[U-Boot] Better I2C support for OMAP
Hugo Vincent wrote:
Hi everyone,
This patch improves I2C support on OMAP3 platforms, including supporting the second and third I2C controllers (mainline only supports the first controller), and supporting writes where alen=0 (i.e. no register address - this was needed for some I2C devices I needed to drive from u-boot).
Tested on Gumstix Overo with several I2C devices, on I2C1 and 3.
The multi-bus support is mostly from this patch: http://www.beagleboard.org/gitweb/?p=u-boot-arm.git;a=commit;h=52eddcd07c2e7...
Best regards, Hugo Vincent
Signed-off-by: Hugo Vincent hugo.vincent@gmail.com
Does anybody have an up to date version of this patch? Seems we need it for Beagle Zippy, too.
Thanks
Dirk
I have cherry picked this change from the above git repo.
There was some cleanup.
The omap24xx version changes were done.
The structure elements were changed from unsigned int to unsigned shorts + pads to make the elements consistent with the writew/readw 's used in the driver.
The cmd_i2c changes that did not seem to fit were removed.
I have run tested this on beagle and zoom1.
Since I don't have a zippy board handy I did not get anything meaningfull when switching to i2c dev 2. The default i2c dev worked as expected.
Tom
This was cherry-picked from
repo: http://www.beagleboard.org/u-boot-arm.git commit: 52eddcd07c2e7ad61d15bab2cf2d0d21466eaca2
In addition to adding multibus support, this patch also cleans up the register access. The register access has been changed from #defines to a structure.
Signed-off-by: Syed Mohammed Khasim khasim@ti.com Signed-off-by: Jason Kridner jkridner@beagleboard.org Signed-off-by: Tom Rix Tom.Rix@windriver.com --- drivers/i2c/omap24xx_i2c.c | 220 ++++++++++++++++++++++------------- include/asm-arm/arch-omap24xx/i2c.h | 52 ++++++--- include/asm-arm/arch-omap3/i2c.h | 48 +++++--- include/configs/omap3_beagle.h | 1 + 4 files changed, 209 insertions(+), 112 deletions(-)
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 1a4c8c9..763d2f8 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -1,7 +1,7 @@ /* * Basic I2C functions * - * Copyright (c) 2004 Texas Instruments + * Copyright (c) 2004, 2009 Texas Instruments * * This package is free software; you can redistribute it and/or * modify it under the terms of the license found in the file @@ -25,10 +25,18 @@ #include <asm/arch/i2c.h> #include <asm/io.h>
+#ifdef CONFIG_OMAP34XX +#define I2C_NUM_IF 3 +#else +#define I2C_NUM_IF 2 +#endif + static void wait_for_bb (void); static u16 wait_for_pin (void); static void flush_fifo(void);
+static i2c_t *i2c = (i2c_t *)I2C_DEFAULT_BASE; + void i2c_init (int speed, int slaveadd) { int psc, fsscll, fssclh; @@ -95,30 +103,30 @@ void i2c_init (int speed, int slaveadd) sclh = (unsigned int)fssclh; }
- writew(0x2, I2C_SYSC); /* for ES2 after soft reset */ + writew(0x2, &i2c->sysc); /* for ES2 after soft reset */ udelay(1000); - writew(0x0, I2C_SYSC); /* will probably self clear but */ + writew(0x0, &i2c->sysc); /* will probably self clear but */
- if (readw (I2C_CON) & I2C_CON_EN) { - writew (0, I2C_CON); - udelay (50000); + if (readw(&i2c->con) & I2C_CON_EN) { + writew(0, &i2c->con); + udelay(50000); }
- writew(psc, I2C_PSC); - writew(scll, I2C_SCLL); - writew(sclh, I2C_SCLH); + writew(psc, &i2c->psc); + writew(scll, &i2c->scll); + writew(sclh, &i2c->sclh);
/* own address */ - writew (slaveadd, I2C_OA); - writew (I2C_CON_EN, I2C_CON); + writew(slaveadd, &i2c->oa); + writew(I2C_CON_EN, &i2c->con);
/* have to enable intrrupts or OMAP i2c module doesn't work */ - writew (I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | - I2C_IE_NACK_IE | I2C_IE_AL_IE, I2C_IE); - udelay (1000); + writew(I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | + I2C_IE_NACK_IE | I2C_IE_AL_IE, &i2c->ie); + udelay(1000); flush_fifo(); - writew (0xFFFF, I2C_STAT); - writew (0, I2C_CNT); + writew(0xFFFF, &i2c->stat); + writew(0, &i2c->cnt); }
static int i2c_read_byte (u8 devaddr, u8 regoffset, u8 * value) @@ -130,19 +138,19 @@ static int i2c_read_byte (u8 devaddr, u8 regoffset, u8 * value) wait_for_bb ();
/* one byte only */ - writew (1, I2C_CNT); + writew(1, &i2c->cnt); /* set slave address */ - writew (devaddr, I2C_SA); + writew(devaddr, &i2c->sa); /* no stop bit needed here */ - writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX, I2C_CON); + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX, &i2c->con);
status = wait_for_pin ();
if (status & I2C_STAT_XRDY) { /* Important: have to use byte access */ - writeb (regoffset, I2C_DATA); - udelay (20000); - if (readw (I2C_STAT) & I2C_STAT_NACK) { + writeb(regoffset, &i2c->data); + udelay(20000); + if (readw(&i2c->stat) & I2C_STAT_NACK) { i2c_error = 1; } } else { @@ -151,28 +159,28 @@ static int i2c_read_byte (u8 devaddr, u8 regoffset, u8 * value)
if (!i2c_error) { /* free bus, otherwise we can't use a combined transction */ - writew (0, I2C_CON); - while (readw (I2C_STAT) || (readw (I2C_CON) & I2C_CON_MST)) { + writew(0, &i2c->con); + while (readw(&i2c->stat) || (readw(&i2c->con) & I2C_CON_MST)) { udelay (10000); /* Have to clear pending interrupt to clear I2C_STAT */ - writew (0xFFFF, I2C_STAT); + writew(0xFFFF, &i2c->stat); }
