[PATCH v6 1/3] dt-bindings: mtd: partitions: Add binman compatible
Add a compatible string for binman, so we can extend fixed-partitions in various ways.
(no changes since v5)
Changes in v5: - Add #address/size-cells and parternProperties - Drop $ref to fixed-partitions.yaml - Drop 'select: false'
Changes in v4: - Change subject line
Changes in v3: - Drop fixed-partition additional compatible string - Drop fixed-partitions from the example - Mention use of compatible instead of label
Changes in v2: - Drop mention of 'enhanced features' in fixed-partitions.yaml - Mention Binman input and output properties - Use plain partition@xxx for the node name
.../bindings/mtd/partitions/binman.yaml | 68 +++++++++++++++++++ .../bindings/mtd/partitions/partitions.yaml | 1 + MAINTAINERS | 5 ++ 3 files changed, 74 insertions(+) create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman.yaml
diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml new file mode 100644 index 000000000000..329217550a98 --- /dev/null +++ b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml @@ -0,0 +1,68 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +# Copyright 2023 Google LLC + +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/mtd/partitions/binman.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Binman firmware layout + +maintainers: + - Simon Glass sjg@chromium.org + +description: | + The binman node provides a layout for firmware, used when packaging firmware + from multiple projects. It is based on fixed-partitions, with some + extensions, but uses 'compatible' to indicate the contents of the node, to + avoid perturbing or confusing existing installations which use 'label' for a + particular purpose. + + Binman supports properties used as inputs to the firmware-packaging process, + such as those which control alignment of partitions. This binding addresses + these 'input' properties. For example, it is common for the 'reg' property + (an 'output' property) to be set by Binman, based on the alignment requested + in the input. + + Once processing is complete, input properties have mostly served their + purpose, at least until the firmware is repacked later, e.g. due to a + firmware update. The 'fixed-partitions' binding should provide enough + information to read the firmware at runtime, including decompression if + needed. + + Documentation for Binman is available at: + + https://u-boot.readthedocs.io/en/latest/develop/package/binman.html + + with the current image-description format at: + + https://u-boot.readthedocs.io/en/latest/develop/package/binman.html#image-de... + +properties: + compatible: + const: binman + + "#address-cells": + const: 1 + + "#size-cells": + const: 1 + +patternProperties: + "^partition(-.+|@[0-9a-f]+)$": + $ref: partition.yaml + +additionalProperties: false + +examples: + - | + partitions { + compatible = "binman"; + #address-cells = <1>; + #size-cells = <1>; + + partition@100000 { + label = "u-boot"; + reg = <0x100000 0xf00000>; + }; + }; diff --git a/Documentation/devicetree/bindings/mtd/partitions/partitions.yaml b/Documentation/devicetree/bindings/mtd/partitions/partitions.yaml index 1dda2c80747b..849fd15d085c 100644 --- a/Documentation/devicetree/bindings/mtd/partitions/partitions.yaml +++ b/Documentation/devicetree/bindings/mtd/partitions/partitions.yaml @@ -15,6 +15,7 @@ maintainers:
oneOf: - $ref: arm,arm-firmware-suite.yaml + - $ref: binman.yaml - $ref: brcm,bcm4908-partitions.yaml - $ref: brcm,bcm947xx-cfe-partitions.yaml - $ref: fixed-partitions.yaml diff --git a/MAINTAINERS b/MAINTAINERS index b294edaf5698..8704eefe6e2a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -3550,6 +3550,11 @@ F: Documentation/filesystems/bfs.rst F: fs/bfs/ F: include/uapi/linux/bfs_fs.h
+BINMAN +M: Simon Glass sjg@chromium.org +S: Supported +F: Documentation/devicetree/bindings/mtd/partitions/binman* + BITMAP API M: Yury Norov yury.norov@gmail.com R: Andy Shevchenko andriy.shevchenko@linux.intel.com
Add two compatible for binman entries, as a starting point for the schema.
Note that, after discussion on v2, we decided to keep the existing meaning of label so as not to require changes to existing userspace software when moving to use binman nodes to specify the firmware layout.
Changes in v5: - Add mention of why 'binman' is the vendor - Drop 'select: false' - Tidy up the compatible setings - Use 'tfa-bl31' instead of 'atf-bl31'
Changes in v4: - Correct selection of multiple compatible strings
Changes in v3: - Drop fixed-partitions from the example - Use compatible instead of label
Changes in v2: - Use plain partition@xxx for the node name
.../mtd/partitions/binman-partition.yaml | 54 +++++++++++++++++++ 1 file changed, 54 insertions(+) create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml
diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml new file mode 100644 index 000000000000..83222ac9aa78 --- /dev/null +++ b/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml @@ -0,0 +1,54 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +# Copyright 2023 Google LLC + +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/mtd/partitions/binman-partition.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: Binman partition + +maintainers: + - Simon Glass sjg@chromium.org + +description: | + This corresponds to a binman 'entry'. It is a single partition which holds + data of a defined type. + + The vendor is specified as binman since there are quite a number + of binman-specific entry types, such as section, fill and files, + to be added later. + +allOf: + - $ref: /schemas/mtd/partitions/partition.yaml# + +properties: + compatible: + enum: + - binman,entry # generic binman entry + - u-boot # u-boot.bin from U-Boot project + - tfa-bl31 # bl31.bin or bl31.elf from TF-A project + + reg: + minItems: 1 + maxItems: 2 + +additionalProperties: false + +examples: + - | + partitions { + compatible = "binman"; + #address-cells = <1>; + #size-cells = <1>; + + partition@100000 { + compatible = "u-boot"; + reg = <0x100000 0xf00000>; + }; + + partition@200000 { + compatible = "tfa-bl31"; + reg = <0x200000 0x100000>; + }; + };
Add three properties for controlling alignment of partitions, aka 'entries' in binman.
