[U-Boot] [PATCH 2/3] add mcf5307 support
Architecture includes.
# new file: arch/m68k/include/asm/immap_5307.h # new file: arch/m68k/include/asm/m5307.h
Signed-off-by: Angelo Dureghello sysamfw@gmail.com ---
diff --git a/arch/m68k/include/asm/immap_5307.h b/arch/m68k/include/asm/immap_5307.h new file mode 100644 index 0000000..cb58297 --- /dev/null +++ b/arch/m68k/include/asm/immap_5307.h @@ -0,0 +1,78 @@ +/* + * MCF5307 Internal Memory Map + * + * Copyright (c) 2011 Angelo Dureghello sysamfw@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __IMMAP_5307__ +#define __IMMAP_5307__ + +#define MMAP_INTC (CONFIG_SYS_MBAR + 0x00000040) +#define MMAP_CSM (CONFIG_SYS_MBAR + 0x00000080) +#define MMAP_DTMR0 (CONFIG_SYS_MBAR + 0x00000140) +#define MMAP_DTMR1 (CONFIG_SYS_MBAR + 0x00000180) +#define MMAP_UART0 (CONFIG_SYS_MBAR + 0x000001C0) +#define MMAP_UART1 (CONFIG_SYS_MBAR + 0x00000200) + +typedef struct csm { + u16 csar0; /* Chip-select Address */ + u16 res0a; + u32 csmr0; /* Chip-select Mask */ + u16 res0b; + u16 cscr0; /* Chip-select Control */ + u16 csar1; + u16 res1a; + u32 csmr1; + u16 res1b; + u16 cscr1; + u16 csar2; + u16 res2a; + u32 csmr2; + u16 res2b; + u16 cscr2; + u16 csar3; + u16 res3a; + u32 csmr3; + u16 res3b; + u16 cscr3; + u16 csar4; + u16 res4a; + u32 csmr4; + u16 res4b; + u16 cscr4; + u16 csar5; + u16 res5a; + u32 csmr5; + u16 res5b; + u16 cscr5; + u16 csar6; + u16 res6a; + u32 csmr6; + u16 res6b; + u16 cscr6; + u16 csar7; + u16 res7a; + u32 csmr7; + u16 res7b; + u16 cscr7; +} csm_t; + +#endif /* __IMMAP_5307__ */ diff --git a/arch/m68k/include/asm/m5307.h b/arch/m68k/include/asm/m5307.h new file mode 100644 index 0000000..edb1bf2 --- /dev/null +++ b/arch/m68k/include/asm/m5307.h @@ -0,0 +1,119 @@ +/* + * mcf5307.h -- Definitions for Motorola Coldfire 5307 + * + * Copyright (c) 2011 Angelo Dureghello sysamfw@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef mcf5307_h +#define mcf5307_h +/****************************************************************************/ + +/* + * useful definitions for reading/writing MBAR offset memory + */ +#define mbar_readLong(x) *((volatile unsigned long *) (CONFIG_SYS_MBAR + x)) +#define mbar_writeLong(x,y) *((volatile unsigned long *) (CONFIG_SYS_MBAR + x)) = y +#define mbar_writeShort(x,y) *((volatile unsigned short *) (CONFIG_SYS_MBAR + x)) = y +#define mbar_writeByte(x,y) *((volatile unsigned char *) (CONFIG_SYS_MBAR + x)) = y + +/* + * Size of internal RAM + */ + +#define INT_RAM_SIZE 4096 /* RAMBAR - 4k */ + +/* + * Define the 5249 SIM register set addresses. + */ + +/***************** + ***** MBAR ***** + *****************/ +#define MCFSIM_RSR 0x00 /* Reset Status reg (r/w) */ +#define MCFSIM_SYPCR 0x01 /* System Protection reg (r/w) */ +#define MCFSIM_SWIVR 0x02 /* SW Watchdog intr reg (r/w) */ +#define MCFSIM_SWSR 0x03 /* SW Watchdog service (r/w) */ +#define MCFSIM_PLLCR 0x08 /* PLL Control register */ +#define MCFSIM_MPARK 0x0c /* Bus master park register (r/w) */ + +#define MCFSIM_SIMR 0x00 /* SIM Config reg (r/w) */ +#define MCFSIM_ICR0 0x4c /* Intr Ctrl reg 0 (r/w) */ +#define MCFSIM_ICR1 0x4d /* Intr Ctrl reg 1 (r/w) */ +#define MCFSIM_ICR2 0x4e /* Intr Ctrl reg 2 (r/w) */ +#define MCFSIM_ICR3 0x4f /* Intr Ctrl reg 3 (r/w) */ +#define MCFSIM_ICR4 0x50 /* Intr Ctrl reg 4 (r/w) */ +#define MCFSIM_ICR5 0x51 /* Intr Ctrl reg 5 (r/w) */ +#define MCFSIM_ICR6 0x52 /* Intr Ctrl reg 6 (r/w) */ +#define MCFSIM_ICR7 0x53 /* Intr Ctrl reg 7 (r/w) */ +#define MCFSIM_ICR8 0x54 /* Intr Ctrl reg 8 (r/w) */ +#define MCFSIM_ICR9 0x55 /* Intr Ctrl reg 9 (r/w) */ +#define MCFSIM_ICR10 0x56 /* Intr Ctrl reg 10 (r/w) */ +#define MCFSIM_ICR11 0x57 /* Intr Ctrl reg 11 (r/w) */ + +#define MCFSIM_IPR 0x40 /* Interrupt Pend reg (r/w) */ +#define MCFSIM_IMR 0x44 /* Interrupt Mask reg (r/w) */ + +#define MCFSIM_DCR 0x100 /* DRAM Control reg (r/w) */ +#define MCFSIM_DACR0 0x108 /* DRAM 0 Addr and Ctrl (r/w) */ +#define MCFSIM_DMR0 0x10c /* DRAM 0 Mask reg (r/w) */ +#define MCFSIM_DACR1 0x110 /* DRAM 1 Addr and Ctrl (r/w) */ +#define MCFSIM_DMR1 0x114 /* DRAM 1 Mask reg (r/w) */ + +/* + * Some symbol defines for the above... + */ +#define MCFSIM_SWDICR MCFSIM_ICR0 /* Watchdog timer ICR */ +#define MCFSIM_TIMER1ICR MCFSIM_ICR1 /* Timer 1 ICR */ +#define MCFSIM_TIMER2ICR MCFSIM_ICR2 /* Timer 2 ICR */ +#define MCFSIM_I2CICR MCFSIM_ICR3 /* I2C ICR */ +#define MCFSIM_UART1ICR MCFSIM_ICR4 /* UART 1 ICR */ +#define MCFSIM_UART2ICR MCFSIM_ICR5 /* UART 2 ICR */ +/* XXX - If needed, DMA ICRs go here */ + +/* + * Bit definitions for the ICR family of registers. + */ +#define MCFSIM_ICR_AUTOVEC 0x80 /* Auto-vectored intr */ +#define MCFSIM_ICR_LEVEL0 0x00 /* Level 0 intr */ +#define MCFSIM_ICR_LEVEL1 0x04 /* Level 1 intr */ +#define MCFSIM_ICR_LEVEL2 0x08 /* Level 2 intr */ +#define MCFSIM_ICR_LEVEL3 0x0c /* Level 3 intr */ +#define MCFSIM_ICR_LEVEL4 0x10 /* Level 4 intr */ +#define MCFSIM_ICR_LEVEL5 0x14 /* Level 5 intr */ +#define MCFSIM_ICR_LEVEL6 0x18 /* Level 6 intr */ +#define MCFSIM_ICR_LEVEL7 0x1c /* Level 7 intr */ + +#define MCFSIM_ICR_PRI0 0x00 /* Priority 0 intr */ +#define MCFSIM_ICR_PRI1 0x01 /* Priority 1 intr */ +#define MCFSIM_ICR_PRI2 0x02 /* Priority 2 intr */ +#define MCFSIM_ICR_PRI3 0x03 /* Priority 3 intr */ + +/* + * Macros to read/set IMR register. It is 32 bits on the 5307. + */ + +#define mcf_getimr() \ + *((volatile unsigned long *) (MCF_MBAR + MCFSIM_IMR)) + +#define mcf_setimr(imr) \ + *((volatile unsigned long *) (MCF_MBAR + MCFSIM_IMR)) = (imr); + +#endif /* mcf5307_h */
Angelo Dureghello