wait_for_bb (); /* set slave address */ - writew (devaddr, I2C_SA); + writew(devaddr, &i2c->sa); /* read one byte from slave */ - writew (1, I2C_CNT); + writew(1, &i2c->cnt); /* need stop bit here */ - writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, - I2C_CON); + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, + &i2c->con);
status = wait_for_pin (); if (status & I2C_STAT_RRDY) { #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) - *value = readb (I2C_DATA); + *value = readb(&i2c->data); #else - *value = readw (I2C_DATA); + *value = readw(&i2c->data); #endif udelay (20000); } else { @@ -180,17 +188,17 @@ static int i2c_read_byte (u8 devaddr, u8 regoffset, u8 * value) }
if (!i2c_error) { - writew (I2C_CON_EN, I2C_CON); - while (readw (I2C_STAT) - || (readw (I2C_CON) & I2C_CON_MST)) { + writew(I2C_CON_EN, &i2c->con); + while (readw(&i2c->stat) + || (readw(&i2c->con) & I2C_CON_MST)) { udelay (10000); - writew (0xFFFF, I2C_STAT); + writew(0xFFFF, &i2c->stat); } } } flush_fifo(); - writew (0xFFFF, I2C_STAT); - writew (0, I2C_CNT); + writew(0xFFFF, &i2c->stat); + writew(0, &i2c->cnt); return i2c_error; }
@@ -203,12 +211,12 @@ static int i2c_write_byte (u8 devaddr, u8 regoffset, u8 value) wait_for_bb ();
/* two bytes */ - writew (2, I2C_CNT); + writew(2, &i2c->cnt); /* set slave address */ - writew (devaddr, I2C_SA); + writew(devaddr, &i2c->sa); /* stop bit needed here */ - writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | - I2C_CON_STP, I2C_CON); + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | + I2C_CON_STP, &i2c->con);
/* wait until state change */ status = wait_for_pin (); @@ -216,24 +224,24 @@ static int i2c_write_byte (u8 devaddr, u8 regoffset, u8 value) if (status & I2C_STAT_XRDY) { #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) /* send out 1 byte */ - writeb (regoffset, I2C_DATA); - writew (I2C_STAT_XRDY, I2C_STAT); + writeb(regoffset, &i2c->data); + writew(I2C_STAT_XRDY, &i2c->stat);
status = wait_for_pin (); if ((status & I2C_STAT_XRDY)) { /* send out next 1 byte */ - writeb (value, I2C_DATA); - writew (I2C_STAT_XRDY, I2C_STAT); + writeb(value, &i2c->data); + writew(I2C_STAT_XRDY, &i2c->stat); } else { i2c_error = 1; } #else /* send out two bytes */ - writew ((value << 8) + regoffset, I2C_DATA); + writew((value << 8) + regoffset, &i2c->data); #endif /* must have enough delay to allow BB bit to go low */ - udelay (50000); - if (readw (I2C_STAT) & I2C_STAT_NACK) { + udelay(50000); + if (readw(&i2c->stat) & I2C_STAT_NACK) { i2c_error = 1; } } else { @@ -243,18 +251,18 @@ static int i2c_write_byte (u8 devaddr, u8 regoffset, u8 value) if (!i2c_error) { int eout = 200;
- writew (I2C_CON_EN, I2C_CON); - while ((stat = readw (I2C_STAT)) || (readw (I2C_CON) & I2C_CON_MST)) { - udelay (1000); + writew(I2C_CON_EN, &i2c->con); + while ((stat = readw(&i2c->stat)) || (readw(&i2c->con) & I2C_CON_MST)) { + udelay(1000); /* have to read to clear intrrupt */ - writew (0xFFFF, I2C_STAT); + writew(0xFFFF, &i2c->stat); if(--eout == 0) /* better leave with error than hang */ break; } } flush_fifo(); - writew (0xFFFF, I2C_STAT); - writew (0, I2C_CNT); + writew(0xFFFF, &i2c->stat); + writew(0, &i2c->cnt); return i2c_error; }
@@ -265,14 +273,14 @@ static void flush_fifo(void) * you get a bus error */ while(1){ - stat = readw(I2C_STAT); + stat = readw(&i2c->stat); if(stat == I2C_STAT_RRDY){ #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) - readb(I2C_DATA); + readb(&i2c->data); #else - readw(I2C_DATA); + readw(&i2c->data); #endif - writew(I2C_STAT_RRDY,I2C_STAT); + writew(I2C_STAT_RRDY, &i2c->stat); udelay(1000); }else break; @@ -283,7 +291,7 @@ int i2c_probe (uchar chip) { int res = 1; /* default = fail */
- if (chip == readw (I2C_OA)) { + if (chip == readw(&i2c->oa)) { return res; }
@@ -291,27 +299,27 @@ int i2c_probe (uchar chip) wait_for_bb ();
/* try to read one byte */ - writew (1, I2C_CNT); + writew(1, &i2c->cnt); /* set slave address */ - writew (chip, I2C_SA); + writew(chip, &i2c->sa); /* stop bit needed here */ - writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, I2C_CON); + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, &i2c->con); /* enough delay for the NACK bit set */ - udelay (50000); + udelay(50000);
- if (!(readw (I2C_STAT) & I2C_STAT_NACK)) { + if (!(readw(&i2c->stat) & I2C_STAT_NACK)) { res = 0; /* success case */ flush_fifo(); - writew(0xFFFF, I2C_STAT); + writew(0xFFFF, &i2c->stat); } else { - writew(0xFFFF, I2C_STAT); /* failue, clear sources*/ - writew (readw (I2C_CON) | I2C_CON_STP, I2C_CON); /* finish up xfer */ + writew(0xFFFF, &i2c->stat); /* failue, clear sources*/ + writew(readw(&i2c->con) | I2C_CON_STP, &i2c->con); /* finish up xfer */ udelay(20000); wait_for_bb (); } flush_fifo(); - writew (0, I2C_CNT); /* don't allow any more data in...we don't want it.*/ - writew(0xFFFF, I2C_STAT); + writew(0, &i2c->cnt); /* don't allow any more data in...we don't want it.*/ + writew(0xFFFF, &i2c->stat); return res; }
@@ -345,18 +353,18 @@ int i2c_write (uchar chip, uint addr, int alen, uchar * buffer, int len) int i;
