[U-Boot] [PATCH 0/3 V4] EXYNOS5: Add GPIO numbering feature
Changes in V2: - Enabled CMD_GPIO as suggested by Simon Glass and supported same for EXYNOS5 Changes in V3: - New patch added to rename S5P GPIO definitions to S5P_GPIO - GPIO Table added to calculate the base address of input gpio bank. Changes in V4: - To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them. - Function and table to support gpio command moved to s5p-gpio driver - Rebased on latest u-boot-samsung tree
Rajeshwari Shinde (3): EXYNOS5: Add gpio pin numbering feature S5P: Rename GPIO definitions EXYNOS5: GPIO: Enable GPIO Command for EXYNOS5
arch/arm/cpu/armv7/exynos/pinmux.c | 206 +++++++--------- arch/arm/include/asm/arch-exynos/cpu.h | 10 +- arch/arm/include/asm/arch-exynos/gpio.h | 410 ++++++++++++++++++++++++++++-- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 26 +- board/samsung/goni/goni.c | 4 +- board/samsung/origen/origen.c | 8 +- board/samsung/smdk5250/smdk5250.c | 24 +-- board/samsung/smdkc100/smdkc100.c | 2 +- board/samsung/smdkv310/smdkv310.c | 10 +- board/samsung/trats/trats.c | 16 +- board/samsung/universal_c210/universal.c | 36 ++-- drivers/gpio/s5p_gpio.c | 134 +++++++++- include/configs/exynos5250-dt.h | 1 + 13 files changed, 669 insertions(+), 218 deletions(-)
This patch adds support for gpio pin numbering support on EXYNOS5250 To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them.
Signed-off-by: Leela Krishna Amudala l.krishna@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - none. Changes in V3: - none. Changes in V4: - To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them. - Combined previous patch 1 and 2 into single patch. arch/arm/cpu/armv7/exynos/pinmux.c | 148 +++++------- arch/arm/include/asm/arch-exynos/cpu.h | 10 +- arch/arm/include/asm/arch-exynos/gpio.h | 376 ++++++++++++++++++++++++++++++- board/samsung/smdk5250/smdk5250.c | 24 +-- drivers/gpio/s5p_gpio.c | 65 ++++++- 5 files changed, 508 insertions(+), 115 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index bd499b4..02a4d88 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -29,89 +29,77 @@
static void exynos5_uart_config(int peripheral) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); - struct s5p_gpio_bank *bank; int i, start, count;
switch (peripheral) { case PERIPH_ID_UART0: - bank = &gpio1->a0; - start = 0; + start = EXYNOS5_GPIO_A00; count = 4; break; case PERIPH_ID_UART1: - bank = &gpio1->d0; - start = 0; + start = EXYNOS5_GPIO_D00; count = 4; break; case PERIPH_ID_UART2: - bank = &gpio1->a1; - start = 0; + start = EXYNOS5_GPIO_A10; count = 4; break; case PERIPH_ID_UART3: - bank = &gpio1->a1; - start = 4; + start = EXYNOS5_GPIO_A14; count = 2; break; } for (i = start; i < start + count; i++) { - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + gpio_set_pull(i, GPIO_PULL_NONE); + gpio_cfg_pin(i, GPIO_FUNC(0x2)); } }
static int exynos5_mmc_config(int peripheral, int flags) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); - struct s5p_gpio_bank *bank, *bank_ext; - int i, start = 0, gpio_func = 0; + int i, start, start_ext, gpio_func = 0;
