs */ diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 9051c1c..31f65a2 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -97,10 +97,6 @@ #define CONFIG_GENERIC_ATMEL_MCI #endif
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index c19e7dc..54b0d7a 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -226,7 +226,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9261" diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index eddc81a..07f1e52 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -255,7 +255,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 28690c2..3263f26 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -111,7 +111,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_UPLL #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* _UHP_OHCI_BASE */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g45" diff --git a/include/configs/pxa-common.h b/include/configs/pxa-common.h index 3fa7739..09a800b 100644 --- a/include/configs/pxa-common.h +++ b/include/configs/pxa-common.h @@ -25,7 +25,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_PXA_MMC_GENERIC -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index a6abba7..6fdf50b 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -54,7 +54,6 @@ #define CONFIG_CONS_INDEX 1
#ifdef CONFIG_SYS_BIG_ENDIAN #define CONFIG_IDE_SWAP_IO diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index 7297a81..4ad230c 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -54,7 +54,6 @@ #define CONFIG_CONS_INDEX 1
#ifdef CONFIG_SYS_BIG_ENDIAN #define CONFIG_IDE_SWAP_IO diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 2c85f65..8cfb8fa 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -118,11 +118,9 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); #define CONFIG_PCI_INDIRECT_BRIDGE
#define CONFIG_LBA48 -#define CONFIG_DOS_PARTITION
/* * Environment diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 477f035..6b2b6d2 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -13,7 +13,6 @@ */ #define CONFIG_CMD_PCI #define CONFIG_CMD_IDE -#define CONFIG_DOS_PARTITION #define CONFIG_CMD_SH_ZIMAGEBOOT
/* SCIF */ diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index d4f200a..867d5b7 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -22,7 +22,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_PCI #define CONFIG_CMD_IDE -#define CONFIG_DOS_PARTITION
#define CONFIG_SCIF_CONSOLE 1 #define CONFIG_BAUDRATE 115200 diff --git a/include/configs/rastaban.h b/include/configs/rastaban.h index d6fead2..64f305f 100644 --- a/include/configs/rastaban.h +++ b/include/configs/rastaban.h @@ -34,8 +34,6 @@ "led4=60,0,1\0" \ "led5=63,0,1\0"
/* Physical Memory Map */ diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 459b077..120ea9b 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -18,7 +18,6 @@
/* Support File sytems */ #define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index ec4d54e..99097e8 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -27,7 +27,6 @@
/* Support File sytems */ #define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #define CONFIG_FS_EXT4 #define CONFIG_EXT4_WRITE diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 92be29e..be2d4ac 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -43,7 +43,6 @@ #define CONFIG_BOUNCE_BUFFER
#define CONFIG_FAT_WRITE -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
#define CONFIG_SYS_SDRAM_BASE 0x60000000 diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 5358372..cda23e9 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -46,7 +46,6 @@ #define CONFIG_BOUNCE_BUFFER
/* RAW SD card / eMMC locations. */ diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 9ec71c4..a7341dc 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -19,7 +19,6 @@ /* Enable gpt partition table */ #define CONFIG_CMD_GPT #define CONFIG_RANDOM_UUID -#define CONFIG_PARTITION_UUIDS #define PARTS_DEFAULT \ "uuid_disk=${uuid_gpt_disk};" \ "name=loader1,start=32K,size=4000K,uuid=${uuid_gpt_loader1};" \ diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 4406366..4fd4fd6 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -132,7 +132,6 @@ #define CONFIG_COMMAND_HISTORY
/* Commands */ -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
/* ATAGs support for bootm/bootz */ diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index 533fde4..7afbe99 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -89,7 +89,6 @@ #define CONFIG_GENERIC_MMC /* #define CONFIG_CMD_EXT2 EXT2 Support */ #define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_DOS_PARTITION
#if 0
diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 124cca3..516949d 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -217,15 +217,11 @@ #define CONFIG_SAMSUNG_ONENAND 1 #define CONFIG_SYS_ONENAND_BASE 0xB0000000