if (alen > 1) { - printf ("I2C read: addr len %d not supported\n", alen); + printf ("I2C write: addr len %d not supported\n", alen); return 1; }
if (addr + len > 256) { - printf ("I2C read: address out of range\n"); + printf ("I2C write: address out of range\n"); return 1; }
for (i = 0; i < len; i++) { if (i2c_write_byte (chip, addr + i, buffer[i])) { - printf ("I2C read: I/O error\n"); + printf ("I2C write: I/O error\n"); i2c_init (CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); return 1; } @@ -370,17 +378,17 @@ static void wait_for_bb (void) int timeout = 10; u16 stat;
- writew(0xFFFF, I2C_STAT); /* clear current interruts...*/ - while ((stat = readw (I2C_STAT) & I2C_STAT_BB) && timeout--) { - writew (stat, I2C_STAT); - udelay (50000); + writew(0xFFFF, &i2c->stat); /* clear current interruts...*/ + while ((stat = readw(&i2c->stat) & I2C_STAT_BB) && timeout--) { + writew(stat, &i2c->stat); + udelay(50000); }
if (timeout <= 0) { printf ("timed out in wait_for_bb: I2C_STAT=%x\n", - readw (I2C_STAT)); + readw(&i2c->stat)); } - writew(0xFFFF, I2C_STAT); /* clear delayed stuff*/ + writew(0xFFFF, &i2c->stat); /* clear delayed stuff*/ }
static u16 wait_for_pin (void) @@ -390,7 +398,7 @@ static u16 wait_for_pin (void)
do { udelay (1000); - status = readw (I2C_STAT); + status = readw(&i2c->stat); } while ( !(status & (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY | I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK | @@ -398,8 +406,58 @@ static u16 wait_for_pin (void)
if (timeout <= 0) { printf ("timed out in wait_for_pin: I2C_STAT=%x\n", - readw (I2C_STAT)); - writew(0xFFFF, I2C_STAT); + readw(&i2c->stat)); + writew(0xFFFF, &i2c->stat); } return status; } + +int i2c_set_bus_num(unsigned int bus) +{ + if ((bus < 0) || (bus >= I2C_NUM_IF)) { + printf("Bad bus ID-%d\n", bus); + return -1; + } + +#if defined(CONFIG_OMAP34XX) + if (bus == 2) + i2c = (i2c_t *)I2C_BASE3; + else +#endif + if (bus == 1) + i2c = (i2c_t *)I2C_BASE2; + else + i2c = (i2c_t *)I2C_BASE1; + + return 0; +} + +unsigned int i2c_get_bus_num(void) +{ + if (i2c == (i2c_t *)I2C_BASE1) + return 0; + else + if (i2c == (i2c_t *)I2C_BASE2) + return 1; +#if defined(CONFIG_OMAP34XX) + else + if (i2c == (i2c_t *)I2C_BASE3) + return 2; +#endif + else + return 0xFFFFFFFF; +} + +/* + * To be Implemented + */ +int i2c_set_bus_speed(unsigned int speed) +{ + return 0; +} + +unsigned int i2c_get_bus_speed(void) +{ + return 0; +} + diff --git a/include/asm-arm/arch-omap24xx/i2c.h b/include/asm-arm/arch-omap24xx/i2c.h index 44db7a2..832a0e1 100644 --- a/include/asm-arm/arch-omap24xx/i2c.h +++ b/include/asm-arm/arch-omap24xx/i2c.h @@ -23,24 +23,44 @@ #ifndef _OMAP24XX_I2C_H_ #define _OMAP24XX_I2C_H_
-#define I2C_BASE 0x48070000 +#define I2C_BASE1 0x48070000 #define I2C_BASE2 0x48072000 /* nothing hooked up on h4 */
-#define I2C_REV (I2C_BASE + 0x00) -#define I2C_IE (I2C_BASE + 0x04) -#define I2C_STAT (I2C_BASE + 0x08) -#define I2C_IV (I2C_BASE + 0x0c) -#define I2C_BUF (I2C_BASE + 0x14) -#define I2C_CNT (I2C_BASE + 0x18) -#define I2C_DATA (I2C_BASE + 0x1c) -#define I2C_SYSC (I2C_BASE + 0x20) -#define I2C_CON (I2C_BASE + 0x24) -#define I2C_OA (I2C_BASE + 0x28) -#define I2C_SA (I2C_BASE + 0x2c) -#define I2C_PSC (I2C_BASE + 0x30) -#define I2C_SCLL (I2C_BASE + 0x34) -#define I2C_SCLH (I2C_BASE + 0x38) -#define I2C_SYSTEST (I2C_BASE + 0x3c) +#define I2C_DEFAULT_BASE I2C_BASE1 + +typedef struct i2c { + unsigned short rev; /* 0x00 */ + unsigned short pad_rev; /* 0x02 */ + unsigned short ie; /* 0x04 */ + unsigned short pad_ie; /* 0x06 */ + unsigned short stat; /* 0x08 */ + unsigned short pad_stat; /* 0x0a */ + unsigned short iv; /* 0x0c */ + unsigned short pad_iv; /* 0x0e */ + unsigned int res1; /* 0x10 */ + unsigned short buf; /* 0x14 */ + unsigned short pad_buf; /* 0x16 */ + unsigned short cnt; /* 0x18 */ + unsigned short pad_cnt; /* 0x1a */ + unsigned short data; /* 0x1c */ + unsigned short pad_data; /* 0x1e */ + unsigned short sysc; /* 0x20 */ + unsigned short pad_sysc; /* 0x22 */ + unsigned short con; /* 0x24 */ + unsigned short pad_con; /* 0x26 */ + unsigned short oa; /* 0x28 */ + unsigned short pad_oa; /* 0x2a */ + unsigned short sa; /* 0x2c */ + unsigned short pad_sa; /* 0x2e */ + unsigned short psc; /* 0x30 */ + unsigned short pad_psc; /* 0x32 */ + unsigned short scll; /* 0x34 */ + unsigned short pad_scll; /* 0x36 */ + unsigned short sclh; /* 0x38 */ + unsigned short pad_sclh; /* 0x3a */ + unsigned short systest; /* 0x3c */ + unsigned short pad_systest; /* 0x3e */ +} i2c_t;
/* I2C masks */
diff --git a/include/asm-arm/arch-omap3/i2c.h b/include/asm-arm/arch-omap3/i2c.h index 8b339cc..3da1fcf 100644 --- a/include/asm-arm/arch-omap3/i2c.h +++ b/include/asm-arm/arch-omap3/i2c.h @@ -25,21 +25,39 @@
