[U-Boot] [PATCH] i.MX6: provide functional names for CCGRx bit fields
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/cpu/armv7/mx6/clock.c | 10 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 358 +++++++++++++++--------------- 2 files changed, 185 insertions(+), 183 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index fddb373..ed2c913 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -43,9 +43,9 @@ void enable_usboh3_clk(unsigned char enable)
reg = __raw_readl(&imx_ccm->CCGR6); if (enable) - reg |= MXC_CCM_CCGR_CG_MASK << MXC_CCM_CCGR0_CG0_OFFSET; + reg |= MXC_CCM_CCGR6_USBOH3_MASK; else - reg &= ~(MXC_CCM_CCGR_CG_MASK << MXC_CCM_CCGR0_CG0_OFFSET); + reg &= ~(MXC_CCM_CCGR6_USBOH3_MASK); __raw_writel(reg, &imx_ccm->CCGR6);
} @@ -59,7 +59,9 @@ int enable_i2c_clk(unsigned char enable, unsigned i2c_num)
if (i2c_num > 2) return -EINVAL; - mask = MXC_CCM_CCGR_CG_MASK << ((i2c_num + 3) << 1); + + mask = MXC_CCM_CCGR_CG_MASK + << (MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET + (i2c_num << 1)); reg = __raw_readl(&imx_ccm->CCGR2); if (enable) reg |= mask; @@ -321,7 +323,7 @@ int enable_sata_clock(void)
/* Enable sata clock */ reg = readl(&imx_ccm->CCGR5); /* CCGR5 */ - reg |= MXC_CCM_CCGR5_CG2_MASK; + reg |= MXC_CCM_CCGR5_SATA_MASK; writel(reg, &imx_ccm->CCGR5);
/* Enable PLLs */ diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 8388e38..f066461 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -395,185 +395,185 @@ struct mxc_ccm_reg { /* Define the bits in registers CCGRx */ #define MXC_CCM_CCGR_CG_MASK 3
-#define MXC_CCM_CCGR0_CG15_OFFSET 30 -#define MXC_CCM_CCGR0_CG15_MASK (0x3 << 30) -#define MXC_CCM_CCGR0_CG14_OFFSET 28 -#define MXC_CCM_CCGR0_CG14_MASK (0x3 << 28) -#define MXC_CCM_CCGR0_CG13_OFFSET 26 -#define MXC_CCM_CCGR0_CG13_MASK (0x3 << 26) -#define MXC_CCM_CCGR0_CG12_OFFSET 24 -#define MXC_CCM_CCGR0_CG12_MASK (0x3 << 24) -#define MXC_CCM_CCGR0_CG11_OFFSET 22 -#define MXC_CCM_CCGR0_CG11_MASK (0x3 << 22) -#define MXC_CCM_CCGR0_CG10_OFFSET 20 -#define MXC_CCM_CCGR0_CG10_MASK (0x3 << 20) -#define MXC_CCM_CCGR0_CG9_OFFSET 18 -#define MXC_CCM_CCGR0_CG9_MASK (0x3 << 18) -#define MXC_CCM_CCGR0_CG8_OFFSET 16 -#define MXC_CCM_CCGR0_CG8_MASK (0x3 << 16) -#define MXC_CCM_CCGR0_CG7_OFFSET 14 -#define MXC_CCM_CCGR0_CG6_OFFSET 12 -#define MXC_CCM_CCGR0_CG5_OFFSET 10 -#define MXC_CCM_CCGR0_CG5_MASK (0x3 << 10) -#define MXC_CCM_CCGR0_CG4_OFFSET 8 -#define MXC_CCM_CCGR0_CG4_MASK (0x3 << 8) -#define MXC_CCM_CCGR0_CG3_OFFSET 6 -#define MXC_CCM_CCGR0_CG3_MASK (0x3 << 6) -#define MXC_CCM_CCGR0_CG2_OFFSET 4 -#define MXC_CCM_CCGR0_CG2_MASK (0x3 << 4) -#define MXC_CCM_CCGR0_CG1_OFFSET 2 -#define MXC_CCM_CCGR0_CG1_MASK (0x3 << 2) -#define MXC_CCM_CCGR0_CG0_OFFSET 0 -#define MXC_CCM_CCGR0_CG0_MASK 3 - -#define MXC_CCM_CCGR1_CG15_OFFSET 30 -#define MXC_CCM_CCGR1_CG14_OFFSET 28 -#define MXC_CCM_CCGR1_CG13_OFFSET 26 -#define MXC_CCM_CCGR1_CG12_OFFSET 24 -#define MXC_CCM_CCGR1_CG11_OFFSET 22 -#define MXC_CCM_CCGR1_CG10_OFFSET 20 -#define MXC_CCM_CCGR1_CG9_OFFSET 18 -#define MXC_CCM_CCGR1_CG8_OFFSET 16 -#define MXC_CCM_CCGR1_CG7_OFFSET 14 -#define MXC_CCM_CCGR1_CG6_OFFSET 12 -#define MXC_CCM_CCGR1_CG5_OFFSET 10 -#define MXC_CCM_CCGR1_CG4_OFFSET 8 -#define MXC_CCM_CCGR1_CG3_OFFSET 6 -#define MXC_CCM_CCGR1_CG2_OFFSET 4 -#define MXC_CCM_CCGR1_CG1_OFFSET 2 -#define MXC_CCM_CCGR1_CG0_OFFSET 0 - -#define MXC_CCM_CCGR2_CG15_OFFSET 30 -#define MXC_CCM_CCGR2_CG14_OFFSET 28 -#define MXC_CCM_CCGR2_CG13_OFFSET 26 -#define MXC_CCM_CCGR2_CG12_OFFSET 24 -#define MXC_CCM_CCGR2_CG11_OFFSET 22 -#define MXC_CCM_CCGR2_CG10_OFFSET 20 -#define MXC_CCM_CCGR2_CG9_OFFSET 18 -#define MXC_CCM_CCGR2_CG8_OFFSET 16 -#define MXC_CCM_CCGR2_CG7_OFFSET 14 -#define MXC_CCM_CCGR2_CG6_OFFSET 12 -#define MXC_CCM_CCGR2_CG5_OFFSET 10 -#define MXC_CCM_CCGR2_CG4_OFFSET 8 -#define MXC_CCM_CCGR2_CG3_OFFSET 6 -#define MXC_CCM_CCGR2_CG2_OFFSET 4 -#define MXC_CCM_CCGR2_CG1_OFFSET 2 -#define MXC_CCM_CCGR2_CG0_OFFSET 0 - -#define MXC_CCM_CCGR3_CG15_OFFSET 30 -#define MXC_CCM_CCGR3_CG14_OFFSET 28 -#define MXC_CCM_CCGR3_CG13_OFFSET 26 -#define MXC_CCM_CCGR3_CG12_OFFSET 24 -#define MXC_CCM_CCGR3_CG11_OFFSET 22 -#define MXC_CCM_CCGR3_CG10_OFFSET 20 -#define MXC_CCM_CCGR3_CG9_OFFSET 18 -#define MXC_CCM_CCGR3_CG8_OFFSET 16 -#define MXC_CCM_CCGR3_CG7_OFFSET 14 -#define MXC_CCM_CCGR3_CG6_OFFSET 12 -#define MXC_CCM_CCGR3_CG5_OFFSET 10 -#define MXC_CCM_CCGR3_CG4_OFFSET 8 -#define MXC_CCM_CCGR3_CG3_OFFSET 6 -#define MXC_CCM_CCGR3_CG2_OFFSET 4 -#define MXC_CCM_CCGR3_CG1_OFFSET 2 -#define MXC_CCM_CCGR3_CG0_OFFSET 0 - -#define MXC_CCM_CCGR4_CG15_OFFSET 30 -#define MXC_CCM_CCGR4_CG14_OFFSET 28 -#define MXC_CCM_CCGR4_CG13_OFFSET 26 -#define MXC_CCM_CCGR4_CG12_OFFSET 24 -#define MXC_CCM_CCGR4_CG11_OFFSET 22 -#define MXC_CCM_CCGR4_CG10_OFFSET 20 -#define MXC_CCM_CCGR4_CG9_OFFSET 18 -#define MXC_CCM_CCGR4_CG8_OFFSET 16 -#define MXC_CCM_CCGR4_CG7_OFFSET 14 -#define MXC_CCM_CCGR4_CG6_OFFSET 12 -#define MXC_CCM_CCGR4_CG5_OFFSET 10 -#define MXC_CCM_CCGR4_CG4_OFFSET 8 -#define MXC_CCM_CCGR4_CG3_OFFSET 6 -#define MXC_CCM_CCGR4_CG2_OFFSET 4 -#define MXC_CCM_CCGR4_CG1_OFFSET 2 -#define MXC_CCM_CCGR4_CG0_OFFSET 0 - -#define MXC_CCM_CCGR5_CG15_OFFSET 30 -#define MXC_CCM_CCGR5_CG14_OFFSET 28 -#define MXC_CCM_CCGR5_CG14_MASK (0x3 << 28) -#define MXC_CCM_CCGR5_CG13_OFFSET 26 -#define MXC_CCM_CCGR5_CG13_MASK (0x3 << 26) -#define MXC_CCM_CCGR5_CG12_OFFSET 24 -#define MXC_CCM_CCGR5_CG12_MASK (0x3 << 24) -#define MXC_CCM_CCGR5_CG11_OFFSET 22 -#define MXC_CCM_CCGR5_CG11_MASK (0x3 << 22) -#define MXC_CCM_CCGR5_CG10_OFFSET 20 -#define MXC_CCM_CCGR5_CG10_MASK (0x3 << 20) -#define MXC_CCM_CCGR5_CG9_OFFSET 18 -#define MXC_CCM_CCGR5_CG9_MASK (0x3 << 18) -#define MXC_CCM_CCGR5_CG8_OFFSET 16 -#define MXC_CCM_CCGR5_CG8_MASK (0x3 << 16) -#define MXC_CCM_CCGR5_CG7_OFFSET 14 -#define MXC_CCM_CCGR5_CG7_MASK (0x3 << 14) -#define MXC_CCM_CCGR5_CG6_OFFSET 12 -#define MXC_CCM_CCGR5_CG6_MASK (0x3 << 12) -#define