[U-Boot] [PATCH] lib/physmem.c: Switch to __weak for arch_phys_memset
We normally use __weak rather than calling it out directly as an alias. Update this function to the normal method.
Signed-off-by: Tom Rini trini@konsulko.com --- lib/physmem.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/lib/physmem.c b/lib/physmem.c index 0f035ed..f21ac24 100644 --- a/lib/physmem.c +++ b/lib/physmem.c @@ -10,8 +10,9 @@
#include <common.h> #include <physmem.h> +#include <linux/compiler.h>
-static phys_addr_t __arch_phys_memset(phys_addr_t s, int c, phys_size_t n) +phys_addr_t __weak arch_phys_memset(phys_addr_t s, int c, phys_size_t n) { void *s_ptr = (void *)(uintptr_t)s;
@@ -19,6 +20,3 @@ static phys_addr_t __arch_phys_memset(phys_addr_t s, int c, phys_size_t n) assert(((phys_addr_t)(uintptr_t)(s + n)) == s + n); return (phys_addr_t)(uintptr_t)memset(s_ptr, c, n); } - -phys_addr_t arch_phys_memset(phys_addr_t s, int c, phys_size_t n) - __attribute__((weak, alias("__arch_phys_memset")));
