[U-Boot] [PATCH][v3] driver: fsl-mc: memset pointers after malloc
Memory allocated via malloc is not guaranteed to be zeroized.
So explicitly use calloc instead of malloc.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v2: Replaced malloc/memset with calloc Changes for v3: Updated patch description
drivers/net/fsl-mc/mc.c | 39 +++++++++++++++++++++------------------ 1 file changed, 21 insertions(+), 18 deletions(-)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 458c458..05d3358 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -725,9 +725,9 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) * Initialize the global default MC portal * And check that the MC firmware is responding portal commands: */ - root_mc_io = (struct fsl_mc_io *)malloc(sizeof(struct fsl_mc_io)); + root_mc_io = (struct fsl_mc_io *)calloc(sizeof(struct fsl_mc_io), 1); if (!root_mc_io) { - printf(" No memory: malloc() failed\n"); + printf(" No memory: calloc() failed\n"); return -ENOMEM; }
@@ -877,11 +877,12 @@ static int dpio_init(void) struct dpio_cfg dpio_cfg; int err = 0;
- dflt_dpio = (struct fsl_dpio_obj *)malloc(sizeof(struct fsl_dpio_obj)); + dflt_dpio = (struct fsl_dpio_obj *)calloc( + sizeof(struct fsl_dpio_obj), 1); if (!dflt_dpio) { - printf("No memory: malloc() failed\n"); + printf("No memory: calloc() failed\n"); err = -ENOMEM; - goto err_malloc; + goto err_calloc; }
dpio_cfg.channel_mode = DPIO_LOCAL_CHANNEL; @@ -946,7 +947,7 @@ err_get_attr: dpio_destroy(dflt_mc_io, MC_CMD_NO_FLAGS, dflt_dpio->dpio_handle); err_create: free(dflt_dpio); -err_malloc: +err_calloc: return err; }
@@ -1028,11 +1029,11 @@ static int dprc_init(void) goto err_create; }
- dflt_mc_io = (struct fsl_mc_io *)malloc(sizeof(struct fsl_mc_io)); + dflt_mc_io = (struct fsl_mc_io *)calloc(sizeof(struct fsl_mc_io), 1); if (!dflt_mc_io) { err = -ENOMEM; - printf(" No memory: malloc() failed\n"); - goto err_malloc; + printf(" No memory: calloc() failed\n"); + goto err_calloc; }
child_portal_id = MC_PORTAL_OFFSET_TO_PORTAL_ID(mc_portal_offset); @@ -1057,7 +1058,7 @@ static int dprc_init(void) return 0; err_child_open: free(dflt_mc_io); -err_malloc: +err_calloc: dprc_destroy_container(root_mc_io, MC_CMD_NO_FLAGS, root_dprc_handle, child_dprc_id); err_create: @@ -1108,11 +1109,12 @@ static int dpbp_init(void) struct dpbp_attr dpbp_attr; struct dpbp_cfg dpbp_cfg;
- dflt_dpbp = (struct fsl_dpbp_obj *)malloc(sizeof(struct fsl_dpbp_obj)); + dflt_dpbp = (struct fsl_dpbp_obj *)calloc( + sizeof(struct fsl_dpbp_obj), 1); if (!dflt_dpbp) { - printf("No memory: malloc() failed\n"); + printf("No memory: calloc() failed\n"); err = -ENOMEM; - goto err_malloc; + goto err_calloc; }
dpbp_cfg.options = 512; @@ -1162,7 +1164,7 @@ err_get_attr: dpbp_close(dflt_mc_io, MC_CMD_NO_FLAGS, dflt_dpbp->dpbp_handle); dpbp_destroy(dflt_mc_io, MC_CMD_NO_FLAGS, dflt_dpbp->dpbp_handle); err_create: -err_malloc: +err_calloc: return err; }
@@ -1204,11 +1206,12 @@ static int dpni_init(void) struct dpni_extended_cfg dpni_extended_cfg; struct dpni_cfg dpni_cfg;
- dflt_dpni = (struct fsl_dpni_obj *)malloc(sizeof(struct fsl_dpni_obj)); + dflt_dpni = (struct fsl_dpni_obj *)calloc( + sizeof(struct fsl_dpni_obj), 1); if (!dflt_dpni) { - printf("No memory: malloc() failed\n"); + printf("No memory: calloc() failed\n"); err = -ENOMEM; - goto err_malloc; + goto err_calloc; }
memset(&dpni_extended_cfg, 0, sizeof(dpni_extended_cfg)); @@ -1270,7 +1273,7 @@ err_get_attr: err_create: err_prepare_extended_cfg: free(dflt_dpni); -err_malloc: +err_calloc: return err; }
Prabhakar Kushwaha
