[PATCH v2 00/14] qemu: arm64: Add support for uefi capsule update on qemu arm platform
The capsule update feature is supported on a platform configuration booting in a non-secure mode, i.e with -machine virt,secure=off option set. This results in the platform booting u-boot directly without the presence of trusted firmware(tf-a). Steps that need to be followed for using this feature have been provided as part of the documentation.
Support has also been added for enabling the capsule authentication feature. Capsule authentication, as defined by the uefi specification is very much on similar lines to the logic used for variable authentication. As a result, most of the signature verification code already in use for variable authentication has been used for capsule authentication.
Storage of the public key certificate, needed for the signature verification process is in form of the efi signature list(esl) structure. This public key is stored on an overlay which is then merged with the platform's base fdt at runtime. The public key esl file can be embedded into the overlay dtb using the mkeficapsule utility that has been added as part of the capsule update support series by Takahiro Akashi. Steps needed for enabling capsule authentication have been provided as part of the documentation.
This patch series needs to be applied on top of the capsule update support patch series from Takahiro Akashi on the next branch.
Changes since V1: * Added support for embedding the public key cert in an overlay using the -O option * The earlier patch was adding a call to pci_init in board_init. Moved the virtio_init call to board_late_init * Change MTDPARTS_NOR[01] as config options instead of defining them in the qemu-arm.h config header. * Enable CONFIG_SYS_MTDPARTS_RUNTIME with CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT * Build set_dfu_alt_info and board_get_alt_info functions only if CONFIG_SET_DFU_ALT_INFO is defined * Enable CONFIG_SET_DFU_ALT_INFO with CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT * Detect the presence of the FMP Payload header at runtime instead of using a Kconfig option, as was suggested by Heinrich * Change the documentation to reflect the usage of overlays for embedding the public key certs at runtime * Fix the build for 'make htmldocs'
Sughosh Ganu (14): mkeficapsule: Add support for embedding public key in a dtb qemu: arm: Initialise virtio in board_late_init crypto: Fix the logic to calculate hash with authattributes set qemu: arm64: Add support for dynamic mtdparts for the platform qemu: arm64: Set dfu_alt_info variable for the platform fsp: Move and rename fsp_types.h file efi_loader: Add logic to parse EDKII specific fmp payload header dfu_mtd: Add provision to unlock mtd device efi_loader: Make the pkcs7 header parsing function an extern efi_loader: Re-factor code to build the signature store from efi signature list efi: capsule: Add support for uefi capsule authentication efi_loader: Enable uefi capsule authentication efidebug: capsule: Add a command to update capsule on disk qemu: arm64: Add documentation for capsule update
arch/x86/include/asm/fsp/fsp_support.h | 3 +- board/emulation/qemu-arm/Kconfig | 20 ++ board/emulation/qemu-arm/qemu-arm.c | 168 +++++++++++++ cmd/efidebug.c | 14 ++ configs/qemu_arm64_defconfig | 1 + doc/board/emulation/qemu-arm.rst | 188 ++++++++++++++ drivers/dfu/dfu_mtd.c | 20 +- include/efi_api.h | 18 ++ include/efi_loader.h | 12 + .../fsp/fsp_types.h => include/signatures.h | 6 +- lib/crypto/pkcs7_verify.c | 37 ++- lib/efi_loader/Kconfig | 19 ++ lib/efi_loader/efi_capsule.c | 122 +++++++++ lib/efi_loader/efi_firmware.c | 77 +++++- lib/efi_loader/efi_signature.c | 192 +++++++++++---- lib/efi_loader/efi_variable.c | 93 +------ tools/Makefile | 1 + tools/mkeficapsule.c | 233 +++++++++++++++++- 18 files changed, 1060 insertions(+), 164 deletions(-) rename arch/x86/include/asm/fsp/fsp_types.h => include/signatures.h (95%)
Add options for embedding the public key esl(efi signature list) file to the platform's dtb. The esl file is then retrieved and used for authenticating the capsule to be used for updating firmare components on the platform.
The esl file can now be embedded in the dtb by invoking the following command mkeficapsule -K <pub_key.esl> -D <dtb>
In the scenario where the esl file is to be embedded in an overlay, this can be done through the following command mkeficapsule -O -K <pub_key.esl> -D <dtb>
This will create a node named 'signature' in the dtb, and the esl file will be stored as 'capsule-key'
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org ---
tools/Makefile | 1 + tools/mkeficapsule.c | 233 ++++++++++++++++++++++++++++++++++++++++--- 2 files changed, 222 insertions(+), 12 deletions(-)
diff --git a/tools/Makefile b/tools/Makefile index 66d9376803..6d7b48fb57 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -218,6 +218,7 @@ hostprogs-$(CONFIG_MIPS) += mips-relocs hostprogs-$(CONFIG_ASN1_COMPILER) += asn1_compiler HOSTCFLAGS_asn1_compiler.o = -idirafter $(srctree)/include
+mkeficapsule-objs := mkeficapsule.o $(LIBFDT_OBJS) hostprogs-$(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) += mkeficapsule
# We build some files with extra pedantic flags to try to minimize things diff --git a/tools/mkeficapsule.c b/tools/mkeficapsule.c index 3f8bc7009b..270943fc90 100644 --- a/tools/mkeficapsule.c +++ b/tools/mkeficapsule.c @@ -4,16 +4,22 @@ * Author: AKASHI Takahiro */
+#include <errno.h> #include <getopt.h> #include <malloc.h> #include <stdbool.h> #include <stdio.h> #include <stdlib.h> #include <string.h> +#include <unistd.h> #include <linux/types.h> + +#include <sys/mman.h> #include <sys/stat.h> #include <sys/types.h>
+#include "fdt_host.h" + typedef __u8 u8; typedef __u16 u16; typedef __u32 u32; @@ -23,6 +29,9 @@ typedef __s32 s32;
#define aligned_u64 __aligned_u64
+#define SIGNATURE_NODENAME "signature" +#define OVERLAY_NODENAME "__overlay__" + #ifndef __packed #define __packed __attribute__((packed)) #endif @@ -43,6 +52,9 @@ static struct option options[] = { {"raw", required_argument, NULL, 'r'}, {"index", required_argument, NULL, 'i'}, {"instance", required_argument, NULL, 'I'}, + {"dtb", required_argument, NULL, 'D'}, + {"public key", required_argument, NULL, 'K'}, + {"overlay", no_argument, NULL, 'O'}, {"help", no_argument, NULL, 'h'}, {NULL, 0, NULL, 0}, }; @@ -51,14 +63,183 @@ static void print_usage(void) { printf("Usage: %s [options] <output file>\n" "Options:\n" - "\t--fit <fit image> new FIT image file\n" - "\t--raw <raw image> new raw image file\n" - "\t--index <index> update image index\n" - "\t--instance <instance> update hardware instance\n" - "\t--help print a help message\n", + + "\t--fit <fit image> new FIT image file\n" + "\t--raw <raw image> new raw image file\n" + "\t--index <index> update image index\n" + "\t--instance <instance> update hardware instance\n" + "\t--public-key <key file> public key esl file\n" + "\t--dtb <dtb file> dtb file\n" + "\t--overlay the dtb file is an overlay\n" + "\t--help print a help message\n", tool_name); }
+static int fdt_add_pub_key_data(void *sptr, void *dptr, size_t key_size, + bool overlay) +{ + int parent; + int ov_node; + int frag_node; + int ret = 0; + + if (overlay) { + /* + * The signature would be stored in the + * first fragment node of the overlay + */ + frag_node = fdt_first_subnode(dptr, 0); + if (frag_node == -FDT_ERR_NOTFOUND) { + fprintf(stderr, + "Couldn't find the fragment node: %s\n", + fdt_strerror(frag_node)); + goto done; + } + + ov_node = fdt_subnode_offset(dptr, frag_node, OVERLAY_NODENAME); + if (ov_node == -FDT_ERR_NOTFOUND) { + fprintf(stderr, + "Couldn't find the __overlay__ node: %s\n", + fdt_strerror(ov_node)); + goto done; + } + } else { + ov_node = 0; + } + + parent = fdt_subnode_offset(dptr, ov_node, SIGNATURE_NODENAME); + if (parent == -FDT_ERR_NOTFOUND) { + parent = fdt_add_subnode(dptr, ov_node, SIGNATURE_NODENAME); + if (parent < 0) { + ret = parent; + if (ret != -FDT_ERR_NOSPACE) { + fprintf(stderr, + "Couldn't create signature node: %s\n", + fdt_strerror(parent)); + } + } + } + if (ret) + goto done; + + /* Write the key to the FDT node */ + ret = fdt_setprop(dptr, parent, "capsule-key", + sptr, key_size); + +done: + if (ret) + ret = ret == -FDT_ERR_NOSPACE ? -ENOSPC : -EIO; + + return ret; +} + +static int add_public_key(const char *pkey_file, const char *dtb_file, + bool overlay) +{ + int ret; + int srcfd = 0; + int destfd = 0; + void *sptr = NULL; + void *dptr = NULL; + off_t src_size; + struct stat pub_key; + struct stat dtb; + + /* Find out the size of the public key */ + srcfd = open(pkey_file, O_RDONLY); + if (srcfd == -1) { + fprintf(stderr, "%s: Can't open %s: %s\n", + __func__, pkey_file, strerror(errno)); + goto err; + } + + ret = fstat(srcfd, &pub_key); + if (ret == -1) { + fprintf(stderr, "%s: Can't stat %s: %s\n", + __func__, pkey_file, strerror(errno)); + goto err; + } + + src_size = pub_key.st_size; + + /* mmap the public key esl file */ + sptr = mmap(0, src_size, PROT_READ, MAP_SHARED, srcfd, 0); + if ((sptr == MAP_FAILED) || (errno != 0)) { + fprintf(stderr, "%s: Failed to mmap %s:%s\n", + __func__, pkey_file, strerror(errno)); + goto err; + } + + /* Open the dest FDT */ + destfd = open(dtb_file, O_RDWR); + if (destfd == -1) { + fprintf(stderr, "%s: Can't open %s: %s\n", + __func__, dtb_file, strerror(errno)); + goto err; + } + + ret = fstat(destfd, &dtb); + if (ret == -1) { + fprintf(stderr, "%s: Can't stat %s: %s\n", + __func__, dtb_file, strerror(errno)); + goto err; + } + + dtb.st_size += src_size + 0x30; + if (ftruncate(destfd, dtb.st_size)) { + fprintf(stderr, "%s: Can't expand %s: %s\n", + __func__, dtb_file, strerror(errno)); + goto err;; + } + + errno = 0; + /* mmap the dtb file */ + dptr = mmap(0, dtb.st_size, PROT_READ | PROT_WRITE, MAP_SHARED, + destfd, 0); + if ((dptr == MAP_FAILED) || (errno != 0)) { + fprintf(stderr, "%s: Failed to mmap %s:%s\n", + __func__, dtb_file, strerror(errno)); + goto err; + } + + if (fdt_check_header(dptr)) { + fprintf(stderr, "%s: Invalid FDT header\n", __func__); + goto err; + } + + ret = fdt_open_into(dptr, dptr, dtb.st_size); + if (ret) { + fprintf(stderr, "%s: Cannot expand FDT: %s\n", + __func__, fdt_strerror(ret)); + goto err; + } + + /* Copy the esl file to the expanded FDT */ + ret = fdt_add_pub_key_data(sptr, dptr, src_size, overlay); + if (ret < 0) { + fprintf(stderr, "%s: Unable to add public key to the FDT\n", + __func__); + goto err; + } + + return 0; + +err: + if (sptr) + munmap(sptr, src_size); + + if (dptr) + munmap(dptr, dtb.st_size); + + if (srcfd >= 0) + close(srcfd); + + if (destfd >= 0) + close(destfd); + + return -1; +} + static int create_fwbin(char *path, char *bin, efi_guid_t *guid, unsigned long index, unsigned long instance) { @@ -173,16 +354,22 @@ err_1: int main(int argc, char **argv) { char *file; + char *pkey_file; + char *dtb_file; efi_guid_t *guid; unsigned long index, instance; int c, idx; + int ret; + bool overlay = false;
file = NULL; + pkey_file = NULL; + dtb_file = NULL; guid = NULL; index = 0; instance = 0; for (;;) { - c = getopt_long(argc, argv, "f:r:i:I:v:h", options, &idx); + c = getopt_long(argc, argv, "f:r:i:I:v:D:K:Oh", options, &idx); if (c == -1) break;
@@ -209,22 +396,44 @@ int main(int argc, char **argv) case 'I': instance = strtoul(optarg, NULL, 0); break; + case 'K': + if (pkey_file) { + printf("Public Key already specified\n"); + return -1; + } + pkey_file = optarg; + break; + case 'D': + if (dtb_file) { + printf("DTB file already specified\n"); + return -1; + } + dtb_file = optarg; + break; + case 'O': + overlay = true; + break; case 'h': print_usage(); return 0; } }
- /* need a output file */ - if (argc != optind + 1) { + /* need a fit image file or raw image file */ + if (!file && !pkey_file && !dtb_file) { + printf("%s: %d\n", __func__, __LINE__); print_usage(); return -1; }
- /* need a fit image file or raw image file */ - if (!file) { - print_usage(); - return -1; + if (pkey_file && dtb_file) { + ret = add_public_key(pkey_file, dtb_file, overlay); + if (ret == -1) { + printf("Adding public key to the dtb failed\n"); + return -1; + } else { + return 0; + } }
if (create_fwbin(argv[optind], file, guid, index, instance)
On the qemu arm platform, the virtio devices are initialised in board_init, which gets called before the initr_pci. With this, the virtio block devices on the pci bus are not initialised. Move the initialisation of virtio devices to board_late_init which gets called after the call to initr_pci.
Changes since V1: * The earlier patch was adding a call to pci_init in board_init. Moved the virtio_init call to board_late_init
board/emulation/qemu-arm/qemu-arm.c | 5 +++++ configs/qemu_arm64_defconfig | 1 + 2 files changed, 6 insertions(+)
diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index f18f2ed7da..aa68bef469 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -64,6 +64,11 @@ struct mm_region *mem_map = qemu_arm64_mem_map; #endif
int board_init(void) +{ + return 0; +} + +int board_late_init(void) { /* * Make sure virtio bus is enumerated so that peripherals diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index f6e586627a..5c855fa08c 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -14,6 +14,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_LATE_INIT=y CONFIG_PCI_INIT_R=y CONFIG_CMD_BOOTEFI_SELFTEST=y CONFIG_CMD_NVEDIT_EFI=y
With which commands can I see the difference before and after the patch?
Best regards
Heinrich
Changes since V1:
The 'rng' command now works without calling 'virtio scan' beforehand.
Best regards
Heinrich
Changes since V1:
- The earlier patch was adding a call to pci_init in board_init. Moved
Why don't you change board/emulation/qemu-riscv/qemu-riscv.c too? I can see no reason why you want to treat RISC-V differently.
What about x86 and MIPS? Why is virtio_init() not called on those architectures?
The C code change concerns both arm64 and arm. So on all ARM QEMU boards except qemu_arm64_defconfig you don't call virtio_init() at all once this patch is applied. This cannot be correct!
Probably you want to change arch/Kconfig instead:
diff --git a/arch/Kconfig b/arch/Kconfig index e8f9a9e1b7..1c66743ab6 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -24,6 +24,7 @@ config ARM bool "ARM architecture" select CREATE_ARCH_SYMLINK select HAVE_PRIVATE_LIBGCC if !ARM64 + select BOARD_LATE_INIT select SUPPORT_OF_CONTROL
Best regards
Heinrich
Without this patch, i am required to run a 'virtio scan' on the command line to access my efi system partition which is a block device on the pci bus. Do you see any issue with moving the virtio_init in board_late_init?
Best regards
Heinrich
Changes since V1:
Like I mentioned in my other mail, I am testing the capsule update feature only on the qemu arm64 platform. I can make this change, but I think this should be done by someone who is actually a user of the qemu risc-v platform.
I have no idea about this :-)
You are right. I should be adding this in the qemu arm platform flavour as well along with the arm64 variant. Will fix.
Will check this out. Thanks.
-sughosh
RFC 2315 Section 9.3 describes the message digesting process. The digest calculated depends on whether the authenticated attributes are present. In case of a scenario where the authenticated attributes are present, the message digest that gets signed and is part of the pkcs7 message is computed from the auth attributes rather than the contents field.
Check if the auth attributes are present, and if set, use the auth attributes to compute the hash that would be compared with the encrypted hash on the pkcs7 message.
Changes since V1: None
lib/crypto/pkcs7_verify.c | 37 ++++++++++++++++++++++++++----------- 1 file changed, 26 insertions(+), 11 deletions(-)
diff --git a/lib/crypto/pkcs7_verify.c b/lib/crypto/pkcs7_verify.c index 320ba49f79..58683ef614 100644 --- a/lib/crypto/pkcs7_verify.c +++ b/lib/crypto/pkcs7_verify.c @@ -50,8 +50,15 @@ static int pkcs7_digest(struct pkcs7_message *pkcs7, struct image_region regions[2]; int ret = 0;
- /* The digest was calculated already. */ - if (sig->digest) + /* + * [RFC2315 9.3] + * If the authenticated attributes are present, + * the message-digest is calculated on the + * attributes present in the + * authenticatedAttributes field and not just + * the contents field + */ + if (!sinfo->authattrs && sig->digest) return 0;
if (!sinfo->sig->hash_algo) @@ -63,17 +70,25 @@ static int pkcs7_digest(struct pkcs7_message *pkcs7, else return -ENOPKG;
- sig->digest = calloc(1, sig->digest_size); - if (!sig->digest) { - pr_warn("Sig %u: Out of memory\n", sinfo->index); - return -ENOMEM; - } + /* + * Calculate the hash only if the data is present. + * In case of authenticated variable and capsule, + * the hash has already been calculated on the + * efi_image_regions and populated + */ + if (pkcs7->data) { + sig->digest = calloc(1, sig->digest_size); + if (!sig->digest) { + pr_warn("Sig %u: Out of memory\n", sinfo->index); + return -ENOMEM; + }
- regions[0].data = pkcs7->data; - regions[0].size = pkcs7->data_len; + regions[0].data = pkcs7->data; + regions[0].size = pkcs7->data_len;
- /* Digest the message [RFC2315 9.3] */ - hash_calculate(sinfo->sig->hash_algo, regions, 1, sig->digest); + /* Digest the message [RFC2315 9.3] */ + hash_calculate(sinfo->sig->hash_algo, regions, 1, sig->digest); + }
/* However, if there are authenticated attributes, there must be a * message digest attribute amongst them which corresponds to the
Hello Takahiro,
as you provided the lib/crypto/pkcs7_verify.c file could you, please, review this patch.