MXC_CCM_CCGR5_CG5_OFFSET 10 -#define MXC_CCM_CCGR5_CG4_OFFSET 8 -#define MXC_CCM_CCGR5_CG3_OFFSET 6 -#define MXC_CCM_CCGR5_CG2_OFFSET 4 -#define MXC_CCM_CCGR5_CG2_MASK (0x3 << 4) -#define MXC_CCM_CCGR5_CG1_OFFSET 2 -#define MXC_CCM_CCGR5_CG0_OFFSET 0 - -#define MXC_CCM_CCGR6_CG15_OFFSET 30 -#define MXC_CCM_CCGR6_CG14_OFFSET 28 -#define MXC_CCM_CCGR6_CG14_MASK (0x3 << 28) -#define MXC_CCM_CCGR6_CG13_OFFSET 26 -#define MXC_CCM_CCGR6_CG13_MASK (0x3 << 26) -#define MXC_CCM_CCGR6_CG12_OFFSET 24 -#define MXC_CCM_CCGR6_CG12_MASK (0x3 << 24) -#define MXC_CCM_CCGR6_CG11_OFFSET 22 -#define MXC_CCM_CCGR6_CG11_MASK (0x3 << 22) -#define MXC_CCM_CCGR6_CG10_OFFSET 20 -#define MXC_CCM_CCGR6_CG10_MASK (0x3 << 20) -#define MXC_CCM_CCGR6_CG9_OFFSET 18 -#define MXC_CCM_CCGR6_CG9_MASK (0x3 << 18) -#define MXC_CCM_CCGR6_CG8_OFFSET 16 -#define MXC_CCM_CCGR6_CG8_MASK (0x3 << 16) -#define MXC_CCM_CCGR6_CG7_OFFSET 14 -#define MXC_CCM_CCGR6_CG7_MASK (0x3 << 14) -#define MXC_CCM_CCGR6_CG6_OFFSET 12 -#define MXC_CCM_CCGR6_CG6_MASK (0x3 << 12) -#define MXC_CCM_CCGR6_CG5_OFFSET 10 -#define MXC_CCM_CCGR6_CG4_OFFSET 8 -#define MXC_CCM_CCGR6_CG3_OFFSET 6 -#define MXC_CCM_CCGR6_CG2_OFFSET 4 -#define MXC_CCM_CCGR6_CG2_MASK (0x3 << 4) -#define MXC_CCM_CCGR6_CG1_OFFSET 2 -#define MXC_CCM_CCGR6_CG0_OFFSET 0 - -#define MXC_CCM_CCGR7_CG15_OFFSET 30 -#define MXC_CCM_CCGR7_CG14_OFFSET 28 -#define MXC_CCM_CCGR7_CG14_MASK (0x3 << 28) -#define MXC_CCM_CCGR7_CG13_OFFSET 26 -#define MXC_CCM_CCGR7_CG13_MASK (0x3 << 26) -#define MXC_CCM_CCGR7_CG12_OFFSET 24 -#define MXC_CCM_CCGR7_CG12_MASK (0x3 << 24) -#define MXC_CCM_CCGR7_CG11_OFFSET 22 -#define MXC_CCM_CCGR7_CG11_MASK (0x3 << 22) -#define MXC_CCM_CCGR7_CG10_OFFSET 20 -#define MXC_CCM_CCGR7_CG10_MASK (0x3 << 20) -#define MXC_CCM_CCGR7_CG9_OFFSET 18 -#define MXC_CCM_CCGR7_CG9_MASK (0x3 << 18) -#define MXC_CCM_CCGR7_CG8_OFFSET 16 -#define MXC_CCM_CCGR7_CG8_MASK (0x3 << 16) -#define MXC_CCM_CCGR7_CG7_OFFSET 14 -#define MXC_CCM_CCGR7_CG7_MASK (0x3 << 14) -#define MXC_CCM_CCGR7_CG6_OFFSET 12 -#define MXC_CCM_CCGR7_CG6_MASK (0x3 << 12) -#define MXC_CCM_CCGR7_CG5_OFFSET 10 -#define MXC_CCM_CCGR7_CG4_OFFSET 8 -#define MXC_CCM_CCGR7_CG3_OFFSET 6 -#define MXC_CCM_CCGR7_CG2_OFFSET 4 -#define MXC_CCM_CCGR7_CG2_MASK (0x3 << 4) -#define MXC_CCM_CCGR7_CG1_OFFSET 2 -#define MXC_CCM_CCGR7_CG0_OFFSET 0 +#define MXC_CCM_CCGR0_AIPS_TZ1_OFFSET 0 +#define MXC_CCM_CCGR0_AIPS_TZ1_MASK (3<<MXC_CCM_CCGR0_AIPS_TZ1_OFFSET) +#define MXC_CCM_CCGR0_AIPS_TZ2_OFFSET 2 +#define MXC_CCM_CCGR0_AIPS_TZ2_MASK (3<<MXC_CCM_CCGR0_AIPS_TZ2_OFFSET) +#define MXC_CCM_CCGR0_APBHDMA HCLK_OFFSET 4 +#define MXC_CCM_CCGR0_AMASK (3<<MXC_CCM_CCGR0_APBHDMA) +#define MXC_CCM_CCGR0_ASRC_OFFSET 6 +#define MXC_CCM_CCGR0_ASRC_MASK (3<<MXC_CCM_CCGR0_ASRC_OFFSET) +#define MXC_CCM_CCGR0_CAAM_SECURE_MEM_OFFSET 8 +#define MXC_CCM_CCGR0_CAAM_SECURE_MEM_MASK (3<<MXC_CCM_CCGR0_CAAM_SECURE_MEM_OFFSET) +#define MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_OFFSET 10 +#define MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_MASK (3<<MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_OFFSET) +#define MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_OFFSET 12 +#define MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_MASK (3<<MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_OFFSET) +#define MXC_CCM_CCGR0_CAN1_OFFSET 14 +#define MXC_CCM_CCGR0_CAN1_MASK (3<<MXC_CCM_CCGR0_CAN1_OFFSET) +#define MXC_CCM_CCGR0_CAN1_SERIAL_OFFSET 16 +#define MXC_CCM_CCGR0_CAN1_SERIAL_MASK (3<<MXC_CCM_CCGR0_CAN1_SERIAL_OFFSET) +#define MXC_CCM_CCGR0_CAN2_OFFSET 18 +#define MXC_CCM_CCGR0_CAN2_MASK (3<<MXC_CCM_CCGR0_CAN2_OFFSET) +#define MXC_CCM_CCGR0_CAN2_SERIAL_OFFSET 20 +#define MXC_CCM_CCGR0_CAN2_SERIAL_MASK (3<<MXC_CCM_CCGR0_CAN2_SERIAL_OFFSET) +#define MXC_CCM_CCGR0_CHEETAH_DBG_CLK_OFFSET 22 +#define MXC_CCM_CCGR0_CHEETAH_DBG_CLK_MASK (3<<MXC_CCM_CCGR0_CHEETAH_DBG_CLK_OFFSET) +#define MXC_CCM_CCGR0_DCIC1_OFFSET 24 +#define MXC_CCM_CCGR0_DCIC1_MASK (3<<MXC_CCM_CCGR0_DCIC1_OFFSET) +#define MXC_CCM_CCGR0_DCIC2_OFFSET 26 +#define MXC_CCM_CCGR0_DCIC2_MASK (3<<MXC_CCM_CCGR0_DCIC2_OFFSET) +#define MXC_CCM_CCGR0_DTCP_OFFSET 28 +#define MXC_CCM_CCGR0_DTCP_MASK (3<<MXC_CCM_CCGR0_DTCP_OFFSET) + +#define MXC_CCM_CCGR1_ECSPI1S_OFFSET 0 +#define MXC_CCM_CCGR1_ECSPI1S_MASK (3<<MXC_CCM_CCGR1_ECSPI1S_OFFSET) +#define MXC_CCM_CCGR1_ECSPI2S_OFFSET 2 +#define MXC_CCM_CCGR1_ECSPI2S_MASK (3<<MXC_CCM_CCGR1_ECSPI2S_OFFSET) +#define MXC_CCM_CCGR1_ECSPI3S_OFFSET 4 +#define MXC_CCM_CCGR1_ECSPI3S_MASK (3<<MXC_CCM_CCGR1_ECSPI3S_OFFSET) +#define MXC_CCM_CCGR1_ECSPI4S_OFFSET 6 +#define MXC_CCM_CCGR1_ECSPI4S_MASK (3<<MXC_CCM_CCGR1_ECSPI4S_OFFSET) +#define MXC_CCM_CCGR1_ECSPI5S_OFFSET 8 +#define MXC_CCM_CCGR1_ECSPI5S_MASK (3<<MXC_CCM_CCGR1_ECSPI5S_OFFSET) +#define MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET 10 +#define MXC_CCM_CCGR1_ENET_CLK_ENABLE_MASK (3<<MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET) +#define MXC_CCM_CCGR1_EPIT1S_OFFSET 12 +#define MXC_CCM_CCGR1_EPIT1S_MASK (3<<MXC_CCM_CCGR1_EPIT1S_OFFSET) +#define MXC_CCM_CCGR1_EPIT2S_OFFSET 14 +#define MXC_CCM_CCGR1_EPIT2S_MASK (3<<MXC_CCM_CCGR1_EPIT2S_OFFSET) +#define MXC_CCM_CCGR1_ESAIS_OFFSET 16 +#define MXC_CCM_CCGR1_ESAIS_MASK (3<<MXC_CCM_CCGR1_ESAIS_OFFSET) +#define MXC_CCM_CCGR1_GPT_BUS_OFFSET 20 +#define MXC_CCM_CCGR1_GPT_BUS_MASK (3<<MXC_CCM_CCGR1_GPT_BUS_OFFSET) +#define MXC_CCM_CCGR1_GPT_SERIAL_OFFSET 22 +#define MXC_CCM_CCGR1_GPT_SERIAL_MASK (3<<MXC_CCM_CCGR1_GPT_SERIAL_OFFSET) +#define MXC_CCM_CCGR1_GPU2D_OFFSET 24 +#define MXC_CCM_CCGR1_GPU2D_MASK (3<<MXC_CCM_CCGR1_GPU2D_OFFSET) +#define MXC_CCM_CCGR1_GPU3D_OFFSET 26 +#define MXC_CCM_CCGR1_GPU3D_MASK (3<<MXC_CCM_CCGR1_GPU3D_OFFSET) + +#define MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_OFFSET 0 +#define MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK (3<<MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_OFFSET) +#define MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_OFFSET 