-#define I2C_REV (I2C_DEFAULT_BASE + 0x00) -#define I2C_IE (I2C_DEFAULT_BASE + 0x04) -#define I2C_STAT (I2C_DEFAULT_BASE + 0x08) -#define I2C_IV (I2C_DEFAULT_BASE + 0x0c) -#define I2C_BUF (I2C_DEFAULT_BASE + 0x14) -#define I2C_CNT (I2C_DEFAULT_BASE + 0x18) -#define I2C_DATA (I2C_DEFAULT_BASE + 0x1c) -#define I2C_SYSC (I2C_DEFAULT_BASE + 0x20) -#define I2C_CON (I2C_DEFAULT_BASE + 0x24) -#define I2C_OA (I2C_DEFAULT_BASE + 0x28) -#define I2C_SA (I2C_DEFAULT_BASE + 0x2c) -#define I2C_PSC (I2C_DEFAULT_BASE + 0x30) -#define I2C_SCLL (I2C_DEFAULT_BASE + 0x34) -#define I2C_SCLH (I2C_DEFAULT_BASE + 0x38) -#define I2C_SYSTEST (I2C_DEFAULT_BASE + 0x3c) +typedef struct i2c { + unsigned short rev; /* 0x00 */ + unsigned short pad_rev; /* 0x02 */ + unsigned short ie; /* 0x04 */ + unsigned short pad_ie; /* 0x06 */ + unsigned short stat; /* 0x08 */ + unsigned short pad_stat; /* 0x0a */ + unsigned short iv; /* 0x0c */ + unsigned short pad_iv; /* 0x0e */ + unsigned int res1; /* 0x10 */ + unsigned short buf; /* 0x14 */ + unsigned short pad_buf; /* 0x16 */ + unsigned short cnt; /* 0x18 */ + unsigned short pad_cnt; /* 0x1a */ + unsigned short data; /* 0x1c */ + unsigned short pad_data; /* 0x1e */ + unsigned short sysc; /* 0x20 */ + unsigned short pad_sysc; /* 0x22 */ + unsigned short con; /* 0x24 */ + unsigned short pad_con; /* 0x26 */ + unsigned short oa; /* 0x28 */ + unsigned short pad_oa; /* 0x2a */ + unsigned short sa; /* 0x2c */ + unsigned short pad_sa; /* 0x2e */ + unsigned short psc; /* 0x30 */ + unsigned short pad_psc; /* 0x32 */ + unsigned short scll; /* 0x34 */ + unsigned short pad_scll; /* 0x36 */ + unsigned short sclh; /* 0x38 */ + unsigned short pad_sclh; /* 0x3a */ + unsigned short systest; /* 0x3c */ + unsigned short pad_systest; /* 0x3e */ +} i2c_t;
/* I2C masks */
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 19a5ec9..d5a0d49 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -128,6 +128,7 @@ #define CONFIG_SYS_I2C_BUS 0 #define CONFIG_SYS_I2C_BUS_SELECT 1 #define CONFIG_DRIVER_OMAP34XX_I2C 1 +#define CONFIG_I2C_MULTI_BUS 1
/* * TWL4030
Have you looked at my proposal I sent some hours before your patch?
http://lists.denx.de/pipermail/u-boot/2009-October/063556.html
- Basic I2C functions
- Copyright (c) 2004 Texas Instruments
- Copyright (c) 2004, 2009 Texas Instruments
- This package is free software; you can redistribute it and/or
- modify it under the terms of the license found in the file
I prefer something like I2C_BUS_MAX for this. And move it to header file. Moving it OMAP2 and OMAP3 i2c.h headers will remove the #ifdef, too.
Looking at the other OMAP3 files, the recent syntax seems to be
static struct i2c *i2c_base = (struct i2c *)I2C_DEFAULT_BASE;
Just to be consistent.
- writew(0x2, &i2c->sysc); /* for ES2 after soft reset */ udelay(1000);
- writew(0x0, &i2c->sysc); /* will probably self clear but */
udelay (50000);
- if (readw(&i2c->con) & I2C_CON_EN) {
udelay(50000);
udelay: Are this formatting changes? You are correct, a lot of formatting improvements are needed here. But they should go to an other patch.
/* own address */
- udelay (1000);
- writew(I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE |
- udelay(1000);
Formatting change?
flush_fifo();
- writew(0xFFFF, &i2c->stat);
- writew(0, &i2c->cnt);
/* one byte only */
- writew(1, &i2c->cnt); /* set slave address */
- writew(devaddr, &i2c->sa); /* no stop bit needed here */
udelay (20000);
udelay(20000);
Formatting change?
} } else {if (readw(&i2c->stat) & I2C_STAT_NACK) { i2c_error = 1;
/* read one byte from slave */writew(devaddr, &i2c->sa);
/* need stop bit here */writew(1, &i2c->cnt);
I2C_CON);
&i2c->con);
#else
if (!i2c_error) {
} } flush_fifo();writew(0xFFFF, &i2c->stat); }
- writew(0, &i2c->cnt); return i2c_error;
/* two bytes */
- writew(2, &i2c->cnt); /* set slave address */
- writew(devaddr, &i2c->sa); /* stop bit needed here */
} else { i2c_error = 1; }writew(I2C_STAT_XRDY, &i2c->stat);
udelay (50000);
udelay(50000);
udelay (1000);
udelay(1000);
Formatting change?
} } flush_fifo();writew(0xFFFF, &i2c->stat); if(--eout == 0) /* better leave with error than hang */ break;
if(stat == I2C_STAT_RRDY){stat = readw(&i2c->stat);
readb(I2C_DATA);
readb(&i2c->data);
#else
readw(I2C_DATA);
readw(&i2c->data);
#endif
}else break;writew(I2C_STAT_RRDY, &i2c->stat); udelay(1000);
- if (chip == readw(&i2c->oa)) { return res; }
- writew(chip, &i2c->sa); /* stop bit needed here */
- writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, &i2c->con); /* enough delay for the NACK bit set */
- udelay (50000);
- udelay(50000);
Formatting change?
- if (!(readw(&i2c->stat) & I2C_STAT_NACK)) { res = 0; /* success case */ flush_fifo();
} else {writew(0xFFFF, &i2c->stat);
udelay(20000); wait_for_bb (); } flush_fifo();writew(readw(&i2c->con) | I2C_CON_STP, &i2c->con); /* finish up xfer */
- writew(0, &i2c->cnt); /* don't allow any more data in...we don't want it.*/
- writew(0xFFFF, &i2c->stat); return res;
if (alen > 1) {
return 1; }
Here and above, typo change?
return 1;
Typo change?
udelay (50000);
Formatting change?
udelay(50000);
readw (I2C_STAT));
}readw(&i2c->stat));
- writew(0xFFFF, &i2c->stat); /* clear delayed stuff*/
do { udelay (1000);
} while ( !(status & (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY | I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK |status = readw(&i2c->stat);
readw (I2C_STAT));
readw(&i2c->stat));
} return status; }
Do we need an extern declaration in i2c.h for this? To be able to call it from somewhere else without warning?