switch (peripheral) { case PERIPH_ID_SDMMC0: - bank = &gpio1->c0; - bank_ext = &gpio1->c1; - start = 0; + start = EXYNOS5_GPIO_C00; + start_ext = EXYNOS5_GPIO_C10; gpio_func = GPIO_FUNC(0x2); break; case PERIPH_ID_SDMMC1: - bank = &gpio1->c2; - bank_ext = NULL; + start = EXYNOS5_GPIO_C20; + start_ext = 0; break; case PERIPH_ID_SDMMC2: - bank = &gpio1->c3; - bank_ext = &gpio1->c4; - start = 3; + start = EXYNOS5_GPIO_C30; + start_ext = EXYNOS5_GPIO_C43; gpio_func = GPIO_FUNC(0x3); break; case PERIPH_ID_SDMMC3: - bank = &gpio1->c4; - bank_ext = NULL; + start = EXYNOS5_GPIO_C40; + start_ext = 0; break; } - if ((flags & PINMUX_FLAG_8BIT_MODE) && !bank_ext) { + if ((flags & PINMUX_FLAG_8BIT_MODE) && !start_ext) { debug("SDMMC device %d does not support 8bit mode", peripheral); return -1; } if (flags & PINMUX_FLAG_8BIT_MODE) { - for (i = start; i <= (start + 3); i++) { - s5p_gpio_cfg_pin(bank_ext, i, gpio_func); - s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_UP); - s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); + for (i = start_ext; i <= (start_ext + 3); i++) { + gpio_cfg_pin(i, gpio_func); + gpio_set_pull(i, GPIO_PULL_UP); + gpio_set_drv(i, GPIO_DRV_4X); } } for (i = 0; i < 2; i++) { - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + gpio_cfg_pin(start + i, GPIO_FUNC(0x2)); + gpio_set_pull(start + i, GPIO_PULL_NONE); + gpio_set_drv(start + i, GPIO_DRV_4X); } for (i = 3; i <= 6; i++) { - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); - s5p_gpio_set_pull(bank, i, GPIO_PULL_UP); - s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + gpio_cfg_pin(start + i, GPIO_FUNC(0x2)); + gpio_set_pull(start + i, GPIO_PULL_UP); + gpio_set_drv(start + i, GPIO_DRV_4X); }
return 0; @@ -119,8 +107,6 @@ static int exynos5_mmc_config(int peripheral, int flags)
static void exynos5_sromc_config(int flags) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); int i;
/* @@ -138,13 +124,13 @@ static void exynos5_sromc_config(int flags) * GPY1[2] SROM_WAIT(2) * GPY1[3] EBI_DATA_RDn(2) */ - s5p_gpio_cfg_pin(&gpio1->y0, (flags & PINMUX_FLAG_BANK), + gpio_cfg_pin(EXYNOS5_GPIO_Y00 + (flags & PINMUX_FLAG_BANK), GPIO_FUNC(2)); - s5p_gpio_cfg_pin(&gpio1->y0, 4, GPIO_FUNC(2)); - s5p_gpio_cfg_pin(&gpio1->y0, 5, GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y04, GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y05, GPIO_FUNC(2));
for (i = 0; i < 4; i++) - s5p_gpio_cfg_pin(&gpio1->y1, i, GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y10 + i, GPIO_FUNC(2));
/* * EBI: 8 Addrss Lines @@ -179,55 +165,52 @@ static void exynos5_sromc_config(int flags) * GPY6[7] EBI_DATA[15](2) */ for (i = 0; i < 8; i++) { - s5p_gpio_cfg_pin(&gpio1->y3, i, GPIO_FUNC(2)); - s5p_gpio_set_pull(&gpio1->y3, i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y30 + i, GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y30 + i, GPIO_PULL_UP);