4 +#define MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK (3<<MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_OFFSET) +#define MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET 6 +#define MXC_CCM_CCGR2_I2C1_SERIAL_MASK (3<<MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET) +#define MXC_CCM_CCGR2_I2C2_SERIAL_OFFSET 8 +#define MXC_CCM_CCGR2_I2C2_SERIAL_MASK (3<<MXC_CCM_CCGR2_I2C2_SERIAL_OFFSET) +#define MXC_CCM_CCGR2_I2C3_SERIAL_OFFSET 10 +#define MXC_CCM_CCGR2_I2C3_SERIAL_MASK (3<<MXC_CCM_CCGR2_I2C3_SERIAL_OFFSET) +#define MXC_CCM_CCGR2_OCOTP_CTRL_OFFSET 12 +#define MXC_CCM_CCGR2_OCOTP_CTRL_MASK (3<<MXC_CCM_CCGR2_OCOTP_CTRL_OFFSET) +#define MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_OFFSET 14 +#define MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK (3<<MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_OFFSET) +#define MXC_CCM_CCGR2_IPMUX1_OFFSET 16 +#define MXC_CCM_CCGR2_IPMUX1_MASK (3<<MXC_CCM_CCGR2_IPMUX1_OFFSET) +#define MXC_CCM_CCGR2_IPMUX2_OFFSET 18 +#define MXC_CCM_CCGR2_IPMUX2_MASK (3<<MXC_CCM_CCGR2_IPMUX2_OFFSET) +#define MXC_CCM_CCGR2_IPMUX3_OFFSET 20 +#define MXC_CCM_CCGR2_IPMUX3_MASK (3<<MXC_CCM_CCGR2_IPMUX3_OFFSET) +#define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_OFFSET 22 +#define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_MASK (3<<MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_OFFSET) +#define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_OFFSET 24 +#define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_MASK (3<<MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_OFFSET) +#define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET 26 +#define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_MASK (3<<MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET) + +#define MXC_CCM_CCGR3_IPU1_IPU_OFFSET 0 +#define MXC_CCM_CCGR3_IPU1_IPU_MASK (3<<MXC_CCM_CCGR3_IPU1_IPU_OFFSET) +#define MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET 2 +#define MXC_CCM_CCGR3_IPU1_IPU_DI0_MASK (3<<MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET) +#define MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET 4 +#define MXC_CCM_CCGR3_IPU1_IPU_DI1_MASK (3<<MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET) +#define MXC_CCM_CCGR3_IPU2_IPU_OFFSET 6 +#define MXC_CCM_CCGR3_IPU2_IPU_MASK (3<<MXC_CCM_CCGR3_IPU2_IPU_OFFSET) +#define MXC_CCM_CCGR3_IPU2_IPU_DI0_OFFSET 8 +#define MXC_CCM_CCGR3_IPU2_IPU_DI0_MASK (3<<MXC_CCM_CCGR3_IPU2_IPU_DI0_OFFSET) +#define MXC_CCM_CCGR3_IPU2_IPU_DI1_OFFSET 10 +#define MXC_CCM_CCGR3_IPU2_IPU_DI1_MASK (3<<MXC_CCM_CCGR3_IPU2_IPU_DI1_OFFSET) +#define MXC_CCM_CCGR3_LDB_DI0_OFFSET 12 +#define MXC_CCM_CCGR3_LDB_DI0_MASK (3<<MXC_CCM_CCGR3_LDB_DI0_OFFSET) +#define MXC_CCM_CCGR3_LDB_DI1_OFFSET 14 +#define MXC_CCM_CCGR3_LDB_DI1_MASK (3<<MXC_CCM_CCGR3_LDB_DI1_OFFSET) +#define MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET 16 +#define MXC_CCM_CCGR3_MIPI_CORE_CFG_MASK (3<<MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET) +#define MXC_CCM_CCGR3_MLB_OFFSET 18 +#define MXC_CCM_CCGR3_MLB_MASK (3<<MXC_CCM_CCGR3_MLB_OFFSET) +#define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET 20 +#define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_MASK (3<<MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET) +#define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_OFFSET 22 +#define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_MASK (3<<MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_OFFSET) +#define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET 24 +#define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_MASK (3<<MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET) +#define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET 26 +#define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_MASK (3<<MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET) +#define MXC_CCM_CCGR3_OCRAM_OFFSET 28 +#define MXC_CCM_CCGR3_OCRAM_MASK (3<<MXC_CCM_CCGR3_OCRAM_OFFSET) +#define MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET 30 +#define MXC_CCM_CCGR3_OPENVGAXICLK_MASK (3<<MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET) + +#define MXC_CCM_CCGR4_PCIE_OFFSET 0 +#define MXC_CCM_CCGR4_PCIE_MASK (3<<MXC_CCM_CCGR4_PCIE_OFFSET) +#define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET 8 +#define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_MASK (3<<MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET) +#define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET 12 +#define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK (3<<MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET) +#define MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_OFFSET 14 +#define MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_MASK (3<<MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_OFFSET) +#define MXC_CCM_CCGR4_PWM1_OFFSET 16 +#define MXC_CCM_CCGR4_PWM1_MASK (3<<MXC_CCM_CCGR4_PWM1_OFFSET) +#define MXC_CCM_CCGR4_PWM2_OFFSET 18 +#define MXC_CCM_CCGR4_PWM2_MASK (3<<MXC_CCM_CCGR4_PWM2_OFFSET) +#define MXC_CCM_CCGR4_PWM3_OFFSET 20 +#define MXC_CCM_CCGR4_PWM3_MASK (3<<MXC_CCM_CCGR4_PWM3_OFFSET) +#define MXC_CCM_CCGR4_PWM4_OFFSET 22 +#define MXC_CCM_CCGR4_PWM4_MASK (3<<MXC_CCM_CCGR4_PWM4_OFFSET) +#define MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_OFFSET 24 +#define MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK (3<<MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_OFFSET) +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_OFFSET 26 +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK (3<<MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_OFFSET) +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_OFFSET 28 +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK (3<<MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_OFFSET) +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_OFFSET 