[GIT PULL] xilinx patches for v2023.07-rc1
Hi Tom,
please pull these patches to your next branch. CI loop doesn't report any issue.
Thanks, Michal
The following changes since commit 70ed05ce6c051e55e126e67e72ab20409134c953:
Merge tag 'next-20230307' of https://source.denx.de/u-boot/custodians/u-boot-video into next (2023-03-07 12:54:01 -0500)
git@source.denx.de:u-boot/custodians/u-boot-microblaze.git tags/xilinx-for-v2023.07-rc1
for you to fetch changes up to 7ac50f88f8a9374e5cb4bc2a88c002d02ef3c570:
microblaze: drop remnants of manual reloc (2023-03-13 11:46:17 +0100)
---------------------------------------------------------------- Xilinx changes for v2023.07-rc1
cmd: - Print results in hex instead of dec in smc command
firmware: - Cover missing ZYNQMP_FIRMWARE dependencies
fpga: - fix loads for unencrypted use case
relocation - Add support for BE systems
spi: - Fix xilinx_spi init reset sequence
arasan nand: - Remove hardcoded bbt option - Set ofnode value
xilinx: - Enable SMC command - Fix some sparse issues
zynqmp: - Remove cdns,zynq-gem compatible string - Add optee node - Some DT cleanups
zynq: - Some DT cleanups
microblaze - Remove MANUAL_RELOC option
---------------------------------------------------------------- Algapally Santosh Sagar (3): arm64: zynqmp: Add missing ZYNQMP_FIRMWARE dependencies xilinx: zynqmp: Add missing prototype for zynqmp_mmio_write spl: Add missing prototype for board_boot_order
Ashok Reddy Soma (4): mtd: nand: arasan: Remove hardcoded bbt option mtd: nand: arasan: Set ofnode value arm64: dts: zynqmp: Fix nand dt node arm64: dts: zynqmp: Enable nand-on-flash-bbt in DT by default
Ilias Apalodimas (1): arm64: zynqmp: Add an OP-TEE node to the device tree
Jiajie Chen (1): spi: xilinx_spi: Fix spi reset
Krzysztof Kozlowski (3): arm64: dts: xilinx: align LED node names with dtschema ARM: dts: xilinx: align gpio-key node names with dtschema ARM: dts: zynq-7000: drop useless 'dma-channels/requests' properties
Michael Grzeschik (1): arm64: zynqmp: Enable hs termination flag for USB dwc3 controller
Michal Simek (6): xilinx: dts: Remove cdns,zynq-gem ARM: zynq: Use recommended dma-controller name instead of dmac ARM: zynq: Comment interrupt names IRQs for pl330 cmd: smccc: Print results in hex instead of dec xilinx: Enable SMC command for arm64 targets arm64: zynqmp: Remove comment about gem spec in kv260
Neal Frager (1): fpga: zynqmppl: fix fpga loads command for unencrypted use case
Ovidiu Panait (5): tools: relocate-rela: adjust le64_to_cpu -> le32_to_cpu in decode_elf32() tools: relocate-rela: introduce elf16_to_cpu() and elf32_to_cpu() tools: relocate-rela: add support for handling 32-bit big endian files microblaze: drop CONFIG_NEEDS_MANUAL_RELOC microblaze: drop remnants of manual reloc
arch/arm/dts/zynq-7000.dtsi | 14 +-- arch/arm/dts/zynq-zc702.dts | 4 +- arch/arm/dts/zynq-zturn-common.dtsi | 2 +- arch/arm/dts/zynqmp-sck-kr-g-revA.dts | 2 +- arch/arm/dts/zynqmp-sck-kr-g-revB.dts | 2 +- arch/arm/dts/zynqmp-sck-kv-g-revA.dts | 4 +- arch/arm/dts/zynqmp-sck-kv-g-revB.dts | 4 +- arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 2 + arch/arm/dts/zynqmp-zc1751-xm017-dc3.dts | 119 ++++++++++++-------- arch/arm/dts/zynqmp-zcu100-revC.dts | 2 +- arch/arm/dts/zynqmp.dtsi | 15 ++- arch/arm/mach-versal-net/include/mach/sys_proto.h | 7 +- arch/arm/mach-versal/include/mach/sys_proto.h | 6 +- arch/microblaze/Kconfig | 13 +-- arch/microblaze/config.mk | 4 - arch/microblaze/cpu/Makefile | 3 +- arch/microblaze/cpu/start.S | 28 ----- board/xilinx/zynqmp/Kconfig | 1 + cmd/smccc.c | 2 +- configs/xilinx_versal_net_virt_defconfig | 1 + configs/xilinx_versal_virt_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + drivers/clk/Kconfig | 4 +- drivers/fpga/Kconfig | 2 +- drivers/fpga/zynqmppl.c | 12 +- drivers/mmc/zynq_sdhci.c | 5 +- drivers/mtd/nand/raw/arasan_nfc.c | 5 +- drivers/net/zynq_gem.c | 2 +- drivers/spi/xilinx_spi.c | 5 +- drivers/spi/zynqmp_gqspi.c | 5 + include/spl.h | 1 + tools/relocate-rela.c | 52 ++++++--- 32 files changed, 175 insertions(+), 155 deletions(-)
On Wed, Mar 15, 2023 at 02:07:30PM +0100, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
