[U-Boot] [RFCv2 1/3] omap3evm: Reorder related config options
This patch brings related config options together. Some formatting changes were also done for consistent look-n-feel after the movement.
The patch doesn't make/include any other functional change.
Signed-off-by: Sanjeev Premi premi@ti.com --- include/configs/omap3_evm.h | 404 ++++++++++++++++++++++--------------------- 1 files changed, 210 insertions(+), 194 deletions(-)
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index e925f3b..0cb12db 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -34,47 +34,79 @@ #define __CONFIG_H
/* - * High Level Configuration Options + * High level configuration options */ #define CONFIG_ARMV7 1 /* This is an ARM V7 CPU core */ #define CONFIG_OMAP 1 /* in a TI OMAP core */ #define CONFIG_OMAP34XX 1 /* which is a 34XX */ #define CONFIG_OMAP3430 1 /* which is in a 3430 */ #define CONFIG_OMAP3_EVM 1 /* working with EVM */ +#define CONFIG_SDRC 1 /* chip has SDRC controller */ +#define CONFIG_OMAP3_MICRON_DDR 1 +#define CONFIG_TWL4030_POWER 1
-#define CONFIG_SDRC /* The chip has SDRC controller */ - -#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/cpu.h> /* get chip and board defs */ #include <asm/arch/omap3.h>
+#undef CONFIG_USE_IRQ /* no support for IRQs */ + /* - * Display CPU and Board information + * Clock related definitions */ -#define CONFIG_DISPLAY_CPUINFO 1 -#define CONFIG_DISPLAY_BOARDINFO 1 - -/* Clock Defines */ #define V_OSCK 26000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK >> 1)
-#undef CONFIG_USE_IRQ /* no support for IRQs */ -#define CONFIG_MISC_INIT_R - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 -#define CONFIG_REVISION_TAG 1 +/* + * OMAP3 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000
/* * Size of malloc() pool */ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ - /* Sector */ + /* Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */ /* - * Hardware drivers + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4 << 10) /* IRQ stack 4 KiB */ +#define CONFIG_STACKSIZE_FIQ (4 << 10) /* FIQ stack 4 KiB */ +#endif + +/* + * Physical Memory Map + * Note 1: CS1 may or may not be populated + * Note 2: SDRAM size is expected to be at least 32MB + */ +#define CONFIG_NR_DRAM_BANKS 2 +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* Limits for memtest */ +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ + 0x01F00000) /* 31MB */ +/* + * SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/* + * Default load address + */ +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0)
/* * NS16550 Configuration @@ -90,23 +122,112 @@ * select serial console configuration */ #define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 #define CONFIG_SERIAL1 1 /* UART1 on OMAP3 EVM */ - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} + +/* + * Size of Console IO Buffer + */ +#define CONFIG_SYS_CBSIZE 256 + +/* + * Size of print buffer + */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* + * Size of bootarg buffer + */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +/* + * I2C + */ +#define CONFIG_HARD_I2C 1 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* + * PISMO support + */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M + +/* Max number of sectors on one chip */ +#define CONFIG_SYS_MAX_FLASH_SECT 520 + +/* Max number of flash banks */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 + +#define CONFIG_SYS_FLASH_BASE boot_flash_base + +/* Monitor at start of flash */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_SYS_ENV_SECT_SIZE boot_flash_sec +#define CONFIG_ENV_OFFSET boot_flash_off +#define CONFIG_ENV_ADDR boot_flash_env_addr + +/* + * Start location of environment + */ +#define ONENAND_ENV_OFFSET 0x260000 +#define SMNAND_ENV_OFFSET 0x260000 + +/* + * NAND + */ +/* Physical address to