[PATCH v2] ls10xxx: Use a sane SPL_SYS_MALLOC_F_LEN default
SPL_SYS_MALLOC_F_LEN defaults to SYS_MALLOC_F_LEN. 0x10000 is 64 KiB, or around half of the total OCRAM size. Revert to the default of 0x2000. This fixes SPL boot.
Fixes: 545eceb520 ("imx8/ls10xx: Use a sane SYS_MALLOC_F_LEN default") Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Fabio Estevam festevam@denx.de ---
Changes in v2: - Reduce SYS_MALLOC_F_LEN as well
Kconfig | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/Kconfig b/Kconfig index bdae59e06f..9aeb9d52ad 100644 --- a/Kconfig +++ b/Kconfig @@ -257,9 +257,7 @@ config SYS_MALLOC_F_LEN default 0x4000 if SANDBOX || RISCV || ARCH_APPLE || ROCKCHIP_RK3368 || \ ROCKCHIP_RK3399 default 0x8000 if RCAR_GEN3 - default 0x10000 if ARCH_IMX8 || (ARCH_IMX8M && !IMX8MQ) || \ - ARCH_LS1012A || ARCH_LS1021A || ARCH_LS1043A || \ - ARCH_LS1046A + default 0x10000 if ARCH_IMX8 || (ARCH_IMX8M && !IMX8MQ) default 0x2000 help Before relocation, memory is very limited on many platforms. Still,
Sean Anderson
