Fwd: [PATCH] arm64: zynqmp: Support converting pm_cfg_obj.c
Forwarding as I forgot to CC ---------- Forwarded message --------- From: Brandon Maier brandon.maier@rockwellcollins.com Date: Tue, Jun 23, 2020 at 12:08 PM Subject: Re: [PATCH] arm64: zynqmp: Support converting pm_cfg_obj.c To: Luca Ceresoli luca@lucaceresoli.net
On Tue, Jun 23, 2020 at 10:18 AM Luca Ceresoli luca@lucaceresoli.net wrote:
Hi Brandon,
On 22/06/20 22:45, Brandon Maier wrote:
To use CONFIG_ZYNQMP_SPL_PM_CFG_OBJ_FILE, a developer must pull down the U-Boot source and run ./tools/zynqmp_pm_cfg_obj_convert.py to convert their pm_cfg_obj.c into U-Boot's PMU loader format, then feed that file back to U-Boot during build.
Instead, by doing the conversion in U-Boot during the build, we can simplify the developer's build system. And it ensures that if zynqmp_pm_cfg_obj_convert.py is updated, the pm_cfg_obj will stay in sync with U-Boot.
In the workflows I have used so far U-Boot tools are extracted in a different step w.r.t. U-Boot cross-compilation, so I never felt the need for this feature. But I understand this feature can be handy.
I'm trying to get it to work with Buildroot. Buildroot does have a package for uboot-tools, so I could use that to run it. I'd have to move the config and build commands into Buildroot's uboot package. Since the script belongs to U-Boot anyway, it seemed cleaner to integrate it directly into U-Boot so it could be used by other build systems too.
The code looks OK too.
Reviewed-by: Luca Ceresoli luca@lucaceresoli.net
-- Luca
Brandon Maier
