Subject: [PATCH v3 00/18] TI TPS6594 PMIC support for multiple TI EVMs
TPS6594 is a Power Management IC which provides regulators and others features like GPIOs, RTC, watchdog, ESMs (Error Signal Monitor), and PFSM (Pre-configurable Finite State Machine). The SoC and the PMIC can communicate through the I2C or SPI interfaces. TPS6594 is the super-set device while TPS6593 and LP8764 are derivatives.
This series fixes LDO voltage conversion for TPS6594 PMIC, it adds support for its derivatives.
The features implemented are: - Regulators - Watchdog disable
Watchdog disable is not a watchdog driver implementation. Watchdog is active by default causing a reboot even if not used. This implementation allows to disable the watchdog at boot time.
This patch suite can be applied only after u-boot dts upstream is re-synced on latest Linux dts: Link: https://gist.github.com/nmenon/030b11b085473fa008145429b39fcc75
This should be applied on top of Linux patch series (for dts inheritence): Link: https://lore.kernel.org/all/20230417154832.216774-1-eblanc@baylibre.com/
Additionally, it should also be applied on top of U-Boot patch series for j784s4 initial board support: Link: https://lore.kernel.org/all/20230321141028.24456-1-hnagalla@ti.com/
Tested on boards listed below (resynched manually on Linux 6.3 dts)
Supported boards: - j721eXSOMXEVM: Link: https://www.ti.com/tool/J721EXSOMXEVM - j721S2XSOMXEVM: Link: https://www.ti.com/tool/J721S2XSOMXEVM - j7200XSOMXEVM: Link: https://www.ti.com/tool/J7200XSOMXEVM - j784S4XEVM Link: https://www.ti.com/tool/J784S4XEVM - AM62A-SKEVM: Link: https://www.ti.com/tool/SK-AM62A-LP
basic tests: => pmic list => regulator list => regulator dev reg_name_to_be_tested => regulator info => regulator value => regulator value my_test_val => regulator value Check watchdog reset is not happening when dip switch SW2 on GPIO8 is High.
History:
v1 Changes: - Link: https://lore.kernel.org/all/20230406153820.2800054-1-jneanne@baylibre.com/
v2 Changes: - added support for 2 additional boards: j721s2 and j7200 - Convert driver model tags to use new schema: 8c103c33f - Link: https://lore.kernel.org/all/20230407133347.2957435-1-jneanne@baylibre.com/
v3 Changes: - addressed v2 review comments - clear WD_EN bit in stop_watchdog() function - use generic node names for pmic and watchdog - added support for 1 additional board: j784s4
Apelete Seketeli (3): DONOTMERGE: arch: arm: dts: k3-j784s4-evm: Add TI TPS6594 PMIC support arch: arm: dts: k3-j784s4-r5-evm: Add TI TPS6594 PMIC support configs: j784s4_evm_a72: Enable TI TPS6594 PMIC support
Esteban Blanc (4): configs: j7200_evm: Enable TP6594 family PMICs configs: j721s2_evm: Enable TP6594 PMIC and AVS0 board: ti: k3-j721s2: Force TPS65941 PMIC WD disable board: ti: k3-j721s2: Enable AVS0 on board init
Jerome Neanne (10): drivers: pmic: TPS65941 add support for WD disable drivers: regulator: Fixes for TPS65941 LDO voltage conversion configs: j721e_evm: Add support for TPS65941 PMICs on j721e TI EVM board board: ti: k3-j721e: Force TPS65941 PMIC WD disable on j721e TI EVM board DONOTMERGE: arm: dts: k3-j721e: u-boot overlay for TI tps6594 PMIC DONOTMERGE: arm: dts: k3-j721e: refactor r5 board file to use Linux dts tps6594 description DONOTMERGE: arm: dts: k3-j721e: realign node name on linux dts name DONOTMERGE: arm: dts: k3-am62a7-sk: Add TI TPS6593 PMIC support DONOTMERGE: arm: dts: k3-j7200: Add TP6594 family PMICs DONOTMERGE: arch: arm: dts: k3-j721s2: Add TPS6594 family PMICs
Julien Panis (1): configs: am62ax_evm_a53: Enable support for TI TPS6593 PMIC
arch/arm/dts/k3-am62a7-sk-u-boot.dtsi | 24 +++- .../k3-j7200-common-proc-board-u-boot.dtsi | 27 ++++ .../arm/dts/k3-j7200-r5-common-proc-board.dts | 56 +++----- .../k3-j721e-common-proc-board-u-boot.dtsi | 22 +++ .../k3-j721e-r5-common-proc-board-u-boot.dtsi | 2 +- .../arm/dts/k3-j721e-r5-common-proc-board.dts | 48 +++---- .../k3-j721s2-common-proc-board-u-boot.dtsi | 37 ++++- .../dts/k3-j721s2-r5-common-proc-board.dts | 44 ++++++ arch/arm/dts/k3-j784s4-evm-u-boot.dtsi | 12 ++ arch/arm/dts/k3-j784s4-r5-evm.dts | 134 ++++++++++++++++++ board/ti/j721e/evm.c | 8 ++ board/ti/j721s2/evm.c | 18 ++- configs/am62ax_evm_a53_defconfig | 8 +- configs/j7200_evm_a72_defconfig | 6 + configs/j721e_evm_a72_defconfig | 6 + configs/j721s2_evm_a72_defconfig | 6 + configs/j721s2_evm_r5_defconfig | 6 + configs/j784s4_evm_a72_defconfig | 19 +-- drivers/power/pmic/tps65941.c | 61 ++++++++ drivers/power/regulator/tps65941_regulator.c | 71 ++++++++-- include/power/tps65941.h | 27 +++- 21 files changed, 558 insertions(+), 84 deletions(-)
This is not a proper WD driver because it's not planned to support WD driver for PMIC in u-boot at any time. The purpose is just WD disable.
Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- drivers/power/pmic/tps65941.c | 61 +++++++++++++++++++++++++++++++++++ include/power/tps65941.h | 27 ++++++++++++++-- 2 files changed, 86 insertions(+), 2 deletions(-)
diff --git a/drivers/power/pmic/tps65941.c b/drivers/power/pmic/tps65941.c index 83d0f83c64..974c8c90dc 100644 --- a/drivers/power/pmic/tps65941.c +++ b/drivers/power/pmic/tps65941.c @@ -47,6 +47,9 @@ static int tps65941_bind(struct udevice *dev) ofnode regulators_node; int children;
+ if (dev->driver_data == TPS65941_WD) + return 0; + regulators_node = dev_read_subnode(dev, "regulators"); if (!ofnode_valid(regulators_node)) { debug("%s: %s regulators subnode not found!\n", __func__, @@ -64,6 +67,61 @@ static int tps65941_bind(struct udevice *dev) return dm_scan_fdt_dev(dev); }
+static int stop_watchdog(struct udevice *wd_i2c_dev) +{ + int ret; + + /* Maintain WD long window */ + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65941_WD_MODE_REG); + if (ret < 0) { + debug("failed to read i2c reg (%d)\n", ret); + return ret; + } + + ret &= ~TPS65941_WD_PWRHOLD_MASK; + ret |= TPS65941_WD_PWRHOLD_MASK; + ret = dm_i2c_reg_write(wd_i2c_dev, TPS65941_WD_MODE_REG, ret); + if (ret) { + debug("%s: %s write WD_PWRHOLD fail!\n", __func__, wd_i2c_dev->name); + return ret; + } + + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65941_WD_MODE_REG); + if (ret < 0) { + debug("failed to read back i2c reg (%d)\n", ret); + return ret; + } + + /* Disable WD */ + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65941_WD_THR_CFG); + if (ret < 0) { + debug("failed to read i2c reg (%d)\n", ret); + return ret; + } + + ret &= ~TPS65941_WD_EN_MASK; + ret = dm_i2c_reg_write(wd_i2c_dev, TPS65941_WD_THR_CFG, ret); + if (ret) { + debug("%s: %s write WD_EN fail!\n", __func__, wd_i2c_dev->name); + return ret; + } + + ret = dm_i2c_reg_read(wd_i2c_dev, TPS65941_WD_THR_CFG); + if (ret < 0) { + debug("failed to read back i2c reg (%d)\n", ret); + return ret; + } + + return 0; +} + +static int tps65941_probe(struct udevice *dev) +{ + if (dev->driver_data == TPS65941_WD) + return stop_watchdog(dev); + return 0; +} + static struct dm_pmic_ops tps65941_ops = { .read = tps65941_read, .write = tps65941_write, @@ -73,7 +131,9 @@ static const struct udevice_id tps65941_ids[] = { { .compatible = "ti,tps659411", .data = TPS659411 }, { .compatible = "ti,tps659412", .data = TPS659411 }, { .compatible = "ti,tps659413", .data = TPS659413 }, + { .compatible = "ti,tps659312", .data = TPS659312 }, { .compatible = "ti,lp876441", .data = LP876441 }, + { .compatible = "ti,tps65941_watchdog", .data = TPS65941_WD }, { } };
@@ -82,5 +142,6 @@ U_BOOT_DRIVER(pmic_tps65941) = { .id = UCLASS_PMIC, .of_match = tps65941_ids, .bind = tps65941_bind, + .probe = tps65941_probe, .ops = &tps65941_ops, }; diff --git a/include/power/tps65941.h b/include/power/tps65941.h index a2bc6814ba..f3bf25a6d2 100644 --- a/include/power/tps65941.h +++ b/include/power/tps65941.h @@ -2,7 +2,9 @@ #define TPS659412 0x1 #define TPS659413 0x2 #define TPS659414 0x3 -#define LP876441 0x4 +#define TPS659312 0x4 +#define LP876441 0x5 +#define TPS65941_WD 0x20
/* I2C device address for pmic tps65941 */ #define TPS65941_I2C_ADDR (0x12 >> 1) @@ -18,10 +20,31 @@ #define TPS65941_BUCK_VOLT_MAX 3340000 #define TPS65941_BUCK_MODE_MASK 0x1
