[PATCH v2 0/3] rockchip: spl: Cache boot source id for later use
This series fixes an issue where /chosen/u-boot,spl-boot-device prop cannot be resolved to the SPI flash node path in spl_perform_fixups() if the affected device was booted from SPI flash.
Changes in v2: - Add patch that sync boot source id enum with bootrom - Add patch that adds missing SPI flash node path for SoCs with DTs having a jedec,spi-nor compatible flash@0 node. - Only cache boot source id that can be resolved to a node path - Make use of synced BROM_BOOTSOURCE_UNKNOWN enum value - Update commit message - Add fixes tag - Collect r-b tag
Jason Zhu (1): rockchip: bootrom: Sync bootsource id enum from bootrom
Jonas Karlman (2): rockchip: spl: Cache boot source id for later use rockchip: spl: Add SPI NOR flash to boot_devices array
arch/arm/include/asm/arch-rockchip/bootrom.h | 3 +++ arch/arm/mach-rockchip/px30/px30.c | 1 + arch/arm/mach-rockchip/rk3288/rk3288.c | 1 + arch/arm/mach-rockchip/rk3308/rk3308.c | 1 + arch/arm/mach-rockchip/rk3368/rk3368.c | 1 + arch/arm/mach-rockchip/rv1126/rv1126.c | 1 + arch/arm/mach-rockchip/spl.c | 14 +++++++++++--- 7 files changed, 19 insertions(+), 3 deletions(-)
Add more bootsource id: 1. BROM_BOOTSOURCE_UNKNOWN 2. BROM_BOOTSOURCE_I2C 3. BROM_BOOTSOURCE_SPI
Signed-off-by: Jason Zhu jason.zhu@rock-chips.com [jonas@kwiboo.se: Update commit message] Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: - New patch --- arch/arm/include/asm/arch-rockchip/bootrom.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/bootrom.h b/arch/arm/include/asm/arch-rockchip/bootrom.h index 4276a0f6811a..ecf3b4e7428c 100644 --- a/arch/arm/include/asm/arch-rockchip/bootrom.h +++ b/arch/arm/include/asm/arch-rockchip/bootrom.h @@ -43,11 +43,14 @@ void back_to_bootrom(enum rockchip_bootrom_cmd brom_cmd); * Boot-device identifiers as used by the BROM */ enum { + BROM_BOOTSOURCE_UNKNOWN = 0, BROM_BOOTSOURCE_NAND = 1, BROM_BOOTSOURCE_EMMC = 2, BROM_BOOTSOURCE_SPINOR = 3, BROM_BOOTSOURCE_SPINAND = 4, BROM_BOOTSOURCE_SD = 5, + BROM_BOOTSOURCE_I2C = 8, + BROM_BOOTSOURCE_SPI = 9, BROM_BOOTSOURCE_USB = 10, BROM_LAST_BOOTSOURCE = BROM_BOOTSOURCE_USB };
- BROM_BOOTSOURCE_UNKNOWN
- BROM_BOOTSOURCE_I2C
- BROM_BOOTSOURCE_SPI
Looking good to me.
Reviewed-by: Dragan Simic dsimic@manjaro.org
v2:
- New patch
- Boot-device identifiers as used by the BROM
*/ enum {
- BROM_BOOTSOURCE_UNKNOWN = 0, BROM_BOOTSOURCE_NAND = 1, BROM_BOOTSOURCE_EMMC = 2, BROM_BOOTSOURCE_SPINOR = 3, BROM_BOOTSOURCE_SPINAND = 4, BROM_BOOTSOURCE_SD = 5,
- BROM_BOOTSOURCE_I2C = 8,
- BROM_BOOTSOURCE_SPI = 9, BROM_BOOTSOURCE_USB = 10, BROM_LAST_BOOTSOURCE = BROM_BOOTSOURCE_USB
Rockchip BROM writes a boot source id at CFG_IRAM_BASE + 0x10, this id indicates from what storage media TPL/SPL was loaded from.
SPL uses this id to determine what device "same-as-spl" represent when determining from where FIT should be loaded. This works as long as the boot_devices array contain a matching id <-> node path entry.
However, SPL typically load a small part of TF-A into SRAM and on RK3399 this overwrites the CFG_IRAM_BASE + 0x10 addr used for boot source id.
For affected devices the u-boot,spl-boot-device would not be set when booting from SPI flash and the flash@0 node was not explicitly listed in the u-boot,spl-boot-order prop.
