[U-Boot] [PATCH v2] AT91: pio: Add PIO3 features
This patch adds the support for new PIO controller introduced by some AT91 SoCs.
New features include * More peripheral multiplexing * Pull-down, Schmitt trigger, Debouncer * More irq trigger mode (may be not interesting in U-Boot)
Signed-off-by: Hong Xu hong.xu@atmel.com --- - Correct register group definitions - ATMEL_CPU_HAS_PIO3 -> CONFIG_CPU_HAS_PIO3
arch/arm/include/asm/arch-at91/at91_pio.h | 48 ++++++++++- drivers/gpio/at91_gpio.c | 130 +++++++++++++++++++++++++++- 2 files changed, 171 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91_pio.h b/arch/arm/include/asm/arch-at91/at91_pio.h index 416cabf..90a3ad6 100644 --- a/arch/arm/include/asm/arch-at91/at91_pio.h +++ b/arch/arm/include/asm/arch-at91/at91_pio.h @@ -4,6 +4,7 @@ * Copyright (C) 2005 Ivan Kokshaysky * Copyright (C) SAN People * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * Copyright (C) 2011 Hong Xu (hong.xu@atmel.com) * * Parallel I/O Controller (PIO) - System peripherals registers. * Based on AT91RM9200 datasheet revision E. @@ -17,7 +18,6 @@ #ifndef AT91_PIO_H #define AT91_PIO_H
- #define AT91_ASM_PIO_RANGE 0x200 #define AT91_ASM_PIOC_ASR \ (ATMEL_BASE_PIO + AT91_PIO_PORTC * AT91_ASM_PIO_RANGE + 0x70) @@ -66,14 +66,51 @@ typedef struct at91_port { u32 puer; /* 0x64 Pull-up Enable Register */ u32 pusr; /* 0x68 Pad Pull-up Status Register */ u32 reserved4; +#if defined(CONFIG_CPU_HAS_PIO3) + u32 abcdsr1; /* 0x70 Peripheral ABCD Select Register 1 */ + u32 abcdsr2; /* 0x74 Peripheral ABCD Select Register 2 */ + u32 reserved5[2]; + u32 ifscdr; /* 0x80 Input Filter SCLK Disable Register */ + u32 ifscer; /* 0x84 Input Filter SCLK Enable Register */ + u32 ifscsr; /* 0x88 Input Filter SCLK Status Register */ + u32 scdr; /* 0x8C SCLK Divider Debouncing Register */ +#define PIO_SCDR_DIV_MASK (0x3fff << 0) /* Slow Clock Divider Mask */ + u32 ppddr; /* 0x90 Pad Pull-down Disable Register */ + u32 ppder; /* 0x94 Pad Pull-down Enable Register */ + u32 ppdsr; /* 0x98 Pad Pull-down Status Register */ + u32 reserved6; +#else u32 asr; /* 0x70 Select A Register */ u32 bsr; /* 0x74 Select B Register */ u32 absr; /* 0x78 AB Select Status Register */ u32 reserved5[9]; /* */ +#endif u32 ower; /* 0xA0 Output Write Enable Register */ u32 owdr; /* 0xA4 Output Write Disable Register */ - u32 owsr; /* OxA8 utput Write Status Register */ + u32 owsr; /* OxA8 Output Write Status Register */ +#if defined(CONFIG_CPU_HAS_PIO3) + u32 reserved7; /* */ + u32 aimer; /* Additional Interrupt Modes Enable Register*/ + u32 aimdr; /* Additional Interrupt Modes Disable Register*/ + u32 aimmr; /* Additional Intterupt Modes Mask Register */ + u32 reserved8; /* */ + u32 esr; /* 0xC0 Edge Select Register */ + u32 lsr; /* 0xC4 Level Select Register */ + u32 elsr; /* 0xC8 Edge/Level Status Register */ + u32 reserved9; /* 0xCC */ + u32 fellsr; /* 0xD0 Falling Edge/Low Level Select Register*/ + u32 rehlsr; /* 0xD4 Rising Edge/High Level Select Register*/ + u32 frlhsr; /* 0xD8 Fall/Rise - Low/High Status Register */ + u32 reserved10; /* */ + u32 locksr; /* 0xE0 Lock Status */ + u32 wpmr; /* 0xE4 Write Protect Mode Register */ + u32 wpsr; /* 0xE4 Write Protect Status Register */ + u32 reserved11[5]; /* */ + u32 schmitt; /* 0x100 Schmitt Trigger Register */ + u32 reserved12[63]; +#else u32 reserved6[85]; +#endif } at91_port_t;
typedef union at91_pio { @@ -94,6 +131,13 @@ typedef union at91_pio { #ifdef CONFIG_AT91_GPIO int at91_set_a_periph(unsigned port, unsigned pin, int use_pullup); int at91_set_b_periph(unsigned port, unsigned pin, int use_pullup); +#if defined(CONFIG_CPU_HAS_PIO3) +int at91_set_c_periph(unsigned port, unsigned pin, int use_pullup); +int at91_set_d_periph(unsigned port, unsigned pin, int use_pullup); +int at91_set_pio_debounce(unsigned port, unsigned pin, int is_on, int div); +int at91_set_pio_pulldown(unsigned port, unsigned pin, int is_on); +int at91_set_pio_disable_schmitt_trig(unsigned port, unsigned pin); +#endif int at91_set_pio_input(unsigned port, unsigned pin, int use_pullup); int at91_set_pio_multi_drive(unsigned port, unsigned pin, int is_on); int at91_set_pio_output(unsigned port, unsigned pin, int value); diff --git a/drivers/gpio/at91_gpio.c b/drivers/gpio/at91_gpio.c index be2a026..d85f3e3 100644 --- a/drivers/gpio/at91_gpio.c +++ b/drivers/gpio/at91_gpio.c @@ -1,6 +1,8 @@ /* * Memory Setup stuff - taken from blob memsetup.S * + * Copyright (C) 2011 Hong Xu (hong.xu@atmel.com) + * * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) * * Copyright (C) 2005 HP Labs @@ -58,7 +60,7 @@ int at91_set_pio_pullup(unsigned port, unsigned pin, int use_pullup) }
