[PATCH] Remove LYNX KDI remainders
The last board that used to set CONFIG_LYNXKDI has been removed in commit 242836a893ae ("powerpc: ppc4xx: remove pcs440ep support"), doc/README.lynxkdi only talks about a MPC8260 board being supported, and the mpc8260 support has been removed four years ago in commit 2eb48ff7a210d ("powerpc, 8260: remove support for mpc8260") already, and common/lynxkdi.c only consists of an "#error" statement these days, so it seems like the LYNX KDI code is dead code nowadays. Let's remove it now.
Signed-off-by: Thomas Huth thuth@redhat.com --- common/Makefile | 1 - common/bootm_os.c | 25 ---------------- common/image.c | 2 +- common/lynxkdi.c | 23 --------------- doc/README.lynxkdi | 57 ------------------------------------ include/bootm.h | 1 - include/lynxkdi.h | 24 --------------- scripts/config_whitelist.txt | 1 - 8 files changed, 1 insertion(+), 133 deletions(-) delete mode 100644 common/lynxkdi.c delete mode 100644 doc/README.lynxkdi delete mode 100644 include/lynxkdi.h
diff --git a/common/Makefile b/common/Makefile index e7839027b6..44baf04572 100644 --- a/common/Makefile +++ b/common/Makefile @@ -50,7 +50,6 @@ obj-$(CONFIG_LCD) += lcd.o lcd_console.o endif obj-$(CONFIG_LCD_ROTATION) += lcd_console_rotation.o obj-$(CONFIG_LCD_DT_SIMPLEFB) += lcd_simplefb.o -obj-$(CONFIG_LYNXKDI) += lynxkdi.o obj-$(CONFIG_MENU) += menu.o obj-$(CONFIG_UPDATE_COMMON) += update.o obj-$(CONFIG_USB_KEYBOARD) += usb_kbd.o diff --git a/common/bootm_os.c b/common/bootm_os.c index 39623f9126..e635c72709 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -138,28 +138,6 @@ static int do_bootm_netbsd(int flag, int argc, char *const argv[], } #endif /* CONFIG_BOOTM_NETBSD*/
-#ifdef CONFIG_LYNXKDI -static int do_bootm_lynxkdi(int flag, int argc, char *const argv[], - bootm_headers_t *images) -{ - image_header_t *hdr = &images->legacy_hdr_os_copy; - - if (flag != BOOTM_STATE_OS_GO) - return 0; - -#if defined(CONFIG_FIT) - if (!images->legacy_hdr_valid) { - fit_unsupported_reset("Lynx"); - return 1; - } -#endif - - lynxkdi_boot((image_header_t *)hdr); - - return 1; -} -#endif /* CONFIG_LYNXKDI */ - #ifdef CONFIG_BOOTM_RTEMS static int do_bootm_rtems(int flag, int argc, char *const argv[], bootm_headers_t *images) @@ -570,9 +548,6 @@ static boot_os_fn *boot_os[] = { #ifdef CONFIG_BOOTM_NETBSD [IH_OS_NETBSD] = do_bootm_netbsd, #endif -#ifdef CONFIG_LYNXKDI - [IH_OS_LYNXOS] = do_bootm_lynxkdi, -#endif #ifdef CONFIG_BOOTM_RTEMS [IH_OS_RTEMS] = do_bootm_rtems, #endif diff --git a/common/image.c b/common/image.c index 3fa60b5827..992e72991d 100644 --- a/common/image.c +++ b/common/image.c @@ -106,7 +106,7 @@ static const table_entry_t uimage_os[] = { { IH_OS_INVALID, "invalid", "Invalid OS", }, { IH_OS_ARM_TRUSTED_FIRMWARE, "arm-trusted-firmware", "ARM Trusted Firmware" }, { IH_OS_LINUX, "linux", "Linux", }, -#if defined(CONFIG_LYNXKDI) || defined(USE_HOSTCC) +#if defined(USE_HOSTCC) { IH_OS_LYNXOS, "lynxos", "LynxOS", }, #endif { IH_OS_NETBSD, "netbsd", "NetBSD", }, diff --git a/common/lynxkdi.c b/common/lynxkdi.c deleted file mode 100644 index 1c8e122c32..0000000000 --- a/common/lynxkdi.c +++ /dev/null @@ -1,23 +0,0 @@ -/* - * Copyright (c) Orbacom Systems, Inc <www.orbacom.com> - * All rights reserved. - * - * Redistribution and use in source and binary forms are freely - * permitted provided that the above copyright notice and this - * paragraph and the following disclaimer are duplicated in all - * such forms. - * - * This software is provided "AS IS" and without any express or - * implied warranties, including, without limitation, the implied - * warranties of merchantability and fitness for a particular - * purpose. - */ - -#include <common.h> -#include <asm/processor.h> -#include <image.h> -#include <net.h> - -#include <lynxkdi.h> - -#error "Lynx KDI support not implemented for configured CPU" diff --git a/doc/README.lynxkdi b/doc/README.lynxkdi deleted file mode 100644 index 076f01862a..0000000000 --- a/doc/README.lynxkdi +++ /dev/null @@ -1,57 +0,0 @@ - LYNX KDI SUPPORT - - Last Update: July 20, 2003 -======================================================================= - -This file describes support for LynuxWorks KDI within U-Boot. Support -is enabled by defining CONFIG_LYNXKDI. - - -LYNXOS AND BLUECAT SUPPORTED -============================ -Both LynxOS and BlueCat linux KDIs are supported. The implementation -automatically detects which is being booted. When you use mkimage -you should specify "lynxos" for both (see target-specific notes). - - -SUPPORTED ARCHITECTURE/TARGETS -============================== -The following targets have been tested: - --PowerPC MPC8260ADS - - -FILES TO LOOK AT -================ -include/lynxkdi.h -defines a simple struct passed to a kdi. -common/lynxkdi.c -implements the call to the kdi. -common/cmd_bootm.c -top-level command implementation ("bootm"). - - -==================================================================== -TARGET SPECIFIC NOTES -==================================================================== - -MPC8260ADS -=========== -The default LynxOS and BlueCat implementations require some -modifications to the config file. - -Edit include/configs/MPC8260ADS.h to use the following: - -#define CONFIG_SYS_IMMR 0xFA200000 -#define CONFIG_SYS_BCSR 0xFA100000 -#define CONFIG_SYS_BR1_PRELIM 0xFA101801 - -When creating a LynxOS or BlueCat u-boot image using mkimage, -you must specify the following: - -Both: -A ppc -O lynxos -T kernel -C none -LynxOS: -a 0x00004000 -e 0x00004020 -BlueCat: -a 0x00500000 -e 0x00507000 - -To pass the MAC address to BlueCat you should define the -"fcc2_ether_addr" parameter in the "bootargs" environment -variable. E.g.: - -==> setenv bootargs fcc2_ether_addr=00:11:22:33:44:55:66 diff --git a/include/bootm.h b/include/bootm.h index 7f88ec718b..48fc668cf3 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -39,7 +39,6 @@ extern boot_os_fn do_bootm_linux; extern boot_os_fn do_bootm_vxworks;
int do_bootelf(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -void lynxkdi_boot(image_header_t *hdr);
boot_os_fn *bootm_os_get_boot_func(int os);
diff --git a/include/lynxkdi.h b/include/lynxkdi.h deleted file mode 100644 index 38640277b2..0000000000 --- a/include/lynxkdi.h +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2003 - * Orbacom Systems, Inc. - */ - -#ifndef __LYNXKDI_H__ -#define __LYNXKDI_H__ - - -/* Boot parameter struct passed to kernel - */ -typedef struct lynxos_bootparms_t { - uint8_t rsvd1[2]; /* Reserved */ - uint8_t ethaddr[6]; /* Ethernet address */ - uint16_t flags; /* Boot flags */ - uint32_t rate; /* System frequency */ - uint32_t clock_ref; /* Time reference */ - uint32_t dramsz; /* DRAM size */ - uint32_t rsvd2; /* Reserved */ -} lynxos_bootparms_t; - - -#endif /* __LYNXKDI_H__ */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 022a27288c..50a9e9d20c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -742,7 +742,6 @@ CONFIG_LQ038J7DH53 CONFIG_LS102XA_STREAM_ID CONFIG_LSCHLV2 CONFIG_LSXHL -CONFIG_LYNXKDI CONFIG_M41T94_SPI_CS CONFIG_M520x CONFIG_M5301x
return 1;
-#endif
- return 1;
By the way, does anybody know whether LynxOS is still used with u-boot? I was just looking for the other spots that use the IH_OS_LYNXOS constant, and it seems to me that this is pretty much unused now, especially after removing the lynxkdi stuff... So I guess this line here could be removed completely, too?