-#define CONFIG_DOS_PARTITION 1 - /* write support for filesystems */ #define CONFIG_FAT_WRITE #define CONFIG_EXT4_WRITE
/* GPT */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index 7a049d4..6fbd053 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -84,7 +84,6 @@
#if defined(CONFIG_CMD_USB) #define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION #endif
/* Ethernet Hardware */ diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index 61e3376..2bcef15 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -54,10 +54,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D2 XPlained"
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* I2C */ #define AT24MAC_ADDR 0x5c #define AT24MAC_REG 0x9a diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index f48559e..2c18528 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_BASE_OHCI #define CONFIG_SYS_USB_OHCI_SLOT_NAME "SAMA5D3 Xplained" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 -#define CONFIG_DOS_PARTITION #endif
#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index ed91bdc..cae287e 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -129,7 +129,6 @@ #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_BASE_OHCI #define CONFIG_SYS_USB_OHCI_SLOT_NAME "sama5d3" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 -#define CONFIG_DOS_PARTITION #endif
/* USB device */ diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 5d78847..b1e5b1d 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -83,10 +83,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D4EK"
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet Hardware */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 498b32b..5184af5 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -83,10 +83,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "Atmel SAMA5D4EK"
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet Hardware */ #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 2daf02d..bcc13a4 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -44,17 +44,10 @@ #define CONFIG_CMD_CBFS #define CONFIG_CMD_CRAMFS #define CONFIG_CMD_PART -#define CONFIG_DOS_PARTITION #define CONFIG_HOST_MAX_DEVICES 4 #define CONFIG_CMD_MD5SUM
#define CONFIG_CMD_GPT -#define CONFIG_PARTITION_UUIDS -#define CONFIG_AMIGA_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION -#define CONFIG_ISO_PARTITION -#define CONFIG_MAC_PARTITION
/* * Size of malloc() pool, before and after relocation diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index 0b2821d..d97b15f 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -11,7 +11,6 @@
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 2bd89f4..a9ebebb 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -306,7 +306,6 @@
-#define CONFIG_DOS_PARTITION #undef CONFIG_SCSI_AHCI
#ifdef CONFIG_SCSI_AHCI diff --git a/include/configs/sc_sps_1.h b/include/configs/sc_sps_1.h index 56a23a6..b79ba49 100644 --- a/include/configs/sc_sps_1.h +++ b/include/configs/sc_sps_1.h @@ -16,7 +16,6 @@
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index ed8a51c..86a7eb4 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -219,9 +219,6 @@ #endif /* CONFIG_440EPX */
/* Partitions */ -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION
/* * Commands additional to the ones defined in amcc-common.h diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index 38bf408..a63e788 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -20,8 +20,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 3718bc5..cf1101a 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -20,8 +20,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 8820e15..7ca77fa 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -20,8 +20,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp" diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index a49e839..93b8dcf 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -17,9 +17,6 @@ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_SH_ZIMAGEBOOT
-#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION - #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC1,115200 root=/dev/nfs ip=dhcp"
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 748a2ea..86ba168 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -95,7 +95,6 @@ #ifdef CONFIG_CMD_IDE #define __io #define CONFIG_IDE_PREINIT -#define CONFIG_DOS_PARTITION #define CONFIG_MVSATA_IDE_USE_PORT0 #define CONFIG_MVSATA_IDE_USE_PORT1 #define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 4564296..66091a1 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -80,7 +80,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