/* - * mux the pin to the "GPIO" peripheral role. + * mux the pin to the "GPIO" peripheral function. */ int at91_set_pio_periph(unsigned port, unsigned pin, int use_pullup) { @@ -75,7 +77,7 @@ int at91_set_pio_periph(unsigned port, unsigned pin, int use_pullup) }
/* - * mux the pin to the "A" internal peripheral role. + * mux the pin to the "A" internal peripheral function. */ int at91_set_a_periph(unsigned port, unsigned pin, int use_pullup) { @@ -86,14 +88,21 @@ int at91_set_a_periph(unsigned port, unsigned pin, int use_pullup) mask = 1 << pin; writel(mask, &pio->port[port].idr); at91_set_pio_pullup(port, pin, use_pullup); +#if defined(CONFIG_CPU_HAS_PIO3) + writel(readl(&pio->port[port].abcdsr1) & ~mask, + &pio->port[port].abcdsr1); + writel(readl(&pio->port[port].abcdsr2) & ~mask, + &pio->port[port].abcdsr2); +#else writel(mask, &pio->port[port].asr); +#endif writel(mask, &pio->port[port].pdr); } return 0; }
/* - * mux the pin to the "B" internal peripheral role. + * mux the pin to the "B" internal peripheral function. */ int at91_set_b_periph(unsigned port, unsigned pin, int use_pullup) { @@ -104,13 +113,120 @@ int at91_set_b_periph(unsigned port, unsigned pin, int use_pullup) mask = 1 << pin; writel(mask, &pio->port[port].idr); at91_set_pio_pullup(port, pin, use_pullup); +#if defined(CONFIG_CPU_HAS_PIO3) + writel(readl(&pio->port[port].abcdsr1) | mask, + &pio->port[port].abcdsr1); + writel(readl(&pio->port[port].abcdsr2) & ~mask, + &pio->port[port].abcdsr2); +#else writel(mask, &pio->port[port].bsr); +#endif + writel(mask, &pio->port[port].pdr); + } + return 0; +} + +#if defined(CONFIG_CPU_HAS_PIO3) +/* + * mux the pin to the "C" internal peripheral function. + */ +int at91_set_c_periph(unsigned port, unsigned pin, int use_pullup) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; + u32 mask; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + mask = 1 << pin; + writel(mask, &pio->port[port].idr); + at91_set_pio_pullup(port, pin, use_pullup); + writel(readl(&pio->port[port].abcdsr1) & ~mask, + &pio->port[port].abcdsr1); + writel(readl(&pio->port[port].abcdsr2) | mask, + &pio->port[port].abcdsr2); writel(mask, &pio->port[port].pdr); } return 0; }
/* + * mux the pin to the "D" internal peripheral function. + */ +int at91_set_d_periph(unsigned port, unsigned pin, int use_pullup) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; + u32 mask; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + mask = 1 << pin; + writel(mask, &pio->port[port].idr); + at91_set_pio_pullup(port, pin, use_pullup); + writel(readl(&pio->port[port].abcdsr1) | mask, + &pio->port[port].abcdsr1); + writel(readl(&pio->port[port].abcdsr2) | mask, + &pio->port[port].abcdsr2); + writel(mask, &pio->port[port].pdr); + } + return 0; +} + +/* + * enable/disable the debounce filter. + */ +int at91_set_pio_debounce(unsigned port, unsigned pin, int is_on, int div) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + if (is_on) { + writel(1 << pin, &pio->port[port].ifscer); + writel(div & PIO_SCDR_DIV_MASK, &pio->port[port].scdr); + writel(1 << pin, &pio->port[port].ifer); + } else { + writel(1 << pin, &pio->port[port].ifdr); + } + } + return 0; +} + +/* + * enable/disable the pull-down. + * If pull-up already enabled while calling the function, we disable it. + */ +int at91_set_pio_pulldown(unsigned port, unsigned pin, int is_pulldown) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + writel(1 << pin, &pio->port[port].pudr); + if (is_pulldown) + writel(1 << pin, &pio->port[port].ppder); + else + writel(1 << pin, &pio->port[port].ppddr); + } + return 0; +} + +/* + * Set Schmitt trigger mode + */ +int at91_set_pio_schmitt_trig(unsigned port, unsigned pin, int is_enabled) +{ + at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; + u32 data; + + if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { + data = readl(&pio->port[port].schmitt); + if (is_enabled) + data &= ~(1 << pin); + else + data |= (1 << pin); + writel(data, &pio->port[port].schmitt); + } + return 0; +} +#endif + +/* * mux the pin to the gpio controller (instead of "A" or "B" peripheral), and * configure it for an input. */ @@ -162,10 +278,14 @@ int at91_set_pio_deglitch(unsigned port, unsigned pin, int is_on)
if ((port < ATMEL_PIO_PORTS) && (pin < 32)) { mask = 1 << pin; - if (is_on) + if (is_on) { +#if defined(CONFIG_CPU_HAS_PIO3) + writel(mask, &pio->port[port].ifscdr); +#endif writel(mask, &pio->port[port].ifer); - else + } else { writel(mask, &pio->port[port].ifdr); + } } return 0; }
Hong Xu