-#define TPS65941_LDO_VOLT_MASK 0x3E +#define TPS65941_LDO_VOLT_MASK 0x7F #define TPS65941_LDO_VOLT_MAX_HEX 0x3A #define TPS65941_LDO_VOLT_MIN_HEX 0x4 #define TPS65941_LDO_VOLT_MAX 3300000 #define TPS65941_LDO_MODE_MASK 0x1 #define TPS65941_LDO_BYPASS_EN 0x80 #define TP65941_BUCK_CONF_SLEW_MASK 0x7 + +/* BYPASS is bit7 of VOUT TPS65941_LDO_BYP_MASK */ +#define TPS65941_LDO123_BYP_CONFIG 7 + +#define TPS65941_LDO123_VOLT_BYP_MIN 1700000 +#define TPS65941_LDO123_VOLT_BYP_MAX 3600000 +#define TPS65941_LDO123_VOLT_MIN 600000 +#define TPS65941_LDO4_VOLT_MIN 1200000 +#define TPS65941_LDO4_VOLT_MIN 1200000 +#define TPS65941_LDO123_VSET_MIN 0x04 +#define TPS65941_LDO4_VSET_MIN 0x20 +#define TPS65941_LDO123_VSET_MAX 0x3A +#define TPS65941_LDO4_VSET_MAX 0x74 +#define TPS65941_LDO123_STEP 50000 +#define TPS65941_LDO4_STEP 25000 + +#define TPS65941_WD_MODE_REG 0x406 +#define TPS65941_WD_PWRHOLD_MASK BIT(2) + +#define TPS65941_WD_THR_CFG 0x409 +#define TPS65941_WD_EN_MASK BIT(6)
Fixes: 065a452ae6a power: regulator: tps65941: add regulator support
LDO voltage conversion was incorrect. This was checked by writing and reading back value.
Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- drivers/power/regulator/tps65941_regulator.c | 71 +++++++++++++++++--- 1 file changed, 63 insertions(+), 8 deletions(-)
diff --git a/drivers/power/regulator/tps65941_regulator.c b/drivers/power/regulator/tps65941_regulator.c index b041126775..7afd68c5c4 100644 --- a/drivers/power/regulator/tps65941_regulator.c +++ b/drivers/power/regulator/tps65941_regulator.c @@ -212,12 +212,55 @@ static int tps65941_ldo_enable(struct udevice *dev, int op, bool *enable) return 0; }
-static int tps65941_ldo_val2volt(int val) +static int tps65941_ldo_volt2val(int idx, int uV) { - if (val > TPS65941_LDO_VOLT_MAX_HEX || val < TPS65941_LDO_VOLT_MIN_HEX) + int base = TPS65941_LDO123_VOLT_MIN; + int max = TPS65941_LDO_VOLT_MAX; + int offset = TPS65941_LDO123_VSET_MIN; + int step = TPS65941_LDO123_STEP; + + if (idx > 2) { + base = TPS65941_LDO4_VOLT_MIN; + offset = TPS65941_LDO4_VSET_MIN; + step = TPS65941_LDO4_STEP; + } + + if (uV > max) return -EINVAL; - else if (val >= TPS65941_LDO_VOLT_MIN_HEX) - return 600000 + (val - TPS65941_LDO_VOLT_MIN_HEX) * 50000; + else if (uV >= base) + return (uV - base) / step + offset; + else + return -EINVAL; +} + +static int tps65941_ldo_val2volt(int idx, int val) +{ + int reg_base = TPS65941_LDO123_VSET_MIN; + int reg_max = TPS65941_LDO123_VSET_MAX; + int base = TPS65941_LDO123_VOLT_MIN; + int max = TPS65941_LDO_VOLT_MAX; + int step = TPS65941_LDO123_STEP; + int mask = TPS65941_LDO_VOLT_MASK >> 1; + + if (idx > 2) { + base = TPS65941_LDO4_VOLT_MIN; + max = TPS65941_LDO_VOLT_MAX; + reg_base = TPS65941_LDO4_VSET_MIN; + reg_max = TPS65941_LDO4_VSET_MAX; + step = TPS65941_LDO4_STEP; + mask = TPS65941_LDO_VOLT_MASK; + } else { + val = val >> 1; + } + + if (val > mask || val < 0) + return -EINVAL; + else if (val >= reg_max) + return max; + else if (val <= reg_base) + return base; + else if (val >= 0) + return base + (step * (val - reg_base)); else return -EINVAL; } @@ -227,7 +270,9 @@ static int tps65941_ldo_val(struct udevice *dev, int op, int *uV) unsigned int hex, adr; int ret; struct dm_regulator_uclass_plat *uc_pdata; + int idx;
+ idx = dev->driver_data - 1; uc_pdata = dev_get_uclass_plat(dev);
if (op == PMIC_OP_GET) @@ -240,7 +285,8 @@ static int tps65941_ldo_val(struct udevice *dev, int op, int *uV) return ret;
ret &= TPS65941_LDO_VOLT_MASK; - ret = tps65941_ldo_val2volt(ret); + ret = tps65941_ldo_val2volt(idx, ret); + if (ret < 0) return ret;
@@ -249,12 +295,21 @@ static int tps65941_ldo_val(struct udevice *dev, int op, int *uV) return 0; }
- hex = tps65941_buck_volt2val(*uV); + /* LDO1, LDO2 & LDO3 in BYPASS mode only supports 1.7V min to 3.6V max */ + if (idx < 2 && + (ret & BIT(TPS65941_LDO123_BYP_CONFIG)) && + *uV < TPS65941_LDO123_VOLT_BYP_MIN) + return -EINVAL; + + hex = tps65941_ldo_volt2val(idx, *uV); if (hex < 0) return hex;
- ret &= 0x0; - ret = hex; + if (idx < 2) + hex = hex << 1; + + ret &= ~TPS65941_LDO_VOLT_MASK; + ret |= hex;
ret = pmic_reg_write(dev->parent, adr, ret);
Add PMIC and regulators feature support for j721e. PMIC is controlled by SoC through I2C interface.
Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- configs/j721e_evm_a72_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index d5f37b134c..af9a755c36 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -67,6 +67,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_MAXARGS=64 CONFIG_CMD_ASKENV=y CONFIG_CMD_DFU=y +CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -79,6 +80,8 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)" @@ -169,9 +172,12 @@ CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_TPS65941=y CONFIG_RAM=y CONFIG_SPL_RAM=y CONFIG_REMOTEPROC_TI_K3_DSP=y
Using uclass_probe_all forces probe on all devices: Only probe for WD stop is really needed here. Probing other devices has no impact.
Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- board/ti/j721e/evm.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 2398bead78..c6391c1bae 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -25,6 +25,8 @@
#include "../common/board_detect.h"
+#include <power/tps65941.h> + #define board_is_j721e_som() (board_ti_k3_is("J721EX-PM1-SOM") || \ board_ti_k3_is("J721EX-PM2-SOM"))
@@ -41,6 +43,12 @@ DECLARE_GLOBAL_DATA_PTR;
int board_init(void) { + int ret; + + /* WD stop is applied unconditionally on all platforms*/ + ret = uclass_probe_all(UCLASS_PMIC); + if (ret) + printf("Failed to probe! stop tps65941 wd\n"); return 0; }
j721e board includes 2 instances of TPS6594: - Primary PMIC - Secondary PMIC
Add AVS class0 in u-boot SPL. AVS is supported only on CPU rail: vdd_cpu_avs. This rail is supplied by the primary PMIC: tps659413 This rail is supplied by a dual-phased buck: buck12.
Other PMICs rails are not AVS capable.
Each PMIC includes a Watchdog that is active by default at boot. This would issue a platform reset unless pmic GPIO8 is driven or this is handled by SW. Watchdog driver is not required for identified use of this product. This software disable inside u-boot avoids parasitic wd reset. GPIO8 can then be used for other purpose.
Board documentation: Link: https://www.ti.com/tool/J721EXSOMXEVM
Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- .../k3-j721e-common-proc-board-u-boot.dtsi | 22 +++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 867ec2bb1a..857d0c0529 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -79,6 +79,14 @@ chipid@43000014 { bootph-pre-ram; }; + + mcu_i2c0: i2c@40b00000 { + status = "okay"; + tps65941_wd: watchdog@12 { + compatible = "ti,tps65941_watchdog"; + reg = <0x12>; + }; + }; };
&secure_proxy_main { @@ -170,6 +178,20 @@
&wkup_i2c0 { bootph-pre-ram; + tps659413: pmic@48 { + bootph-pre-ram; + compatible = "ti,tps659413"; + + regulators { + bootph-pre-ram; + bucka12: buck12 { + bootph-pre-ram; + }; + }; + }; + tps659411: pmic@4c { + compatible = "ti,tps659411"; + }; };
&main_i2c0 {
Use a copy of Linux dts for TPS6594 PMIC description instead of custom u-boot
Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- .../arm/dts/k3-j721e-r5-common-proc-board.dts | 48 +++++++++---------- 1 file changed, 22 insertions(+), 26 deletions(-)
diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts index 1b40cf2580..f6456034d4 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts @@ -21,6 +21,27 @@ tick-timer = &timer1; };
+ evm_12v0: fixedregulator-evm12v0 { + /* main supply */ + compatible = "regulator-fixed"; + regulator-name = "evm_12v0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of LM5140 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&evm_12v0>; + regulator-always-on; + regulator-boot-on; + }; + a72_0: a72@0 { compatible = "ti,am654-rproc"; reg = <0x0 0x00a90000 0x0 0x10>; @@ -277,33 +298,8 @@ ti,driver-strength-ohm = <50>; };
-&wkup_i2c0 { - bootph-pre-ram; - tps659413a: tps659413a@48 { - reg = <0x48>; - compatible = "ti,tps659413"; - bootph-pre-ram; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_i2c0_pins_default>; - clock-frequency = <400000>; - - regulators: regulators { - bootph-pre-ram; - buck12_reg: buck12 { - /*VDD_CPU*/ - regulator-name = "buck12"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <900000>; - regulator-always-on; - regulator-boot-on; - bootph-pre-ram; - }; - }; - }; -}; - &wkup_vtm0 { - vdd-supply-2 = <&buck12_reg>; + vdd-supply-2 = <&bucka12>; bootph-pre-ram; };
Change node name to reuse Linux common dts naming style.
Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi index f9746d33ec..332f3f4672 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi @@ -21,7 +21,7 @@ }; };
-&tps659413a { +&tps659413 { esm: esm { compatible = "ti,tps659413-esm"; bootph-pre-ram;
Add support for TPS6593 regulators and watchdog. PMIC is controlled by SoC through I2C interface.
Signed-off-by: Julien Panis jpanis@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- configs/am62ax_evm_a53_defconfig | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/configs/am62ax_evm_a53_defconfig b/configs/am62ax_evm_a53_defconfig index 41fa6f38aa..70d1a03e6a 100644 --- a/configs/am62ax_evm_a53_defconfig +++ b/configs/am62ax_evm_a53_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" +CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_POWER_DOMAIN=y CONFIG_CMD_MMC=y @@ -52,7 +53,8 @@ CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y CONFIG_TI_SCI_PROTOCOL=y # CONFIG_GPIO is not set -# CONFIG_I2C is not set +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_MMC_SDHCI=y @@ -64,6 +66,10 @@ CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_TPS65941=y CONFIG_K3_SYSTEM_CONTROLLER=y CONFIG_REMOTEPROC_TI_K3_ARM64=y CONFIG_RESET_TI_SCI=y
Add support for TPS6593 PMIC devices: - regulators (bucks and LDOs) on main I2C0 bus, - watchdog on MCU I2C0 bus.
Signed-off-by: Julien Panis jpanis@baylibre.com Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- arch/arm/dts/k3-am62a7-sk-u-boot.dtsi | 24 ++++++++++++++++++++++-- 1 file changed, 22 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/k3-am62a7-sk-u-boot.dtsi b/arch/arm/dts/k3-am62a7-sk-u-boot.dtsi index cf938c43b8..fe392054c8 100644 --- a/arch/arm/dts/k3-am62a7-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am62a7-sk-u-boot.dtsi @@ -84,7 +84,14 @@ };
&mcu_pmx0 { - bootph-pre-ram; + status = "okay"; + + mcu_i2c0_pins_default: mcu_i2c0_pins_default { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x044, PIN_INPUT_PULLUP, 0) /* (E12) MCU_I2C0_SCL */ + AM62X_MCU_IOPAD(0x048, PIN_INPUT_PULLUP, 0) /* (D9) MCU_I2C0_SDA */ + >; + }; };
&wkup_uart0 { @@ -96,7 +103,20 @@ };
&main_i2c0 { - bootph-pre-ram; + tps659312: pmic@48 { + compatible = "ti,tps659312"; + }; +}; + +&mcu_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_i2c0_pins_default>; + + tps65931_wd: watchdog@12 { + compatible = "ti,tps65941_watchdog"; + reg = <0x12>; + }; };
&main_i2c0_pins_default {
Add support for TPS6594 family regulators and watchdog. PMIC is controlled by SoC through I2C interface.
Add dm, pmic and regulators commands to allow testing
Signed-off-by: Esteban Blanc eblanc@baylibre.com Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- configs/j7200_evm_a72_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index e40900fffa..8850187924 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -70,6 +70,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_MAXARGS=64 CONFIG_CMD_ASKENV=y CONFIG_CMD_DFU=y +CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -82,6 +83,8 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)" @@ -167,9 +170,12 @@ CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_TPS65941=y CONFIG_RAM=y CONFIG_SPL_RAM=y CONFIG_REMOTEPROC_TI_K3_R5F=y
Add support for TPS6594 PMIC family devices: - regulators (bucks and LDOs) on WKUP_I2C0 bus, - watchdog on MCU_I2C0 bus.