- s5p_gpio_cfg_pin(&gpio1->y5, i, GPIO_FUNC(2)); - s5p_gpio_set_pull(&gpio1->y5, i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y50 + i, GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y50 + i, GPIO_PULL_UP);
- s5p_gpio_cfg_pin(&gpio1->y6, i, GPIO_FUNC(2)); - s5p_gpio_set_pull(&gpio1->y6, i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y60 + i, GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y60 + i, GPIO_PULL_UP); } }
static void exynos5_i2c_config(int peripheral, int flags) {
- struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); - switch (peripheral) { case PERIPH_ID_I2C0: - s5p_gpio_cfg_pin(&gpio1->b3, 0, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b3, 1, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B30, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B31, GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C1: - s5p_gpio_cfg_pin(&gpio1->b3, 2, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->b3, 3, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B32, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B33, GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C2: - s5p_gpio_cfg_pin(&gpio1->a0, 6, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a0, 7, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A06, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A07, GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C3: - s5p_gpio_cfg_pin(&gpio1->a1, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a1, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A12, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A13, GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C4: - s5p_gpio_cfg_pin(&gpio1->a2, 0, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a2, 1, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A20, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A21, GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C5: - s5p_gpio_cfg_pin(&gpio1->a2, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a2, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A22, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A23, GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C6: - s5p_gpio_cfg_pin(&gpio1->b1, 3, GPIO_FUNC(0x4)); - s5p_gpio_cfg_pin(&gpio1->b1, 4, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_B13, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_B14, GPIO_FUNC(0x4)); break; case PERIPH_ID_I2C7: - s5p_gpio_cfg_pin(&gpio1->b2, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->b2, 3, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_B22, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_B23, GPIO_FUNC(0x3)); break; } } @@ -235,53 +218,42 @@ static void exynos5_i2c_config(int peripheral, int flags) static void exynos5_i2s_config(int peripheral) { int i; - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1();
for (i = 0; i < 5; i++) - s5p_gpio_cfg_pin(&gpio1->b0, i, GPIO_FUNC(0x02)); + gpio_cfg_pin(EXYNOS5_GPIO_B00+i, GPIO_FUNC(0x02)); }