Best regards
Heinrich
- if (sig->digest)
* [RFC2315 9.3]
return -ENOMEM;
- if (pkcs7->data) {
if (!sig->digest) {
return -ENOMEM;
- message digest attribute amongst them which corresponds to the
Add support for setting the default values for mtd partitions on the platform for the nor flash. This would be used for updating the firmware image using uefi capsule update with the dfu mtd backend driver.
Changes since V1: * Change MTDPARTS_NOR[01] as config options instead of defining them in the qemu-arm.h config header. * Enable CONFIG_SYS_MTDPARTS_RUNTIME with CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT
board/emulation/qemu-arm/Kconfig | 20 +++++++++ board/emulation/qemu-arm/qemu-arm.c | 70 +++++++++++++++++++++++++++++ lib/efi_loader/Kconfig | 1 + 3 files changed, 91 insertions(+)
diff --git a/board/emulation/qemu-arm/Kconfig b/board/emulation/qemu-arm/Kconfig index 02ae4d9884..ed0097963a 100644 --- a/board/emulation/qemu-arm/Kconfig +++ b/board/emulation/qemu-arm/Kconfig @@ -11,3 +11,23 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply VIRTIO_BLK
endif + +if TARGET_QEMU_ARM_64BIT && !TFABOOT + +config MTDPARTS_NOR0 + string "mtd boot partition for nor0" + default "64m(u-boot)" + depends on SYS_MTDPARTS_RUNTIME + help + This define the partition of nor0 used to build mtparts dynamically + for boot from nor0. + +config MTDPARTS_NOR1 + string "mtd u-boot env partition for nor1" + default "64m(u-boot-env)" + depends on SYS_MTDPARTS_RUNTIME + help + This define the partition of nor1 used to build mtparts dynamically + for the u-boot env stored on nor1. + +endif diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index aa68bef469..68f70cb9be 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -192,3 +192,73 @@ void flash_write32(u32 value, void *addr) { asm("str %" __W "1, %0" : "=m"(*(u32 *)addr) : "r"(value)); } + +#if defined(CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT) + +#include <mtd.h> + +static void board_get_mtdparts(const char *dev, const char *partition, + char *mtdids, char *mtdparts) +{ + /* mtdids: "<dev>=<dev>, ...." */ + if (mtdids[0] != '\0') + strcat(mtdids, ","); + strcat(mtdids, dev); + strcat(mtdids, "="); + strcat(mtdids, dev); + + /* mtdparts: "mtdparts=<dev>:<mtdparts_<dev>>;..." */ + if (mtdparts[0] != '\0') + strncat(mtdparts, ";", MTDPARTS_LEN); + else + strcat(mtdparts, "mtdparts="); + + strncat(mtdparts, dev, MTDPARTS_LEN); + strncat(mtdparts, ":", MTDPARTS_LEN); + strncat(mtdparts, partition, MTDPARTS_LEN); +} + +void board_mtdparts_default(const char **mtdids, const char **mtdparts) +{ + struct mtd_info *mtd; + struct udevice *dev; + const char *mtd_partition; + static char parts[3 * MTDPARTS_LEN + 1]; + static char ids[MTDIDS_LEN + 1]; + static bool mtd_initialized; + + if (mtd_initialized) { + *mtdids = ids; + *mtdparts = parts; + return; + } + + memset(parts, 0, sizeof(parts)); + memset(ids, 0, sizeof(ids)); + + /* probe all MTD devices */ + for (uclass_first_device(UCLASS_MTD, &dev); dev; + uclass_next_device(&dev)) { + debug("mtd device = %s\n", dev->name); + } + + mtd = get_mtd_device_nm("nor0"); + if (!IS_ERR_OR_NULL(mtd)) { + mtd_partition = CONFIG_MTDPARTS_NOR0; + board_get_mtdparts("nor0", mtd_partition, ids, parts); + put_mtd_device(mtd); + } + + mtd = get_mtd_device_nm("nor1"); + if (!IS_ERR_OR_NULL(mtd)) { + mtd_partition = CONFIG_MTDPARTS_NOR1; + board_get_mtdparts("nor1", mtd_partition, ids, parts); + put_mtd_device(mtd); + } + + mtd_initialized = true; + *mtdids = ids; + *mtdparts = parts; + debug("%s:mtdids=%s & mtdparts=%s\n", __func__, ids, parts); +} +#endif /* CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 8746e10032..2cb0a6e399 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -135,6 +135,7 @@ config EFI_CAPSULE_FIRMWARE_MANAGEMENT bool "Capsule: Firmware Management Protocol" depends on EFI_HAVE_CAPSULE_SUPPORT default y + select SYS_MTDPARTS_RUNTIME help Select this option if you want to enable capsule-based firmware update using Firmware Management Protocol.
The dfu framework uses the dfu_alt_info environment variable to get information that is needed for performing the firmware update. Set the dfu_alt_info for the platform to reflect the two mtd partitions created for the u-boot env and the firmware image.
Changes since V1: * Build set_dfu_alt_info and board_get_alt_info functions only if CONFIG_SET_DFU_ALT_INFO is defined * Enable CONFIG_SET_DFU_ALT_INFO with CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT
board/emulation/qemu-arm/qemu-arm.c | 57 +++++++++++++++++++++++++++++ lib/efi_loader/Kconfig | 1 + 2 files changed, 58 insertions(+)
diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index 68f70cb9be..a7be3c7c1c 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -195,8 +195,65 @@ void flash_write32(u32 value, void *addr)
+#include <memalign.h> #include <mtd.h>
+#define MTDPARTS_LEN 256 +#define MTDIDS_LEN 128 + +#define DFU_ALT_BUF_LEN SZ_1K + +#if defined(CONFIG_SET_DFU_ALT_INFO) +static void board_get_alt_info(struct mtd_info *mtd, char *buf) +{ + struct mtd_info *part; + bool first = true; + const char *name; + int len, partnum = 0; + + name = mtd->name; + len = strlen(buf); + + if (buf[0] != '\0') + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, "&"); + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "mtd %s=", name); + + list_for_each_entry(part, &mtd->partitions, node) { + partnum++; + if (!first) + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, ";"); + first = false; + + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s part %d", + part->name, partnum); + } +} + +void set_dfu_alt_info(char *interface, char *devstr) +{ + struct mtd_info *mtd; + + ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN); + + if (env_get("dfu_alt_info")) + return; + + memset(buf, 0, sizeof(buf)); + + /* probe all MTD devices */ + mtd_probe_devices(); + + mtd = get_mtd_device_nm("nor0"); + if (!IS_ERR_OR_NULL(mtd)) + board_get_alt_info(mtd, buf); + + env_set("dfu_alt_info", buf); + printf("dfu_alt_info set\n"); +} +#endif /* CONFIG_SET_DFU_ALT_INFO */ + static void board_get_mtdparts(const char *dev, const char *partition, char *mtdids, char *mtdparts) { diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 2cb0a6e399..bc47e7fe76 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -136,6 +136,7 @@ config EFI_CAPSULE_FIRMWARE_MANAGEMENT depends on EFI_HAVE_CAPSULE_SUPPORT default y select SYS_MTDPARTS_RUNTIME + select SET_DFU_ALT_INFO help Select this option if you want to enable capsule-based firmware update using Firmware Management Protocol.
The fsp_types.h header file contains macros for building signatures of different widths. These signature macros are architecture agnostic, and can be used in all places which use signatures in a data structure. Move and rename the fsp_types.h under the common include header.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org ---
This patch had been sent to the mailing list separately[1] and has been reviewed by Simon Glass.
[1] - https://lists.denx.de/pipermail/u-boot/2020-December/434849.html
arch/x86/include/asm/fsp/fsp_support.h | 3 ++- .../x86/include/asm/fsp/fsp_types.h => include/signatures.h | 6 +++--- 2 files changed, 5 insertions(+), 4 deletions(-) rename arch/x86/include/asm/fsp/fsp_types.h => include/signatures.h (95%)
diff --git a/arch/x86/include/asm/fsp/fsp_support.h b/arch/x86/include/asm/fsp/fsp_support.h index 29e511415c..3cd3e4fcf5 100644 --- a/arch/x86/include/asm/fsp/fsp_support.h +++ b/arch/x86/include/asm/fsp/fsp_support.h @@ -7,11 +7,12 @@ #ifndef __FSP_SUPPORT_H__ #define __FSP_SUPPORT_H__
+#include <signatures.h> + #include <asm/fsp/fsp_bootmode.h> #include <asm/fsp/fsp_fv.h> #include <asm/fsp/fsp_hob.h> #include <asm/fsp/fsp_infoheader.h> -#include <asm/fsp/fsp_types.h> #include <asm/fsp_arch.h> #include <asm/fsp/fsp_azalia.h>
diff --git a/arch/x86/include/asm/fsp/fsp_types.h b/include/signatures.h similarity index 95% rename from arch/x86/include/asm/fsp/fsp_types.h rename to include/signatures.h index 3d5b17ecf1..4042db1e00 100644 --- a/arch/x86/include/asm/fsp/fsp_types.h +++ b/include/signatures.h @@ -4,8 +4,8 @@ * Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com */
-#ifndef __FSP_TYPES_H__ -#define __FSP_TYPES_H__ +#ifndef __SIGNATURES_H__ +#define __SIGNATURES_H__
/** * Returns a 16-bit signature built from 2 ASCII characters. @@ -59,4 +59,4 @@ #define SIGNATURE_64(A, B, C, D, E, F, G, H) \ (SIGNATURE_32(A, B, C, D) | ((u64)(SIGNATURE_32(E, F, G, H)) << 32))
-#endif +#endif /* __SIGNATURES_H__ */
When building the capsule using scripts in edk2, a fmp header is added on top of the binary payload. Add logic to detect presence of the header. When present, the pointer to the image needs to be adjusted as per the size of the header to point to the actual binary payload.
