[U-Boot] [PATCH v3 1/3] spi: sh_qspi: DM conversion
This patch adds support for DM to the sh_qspi SPI driver. The legacy functionality is removed in this version, so old boards in the tree is not working with legacy SPI driver functionality. Some TODOs are left over for later, These would be enhancements to the original functionality, and can come later.
Signed-off-by: Akash Gajjar akash@openedev.com --- changes in v2: Update Kconfig Replace __sh_qspi_setup to sh_qspi_setup Add missing memeber of platform data
changes in v3: Changes made on top of previous patch is merged in v3 --- drivers/spi/Kconfig | 12 +-- drivers/spi/sh_qspi.c | 199 ++++++++++++++++++------------------- include/dm/platform_data/qspi_sh.h | 15 +++ 3 files changed, 120 insertions(+), 106 deletions(-) create mode 100644 include/dm/platform_data/qspi_sh.h
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index ec92b84..81079c5 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -155,6 +155,12 @@ config SANDBOX_SPI }; };
+config SH_QSPI + bool "Renesas Quad SPI driver" + help + Enable the Renesas Quad SPI controller driver. This driver can be + used on Renesas SoCs. + config STM32_QSPI bool "STM32F7 QSPI driver" depends on STM32F7 @@ -259,12 +265,6 @@ config SH_SPI Enable the SuperH SPI controller driver. This driver can be used on various SuperH SoCs, such as SH7757.
-config SH_QSPI - bool "Renesas Quad SPI driver" - help - Enable the Renesas Quad SPI controller driver. This driver can be - used on Renesas SoCs. - config TI_QSPI bool "TI QSPI driver" help diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c index 5075be3..1ea24ce 100644 --- a/drivers/spi/sh_qspi.c +++ b/drivers/spi/sh_qspi.c @@ -1,6 +1,9 @@ /* * SH QSPI (Quad SPI) driver * + * Support for device model: + * Copyright (C) 2018 Akash Gajjar akash@openedev.com + * * Copyright (C) 2013 Renesas Electronics Corporation * Copyright (C) 2013 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com * @@ -14,6 +17,8 @@ #include <wait_bit.h> #include <asm/arch/rmobile.h> #include <asm/io.h> +#include <dm.h> +#include <dm/platform_data/qspi_sh.h>
/* SH QSPI register bit masks <REG>_<BIT> */ #define SPCR_MSTR 0x08 @@ -67,151 +72,89 @@ struct sh_qspi_regs { u32 spbmul3; };
-struct sh_qspi_slave { - struct spi_slave slave; - struct sh_qspi_regs *regs; +struct sh_qspi_priv { + struct sh_qspi_regs *regs; };
-static inline struct sh_qspi_slave *to_sh_qspi(struct spi_slave *slave) +static void sh_qspi_setup(struct sh_qspi_priv *priv) { - return container_of(slave, struct sh_qspi_slave, slave); -} + struct sh_qspi_regs *regs = priv->regs;
-static void sh_qspi_init(struct sh_qspi_slave *ss) -{ - /* QSPI initialize */ /* Set master mode only */ - writeb(SPCR_MSTR, &ss->regs->spcr); + writeb(SPCR_MSTR, ®s->spcr);
/* Set SSL signal level */ - writeb(0x00, &ss->regs->sslp); + writeb(0x00, ®s->sslp);
/* Set MOSI signal value when transfer is in idle state */ - writeb(SPPCR_IO3FV|SPPCR_IO2FV, &ss->regs->sppcr); + writeb(SPPCR_IO3FV | SPPCR_IO2FV, ®s->sppcr);
/* Set bit rate. See 58.3.8 Quad Serial Peripheral Interface */ - writeb(0x01, &ss->regs->spbr); + writeb(0x01, ®s->spbr);
