Re: [U-Boot] Intermediate ARM status
Hi Anatolij,
On Sat, 25 Aug 2012 17:47:57 +0200, Anatolij Gustschin agust@denx.de wrote:
Hi Albert,
On Sat, 25 Aug 2012 14:22:26 +0200 Albert ARIBAUD albert.u.boot@aribaud.net wrote: ...
ydirectenv.h:69:0: warning: "vfree" redefined [enabled by default] /home/uboot/src/u-boot-arm/include/linux/compat.h:24:0: note: this is the location of the previous definition In file included from yportenv.h:80:0,
I believe the errors / warnings have nothing to do with the arm sub-tree ARM commits per se.
Yes, these appear with the current master branch, too. A patch fixing them is already pending, http://patchwork.ozlabs.org/patch/177537/
It does fix some, but not all warnings:
=========================================================================== uboot@lilith:~/src/u-boot-arm$ time LANG=C BUILD_NBUILDS=7 BUILD_NCPUS=1 ./MAKEALL VCMA9 smdk2410 Configuring for VCMA9 board... Configuring for smdk2410 board... text data bss dec hex filename 482924 10292 287516 780732 be9bc ./build/smdk2410/u-boot yaffs_guts.c: In function 'yaffs_check_chunk_erased': yaffs_guts.c:324:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_verify_chunk_written': yaffs_guts.c:352:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_grab_chunk_cache': yaffs_guts.c:1488:6: warning: variable 'pushout' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_check_obj_details_loaded': yaffs_guts.c:3180:6: warning: variable 'alloc_failed' set but not used [-Wunused-but-set-variable] yaffs_guts.c:3179:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_update_oh': yaffs_guts.c:3288:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_get_obj_name': yaffs_guts.c:4447:7: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_summary.c: In function 'yaffs_summary_read': yaffs_summary.c:194:6: warning: variable 'sum_tags_bytes' set but not used [-Wunused-but-set-variable] yaffs_verify.c: In function 'yaffs_verify_file': yaffs_verify.c:227:6: warning: variable 'actual_depth' set but not used [-Wunused-but-set-variable] yaffs_yaffs1.c: In function 'yaffs1_scan': yaffs_yaffs1.c:26:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_chunk': yaffs_yaffs2.c:949:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_backwards': yaffs_yaffs2.c:1352:6: warning: variable 'deleted' set but not used [-Wunused-but-set-variable] text data bss dec hex filename 508063 10688 287580 806331 c4dbb ./build/VCMA9/u-boot yaffs_guts.c: In function 'yaffs_check_chunk_erased': yaffs_guts.c:324:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_verify_chunk_written': yaffs_guts.c:352:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_grab_chunk_cache': yaffs_guts.c:1488:6: warning: variable 'pushout' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_check_obj_details_loaded': yaffs_guts.c:3180:6: warning: variable 'alloc_failed' set but not used [-Wunused-but-set-variable] yaffs_guts.c:3179:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_update_oh': yaffs_guts.c:3288:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_guts.c: In function 'yaffs_get_obj_name': yaffs_guts.c:4447:7: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_summary.c: In function 'yaffs_summary_read': yaffs_summary.c:194:6: warning: variable 'sum_tags_bytes' set but not used [-Wunused-but-set-variable] yaffs_verify.c: In function 'yaffs_verify_file': yaffs_verify.c:227:6: warning: variable 'actual_depth' set but not used [-Wunused-but-set-variable] yaffs_yaffs1.c: In function 'yaffs1_scan': yaffs_yaffs1.c:26:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_chunk': yaffs_yaffs2.c:949:6: warning: variable 'result' set but not used [-Wunused-but-set-variable] yaffs_yaffs2.c: In function 'yaffs2_scan_backwards': yaffs_yaffs2.c:1352:6: warning: variable 'deleted' set but not used [-Wunused-but-set-variable]
--------------------- SUMMARY ---------------------------- Boards compiled: 2 Boards with warnings but no errors: 2 ( VCMA9 smdk2410 ) ----------------------------------------------------------
real 0m29.001s user 0m40.947s sys 0m6.328s ===========================================================================
Although, it may be my toolchain being more sensitive than others.
Thanks,
Anatolij
Amicalement,
Dear Albert ARIBAUD,
Hi Anatolij,
wrote:
Hi Albert,
Yaffs is borked indeed, I submitted similar patch that Charles did, but his is better indeed. Maybe we can ask Detlev to apply some of the pulls ?
Best regards, Marek Vasut
Albert ARIBAUD