- if ((bus < 0) || (bus >= I2C_NUM_IF)) {
As mentioned above, I'd like something like bus max here.
return -1;
- if (bus == 2)
- else
- if (bus == 1)
- else
I would remove the following three functions as they are not needed at the moment (i.e. without command line interface).
- if (i2c == (i2c_t *)I2C_BASE1)
- else
- if (i2c == (i2c_t *)I2C_BASE2)
return 1;
- else
- if (i2c == (i2c_t *)I2C_BASE3)
return 2;
- else
return 0xFFFFFFFF;
- To be Implemented
Ah, thanks for pointing to this. I missed this.
I wonder why arch-omap24xx/i2c.h has no I2C_DEFAULT_BASE (used above now).
Seems the recent syntax is without typedef.
- unsigned short rev; /* 0x00 */
- unsigned short pad_rev; /* 0x02 */
Looking at
include/asm-arm/arch-omap3/cpu.h
the current style is to use resX for padding. Like done below with res1 already. We should stay consistent here.
- unsigned short ie; /* 0x04 */
- unsigned short pad_ie; /* 0x06 */
- unsigned short stat; /* 0x08 */
- unsigned short pad_stat; /* 0x0a */
- unsigned short iv; /* 0x0c */
- unsigned short pad_iv; /* 0x0e */
- unsigned int res1; /* 0x10 */
unsigned short resX[3] instead?
- unsigned short buf; /* 0x14 */
- unsigned short pad_buf; /* 0x16 */
- unsigned short cnt; /* 0x18 */
- unsigned short pad_cnt; /* 0x1a */
- unsigned short data; /* 0x1c */
- unsigned short pad_data; /* 0x1e */
- unsigned short sysc; /* 0x20 */
- unsigned short pad_sysc; /* 0x22 */
- unsigned short con; /* 0x24 */
- unsigned short pad_con; /* 0x26 */
- unsigned short oa; /* 0x28 */
- unsigned short pad_oa; /* 0x2a */
- unsigned short sa; /* 0x2c */
- unsigned short pad_sa; /* 0x2e */
- unsigned short psc; /* 0x30 */
- unsigned short pad_psc; /* 0x32 */
- unsigned short scll; /* 0x34 */
- unsigned short pad_scll; /* 0x36 */
- unsigned short sclh; /* 0x38 */
- unsigned short pad_sclh; /* 0x3a */
- unsigned short systest; /* 0x3c */
- unsigned short pad_systest; /* 0x3e */
+} i2c_t;
/* I2C masks */
Comments from above apply here, too.
+} i2c_t;
/* I2C masks */
Not needed.
While all above are only style questions, what's about the main functionality topic:
Do we have to call i2c_init() for bus 1 and 2 if switching to it? If yes, who does it? For bus 0 it's already in the code. I'd like that the user doesn't have to care about it. Therefore, I added
static unsigned int bus_initialized[3] = {0, 0, 0}; static unsigned int current_bus = 0;
void i2c_init (int speed, int slaveadd) { ... bus_initialized[current_bus] = 1; }
int i2c_set_bus_num(unsigned int bus) { ... current_bus = bus;
if(!bus_initialized[current_bus]) i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); ... }
Do you like to test my patch in attachment?
It is an extension of
to cover arch-omap24xx/i2c.h, too.
Compile tested for omap3_beagle and omap2420h4.
Best regards
Dirk
Subject: [PATCH] OMAP2/3: I2C: Add support for second and third bus From: Dirk Behme dirk.behme@googlemail.com
Add support to use second and third I2C bus, too.
Bus 0 is still the default, but by calling i2c_set_bus_num(1/2) before doing I2C accesses, code can switch to bus 1 and 2, too. Don't forget to switch back afterwards, then.
Signed-off-by: Dirk Behme dirk.behme@googlemail.com ---
Based on Hugo Vincent's patch
http://lists.denx.de/pipermail/u-boot/2009-June/055029.html
(this patch only contains the multibus support)
drivers/i2c/omap24xx_i2c.c | 166 +++++++++++++++++++++--------------- include/asm-arm/arch-omap24xx/i2c.h | 55 ++++++++--- include/asm-arm/arch-omap3/i2c.h | 50 +++++++--- 3 files changed, 172 insertions(+), 99 deletions(-)
Index: u-boot-main/drivers/i2c/omap24xx_i2c.c =================================================================== --- u-boot-main.orig/drivers/i2c/omap24xx_i2c.c +++ u-boot-main/drivers/i2c/omap24xx_i2c.c @@ -29,6 +29,11 @@ static void wait_for_bb (void); static u16 wait_for_pin (void); static void flush_fifo(void);
+static struct i2c *i2c_base = (struct i2c *)I2C_DEFAULT_BASE; + +static unsigned int bus_initialized[3] = {0, 0, 0}; +static unsigned int current_bus = 0; + void i2c_init (int speed, int slaveadd) { int psc, fsscll, fssclh; @@ -95,30 +100,32 @@ void i2c_init (int speed, int slaveadd) sclh = (unsigned int)fssclh; }
- writew(0x2, I2C_SYSC); /* for ES2 after soft reset */ + writew(0x2, &i2c_base->sysc); /* for ES2 after soft reset */ udelay(1000); - writew(0x0, I2C_SYSC); /* will probably self clear but */ + writew(0x0, &i2c_base->sysc); /* will probably self clear but */
- if (readw (I2C_CON) & I2C_CON_EN) { - writew (0, I2C_CON); + if (readw (&i2c_base->con) & I2C_CON_EN) { + writew (0, &i2c_base->con); udelay (50000); }
- writew(psc, I2C_PSC); - writew(scll, I2C_SCLL); - writew(sclh, I2C_SCLH); + writew(psc, &i2c_base->psc); + writew(scll, &i2c_base->scll); + writew(sclh, &i2c_base->sclh);
/* own address */ - writew (slaveadd, I2C_OA); - writew (I2C_CON_EN, I2C_CON); + writew (slaveadd, &i2c_base->oa); + writew (I2C_CON_EN, &i2c_base->con);
/* have to enable intrrupts or OMAP i2c module doesn't work */ writew (I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | - I2C_IE_NACK_IE | I2C_IE_AL_IE, I2C_IE); + I2C_IE_NACK_IE | I2C_IE_AL_IE, &i2c_base->ie); udelay (1000); flush_fifo(); - writew (0xFFFF, I2C_STAT); - writew (0, I2C_CNT); + writew (0xFFFF, &i2c_base->stat); + writew (0, &i2c_base->cnt); + + bus_initialized[current_bus] = 1; }