For now there is no explicit mention of hierarchy, so a 'section' is just the 'binman' node.
These new properties are inputs to the packaging process, but are also needed if the firmware is repacked, to ensure that alignment constraints are not violated. Therefore they are provided as part of the schema.
Changes in v6: - Correct schema-validation errors missed due to older dt-schema (enum fix and reg addition)
Changes in v5: - Add value ranges - Consistently mention alignment must be power-of-2 - Mention that alignment refers to bytes
Changes in v2: - Fix 'a' typo in commit message
diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml index 83222ac9aa78..2bc80c24bb9b 100644 --- a/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml +++ b/Documentation/devicetree/bindings/mtd/partitions/binman-partition.yaml @@ -33,6 +33,57 @@ properties: minItems: 1 maxItems: 2
+ align: + $ref: /schemas/types.yaml#/definitions/uint32 + minimum: 1 + maximum: 0x80000000 + multipleOf: 2 + description: + This sets the alignment of the entry in bytes. + + The entry offset is adjusted so that the entry starts on an aligned + boundary within the containing section or image. For example ‘align = + <16>’ means that the entry will start on a 16-byte boundary. This may + mean that padding is added before the entry. The padding is part of + the containing section but is not included in the entry, meaning that + an empty space may be created before the entry starts. Alignment + must be a power of 2. If ‘align’ is not provided, no alignment is + performed. + + align-size: + $ref: /schemas/types.yaml#/definitions/uint32 + minimum: 1 + maximum: 0x80000000 + multipleOf: 2 + description: + This sets the alignment of the entry size in bytes. It must be a power + of 2. + + For example, to ensure that the size of an entry is a multiple of 64 + bytes, set this to 64. While this does not affect the contents of the + entry within binman itself (the padding is performed only when its + parent section is assembled), the end result is that the entry ends + with the padding bytes, so may grow. If ‘align-size’ is not provided, + no alignment is performed. + + align-end: + $ref: /schemas/types.yaml#/definitions/uint32 + minimum: 1 + maximum: 0x80000000 + multipleOf: 2 + description: + This sets the alignment (in bytes) of the end of an entry with respect + to the containing section. It must be a power of 2. + + Some entries require that they end on an alignment boundary, + regardless of where they start. This does not move the start of the + entry, so the contents of the entry will still start at the beginning. + But there may be padding at the end. While this does not affect the + contents of the entry within binman itself (the padding is performed + only when its parent section is assembled), the end result is that the + entry ends with the padding bytes, so may grow. If ‘align-end’ is not + provided, no alignment is performed. + additionalProperties: false
examples: @@ -45,10 +96,13 @@ examples: partition@100000 { compatible = "u-boot"; reg = <0x100000 0xf00000>; + align-size = <0x1000>; + align-end = <0x10000>; };
partition@200000 { compatible = "tfa-bl31"; reg = <0x200000 0x100000>; + align = <0x4000>; }; };
Is there any movement on this series, please?
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+maintainers:
+description: |
- The binman node provides a layout for firmware, used when packaging firmware
- from multiple projects. It is based on fixed-partitions, with some
- extensions, but uses 'compatible' to indicate the contents of the node, to
- avoid perturbing or confusing existing installations which use 'label' for a
- particular purpose.
- Binman supports properties used as inputs to the firmware-packaging process,
- such as those which control alignment of partitions. This binding addresses
- these 'input' properties. For example, it is common for the 'reg' property
- (an 'output' property) to be set by Binman, based on the alignment requested
- in the input.
- Once processing is complete, input properties have mostly served their
- purpose, at least until the firmware is repacked later, e.g. due to a
- firmware update. The 'fixed-partitions' binding should provide enough
- information to read the firmware at runtime, including decompression if
- needed.
How is this going to work exactly? binman reads these nodes and then writes out 'fixed-partitions' nodes. But then you've lost the binman specifc parts needed for repacking.
Rob
Hi Rob,
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+maintainers:
+description: |
- in the input.
- needed.
No, they are the same node. I do want the extra information to stick around. So long as it is compatible with fixed-partition as well, this should work OK.
Regards, SImon
On Fri, Dec 8, 2023 at 11:47 AM Simon Glass sjg@chromium.org wrote:
Hi Rob,
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+maintainers:
+description: |
- in the input.
- needed.
How can it be both? The partitions node compatible can be either 'fixed-partitions' or 'binman'.
In the partition nodes, 'align' for example is allowed for a binman partition but not a fixed-partition.
