[U-Boot] [PATCH] configs: Remove CONFIG_NET_MULTI from board files
CONFIG_NET_MULTI is not used anymore, so remove it from board files.
Cc: Marek Vasut marek.vasut@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Kumar Gala kumar.gala@freescale.com Cc: Sandeep Paulraj s-paulraj@ti.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/P1010RDB.h | 5 ----- include/configs/PM826.h | 2 -- include/configs/PM828.h | 2 -- include/configs/cam_enc_4xx.h | 1 - include/configs/coreboot.h | 6 ------ include/configs/da850_am18xxevm.h | 1 - include/configs/ecovec.h | 1 - include/configs/efikamx.h | 1 - include/configs/enbw_cmc.h | 1 - include/configs/ethernut5.h | 1 - include/configs/flea3.h | 1 - include/configs/m28evk.h | 1 - include/configs/omap3_evm_common.h | 1 - include/configs/omap3_mvblx.h | 1 - include/configs/p1_p2_rdb_pc.h | 7 ------- include/configs/tam3517-common.h | 1 - 16 files changed, 0 insertions(+), 33 deletions(-)
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index af4609f..a9251b4 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -518,11 +518,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #endif
-#if defined(CONFIG_TSEC_ENET) -#ifndef CONFIG_NET_MULTI -#define CONFIG_NET_MULTI -#endif - #define CONFIG_MII /* MII PHY management */ #define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ #define CONFIG_TSEC1 1 diff --git a/include/configs/PM826.h b/include/configs/PM826.h index f4f9305..cde0fd6 100644 --- a/include/configs/PM826.h +++ b/include/configs/PM826.h @@ -100,11 +100,9 @@ * * if CONFIG_ETHER_ON_SCC is selected, then * - CONFIG_ETHER_INDEX must be set to the channel number (1-4) - * - CONFIG_NET_MULTI must not be defined * * if CONFIG_ETHER_ON_FCC is selected, then * - one or more CONFIG_ETHER_ON_FCCx (x=1,2,3) must also be selected - * - CONFIG_NET_MULTI must be defined * * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. diff --git a/include/configs/PM828.h b/include/configs/PM828.h index 28666d6..74ced5a 100644 --- a/include/configs/PM828.h +++ b/include/configs/PM828.h @@ -100,11 +100,9 @@ * * if CONFIG_ETHER_ON_SCC is selected, then * - CONFIG_ETHER_INDEX must be set to the channel number (1-4) - * - CONFIG_NET_MULTI must not be defined * * if CONFIG_ETHER_ON_FCC is selected, then * - one or more CONFIG_ETHER_ON_FCCx (x=1,2,3) must also be selected - * - CONFIG_NET_MULTI must be defined * * if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be * defined elsewhere (as for the console), or CONFIG_CMD_NET must be unset. diff --git a/include/configs/cam_enc_4xx.h b/include/configs/cam_enc_4xx.h index a21d448..50a967c 100644 --- a/include/configs/cam_enc_4xx.h +++ b/include/configs/cam_enc_4xx.h @@ -68,7 +68,6 @@ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_NET_MULTI #define CONFIG_CMD_MII #define CONFIG_SYS_DCACHE_OFF #define CONFIG_RESET_PHY_R diff --git a/include/configs/coreboot.h b/include/configs/coreboot.h index 348a25b..2c65d74 100644 --- a/include/configs/coreboot.h +++ b/include/configs/coreboot.h @@ -216,10 +216,4 @@ */ #define CONFIG_PCI
-/*----------------------------------------------------------------------- - * Network device support - */ -#define CONFIG_NET_MULTI - - #endif /* __CONFIG_H */ diff --git a/include/configs/da850_am18xxevm.h b/include/configs/da850_am18xxevm.h index 9b7bf1e..6fb3920 100644 --- a/include/configs/da850_am18xxevm.h +++ b/include/configs/da850_am18xxevm.h @@ -125,7 +125,6 @@ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_NET_MULTI #endif
#ifdef CONFIG_USE_NOR diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 2e2a9a7..4549a4c 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -88,7 +88,6 @@ #define CONFIG_SH_I2C_BASE1 0xA4750000
