[PATCH] event.h: Documented some newly added portions better
After the merge of v2023.10-rc4 to next include/event.h needs to be fully documented in order for documentation builds to complete. Rewords two of the event_t descriptions to be docbook style and better match the rest of this enum. Fix two typos (flag->flags) in other comments.
Signed-off-by: Tom Rini trini@konsulko.com --- include/event.h | 17 +++++++++-------- 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/include/event.h b/include/event.h index c37deae94527..311df878c4a5 100644 --- a/include/event.h +++ b/include/event.h @@ -94,18 +94,19 @@ enum event_t { */ EVT_MISC_INIT_F,
- /* - * Emitted before relocation to set up Firmware Support Package - * + /** + * @EVT_FSP_INIT_F: + * This event is triggered before relocation to set up Firmware Support + * Package. * Where U-Boot relies on binary blobs to handle part of the system * init, this event can be used to set up the blobs. This is used on * some Intel platforms */ EVT_FSP_INIT_F,
- /* - * Emitted just before jumping to the main loop - * + /** + * @EVT_LAST_STAGE_INIT: + * This event is triggered just before jumping to the main loop. * Some boards need to perform initialisation immediately before control * is passed to the command-line interpreter (e.g. for init that depend * on later phases in the init sequence). @@ -222,7 +223,7 @@ typedef int (*event_handler_simple_t)(void); * * @func: Function to call when the event is activated (must be first) * @type: Event type - * @flag: Flags for this spy + * @flags: Flags for this spy * @id: Event id string */ struct evspy_info { @@ -241,7 +242,7 @@ struct evspy_info { * * @func: Function to call when the event is activated (must be first) * @type: Event type - * @flag: Flags for this spy + * @flags: Flags for this spy * @id: Event id string */ struct evspy_info_simple {