Note that the schema may not actually warn on extra properties ATM because there are some issues with the schema structure. Since there can be nested partittions, that complicates matters. It's been on my todo list to fix.
Rob
Hi Rob,
Hi Rob,
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+maintainers:
+description: |
- in the input.
- needed.
Can we not allow it to be both? I have tried to adjust things in response to feedback but perhaps the feedback was leading me down the wrong path?
But if not, then whatever works is fine for now. I just want to make some progress on this very, very old series.
OK.
On Fri, Dec 08, 2023 at 03:58:10PM -0700, Simon Glass wrote:
Hi Rob,
Hi Rob,
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+maintainers:
+description: |
- in the input.
- needed.
Sure, but then the schema has to and that means extending fixed-partitions.
Rob
Hi Rob,
Hi Rob,
Hi Rob,
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+maintainers:
+description: |
- in the input.
- needed.
Can we cross that bridge later? There might be resistance to it. I'm not sure. For now, perhaps just a binman compatible works well enough to make progress.
Hi Rob,
On Thu, Dec 14, 2023 at 2:09 PM Simon Glass sjg@chromium.org wrote:
Hi Rob,
Hi Rob,
Hi Rob,
On Thu, Nov 16, 2023 at 10:28:50AM -0700, Simon Glass wrote: > Add a compatible string for binman, so we can extend fixed-partitions > in various ways. > > Signed-off-by: Simon Glass sjg@chromium.org > --- > > (no changes since v5) > > Changes in v5: > - Add #address/size-cells and parternProperties > - Drop $ref to fixed-partitions.yaml > - Drop 'select: false' > > Changes in v4: > - Change subject line > > Changes in v3: > - Drop fixed-partition additional compatible string > - Drop fixed-partitions from the example > - Mention use of compatible instead of label > > Changes in v2: > - Drop mention of 'enhanced features' in fixed-partitions.yaml > - Mention Binman input and output properties > - Use plain partition@xxx for the node name > > .../bindings/mtd/partitions/binman.yaml | 68 +++++++++++++++++++ > .../bindings/mtd/partitions/partitions.yaml | 1 + > MAINTAINERS | 5 ++ > 3 files changed, 74 insertions(+) > create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > new file mode 100644 > index 000000000000..329217550a98 > --- /dev/null > +++ b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > @@ -0,0 +1,68 @@ > +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) > +# Copyright 2023 Google LLC > + > +%YAML 1.2 > +--- > +$id: http://devicetree.org/schemas/mtd/partitions/binman.yaml# > +$schema: http://devicetree.org/meta-schemas/core.yaml# > + > +title: Binman firmware layout > + > +maintainers: > + - Simon Glass sjg@chromium.org > + > +description: | > + The binman node provides a layout for firmware, used when packaging firmware > + from multiple projects. It is based on fixed-partitions, with some > + extensions, but uses 'compatible' to indicate the contents of the node, to > + avoid perturbing or confusing existing installations which use 'label' for a > + particular purpose. > + > + Binman supports properties used as inputs to the firmware-packaging process, > + such as those which control alignment of partitions. This binding addresses > + these 'input' properties. For example, it is common for the 'reg' property > + (an 'output' property) to be set by Binman, based on the alignment requested > + in the input. > + > + Once processing is complete, input properties have mostly served their > + purpose, at least until the firmware is repacked later, e.g. due to a > + firmware update. The 'fixed-partitions' binding should provide enough > + information to read the firmware at runtime, including decompression if > + needed.
Is there any way to make progress on this? I would like to have software which doesn't understand the binman compatible to at least be able to understand the fixed-partition compatible. Is that acceptable? If not, what is?
In any case, please can you help with this?
On Thu, Jan 4, 2024 at 3:54 PM Simon Glass sjg@chromium.org wrote:
Hi Rob,
Hi Rob,
Hi Rob,
Hi Rob,
On Fri, 8 Dec 2023 at 08:00, Rob Herring robh@kernel.org wrote: > > On Thu, Nov 16, 2023 at 10:28:50AM -0700, Simon Glass wrote: > > Add a compatible string for binman, so we can extend fixed-partitions > > in various ways. > > > > Signed-off-by: Simon Glass sjg@chromium.org > > --- > > > > (no changes since v5) > > > > Changes in v5: > > - Add #address/size-cells and parternProperties > > - Drop $ref to fixed-partitions.yaml > > - Drop 'select: false' > > > > Changes in v4: > > - Change subject line > > > > Changes in v3: > > - Drop fixed-partition additional compatible string > > - Drop fixed-partitions from the example > > - Mention use of compatible instead of label > > > > Changes in v2: > > - Drop mention of 'enhanced features' in fixed-partitions.yaml > > - Mention Binman input and output properties > > - Use plain partition@xxx for the node name > > > > .../bindings/mtd/partitions/binman.yaml | 68 +++++++++++++++++++ > > .../bindings/mtd/partitions/partitions.yaml | 1 + > > MAINTAINERS | 5 ++ > > 3 files changed, 74 insertions(+) > > create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > > diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > new file mode 100644 > > index 000000000000..329217550a98 > > --- /dev/null > > +++ b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > @@ -0,0 +1,68 @@ > > +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) > > +# Copyright 2023 Google LLC > > + > > +%YAML 1.2 > > +--- > > +$id: http://devicetree.org/schemas/mtd/partitions/binman.yaml# > > +$schema: http://devicetree.org/meta-schemas/core.yaml# > > + > > +title: Binman firmware layout > > + > > +maintainers: > > + - Simon Glass sjg@chromium.org > > + > > +description: | > > + The binman node provides a layout for firmware, used when packaging firmware > > + from multiple projects. It is based on fixed-partitions, with some > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > + avoid perturbing or confusing existing installations which use 'label' for a > > + particular purpose. > > + > > + Binman supports properties used as inputs to the firmware-packaging process, > > + such as those which control alignment of partitions. This binding addresses > > + these 'input' properties. For example, it is common for the 'reg' property > > + (an 'output' property) to be set by Binman, based on the alignment requested > > + in the input. > > + > > + Once processing is complete, input properties have mostly served their > > + purpose, at least until the firmware is repacked later, e.g. due to a > > + firmware update. The 'fixed-partitions' binding should provide enough > > + information to read the firmware at runtime, including decompression if > > + needed. > > How is this going to work exactly? binman reads these nodes and then > writes out 'fixed-partitions' nodes. But then you've lost the binman > specifc parts needed for repacking.
