[PATCH 1/1] efi_loader: function descriptions efi_unicode_collation.c
Correct function descriptions in efi_unicode_collation.c Add the Unicode collation protocol to the generated HTML documentation.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/api/efi.rst | 6 ++++++ lib/efi_loader/efi_unicode_collation.c | 6 ++---- 2 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/doc/api/efi.rst b/doc/api/efi.rst index 631c0ceb1d..b9c0c6efc5 100644 --- a/doc/api/efi.rst +++ b/doc/api/efi.rst @@ -151,3 +151,9 @@ Text IO protocols
.. kernel-doc:: lib/efi_loader/efi_console.c :internal: + +Unicode Collation protocol +~~~~~~~~~~~~~~~~~~~~~~~~~~ + +.. kernel-doc:: lib/efi_loader/efi_unicode_collation.c + :internal: diff --git a/lib/efi_loader/efi_unicode_collation.c b/lib/efi_loader/efi_unicode_collation.c index c700be8756..6655c68092 100644 --- a/lib/efi_loader/efi_unicode_collation.c +++ b/lib/efi_loader/efi_unicode_collation.c @@ -169,8 +169,8 @@ static bool metai_match(const u16 *string, const u16 *pattern) * case-insenitively * * @this: unicode collation protocol instance - * @s: string to compare - * @p: pattern string + * @string: string to compare + * @pattern: pattern string * * The pattern string may use these: * - * matches >= 0 characters @@ -199,7 +199,6 @@ static bool EFIAPI efi_metai_match(struct efi_unicode_collation_protocol *this, * * @this: unicode collation protocol instance * @string: string to convert - * @p: pattern string * * The conversion is done in place. As long as upper and lower letters use the * same number of words this does not pose a problem. @@ -221,7 +220,6 @@ static void EFIAPI efi_str_lwr(struct efi_unicode_collation_protocol *this, * * @this: unicode collation protocol instance * @string: string to convert - * @p: pattern string * * The conversion is done in place. As long as upper and lower letters use the * same number of words this does not pose a problem. -- 2.25.1