static int i2c_read_byte (u8 devaddr, u8 regoffset, u8 * value) @@ -130,19 +137,19 @@ static int i2c_read_byte (u8 devaddr, u8 wait_for_bb ();
/* one byte only */ - writew (1, I2C_CNT); + writew (1, &i2c_base->cnt); /* set slave address */ - writew (devaddr, I2C_SA); + writew (devaddr, &i2c_base->sa); /* no stop bit needed here */ - writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX, I2C_CON); + writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX, &i2c_base->con);
if (status & I2C_STAT_XRDY) { /* Important: have to use byte access */ - writeb (regoffset, I2C_DATA); + writeb (regoffset, &i2c_base->data); udelay (20000); - if (readw (I2C_STAT) & I2C_STAT_NACK) { + if (readw (&i2c_base->stat) & I2C_STAT_NACK) { i2c_error = 1; } } else { @@ -151,28 +158,28 @@ static int i2c_read_byte (u8 devaddr, u8
if (!i2c_error) { /* free bus, otherwise we can't use a combined transction */ - writew (0, I2C_CON); - while (readw (I2C_STAT) || (readw (I2C_CON) & I2C_CON_MST)) { + writew (0, &i2c_base->con); + while (readw (&i2c_base->stat) || (readw (&i2c_base->con) & I2C_CON_MST)) { udelay (10000); /* Have to clear pending interrupt to clear I2C_STAT */ - writew (0xFFFF, I2C_STAT); + writew (0xFFFF, &i2c_base->stat); }
wait_for_bb (); /* set slave address */ - writew (devaddr, I2C_SA); + writew (devaddr, &i2c_base->sa); /* read one byte from slave */ - writew (1, I2C_CNT); + writew (1, &i2c_base->cnt); /* need stop bit here */ writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, - I2C_CON); + &i2c_base->con);
status = wait_for_pin (); if (status & I2C_STAT_RRDY) { #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) - *value = readb (I2C_DATA); + *value = readb (&i2c_base->data); #else - *value = readw (I2C_DATA); + *value = readw (&i2c_base->data); #endif udelay (20000); } else { @@ -180,17 +187,17 @@ static int i2c_read_byte (u8 devaddr, u8 }
if (!i2c_error) { - writew (I2C_CON_EN, I2C_CON); - while (readw (I2C_STAT) - || (readw (I2C_CON) & I2C_CON_MST)) { + writew (I2C_CON_EN, &i2c_base->con); + while (readw (&i2c_base->stat) + || (readw (&i2c_base->con) & I2C_CON_MST)) { udelay (10000); - writew (0xFFFF, I2C_STAT); + writew (0xFFFF, &i2c_base->stat); } } } flush_fifo(); - writew (0xFFFF, I2C_STAT); - writew (0, I2C_CNT); + writew (0xFFFF, &i2c_base->stat); + writew (0, &i2c_base->cnt); return i2c_error; }
@@ -203,12 +210,12 @@ static int i2c_write_byte (u8 devaddr, u wait_for_bb ();
/* two bytes */ - writew (2, I2C_CNT); + writew (2, &i2c_base->cnt); /* set slave address */ - writew (devaddr, I2C_SA); + writew (devaddr, &i2c_base->sa); /* stop bit needed here */ writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | - I2C_CON_STP, I2C_CON); + I2C_CON_STP, &i2c_base->con);
/* wait until state change */ status = wait_for_pin (); @@ -216,24 +223,24 @@ static int i2c_write_byte (u8 devaddr, u if (status & I2C_STAT_XRDY) { #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) /* send out 1 byte */ - writeb (regoffset, I2C_DATA); - writew (I2C_STAT_XRDY, I2C_STAT); + writeb (regoffset, &i2c_base->data); + writew (I2C_STAT_XRDY, &i2c_base->stat);
status = wait_for_pin (); if ((status & I2C_STAT_XRDY)) { /* send out next 1 byte */ - writeb (value, I2C_DATA); - writew (I2C_STAT_XRDY, I2C_STAT); + writeb (value, &i2c_base->data); + writew (I2C_STAT_XRDY, &i2c_base->stat); } else { i2c_error = 1; } #else /* send out two bytes */ - writew ((value << 8) + regoffset, I2C_DATA); + writew ((value << 8) + regoffset, &i2c_base->data); #endif /* must have enough delay to allow BB bit to go low */ udelay (50000); - if (readw (I2C_STAT) & I2C_STAT_NACK) { + if (readw (&i2c_base->stat) & I2C_STAT_NACK) { i2c_error = 1; } } else { @@ -243,18 +250,18 @@ static int i2c_write_byte (u8 devaddr, u if (!i2c_error) { int eout = 200;
- writew (I2C_CON_EN, I2C_CON); - while ((stat = readw (I2C_STAT)) || (readw (I2C_CON) & I2C_CON_MST)) { + writew (I2C_CON_EN, &i2c_base->con); + while ((stat = readw (&i2c_base->stat)) || (readw (&i2c_base->con) & I2C_CON_MST)) { udelay (1000); /* have to read to clear intrrupt */ - writew (0xFFFF, I2C_STAT); + writew (0xFFFF, &i2c_base->stat); if(--eout == 0) /* better leave with error than hang */ break; } } flush_fifo(); - writew (0xFFFF, I2C_STAT); - writew (0, I2C_CNT); + writew (0xFFFF, &i2c_base->stat); + writew (0, &i2c_base->cnt); return i2c_error; }
@@ -265,14 +272,14 @@ static void flush_fifo(void) * you get a bus error */ while(1){ - stat = readw(I2C_STAT); + stat = readw(&i2c_base->stat); if(stat == I2C_STAT_RRDY){ #if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX) - readb(I2C_DATA); + readb(&i2c_base->data); #else - readw(I2C_DATA); + readw(&i2c_base->data); #endif - writew(I2C_STAT_RRDY,I2C_STAT); + writew(I2C_STAT_RRDY,&i2c_base->stat); udelay(1000); }else break; @@ -283,7 +290,7 @@ int i2c_probe (uchar chip) { int res = 1; /* default = fail */
- if (chip == readw (I2C_OA)) { + if (chip == readw (&i2c_base->oa)) { return res; }