void exynos5_spi_config(int peripheral) { int cfg = 0, pin = 0, i; - struct s5p_gpio_bank *bank = NULL; - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); - struct exynos5_gpio_part2 *gpio2 = - (struct exynos5_gpio_part2 *) samsung_get_base_gpio_part2();
switch (peripheral) { case PERIPH_ID_SPI0: - bank = &gpio1->a2; cfg = GPIO_FUNC(0x2); - pin = 0; + pin = EXYNOS5_GPIO_A20; break; case PERIPH_ID_SPI1: - bank = &gpio1->a2; cfg = GPIO_FUNC(0x2); - pin = 4; + pin = EXYNOS5_GPIO_A24; break; case PERIPH_ID_SPI2: - bank = &gpio1->b1; cfg = GPIO_FUNC(0x5); - pin = 1; + pin = EXYNOS5_GPIO_B11; break; case PERIPH_ID_SPI3: - bank = &gpio2->f1; cfg = GPIO_FUNC(0x2); - pin = 0; + pin = EXYNOS5_GPIO_F10; break; case PERIPH_ID_SPI4: for (i = 0; i < 2; i++) { - s5p_gpio_cfg_pin(&gpio2->f0, i + 2, GPIO_FUNC(0x4)); - s5p_gpio_cfg_pin(&gpio2->e0, i + 4, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_F02 + i, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_E04 + i, GPIO_FUNC(0x4)); } break; } if (peripheral != PERIPH_ID_SPI4) { for (i = pin; i < pin + 4; i++) - s5p_gpio_cfg_pin(bank, i, cfg); + gpio_cfg_pin(i, cfg); } }
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index eb34422..5f08f11 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -99,7 +99,7 @@ /* EXYNOS5 Common*/ #define EXYNOS5_I2C_SPACING 0x10000
-#define EXYNOS5_GPIO_PART4_BASE 0x03860000 +#define EXYNOS5_GPIO_PART8_BASE 0x03860000 #define EXYNOS5_PRO_ID 0x10000000 #define EXYNOS5_CLOCK_BASE 0x10010000 #define EXYNOS5_POWER_BASE 0x10040000 @@ -108,9 +108,13 @@ #define EXYNOS5_WATCHDOG_BASE 0x101D0000 #define EXYNOS5_DMC_PHY0_BASE 0x10C00000 #define EXYNOS5_DMC_PHY1_BASE 0x10C10000 -#define EXYNOS5_GPIO_PART3_BASE 0x10D10000 +#define EXYNOS5_GPIO_PART5_BASE 0x10D10000 +#define EXYNOS5_GPIO_PART6_BASE 0x10D10060 +#define EXYNOS5_GPIO_PART7_BASE 0x10D100C0 #define EXYNOS5_DMC_CTRL_BASE 0x10DD0000 #define EXYNOS5_GPIO_PART1_BASE 0x11400000 +#define EXYNOS5_GPIO_PART2_BASE 0x114002E0 +#define EXYNOS5_GPIO_PART3_BASE 0x11400C00 #define EXYNOS5_MIPI_DSIM_BASE 0x11D00000 #define EXYNOS5_USB_HOST_EHCI_BASE 0x12110000 #define EXYNOS5_USBPHY_BASE 0x12130000 @@ -123,7 +127,7 @@ #define EXYNOS5_I2S_BASE 0x12D60000 #define EXYNOS5_PWMTIMER_BASE 0x12DD0000 #define EXYNOS5_SPI_ISP_BASE 0x131A0000 -#define EXYNOS5_GPIO_PART2_BASE 0x13400000 +#define EXYNOS5_GPIO_PART4_BASE 0x13400000 #define EXYNOS5_FIMD_BASE 0x14400000 #define EXYNOS5_DP_BASE 0x145B0000
diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index cfe1024..e1e59f1 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -161,16 +161,20 @@ struct exynos5_gpio_part1 { struct s5p_gpio_bank y4; struct s5p_gpio_bank y5; struct s5p_gpio_bank y6; - struct s5p_gpio_bank res1[0x3]; +}; + +struct exynos5_gpio_part2 { struct s5p_gpio_bank c4; - struct s5p_gpio_bank res2[0x48]; +}; + +struct exynos5_gpio_part3 { struct s5p_gpio_bank x0; struct s5p_gpio_bank x1; struct s5p_gpio_bank x2; struct s5p_gpio_bank x3; };
-struct exynos5_gpio_part2 { +struct exynos5_gpio_part4 { struct s5p_gpio_bank e0; struct s5p_gpio_bank e1; struct s5p_gpio_bank f0; @@ -182,20 +186,26 @@ struct exynos5_gpio_part2 { struct s5p_gpio_bank h1; };