Changes since V1: * Detect the presence of the FMP Payload header at runtime instead of using a Kconfig option, as was suggested by Heinrich
lib/efi_loader/efi_firmware.c | 41 +++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/lib/efi_loader/efi_firmware.c b/lib/efi_loader/efi_firmware.c index 72c560dbc2..5d2ecde2f1 100644 --- a/lib/efi_loader/efi_firmware.c +++ b/lib/efi_loader/efi_firmware.c @@ -11,8 +11,30 @@ #include <dfu.h> #include <efi_loader.h> #include <image.h> +#include <signatures.h> + #include <linux/list.h>
+#define FMP_PAYLOAD_HDR_SIGNATURE SIGNATURE_32('M', 'S', 'S', '1') + +/** + * struct fmp_payload_header - EDK2 header for the FMP payload + * + * This structure describes the header which is preprended to the + * FMP payload by the edk2 capsule generation scripts. + * + * @signature: Header signature used to identify the header + * @header_size: Size of the structure + * @fw_version: Firmware versions used + * @lowest_supported_version: Lowest supported version + */ +struct fmp_payload_header { + u32 signature; + u32 header_size; + u32 fw_version; + u32 lowest_supported_version; +}; + /* Place holder; not supported */ static efi_status_t EFIAPI efi_firmware_get_image_unsupported( @@ -379,12 +401,31 @@ efi_status_t EFIAPI efi_firmware_raw_set_image( efi_status_t (*progress)(efi_uintn_t completion), u16 **abort_reason) { + u32 fmp_hdr_signature; + struct fmp_payload_header *header; + EFI_ENTRY("%p %d %p %ld %p %p %p\n", this, image_index, image, image_size, vendor_code, progress, abort_reason);
if (!image) return EFI_EXIT(EFI_INVALID_PARAMETER);
+ fmp_hdr_signature = FMP_PAYLOAD_HDR_SIGNATURE; + header = (void *)image; + + if (!memcmp(&header->signature, &fmp_hdr_signature, + sizeof(fmp_hdr_signature))) { + /* + * When building the capsule with the scripts in + * edk2, a FMP header is inserted above the capsule + * payload. Compensate for this header to get the + * actual payload that is to be updated. + */ + image += header->header_size; + image_size -= header->header_size; + + } + if (dfu_write_by_alt(image_index - 1, (void *)image, image_size, NULL, NULL)) return EFI_EXIT(EFI_DEVICE_ERROR);
Prior to writing to an mtd device, mtd_erase is called. This call fails in case the sector being erased is locked. Call mtd_unlock to unlock the region which is to be erased and later written to. Lock the region once the write to the region has completed.
drivers/dfu/dfu_mtd.c | 20 +++++++++++++++++--- 1 file changed, 17 insertions(+), 3 deletions(-)
diff --git a/drivers/dfu/dfu_mtd.c b/drivers/dfu/dfu_mtd.c index 36cd4e945b..b34975dbb0 100644 --- a/drivers/dfu/dfu_mtd.c +++ b/drivers/dfu/dfu_mtd.c @@ -21,7 +21,7 @@ static bool mtd_is_aligned_with_block_size(struct mtd_info *mtd, u64 size) static int mtd_block_op(enum dfu_op op, struct dfu_entity *dfu, u64 offset, void *buf, long *len) { - u64 off, lim, remaining; + u64 off, lim, remaining, lock_ofs, lock_len; struct mtd_info *mtd = dfu->data.mtd.info; struct mtd_oob_ops io_op = {}; int ret = 0; @@ -34,7 +34,7 @@ static int mtd_block_op(enum dfu_op op, struct dfu_entity *dfu, return 0; }
- off = dfu->data.mtd.start + offset + dfu->bad_skip; + off = lock_ofs = dfu->data.mtd.start + offset + dfu->bad_skip; lim = dfu->data.mtd.start + dfu->data.mtd.size;
if (off >= lim) { @@ -56,12 +56,19 @@ static int mtd_block_op(enum dfu_op op, struct dfu_entity *dfu, if (op == DFU_OP_WRITE) { struct erase_info erase_op = {};
- remaining = round_up(*len, mtd->erasesize); + remaining = lock_len = round_up(*len, mtd->erasesize); erase_op.mtd = mtd; erase_op.addr = off; erase_op.len = mtd->erasesize; erase_op.scrub = 0;
+ debug("Unlocking the mtd device\n"); + ret = mtd_unlock(mtd, lock_ofs, lock_len); + if (ret && ret != -EOPNOTSUPP) { + printf("MTD device unlock failed\n"); + return 0; + } + while (remaining) { if (erase_op.addr + remaining > lim) { printf("Limit reached 0x%llx while erasing at offset 0x%llx\n", @@ -139,6 +146,13 @@ static int mtd_block_op(enum dfu_op op, struct dfu_entity *dfu, io_op.len = mtd->writesize; }
+ if (op == DFU_OP_WRITE) { + /* Write done, lock again */ + debug("Locking the mtd device\n"); + ret = mtd_lock(mtd, lock_ofs, lock_len); + if (ret && ret != -EOPNOTSUPP) + printf("MTD device lock failed\n"); + } return ret; }
The pkcs7 header parsing functionality is pretty generic, and can be used by other features like capsule authentication. Make the function an extern, also changing it's name to efi_parse_pkcs7_header
include/efi_loader.h | 4 ++ lib/efi_loader/efi_signature.c | 85 +++++++++++++++++++++++++++++++ lib/efi_loader/efi_variable.c | 93 ++-------------------------------- 3 files changed, 93 insertions(+), 89 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 365f3d01dc..8807fcd913 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -818,6 +818,10 @@ bool efi_secure_boot_enabled(void); bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, WIN_CERTIFICATE **auth, size_t *auth_len);
+struct pkcs7_message *efi_parse_pkcs7_header(const void *buf, + size_t buflen, + u8 **tmpbuf); + /* runtime implementation of memcpy() */ void efi_memcpy_runtime(void *dest, const void *src, size_t n);
diff --git a/lib/efi_loader/efi_signature.c b/lib/efi_loader/efi_signature.c index 79dee27421..9ab071b611 100644 --- a/lib/efi_loader/efi_signature.c +++ b/lib/efi_loader/efi_signature.c @@ -27,6 +27,91 @@ const efi_guid_t efi_guid_cert_x509_sha256 = EFI_CERT_X509_SHA256_GUID; const efi_guid_t efi_guid_cert_type_pkcs7 = EFI_CERT_TYPE_PKCS7_GUID;
#ifdef CONFIG_EFI_SECURE_BOOT +static u8 pkcs7_hdr[] = { + /* SEQUENCE */ + 0x30, 0x82, 0x05, 0xc7, + /* OID: pkcs7-signedData */ + 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, + /* Context Structured? */ + 0xa0, 0x82, 0x05, 0xb8, +}; + +/** + * efi_parse_pkcs7_header - parse a signature in payload + * @buf: Pointer to payload's value + * @buflen: Length of @buf + * @tmpbuf: Pointer to temporary buffer + * + * Parse a signature embedded in payload's value and instantiate + * a pkcs7_message structure. Since pkcs7_parse_message() accepts only + * pkcs7's signedData, some header needed be prepended for correctly + * parsing authentication data + * A temporary buffer will be allocated if needed, and it should be + * kept valid during the authentication because some data in the buffer + * will be referenced by efi_signature_verify(). + * + * Return: Pointer to pkcs7_message structure on success, NULL on error + */ +struct pkcs7_message *efi_parse_pkcs7_header(const void *buf, + size_t buflen, + u8 **tmpbuf) +{ + u8 *ebuf; + size_t ebuflen, len; + struct pkcs7_message *msg; + + /* + * This is the best assumption to check if the binary is + * already in a form of pkcs7's signedData. + */ + if (buflen > sizeof(pkcs7_hdr) && + !memcmp(&((u8 *)buf)[4], &pkcs7_hdr[4], 11)) { + msg = pkcs7_parse_message(buf, buflen); + if (IS_ERR(msg)) + return NULL; + return msg; + } + + /* + * Otherwise, we should add a dummy prefix sequence for pkcs7 + * message parser to be able to process. + * NOTE: EDK2 also uses similar hack in WrapPkcs7Data() + * in CryptoPkg/Library/BaseCryptLib/Pk/CryptPkcs7VerifyCommon.c + * TODO: + * The header should be composed in a more refined manner. + */ + EFI_PRINT("Makeshift prefix added to authentication data\n"); + ebuflen = sizeof(pkcs7_hdr) + buflen; + if (ebuflen <= 0x7f) { + EFI_PRINT("Data is too short\n"); + return NULL; + } + + ebuf = malloc(ebuflen); + if (!ebuf) { + EFI_PRINT("Out of memory\n"); + return NULL; + } + + memcpy(ebuf, pkcs7_hdr, sizeof(pkcs7_hdr)); + memcpy(ebuf + sizeof(pkcs7_hdr), buf, buflen); + len = ebuflen - 4; + ebuf[2] = (len >> 8) & 0xff; + ebuf[3] = len & 0xff; + len = ebuflen - 0x13; + ebuf[0x11] = (len >> 8) & 0xff; + ebuf[0x12] = len & 0xff; + + msg = pkcs7_parse_message(ebuf, ebuflen); + + if (IS_ERR(msg)) { + free(ebuf); + return NULL; + } + + *tmpbuf = ebuf; + return msg; +}