@@ -291,27 +298,27 @@ int i2c_probe (uchar chip) wait_for_bb ();
/* try to read one byte */ - writew (1, I2C_CNT); + writew (1, &i2c_base->cnt); /* set slave address */ - writew (chip, I2C_SA); + writew (chip, &i2c_base->sa); /* stop bit needed here */ - writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, I2C_CON); + writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, &i2c_base->con); /* enough delay for the NACK bit set */ udelay (50000);
- if (!(readw (I2C_STAT) & I2C_STAT_NACK)) { + if (!(readw (&i2c_base->stat) & I2C_STAT_NACK)) { res = 0; /* success case */ flush_fifo(); - writew(0xFFFF, I2C_STAT); + writew(0xFFFF, &i2c_base->stat); } else { - writew(0xFFFF, I2C_STAT); /* failue, clear sources*/ - writew (readw (I2C_CON) | I2C_CON_STP, I2C_CON); /* finish up xfer */ + writew(0xFFFF, &i2c_base->stat); /* failue, clear sources*/ + writew (readw (&i2c_base->con) | I2C_CON_STP, &i2c_base->con); /* finish up xfer */ udelay(20000); wait_for_bb (); } flush_fifo(); - writew (0, I2C_CNT); /* don't allow any more data in...we don't want it.*/ - writew(0xFFFF, I2C_STAT); + writew (0, &i2c_base->cnt); /* don't allow any more data in...we don't want it.*/ + writew(0xFFFF, &i2c_base->stat); return res; }
@@ -370,17 +377,17 @@ static void wait_for_bb (void) int timeout = 10; u16 stat;
- writew(0xFFFF, I2C_STAT); /* clear current interruts...*/ - while ((stat = readw (I2C_STAT) & I2C_STAT_BB) && timeout--) { - writew (stat, I2C_STAT); + writew(0xFFFF, &i2c_base->stat); /* clear current interruts...*/ + while ((stat = readw (&i2c_base->stat) & I2C_STAT_BB) && timeout--) { + writew (stat, &i2c_base->stat); udelay (50000); }
if (timeout <= 0) { printf ("timed out in wait_for_bb: I2C_STAT=%x\n", - readw (I2C_STAT)); + readw (&i2c_base->stat)); } - writew(0xFFFF, I2C_STAT); /* clear delayed stuff*/ + writew(0xFFFF, &i2c_base->stat); /* clear delayed stuff*/ }
static u16 wait_for_pin (void) @@ -390,7 +397,7 @@ static u16 wait_for_pin (void)
do { udelay (1000); - status = readw (I2C_STAT); + status = readw (&i2c_base->stat); } while ( !(status & (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY | I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK | @@ -398,8 +405,33 @@ static u16 wait_for_pin (void)
if (timeout <= 0) { printf ("timed out in wait_for_pin: I2C_STAT=%x\n", - readw (I2C_STAT)); - writew(0xFFFF, I2C_STAT); + readw (&i2c_base->stat)); + writew(0xFFFF, &i2c_base->stat); } return status; } + +int i2c_set_bus_num(unsigned int bus) +{ + if ((bus < 0) || (bus >= I2C_BUS_MAX)) { + printf("Bad bus: %d\n", bus); + return -1; + } + +#ifdef CONFIG_OMAP34XX + if (bus == 2) + i2c_base = (struct i2c *)I2C_BASE3; + else +#endif + if (bus == 1) + i2c_base = (struct i2c *)I2C_BASE2; + else + i2c_base = (struct i2c *)I2C_BASE1; + + current_bus = bus; + + if(!bus_initialized[current_bus]) + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + return 0; +} Index: u-boot-main/include/asm-arm/arch-omap3/i2c.h =================================================================== --- u-boot-main.orig/include/asm-arm/arch-omap3/i2c.h +++ u-boot-main/include/asm-arm/arch-omap3/i2c.h @@ -25,21 +25,39 @@
-#define I2C_REV (I2C_DEFAULT_BASE + 0x00) -#define I2C_IE (I2C_DEFAULT_BASE + 0x04) -#define I2C_STAT (I2C_DEFAULT_BASE + 0x08) -#define I2C_IV (I2C_DEFAULT_BASE + 0x0c) -#define I2C_BUF (I2C_DEFAULT_BASE + 0x14) -#define I2C_CNT (I2C_DEFAULT_BASE + 0x18) -#define I2C_DATA (I2C_DEFAULT_BASE + 0x1c) -#define I2C_SYSC (I2C_DEFAULT_BASE + 0x20) -#define I2C_CON (I2C_DEFAULT_BASE + 0x24) -#define I2C_OA (I2C_DEFAULT_BASE + 0x28) -#define I2C_SA (I2C_DEFAULT_BASE + 0x2c) -#define I2C_PSC (I2C_DEFAULT_BASE + 0x30) -#define I2C_SCLL (I2C_DEFAULT_BASE + 0x34) -#define I2C_SCLH (I2C_DEFAULT_BASE + 0x38) -#define I2C_SYSTEST (I2C_DEFAULT_BASE + 0x3c) +struct i2c { + unsigned short rev; /* 0x00 */ + unsigned short res1; + unsigned short ie; /* 0x04 */ + unsigned short res2; + unsigned short stat; /* 0x08 */ + unsigned short res3; + unsigned short iv; /* 0x0C */ + unsigned short res4[3]; + unsigned short buf; /* 0x14 */ + unsigned short res5; + unsigned short cnt; /* 0x18 */ + unsigned short res6; + unsigned short data; /* 0x1C */ + unsigned short res7; + unsigned short sysc; /* 0x20 */ + unsigned short res8; + unsigned short con; /* 0x24 */ + unsigned short res9; + unsigned short oa; /* 0x28 */ + unsigned short res10; + unsigned short sa; /* 0x2C */ + unsigned short res11; + unsigned short psc; /* 0x30 */ + unsigned short res12; + unsigned short scll; /* 0x34 */ + unsigned short res13; + unsigned short sclh; /* 0x38 */ + unsigned short res14; + unsigned short systest; /* 0x3c */ +}; + +#define I2C_BUS_MAX 3
/* I2C masks */
@@ -181,4 +199,6 @@ #define I2C_PSC_MAX 0x0f #define I2C_PSC_MIN 0x00
+extern int i2c_set_bus_num(unsigned int); + #endif /* _I2C_H_ */ Index: u-boot-main/include/asm-arm/arch-omap24xx/i2c.h =================================================================== --- u-boot-main.orig/include/asm-arm/arch-omap24xx/i2c.h +++ u-boot-main/include/asm-arm/arch-omap24xx/i2c.h @@ -6,7 +6,7 @@ * project. * * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as + * moify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of * the License, or (at your option) any later version. * @@ -23,24 +23,44 @@ #ifndef _OMAP24XX_I2C_H_ #define _OMAP24XX_I2C_H_