There's only 2 ways that it can work. Either binman writes out fixed-partition nodes dropping/replacing anything only defined for binman or fixed-partition is extended to include what binman needs.
Rob
Hi Rob,
Hi Rob,
Hi Rob,
Hi Rob,
On Fri, Dec 8, 2023 at 11:47 AM Simon Glass sjg@chromium.org wrote: > > Hi Rob, > > On Fri, 8 Dec 2023 at 08:00, Rob Herring robh@kernel.org wrote: > > > > On Thu, Nov 16, 2023 at 10:28:50AM -0700, Simon Glass wrote: > > > Add a compatible string for binman, so we can extend fixed-partitions > > > in various ways. > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > --- > > > > > > (no changes since v5) > > > > > > Changes in v5: > > > - Add #address/size-cells and parternProperties > > > - Drop $ref to fixed-partitions.yaml > > > - Drop 'select: false' > > > > > > Changes in v4: > > > - Change subject line > > > > > > Changes in v3: > > > - Drop fixed-partition additional compatible string > > > - Drop fixed-partitions from the example > > > - Mention use of compatible instead of label > > > > > > Changes in v2: > > > - Drop mention of 'enhanced features' in fixed-partitions.yaml > > > - Mention Binman input and output properties > > > - Use plain partition@xxx for the node name > > > > > > .../bindings/mtd/partitions/binman.yaml | 68 +++++++++++++++++++ > > > .../bindings/mtd/partitions/partitions.yaml | 1 + > > > MAINTAINERS | 5 ++ > > > 3 files changed, 74 insertions(+) > > > create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > > > > diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > new file mode 100644 > > > index 000000000000..329217550a98 > > > --- /dev/null > > > +++ b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > @@ -0,0 +1,68 @@ > > > +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) > > > +# Copyright 2023 Google LLC > > > + > > > +%YAML 1.2 > > > +--- > > > +$id: http://devicetree.org/schemas/mtd/partitions/binman.yaml# > > > +$schema: http://devicetree.org/meta-schemas/core.yaml# > > > + > > > +title: Binman firmware layout > > > + > > > +maintainers: > > > + - Simon Glass sjg@chromium.org > > > + > > > +description: | > > > + The binman node provides a layout for firmware, used when packaging firmware > > > + from multiple projects. It is based on fixed-partitions, with some > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > + particular purpose. > > > + > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > + such as those which control alignment of partitions. This binding addresses > > > + these 'input' properties. For example, it is common for the 'reg' property > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > + in the input. > > > + > > > + Once processing is complete, input properties have mostly served their > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > + information to read the firmware at runtime, including decompression if > > > + needed. > > > > How is this going to work exactly? binman reads these nodes and then > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > specifc parts needed for repacking. > > No, they are the same node. I do want the extra information to stick > around. So long as it is compatible with fixed-partition as well, this > should work OK.
OK, then I suppose the best way is to add a new binman compatible, as is done with this v6 series. People then need to choose it instead of fixed-partition.
Should I resend this series, or is it OK as it is?