30 +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK (3<<MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_OFFSET) + +#define MXC_CCM_CCGR5_ROM_OFFSET 0 +#define MXC_CCM_CCGR5_ROM_MASK (3<<MXC_CCM_CCGR5_ROM_OFFSET) +#define MXC_CCM_CCGR5_SATA_OFFSET 4 +#define MXC_CCM_CCGR5_SATA_MASK (3<<MXC_CCM_CCGR5_SATA_OFFSET) +#define MXC_CCM_CCGR5_SDMA_OFFSET 6 +#define MXC_CCM_CCGR5_SDMA_MASK (3<<MXC_CCM_CCGR5_SDMA_OFFSET) +#define MXC_CCM_CCGR5_SPBA_OFFSET 12 +#define MXC_CCM_CCGR5_SPBA_MASK (3<<MXC_CCM_CCGR5_SPBA_OFFSET) +#define MXC_CCM_CCGR5_SPDIF_OFFSET 14 +#define MXC_CCM_CCGR5_SPDIF_MASK (3<<MXC_CCM_CCGR5_SPDIF_OFFSET) +#define MXC_CCM_CCGR5_SSI1_OFFSET 18 +#define MXC_CCM_CCGR5_SSI1_MASK (3<<MXC_CCM_CCGR5_SSI1_OFFSET) +#define MXC_CCM_CCGR5_SSI2_OFFSET 20 +#define MXC_CCM_CCGR5_SSI2_MASK (3<<MXC_CCM_CCGR5_SSI2_OFFSET) +#define MXC_CCM_CCGR5_SSI3_OFFSET 22 +#define MXC_CCM_CCGR5_SSI3_MASK (3<<MXC_CCM_CCGR5_SSI3_OFFSET) +#define MXC_CCM_CCGR5_UART_OFFSET 24 +#define MXC_CCM_CCGR5_UART_MASK (3<<MXC_CCM_CCGR5_UART_OFFSET) +#define MXC_CCM_CCGR5_UART_SERIAL_OFFSET 26 +#define MXC_CCM_CCGR5_UART_SERIAL_MASK (3<<MXC_CCM_CCGR5_UART_SERIAL_OFFSET) + +#define MXC_CCM_CCGR6_USBOH3_OFFSET 0 +#define MXC_CCM_CCGR6_USBOH3_MASK (3<<MXC_CCM_CCGR6_USBOH3_OFFSET) +#define MXC_CCM_CCGR6_USDHC1_OFFSET 2 +#define MXC_CCM_CCGR6_USDHC1_MASK (3<<MXC_CCM_CCGR6_USDHC1_OFFSET) +#define MXC_CCM_CCGR6_USDHC2_OFFSET 4 +#define MXC_CCM_CCGR6_USDHC2_MASK (3<<MXC_CCM_CCGR6_USDHC2_OFFSET) +#define MXC_CCM_CCGR6_USDHC3_OFFSET 6 +#define MXC_CCM_CCGR6_USDHC3_MASK (3<<MXC_CCM_CCGR6_USDHC3_OFFSET) +#define MXC_CCM_CCGR6_USDHC4_OFFSET 8 +#define MXC_CCM_CCGR6_USDHC4_MASK (3<<MXC_CCM_CCGR6_USDHC4_OFFSET) +#define MXC_CCM_CCGR6_EMI_SLOW_OFFSET 10 +#define MXC_CCM_CCGR6_EMI_SLOW_MASK (3<<MXC_CCM_CCGR6_EMI_SLOW_OFFSET) +#define MXC_CCM_CCGR6_VDOAXICLK_OFFSET 12 +#define MXC_CCM_CCGR6_VDOAXICLK_MASK (3<<MXC_CCM_CCGR6_VDOAXICLK_OFFSET) + #define BM_ANADIG_PLL_SYS_LOCK 0x80000000 #define BP_ANADIG_PLL_SYS_RSVD0 20 #define BM_ANADIG_PLL_SYS_RSVD0 0x7FF00000
On 09/19/2012 11:17 AM, Eric Nelson wrote:
Signed-off-by: Eric Nelsoneric.nelson@boundarydevices.com
reg |= MXC_CCM_CCGR_CG_MASK<< MXC_CCM_CCGR0_CG0_OFFSET;
elsereg |= MXC_CCM_CCGR6_USBOH3_MASK;
reg&= ~(MXC_CCM_CCGR_CG_MASK<< MXC_CCM_CCGR0_CG0_OFFSET);
reg&= ~(MXC_CCM_CCGR6_USBOH3_MASK);
__raw_writel(reg,&imx_ccm->CCGR6);
if (i2c_num> 2) return -EINVAL;
- mask = MXC_CCM_CCGR_CG_MASK<< ((i2c_num + 3)<< 1);
reg = __raw_readl(&imx_ccm->CCGR2); if (enable) reg |= mask;<< (MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET + (i2c_num<< 1));
reg |= MXC_CCM_CCGR5_SATA_MASK; writel(reg,&imx_ccm->CCGR5);
/* Enable PLLs */
-#define MXC_CCM_CCGR0_CG15_OFFSET 30 -#define MXC_CCM_CCGR0_CG15_MASK (0x3<< 30) -#define MXC_CCM_CCGR0_CG14_OFFSET 28 -#define MXC_CCM_CCGR0_CG14_MASK (0x3<< 28) -#define MXC_CCM_CCGR0_CG13_OFFSET 26 -#define MXC_CCM_CCGR0_CG13_MASK (0x3<< 26) -#define MXC_CCM_CCGR0_CG12_OFFSET 24 -#define MXC_CCM_CCGR0_CG12_MASK (0x3<< 24) -#define MXC_CCM_CCGR0_CG11_OFFSET 22 -#define MXC_CCM_CCGR0_CG11_MASK (0x3<< 22) -#define MXC_CCM_CCGR0_CG10_OFFSET 20 -#define MXC_CCM_CCGR0_CG10_MASK (0x3<< 20) -#define MXC_CCM_CCGR0_CG9_OFFSET 18 -#define MXC_CCM_CCGR0_CG9_MASK (0x3<< 18) -#define MXC_CCM_CCGR0_CG8_OFFSET 16 -#define MXC_CCM_CCGR0_CG8_MASK (0x3<< 16) -#define MXC_CCM_CCGR0_CG7_OFFSET 14 -#define MXC_CCM_CCGR0_CG6_OFFSET 12 -#define MXC_CCM_CCGR0_CG5_OFFSET 10 -#define MXC_CCM_CCGR0_CG5_MASK (0x3<< 10) -#define MXC_CCM_CCGR0_CG4_OFFSET 8 -#define MXC_CCM_CCGR0_CG4_MASK (0x3<< 8) -#define MXC_CCM_CCGR0_CG3_OFFSET 6 -#define MXC_CCM_CCGR0_CG3_MASK (0x3<< 6) -#define MXC_CCM_CCGR0_CG2_OFFSET 4 -#define MXC_CCM_CCGR0_CG2_MASK (0x3<< 4) -#define MXC_CCM_CCGR0_CG1_OFFSET 2 -#define MXC_CCM_CCGR0_CG1_MASK (0x3<< 2) -#define MXC_CCM_CCGR0_CG0_OFFSET 0 -#define MXC_CCM_CCGR0_CG0_MASK 3
-#define MXC_CCM_CCGR5_CG15_OFFSET 30 -#define MXC_CCM_CCGR5_CG14_OFFSET 28 -#define MXC_CCM_CCGR5_CG14_MASK (0x3<< 28) -#define MXC_CCM_CCGR5_CG13_OFFSET 26 -#define MXC_CCM_CCGR5_CG13_MASK (0x3<< 26) -#define MXC_CCM_CCGR5_CG12_OFFSET 24 -#define MXC_CCM_CCGR5_CG12_MASK (0x3<< 24) -#define MXC_CCM_CCGR5_CG11_OFFSET 22 -#define MXC_CCM_CCGR5_CG11_MASK (0x3<< 22) -#define MXC_CCM_CCGR5_CG10_OFFSET 20 -#define MXC_CCM_CCGR5_CG10_MASK (0x3<< 20) -#define MXC_CCM_CCGR5_CG9_OFFSET 18 -#define MXC_CCM_CCGR5_CG9_MASK (0x3<< 18) -#define MXC_CCM_CCGR5_CG8_OFFSET 16 -#define MXC_CCM_CCGR5_CG8_MASK (0x3<< 16) -#define MXC_CCM_CCGR5_CG7_OFFSET 14 -#define MXC_CCM_CCGR5_CG7_MASK (0x3<< 14) -#define MXC_CCM_CCGR5_CG6_OFFSET 12 -#define MXC_CCM_CCGR5_CG6_MASK (0x3<< 12) -#define MXC_CCM_CCGR5_CG5_OFFSET 10 -#define MXC_CCM_CCGR5_CG4_OFFSET 8 -#define MXC_CCM_CCGR5_CG3_OFFSET 6 -#define MXC_CCM_CCGR5_CG2_OFFSET 4 -#define MXC_CCM_CCGR5_CG2_MASK (0x3<< 4) -#define MXC_CCM_CCGR5_CG1_OFFSET 2 -#define MXC_CCM_CCGR5_CG0_OFFSET 0
-#define MXC_CCM_CCGR6_CG15_OFFSET 30 -#define MXC_CCM_CCGR6_CG14_OFFSET 28 -#define MXC_CCM_CCGR6_CG14_MASK (0x3<< 28) -#define MXC_CCM_CCGR6_CG13_OFFSET 26 -#define MXC_CCM_CCGR6_CG13_MASK (0x3<< 26) -#define MXC_CCM_CCGR6_CG12_OFFSET 24 -#define MXC_CCM_CCGR6_CG12_MASK (0x3<< 24) -#define MXC_CCM_CCGR6_CG11_OFFSET 22 -#define MXC_CCM_CCGR6_CG11_MASK (0x3<< 22) -#define MXC_CCM_CCGR6_CG10_OFFSET 20 -#define MXC_CCM_CCGR6_CG10_MASK (0x3<< 20) -#define MXC_CCM_CCGR6_CG9_OFFSET 18 -#define MXC_CCM_CCGR6_CG9_MASK (0x3<< 18) -#define MXC_CCM_CCGR6_CG8_OFFSET 16 -#define MXC_CCM_CCGR6_CG8_MASK (0x3<< 16) -#define MXC_CCM_CCGR6_CG7_OFFSET 14 -#define MXC_CCM_CCGR6_CG7_MASK (0x3<< 14) -#define MXC_CCM_CCGR6_CG6_OFFSET 12 -#define MXC_CCM_CCGR6_CG6_MASK (0x3<< 12) -#define MXC_CCM_CCGR6_CG5_OFFSET 10 -#define MXC_CCM_CCGR6_CG4_OFFSET 8 -#define MXC_CCM_CCGR6_CG3_OFFSET 6 -#define MXC_CCM_CCGR6_CG2_OFFSET 4 -#define MXC_CCM_CCGR6_CG2_MASK (0x3<< 4) -#define MXC_CCM_CCGR6_CG1_OFFSET 2 -#define MXC_CCM_CCGR6_CG0_OFFSET 0