Signed-off-by: Esteban Blanc eblanc@baylibre.com Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- .../k3-j7200-common-proc-board-u-boot.dtsi | 27 +++++++++ .../arm/dts/k3-j7200-r5-common-proc-board.dts | 56 ++++++++----------- 2 files changed, 49 insertions(+), 34 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index f57c2306ba..5088f918e8 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -120,6 +120,15 @@
&wkup_i2c0 { bootph-pre-ram; + status = "okay"; +}; + +&mcu_i2c0 { + status="okay"; + tps65941_wd: watchdog@12 { + compatible = "ti,tps65941_watchdog"; + reg = <0x12>; + }; };
&main_i2c0 { @@ -196,3 +205,21 @@ &main_r5fss0 { ti,cluster-mode = <0>; }; + +&wkup_i2c0 { + bootph-pre-ram; + lp876441: pmic@4c { + bootph-pre-ram; + compatible = "ti,lp876441"; + regulators { + bootph-pre-ram; + buckb1: buck1 { + bootph-pre-ram; + }; + }; + }; +}; + +&tps659414 { + compatible = "ti,tps659411"; +}; diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index e62f9218e8..1318edf9af 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -21,6 +21,27 @@ firmware-loader = &fs_loader0; };
+ evm_12v0: fixedregulator-evm12v0 { + /* main supply */ + compatible = "regulator-fixed"; + regulator-name = "evm_12v0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of LM5140 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&evm_12v0>; + regulator-always-on; + regulator-boot-on; + }; + fs_loader0: fs_loader@0 { bootph-all; compatible = "u-boot,fs-loader"; @@ -126,13 +147,6 @@ >; };
- wkup_i2c0_pins_default: wkup-i2c0-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x100, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ - J721E_WKUP_IOPAD(0x104, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */ - >; - }; - mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-pins-default { pinctrl-single,pins = < J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (E20) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ @@ -247,35 +261,9 @@ ti,driver-strength-ohm = <50>; };
-&wkup_i2c0 { - bootph-pre-ram; - lp876441: lp876441@4c { - compatible = "ti,lp876441"; - reg = <0x4c>; - bootph-pre-ram; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_i2c0_pins_default>; - clock-frequency = <400000>; - - regulators: regulators { - bootph-pre-ram; - buck1_reg: buck1 { - /*VDD_CPU_AVS_REG*/ - regulator-name = "buck1"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1250000>; - regulator-always-on; - regulator-boot-on; - bootph-pre-ram; - }; - }; - }; - -}; - &wkup_vtm0 { - vdd-supply-2 = <&buck1_reg>; bootph-pre-ram; + vdd-supply-2 = <&buckb1>; };
&main_i2c0 {
Add support for TPS6594 PMIC family devices: - regulators (bucks and LDOs) on main WKUP_I2C0 bus, - watchdog on MCU_I2C0 bus.
Signed-off-by: Esteban Blanc eblanc@baylibre.com Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- .../k3-j721s2-common-proc-board-u-boot.dtsi | 37 +++++++++++++++- .../dts/k3-j721s2-r5-common-proc-board.dts | 44 +++++++++++++++++++ 2 files changed, 80 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi index 4fd6d36417..cb9f9ab86d 100644 --- a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi @@ -21,8 +21,26 @@ }; };
-&wkup_i2c0 { +&wkup_i2c0{ bootph-pre-ram; + tps659411: pmic@48 { + bootph-pre-ram; + compatible = "ti,tps659411"; + regulators { + bootph-pre-ram; + bucka1234: buck1234 { + bootph-pre-ram; + }; + }; + }; +}; + +&tps659414 { + compatible = "ti,tps659411"; +}; + +&lp876411 { + compatible = "ti,lp876441"; };
&cbass_main { @@ -47,6 +65,17 @@ chipid@43000014 { bootph-pre-ram; }; + + mcu_i2c0: i2c@40b00000 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_i2c0_pins_default>; + + tps65941_wd: watchdog@12 { + compatible = "ti,tps65941_watchdog"; + reg = <0x12>; + }; + }; };
&mcu_navss { @@ -101,6 +130,12 @@
&wkup_pmx0 { bootph-pre-ram; + mcu_i2c0_pins_default: mcu_i2c0_pins_default { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x108, PIN_INPUT, 0) /* (G24) MCU_I2C0_SCL */ + J721S2_WKUP_IOPAD(0x10c, PIN_INPUT, 0) /* (J25) MCU_I2C0_SDA */ + >; + }; };
&k3_pds { diff --git a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts index e02b334d10..8a24002045 100644 --- a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts @@ -21,6 +21,38 @@ remoteproc1 = &a72_0; };
+ evm_12v0: fixedregulator-evm12v0 { + /* main supply */ + compatible = "regulator-fixed"; + regulator-name = "evm_12v0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of LM5140 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&evm_12v0>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_5v0: fixedregulator-vsys5v0 { + /* Output of LM5140 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&evm_12v0>; + regulator-always-on; + regulator-boot-on; + }; + fs_loader0: fs_loader@0 { compatible = "u-boot,fs-loader"; bootph-all; @@ -95,6 +127,13 @@ <&mcu_secproxy 23>; bootph-pre-ram; }; + + wkup_vtm0: vtm@42040000 { + compatible = "ti,am654-vtm", "ti,j721e-avs"; + reg = <0x0 0x42040000 0x0 0x330>; + power-domains = <&k3_pds 180 TI_SCI_PD_EXCLUSIVE>; + #thermal-sensor-cells = <1>; + }; };
&main_pmx0 { @@ -196,4 +235,9 @@ ti,sci = <&dm_tifs>; };
+&wkup_vtm0 { + vdd-supply-2 = <&bucka1234>; + bootph-pre-ram; +}; + #include "k3-j721s2-common-proc-board-u-boot.dtsi"
Add support for TPS6594 family regulators and watchdog. Add support for AVS0. PMIC is controlled by SoC through I2C interface.