Hi Simon,
sjg@chromium.org wrote on Sun, 4 Feb 2024 05:07:38 -0700:
Hi Rob,
Hi Rob,
Hi Rob,
Hi Rob,
On Fri, 8 Dec 2023 at 14:56, Rob Herring robh@kernel.org wrote: > > On Fri, Dec 8, 2023 at 11:47 AM Simon Glass sjg@chromium.org wrote: > > > > Hi Rob, > > > > On Fri, 8 Dec 2023 at 08:00, Rob Herring robh@kernel.org wrote: > > > > > > On Thu, Nov 16, 2023 at 10:28:50AM -0700, Simon Glass wrote: > > > > Add a compatible string for binman, so we can extend fixed-partitions > > > > in various ways. > > > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > > --- > > > > > > > > (no changes since v5) > > > > > > > > Changes in v5: > > > > - Add #address/size-cells and parternProperties > > > > - Drop $ref to fixed-partitions.yaml > > > > - Drop 'select: false' > > > > > > > > Changes in v4: > > > > - Change subject line > > > > > > > > Changes in v3: > > > > - Drop fixed-partition additional compatible string > > > > - Drop fixed-partitions from the example > > > > - Mention use of compatible instead of label > > > > > > > > Changes in v2: > > > > - Drop mention of 'enhanced features' in fixed-partitions.yaml > > > > - Mention Binman input and output properties > > > > - Use plain partition@xxx for the node name > > > > > > > > .../bindings/mtd/partitions/binman.yaml | 68 +++++++++++++++++++ > > > > .../bindings/mtd/partitions/partitions.yaml | 1 + > > > > MAINTAINERS | 5 ++ > > > > 3 files changed, 74 insertions(+) > > > > create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > > > > > > diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > > new file mode 100644 > > > > index 000000000000..329217550a98 > > > > --- /dev/null > > > > +++ b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > > @@ -0,0 +1,68 @@ > > > > +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) > > > > +# Copyright 2023 Google LLC > > > > + > > > > +%YAML 1.2 > > > > +--- > > > > +$id: http://devicetree.org/schemas/mtd/partitions/binman.yaml# > > > > +$schema: http://devicetree.org/meta-schemas/core.yaml# > > > > + > > > > +title: Binman firmware layout > > > > + > > > > +maintainers: > > > > + - Simon Glass sjg@chromium.org > > > > + > > > > +description: | > > > > + The binman node provides a layout for firmware, used when packaging firmware > > > > + from multiple projects. It is based on fixed-partitions, with some > > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > > + particular purpose. > > > > + > > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > > + such as those which control alignment of partitions. This binding addresses > > > > + these 'input' properties. For example, it is common for the 'reg' property > > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > > + in the input. > > > > + > > > > + Once processing is complete, input properties have mostly served their > > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > > + information to read the firmware at runtime, including decompression if > > > > + needed. > > > > > > How is this going to work exactly? binman reads these nodes and then > > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > > specifc parts needed for repacking. > > > > No, they are the same node. I do want the extra information to stick > > around. So long as it is compatible with fixed-partition as well, this > > should work OK. > > How can it be both? The partitions node compatible can be either > 'fixed-partitions' or 'binman'.
I'm sorry this is not at all what Rob suggested, or did I totally misunderstand his answer?
In both cases the solution is to generate a "fixed-partition" node. Now up to you to decide whether binman should adapt the output to the current schema, or if the current schema should be extended to understand all binman's output.
At least that is my understanding and also what I kind of agree with.
Thanks, Miquèl
Hi Miquel,
On Mon, 5 Feb 2024 at 00:50, Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Simon,
Hi Rob,
Hi Rob,
Hi Rob,
On Fri, Dec 08, 2023 at 03:58:10PM -0700, Simon Glass wrote: > Hi Rob, > > On Fri, 8 Dec 2023 at 14:56, Rob Herring robh@kernel.org wrote: > > > > On Fri, Dec 8, 2023 at 11:47 AM Simon Glass sjg@chromium.org wrote: > > > > > > Hi Rob, > > > > > > On Fri, 8 Dec 2023 at 08:00, Rob Herring robh@kernel.org wrote: > > > > > > > > On Thu, Nov 16, 2023 at 10:28:50AM -0700, Simon Glass wrote: > > > > > Add a compatible string for binman, so we can extend fixed-partitions > > > > > in various ways. > > > > > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > > > --- > > > > > > > > > > (no changes since v5) > > > > > > > > > > Changes in v5: > > > > > - Add #address/size-cells and parternProperties > > > > > - Drop $ref to fixed-partitions.yaml > > > > > - Drop 'select: false' > > > > > > > > > > Changes in v4: > > > > > - Change subject line > > > > > > > > > > Changes in v3: > > > > > - Drop fixed-partition additional compatible string > > > > > - Drop fixed-partitions from the example > > > > > - Mention use of compatible instead of label > > > > > > > > > > Changes in v2: > > > > > - Drop mention of 'enhanced features' in fixed-partitions.yaml > > > > > - Mention Binman input and output properties > > > > > - Use plain partition@xxx for the node name > > > > > > > > > > .../bindings/mtd/partitions/binman.yaml | 68 +++++++++++++++++++ > > > > > .../bindings/mtd/partitions/partitions.yaml | 1 + > > > > > MAINTAINERS | 5 ++ > > > > > 3 files changed, 74 insertions(+) > > > > > create mode 100644 Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > > > > > > > > diff --git a/Documentation/devicetree/bindings/mtd/partitions/binman.yaml b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > > > new file mode 100644 > > > > > index 000000000000..329217550a98 > > > > > --- /dev/null > > > > > +++ b/Documentation/devicetree/bindings/mtd/partitions/binman.yaml > > > > > @@ -0,0 +1,68 @@ > > > > > +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) > > > > > +# Copyright 2023 Google LLC > > > > > + > > > > > +%YAML 1.2 > > > > > +--- > > > > > +$id: http://devicetree.org/schemas/mtd/partitions/binman.yaml# > > > > > +$schema: http://devicetree.org/meta-schemas/core.yaml# > > > > > + > > > > > +title: Binman firmware layout > > > > > + > > > > > +maintainers: > > > > > + - Simon Glass sjg@chromium.org > > > > > + > > > > > +description: | > > > > > + The binman node provides a layout for firmware, used when packaging firmware > > > > > + from multiple projects. It is based on fixed-partitions, with some > > > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > > > + particular purpose. > > > > > + > > > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > > > + such as those which control alignment of partitions. This binding addresses > > > > > + these 'input' properties. For example, it is common for the 'reg' property > > > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > > > + in the input. > > > > > + > > > > > + Once processing is complete, input properties have mostly served their > > > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > > > + information to read the firmware at runtime, including decompression if > > > > > + needed. > > > > > > > > How is this going to work exactly? binman reads these nodes and then > > > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > > > specifc parts needed for repacking. > > > > > > No, they are the same node. I do want the extra information to stick > > > around. So long as it is compatible with fixed-partition as well, this > > > should work OK. > > > > How can it be both? The partitions node compatible can be either > > 'fixed-partitions' or 'binman'. > > Can we not allow it to be both? I have tried to adjust things in > response to feedback but perhaps the feedback was leading me down the > wrong path?
