[U-Boot] [PATCH] SMC91111: Clean up SMC_inx macros on xsengine and xaeniax
This patch fixes the following warnings:
Configuring for xaeniax board... smc91111_eeprom.c: In function 'print_macaddr': smc91111_eeprom.c:278: warning: suggest parentheses around + or - in operand of & smc91111_eeprom.c:281: warning: suggest parentheses around + or - in operand of & ... Configuring for xsengine board... smc91111_eeprom.c: In function 'print_macaddr': smc91111_eeprom.c:278: warning: suggest parentheses around + or - inside shift smc91111_eeprom.c:281: warning: suggest parentheses around + or - inside shift
Signed-off-by: Ben Warren biggerbadderben@gmail.com ---
This replaces the previous 'bad' patch named 'smc91111_eeprom: fix compile warning
drivers/net/smc91111.h | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/smc91111.h b/drivers/net/smc91111.h index bb45241..895c749 100644 --- a/drivers/net/smc91111.h +++ b/drivers/net/smc91111.h @@ -81,10 +81,10 @@ struct smc91111_priv{ #ifdef CONFIG_PXA250
#ifdef CONFIG_XSENGINE -#define SMC_inl(a,r) (*((volatile dword *)((a)->iobase+(r<<1)))) -#define SMC_inw(a,r) (*((volatile word *)((a)->iobase+(r<<1)))) +#define SMC_inl(a,r) (*((volatile dword *)((a)->iobase+((r)<<1)))) +#define SMC_inw(a,r) (*((volatile word *)((a)->iobase+((r)<<1)))) #define SMC_inb(a,p) ({ \ - unsigned int __p = (unsigned int)((a)->iobase + (p<<1)); \ + unsigned int __p = (unsigned int)((a)->iobase + ((p)<<1)); \ unsigned int __v = *(volatile unsigned short *)((__p) & ~2); \ if (__p & 2) __v >>= 8; \ else __v &= 0xff; \ @@ -99,7 +99,7 @@ struct smc91111_priv{ __v; }) #define SMC_inb(a,p) ({ \ unsigned int ___v = SMC_inw((a),(p) & ~1); \ - if (p & 1) ___v >>= 8; \ + if ((p) & 1) ___v >>= 8; \ else ___v &= 0xff; \ ___v; }) #else
Ben Warren