access NAND */ +#define CONFIG_SYS_NAND_ADDR NAND_BASE + +/* Physical address to access NAND at CS0 */ +#define CONFIG_SYS_NAND_BASE NAND_BASE + +/* Max number of NAND devices */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +/* Timeout values (in ticks) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) + +/* Flash banks JFFS2 should use */ +#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + \ + CONFIG_SYS_MAX_NAND_DEVICE) + +#define CONFIG_SYS_JFFS2_MEM_NAND +#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +#define CONFIG_JFFS2_NAND +/* nand device jffs2 lives on */ +#define CONFIG_JFFS2_DEV "nand0" +/* Start of jffs2 partition */ +#define CONFIG_JFFS2_PART_OFFSET 0x680000 +/* Size of jffs2 partition */ +#define CONFIG_JFFS2_PART_SIZE 0xf980000 + +#define CONFIG_SYS_NO_FLASH + +/* + * MMC + */ #define CONFIG_MMC 1 #define CONFIG_OMAP3_MMC 1 #define CONFIG_DOS_PARTITION 1
-/* DDR - I use Micron DDR */ -#define CONFIG_OMAP3_MICRON_DDR 1 - -/* USB - * Enable CONFIG_MUSB_HCD for Host functionalities MSC, keyboard +/* + * USB + * + * Enable CONFIG_MUSB_HCD for Host functionalities e.g. MSC, keyboard * Enable CONFIG_MUSB_UDD for Device functionalities. */ #define CONFIG_USB_OMAP3 1 @@ -124,7 +245,7 @@
#ifdef CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL -#define CONFIG_PREBOOT "usb start" +#define CONFIG_PREBOOT "usb start" #endif /* CONFIG_USB_KEYBOARD */
#endif /* CONFIG_MUSB_HCD */ @@ -143,7 +264,39 @@
#endif /* CONFIG_USB_OMAP3 */
-/* commands to include */ +#ifndef __ASSEMBLY__ +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + +/* + * U-boot features + */ +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT "OMAP3_EVM # " +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_MAXARGS 16 /* max args for a command */ + +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +#define CONFIG_MISC_INIT_R 1 + +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_AUTO_COMPLETE 1 + +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* + * Common commands + */ #include <config_cmd_default.h>
#define CONFIG_CMD_EXT2 /* EXT2 Support */ @@ -161,41 +314,39 @@ #undef CONFIG_CMD_IMI /* iminfo */ #undef CONFIG_CMD_IMLS /* List all found images */
-#define CONFIG_SYS_NO_FLASH -#define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 100000 -#define CONFIG_SYS_I2C_SLAVE 1 -#define CONFIG_SYS_I2C_BUS 0 -#define CONFIG_SYS_I2C_BUS_SELECT 1 -#define CONFIG_DRIVER_OMAP34XX_I2C 1 - /* - * TWL4030 + * Additional definitions that depend on chosen commands */ -#define CONFIG_TWL4030_POWER 1 +/* NAND */ +#if defined(CONFIG_CMD_NAND) +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 +#define CONFIG_ENV_IS_IN_NAND +#elif defined(CONFIG_CMD_ONENAND) +#define CONFIG_ENV_IS_IN_ONENAND 1 +#endif
-/* - * Board NAND Info. - */ -#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ - /* to access nand */ -#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ - /* to access */ - /* nand at CS0 */ - -#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ - /* NAND devices */ -#define CONFIG_JFFS2_NAND -/* nand device jffs2 lives on */ -#define CONFIG_JFFS2_DEV "nand0" -/* start of jffs2 partition */ -#define CONFIG_JFFS2_PART_OFFSET 0x680000 -#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* sz of jffs2 part */ +/* Ethernet (SMSC9115 from SMSC9118 family) */ +#if defined(CONFIG_CMD_NET) + +#define CONFIG_NET_MULTI +#define CONFIG_SMC911X +#define CONFIG_SMC911X_32_BIT +#define CONFIG_SMC911X_BASE 0x2C000000 + +/* BOOTP fields */ +#define CONFIG_BOOTP_SUBNETMASK 0x00000001 +#define CONFIG_BOOTP_GATEWAY 0x00000002 +#define CONFIG_BOOTP_HOSTNAME 0x00000004 +#define CONFIG_BOOTP_BOOTPATH 0x00000010
-/* Environment information */ -#define CONFIG_BOOTDELAY 10 +#endif /* (CONFIG_CMD_NET) */
-#define CONFIG_BOOTFILE uImage +/* + * Environment and boot command + */ +#define CONFIG_BOOTDELAY 10 +#define CONFIG_BOOTFILE uImage