Thomas
- Copyright (c) Orbacom Systems, Inc <www.orbacom.com>
- All rights reserved.
- Redistribution and use in source and binary forms are freely
- permitted provided that the above copyright notice and this
- paragraph and the following disclaimer are duplicated in all
- such forms.
- This software is provided "AS IS" and without any express or
- implied warranties, including, without limitation, the implied
- warranties of merchantability and fitness for a particular
- purpose.
LYNX KDI SUPPORT
-FILES TO LOOK AT
-MPC8260ADS
- (C) Copyright 2003
- Orbacom Systems, Inc.
diff --git a/common/Makefile b/common/Makefile index e7839027b6..44baf04572 100644 --- a/common/Makefile +++ b/common/Makefile @@ -50,7 +50,6 @@ obj-$(CONFIG_LCD) += lcd.o lcd_console.o endif obj-$(CONFIG_LCD_ROTATION) += lcd_console_rotation.o obj-$(CONFIG_LCD_DT_SIMPLEFB) += lcd_simplefb.o -obj-$(CONFIG_LYNXKDI) += lynxkdi.o obj-$(CONFIG_MENU) += menu.o obj-$(CONFIG_UPDATE_COMMON) += update.o obj-$(CONFIG_USB_KEYBOARD) += usb_kbd.o diff --git a/common/bootm_os.c b/common/bootm_os.c index 39623f9126..e635c72709 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -138,28 +138,6 @@ static int do_bootm_netbsd(int flag, int argc, char *const argv[], } #endif /* CONFIG_BOOTM_NETBSD*/ -#ifdef CONFIG_LYNXKDI -static int do_bootm_lynxkdi(int flag, int argc, char *const argv[], - bootm_headers_t *images) -{ - image_header_t *hdr = &images->legacy_hdr_os_copy;
I have no idea, sorry. It might very well be the case, that it's completely unused since quite a few years.
Please go ahead. And Cc some people that did contribute to the LynxOS stuff over the time, so they might intervene.
Thanks, Stefan
Thomas
- such forms.
- purpose.
-FILES TO LOOK AT
-MPC8260ADS
-==> setenv bootargs fcc2_ether_addr=00:11:22:33:44:55:66 diff --git a/include/bootm.h b/include/bootm.h index 7f88ec718b..48fc668cf3 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -39,7 +39,6 @@ extern boot_os_fn do_bootm_linux; extern boot_os_fn do_bootm_vxworks; int do_bootelf(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -void lynxkdi_boot(image_header_t *hdr); boot_os_fn *bootm_os_get_boot_func(int os); diff --git a/include/lynxkdi.h b/include/lynxkdi.h deleted file mode 100644 index 38640277b2..0000000000 --- a/include/lynxkdi.h +++ /dev/null @@ -1,24 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/*
Viele Grüße, Stefan Roese
Stefan Roese
Thomas Huth