/* Ether */ -#define CONFIG_NET_MULTI 1 #define CONFIG_SH_ETHER 1 #define CONFIG_SH_ETHER_USE_PORT (0) #define CONFIG_SH_ETHER_PHY_ADDR (0x1f) diff --git a/include/configs/efikamx.h b/include/configs/efikamx.h index 522487b..e2f0f74 100644 --- a/include/configs/efikamx.h +++ b/include/configs/efikamx.h @@ -206,7 +206,6 @@ /* USB NET */ #ifdef CONFIG_CMD_NET #define CONFIG_USB_ETHER_ASIX -#define CONFIG_NET_MULTI #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP #endif diff --git a/include/configs/enbw_cmc.h b/include/configs/enbw_cmc.h index c427dc7..5c14379 100644 --- a/include/configs/enbw_cmc.h +++ b/include/configs/enbw_cmc.h @@ -146,7 +146,6 @@ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_NET_MULTI #endif
/* diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index f878665..604d2dd 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -179,7 +179,6 @@ #endif
/* Ethernet */ -#define CONFIG_NET_MULTI #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_MACB #define CONFIG_RMII diff --git a/include/configs/flea3.h b/include/configs/flea3.h index aac3930..649e272 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -113,7 +113,6 @@ /* * Ethernet on SOC (FEC) */ -#define CONFIG_NET_MULTI #define CONFIG_FEC_MXC #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_PHYLIB diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 39c841f..51eb1c1 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -179,7 +179,6 @@ * Ethernet on SOC (FEC) */ #ifdef CONFIG_CMD_NET -#define CONFIG_NET_MULTI #define CONFIG_ETHPRIME "FEC0" #define CONFIG_FEC_MXC #define CONFIG_FEC_MXC_MULTI diff --git a/include/configs/omap3_evm_common.h b/include/configs/omap3_evm_common.h index b256317..4910dda 100644 --- a/include/configs/omap3_evm_common.h +++ b/include/configs/omap3_evm_common.h @@ -248,7 +248,6 @@ #if defined(CONFIG_CMD_NET)
/* Ethernet (SMSC9115 from SMSC9118 family) */ -#define CONFIG_NET_MULTI #define CONFIG_SMC911X #define CONFIG_SMC911X_32_BIT #define CONFIG_SMC911X_BASE 0x2C000000 diff --git a/include/configs/omap3_mvblx.h b/include/configs/omap3_mvblx.h index eb51ea9..0d78529 100644 --- a/include/configs/omap3_mvblx.h +++ b/include/configs/omap3_mvblx.h @@ -272,7 +272,6 @@ *---------------------------------------------------------------------------- */ #if defined(CONFIG_CMD_NET) - #define CONFIG_NET_MULTI #define CONFIG_SMC911X 1 #define CONFIG_SMC911X_32_BIT #define CONFIG_SMC911X_BASE 0x2C000000 diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 8e8fa16..9297dd0 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -630,7 +630,6 @@ #endif #define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */
-#define CONFIG_NET_MULTI #define CONFIG_PCI_PNP /* do pci plug-and-play */ #define CONFIG_E1000 /* Defind e1000 pci Ethernet card*/ #define CONFIG_CMD_PCI @@ -640,12 +639,6 @@ #define CONFIG_DOS_PARTITION #endif /* CONFIG_PCI */
-#if defined(CONFIG_TSEC_ENET) - -#ifndef CONFIG_NET_MULTI -#define CONFIG_NET_MULTI -#endif - #define CONFIG_MII /* MII PHY management */ #define CONFIG_TSEC1 #define CONFIG_TSEC1_NAME "eTSEC1" diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 817d468..6682714 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -238,7 +238,6 @@ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_NET_MULTI
/* Defines for SPL */ #define CONFIG_SPL
Acked-by: Marek Vasut marek.vasut@gmail.com
For efikamx:
Tested-by: Marek Vasut marek.vasut@gmail.com
- if CONFIG_ETHER_ON_SCC is selected, then
- if CONFIG_ETHER_ON_FCC is selected, then
- if CONFIG_ETHER_NONE is defined, then either the ethernet routines must
- Network device support
- Ethernet on SOC (FEC)
*------------------------------------------------------------------------- --- */ #if defined(CONFIG_CMD_NET)
Hello Fabio,
Acked-by: Heiko Schocher hs@denx.de
Tested on the enbw_cmc and cam_enc_4xx board, so:
Tested-by: Heiko Schocher hs@denx.de
Thanks!