#define CONFIG_SPI #define CONFIG_OMAP3_SPI diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index 1578310..9c2bef1 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -50,7 +50,6 @@ ************************************************************/ #define CONFIG_USB_OHCI #define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_DOS_PARTITION
/************************************************************ * RTC diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index 4292566..f605f10 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -187,8 +187,6 @@ #define CONFIG_SAMSUNG_ONENAND 1 #define CONFIG_SYS_ONENAND_BASE 0xE7100000
-#define CONFIG_DOS_PARTITION 1 - #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
/* diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 8bd5806..0e079b0 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -64,7 +64,6 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_UHP_BASE #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index c76c55f..fc1cb4c 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -67,8 +67,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_ATMEL #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#define CONFIG_DOS_PARTITION -#define CONFIG_PARTITION_UUIDS
/* MMC */ #define CONFIG_MMC diff --git a/include/configs/sniper.h b/include/configs/sniper.h index e12b101..7a8c16d 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -115,7 +115,6 @@ * Partitions */
/* diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index 3b0b416..bc4d3cd 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -10,7 +10,6 @@
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index 7ced6a6..5e317bb 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index 6b9546e..361019c 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_is1.h b/include/configs/socfpga_is1.h index cc07253..f102a18 100644 --- a/include/configs/socfpga_is1.h +++ b/include/configs/socfpga_is1.h @@ -11,7 +11,6 @@
diff --git a/include/configs/socfpga_mcvevk.h b/include/configs/socfpga_mcvevk.h index d1b31c4..d36fac6 100644 --- a/include/configs/socfpga_mcvevk.h +++ b/include/configs/socfpga_mcvevk.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index 3fceb31..16a85ae 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_socrates.h b/include/configs/socfpga_socrates.h index c9473df..0c8da60 100644 --- a/include/configs/socfpga_socrates.h +++ b/include/configs/socfpga_socrates.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 0407f03..8624bb3 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -11,7 +11,6 @@ #define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_HW_WATCHDOG diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index c5555e6..205b10b 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -10,7 +10,6 @@
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index c697f63..5a78abc 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -409,6 +409,5 @@ #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" #define CONFIG_SYS_OHCI_SWAP_REG_ACCESS 1 -#define CONFIG_DOS_PARTITION 1
#endif /* __CONFIG_H */ diff --git a/include/configs/strider.h b/include/configs/strider.h index 6604cec..94dc9b7 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#define CONFIG_SYS_ALT_MEMTEST
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b0bfc0d..508d8d5 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -337,7 +337,6 @@ extern int soft_i2c_gpio_scl;
#ifdef CONFIG_MMC #define CONFIG_FASTBOOT_FLASH_MMC_DEV 0 -#define CONFIG_EFI_PARTITION #endif #endif
diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 0aba18b..3a4aced 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -215,7 +215,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE
/* SATA */ @@ -233,7 +232,6 @@
#define CONFIG_LBA48 #define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION #endif
#ifdef CONFIG_FMAN_ENET diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index ff0c60d..770117b 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -76,7 +76,6 @@ #define CONFIG_MMC #define CONFIG_OMAP_HSMMC #define CONFIG_GENERIC_MMC -#define CONFIG_DOS_PARTITION
/* EHCI */ #define CONFIG_OMAP3_GPIO_5 diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index a873e7b..114efb8 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -73,7 +73,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* GPIO banks */ #define CONFIG_OMAP3_GPIO_2 /* GPIO32 ..63 is in GPIO bank 2 */ diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 0dc4a28..0ef5a8e 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -53,8 +53,6 @@ #define CONFIG_CMD_PART
/* Filesystems / image support */ -#define CONFIG_EFI_PARTITION -#define CONFIG_PARTITION_UUIDS