/* Disable Dummy Data Transmission */ - writeb(0x00, &ss->regs->spdcr); + writeb(0x00, ®s->spdcr);
/* Set clock delay value */ - writeb(0x00, &ss->regs->spckd); + writeb(0x00, ®s->spckd);
/* Set SSL negation delay value */ - writeb(0x00, &ss->regs->sslnd); + writeb(0x00, ®s->sslnd);
/* Set next-access delay value */ - writeb(0x00, &ss->regs->spnd); + writeb(0x00, ®s->spnd);
/* Set equence command */ - writew(SPCMD_INIT2, &ss->regs->spcmd0); - - /* Reset transfer and receive Buffer */ - setbits_8(&ss->regs->spbfcr, SPBFCR_TXRST|SPBFCR_RXRST); - - /* Clear transfer and receive Buffer control bit */ - clrbits_8(&ss->regs->spbfcr, SPBFCR_TXRST|SPBFCR_RXRST); - - /* Set equence control method. Use equence0 only */ - writeb(0x00, &ss->regs->spscr); - - /* Enable SPI function */ - setbits_8(&ss->regs->spcr, SPCR_SPE); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return 1; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - struct sh_qspi_slave *ss = to_sh_qspi(slave); - - /* Set master mode only */ - writeb(SPCR_MSTR, &ss->regs->spcr); - - /* Set command */ - writew(SPCMD_INIT1, &ss->regs->spcmd0); + writew(SPCMD_INIT2, ®s->spcmd0);
/* Reset transfer and receive Buffer */ - setbits_8(&ss->regs->spbfcr, SPBFCR_TXRST|SPBFCR_RXRST); + setbits_8(®s->spbfcr, SPBFCR_TXRST | SPBFCR_RXRST);
/* Clear transfer and receive Buffer control bit */ - clrbits_8(&ss->regs->spbfcr, SPBFCR_TXRST|SPBFCR_RXRST); + clrbits_8(®s->spbfcr, SPBFCR_TXRST | SPBFCR_RXRST);
/* Set equence control method. Use equence0 only */ - writeb(0x00, &ss->regs->spscr); + writeb(0x00, ®s->spscr);
/* Enable SPI function */ - setbits_8(&ss->regs->spcr, SPCR_SPE); -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - struct sh_qspi_slave *ss = to_sh_qspi(slave); - - /* Disable SPI Function */ - clrbits_8(&ss->regs->spcr, SPCR_SPE); + setbits_8(®s->spcr, SPCR_SPE); }
-void spi_init(void) +static int sh_qspi_set_speed(struct udevice *bus, uint hz) { - /* nothing to do */ -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct sh_qspi_slave *ss; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - ss = spi_alloc_slave(struct sh_qspi_slave, bus, cs); - if (!ss) { - printf("SPI_error: Fail to allocate sh_qspi_slave\n"); - return NULL; - } - - ss->regs = (struct sh_qspi_regs *)SH_QSPI_BASE; - - /* Init SH QSPI */ - sh_qspi_init(ss); - - return &ss->slave; + return 0; }
-void spi_free_slave(struct spi_slave *slave) +static int sh_qspi_set_mode(struct udevice *bus, uint mode) { - struct sh_qspi_slave *spi = to_sh_qspi(slave); - - free(spi); + return 0; }
-int spi_claim_bus(struct spi_slave *slave) +static int sh_qspi_claim_bus(struct udevice *dev) { return 0; }
-void spi_release_bus(struct spi_slave *slave) +static int sh_qspi_release_bus(struct udevice *dev) { + return 0; }
-int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, - void *din, unsigned long flags) +static int sh_qspi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) { - struct sh_qspi_slave *ss = to_sh_qspi(slave); + struct udevice *bus = dev_get_parent(dev); + struct sh_qspi_priv *priv = dev_get_priv(bus); + struct sh_qspi_regs *regs = priv->regs; u32 nbyte, chunk; int i, ret = 0; u8 dtdata = 0, drdata; u8 *tdata = &dtdata, *rdata = &drdata; - u32 *spbmul0 = &ss->regs->spbmul0; + u32 *spbmul0 = ®s->spbmul0;
