[U-Boot] [PATCH] armv8: fsl-layerscape: don't reconfigure QSPI clock when booting from QSPI
It has set the qspi_cfg register earlier through PBI when booting from QSPI. We'd better not change it.
Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 213ce3a..bf04742 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -240,7 +240,7 @@ void fsl_lsch2_early_init_f(void) init_early_memctl_regs(); /* tighten IFC timing */ #endif
-#ifdef CONFIG_FSL_QSPI +#if defined(CONFIG_FSL_QSPI) && !defined(CONFIG_QSPI_BOOT) out_be32(&scfg->qspi_cfg, SCFG_QSPI_CLKSEL); #endif /* Make SEC reads and writes snoopable */
Minor change in subject and commit message.
Applied to u-boot-fsl-qoriq master. Awaiting upstream.
Thanks.
York
Gong Qianyu
York Sun