/* MMC */ #define CONFIG_SYS_FSL_USDHC_NUM 3 diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index a9990b7..fb005e9 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -128,12 +128,6 @@ #endif
/* remove partitions/filesystems */ -#ifdef CONFIG_DOS_PARTITION -#undef CONFIG_DOS_PARTITION -#endif -#ifdef CONFIG_EFI_PARTITION -#undef CONFIG_EFI_PARTITION -#endif #ifdef CONFIG_FS_EXT4 #undef CONFIG_FS_EXT4 #endif @@ -152,9 +146,6 @@ #endif
/* remove part command support */ -#ifdef CONFIG_PARTITION_UUIDS -#undef CONFIG_PARTITION_UUIDS -#endif
#ifdef CONFIG_CMD_PART #undef CONFIG_CMD_PART diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 63b711b..1df3f4e 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -55,7 +55,6 @@ #define CONFIG_COMMAND_HISTORY
/* turn on commonly used storage-related commands */ -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 281593a..5db0b8c 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -76,8 +76,6 @@ #define CONFIG_SATA_MV #define CONFIG_LIBATA #define CONFIG_LBA48 -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION
/* Additional FS support/configuration */ #define CONFIG_SUPPORT_VFAT diff --git a/include/configs/thuban.h b/include/configs/thuban.h index a235253..fc0fa63 100644 --- a/include/configs/thuban.h +++ b/include/configs/thuban.h @@ -27,8 +27,6 @@ "led0=103,1,0\0" \ "led1=64,0,1\0"
/* Physical Memory Map */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 6a5ed19..3b4676f 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -116,7 +116,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/** * Physical Memory Map diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 5db4c60..8473aad 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -55,7 +55,6 @@ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 1be8137..fd0a305 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -184,9 +184,7 @@ * enabled a number of useful commands and support. */ #if defined(CONFIG_MMC) || defined(CONFIG_USB_STORAGE) -#define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART #endif
diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index cfb4b30..9881407 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -194,7 +194,6 @@ /* USB Configuration */ #define CONFIG_USB_XHCI_KEYSTONE #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 -#define CONFIG_EFI_PARTITION #define CONFIG_FS_FAT #define CONFIG_USB_SS_BASE KS2_USB_SS_BASE #define CONFIG_USB_HOST_XHCI_BASE KS2_USB_HOST_XHCI_BASE diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index fefc902..6a10f12 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -64,8 +64,6 @@ #define CONFIG_EHCI_DESC_BIG_ENDIAN #define CONFIG_EHCI_IS_TDI
-#define CONFIG_DOS_PARTITION - /* * Diagnostics */ diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 07a92eb..f257c7e 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -91,7 +91,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_MMC #define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/ts4600.h b/include/configs/ts4600.h index 9b7bd1b..2219a53 100644 --- a/include/configs/ts4600.h +++ b/include/configs/ts4600.h @@ -19,7 +19,6 @@
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH /* No NOR Flash */ -#define CONFIG_DOS_PARTITION
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index 2e5f38d..88d0b7b 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -64,7 +64,6 @@ #define CONFIG_MMC
/* * Eth Configs diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index f9c9f82..ffe5ed0 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -128,7 +128,6 @@ /* USB */ #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 4 #define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION
/* SD/MMC */ #define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 075d9c9..a1ba428 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -104,7 +104,6 @@ #ifdef CONFIG_CMD_USB #define CONFIG_USB_ATMEL #define CONFIG_USB_OHCI_NEW -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 229c242..eabdd62 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -60,8 +60,6 @@ /* * Partitions */ -#define CONFIG_MAC_PARTITION 1 -#define CONFIG_DOS_PARTITION 1
/* * USB diff --git a/include/configs/vct.h b/include/configs/vct.h index 6ff22c2..22f170c 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -97,9 +97,6 @@ #endif
#if defined(CONFIG_CMD_USB) -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION - #define CONFIG_SUPPORT_VFAT
/* diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index 48834c2..51e22ea 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -131,7 +131,6 @@ #define CONFIG_CMD_UNZIP #define CONFIG_CMD_PXE #define CONFIG_CMD_ENV -#define CONFIG_DOS_PARTITION
/* BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index af5ba61..3564eb2 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -73,7 +73,6 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 0f3fc8f..ec3fbbc 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -64,9 +64,7 @@ #define CONFIG_SYS_MMC_CLK_OD 500000
/* For generating MMC partitions */ -#define CONFIG_PARTITION_UUIDS #define CONFIG_RANDOM_UUID -#define CONFIG_EFI_PARTITION #define CONFIG_CMD_GPT
#endif @@ -84,10 +82,6 @@ #define CONFIG_USB_ETH_RNDIS #define CONFIG_USBNET_MANUFACTURER "L+G VInCo"
-#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) -#define CONFIG_DOS_PARTITION -#endif - /* Ethernet Hardware */ #define CONFIG_PHY_SMSC #define CONFIG_MACB diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 235574d..57cf9f5 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -112,8 +112,6 @@
#ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_SUPPORT_EMMC_BOOT -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_EMMC_RPMB #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC4 eMMC */ /* 0=user, 1=boot0, 2=boot1, * 4..7=general0..3. */ diff --git a/include/configs/warp7.h b/include/configs/warp7.h index d3b0c5e..27c1241 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE #define CONFIG_SYS_MMC_IMG_LOAD_PART 1
#define CONFIG_DFU_ENV_SETTINGS \ diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 50495bf..cd8115e 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -87,9 +87,6 @@
-#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION - #define CONFIG_MXC_GPIO
#define CONFIG_NET_RETRY_COUNT 100 diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index b08641f..cf9976b 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -108,7 +108,6 @@
/* * No NOR diff --git a/include/configs/x600.h b/include/configs/x600.h index 5e51f65..45bcf49 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -120,7 +120,6 @@
/* Filesystem support (for USB key) */ #define CONFIG_SUPPORT_VFAT -#define CONFIG_DOS_PARTITION
/* diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 04d151b..52ff4b0 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -70,16 +70,11 @@ /************************************************************ * DISK Partition support ************************************************************/ -#define CONFIG_EFI_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION /* Experimental */
#define CONFIG_CMD_PART #ifdef CONFIG_SYS_COREBOOT #define CONFIG_CMD_CBFS #endif -#define CONFIG_PARTITION_UUIDS
/* x86 GPIOs are accessed through a PCI device */ #define CONFIG_INTEL_ICH6_GPIO diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index ae9ab71..8e9b5d7 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -11,7 +11,6 @@
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index cbdef6e..866d082 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -56,11 +56,6 @@
/* Command line configuration */ #define CONFIG_CMD_ENV -#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION -#ifndef CONFIG_SPL_BUILD -# define CONFIG_ISO_PARTITION -#endif #define CONFIG_MP
/* BOOTP options */ diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index f12f8fe..9f3eb52 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -342,7 +342,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_DOS_PARTITION
/* * Command configuration. diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index a355112..55dd365 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -158,9 +158,6 @@ #define CONFIG_PHY1_ADDR 3
#ifdef CONFIG_440EP /* USB */ diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 97dfc0e..3b5c8ae 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -66,7 +66,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_PXA_MMC_GENERIC #define CONFIG_SYS_MMC_BASE 0xF0000000 -#define CONFIG_DOS_PARTITION #endif
/* diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 7038e6b..6df4761 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -91,7 +91,6 @@ #define CONFIG_MXC_USB_PORTSC MXC_EHCI_MODE_SERIAL #define CONFIG_MXC_USB_FLAGS (MXC_EHCI_INTERNAL_PHY | MXC_EHCI_IPPUE_DOWN) #define CONFIG_EHCI_IS_TDI -#define CONFIG_DOS_PARTITION #define CONFIG_SUPPORT_VFAT #endif /* CONFIG_CMD_USB */
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 8524b28..012754e 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -136,7 +136,6 @@ #if defined(CONFIG_ZYNQ_SDHCI) || defined(CONFIG_ZYNQ_USB) # define CONFIG_SUPPORT_VFAT # define CONFIG_FAT_WRITE -# define CONFIG_DOS_PARTITION #endif
#if defined(CONFIG_ZYNQ_I2C0) || defined(CONFIG_ZYNQ_I2C1) diff --git a/include/part.h b/include/part.h index 0979005..243bcfd 100644 --- a/include/part.h +++ b/include/part.h @@ -255,7 +255,7 @@ struct part_driver { #define U_BOOT_PART_TYPE(__name) \ ll_entry_declare(struct part_driver, __name, part_driver)