if (dout == NULL && din == NULL) { if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); + spi_cs_deactivate(regs); /* TODO */ return 0; }
@@ -223,7 +166,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, nbyte = bitlen / 8;
if (flags & SPI_XFER_BEGIN) { - spi_cs_activate(slave); + spi_cs_activate(regs); /* TODO */
/* Set 1048576 byte */ writel(0x100000, spbmul0); @@ -245,27 +188,27 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, */ chunk = (nbyte >= 32) ? 32 : 1;
- clrsetbits_8(&ss->regs->spbfcr, SPBFCR_TXTRG | SPBFCR_RXTRG, + clrsetbits_8(®s->spbfcr, SPBFCR_TXTRG | SPBFCR_RXTRG, chunk == 32 ? SPBFCR_TXTRG | SPBFCR_RXTRG : 0);
- ret = wait_for_bit_8(&ss->regs->spsr, SPSR_SPTEF, + ret = wait_for_bit_8(®s->spsr, SPSR_SPTEF, true, 1000, true); if (ret) return ret;
for (i = 0; i < chunk; i++) { - writeb(*tdata, &ss->regs->spdr); + writeb(*tdata, ®s->spdr); if (dout != NULL) tdata++; }
- ret = wait_for_bit_8(&ss->regs->spsr, SPSR_SPRFF, + ret = wait_for_bit_8(®s->spsr, SPSR_SPRFF, true, 1000, true); if (ret) return ret;
for (i = 0; i < chunk; i++) { - *rdata = readb(&ss->regs->spdr); + *rdata = readb(®s->spdr); if (din != NULL) rdata++; } @@ -274,7 +217,63 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, }
return ret; } + +static int sh_qspi_probe(struct udevice *bus) +{ + struct sh_qspi_platdata *plat = bus->platdata; + struct sh_qspi_priv *priv = dev_get_priv(bus); + + priv->regs = plat->regs; + + sh_qspi_setup(priv); + + return 0; +} + +static const struct dm_spi_ops sh_qspi_ops = { + .claim_bus = sh_qspi_claim_bus, + .release_bus = sh_qspi_release_bus, + .xfer = sh_qspi_xfer, + .set_speed = sh_qspi_set_speed, + .set_mode = sh_qspi_set_mode, +}; + +#if CONFIG_IS_ENABLED(OF_CONTROL) +static int sh_qspi_ofdata_to_platadata(struct udevice *bus) +{ + struct sh_qspi_platdata *plat = bus->platdata; + fdt_addr_t addr; + + addr = devfdt_get_addr(bus); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->regs = (struct sh_qspi_regs *regs)addr; + + return 0; +} + +/* TODO: update comptaible device tree binding */ +static const struct udevice_id sh_qspi_ids[] = { + { .compatible = " " }, + { } +}; +#endif + +U_BOOT_DRIVER(sh_qspi) = { + .name = "sh_qspi", + .id = UCLASS_SPI, +#if CONFIG_IS_ENABLED(OF_CONTROL) + .of_match = sh_qspi_ids, + .ofdata_to_platdata = sh_qspi_ofdata_to_platadata, + .platdata_auto_alloc_size = sizeof(struct sh_qspi_platdata), +#endif + .ops = &sh_qspi_ops, + .priv_auto_alloc_size = sizeof(struct sh_qspi_priv), + .probe = sh_qspi_probe, +}; +#endif diff --git a/include/dm/platform_data/qspi_sh.h b/include/dm/platform_data/qspi_sh.h new file mode 100644 index 0000000..4e24e51 --- /dev/null +++ b/include/dm/platform_data/qspi_sh.h @@ -0,0 +1,15 @@ +/* + * Copyright (c) 2018 Akash Gajjar akash@openedev.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __qspi_sh_h +#define __qspi_sh_h + +struct sh_qspi_platdata { + struct sh_qspi_regs *regs; + uint cs; +}; + +#endif /* __qspi_sh_h */
Akash Gajjar
