[U-Boot] [PATCH] EXYNOS: SPI: Support word transfers
Since SPI register access is so expensive, it is worth transferring data a word at a time if we can. This complicates the driver unfortunately.
Use the byte-swapping feature to avoid having to convert to/from big endian in software.
This change increases speed from about 2MB/s to about 4.5MB/s.
Based on "EXYNOS: SPI: Minimise access to SPI FIFO level" link: http://patchwork.ozlabs.org/patch/230034/
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- arch/arm/include/asm/arch-exynos/spi.h | 11 ++++- drivers/spi/exynos_spi.c | 77 +++++++++++++++++++++++++------ 2 files changed, 72 insertions(+), 16 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/spi.h b/arch/arm/include/asm/arch-exynos/spi.h index 7cab1e9..e67ad27 100644 --- a/arch/arm/include/asm/arch-exynos/spi.h +++ b/arch/arm/include/asm/arch-exynos/spi.h @@ -34,7 +34,7 @@ struct exynos_spi { unsigned int rx_data; /* 0x1c */ unsigned int pkt_cnt; /* 0x20 */ unsigned char reserved2[4]; - unsigned char reserved3[4]; + unsigned int swap_cfg; /* 0x28 */ unsigned int fb_clk; /* 0x2c */ unsigned char padding[0xffd0]; }; @@ -74,5 +74,14 @@ struct exynos_spi { /* Packet Count */ #define SPI_PACKET_CNT_EN (1 << 16)
+/* Swap config */ +#define SPI_TX_SWAP_EN (1 << 0) +#define SPI_TX_BYTE_SWAP (1 << 2) +#define SPI_TX_HWORD_SWAP (1 << 3) +#define SPI_TX_BYTE_SWAP (1 << 2) +#define SPI_RX_SWAP_EN (1 << 4) +#define SPI_RX_BYTE_SWAP (1 << 6) +#define SPI_RX_HWORD_SWAP (1 << 7) + #endif /* __ASSEMBLY__ */ #endif diff --git a/drivers/spi/exynos_spi.c b/drivers/spi/exynos_spi.c index 7bbf9ce..d1918cf 100644 --- a/drivers/spi/exynos_spi.c +++ b/drivers/spi/exynos_spi.c @@ -218,12 +218,29 @@ static void spi_get_fifo_levels(struct exynos_spi *regs, * * @param regs SPI peripheral registers * @param count Number of bytes to transfer + * @param step Number of bytes to transfer in each packet (1 or 4) */ -static void spi_request_bytes(struct exynos_spi *regs, int count) +static void spi_request_bytes(struct exynos_spi *regs, int count, int step) { + /* For word address we need to swap bytes */ + if (step == 4) { + setbits_le32(®s->mode_cfg, + SPI_MODE_CH_WIDTH_WORD | SPI_MODE_BUS_WIDTH_WORD); + count /= 4; + setbits_le32(®s->swap_cfg, SPI_TX_SWAP_EN | SPI_RX_SWAP_EN | + SPI_TX_BYTE_SWAP | SPI_RX_BYTE_SWAP | + SPI_TX_HWORD_SWAP | SPI_RX_HWORD_SWAP); + } else { + /* Select byte access and clear the swap configuration */ + clrbits_le32(®s->mode_cfg, + SPI_MODE_CH_WIDTH_WORD | SPI_MODE_BUS_WIDTH_WORD); + writel(0, ®s->swap_cfg); + } + assert(count && count < (1 << 16)); setbits_le32(®s->ch_cfg, SPI_CH_RST); clrbits_le32(®s->ch_cfg, SPI_CH_RST); + writel(count | SPI_PACKET_CNT_EN, ®s->pkt_cnt); }
@@ -238,6 +255,7 @@ static int spi_rx_tx(struct exynos_spi_slave *spi_slave, int todo, int toread, preamable_count = 0; unsigned start = get_timer(0); int stopping; + int step;
out_bytes = in_bytes = todo;
@@ -245,10 +263,19 @@ static int spi_rx_tx(struct exynos_spi_slave *spi_slave, int todo, !(spi_slave->mode & SPI_SLAVE);
/* + * Try to transfer words if we can. This helps read performance at + * SPI clock speeds above about 20MHz. + */ + step = 1; + if (!((todo | (uintptr_t)rxp | (uintptr_t)txp) & 3) && + !spi_slave->skip_preamble) + step = 4; + + /* * If there's something to send, do a software reset and set a * transaction size. */ - spi_request_bytes(regs, todo); + spi_request_bytes(regs, todo, step);
/* * Bytes are transmitted/received in pairs. Wait to receive all the @@ -260,28 +287,44 @@ static int spi_rx_tx(struct exynos_spi_slave *spi_slave, int todo,
/* Keep the fifos full/empty. */ spi_get_fifo_levels(regs, &rx_lvl, &tx_lvl); + + /* + * Don't completely fill the txfifo, since we don't want our + * rxfifo to overflow, and it may already contain data. + */ while (tx_lvl < spi_slave->fifo_size / 2 && out_bytes) { - temp = txp ? *txp++ : 0xff; + if (!txp) + temp = -1; + else if (step == 4) + temp = *(uint32_t *)txp; + else + temp = *txp; writel(temp, ®s->tx_data); - out_bytes--; - tx_lvl++; + out_bytes -= step; + if (txp) + txp += step; + tx_lvl += step; } - if (rx_lvl > 0 && in_bytes) { - while (rx_lvl > 0 && in_bytes) { + if (rx_lvl >= step && in_bytes) { + while (rx_lvl >= step && in_bytes) { temp = readl(®s->rx_data); if (!rxp && !stopping) { - in_bytes--; + in_bytes -= step; } else if (spi_slave->skip_preamble) { if (temp == SPI_PREAMBLE_END_BYTE) { spi_slave->skip_preamble = 0; stopping = 0; } } else { - *rxp++ = temp; - in_bytes--; + if (step == 4) + *(uint32_t *)rxp = temp; + else + *rxp = temp; + in_bytes -= step; + rxp += step; } - toread--; - rx_lvl--; + toread -= step; + rx_lvl -= step; } /* * We have run out of input data, but haven't read enough @@ -293,7 +336,7 @@ static int spi_rx_tx(struct exynos_spi_slave *spi_slave, int todo, assert(!out_bytes); toread = out_bytes = in_bytes; txp = NULL; - spi_request_bytes(regs, toread); + spi_request_bytes(regs, toread, step); } if (spi_slave->skip_preamble && get_timer(start) > 100) { printf("SPI timeout: in_bytes=%d, out_bytes=%d, ", @@ -336,10 +379,14 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, if ((flags & SPI_XFER_BEGIN)) spi_cs_activate(slave);
- /* Exynos SPI limits each transfer to 65535 bytes */ + /* + * Exynos SPI limits each transfer to 65535 transfers. To keep + * things simple, allow a maximum of 65532 bytes. We could allow + * more in word mode, but the performance difference is small. + */ bytelen = bitlen / 8; for (upto = 0; !ret && upto < bytelen; upto += todo) { - todo = min(bytelen - upto, (1 << 16) - 1); + todo = min(bytelen - upto, (1 << 16) - 4); ret = spi_rx_tx(spi_slave, todo, &din, &dout, flags); }
On Mon, Mar 25, 2013 at 1:56 AM, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
We tested this today.
Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
Rajeshwari Shinde
