[U-Boot] [PATCH 1/2] fdtdec: Use fdt_setprop_u32() for fdtdec_set_phandle()
The fdt_setprop_u32() function does everything that we need, so we really only use the function as a convenience wrapper, in which case it can simply be a static inline function.
Signed-off-by: Thierry Reding treding@nvidia.com --- include/fdtdec.h | 5 ++++- lib/fdtdec.c | 7 ------- 2 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index 266c58271f0b..110aa6ab6dea 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -1029,7 +1029,10 @@ int fdtdec_setup_memory_banksize(void); * @param phandle phandle to set for the given node * @return 0 on success or a negative error code on failure */ -int fdtdec_set_phandle(void *blob, int node, uint32_t phandle); +static inline int fdtdec_set_phandle(void *blob, int node, uint32_t phandle) +{ + return fdt_setprop_u32(blob, node, "phandle", phandle); +}
/** * fdtdec_add_reserved_memory() - add or find a reserved-memory node diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 9c9c30234732..fea44a9a8c65 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1261,13 +1261,6 @@ __weak void *board_fdt_blob_setup(void) } #endif
-int fdtdec_set_phandle(void *blob, int node, uint32_t phandle) -{ - fdt32_t value = cpu_to_fdt32(phandle); - - return fdt_setprop(blob, node, "phandle", &value, sizeof(value)); -} - static int fdtdec_init_reserved_memory(void *blob) { int na, ns, node, err;
U-Boot already defines the {upper,lower}_32_bits() macros that have the same purpose. Use the existing macros instead of defining new APIs.
Signed-off-by: Thierry Reding treding@nvidia.com --- include/fdtdec.h | 24 ------------------------ lib/fdtdec.c | 8 ++++++-- lib/fdtdec_test.c | 8 ++++++-- 3 files changed, 12 insertions(+), 28 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index 110aa6ab6dea..fa8e34f6f960 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -24,30 +24,6 @@ typedef phys_addr_t fdt_addr_t; typedef phys_size_t fdt_size_t;
-static inline fdt32_t fdt_addr_unpack(fdt_addr_t addr, fdt32_t *upper) -{ - if (upper) -#ifdef CONFIG_PHYS_64BIT - *upper = addr >> 32; -#else - *upper = 0; -#endif - - return addr; -} - -static inline fdt32_t fdt_size_unpack(fdt_size_t size, fdt32_t *upper) -{ - if (upper) -#ifdef CONFIG_PHYS_64BIT - *upper = size >> 32; -#else - *upper = 0; -#endif - - return size; -} - #ifdef CONFIG_PHYS_64BIT #define FDT_ADDR_T_NONE (-1U) #define fdt_addr_to_cpu(reg) be64_to_cpu(reg) diff --git a/lib/fdtdec.c b/lib/fdtdec.c index fea44a9a8c65..d0ba88897335 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1300,6 +1300,7 @@ int fdtdec_add_reserved_memory(void *blob, const char *basename, fdt32_t cells[4] = {}, *ptr = cells; uint32_t upper, lower, phandle; int parent, node, na, ns, err; + fdt_size_t size; char name[64];
/* create an empty /reserved-memory node if one doesn't exist */ @@ -1340,7 +1341,8 @@ int fdtdec_add_reserved_memory(void *blob, const char *basename, * Unpack the start address and generate the name of the new node * base on the basename and the unit-address. */ - lower = fdt_addr_unpack(carveout->start, &upper); + upper = upper_32_bits(carveout->start); + lower = lower_32_bits(carveout->start);
if (na > 1 && upper > 0) snprintf(name, sizeof(name), "%s@%x,%x", basename, upper, @@ -1374,7 +1376,9 @@ int fdtdec_add_reserved_memory(void *blob, const char *basename, *ptr++ = cpu_to_fdt32(lower);
/* store one or two size cells */ - lower = fdt_size_unpack(carveout->end - carveout->start + 1, &upper); + size = carveout->end - carveout->start + 1; + upper = upper_32_bits(size); + lower = lower_32_bits(size);
if (ns > 1) *ptr++ = cpu_to_fdt32(upper); diff --git a/lib/fdtdec_test.c b/lib/fdtdec_test.c index f6defe16c5a6..1f4f27054057 100644 --- a/lib/fdtdec_test.c +++ b/lib/fdtdec_test.c @@ -155,11 +155,13 @@ static int make_fdt_carveout_device(void *fdt, uint32_t na, uint32_t ns) }; fdt32_t cells[4], *ptr = cells; uint32_t upper, lower; + fdt_size_t size; char name[32]; int offset;
/* store one or two address cells */ - lower = fdt_addr_unpack(carveout.start, &upper); + upper = upper_32_bits(carveout.start); + lower = lower_32_bits(carveout.start);
if (na > 1 && upper > 0) snprintf(name, sizeof(name), "%s@%x,%x", basename, upper, @@ -173,7 +175,9 @@ static int make_fdt_carveout_device(void *fdt, uint32_t na, uint32_t ns) *ptr++ = cpu_to_fdt32(lower);
/* store one or two size cells */ - lower = fdt_size_unpack(carveout.end - carveout.start + 1, &upper); + size = carveout.end - carveout.start + 1; + upper = upper_32_bits(size); + lower = lower_32_bits(size);
Hi Simon,
you picked up patch 1/2 of this set. Did you have any comments on v2, or did you overlook it?
Thierry
- if (upper)
-#else
*upper = 0;
-#endif
- return addr;
- if (upper)
-#else
*upper = 0;
-#endif
- return size;
-- 2.21.0
Hi Thierry,
Hi Simon,
I marked it as superseded.
http://patchwork.ozlabs.org/patch/1085480/
Is that incorrect?
On Mon, May 06, 2019 at 09:52:02PM -0600, Simon Glass wrote:
Hi Thierry,
Hi Simon,
Is that incorrect?
I think I messed up my earlier email. What I meant to say was whether you had any comments on patch 2/2. There's no v2 of this patch and it hasn't been applied. It's also not superseeded by anything. So I think this should still be applied.
Thierry
Hi Simon,
gentle reminder on these. These are the two follow-up patches that you had suggested I make on top of the other fdtdec series that you applied a couple of weeks ago.
Thierry
- @param phandle phandle to set for the given node
- @return 0 on success or a negative error code on failure
- return fdt_setprop_u32(blob, node, "phandle", phandle);
- fdtdec_add_reserved_memory() - add or find a reserved-memory node
static int fdtdec_init_reserved_memory(void *blob) { int na, ns, node, err; -- 2.21.0
Hi Thierry,
Hi Simon,
I think this is applied now?
On Mon, May 06, 2019 at 09:52:00PM -0600, Simon Glass wrote:
Hi Thierry,
Hi Simon,
Yes, I can see this in origin/master now.
Thierry
Thierry Reding