-#define I2C_REV (I2C_BASE + 0x00) -#define I2C_IE (I2C_BASE + 0x04) -#define I2C_STAT (I2C_BASE + 0x08) -#define I2C_IV (I2C_BASE + 0x0c) -#define I2C_BUF (I2C_BASE + 0x14) -#define I2C_CNT (I2C_BASE + 0x18) -#define I2C_DATA (I2C_BASE + 0x1c) -#define I2C_SYSC (I2C_BASE + 0x20) -#define I2C_CON (I2C_BASE + 0x24) -#define I2C_OA (I2C_BASE + 0x28) -#define I2C_SA (I2C_BASE + 0x2c) -#define I2C_PSC (I2C_BASE + 0x30) -#define I2C_SCLL (I2C_BASE + 0x34) -#define I2C_SCLH (I2C_BASE + 0x38) -#define I2C_SYSTEST (I2C_BASE + 0x3c) +#define I2C_DEFAULT_BASE I2C_BASE1 + +struct i2c { + unsigned short rev; /* 0x00 */ + unsigned short res1; + unsigned short ie; /* 0x04 */ + unsigned short res2; + unsigned short stat; /* 0x08 */ + unsigned short res3; + unsigned short iv; /* 0x0C */ + unsigned short res4[3]; + unsigned short buf; /* 0x14 */ + unsigned short res5; + unsigned short cnt; /* 0x18 */ + unsigned short res6; + unsigned short data; /* 0x1C */ + unsigned short res7; + unsigned short sysc; /* 0x20 */ + unsigned short res8; + unsigned short con; /* 0x24 */ + unsigned short res9; + unsigned short oa; /* 0x28 */ + unsigned short res10; + unsigned short sa; /* 0x2C */ + unsigned short res11; + unsigned short psc; /* 0x30 */ + unsigned short res12; + unsigned short scll; /* 0x34 */ + unsigned short res13; + unsigned short sclh; /* 0x38 */ + unsigned short res14; + unsigned short systest; /* 0x3c */ +}; + +#define I2C_BUS_MAX 2
/* I2C masks */
@@ -147,5 +167,6 @@ #define I2C_PSC_MAX 0x0f #define I2C_PSC_MIN 0x00
#endif
Sorry. I did not. Not surprisingly it looks similar.
The formatting changes you mentioned were part of the original cherry-picked commit. I tried to leave as much of the original commit intact as possible. I ran but ignored the output of checkpatch.. The biggest complaint it has is with 80 char lines.
I looked over your patch. It looks like an improvement to mine.
I'm all for dropping mine and using yours. I will run test yours.
Do you have a zippy board that you can use to test the 2nd bus ?
Tom
Dirk,
Some feedback.
No regressions on MAKEALL arm
I ran tested your patch Zoom1 and Beagle. Default i2c looks good. I did not test the multibus support.
Looks good, please officially submit your patch.
Tom
Tom _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hello Dirk,
Yep, I2C_BUS_MAX would be better.
readw (I2C_STAT));
readw(&i2c->stat));
} return status; }
Hmm.. isn;t it declared in i2c.h?
return -1;
- if (bus == 2)
- else
- if (bus == 1)
- else
Hmm... really? If someone uses multibus support, this functions are needed, or?
- else
return 1;
- else
return 2;
- else
return 0xFFFFFFFF;
- To be Implemented
Not needed.
I solved this in the multibus_v2 branch, see:
http://git.denx.de/?p=u-boot/u-boot-i2c.git;a=shortlog;h=refs/heads/multibus...
i2c_init() gets just called if switching to an I2C bus. This is done in i2c_set_bus_num()
http://git.denx.de/?p=u-boot/u-boot-i2c.git;a=blob;f=drivers/i2c/i2c_core.c;...
pro:
a I2C adapter gets only initialized, if used, and there is the option to extend this functionality to: - when switching to another i2c adapter call (a not yet existing) i2c adapter deinit function ...
Ah, you also tend to this direction ;-) Great!
bye Heiko
Hi Heiko,
Well, most probably yes. But I was not really looking for multibus support ;)
The functionality needed for Zippy I'm currently working on is just to be able to do
i2c_get_bus_num(1); /* Switch to bus 1 */ ... do some stuff on bus 1 ... i2c_get_bus_num(0); /* Switch back to default bus 0 */
And for this having only i2c_get_bus_num() is sufficient. And the only tested ;)
- else
return 1;
- else
return 2;
- else
return 0xFFFFFFFF;
- To be Implemented
Looks like we have to merge that with what is in this patch somehow. What are your plans with that branch? Is it intended to go into mainline, soon?
It seems to me that multibus_v2 and this patch are somehow orthogonal (but yes, they will need some merging). Regarding omap24xx_i2c.c, multibus_v2 seems to deal mainly with the API stuff
http://git.denx.de/?p=u-boot/u-boot-i2c.git;a=blobdiff;f=drivers/i2c/omap24x...
while the main part of this patch is to replace all hard coded registers by the ability to switch to an other bus.
I will send an updated patch with fixing at least the review comments, soon.
Best regards
Dirk
Hello Dirk,
I have to do some more work, before this is ready to go in mainline...
Yep, I hold the multibus_v2 branch in sync with mainline.
Yep, I adapt this driver only for working with this new API.
OK, thanks.
bye Heiko
Hi Heiko,
Hello Dirk,
Hmm, do you like to push
http://lists.denx.de/pipermail/u-boot/2009-November/063658.html
to I2C git main branch then?
Or are you fine that we push it to u-boot-ti?
Or?
Thanks
Dirk
Hello Dirk,
Or?
It;s in u-boot-i2c next, see
http://git.denx.de/?p=u-boot/u-boot-i2c.git;a=shortlog;h=refs/heads/next
because I think it is for the next merge window ...
bye Heiko
Dirk Behme
Heiko Schocher
Tom
Tom Rix