Add dm, pmic and regulators commands to allow testing.
Signed-off-by: Esteban Blanc eblanc@baylibre.com Signed-off-by: Jerome Neanne jneanne@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- configs/j721s2_evm_a72_defconfig | 6 ++++++ configs/j721s2_evm_r5_defconfig | 6 ++++++ 2 files changed, 12 insertions(+)
diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 594c8dad2c..407d43509d 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -68,6 +68,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_MAXARGS=64 CONFIG_CMD_ASKENV=y CONFIG_CMD_DFU=y +CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -80,6 +81,8 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs)" @@ -173,9 +176,12 @@ CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_TPS65941=y CONFIG_RAM=y CONFIG_SPL_RAM=y CONFIG_REMOTEPROC_TI_K3_DSP=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 4ddbe8faef..01096fa937 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -114,6 +114,7 @@ CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_FS_LOADER=y CONFIG_SPL_FS_LOADER=y +CONFIG_K3_AVS0=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_SPL_MMC_HS400_SUPPORT=y CONFIG_MMC_SDHCI=y @@ -143,6 +144,11 @@ CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y CONFIG_TI_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_TPS65941=y CONFIG_K3_SYSTEM_CONTROLLER=y CONFIG_REMOTEPROC_TI_K3_ARM64=y CONFIG_RESET_TI_SCI=y
Signed-off-by: Esteban Blanc eblanc@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- board/ti/j721s2/evm.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 8eaca9d5af..ec7abea387 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -29,7 +29,14 @@ DECLARE_GLOBAL_DATA_PTR;
int board_init(void) { - return 0; + int ret = 0; + + /* WD stop is applied unconditionally on all platforms*/ + ret = uclass_probe_all(UCLASS_PMIC); + if (ret) + printf("Failed to probe! stop tps65941 wd\n"); + + return ret; }
int dram_init(void)
Signed-off-by: Esteban Blanc eblanc@baylibre.com Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- board/ti/j721s2/evm.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index ec7abea387..818edea686 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -326,4 +326,13 @@ int board_late_init(void)
void spl_board_init(void) { + struct udevice *dev; + int ret; + +#if defined(CONFIG_CPU_V7R) && defined(CONFIG_K3_AVS0) + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(k3_avs), + &dev); + if (ret) + printf("AVS init failed: %d\n", ret); +#endif }
Add support for TPS6594 PMIC devices : - overlaying regulators definition with compatible device, - watchdog on MCU_I2C0 bus.
Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- arch/arm/dts/k3-j784s4-evm-u-boot.dtsi | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/dts/k3-j784s4-evm-u-boot.dtsi b/arch/arm/dts/k3-j784s4-evm-u-boot.dtsi index cd2e1e1df5..22bcf2cebe 100644 --- a/arch/arm/dts/k3-j784s4-evm-u-boot.dtsi +++ b/arch/arm/dts/k3-j784s4-evm-u-boot.dtsi @@ -24,6 +24,14 @@ u-boot,dm-spl; };
+&mcu_i2c0 { + status="okay"; + tps65941_wd: watchdog@12 { + compatible = "ti,tps65941_watchdog"; + reg = <0x12>; + }; +}; + &cbass_main { u-boot,dm-spl; }; @@ -133,3 +141,7 @@ &main_sdhci1 { u-boot,dm-spl; }; + +&tps659413 { + compatible = "ti,tps659411"; +};
Add support for TPS6594 PMIC devices : - regulators (bucks and LDOs) on WKUP_I2C0 bus, - watchdog on MCU_I2C0 bus.
Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- arch/arm/dts/k3-j784s4-r5-evm.dts | 134 ++++++++++++++++++++++++++++++ 1 file changed, 134 insertions(+)
diff --git a/arch/arm/dts/k3-j784s4-r5-evm.dts b/arch/arm/dts/k3-j784s4-r5-evm.dts index 7350a9be34..27b91100af 100644 --- a/arch/arm/dts/k3-j784s4-r5-evm.dts +++ b/arch/arm/dts/k3-j784s4-r5-evm.dts @@ -22,6 +22,27 @@ remoteproc1 = &a72_0; };
+ evm_12v0: fixedregulator-evm12v0 { + /* main supply */ + compatible = "regulator-fixed"; + regulator-name = "evm_12v0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of LM5140 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&evm_12v0>; + regulator-always-on; + regulator-boot-on; + }; + fs_loader0: fs_loader@0 { compatible = "u-boot,fs-loader"; u-boot,dm-pre-reloc; @@ -97,6 +118,105 @@ }; };
+&wkup_gpio0 { + status = "okay"; +}; + +&wkup_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; + tps659413: pmic@48 { + compatible = "ti,tps65941-q1"; + reg = <0x48>; + system-power-controller; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_irq_pins_default>; + interrupt-parent = <&wkup_gpio0>; + interrupts = <39 IRQ_TYPE_EDGE_FALLING>; + ti,primary-pmic; + + gpio-controller; + #gpio-cells = <2>; + + buck12-supply = <&vsys_3v3>; + buck3-supply = <&vsys_3v3>; + buck4-supply = <&vsys_3v3>; + buck5-supply = <&vsys_3v3>; + ldo1-supply = <&vsys_3v3>; + ldo2-supply = <&vsys_3v3>; + ldo3-supply = <&vsys_3v3>; + ldo4-supply = <&vsys_3v3>; + + regulators { + bucka12: buck12 { + regulator-name = "vdd_ddr_1v1"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-boot-on; + regulator-always-on; + }; + + bucka3: buck3 { + regulator-name = "vdd_ram_0v85"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-boot-on; + regulator-always-on; + }; + + bucka4: buck4 { + regulator-name = "vdd_io_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + bucka5: buck5 { + regulator-name = "vdd_mcu_0v85"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-boot-on; + regulator-always-on; + }; + + ldoa1: ldo1 { + regulator-name = "vdd_mcuio_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldoa2: ldo2 { + regulator-name = "vdd_mcuio_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldoa3: ldo3 { + regulator-name = "vds_dll_0v8"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldoa4: ldo4 { + regulator-name = "vda_mcu_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + &main_pmx0 { u-boot,dm-spl;
@@ -144,6 +264,20 @@ J784S4_WKUP_IOPAD(0x0b4, PIN_OUTPUT, 0) /* (K34) WKUP_UART0_TXD */ >; }; + + wkup_i2c0_pins_default: wkup_i2c0_pins_default { + pinctrl-single,pins = < + J784S4_WKUP_IOPAD(0x100, PIN_INPUT, 0) /* (N33) WKUP_I2C0_SCL */ + J784S4_WKUP_IOPAD(0x104, PIN_INPUT, 0) /* (N35) WKUP_I2C0_SDA */ + >; + }; + + pmic_irq_pins_default: pmic-irq-pins-default { + pinctrl-single,pins = < + /* (G33) MCU_OSPI1_CSn1.WKUP_GPIO0_39 */ + J784S4_WKUP_IOPAD(0x060, PIN_INPUT, 7) + >; + }; };
&sms {
Enable TPS6594 PMIC support (regulators and watchdog) for j784s4 SoC. PMIC is controlled by SoC through I2C interface.
Signed-off-by: Apelete Seketeli aseketeli@baylibre.com --- configs/j784s4_evm_a72_defconfig | 19 +++++++++++-------- 1 file changed, 11 insertions(+), 8 deletions(-)
diff --git a/configs/j784s4_evm_a72_defconfig b/configs/j784s4_evm_a72_defconfig index 7de8925b27..df95bd58fd 100644 --- a/configs/j784s4_evm_a72_defconfig +++ b/configs/j784s4_evm_a72_defconfig @@ -8,12 +8,16 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_J784S4=y CONFIG_TARGET_J784S4_A72_EVM=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="k3-j784s4-evm" CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y @@ -24,14 +28,11 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y # CONFIG_PSCI_RESET is not set -CONFIG_DISTRO_DEFAULTS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y +CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; setenv fdtfile ti/${name_fdt}; run distro_bootcmd" CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 @@ -52,7 +53,6 @@ CONFIG_SPL_I2C=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_DM_SPI_FLASH=y -# CONFIG_SPL_NOR_SUPPORT=y CONFIG_SPL_DM_RESET=y CONFIG_SPL_POWER_DOMAIN=y CONFIG_SPL_RAM_SUPPORT=y @@ -68,6 +68,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_MAXARGS=64 CONFIG_CMD_ASKENV=y CONFIG_CMD_DFU=y +CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -80,6 +81,8 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs)" @@ -89,7 +92,6 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_OF_LIST="k3-j784s4-evm" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y @@ -171,14 +173,16 @@ CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_TPS65941=y CONFIG_RAM=y CONFIG_SPL_RAM=y CONFIG_REMOTEPROC_TI_K3_DSP=y CONFIG_REMOTEPROC_TI_K3_R5F=y -CONFIG_DM_RESET=y CONFIG_RESET_TI_SCI=y CONFIG_SCSI=y CONFIG_DM_SCSI=y @@ -210,4 +214,3 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 CONFIG_UFS=y CONFIG_CADENCE_UFS=y CONFIG_TI_J721E_UFS=y -CONFIG_OF_LIBFDT_OVERLAY=y
Apelete Seketeli