-#define MXC_CCM_CCGR7_CG15_OFFSET 30 -#define MXC_CCM_CCGR7_CG14_OFFSET 28 -#define MXC_CCM_CCGR7_CG14_MASK (0x3<< 28) -#define MXC_CCM_CCGR7_CG13_OFFSET 26 -#define MXC_CCM_CCGR7_CG13_MASK (0x3<< 26) -#define MXC_CCM_CCGR7_CG12_OFFSET 24 -#define MXC_CCM_CCGR7_CG12_MASK (0x3<< 24) -#define MXC_CCM_CCGR7_CG11_OFFSET 22 -#define MXC_CCM_CCGR7_CG11_MASK (0x3<< 22) -#define MXC_CCM_CCGR7_CG10_OFFSET 20 -#define MXC_CCM_CCGR7_CG10_MASK (0x3<< 20) -#define MXC_CCM_CCGR7_CG9_OFFSET 18 -#define MXC_CCM_CCGR7_CG9_MASK (0x3<< 18) -#define MXC_CCM_CCGR7_CG8_OFFSET 16 -#define MXC_CCM_CCGR7_CG8_MASK (0x3<< 16) -#define MXC_CCM_CCGR7_CG7_OFFSET 14 -#define MXC_CCM_CCGR7_CG7_MASK (0x3<< 14) -#define MXC_CCM_CCGR7_CG6_OFFSET 12 -#define MXC_CCM_CCGR7_CG6_MASK (0x3<< 12) -#define MXC_CCM_CCGR7_CG5_OFFSET 10 -#define MXC_CCM_CCGR7_CG4_OFFSET 8 -#define MXC_CCM_CCGR7_CG3_OFFSET 6 -#define MXC_CCM_CCGR7_CG2_OFFSET 4 -#define MXC_CCM_CCGR7_CG2_MASK (0x3<< 4) -#define MXC_CCM_CCGR7_CG1_OFFSET 2 -#define MXC_CCM_CCGR7_CG0_OFFSET 0 +#define MXC_CCM_CCGR0_AIPS_TZ1_OFFSET 0 +#define MXC_CCM_CCGR0_AIPS_TZ1_MASK (3<<MXC_CCM_CCGR0_AIPS_TZ1_OFFSET) +#define MXC_CCM_CCGR0_AIPS_TZ2_OFFSET 2 +#define MXC_CCM_CCGR0_AIPS_TZ2_MASK (3<<MXC_CCM_CCGR0_AIPS_TZ2_OFFSET) +#define MXC_CCM_CCGR0_APBHDMA HCLK_OFFSET 4 +#define MXC_CCM_CCGR0_AMASK (3<<MXC_CCM_CCGR0_APBHDMA) +#define MXC_CCM_CCGR0_ASRC_OFFSET 6 +#define MXC_CCM_CCGR0_ASRC_MASK (3<<MXC_CCM_CCGR0_ASRC_OFFSET) +#define MXC_CCM_CCGR0_CAAM_SECURE_MEM_OFFSET 8 +#define MXC_CCM_CCGR0_CAAM_SECURE_MEM_MASK (3<<MXC_CCM_CCGR0_CAAM_SECURE_MEM_OFFSET) +#define MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_OFFSET 10 +#define MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_MASK (3<<MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_OFFSET) +#define MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_OFFSET 12 +#define MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_MASK (3<<MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_OFFSET) +#define MXC_CCM_CCGR0_CAN1_OFFSET 14 +#define MXC_CCM_CCGR0_CAN1_MASK (3<<MXC_CCM_CCGR0_CAN1_OFFSET) +#define MXC_CCM_CCGR0_CAN1_SERIAL_OFFSET 16 +#define MXC_CCM_CCGR0_CAN1_SERIAL_MASK (3<<MXC_CCM_CCGR0_CAN1_SERIAL_OFFSET) +#define MXC_CCM_CCGR0_CAN2_OFFSET 18 +#define MXC_CCM_CCGR0_CAN2_MASK (3<<MXC_CCM_CCGR0_CAN2_OFFSET) +#define MXC_CCM_CCGR0_CAN2_SERIAL_OFFSET 20 +#define MXC_CCM_CCGR0_CAN2_SERIAL_MASK (3<<MXC_CCM_CCGR0_CAN2_SERIAL_OFFSET) +#define MXC_CCM_CCGR0_CHEETAH_DBG_CLK_OFFSET 22 +#define MXC_CCM_CCGR0_CHEETAH_DBG_CLK_MASK (3<<MXC_CCM_CCGR0_CHEETAH_DBG_CLK_OFFSET) +#define MXC_CCM_CCGR0_DCIC1_OFFSET 24 +#define MXC_CCM_CCGR0_DCIC1_MASK (3<<MXC_CCM_CCGR0_DCIC1_OFFSET) +#define MXC_CCM_CCGR0_DCIC2_OFFSET 26 +#define MXC_CCM_CCGR0_DCIC2_MASK (3<<MXC_CCM_CCGR0_DCIC2_OFFSET) +#define MXC_CCM_CCGR0_DTCP_OFFSET 28 +#define MXC_CCM_CCGR0_DTCP_MASK (3<<MXC_CCM_CCGR0_DTCP_OFFSET)
- #define BM_ANADIG_PLL_SYS_LOCK 0x80000000 #define BP_ANADIG_PLL_SYS_RSVD0 20 #define BM_ANADIG_PLL_SYS_RSVD0 0x7FF00000
NAK.
I just found that removal of the generic CCGRx_CGy_OFFSET bitfields highlighted another MX5-dependent fragment in drivers/video/ipu_common.c:
http://git.denx.de/u-boot-imx.git/?p=u-boot.git;a=blob;f=drivers/video/ipu_c...
Fabio's patch from 5/31 (e4942ad7) caught a portion of this, but perhaps not enough.
Add meaningful constants for each clock channels and use them for enabling and disabling i.MX6 clocks.
Includes an update to enable/disable the IPU1 clock in drivers/video/ipu_common to remove IMX5x register access when used on i.MX6 as discussed in V1:
http://patchwork.ozlabs.org/patch/185129/
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/cpu/armv7/mx6/clock.c | 10 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 358 +++++++++++++++--------------- drivers/video/ipu_common.c | 10 +- 3 files changed, 193 insertions(+), 185 deletions(-)
-#define MXC_CCM_CCGR0_CG15_OFFSET 30 -#define MXC_CCM_CCGR0_CG15_MASK (0x3 << 30) -#define MXC_CCM_CCGR0_CG14_OFFSET 28 -#define MXC_CCM_CCGR0_CG14_MASK (0x3 << 28) -#define MXC_CCM_CCGR0_CG13_OFFSET 26 -#define MXC_CCM_CCGR0_CG13_MASK (0x3 << 26) -#define MXC_CCM_CCGR0_CG12_OFFSET 24 -#define MXC_CCM_CCGR0_CG12_MASK (0x3 << 24) -#define MXC_CCM_CCGR0_CG11_OFFSET 22 -#define MXC_CCM_CCGR0_CG11_MASK (0x3 << 22) -#define MXC_CCM_CCGR0_CG10_OFFSET 20 -#define MXC_CCM_CCGR0_CG10_MASK (0x3 << 20) -#define MXC_CCM_CCGR0_CG9_OFFSET 18 -#define MXC_CCM_CCGR0_CG9_MASK (0x3 << 18) -#define MXC_CCM_CCGR0_CG8_OFFSET 16 -#define MXC_CCM_CCGR0_CG8_MASK (0x3 << 16) -#define MXC_CCM_CCGR0_CG7_OFFSET 14 -#define MXC_CCM_CCGR0_CG6_OFFSET 12 -#define MXC_CCM_CCGR0_CG5_OFFSET 10 -#define MXC_CCM_CCGR0_CG5_MASK (0x3 << 10) -#define MXC_CCM_CCGR0_CG4_OFFSET 8 -#define MXC_CCM_CCGR0_CG4_MASK (0x3 << 8) -#define MXC_CCM_CCGR0_CG3_OFFSET 6 -#define MXC_CCM_CCGR0_CG3_MASK (0x3 << 6) -#define MXC_CCM_CCGR0_CG2_OFFSET 4 -#define MXC_CCM_CCGR0_CG2_MASK (0x3 << 4) -#define MXC_CCM_CCGR0_CG1_OFFSET 2 -#define MXC_CCM_CCGR0_CG1_MASK (0x3 << 2) -#define MXC_CCM_CCGR0_CG0_OFFSET 0 -#define MXC_CCM_CCGR0_CG0_MASK 3 - -#define MXC_CCM_CCGR1_CG15_OFFSET 30 -#define MXC_CCM_CCGR1_CG14_OFFSET 28 -#define MXC_CCM_CCGR1_CG13_OFFSET 26 -#define MXC_CCM_CCGR1_CG12_OFFSET 24 -#define MXC_CCM_CCGR1_CG11_OFFSET 22 -#define MXC_CCM_CCGR1_CG10_OFFSET 20 -#define MXC_CCM_CCGR1_CG9_OFFSET 18 -#define MXC_CCM_CCGR1_CG8_OFFSET 16 -#define MXC_CCM_CCGR1_CG7_OFFSET 14 -#define MXC_CCM_CCGR1_CG6_OFFSET 12 -#define MXC_CCM_CCGR1_CG5_OFFSET 10 -#define MXC_CCM_CCGR1_CG4_OFFSET 8 -#define MXC_CCM_CCGR1_CG3_OFFSET 6 -#define MXC_CCM_CCGR1_CG2_OFFSET 4 -#define MXC_CCM_CCGR1_CG1_OFFSET 2 -#define MXC_CCM_CCGR1_CG0_OFFSET 0 - -#define MXC_CCM_CCGR2_CG15_OFFSET 30 -#define MXC_CCM_CCGR2_CG14_OFFSET 28 -#define MXC_CCM_CCGR2_CG13_OFFSET 26 -#define MXC_CCM_CCGR2_CG12_OFFSET 24 -#define MXC_CCM_CCGR2_CG11_OFFSET 22 -#define MXC_CCM_CCGR2_CG10_OFFSET 20 -#define MXC_CCM_CCGR2_CG9_OFFSET 