/** * efi_hash_regions - calculate a hash value diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index 0c689cfb47..ba0874e9e7 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -24,91 +24,6 @@ #include <asm/sections.h>
#ifdef CONFIG_EFI_SECURE_BOOT -static u8 pkcs7_hdr[] = { - /* SEQUENCE */ - 0x30, 0x82, 0x05, 0xc7, - /* OID: pkcs7-signedData */ - 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, - /* Context Structured? */ - 0xa0, 0x82, 0x05, 0xb8, -}; - -/** - * efi_variable_parse_signature - parse a signature in variable - * @buf: Pointer to variable's value - * @buflen: Length of @buf - * @tmpbuf: Pointer to temporary buffer - * - * Parse a signature embedded in variable's value and instantiate - * a pkcs7_message structure. Since pkcs7_parse_message() accepts only - * pkcs7's signedData, some header needed be prepended for correctly - * parsing authentication data, particularly for variable's. - * A temporary buffer will be allocated if needed, and it should be - * kept valid during the authentication because some data in the buffer - * will be referenced by efi_signature_verify(). - * - * Return: Pointer to pkcs7_message structure on success, NULL on error - */ -static struct pkcs7_message *efi_variable_parse_signature(const void *buf, - size_t buflen, - u8 **tmpbuf) -{ - u8 *ebuf; - size_t ebuflen, len; - struct pkcs7_message *msg; - - /* - * This is the best assumption to check if the binary is - * already in a form of pkcs7's signedData. - */ - if (buflen > sizeof(pkcs7_hdr) && - !memcmp(&((u8 *)buf)[4], &pkcs7_hdr[4], 11)) { - msg = pkcs7_parse_message(buf, buflen); - if (IS_ERR(msg)) - return NULL; - return msg; - } - - /* - * Otherwise, we should add a dummy prefix sequence for pkcs7 - * message parser to be able to process. - * NOTE: EDK2 also uses similar hack in WrapPkcs7Data() - * in CryptoPkg/Library/BaseCryptLib/Pk/CryptPkcs7VerifyCommon.c - * TODO: - * The header should be composed in a more refined manner. - */ - EFI_PRINT("Makeshift prefix added to authentication data\n"); - ebuflen = sizeof(pkcs7_hdr) + buflen; - if (ebuflen <= 0x7f) { - EFI_PRINT("Data is too short\n"); - return NULL; - } - - ebuf = malloc(ebuflen); - if (!ebuf) { - EFI_PRINT("Out of memory\n"); - return NULL; - } - - memcpy(ebuf, pkcs7_hdr, sizeof(pkcs7_hdr)); - memcpy(ebuf + sizeof(pkcs7_hdr), buf, buflen); - len = ebuflen - 4; - ebuf[2] = (len >> 8) & 0xff; - ebuf[3] = len & 0xff; - len = ebuflen - 0x13; - ebuf[0x11] = (len >> 8) & 0xff; - ebuf[0x12] = len & 0xff; - - msg = pkcs7_parse_message(ebuf, ebuflen); - - if (IS_ERR(msg)) { - free(ebuf); - return NULL; - } - - *tmpbuf = ebuf; - return msg; -}
/** * efi_variable_authenticate - authenticate a variable @@ -215,10 +130,10 @@ static efi_status_t efi_variable_authenticate(u16 *variable, goto err;
/* ebuf should be kept valid during the authentication */ - var_sig = efi_variable_parse_signature(auth->auth_info.cert_data, - auth->auth_info.hdr.dwLength - - sizeof(auth->auth_info), - &ebuf); + var_sig = efi_parse_pkcs7_header(auth->auth_info.cert_data, + auth->auth_info.hdr.dwLength + - sizeof(auth->auth_info), + &ebuf); if (!var_sig) { EFI_PRINT("Parsing variable's signature failed\n"); goto err;
The efi_sigstore_parse_sigdb function reads the uefi authenticated variable, stored in the signature database format and builds the signature store structure. Factor out the code for building the signature store. This can then be used by the capsule authentication routine to build the signature store even when the signature database is not stored as an uefi authenticated variable
include/efi_loader.h | 2 + lib/efi_loader/efi_signature.c | 103 +++++++++++++++++++-------------- 2 files changed, 63 insertions(+), 42 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 8807fcd913..73c3c4b85a 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -811,6 +811,8 @@ efi_status_t efi_image_region_add(struct efi_image_regions *regs, int nocheck);
void efi_sigstore_free(struct efi_signature_store *sigstore); +struct efi_signature_store *efi_build_signature_store(void *sig_list, + efi_uintn_t size); struct efi_signature_store *efi_sigstore_parse_sigdb(u16 *name);
bool efi_secure_boot_enabled(void); diff --git a/lib/efi_loader/efi_signature.c b/lib/efi_loader/efi_signature.c index 9ab071b611..87525bdc80 100644 --- a/lib/efi_loader/efi_signature.c +++ b/lib/efi_loader/efi_signature.c @@ -736,6 +736,63 @@ err: return NULL; }
+/** + * efi_sigstore_parse_sigdb - parse the signature list and populate + * the signature store + * + * @sig_list: Pointer to the signature list + * @size: Size of the signature list + * + * Parse the efi signature list and instantiate a signature store + * structure. + * + * Return: Pointer to signature store on success, NULL on error + */ +struct efi_signature_store *efi_build_signature_store(void *sig_list, + efi_uintn_t size) +{ + struct efi_signature_list *esl; + struct efi_signature_store *sigstore = NULL, *siglist; + + esl = sig_list; + while (size > 0) { + /* List must exist if there is remaining data. */ + if (size < sizeof(*esl)) { + EFI_PRINT("Signature list in wrong format\n"); + goto err; + } + + if (size < esl->signature_list_size) { + EFI_PRINT("Signature list in wrong format\n"); + goto err; + } + + /* Parse a single siglist. */ + siglist = efi_sigstore_parse_siglist(esl); + if (!siglist) { + EFI_PRINT("Parsing of signature list of failed\n"); + goto err; + } + + /* Append siglist */ + siglist->next = sigstore; + sigstore = siglist; + + /* Next */ + size -= esl->signature_list_size; + esl = (void *)esl + esl->signature_list_size; + } + free(sig_list); + + return sigstore; + +err: + efi_sigstore_free(sigstore); + free(sig_list); + + return NULL; +} + /** * efi_sigstore_parse_sigdb - parse a signature database variable * @name: Variable's name @@ -747,8 +804,7 @@ err: */ struct efi_signature_store *efi_sigstore_parse_sigdb(u16 *name) { - struct efi_signature_store *sigstore = NULL, *siglist; - struct efi_signature_list *esl; + struct efi_signature_store *sigstore = NULL; const efi_guid_t *vendor; void *db; efi_uintn_t db_size; @@ -784,47 +840,10 @@ struct efi_signature_store *efi_sigstore_parse_sigdb(u16 *name) ret = EFI_CALL(efi_get_variable(name, vendor, NULL, &db_size, db)); if (ret != EFI_SUCCESS) { EFI_PRINT("Getting variable, %ls, failed\n", name); - goto err; - } - - /* Parse siglist list */ - esl = db; - while (db_size > 0) { - /* List must exist if there is remaining data. */ - if (db_size < sizeof(*esl)) { - EFI_PRINT("variable, %ls, in wrong format\n", name); - goto err; - } - - if (db_size < esl->signature_list_size) { - EFI_PRINT("variable, %ls, in wrong format\n", name); - goto err; - } - - /* Parse a single siglist. */ - siglist = efi_sigstore_parse_siglist(esl); - if (!siglist) { - EFI_PRINT("Parsing signature list of %ls failed\n", - name); - goto err; - } - - /* Append siglist */ - siglist->next = sigstore; - sigstore = siglist; - - /* Next */ - db_size -= esl->signature_list_size; - esl = (void *)esl + esl->signature_list_size; + free(db); + return NULL; } - free(db); - - return sigstore;
-err: - efi_sigstore_free(sigstore); - free(db); - - return NULL; + return efi_build_signature_store(db, db_size); } #endif /* CONFIG_EFI_SECURE_BOOT */
Add support for authenticating uefi capsules. Most of the signature verification functionality is shared with the uefi secure boot feature.