-#ifdef CONFIG_EFI_PARTITION +#if CONFIG_IS_ENABLED(EFI_PARTITION) #include <part_efi.h> /* disk/part_efi.c */ /** @@ -365,7 +365,7 @@ int gpt_verify_partitions(struct blk_desc *dev_desc, gpt_header *gpt_head, gpt_entry **gpt_pte); #endif
-#ifdef CONFIG_DOS_PARTITION +#if CONFIG_IS_ENABLED(DOS_PARTITION) /** * is_valid_dos_buf() - Ensure that a DOS MBR image is valid * diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 1e3dca4..39e602a 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -251,7 +251,7 @@ static int efi_disk_create_eltorito(struct blk_desc *desc, const char *pdevname) { int disks = 0; -#ifdef CONFIG_ISO_PARTITION +#if CONFIG_IS_ENABLED(ISO_PARTITION) char devname[32] = { 0 }; /* dp->str is u16[32] long */ disk_partition_t info; int part = 1; diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b3ed48b..ee21f4b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -95,7 +95,6 @@ CONFIG_AMCC_DEF_ENV_PPC CONFIG_AMCC_DEF_ENV_PPC_OLD CONFIG_AMCC_DEF_ENV_ROOTPATH CONFIG_AMCORE -CONFIG_AMIGA_PARTITION CONFIG_ANDES_PCU CONFIG_ANDES_PCU_BASE CONFIG_AP325RXA @@ -874,7 +873,6 @@ CONFIG_DMC_DDRTR1 CONFIG_DMC_DDRTR2 CONFIG_DNET_AUTONEG_TIMEOUT CONFIG_DNP5370_EXT_WD_DISABLE -CONFIG_DOS_PARTITION CONFIG_DP_DDR_CTRL CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR CONFIG_DP_DDR_NUM_CTRLS @@ -1010,7 +1008,6 @@ CONFIG_EEPRO100_SROM_WRITE CONFIG_EEPROM_BUS_ADDRESS CONFIG_EEPROM_CHIP_ADDRESS CONFIG_EEPROM_LAYOUT_HELP_STRING -CONFIG_EFI_PARTITION CONFIG_EFLASH_PROTSECTORS CONFIG_EHCI_DESC_BIG_ENDIAN CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -1704,7 +1701,6 @@ CONFIG_IRAM_SIZE CONFIG_IRAM_STACK CONFIG_IRAM_TOP CONFIG_IRDA_BASE -CONFIG_ISO_PARTITION CONFIG_ISP1362_USB CONFIG_IS_BUILTIN CONFIG_IS_ENABLED @@ -3009,7 +3005,6 @@ CONFIG_MACRESET_TIMEOUT CONFIG_MAC_ADDR_IN_EEPROM CONFIG_MAC_ADDR_IN_SPIFLASH CONFIG_MAC_OFFSET -CONFIG_MAC_PARTITION CONFIG_MAKALU CONFIG_MALLOC_F_ADDR CONFIG_MALTA @@ -3386,9 +3381,6 @@ CONFIG_PALMAS_SMPS7_FPWM CONFIG_PALMAS_USB_SS_PWR CONFIG_PANIC_HANG CONFIG_PARAVIRT -CONFIG_PARTITIONS -CONFIG_PARTITION_TYPE_GUID -CONFIG_PARTITION_UUIDS CONFIG_PATA_BFIN CONFIG_PATI CONFIG_PB1000
On Mon, Dec 05, 2016 at 01:01:05PM +0100, Patrick Delaunay wrote:
This converts the following to Kconfig: CONFIG_PARTITIONS CONFIG_MAC_PARTITION CONFIG_DOS_PARTITION CONFIG_ISO_PARTITION CONFIG_AMIGA_PARTITION CONFIG_EFI_PARTITION CONFIG_PARTITION_UUIDS CONFIG_PARTITION_TYPE_GUID
Specific SPL config are added to reduce SPL size for some target and solve compilation issues
CONFIG_SPL_MAC_PARTITION CONFIG_SPL_DOS_PARTITION CONFIG_SPL_ISO_PARTITION CONFIG_SPL_AMIGA_PARTITION CONFIG_SPL_EFI_PARTITION
Associated test are updated to the correct CONFIG (SPL or not) by using macro CONFIG_IS_ENABLED
To update the U-Boot code I use : 0- Resync with savedefconfig /tools/moveconfig.py -s -Cy
1- update defconfig for new SPL option ./tools/moveconfig.py --spl --commit \ PARTITIONS MAC_PARTITION DOS_PARTITION \ ISO_PARTITION AMIGA_PARTITION EFI_PARTITION \ PARTITION_UUIDS PARTITION_TYPE_GUID
then replace CONFIG by CONFIG_SPL in defconfig sed -i "s/CONFIG_\(DOS\|EFI\|ISO\|MAC\|AMIGA\)_PARTITION/CONFIG_SPL_\1_PARTITION/" \ configs/*
2- update defconfig for existing option ./tools/moveconfig.py --commit --yes \ PARTITIONS MAC_PARTITION DOS_PARTITION \ ISO_PARTITION AMIGA_PARTITION EFI_PARTITION \ PARTITION_UUIDS PARTITION_TYPE_GUID
=> squash the 2 modifications
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay73@gmail.com
First, thanks for doing all of this, I think it's just about ready to apply so:
But that said, I'm going to re-run the sync as there's still a few places where we enable $X in the defconfig file as it wasn't setting DISTRO_DEFAULTS before, but is now (am335x* and making EFI_PARTITIONS default y if TEGRA). But I'll fix that up in-place so you don't have to re-submit the giant thing. Thanks!
-- Tom
Hi Tom
I see that your patch is now merged and integrated in v2017.01 (https://patchwork.ozlabs.org/patch/700546/), do you need some re-submit of my giant patch for the next merge windows ? or you can handle it my simple merge ?
Regards
Patrick
-- Tom
Hi Tom
So, I took some attempts at merging this. The problem is that as the changes exist today it's not size-neutral which means that some of the changes aren't quite right. Do you have the time to look at making sure it's size neutral? Thanks!
Subject: Re: [PATCH v3] disk: convert to Kconfig
-- Tom
Hi Tom
windows ?
Hi Tom,
I will take some time (in background) to merge my patch on v2017.01 to be sure it is neutral .
If I have a better result I will push it again on top of v2017.01 next week.
Patrick
-- Tom
Patrick Delaunay
Patrick DELAUNAY