18 -#define MXC_CCM_CCGR2_CG8_OFFSET 16 -#define MXC_CCM_CCGR2_CG7_OFFSET 14 -#define MXC_CCM_CCGR2_CG6_OFFSET 12 -#define MXC_CCM_CCGR2_CG5_OFFSET 10 -#define MXC_CCM_CCGR2_CG4_OFFSET 8 -#define MXC_CCM_CCGR2_CG3_OFFSET 6 -#define MXC_CCM_CCGR2_CG2_OFFSET 4 -#define MXC_CCM_CCGR2_CG1_OFFSET 2 -#define MXC_CCM_CCGR2_CG0_OFFSET 0 - -#define MXC_CCM_CCGR3_CG15_OFFSET 30 -#define MXC_CCM_CCGR3_CG14_OFFSET 28 -#define MXC_CCM_CCGR3_CG13_OFFSET 26 -#define MXC_CCM_CCGR3_CG12_OFFSET 24 -#define MXC_CCM_CCGR3_CG11_OFFSET 22 -#define MXC_CCM_CCGR3_CG10_OFFSET 20 -#define MXC_CCM_CCGR3_CG9_OFFSET 18 -#define MXC_CCM_CCGR3_CG8_OFFSET 16 -#define MXC_CCM_CCGR3_CG7_OFFSET 14 -#define MXC_CCM_CCGR3_CG6_OFFSET 12 -#define MXC_CCM_CCGR3_CG5_OFFSET 10 -#define MXC_CCM_CCGR3_CG4_OFFSET 8 -#define MXC_CCM_CCGR3_CG3_OFFSET 6 -#define MXC_CCM_CCGR3_CG2_OFFSET 4 -#define MXC_CCM_CCGR3_CG1_OFFSET 2 -#define MXC_CCM_CCGR3_CG0_OFFSET 0 - -#define MXC_CCM_CCGR4_CG15_OFFSET 30 -#define MXC_CCM_CCGR4_CG14_OFFSET 28 -#define MXC_CCM_CCGR4_CG13_OFFSET 26 -#define MXC_CCM_CCGR4_CG12_OFFSET 24 -#define MXC_CCM_CCGR4_CG11_OFFSET 22 -#define MXC_CCM_CCGR4_CG10_OFFSET 20 -#define MXC_CCM_CCGR4_CG9_OFFSET 18 -#define MXC_CCM_CCGR4_CG8_OFFSET 16 -#define MXC_CCM_CCGR4_CG7_OFFSET 14 -#define MXC_CCM_CCGR4_CG6_OFFSET 12 -#define MXC_CCM_CCGR4_CG5_OFFSET 10 -#define MXC_CCM_CCGR4_CG4_OFFSET 8 -#define MXC_CCM_CCGR4_CG3_OFFSET 6 -#define MXC_CCM_CCGR4_CG2_OFFSET 4 -#define MXC_CCM_CCGR4_CG1_OFFSET 2 -#define MXC_CCM_CCGR4_CG0_OFFSET 0 - -#define MXC_CCM_CCGR5_CG15_OFFSET 30 -#define MXC_CCM_CCGR5_CG14_OFFSET 28 -#define MXC_CCM_CCGR5_CG14_MASK (0x3 << 28) -#define MXC_CCM_CCGR5_CG13_OFFSET 26 -#define MXC_CCM_CCGR5_CG13_MASK (0x3 << 26) -#define MXC_CCM_CCGR5_CG12_OFFSET 24 -#define MXC_CCM_CCGR5_CG12_MASK (0x3 << 24) -#define MXC_CCM_CCGR5_CG11_OFFSET 22 -#define MXC_CCM_CCGR5_CG11_MASK (0x3 << 22) -#define MXC_CCM_CCGR5_CG10_OFFSET 20 -#define MXC_CCM_CCGR5_CG10_MASK (0x3 << 20) -#define MXC_CCM_CCGR5_CG9_OFFSET 18 -#define MXC_CCM_CCGR5_CG9_MASK (0x3 << 18) -#define MXC_CCM_CCGR5_CG8_OFFSET 16 -#define MXC_CCM_CCGR5_CG8_MASK (0x3 << 16) -#define MXC_CCM_CCGR5_CG7_OFFSET 14 -#define MXC_CCM_CCGR5_CG7_MASK (0x3 << 14) -#define MXC_CCM_CCGR5_CG6_OFFSET 12 -#define MXC_CCM_CCGR5_CG6_MASK (0x3 << 12) -#define MXC_CCM_CCGR5_CG5_OFFSET 10 -#define MXC_CCM_CCGR5_CG4_OFFSET 8 -#define MXC_CCM_CCGR5_CG3_OFFSET 6 -#define MXC_CCM_CCGR5_CG2_OFFSET 4 -#define MXC_CCM_CCGR5_CG2_MASK (0x3 << 4) -#define MXC_CCM_CCGR5_CG1_OFFSET 2 -#define MXC_CCM_CCGR5_CG0_OFFSET 0 - -#define MXC_CCM_CCGR6_CG15_OFFSET 30 -#define MXC_CCM_CCGR6_CG14_OFFSET 28 -#define MXC_CCM_CCGR6_CG14_MASK (0x3 << 28) -#define MXC_CCM_CCGR6_CG13_OFFSET 26 -#define MXC_CCM_CCGR6_CG13_MASK (0x3 << 26) -#define MXC_CCM_CCGR6_CG12_OFFSET 24 -#define MXC_CCM_CCGR6_CG12_MASK (0x3 << 24) -#define MXC_CCM_CCGR6_CG11_OFFSET 22 -#define MXC_CCM_CCGR6_CG11_MASK (0x3 << 22) -#define MXC_CCM_CCGR6_CG10_OFFSET 20 -#define MXC_CCM_CCGR6_CG10_MASK (0x3 << 20) -#define MXC_CCM_CCGR6_CG9_OFFSET 18 -#define MXC_CCM_CCGR6_CG9_MASK (0x3 << 18) -#define MXC_CCM_CCGR6_CG8_OFFSET 16 -#define MXC_CCM_CCGR6_CG8_MASK (0x3 << 16) -#define MXC_CCM_CCGR6_CG7_OFFSET 14 -#define MXC_CCM_CCGR6_CG7_MASK (0x3 << 14) -#define MXC_CCM_CCGR6_CG6_OFFSET 12 -#define MXC_CCM_CCGR6_CG6_MASK (0x3 << 12) -#define MXC_CCM_CCGR6_CG5_OFFSET 10 -#define MXC_CCM_CCGR6_CG4_OFFSET 8 -#define MXC_CCM_CCGR6_CG3_OFFSET 6 -#define MXC_CCM_CCGR6_CG2_OFFSET 4 -#define MXC_CCM_CCGR6_CG2_MASK (0x3 << 4) -#define MXC_CCM_CCGR6_CG1_OFFSET 2 -#define MXC_CCM_CCGR6_CG0_OFFSET 0 - -#define MXC_CCM_CCGR7_CG15_OFFSET 30 -#define MXC_CCM_CCGR7_CG14_OFFSET 28 -#define MXC_CCM_CCGR7_CG14_MASK (0x3 << 28) -#define MXC_CCM_CCGR7_CG13_OFFSET 26 -#define MXC_CCM_CCGR7_CG13_MASK (0x3 << 26) -#define MXC_CCM_CCGR7_CG12_OFFSET 24 -#define MXC_CCM_CCGR7_CG12_MASK (0x3 << 24) -#define MXC_CCM_CCGR7_CG11_OFFSET 22 -#define MXC_CCM_CCGR7_CG11_MASK (0x3 << 22) -#define MXC_CCM_CCGR7_CG10_OFFSET 20 -#define MXC_CCM_CCGR7_CG10_MASK (0x3 << 20) -#define MXC_CCM_CCGR7_CG9_OFFSET 18 -#define MXC_CCM_CCGR7_CG9_MASK (0x3 << 18) -#define MXC_CCM_CCGR7_CG8_OFFSET 16 -#define MXC_CCM_CCGR7_CG8_MASK (0x3 << 16) -#define MXC_CCM_CCGR7_CG7_OFFSET 14 -#define MXC_CCM_CCGR7_CG7_MASK (0x3 << 14) -#define MXC_CCM_CCGR7_CG6_OFFSET 12 -#define MXC_CCM_CCGR7_CG6_MASK (0x3 << 12) -#define MXC_CCM_CCGR7_CG5_OFFSET 10 -#define MXC_CCM_CCGR7_CG4_OFFSET 8 -#define MXC_CCM_CCGR7_CG3_OFFSET 6 -#define MXC_CCM_CCGR7_CG2_OFFSET 4 -#define MXC_CCM_CCGR7_CG2_MASK (0x3 << 4) -#define MXC_CCM_CCGR7_CG1_OFFSET 2 -#define MXC_CCM_CCGR7_CG0_OFFSET 0 +#define MXC_CCM_CCGR0_AIPS_TZ1_OFFSET 0 +#define MXC_CCM_CCGR0_AIPS_TZ1_MASK (3<<MXC_CCM_CCGR0_AIPS_TZ1_OFFSET) +#define MXC_CCM_CCGR0_AIPS_TZ2_OFFSET 2 +#define MXC_CCM_CCGR0_AIPS_TZ2_MASK (3<<MXC_CCM_CCGR0_AIPS_TZ2_OFFSET) +#define MXC_CCM_CCGR0_APBHDMA HCLK_OFFSET 4 +#define MXC_CCM_CCGR0_AMASK (3<<MXC_CCM_CCGR0_APBHDMA) +#define MXC_CCM_CCGR0_ASRC_OFFSET 6 +#define MXC_CCM_CCGR0_ASRC_MASK (3<<MXC_CCM_CCGR0_ASRC_OFFSET) +#define MXC_CCM_CCGR0_CAAM_SECURE_MEM_OFFSET 8 +#define MXC_CCM_CCGR0_CAAM_SECURE_MEM_MASK (3<<MXC_CCM_CCGR0_CAAM_SECURE_MEM_OFFSET) +#define MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_OFFSET 10 +#define MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_MASK (3<<MXC_CCM_CCGR0_CAAM_WRAPPER_ACLK_OFFSET) +#define MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_OFFSET 12 +#define MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_MASK (3<<MXC_CCM_CCGR0_CAAM_WRAPPER_IPG_OFFSET) +#define MXC_CCM_CCGR0_CAN1_OFFSET 14 +#define MXC_CCM_CCGR0_CAN1_MASK (3<<MXC_CCM_CCGR0_CAN1_OFFSET) +#define MXC_CCM_CCGR0_CAN1_SERIAL_OFFSET 16 +#define MXC_CCM_CCGR0_CAN1_SERIAL_MASK (3<<MXC_CCM_CCGR0_CAN1_SERIAL_OFFSET) +#define MXC_CCM_CCGR0_CAN2_OFFSET 18 +#define MXC_CCM_CCGR0_CAN2_MASK (3<<MXC_CCM_CCGR0_CAN2_OFFSET) +#define MXC_CCM_CCGR0_CAN2_SERIAL_OFFSET 20 +#define MXC_CCM_CCGR0_CAN2_SERIAL_MASK (3<<MXC_CCM_CCGR0_CAN2_SERIAL_OFFSET) +#define MXC_CCM_CCGR0_CHEETAH_DBG_CLK_OFFSET 22 +#define MXC_CCM_CCGR0_CHEETAH_DBG_CLK_MASK (3<<MXC_CCM_CCGR0_CHEETAH_DBG_CLK_OFFSET) +#define MXC_CCM_CCGR0_DCIC1_OFFSET 24 +#define MXC_CCM_CCGR0_DCIC1_MASK (3<<MXC_CCM_CCGR0_DCIC1_OFFSET) +#define MXC_CCM_CCGR0_DCIC2_OFFSET 26 +#define MXC_CCM_CCGR0_DCIC2_MASK (3<<MXC_CCM_CCGR0_DCIC2_OFFSET) +#define MXC_CCM_CCGR0_DTCP_OFFSET 28 +#define MXC_CCM_CCGR0_DTCP_MASK (3<<MXC_CCM_CCGR0_DTCP_OFFSET) + +#define MXC_CCM_CCGR1_ECSPI1S_OFFSET 0 +#define MXC_CCM_CCGR1_ECSPI1S_MASK (3<<MXC_CCM_CCGR1_ECSPI1S_OFFSET) +#define MXC_CCM_CCGR1_ECSPI2S_OFFSET 2 +#define MXC_CCM_CCGR1_ECSPI2S_MASK (3<<MXC_CCM_CCGR1_ECSPI2S_OFFSET) +#define MXC_CCM_CCGR1_ECSPI3S_OFFSET 4 +#define MXC_CCM_CCGR1_ECSPI3S_MASK (3<<MXC_CCM_CCGR1_ECSPI3S_OFFSET) +#define MXC_CCM_CCGR1_ECSPI4S_OFFSET 6 +#define MXC_CCM_CCGR1_ECSPI4S_MASK (3<<MXC_CCM_CCGR1_ECSPI4S_OFFSET) +#define MXC_CCM_CCGR1_ECSPI5S_OFFSET 8 +#define MXC_CCM_CCGR1_ECSPI5S_MASK (3<<MXC_CCM_CCGR1_ECSPI5S_OFFSET) +#define MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET 10 +#define MXC_CCM_CCGR1_ENET_CLK_ENABLE_MASK (3<<MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET) +#define MXC_CCM_CCGR1_EPIT1S_OFFSET 12 +#define MXC_CCM_CCGR1_EPIT1S_MASK (3<<MXC_CCM_CCGR1_EPIT1S_OFFSET) +#define MXC_CCM_CCGR1_EPIT2S_OFFSET 14 +#define MXC_CCM_CCGR1_EPIT2S_MASK (3<<MXC_CCM_CCGR1_EPIT2S_OFFSET) +#define MXC_CCM_CCGR1_ESAIS_OFFSET 16 +#define MXC_CCM_CCGR1_ESAIS_MASK (3<<MXC_CCM_CCGR1_ESAIS_OFFSET) +#define MXC_CCM_CCGR1_GPT_BUS_OFFSET 20 +#define MXC_CCM_CCGR1_GPT_BUS_MASK (3<<MXC_CCM_CCGR1_GPT_BUS_OFFSET) +#define MXC_CCM_CCGR1_GPT_SERIAL_OFFSET 22 +#define MXC_CCM_CCGR1_GPT_SERIAL_MASK (3<<MXC_CCM_CCGR1_GPT_SERIAL_OFFSET) +#define MXC_CCM_CCGR1_GPU2D_OFFSET 24 +#define MXC_CCM_CCGR1_GPU2D_MASK (3<<MXC_CCM_CCGR1_GPU2D_OFFSET) +#define MXC_CCM_CCGR1_GPU3D_OFFSET 26 +#define MXC_CCM_CCGR1_GPU3D_MASK (3<<MXC_CCM_CCGR1_GPU3D_OFFSET) + +#define MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_OFFSET 0 +#define MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK (3<<MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_OFFSET) +#define MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_OFFSET 4 +#define MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK (3<<MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_OFFSET) +#define MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET 6 +#define MXC_CCM_CCGR2_I2C1_SERIAL_MASK (3<<MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET) +#define MXC_CCM_CCGR2_I2C2_SERIAL_OFFSET 8 +#define MXC_CCM_CCGR2_I2C2_SERIAL_MASK (3<<MXC_CCM_CCGR2_I2C2_SERIAL_OFFSET) +#define MXC_CCM_CCGR2_I2C3_SERIAL_OFFSET 10 +#define MXC_CCM_CCGR2_I2C3_SERIAL_MASK (3<<MXC_CCM_CCGR2_I2C3_SERIAL_OFFSET) +#define MXC_CCM_CCGR2_OCOTP_CTRL_OFFSET 12 +#define MXC_CCM_CCGR2_OCOTP_CTRL_MASK (3<<MXC_CCM_CCGR2_OCOTP_CTRL_OFFSET) +#define MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_OFFSET 14 +#define MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK (3<<MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_OFFSET) +#define MXC_CCM_CCGR2_IPMUX1_OFFSET 16 +#define MXC_CCM_CCGR2_IPMUX1_MASK (3<<MXC_CCM_CCGR2_IPMUX1_OFFSET) +#define MXC_CCM_CCGR2_IPMUX2_OFFSET 18 +#define MXC_CCM_CCGR2_IPMUX2_MASK (3<<MXC_CCM_CCGR2_IPMUX2_OFFSET) +#define MXC_CCM_CCGR2_IPMUX3_OFFSET 20 +#define MXC_CCM_CCGR2_IPMUX3_MASK (3<<MXC_CCM_CCGR2_IPMUX3_OFFSET) +#define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_OFFSET 22 +#define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_MASK (3<<MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_OFFSET) +#define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_OFFSET 24 +#define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_MASK (3<<MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_OFFSET) +#define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET 26 +#define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_MASK (3<<MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET) + +#define MXC_CCM_CCGR3_IPU1_IPU_OFFSET 0 +#define MXC_CCM_CCGR3_IPU1_IPU_MASK (3<<MXC_CCM_CCGR3_IPU1_IPU_OFFSET) +#define MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET 2 +#define MXC_CCM_CCGR3_IPU1_IPU_DI0_MASK (3<<MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET) +#define MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET 4 +#define MXC_CCM_CCGR3_IPU1_IPU_DI1_MASK (3<<MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET) +#define MXC_CCM_CCGR3_IPU2_IPU_OFFSET 6 +#define MXC_CCM_CCGR3_IPU2_IPU_MASK (3<<MXC_CCM_CCGR3_IPU2_IPU_OFFSET) +#define MXC_CCM_CCGR3_IPU2_IPU_DI0_OFFSET 8 +#define MXC_CCM_CCGR3_IPU2_IPU_DI0_MASK (3<<MXC_CCM_CCGR3_IPU2_IPU_DI0_OFFSET) +#define MXC_CCM_CCGR3_IPU2_IPU_DI1_OFFSET 10 +#define MXC_CCM_CCGR3_IPU2_IPU_DI1_MASK (3<<MXC_CCM_CCGR3_IPU2_IPU_DI1_OFFSET) +#define MXC_CCM_CCGR3_LDB_DI0_OFFSET 12 +#define MXC_CCM_CCGR3_LDB_DI0_MASK (3<<MXC_CCM_CCGR3_LDB_DI0_OFFSET) +#define MXC_CCM_CCGR3_LDB_DI1_OFFSET 14 +#define MXC_CCM_CCGR3_LDB_DI1_MASK (3<<MXC_CCM_CCGR3_LDB_DI1_OFFSET) +#define MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET 16 +#define MXC_CCM_CCGR3_MIPI_CORE_CFG_MASK (3<<MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET) +#define MXC_CCM_CCGR3_MLB_OFFSET 18 +#define MXC_CCM_CCGR3_MLB_MASK (3<<MXC_CCM_CCGR3_MLB_OFFSET) +#define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET 20 +#define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_MASK (3<<MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET) +#define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_OFFSET 22 +#define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_MASK (3<<MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_OFFSET) +#define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET 24 +#define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_MASK (3<<MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET) +#define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET 26 +#define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_MASK (3<<MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET) +#define MXC_CCM_CCGR3_OCRAM_OFFSET 28 +#define MXC_CCM_CCGR3_OCRAM_MASK (3<<MXC_CCM_CCGR3_OCRAM_OFFSET) +#define MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET 30 +#define MXC_CCM_CCGR3_OPENVGAXICLK_MASK (3<<MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET) + +#define MXC_CCM_CCGR4_PCIE_OFFSET 0 +#define MXC_CCM_CCGR4_PCIE_MASK (3<<MXC_CCM_CCGR4_PCIE_OFFSET) +#define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET 8 +#define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_MASK (3<<MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET) +#define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET 12 +#define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK (3<<MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET) +#define MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_OFFSET 14 +#define MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_MASK (3<<MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_OFFSET) +#define MXC_CCM_CCGR4_PWM1_OFFSET 16 +#define MXC_CCM_CCGR4_PWM1_MASK (3<<MXC_CCM_CCGR4_PWM1_OFFSET) +#define MXC_CCM_CCGR4_PWM2_OFFSET 18 +#define MXC_CCM_CCGR4_PWM2_MASK (3<<MXC_CCM_CCGR4_PWM2_OFFSET) +#define MXC_CCM_CCGR4_PWM3_OFFSET 20 +#define MXC_CCM_CCGR4_PWM3_MASK (3<<MXC_CCM_CCGR4_PWM3_OFFSET) +#define MXC_CCM_CCGR4_PWM4_OFFSET 22 +#define MXC_CCM_CCGR4_PWM4_MASK (3<<MXC_CCM_CCGR4_PWM4_OFFSET) +#define MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_OFFSET 24 +#define MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK (3<<MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_OFFSET) +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_OFFSET 26 +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK (3<<MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_OFFSET) +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_OFFSET 28 +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK (3<<MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_OFFSET) +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_OFFSET 30 +#define MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK (3<<MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_OFFSET) + +#define MXC_CCM_CCGR5_ROM_OFFSET 0 +#define MXC_CCM_CCGR5_ROM_MASK (3<<MXC_CCM_CCGR5_ROM_OFFSET) +#define MXC_CCM_CCGR5_SATA_OFFSET 4 +#define MXC_CCM_CCGR5_SATA_MASK (3<<MXC_CCM_CCGR5_SATA_OFFSET) +#define MXC_CCM_CCGR5_SDMA_OFFSET 6 +#define MXC_CCM_CCGR5_SDMA_MASK (3<<MXC_CCM_CCGR5_SDMA_OFFSET) +#define MXC_CCM_CCGR5_SPBA_OFFSET 12 +#define MXC_CCM_CCGR5_SPBA_MASK (3<<MXC_CCM_CCGR5_SPBA_OFFSET) +#define MXC_CCM_CCGR5_SPDIF_OFFSET 14 +#define MXC_CCM_CCGR5_SPDIF_MASK (3<<MXC_CCM_CCGR5_SPDIF_OFFSET) +#define MXC_CCM_CCGR5_SSI1_OFFSET 18 +#define MXC_CCM_CCGR5_SSI1_MASK (3<<MXC_CCM_CCGR5_SSI1_OFFSET) +#define MXC_CCM_CCGR5_SSI2_OFFSET 20 +#define MXC_CCM_CCGR5_SSI2_MASK (3<<MXC_CCM_CCGR5_SSI2_OFFSET) +#define MXC_CCM_CCGR5_SSI3_OFFSET 22 +#define MXC_CCM_CCGR5_SSI3_MASK (3<<MXC_CCM_CCGR5_SSI3_OFFSET) +#define MXC_CCM_CCGR5_UART_OFFSET 24 +#define MXC_CCM_CCGR5_UART_MASK (3<<MXC_CCM_CCGR5_UART_OFFSET) +#define MXC_CCM_CCGR5_UART_SERIAL_OFFSET 26 +#define MXC_CCM_CCGR5_UART_SERIAL_MASK (3<<MXC_CCM_CCGR5_UART_SERIAL_OFFSET) + +#define MXC_CCM_CCGR6_USBOH3_OFFSET 0 +#define MXC_CCM_CCGR6_USBOH3_MASK (3<<MXC_CCM_CCGR6_USBOH3_OFFSET) +#define MXC_CCM_CCGR6_USDHC1_OFFSET 2 +#define MXC_CCM_CCGR6_USDHC1_MASK (3<<MXC_CCM_CCGR6_USDHC1_OFFSET) +#define MXC_CCM_CCGR6_USDHC2_OFFSET 4 +#define MXC_CCM_CCGR6_USDHC2_MASK (3<<MXC_CCM_CCGR6_USDHC2_OFFSET) +#define MXC_CCM_CCGR6_USDHC3_OFFSET 6 +#define MXC_CCM_CCGR6_USDHC3_MASK (3<<MXC_CCM_CCGR6_USDHC3_OFFSET) +#define MXC_CCM_CCGR6_USDHC4_OFFSET 8 +#define MXC_CCM_CCGR6_USDHC4_MASK (3<<MXC_CCM_CCGR6_USDHC4_OFFSET) +#define MXC_CCM_CCGR6_EMI_SLOW_OFFSET 10 +#define MXC_CCM_CCGR6_EMI_SLOW_MASK (3<<MXC_CCM_CCGR6_EMI_SLOW_OFFSET) +#define MXC_CCM_CCGR6_VDOAXICLK_OFFSET 12 +#define MXC_CCM_CCGR6_VDOAXICLK_MASK (3<<MXC_CCM_CCGR6_VDOAXICLK_OFFSET) + #define BM_ANADIG_PLL_SYS_LOCK 0x80000000 #define BP_ANADIG_PLL_SYS_RSVD0 20 #define BM_ANADIG_PLL_SYS_RSVD0 0x7FF00000 diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 2020da9..cc8f881 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -163,13 +163,13 @@ int clk_set_parent(struct clk *clk, struct clk *parent)
static int clk_ipu_enable(struct clk *clk) { -#if defined(CONFIG_MX51) || defined(CONFIG_MX53) u32 reg;
reg = __raw_readl(clk->enable_reg); reg |= MXC_CCM_CCGR_CG_MASK << clk->enable_shift; __raw_writel(reg, clk->enable_reg);
+#if defined(CONFIG_MX51) || defined(CONFIG_MX53) /* Handshake with IPU when certain clock rates are changed. */ reg = __raw_readl(&mxc_ccm->ccdr); reg &= ~MXC_CCM_CCDR_IPU_HS_MASK; @@ -185,13 +185,13 @@ static int clk_ipu_enable(struct clk *clk)
static void clk_ipu_disable(struct clk *clk) { -#if defined(CONFIG_MX51) || defined(CONFIG_MX53) u32 reg;
reg = __raw_readl(clk->enable_reg); reg &= ~(MXC_CCM_CCGR_CG_MASK << clk->enable_shift); __raw_writel(reg, clk->enable_reg);
+#if defined(CONFIG_MX51) || defined(CONFIG_MX53) /* * No handshake with IPU whe dividers are changed * as its not enabled. @@ -211,9 +211,15 @@ static void clk_ipu_disable(struct clk *clk) static struct clk ipu_clk = { .name = "ipu_clk", .rate = CONFIG_IPUV3_CLK, +#if defined(CONFIG_MX51) || defined(CONFIG_MX53) .enable_reg = (u32 *)(CCM_BASE_ADDR + offsetof(struct mxc_ccm_reg, CCGR5)), .enable_shift = MXC_CCM_CCGR5_CG5_OFFSET, +#else + .enable_reg = (u32 *)(CCM_BASE_ADDR + + offsetof(struct mxc_ccm_reg, CCGR3)), + .enable_shift = MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET, +#endif .enable = clk_ipu_enable, .disable = clk_ipu_disable, .usecount = 0,
Eric Nelson