I do want to binman schema to include all the features of Binman.
So are you saying that there should not be a 'binman' schema, but I should just add all the binman properties to the fixed-partition schema?
Hi Simon,
> > > > > > +description: | > > > > > > + The binman node provides a layout for firmware, used when packaging firmware > > > > > > + from multiple projects. It is based on fixed-partitions, with some > > > > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > > > > + particular purpose. > > > > > > + > > > > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > > > > + such as those which control alignment of partitions. This binding addresses > > > > > > + these 'input' properties. For example, it is common for the 'reg' property > > > > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > > > > + in the input. > > > > > > + > > > > > > + Once processing is complete, input properties have mostly served their > > > > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > > > > + information to read the firmware at runtime, including decompression if > > > > > > + needed. > > > > > > > > > > How is this going to work exactly? binman reads these nodes and then > > > > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > > > > specifc parts needed for repacking. > > > > > > > > No, they are the same node. I do want the extra information to stick > > > > around. So long as it is compatible with fixed-partition as well, this > > > > should work OK. > > > > > > How can it be both? The partitions node compatible can be either > > > 'fixed-partitions' or 'binman'. > > > > Can we not allow it to be both? I have tried to adjust things in > > response to feedback but perhaps the feedback was leading me down the > > wrong path? > > Sure, but then the schema has to and that means extending > fixed-partitions.
This is my current understanding, yes. But acknowledgment from Rob is also welcome.
Thanks, Miquèl
Hi Miquel,
On Tue, 6 Feb 2024 at 01:17, Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Simon,
> > > > > > > +description: | > > > > > > > + The binman node provides a layout for firmware, used when packaging firmware > > > > > > > + from multiple projects. It is based on fixed-partitions, with some > > > > > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > > > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > > > > > + particular purpose. > > > > > > > + > > > > > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > > > > > + such as those which control alignment of partitions. This binding addresses > > > > > > > + these 'input' properties. For example, it is common for the 'reg' property > > > > > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > > > > > + in the input. > > > > > > > + > > > > > > > + Once processing is complete, input properties have mostly served their > > > > > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > > > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > > > > > + information to read the firmware at runtime, including decompression if > > > > > > > + needed. > > > > > > > > > > > > How is this going to work exactly? binman reads these nodes and then > > > > > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > > > > > specifc parts needed for repacking. > > > > > > > > > > No, they are the same node. I do want the extra information to stick > > > > > around. So long as it is compatible with fixed-partition as well, this > > > > > should work OK. > > > > > > > > How can it be both? The partitions node compatible can be either > > > > 'fixed-partitions' or 'binman'. > > > > > > Can we not allow it to be both? I have tried to adjust things in > > > response to feedback but perhaps the feedback was leading me down the > > > wrong path? > > > > Sure, but then the schema has to and that means extending > > fixed-partitions. > > Can we cross that bridge later? There might be resistance to it. I'm > not sure. For now, perhaps just a binman compatible works well enough > to make progress.
I am trying again to wade through all the confusion here.
There is not actually a 'fixed-partition' node. So are you saying I should add one? There is already a 'partitions' node. Won't they conflict?
Would it be possible for you to look at my patches and suggest something? I think at this point, after so many hours of trying different things and trying to understand what is needed, I could really use a little help.