Here boot source id is 3 before FIT images is loaded, and 0 after:
U-Boot SPL 2024.04-rc4 (Mar 15 2024 - 17:26:19 +0000) board_spl_was_booted_from: brom_bootdevice_id 3 maps to '/spi@ff1d0000/flash@0' Trying to boot from SPI ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK ## Checking hash(es) for Image atf-2 ... sha256+ OK ## Checking hash(es) for Image atf-3 ... sha256+ OK board_spl_was_booted_from: failed to resolve brom_bootdevice_id 0 spl_decode_boot_device: could not find udevice for /mmc@fe330000 spl_decode_boot_device: could not find udevice for /mmc@fe320000 spl_perform_fixups: could not map boot_device to ofpath: -19
Use a static brom_bootsource_id_cache to save the boot source id after an initial read from SRAM to fix this, this allow spl_perform_fixups() to resolve correct boot source path for "same-as-spl" after SPL have loaded TF-A related FIT images into memory.
With this the spl-boot-device prop can correctly be resolved to the SPI flash node in the control FDT:
=> fdt addr ${fdtcontroladdr} Working FDT set to f1ee6710 => fdt list /chosen chosen { u-boot,spl-boot-device = "/spi@ff1d0000/flash@0"; stdout-path = "serial2:1500000n8"; u-boot,spl-boot-order = "same-as-spl", "/mmc@fe330000", "/mmc@fe320000"; };
Fixes: d57e16c7e712 ("rockchip: find U-boot proper boot device by inverting the logic that sets it") Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Only cache boot source id that can be resolved to a node path - Make use of the new BROM_BOOTSOURCE_UNKNOWN enum value - Update commit message - Add fixes tag - Collect r-b tag --- arch/arm/mach-rockchip/spl.c | 14 +++++++++++--- 1 file changed, 11 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index 1586a093fc37..3ce7e792b5a2 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -32,18 +32,26 @@ __weak const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = {
const char *board_spl_was_booted_from(void) { - u32 bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR); + static u32 brom_bootsource_id_cache = BROM_BOOTSOURCE_UNKNOWN; + u32 bootdevice_brom_id; const char *bootdevice_ofpath = NULL;
+ if (brom_bootsource_id_cache != BROM_BOOTSOURCE_UNKNOWN) + bootdevice_brom_id = brom_bootsource_id_cache; + else + bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR); + if (bootdevice_brom_id < ARRAY_SIZE(boot_devices)) bootdevice_ofpath = boot_devices[bootdevice_brom_id];
- if (bootdevice_ofpath) + if (bootdevice_ofpath) { + brom_bootsource_id_cache = bootdevice_brom_id; debug("%s: brom_bootdevice_id %x maps to '%s'\n", __func__, bootdevice_brom_id, bootdevice_ofpath); - else + } else { debug("%s: failed to resolve brom_bootdevice_id %x\n", __func__, bootdevice_brom_id); + }
return bootdevice_ofpath; }
Looking good to me! Thanks for taking the time to implement this version, as a more robust approach.
v2:
- Add fixes tag
- Collect r-b tag
else
- if (bootdevice_ofpath) {
debug("%s: brom_bootdevice_id %x maps to '%s'\n", __func__, bootdevice_brom_id, bootdevice_ofpath);brom_bootsource_id_cache = bootdevice_brom_id;
- else
Add missing boot source id <-> device tree node path mapping for SPI NOR flash on PX30, RK3288, RK3308, RK3368 and RV1126.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: - New patch --- arch/arm/mach-rockchip/px30/px30.c | 1 + arch/arm/mach-rockchip/rk3288/rk3288.c | 1 + arch/arm/mach-rockchip/rk3308/rk3308.c | 1 + arch/arm/mach-rockchip/rk3368/rk3368.c | 1 + arch/arm/mach-rockchip/rv1126/rv1126.c | 1 + 5 files changed, 5 insertions(+)
diff --git a/arch/arm/mach-rockchip/px30/px30.c b/arch/arm/mach-rockchip/px30/px30.c index b4f655fa4b3e..2ec3289d75b7 100644 --- a/arch/arm/mach-rockchip/px30/px30.c +++ b/arch/arm/mach-rockchip/px30/px30.c @@ -19,6 +19,7 @@
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_EMMC] = "/mmc@ff390000", + [BROM_BOOTSOURCE_SPINOR] = "/spi@ff3a0000/flash@0", [BROM_BOOTSOURCE_SD] = "/mmc@ff370000", };
diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index c77c56c1dab5..70cf50029121 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -28,6 +28,7 @@ DECLARE_GLOBAL_DATA_PTR;
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_EMMC] = "/mmc@ff0f0000", + [BROM_BOOTSOURCE_SPINOR] = "/spi@ff130000/flash@0", [BROM_BOOTSOURCE_SD] = "/mmc@ff0c0000", };
diff --git a/arch/arm/mach-rockchip/rk3308/rk3308.c b/arch/arm/mach-rockchip/rk3308/rk3308.c index 27a748327e31..b3ffabc5449a 100644 --- a/arch/arm/mach-rockchip/rk3308/rk3308.c +++ b/arch/arm/mach-rockchip/rk3308/rk3308.c @@ -141,6 +141,7 @@ enum {
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_EMMC] = "/mmc@ff490000", + [BROM_BOOTSOURCE_SPINOR] = "/spi@ff4c0000/flash@0", [BROM_BOOTSOURCE_SD] = "/mmc@ff480000", };
diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index 651ba1090206..8f5ca1dfa7c9 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -55,6 +55,7 @@ struct mm_region *mem_map = rk3368_mem_map;
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_EMMC] = "/mmc@ff0f0000", + [BROM_BOOTSOURCE_SPINOR] = "/spi@ff120000/flash@0", [BROM_BOOTSOURCE_SD] = "/mmc@ff0c0000", };
diff --git a/arch/arm/mach-rockchip/rv1126/rv1126.c b/arch/arm/mach-rockchip/rv1126/rv1126.c index 8589c46f10aa..40eb9eb7b196 100644 --- a/arch/arm/mach-rockchip/rv1126/rv1126.c +++ b/arch/arm/mach-rockchip/rv1126/rv1126.c @@ -15,6 +15,7 @@
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_EMMC] = "/mmc@ffc50000", + [BROM_BOOTSOURCE_SPINOR] = "/spi@ffc90000/flash@0", [BROM_BOOTSOURCE_SD] = "/mmc@ffc60000", };
Hello Jonas,
Please see my comments below.
v2:
- New patch
- [BROM_BOOTSOURCE_SPINOR] = "/spi@ff3a0000/flash@0",
AFAICT, no PX30-based board contains an SPI chip, but making this future-proof perhaps shouldn't hurt.
- [BROM_BOOTSOURCE_SPINOR] = "/spi@ff130000/flash@0",
Using spi2 for a flash chip applies to some RK3288-based boards, but AFAICT not to all of them. For example, arch/arm/dts/rk3288-evb.dtsi uses spi0 for a flash chip, which in turn translates to /spi@ff110000/flash@0. The same also applies to arch/arm/dts/rk3288-firefly.dtsi, for example.
- [BROM_BOOTSOURCE_SPINOR] = "/spi@ff4c0000/flash@0",
AFAICT, no RK3308-based board contains an SPI chip, and I'm not really sure where does /spi@ff4c0000/flash@0 come from.
- [BROM_BOOTSOURCE_SPINOR] = "/spi@ff120000/flash@0",
This is fine.
- [BROM_BOOTSOURCE_SPINOR] = "/spi@ffc90000/flash@0",
This is also fine.
Hi Dragan,
On 2024-03-24 17:52, Dragan Simic wrote:
Hello Jonas,
v2:
- New patch
The rk3326-odroid-go2 variant of PX30 has a jedec,spi-nor node.
The RK3288 TRM explicitly mention that it can boot from SPI2 CS0.
Also I can only find jedec,spi-nor reference in rk3288-phycore-som.dtsi and rk3288-veyron.dtsi, nothing in rk3288-evb.dtsi or rk3288-firefly.dtsi.
RK3308 TRM mention that it can boot from the SFC. And yes there is no upstream board that currently have a jedec,spi-nor node, it however have the sfc (spi@ff4c0000) node so this adds correct node path.
Regards, Jonas
This is fine.
This is also fine.
v2:
- New patch
Ah, I see, I missed that. Thanks for the clarification.
Oh, I see now, you're right. I've checked the Firefly-RK3288 schematic and it just exposes the spi0 interface on one of its expansion headers.
Hmm, I see no sfc node in any of the arch/arm/dts/rk3308* files? Maybe I'm missing something, but there's also no "ff4c0000" string in the entire arch/arm/dts directory.
v2:
- New patch
The rk3308 DTs in U-Boot is very outdated so the sfc node cannot be found in current master branch.
The sfc node is part of linux upstream DT, should also match in dts/upstream in next branch and after the rk3308 DT sync series [1].
rockchip: rk3308: Sync DT with linux v6.8 and update defconfigs: [1] https://patchwork.ozlabs.org/cover/1912830/
Regards, Jonas
All good, thanks for explaining it further. Please add
Dragan Simic
Jonas Karlman