The root certificate containing the public key used for the signature verification is stored as part of the device tree blob. The root certificate is stored as an efi signature list(esl) file -- this file contains the x509 certificate which is the root certificate.
board/emulation/qemu-arm/qemu-arm.c | 36 ++++++++ include/efi_api.h | 18 ++++ include/efi_loader.h | 6 ++ lib/efi_loader/Kconfig | 17 ++++ lib/efi_loader/efi_capsule.c | 122 ++++++++++++++++++++++++++++ lib/efi_loader/efi_signature.c | 4 +- 6 files changed, 201 insertions(+), 2 deletions(-)
diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index a7be3c7c1c..c10bd0401f 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -203,6 +203,42 @@ void flash_write32(u32 value, void *addr)
+int efi_get_public_key_data(void **pkey, efi_uintn_t *pkey_len) +{ + const void *fdt_blob = gd->fdt_blob; + const void *blob; + const char *cnode_name = "capsule-key"; + const char *snode_name = "signature"; + int sig_node; + int len; + + sig_node = fdt_subnode_offset(fdt_blob, 0, snode_name); + if (sig_node < 0) { + EFI_PRINT("Unable to get signature node offset\n"); + return -FDT_ERR_NOTFOUND; + } + + blob = fdt_getprop(fdt_blob, sig_node, cnode_name, &len); + + if (!blob || len < 0) { + EFI_PRINT("Unable to get capsule-key value\n"); + *pkey = NULL; + *pkey_len = 0; + return -FDT_ERR_NOTFOUND; + } + + *pkey = (void *)blob; + *pkey_len = len; + + return 0; +} + +bool efi_capsule_auth_enabled(void) +{ + return env_get("capsule_authentication_enabled") != NULL ? + true : false; +} + #if defined(CONFIG_SET_DFU_ALT_INFO) static void board_get_alt_info(struct mtd_info *mtd, char *buf) { diff --git a/include/efi_api.h b/include/efi_api.h index e82d4ca9ff..ecb43a0607 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -1812,6 +1812,24 @@ struct efi_variable_authentication_2 { struct win_certificate_uefi_guid auth_info; } __attribute__((__packed__));
+/** + * efi_firmware_image_authentication - Capsule authentication method + * descriptor + * + * This structure describes an authentication information for + * a capsule with IMAGE_ATTRIBUTE_AUTHENTICATION_REQUIRED set + * and should be included as part of the capsule. + * Only EFI_CERT_TYPE_PKCS7_GUID is accepted. + * + * @monotonic_count: Count to prevent replay + * @auth_info: Authentication info + */ +struct efi_firmware_image_authentication { + uint64_t monotonic_count; + struct win_certificate_uefi_guid auth_info; +} __attribute__((__packed__)); + + /** * efi_signature_data - A format of signature * diff --git a/include/efi_loader.h b/include/efi_loader.h index 73c3c4b85a..fb3e974aa1 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -817,6 +817,8 @@ struct efi_signature_store *efi_sigstore_parse_sigdb(u16 *name);
+bool efi_capsule_auth_enabled(void); + bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, WIN_CERTIFICATE **auth, size_t *auth_len);
@@ -844,6 +846,10 @@ efi_status_t EFIAPI efi_query_capsule_caps( u64 *maximum_capsule_size, u32 *reset_type);
+efi_status_t efi_capsule_authenticate(const void *capsule, + efi_uintn_t capsule_size, + void **image, efi_uintn_t *image_size); + #define EFI_CAPSULE_DIR L"\EFI\UpdateCapsule\"
/* Hook at initialization */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index bc47e7fe76..3e8533c430 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -141,6 +141,23 @@ config EFI_CAPSULE_FIRMWARE_MANAGEMENT Select this option if you want to enable capsule-based firmware update using Firmware Management Protocol.
+config EFI_CAPSULE_AUTHENTICATE + bool "Update Capsule authentication" + depends on EFI_CAPSULE_FIRMWARE + depends on EFI_CAPSULE_ON_DISK + depends on EFI_CAPSULE_FIRMWARE_MANAGEMENT + select SHA256 + select RSA + select RSA_VERIFY + select RSA_VERIFY_WITH_PKEY + select X509_CERTIFICATE_PARSER + select PKCS7_MESSAGE_PARSER + select PKCS7_VERIFY + default n + help + Select this option if you want to enable capsule + authentication + config EFI_CAPSULE_FIRMWARE_FIT bool "FMP driver for FIT image" depends on EFI_CAPSULE_FIRMWARE_MANAGEMENT diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index ea22ee7968..d9a7bbd509 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -14,6 +14,10 @@ #include <mapmem.h> #include <sort.h>
+#include <crypto/pkcs7.h> +#include <crypto/pkcs7_parser.h> +#include <linux/err.h> + const efi_guid_t efi_guid_capsule_report = EFI_CAPSULE_REPORT_GUID; static const efi_guid_t efi_guid_firmware_management_capsule_id = EFI_FIRMWARE_MANAGEMENT_CAPSULE_ID_GUID; @@ -191,6 +195,124 @@ skip: return NULL; }
+#if defined(CONFIG_EFI_CAPSULE_AUTHENTICATE) + +const efi_guid_t efi_guid_capsule_root_cert_guid = + EFI_FIRMWARE_MANAGEMENT_CAPSULE_ID_GUID; + +__weak int efi_get_public_key_data(void **pkey, efi_uintn_t *pkey_len) +{ + /* The platform is supposed to provide + * a method for getting the public key + * stored in the form of efi signature + * list + */ + return 0; +} + +efi_status_t efi_capsule_authenticate(const void *capsule, efi_uintn_t capsule_size, + void **image, efi_uintn_t *image_size) +{ + u8 *buf; + int ret; + void *fdt_pkey, *pkey; + efi_uintn_t pkey_len; + uint64_t monotonic_count; + struct efi_signature_store *truststore; + struct pkcs7_message *capsule_sig; + struct efi_image_regions *regs; + struct efi_firmware_image_authentication *auth_hdr; + efi_status_t status; + + status = EFI_SECURITY_VIOLATION; + capsule_sig = NULL; + truststore = NULL; + regs = NULL; + + /* Sanity checks */ + if (capsule == NULL || capsule_size == 0) + goto out; + + auth_hdr = (struct efi_firmware_image_authentication *)capsule; + if (capsule_size < sizeof(*auth_hdr)) + goto out; + + if (auth_hdr->auth_info.hdr.dwLength <= + offsetof(struct win_certificate_uefi_guid, cert_data)) + goto out; + + if (guidcmp(&auth_hdr->auth_info.cert_type, &efi_guid_cert_type_pkcs7)) + goto out; + + *image = (uint8_t *)capsule + sizeof(auth_hdr->monotonic_count) + + auth_hdr->auth_info.hdr.dwLength; + *image_size = capsule_size - auth_hdr->auth_info.hdr.dwLength - + sizeof(auth_hdr->monotonic_count); + memcpy(&monotonic_count, &auth_hdr->monotonic_count, + sizeof(monotonic_count)); + + /* data to be digested */ + regs = calloc(sizeof(*regs) + sizeof(struct image_region) * 2, 1); + if (!regs) + goto out; + + regs->max = 2; + efi_image_region_add(regs, (uint8_t *)*image, + (uint8_t *)*image + *image_size, 1); + + efi_image_region_add(regs, (uint8_t *)&monotonic_count, + (uint8_t *)&monotonic_count + sizeof(monotonic_count), + 1); + + capsule_sig = efi_parse_pkcs7_header(auth_hdr->auth_info.cert_data, + auth_hdr->auth_info.hdr.dwLength + - sizeof(auth_hdr->auth_info), + &buf); + if (IS_ERR(capsule_sig)) { + debug("Parsing variable's pkcs7 header failed\n"); + capsule_sig = NULL; + goto out; + } + + ret = efi_get_public_key_data(&fdt_pkey, &pkey_len); + if (ret < 0) + goto out; + + pkey = malloc(pkey_len); + if (!pkey) + goto out; + + memcpy(pkey, fdt_pkey, pkey_len); + truststore = efi_build_signature_store(pkey, pkey_len); + if (!truststore) + goto out; + + /* verify signature */ + if (efi_signature_verify(regs, capsule_sig, truststore, NULL)) { + debug("Verified\n"); + } else { + debug("Verifying variable's signature failed\n"); + goto out; + } + + status = EFI_SUCCESS; + +out: + efi_sigstore_free(truststore); + pkcs7_free_message(capsule_sig); + free(regs); + + return status; +} +#else +efi_status_t efi_capsule_authenticate(const void *capsule, efi_uintn_t capsule_size, + void **image, efi_uintn_t *image_size) +{ + return EFI_UNSUPPORTED; +} +#endif /* CONFIG_EFI_CAPSULE_AUTHENTICATE */ + + /** * efi_capsule_update_firmware - update firmware from capsule * @capsule_data: Capsule diff --git a/lib/efi_loader/efi_signature.c b/lib/efi_loader/efi_signature.c index 87525bdc80..c7ec275414 100644 --- a/lib/efi_loader/efi_signature.c +++ b/lib/efi_loader/efi_signature.c @@ -26,7 +26,7 @@ const efi_guid_t efi_guid_cert_x509 = EFI_CERT_X509_GUID; const efi_guid_t efi_guid_cert_x509_sha256 = EFI_CERT_X509_SHA256_GUID; const efi_guid_t efi_guid_cert_type_pkcs7 = EFI_CERT_TYPE_PKCS7_GUID;
-#ifdef CONFIG_EFI_SECURE_BOOT +#if defined(CONFIG_EFI_SECURE_BOOT) || defined(CONFIG_EFI_CAPSULE_AUTHENTICATE) static u8 pkcs7_hdr[] = { /* SEQUENCE */ 0x30, 0x82, 0x05, 0xc7, @@ -846,4 +846,4 @@ struct efi_signature_store *efi_sigstore_parse_sigdb(u16 *name)
return efi_build_signature_store(db, db_size); } -#endif /* CONFIG_EFI_SECURE_BOOT */ +#endif /* CONFIG_EFI_SECURE_BOOT || CONFIG_EFI_CAPSULE_AUTHENTICATE */
Add support for enabling uefi capsule authentication. This feature is enabled by setting the environment variable "capsule_authentication_enabled".
The following configs are needed for enabling uefi capsule update and capsule authentication features on the platform.
