[U-Boot] [PATCH 1/2] ARM: zynq: Add support for Zynq 7000S 7007s/7012s/7014s devices
Zynq 7000S (Single A9 core) devices is using different ID code. This patch adds this new codes and assign them.
board/xilinx/zynq/board.c | 12 ++++++++++++ include/zynqpl.h | 18 ++++++++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 183f64275349..2c86940957ec 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -19,7 +19,10 @@ DECLARE_GLOBAL_DATA_PTR; static xilinx_desc fpga;
/* It can be done differently */ +static xilinx_desc fpga007s = XILINX_XC7Z007S_DESC(0x7); static xilinx_desc fpga010 = XILINX_XC7Z010_DESC(0x10); +static xilinx_desc fpga012s = XILINX_XC7Z012S_DESC(0x12); +static xilinx_desc fpga014s = XILINX_XC7Z014S_DESC(0x14); static xilinx_desc fpga015 = XILINX_XC7Z015_DESC(0x15); static xilinx_desc fpga020 = XILINX_XC7Z020_DESC(0x20); static xilinx_desc fpga030 = XILINX_XC7Z030_DESC(0x30); @@ -37,9 +40,18 @@ int board_init(void) idcode = zynq_slcr_get_idcode();
switch (idcode) { + case XILINX_ZYNQ_7007S: + fpga = fpga007s; + break; case XILINX_ZYNQ_7010: fpga = fpga010; break; + case XILINX_ZYNQ_7012S: + fpga = fpga012s; + break; + case XILINX_ZYNQ_7014S: + fpga = fpga014s; + break; case XILINX_ZYNQ_7015: fpga = fpga015; break; diff --git a/include/zynqpl.h b/include/zynqpl.h index 1d37a51a04ef..5a34a17daefe 100644 --- a/include/zynqpl.h +++ b/include/zynqpl.h @@ -19,7 +19,10 @@ extern struct xilinx_fpga_op zynq_op; # define FPGA_ZYNQPL_OPS NULL #endif
+#define XILINX_ZYNQ_7007S 0x3 #define XILINX_ZYNQ_7010 0x2 +#define XILINX_ZYNQ_7012S 0x1c +#define XILINX_ZYNQ_7014S 0x8 #define XILINX_ZYNQ_7015 0x1b #define XILINX_ZYNQ_7020 0x7 #define XILINX_ZYNQ_7030 0xc @@ -28,7 +31,10 @@ extern struct xilinx_fpga_op zynq_op; #define XILINX_ZYNQ_7100 0x16
/* Device Image Sizes */ +#define XILINX_XC7Z007S_SIZE 16669920/8 #define XILINX_XC7Z010_SIZE 16669920/8 +#define XILINX_XC7Z012S_SIZE 28085344/8 +#define XILINX_XC7Z014S_SIZE 32364512/8 #define XILINX_XC7Z015_SIZE 28085344/8 #define XILINX_XC7Z020_SIZE 32364512/8 #define XILINX_XC7Z030_SIZE 47839328/8 @@ -37,10 +43,22 @@ extern struct xilinx_fpga_op zynq_op; #define XILINX_XC7Z100_SIZE 139330784/8
/* Descriptor Macros */ +#define XILINX_XC7Z007S_DESC(cookie) \ +{ xilinx_zynq, devcfg, XILINX_XC7Z007S_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z007s" } + #define XILINX_XC7Z010_DESC(cookie) \ { xilinx_zynq, devcfg, XILINX_XC7Z010_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ "7z010" }
+#define XILINX_XC7Z012S_DESC(cookie) \ +{ xilinx_zynq, devcfg, XILINX_XC7Z012S_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z012s" } + +#define XILINX_XC7Z014S_DESC(cookie) \ +{ xilinx_zynq, devcfg, XILINX_XC7Z014S_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z014s" } + #define XILINX_XC7Z015_DESC(cookie) \ { xilinx_zynq, devcfg, XILINX_XC7Z015_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ "7z015" }
This patch adds support to check the buswidth on nand flash at runtime based on nand MIO configurations done by FSBL.
User needs to correctly configure the MIO's based on the buswidth supported by the nand flash which is present on the board.
Added nand8 and nand16 @periph names on slcr driver.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/mach-zynq/slcr.c | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/arch/arm/mach-zynq/slcr.c b/arch/arm/mach-zynq/slcr.c index 05f4099aaee8..2d3bf2acef7e 100644 --- a/arch/arm/mach-zynq/slcr.c +++ b/arch/arm/mach-zynq/slcr.c @@ -14,6 +14,9 @@ #define SLCR_LOCK_MAGIC 0x767B #define SLCR_UNLOCK_MAGIC 0xDF0D
+#define SLCR_NAND_L2_SEL 0x10 +#define SLCR_NAND_L2_SEL_MASK 0x1F + #define SLCR_USB_L1_SEL 0x04
#define SLCR_IDCODE_MASK 0x1F000 @@ -36,6 +39,14 @@ struct zynq_slcr_mio_get_status { u32 check_val; };
+static const int nand8_pins[] = { + 0, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 +}; + +static const int nand16_pins[] = { + 16, 17, 18, 19, 20, 21, 22, 23 +}; + static const int usb0_pins[] = { 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39 }; @@ -46,6 +57,20 @@ static const int usb1_pins[] = {
static const struct zynq_slcr_mio_get_status mio_periphs[] = { { + "nand8", + nand8_pins, + ARRAY_SIZE(nand8_pins), + SLCR_NAND_L2_SEL_MASK, + SLCR_NAND_L2_SEL, + }, + { + "nand16", + nand16_pins, + ARRAY_SIZE(nand16_pins), + SLCR_NAND_L2_SEL_MASK, + SLCR_NAND_L2_SEL, + }, + { "usb0", usb0_pins, ARRAY_SIZE(usb0_pins),
Michal Simek