Thank you, Simon
Hi Simon,
sjg@chromium.org wrote on Fri, 8 Mar 2024 15:44:25 +1300:
Hi Miquel,
Hi Simon,
> > > > > > > > +description: | > > > > > > > > + The binman node provides a layout for firmware, used when packaging firmware > > > > > > > > + from multiple projects. It is based on fixed-partitions, with some > > > > > > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > > > > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > > > > > > + particular purpose. > > > > > > > > + > > > > > > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > > > > > > + such as those which control alignment of partitions. This binding addresses > > > > > > > > + these 'input' properties. For example, it is common for the 'reg' property > > > > > > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > > > > > > + in the input. > > > > > > > > + > > > > > > > > + Once processing is complete, input properties have mostly served their > > > > > > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > > > > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > > > > > > + information to read the firmware at runtime, including decompression if > > > > > > > > + needed. > > > > > > > > > > > > > > How is this going to work exactly? binman reads these nodes and then > > > > > > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > > > > > > specifc parts needed for repacking. > > > > > > > > > > > > No, they are the same node. I do want the extra information to stick > > > > > > around. So long as it is compatible with fixed-partition as well, this > > > > > > should work OK. > > > > > > > > > > How can it be both? The partitions node compatible can be either > > > > > 'fixed-partitions' or 'binman'. > > > > > > > > Can we not allow it to be both? I have tried to adjust things in > > > > response to feedback but perhaps the feedback was leading me down the > > > > wrong path? > > > > > > Sure, but then the schema has to and that means extending > > > fixed-partitions. > > > > Can we cross that bridge later? There might be resistance to it. I'm > > not sure. For now, perhaps just a binman compatible works well enough > > to make progress. > > Is there any way to make progress on this? I would like to have > software which doesn't understand the binman compatible to at least be > able to understand the fixed-partition compatible. Is that acceptable?
Sorry for the confusion, there is a 'partitions' node indeed. This node shall declare it's "programming model" (let's say), ie. how it should be parsed. What defines this programming model today is the 'fixed-partitions' compatible. I think we (Rob and myself, but again, Rob, please confirm) agree on the fact that we don't want to duplicate the fixed-partitions compatible/logic and thus the binman compatible was rejected.
Hence, in order to move forward, I would definitely appreciate an update of the fixed-partitions binding in order to support what binman can generate.
We are here talking about the output of binman, not its input. TBH I haven't understood the point in having binman's input parsed by the generic yaml binding. I would advise to focus on binman's output first because it feels more relevant, at a first glance.
I hope the above details will help.
Thanks, Miquèl
Hi Miquel,
On Fri, 8 Mar 2024 at 20:42, Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Simon,
Hi Miquel,
Hi Simon,
> > > > > > > > > +description: | > > > > > > > > > + The binman node provides a layout for firmware, used when packaging firmware > > > > > > > > > + from multiple projects. It is based on fixed-partitions, with some > > > > > > > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > > > > > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > > > > > > > + particular purpose. > > > > > > > > > + > > > > > > > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > > > > > > > + such as those which control alignment of partitions. This binding addresses > > > > > > > > > + these 'input' properties. For example, it is common for the 'reg' property > > > > > > > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > > > > > > > + in the input. > > > > > > > > > + > > > > > > > > > + Once processing is complete, input properties have mostly served their > > > > > > > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > > > > > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > > > > > > > + information to read the firmware at runtime, including decompression if > > > > > > > > > + needed. > > > > > > > > > > > > > > > > How is this going to work exactly? binman reads these nodes and then > > > > > > > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > > > > > > > specifc parts needed for repacking. > > > > > > > > > > > > > > No, they are the same node. I do want the extra information to stick > > > > > > > around. So long as it is compatible with fixed-partition as well, this > > > > > > > should work OK. > > > > > > > > > > > > How can it be both? The partitions node compatible can be either > > > > > > 'fixed-partitions' or 'binman'. > > > > > > > > > > Can we not allow it to be both? I have tried to adjust things in > > > > > response to feedback but perhaps the feedback was leading me down the > > > > > wrong path? > > > > > > > > Sure, but then the schema has to and that means extending > > > > fixed-partitions. > > > > > > Can we cross that bridge later? There might be resistance to it. I'm > > > not sure. For now, perhaps just a binman compatible works well enough > > > to make progress. > > > > Is there any way to make progress on this? I would like to have > > software which doesn't understand the binman compatible to at least be > > able to understand the fixed-partition compatible. Is that acceptable? > > There's only 2 ways that it can work. Either binman writes out > fixed-partition nodes dropping/replacing anything only defined for > binman or fixed-partition is extended to include what binman needs.
OK, so I think my confusion is that I thought you were referring to a 'partitions' compatible. But you are just referring to the name of the node being 'partitions', with the compatible string being 'fixed-partitions'.
I believe I can make this work by adding a new 'binman.yaml' with the compatibles that I want to introduce. I cannot change partition.yaml since it does not itself specify a compatible.
Yes that is fine.
I think so, thank you. I will send another version.