CONFIG_EFI_HAVE_CAPSULE_SUPPORT=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT=y CONFIG_EFI_CAPSULE_FIRMWARE=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_EFI_CAPSULE_AUTHENTICATE=y
lib/efi_loader/efi_firmware.c | 36 ++++++++++++++++++++++++++++++++++- 1 file changed, 35 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_firmware.c b/lib/efi_loader/efi_firmware.c index 5d2ecde2f1..5e401bbca2 100644 --- a/lib/efi_loader/efi_firmware.c +++ b/lib/efi_loader/efi_firmware.c @@ -184,9 +184,16 @@ static efi_status_t efi_get_dfu_info( image_info[i].version_name = NULL; /* not supported */ image_info[i].size = 0; image_info[i].attributes_supported = - IMAGE_ATTRIBUTE_IMAGE_UPDATABLE; + IMAGE_ATTRIBUTE_IMAGE_UPDATABLE | + IMAGE_ATTRIBUTE_AUTHENTICATION_REQUIRED; image_info[i].attributes_setting = IMAGE_ATTRIBUTE_IMAGE_UPDATABLE; + + /* Check if the capsule authentication is enabled */ + if (env_get("capsule_authentication_enabled")) + image_info[0].attributes_setting |= + IMAGE_ATTRIBUTE_AUTHENTICATION_REQUIRED; + image_info[i].lowest_supported_image_version = 0; image_info[i].last_attempt_version = 0; image_info[i].last_attempt_status = LAST_ATTEMPT_STATUS_SUCCESS; @@ -403,6 +410,9 @@ efi_status_t EFIAPI efi_firmware_raw_set_image( { u32 fmp_hdr_signature; struct fmp_payload_header *header; + void *capsule_payload; + efi_status_t status; + efi_uintn_t capsule_payload_size;
EFI_ENTRY("%p %d %p %ld %p %p %p\n", this, image_index, image, image_size, vendor_code, progress, abort_reason); @@ -410,6 +420,30 @@ efi_status_t EFIAPI efi_firmware_raw_set_image( if (!image) return EFI_EXIT(EFI_INVALID_PARAMETER);
+ /* Authenticate the capsule if authentication enabled */ + if (IS_ENABLED(CONFIG_EFI_CAPSULE_AUTHENTICATE) && + env_get("capsule_authentication_enabled")) { + capsule_payload = NULL; + capsule_payload_size = 0; + status = efi_capsule_authenticate(image, image_size, + &capsule_payload, + &capsule_payload_size); + + if (status == EFI_SECURITY_VIOLATION) { + printf("Capsule authentication check failed. Aborting update\n"); + return EFI_EXIT(status); + } else if (status != EFI_SUCCESS) { + return EFI_EXIT(status); + } + + debug("Capsule authentication successfull\n"); + image = capsule_payload; + image_size = capsule_payload_size; + } else { + debug("Capsule authentication disabled. "); + debug("Updating capsule without authenticating.\n"); + } + fmp_hdr_signature = FMP_PAYLOAD_HDR_SIGNATURE; header = (void *)image;
Add a efidebug subcommand to initiate a firmware update using the efi firmware management protocol(fmp) set_image routine.
The firmware update can be initiated through
'efidebug capsule disk-update'
This would locate the efi capsule file on the efi system partition, and call the platform's set_image fmp routine to initiate the firmware update.
cmd/efidebug.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index fa9d7fe757..5fb7b1e3c6 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -79,6 +79,16 @@ static int do_efi_capsule_update(struct cmd_tbl *cmdtp, int flag, return CMD_RET_SUCCESS; }
+static int do_efi_capsule_on_disk_update(struct cmd_tbl *cmdtp, int flag, + int argc, char * const argv[]) +{ + efi_status_t ret; + + ret = efi_launch_capsules(); + + return ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE; +} + /** * do_efi_capsule_show() - show capsule information * @@ -207,6 +217,8 @@ static struct cmd_tbl cmd_efidebug_capsule_sub[] = { "", ""), U_BOOT_CMD_MKENT(show, CONFIG_SYS_MAXARGS, 1, do_efi_capsule_show, "", ""), + U_BOOT_CMD_MKENT(disk-update, 0, 0, do_efi_capsule_on_disk_update, + "", ""), U_BOOT_CMD_MKENT(result, CONFIG_SYS_MAXARGS, 1, do_efi_capsule_res, "", ""), }; @@ -1544,6 +1556,8 @@ static char efidebug_help_text[] = #ifdef CONFIG_EFI_HAVE_CAPSULE_SUPPORT "efidebug capsule update [-v] <capsule address>\n" " - process a capsule\n" + "efidebug capsule disk-update\n" + " - update a capsule from disk\n" "efidebug capsule show <capsule address>\n" " - show capsule information\n" "efidebug capsule result [<capsule result var>]\n"
Add documentation highlighting the steps for using the uefi capsule update feature for updating the u-boot firmware image.
Changes since V1: * Change the documentation to reflect the usage of overlays for embedding the public key certs at runtime * Fix the build for 'make htmldocs'
doc/board/emulation/qemu-arm.rst | 188 +++++++++++++++++++++++++++++++ 1 file changed, 188 insertions(+)
diff --git a/doc/board/emulation/qemu-arm.rst b/doc/board/emulation/qemu-arm.rst index 8d7fda10f1..11d91811b3 100644 --- a/doc/board/emulation/qemu-arm.rst +++ b/doc/board/emulation/qemu-arm.rst @@ -90,3 +90,191 @@ The debug UART on the ARM virt board uses these settings:: CONFIG_DEBUG_UART_PL010=y CONFIG_DEBUG_UART_BASE=0x9000000 CONFIG_DEBUG_UART_CLOCK=0 + +Enabling Uefi Capsule Update feature +------------------------------------ + +Support has been added for the uefi capsule update feature which +enables updating the u-boot image using the uefi firmware management +protocol (fmp). The capsules are not passed to the firmware through +the UpdateCapsule runtime service. Instead, capsule-on-disk +functionality is used for fetching the capsule from the EFI System +Partition (ESP). + +Currently, support has been added for updating the u-boot binary as a +raw image when the platform is booted in non-secure mode, i.e with +CONFIG_TFABOOT disabled. For this configuration, the qemu platform +needs to be booted with 'secure=off'. The u-boot binary placed on the +first bank of the Nor Flash at offset 0x0. The u-boot environment is +placed on the second Nor Flash bank at offset 0x4000000. + +The capsule update feature is enabled with the following configs:: + + CONFIG_MTD=y + CONFIG_FLASH_CFI_MTD=y + CONFIG_CMD_MTDPARTS=y + CONFIG_CMD_DFU=y + CONFIG_DFU_MTD=y + CONFIG_PCI_INIT_R=y + CONFIG_EFI_CAPSULE_ON_DISK=y + CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT=y + CONFIG_EFI_CAPSULE_FIRMWARE=y + CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y + CONFIG_EFI_CAPSULE_FMP_HEADER=y + +In addition, the following config needs to be disabled:: + + CONFIG_TFABOOT + +The capsule file can be generated by using the GenerateCapsule.py +script in edk2:: + + $ ./BaseTools/BinWrappers/PosixLike/GenerateCapsule -e -o \ + <capsule_file_name> --fw-version <val> --lsv <val> --guid \ + e2bb9c06-70e9-4b14-97a3-5a7913176e3f --verbose --update-image-index \ + <val> --verbose <u-boot.bin> + +As per the uefi specification, the capsule file needs to be placed on +the EFI System Partition, under the EFI/UpdateCapsule/ directory. The +EFI System Partition can be a virtio-blk-device. + +Before initiating the firmware update, the efi variables BootNext, +BootXXXX and OsIndications need to be set. The BootXXXX variable needs +to be pointing to the EFI System Partition which contains the capsule +file. The BootNext, BootXXXX and OsIndications variables can be set +using the following commands:: + + => efidebug boot add 0 Boot0000 virtio 0:1 <capsule_file_name> + => efidebug boot next 0 + => setenv -e -nv -bs -rt -v OsIndications =0x04 + => saveenv + +Finally, the capsule update can be initiated with the following +command:: + + => efidebug capsule disk-update + +The updated u-boot image will be booted on subsequent boot. + +Enabling Capsule Authentication +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +The uefi specification defines a way of authenticating the capsule to +be updated by verifying the capsule signature. The capsule signature +is computed and prepended to the capsule payload at the time of +capsule generation. This signature is then verified by using the +public key stored as part of the X509 certificate. This certificate is +in the form of an efi signature list (esl) file, which is embedded as +part of the platform's device tree blob using the mkeficapsule +utility. + +On the qemu virt platforms, the device-tree is generated on the fly +based on the devices configured. This device tree is then passed on to +the various software components booting on the platform, including +u-boot. Therefore, on the qemu virt platform, the signatute is +embedded on an overlay. This overlay is then applied at runtime to the +base platform device-tree. Steps needed for embedding the esl file in +the overlay are highlighted below. + +The capsule authentication feature can be enabled through the +following config, in addition to the configs listed above for capsule +update:: + + CONFIG_EFI_CAPSULE_AUTHENTICATE=y + +The public and private keys used for the