bye, Heiko
Acked-by: Kumar Gala galak@kernel.crashing.org
For P1010RDB & p1_p2_rdb_pc.h
- k
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Acked-by: Tom Rini trini@ti.com
For the TI parts.
Applied to u-boot-imx after rebasing on u-boot-arm/master (include/configs/da850_am18xxevm.h was dropped in a recent patch), thanks.
might want to drop it considering it's buggy -mike
Right, I have not seen your comment, thanks. Dropped from u-boot-imx.
Fabio, changes for P1010RDB are buggy - can you post a new version fixing it ?
Thanks, Stefano Babic
NAK: idea: good. actual patch: buggy :(.
you sure this is correct ? looks like you deleted 2 if statements but only 1 endif.
same issue here -mike
Cc: Marek Vasut marek.vasut@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Kumar Gala kumar.gala@freescale.com Cc: Sandeep Paulraj s-paulraj@ti.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Fix P1010RDB and p1_p2_rdb_pc targets include/configs/P1010RDB.h | 4 ---- include/configs/PM826.h | 2 -- include/configs/PM828.h | 2 -- include/configs/cam_enc_4xx.h | 1 - include/configs/coreboot.h | 6 ------ include/configs/da850_am18xxevm.h | 1 - include/configs/ecovec.h | 1 - include/configs/efikamx.h | 1 - include/configs/enbw_cmc.h | 1 - include/configs/ethernut5.h | 1 - include/configs/flea3.h | 1 - include/configs/m28evk.h | 1 - include/configs/omap3_evm_common.h | 1 - include/configs/omap3_mvblx.h | 1 - include/configs/p1_p2_rdb_pc.h | 6 ------ include/configs/tam3517-common.h | 1 - 16 files changed, 0 insertions(+), 31 deletions(-)
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index af4609f..2ee2619 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -519,10 +519,6 @@ extern unsigned long get_sdram_size(void); #endif
/* Ethernet (SMSC9115 from SMSC9118 family) */ -#define CONFIG_NET_MULTI #define CONFIG_SMC911X #define CONFIG_SMC911X_32_BIT #define CONFIG_SMC911X_BASE 0x2C000000 diff --git a/include/configs/omap3_mvblx.h b/include/configs/omap3_mvblx.h index eb51ea9..0d78529 100644 --- a/include/configs/omap3_mvblx.h +++ b/include/configs/omap3_mvblx.h @@ -272,7 +272,6 @@ *---------------------------------------------------------------------------- */ #if defined(CONFIG_CMD_NET) - #define CONFIG_NET_MULTI #define CONFIG_SMC911X 1 #define CONFIG_SMC911X_32_BIT #define CONFIG_SMC911X_BASE 0x2C000000 diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 8e8fa16..b5081b0 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -630,7 +630,6 @@ #endif #define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */
-#define CONFIG_NET_MULTI #define CONFIG_PCI_PNP /* do pci plug-and-play */ #define CONFIG_E1000 /* Defind e1000 pci Ethernet card*/ #define CONFIG_CMD_PCI @@ -641,11 +640,6 @@ #endif /* CONFIG_PCI */
For the TI bits.
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Applied to u-boot-imx, thanks.
participants (7)
Fabio Estevam
Heiko Schocher
Kumar Gala
Mike Frysinger
Stefano Babic