Hi Simon,
sjg@chromium.org wrote on Wed, 13 Mar 2024 11:25:42 +1300:
Hi Miquel,
Hi Simon,
Hi Miquel,
Hi Simon,
> > > > > > > > > > +description: | > > > > > > > > > > + The binman node provides a layout for firmware, used when packaging firmware > > > > > > > > > > + from multiple projects. It is based on fixed-partitions, with some > > > > > > > > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > > > > > > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > > > > > > > > + particular purpose. > > > > > > > > > > + > > > > > > > > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > > > > > > > > + such as those which control alignment of partitions. This binding addresses > > > > > > > > > > + these 'input' properties. For example, it is common for the 'reg' property > > > > > > > > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > > > > > > > > + in the input. > > > > > > > > > > + > > > > > > > > > > + Once processing is complete, input properties have mostly served their > > > > > > > > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > > > > > > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > > > > > > > > + information to read the firmware at runtime, including decompression if > > > > > > > > > > + needed. > > > > > > > > > > > > > > > > > > How is this going to work exactly? binman reads these nodes and then > > > > > > > > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > > > > > > > > specifc parts needed for repacking. > > > > > > > > > > > > > > > > No, they are the same node. I do want the extra information to stick > > > > > > > > around. So long as it is compatible with fixed-partition as well, this > > > > > > > > should work OK. > > > > > > > > > > > > > > How can it be both? The partitions node compatible can be either > > > > > > > 'fixed-partitions' or 'binman'. > > > > > > > > > > > > Can we not allow it to be both? I have tried to adjust things in > > > > > > response to feedback but perhaps the feedback was leading me down the > > > > > > wrong path? > > > > > > > > > > Sure, but then the schema has to and that means extending > > > > > fixed-partitions. > > > > > > > > Can we cross that bridge later? There might be resistance to it. I'm > > > > not sure. For now, perhaps just a binman compatible works well enough > > > > to make progress. > > > > > > Is there any way to make progress on this? I would like to have > > > software which doesn't understand the binman compatible to at least be > > > able to understand the fixed-partition compatible. Is that acceptable? > > > > There's only 2 ways that it can work. Either binman writes out > > fixed-partition nodes dropping/replacing anything only defined for > > binman or fixed-partition is extended to include what binman needs. > > OK, then I suppose the best way is to add a new binman compatible, as > is done with this v6 series. People then need to choose it instead of > fixed-partition.
Yes.
What about fixed-partitions.ymal? The yaml file name should match the compatible.
Yes that is fine.
Thanks, Miquèl
Hi Miquel,
On Wed, 13 Mar 2024 at 20:35, Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Simon,
Hi Miquel,
Hi Simon,
Hi Miquel,
Hi Simon,
> > > > > > > > > > > +description: | > > > > > > > > > > > + The binman node provides a layout for firmware, used when packaging firmware > > > > > > > > > > > + from multiple projects. It is based on fixed-partitions, with some > > > > > > > > > > > + extensions, but uses 'compatible' to indicate the contents of the node, to > > > > > > > > > > > + avoid perturbing or confusing existing installations which use 'label' for a > > > > > > > > > > > + particular purpose. > > > > > > > > > > > + > > > > > > > > > > > + Binman supports properties used as inputs to the firmware-packaging process, > > > > > > > > > > > + such as those which control alignment of partitions. This binding addresses > > > > > > > > > > > + these 'input' properties. For example, it is common for the 'reg' property > > > > > > > > > > > + (an 'output' property) to be set by Binman, based on the alignment requested > > > > > > > > > > > + in the input. > > > > > > > > > > > + > > > > > > > > > > > + Once processing is complete, input properties have mostly served their > > > > > > > > > > > + purpose, at least until the firmware is repacked later, e.g. due to a > > > > > > > > > > > + firmware update. The 'fixed-partitions' binding should provide enough > > > > > > > > > > > + information to read the firmware at runtime, including decompression if > > > > > > > > > > > + needed. > > > > > > > > > > > > > > > > > > > > How is this going to work exactly? binman reads these nodes and then > > > > > > > > > > writes out 'fixed-partitions' nodes. But then you've lost the binman > > > > > > > > > > specifc parts needed for repacking. > > > > > > > > > > > > > > > > > > No, they are the same node. I do want the extra information to stick > > > > > > > > > around. So long as it is compatible with fixed-partition as well, this > > > > > > > > > should work OK. > > > > > > > > > > > > > > > > How can it be both? The partitions node compatible can be either > > > > > > > > 'fixed-partitions' or 'binman'. > > > > > > > > > > > > > > Can we not allow it to be both? I have tried to adjust things in > > > > > > > response to feedback but perhaps the feedback was leading me down the > > > > > > > wrong path? > > > > > > > > > > > > Sure, but then the schema has to and that means extending > > > > > > fixed-partitions. > > > > > > > > > > Can we cross that bridge later? There might be resistance to it. I'm > > > > > not sure. For now, perhaps just a binman compatible works well enough > > > > > to make progress. > > > > > > > > Is there any way to make progress on this? I would like to have > > > > software which doesn't understand the binman compatible to at least be > > > > able to understand the fixed-partition compatible. Is that acceptable? > > > > > > There's only 2 ways that it can work. Either binman writes out > > > fixed-partition nodes dropping/replacing anything only defined for > > > binman or fixed-partition is extended to include what binman needs. > > > > OK, then I suppose the best way is to add a new binman compatible, as > > is done with this v6 series. People then need to choose it instead of > > fixed-partition. > > I'm sorry this is not at all what Rob suggested, or did I totally > misunderstand his answer? > > In both cases the solution is to generate a "fixed-partition" node. Now > up to you to decide whether binman should adapt the output to the > current schema, or if the current schema should be extended to > understand all binman's output. > > At least that is my understanding and also what I kind of agree with.
Yes.
But we already decided we cannot add a new 'binman' compatible but want to use the existing fixed-partitions.yaml
I cannot add compatible strings into that, since these are defined by the default files which make use of partition.yaml
Anyway, I will see v7 so you can see what I mean.
Yes that is fine.
Miquel Raynal
Rob Herring