signing process are generated +and used by the steps highlighted below:: + + 1. Install utility commands on your host + * openssl + * efitools + + 2. Create signing keys and certificate files on your host + + $ openssl req -x509 -sha256 -newkey rsa:2048 -subj /CN=CRT/ \ + -keyout CRT.key -out CRT.crt -nodes -days 365 + $ cert-to-efi-sig-list CRT.crt CRT.esl + + $ openssl x509 -in CRT.crt -out CRT.cer -outform DER + $ openssl x509 -inform DER -in CRT.cer -outform PEM -out CRT.pub.pem + + $ openssl pkcs12 -export -out CRT.pfx -inkey CRT.key -in CRT.crt + $ openssl pkcs12 -in CRT.pfx -nodes -out CRT.pem + +The capsule file can be generated by using the GenerateCapsule.py +script in edk2:: + + $ ./BaseTools/BinWrappers/PosixLike/GenerateCapsule -e -o \ + <capsule_file_name> --monotonic-count <val> --fw-version \ + <val> --lsv <val> --guid \ + e2bb9c06-70e9-4b14-97a3-5a7913176e3f --verbose \ + --update-image-index <val> --signer-private-cert \ + /path/to/CRT.pem --trusted-public-cert \ + /path/to/CRT.pub.pem --other-public-cert /path/to/CRT.pub.pem \ + <u-boot.bin> + +Place the capsule generated in the above step on the EFI System +Partition under the EFI/UpdateCapsule directory + +For embedding the public key certificate, the following steps need to +be followed:: + + 1. Generate a skeleton overlay dts file, with a single fragment + node and an empty __overlay__ node + + 2. Convert the dts to a corresponding dtb with the following + command + ./scripts/dtc/dtc -@ -I dts -O dtb -o <ov_dtb_file_name> \ + <dts_file> + + 3. Run the dtb file generated above through the mkeficapsule tool + in u-boot + ./tools/mkeficapsule -O <pub_key.esl> -D <ov_dtb> + +Running the above command results in the creation of a 'signature' +node in the dtb, under which the public key is stored as a +'capsule-key' property. The '-O' option is to be used since the +public key certificate(esl) file is being embedded in an overlay. + +The dtb file embedded with the certificate is now to be placed on an +EFI System Partition. This would then be loaded and "merged" with the +base platform fdt at runtime. + +Build u-boot with the following steps:: + + $ make qemu_arm64_defconfig + $ make menuconfig + Disable CONFIG_TFABOOT + Enable CONFIG_EFI_CAPSULE_AUTHENTICATE + Enable all configs needed for capsule update(listed above) + $ make all + +Boot the platform and perform the following steps on the u-boot +command line:: + + 1. Enable capsule authentication by setting the following env + variable + + => setenv capsule_authentication_enabled 1 + => saveenv + + 2. Load the overlay dtb to memory and merge it with the base fdt + + => fatload virtio 0:1 <$fdtovaddr> EFI/<ov_dtb_file> + => fdt addr $fdtcontroladdr + => fdt resize <size_of_ov_dtb_file> + => fdt apply <$fdtovaddr> + + 3. Set the following env and efi Boot variables + + => setenv -e -nv -bs -rt -v OsIndications =0x04 + => efidebug boot add 0 Boot0000 virtio 0:1 <capsule_file_name> + => efidebug boot next 0 + => saveenv + + 4. Finally, the capsule update can be initiated with the following + command + + => efidebug capsule disk-update + +On subsequent reboot, the platform should boot the updated u-boot binary.
Changes since V1:
Why do you put the information into doc/board/emulation/qemu-arm.rst?
Isn't the same applicable to RISC-V QEMU?
Best regards
Heinrich
- CONFIG_MTD=y
- CONFIG_FLASH_CFI_MTD=y
- CONFIG_CMD_MTDPARTS=y
- CONFIG_CMD_DFU=y
- CONFIG_DFU_MTD=y
- CONFIG_PCI_INIT_R=y
- CONFIG_EFI_CAPSULE_ON_DISK=y
- CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT=y
- CONFIG_EFI_CAPSULE_FIRMWARE=y
- CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y
- CONFIG_EFI_CAPSULE_FMP_HEADER=y
- CONFIG_TFABOOT
- $ ./BaseTools/BinWrappers/PosixLike/GenerateCapsule -e -o \
- <capsule_file_name> --fw-version <val> --lsv <val> --guid \
- e2bb9c06-70e9-4b14-97a3-5a7913176e3f --verbose --update-image-index \
- <val> --verbose <u-boot.bin>
- => efidebug boot add 0 Boot0000 virtio 0:1 <capsule_file_name>
- => efidebug boot next 0
- => setenv -e -nv -bs -rt -v OsIndications =0x04
- => saveenv
- => efidebug capsule disk-update
- CONFIG_EFI_CAPSULE_AUTHENTICATE=y
- Install utility commands on your host
* openssl
* efitools
- Create signing keys and certificate files on your host
<u-boot.bin>
- Generate a skeleton overlay dts file, with a single fragment
- Convert the dts to a corresponding dtb with the following
command
<dts_file>
- Run the dtb file generated above through the mkeficapsule tool
in u-boot
- $ make qemu_arm64_defconfig
- $ make menuconfig
- $ make all
- Enable capsule authentication by setting the following env
variable
=> saveenv
- Load the overlay dtb to memory and merge it with the base fdt
- Set the following env and efi Boot variables
=> saveenv
- Finally, the capsule update can be initiated with the following
command
Changes since V1:
Where do you want me to put it. Currently, I do not see any common document for qemu which can be shared between qemu-arm and qemu risc-v. Or do you think a new document should be created under doc/board/emulation/ directory. Moreover, my series is adding support for capsule update feature on the qemu arm64 platform, and i have only tested this feature on the qemu arm64 platform. If someone wants to extend this on the qemu risc-v platform, that work i think needs to be done separately, with whatever changes that may be needed to get capsule updates working on qemu risc-v. If you so prefer, I can move the changes made for mtdparts and dfu(patches 4/14 and 5/14) under a common directory under board/emulation.
-sughosh
Best regards
Heinrich
settings::
- CONFIG_MTD=y
- CONFIG_CMD_DFU=y
- CONFIG_DFU_MTD=y
- CONFIG_TFABOOT
- => saveenv
* openssl
* efitools
CRT.pub.pem
<u-boot.bin>
command
<dts_file>
in u-boot
- $ make menuconfig
- $ make all
variable
=> saveenv
=> saveenv
command
binary.
Changes since V1:
I have started putting the documentation for shell commands into doc/usage. This is where a description of efidebug could be placed.
Equally I think we should put the documentation of tools like mkeficapsule under doc/usage.
The description on the usage of the UEFI firmware protocol would fit into doc/uefi/uefi.rst.
When it comes to things that are really QEMU specific doc/board/emulation/ is the right folder.
See more comments below.
-sughosh
Best regards
Heinrich
settings::
%s/uefi/UEFI/
According to the UEFI spec the relevant directory is \EFI\UpdateCapsule. I think you should mentions this path.
%s/u-boot/U-Boot/g
%s/i.e/i.e./
%s/qemu/QEMU/
U-Boot
%s/Nor Flash/NOR flash/
U-Boot
NOR flash
%s/configs/configuration settings/
- CONFIG_MTD=y
- CONFIG_CMD_DFU=y
- CONFIG_DFU_MTD=y
- CONFIG_TFABOOT
EDK II
UEFI
\EFI\UpdateCapsule\ (see UEFI specification)
%s/efi/UEFI/
Shouldn't OsIndications bit 2 be set by default when EFI capsule support is enabled? How about bit 3 (EFI_OS_INDICATIONS_FMP_CAPSULE_SUPPORTED)?
- => saveenv
U-Boot
UEFI
QEMU
QEMU
* openssl
OpenSSL
* efitools
CRT.pub.pem
EDK II
Above you wrote GenerateCapsule.py. I understand that the binary wrapper shall be used. But somehow this should be explained.
<u-boot.bin>
A typical user will be lost here. Please, provide the content of the file here.
command
<dts_file>
in u-boot
%s/fdt/flattened device-tree (dtb)/
U-Boot
- $ make menuconfig
- $ make all
variable
=> saveenv
environment and UEFI boot variables
=> saveenv
command
U-Boot
Best regards
Heinrich
binary.
Changes since V1:
document
feature
qemu
qemu
board/emulation.
Ok. I will create a Qemu specific file for capsule updates under the doc/board/emulation/ directory.
-sughosh
Best regards
Heinrich
settings::
%s/uefi/UEFI/
%s/u-boot/U-Boot/g
%s/i.e/i.e./
%s/qemu/QEMU/
U-Boot
U-Boot
NOR flash
- CONFIG_MTD=y
- CONFIG_CMD_DFU=y
- CONFIG_DFU_MTD=y
- CONFIG_TFABOOT
EDK II
UEFI
%s/efi/UEFI/
The OsIndications bit 2(EFI_OS_INDICATIONS_FILE_CAPSULE_DELIEVERY_SUPPORTED) should be set by the OS through a SetVariable call. This is still work in progress though, hence, for now, we are setting the bit in u-boot before invoking the capsule update.
As for the bit 3(EFI_OS_INDICATIONS_FMP_CAPSULE_SUPPORTED), this has no function in the OsIndications variable. This needs to be set in the variable OsIndicationsSupported, which is being done in the function efi_init_os_indications.
-sughosh
- => saveenv
U-Boot
UEFI
QEMU
QEMU
* openssl
OpenSSL
* efitools
CRT.pub.pem
CRT.crt
EDK II
<u-boot.bin>
command
<dts_file>
in u-boot
U-Boot
- $ make menuconfig
- $ make all
variable
=> saveenv
=> saveenv
command
U-Boot
Best regards
Heinrich
binary.
Sughosh Ganu