#define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x82000000\0" \ @@ -231,139 +382,4 @@ "fi; " \ "else run nandboot; fi"
-#define CONFIG_AUTO_COMPLETE 1 -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#define CONFIG_SYS_PROMPT "OMAP3_EVM # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command */ - /* args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) -/* memtest works on */ -#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) -#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ - 0x01F00000) /* 31MB */ - -#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ - /* address */ - -/* - * OMAP3 has 12 GP timers, they can be driven by the system clock - * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). - * This rate is divided by a local divisor. - */ -#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 -#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ -#define CONFIG_SYS_HZ 1000 - -/*----------------------------------------------------------------------- - * Stack sizes - * - * The stack sizes are set up in start.S using the settings below - */ -#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ -#ifdef CONFIG_USE_IRQ -#define CONFIG_STACKSIZE_IRQ (4 << 10) /* IRQ stack 4 KiB */ -#define CONFIG_STACKSIZE_FIQ (4 << 10) /* FIQ stack 4 KiB */ -#endif - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ -#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 -#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 MiB */ -#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 - -/* SDRAM Bank Allocation method */ -#define SDRC_R_B_C 1 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ - -/* **** PISMO SUPPORT *** */ - -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M - -#define CONFIG_SYS_MAX_FLASH_SECT 520 /* max number of sectors */ - /* on one chip */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ - -#define CONFIG_SYS_FLASH_BASE boot_flash_base - -/* Monitor at start of flash */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP - -#if defined(CONFIG_CMD_NAND) -#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 -#define CONFIG_ENV_IS_IN_NAND -#elif defined(CONFIG_CMD_ONENAND) -#define CONFIG_ENV_IS_IN_ONENAND 1 -#endif -#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ -#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ - -#define CONFIG_SYS_ENV_SECT_SIZE boot_flash_sec -#define CONFIG_ENV_OFFSET boot_flash_off -#define CONFIG_ENV_ADDR boot_flash_env_addr - -/*----------------------------------------------------------------------- - * CFI FLASH driver setup - */ -/* timeout values are in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) - -/* Flash banks JFFS2 should use */ -#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + \ - CONFIG_SYS_MAX_NAND_DEVICE) -#define CONFIG_SYS_JFFS2_MEM_NAND -/* use flash_info[2] */ -#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS -#define CONFIG_SYS_JFFS2_NUM_BANKS 1 - -#ifndef __ASSEMBLY__ -extern unsigned int boot_flash_base; -extern volatile unsigned int boot_flash_env_addr; -extern unsigned int boot_flash_off; -extern unsigned int boot_flash_sec; -extern unsigned int boot_flash_type; -#endif - -/*---------------------------------------------------------------------------- - * SMSC9115 Ethernet from SMSC9118 family - *---------------------------------------------------------------------------- - */ -#if defined(CONFIG_CMD_NET) - -#define CONFIG_NET_MULTI -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE 0x2C000000 - -#endif /* (CONFIG_CMD_NET) */ - -/* - * BOOTP fields - */ - -#define CONFIG_BOOTP_SUBNETMASK 0x00000001 -#define CONFIG_BOOTP_GATEWAY 0x00000002 -#define CONFIG_BOOTP_HOSTNAME 0x00000004 -#define CONFIG_BOOTP_BOOTPATH 0x00000010 - #endif /* __CONFIG_H */
Sanjeev Premi