-struct exynos5_gpio_part3 { +struct exynos5_gpio_part5 { struct s5p_gpio_bank v0; struct s5p_gpio_bank v1; - struct s5p_gpio_bank res1[0x1]; +}; + +struct exynos5_gpio_part6 { struct s5p_gpio_bank v2; struct s5p_gpio_bank v3; - struct s5p_gpio_bank res2[0x1]; +}; + +struct exynos5_gpio_part7 { struct s5p_gpio_bank v4; };
-struct exynos5_gpio_part4 { +struct exynos5_gpio_part8 { struct s5p_gpio_bank z; };
+#define EXYNOS5_GPIO_NUM_PARTS 8 + /* functions */ void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg); void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en); @@ -272,6 +282,352 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode); - EXYNOS5_GPIO_PART3_BASE) / sizeof(struct s5p_gpio_bank)) \ * GPIO_PER_BANK) + pin) + EXYNOS5_GPIO_PART2_MAX)
+/* A list of valid GPIO numbers for the asm-generic/gpio.h interface */ +enum exynos5_gpio_pin { + /* GPIO_PART1_STARTS */ + EXYNOS5_GPIO_A00, + EXYNOS5_GPIO_A01, + EXYNOS5_GPIO_A02, + EXYNOS5_GPIO_A03, + EXYNOS5_GPIO_A04, + EXYNOS5_GPIO_A05, + EXYNOS5_GPIO_A06, + EXYNOS5_GPIO_A07, + EXYNOS5_GPIO_A10, + EXYNOS5_GPIO_A11, + EXYNOS5_GPIO_A12, + EXYNOS5_GPIO_A13, + EXYNOS5_GPIO_A14, + EXYNOS5_GPIO_A15, + EXYNOS5_GPIO_A16, + EXYNOS5_GPIO_A17, + EXYNOS5_GPIO_A20, + EXYNOS5_GPIO_A21, + EXYNOS5_GPIO_A22, + EXYNOS5_GPIO_A23, + EXYNOS5_GPIO_A24, + EXYNOS5_GPIO_A25, + EXYNOS5_GPIO_A26, + EXYNOS5_GPIO_A27, + EXYNOS5_GPIO_B00, + EXYNOS5_GPIO_B01, + EXYNOS5_GPIO_B02, + EXYNOS5_GPIO_B03, + EXYNOS5_GPIO_B04, + EXYNOS5_GPIO_B05, + EXYNOS5_GPIO_B06, + EXYNOS5_GPIO_B07, + EXYNOS5_GPIO_B10, + EXYNOS5_GPIO_B11, + EXYNOS5_GPIO_B12, + EXYNOS5_GPIO_B13, + EXYNOS5_GPIO_B14, + EXYNOS5_GPIO_B15, + EXYNOS5_GPIO_B16, + EXYNOS5_GPIO_B17, + EXYNOS5_GPIO_B20, + EXYNOS5_GPIO_B21, + EXYNOS5_GPIO_B22, + EXYNOS5_GPIO_B23, + EXYNOS5_GPIO_B24, + EXYNOS5_GPIO_B25, + EXYNOS5_GPIO_B26, + EXYNOS5_GPIO_B27, + EXYNOS5_GPIO_B30, + EXYNOS5_GPIO_B31, + EXYNOS5_GPIO_B32, + EXYNOS5_GPIO_B33, + EXYNOS5_GPIO_B34, + EXYNOS5_GPIO_B35, + EXYNOS5_GPIO_B36, + EXYNOS5_GPIO_B37, + EXYNOS5_GPIO_C00, + EXYNOS5_GPIO_C01, + EXYNOS5_GPIO_C02, + EXYNOS5_GPIO_C03, + EXYNOS5_GPIO_C04, + EXYNOS5_GPIO_C05, + EXYNOS5_GPIO_C06, + EXYNOS5_GPIO_C07, + EXYNOS5_GPIO_C10, + EXYNOS5_GPIO_C11, + EXYNOS5_GPIO_C12, + EXYNOS5_GPIO_C13, + EXYNOS5_GPIO_C14, + EXYNOS5_GPIO_C15, + EXYNOS5_GPIO_C16, + EXYNOS5_GPIO_C17, + EXYNOS5_GPIO_C20, + EXYNOS5_GPIO_C21, + EXYNOS5_GPIO_C22, + EXYNOS5_GPIO_C23, + EXYNOS5_GPIO_C24, + EXYNOS5_GPIO_C25, + EXYNOS5_GPIO_C26, + EXYNOS5_GPIO_C27, + EXYNOS5_GPIO_C30, + EXYNOS5_GPIO_C31, + EXYNOS5_GPIO_C32, + EXYNOS5_GPIO_C33, + EXYNOS5_GPIO_C34, + EXYNOS5_GPIO_C35, + EXYNOS5_GPIO_C36, + EXYNOS5_GPIO_C37, + EXYNOS5_GPIO_D00, + EXYNOS5_GPIO_D01, + EXYNOS5_GPIO_D02, + EXYNOS5_GPIO_D03, + EXYNOS5_GPIO_D04, + EXYNOS5_GPIO_D05, + EXYNOS5_GPIO_D06, + EXYNOS5_GPIO_D07, + EXYNOS5_GPIO_D10, + EXYNOS5_GPIO_D11, + EXYNOS5_GPIO_D12, + EXYNOS5_GPIO_D13, + EXYNOS5_GPIO_D14, + EXYNOS5_GPIO_D15, + EXYNOS5_GPIO_D16, + EXYNOS5_GPIO_D17, + EXYNOS5_GPIO_Y00, + EXYNOS5_GPIO_Y01, + EXYNOS5_GPIO_Y02, + EXYNOS5_GPIO_Y03, + EXYNOS5_GPIO_Y04, + EXYNOS5_GPIO_Y05, + EXYNOS5_GPIO_Y06, + EXYNOS5_GPIO_Y07, + EXYNOS5_GPIO_Y10, + EXYNOS5_GPIO_Y11, + EXYNOS5_GPIO_Y12, + EXYNOS5_GPIO_Y13, + EXYNOS5_GPIO_Y14, + EXYNOS5_GPIO_Y15, + EXYNOS5_GPIO_Y16, + EXYNOS5_GPIO_Y17, + EXYNOS5_GPIO_Y20, + EXYNOS5_GPIO_Y21, + EXYNOS5_GPIO_Y22, + EXYNOS5_GPIO_Y23, + EXYNOS5_GPIO_Y24, + EXYNOS5_GPIO_Y25, + EXYNOS5_GPIO_Y26, + EXYNOS5_GPIO_Y27, + EXYNOS5_GPIO_Y30, + EXYNOS5_GPIO_Y31, + EXYNOS5_GPIO_Y32, + EXYNOS5_GPIO_Y33, + EXYNOS5_GPIO_Y34, + EXYNOS5_GPIO_Y35, + EXYNOS5_GPIO_Y36, + EXYNOS5_GPIO_Y37, + EXYNOS5_GPIO_Y40, + EXYNOS5_GPIO_Y41, + EXYNOS5_GPIO_Y42, + EXYNOS5_GPIO_Y43, + EXYNOS5_GPIO_Y44, + EXYNOS5_GPIO_Y45, + EXYNOS5_GPIO_Y46, + EXYNOS5_GPIO_Y47, + EXYNOS5_GPIO_Y50, + EXYNOS5_GPIO_Y51, + EXYNOS5_GPIO_Y52, + EXYNOS5_GPIO_Y53, + EXYNOS5_GPIO_Y54, + EXYNOS5_GPIO_Y55, + EXYNOS5_GPIO_Y56, + EXYNOS5_GPIO_Y57, + EXYNOS5_GPIO_Y60, + EXYNOS5_GPIO_Y61, + EXYNOS5_GPIO_Y62, + EXYNOS5_GPIO_Y63, + EXYNOS5_GPIO_Y64, + EXYNOS5_GPIO_Y65, + EXYNOS5_GPIO_Y66, + EXYNOS5_GPIO_Y67, + + /* GPIO_PART2_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_1, + EXYNOS5_GPIO_C40 = EXYNOS5_GPIO_MAX_PORT_PART_1, + EXYNOS5_GPIO_C41, + EXYNOS5_GPIO_C42, + EXYNOS5_GPIO_C43, + EXYNOS5_GPIO_C44, + EXYNOS5_GPIO_C45, + EXYNOS5_GPIO_C46, + EXYNOS5_GPIO_C47, + + /* GPIO_PART3_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_2, + EXYNOS5_GPIO_X00 = EXYNOS5_GPIO_MAX_PORT_PART_2, + EXYNOS5_GPIO_X01, + EXYNOS5_GPIO_X02, + EXYNOS5_GPIO_X03, + EXYNOS5_GPIO_X04, + EXYNOS5_GPIO_X05, + EXYNOS5_GPIO_X06, + EXYNOS5_GPIO_X07, + EXYNOS5_GPIO_X10, + EXYNOS5_GPIO_X11, + EXYNOS5_GPIO_X12, + EXYNOS5_GPIO_X13, + EXYNOS5_GPIO_X14, + EXYNOS5_GPIO_X15, + EXYNOS5_GPIO_X16, + EXYNOS5_GPIO_X17, + EXYNOS5_GPIO_X20, + EXYNOS5_GPIO_X21, + EXYNOS5_GPIO_X22, + EXYNOS5_GPIO_X23, + EXYNOS5_GPIO_X24, + EXYNOS5_GPIO_X25, + EXYNOS5_GPIO_X26, + EXYNOS5_GPIO_X27, + EXYNOS5_GPIO_X30, + EXYNOS5_GPIO_X31, + EXYNOS5_GPIO_X32, + EXYNOS5_GPIO_X33, + EXYNOS5_GPIO_X34, + EXYNOS5_GPIO_X35, + EXYNOS5_GPIO_X36, + EXYNOS5_GPIO_X37, + + /* GPIO_PART4_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_3, + EXYNOS5_GPIO_E00 = EXYNOS5_GPIO_MAX_PORT_PART_3, + EXYNOS5_GPIO_E01, + EXYNOS5_GPIO_E02, + EXYNOS5_GPIO_E03, + EXYNOS5_GPIO_E04, + EXYNOS5_GPIO_E05, + EXYNOS5_GPIO_E06, + EXYNOS5_GPIO_E07, + EXYNOS5_GPIO_E10, + EXYNOS5_GPIO_E11, + EXYNOS5_GPIO_E12, + EXYNOS5_GPIO_E13, + EXYNOS5_GPIO_E14, + EXYNOS5_GPIO_E15, + EXYNOS5_GPIO_E16, + EXYNOS5_GPIO_E17, + EXYNOS5_GPIO_F00, + EXYNOS5_GPIO_F01, + EXYNOS5_GPIO_F02, + EXYNOS5_GPIO_F03, + EXYNOS5_GPIO_F04, + EXYNOS5_GPIO_F05, + EXYNOS5_GPIO_F06, + EXYNOS5_GPIO_F07, + EXYNOS5_GPIO_F10, + EXYNOS5_GPIO_F11, + EXYNOS5_GPIO_F12, + EXYNOS5_GPIO_F13, + EXYNOS5_GPIO_F14, + EXYNOS5_GPIO_F15, + EXYNOS5_GPIO_F16, + EXYNOS5_GPIO_F17, + EXYNOS5_GPIO_G00, + EXYNOS5_GPIO_G01, + EXYNOS5_GPIO_G02, + EXYNOS5_GPIO_G03, + EXYNOS5_GPIO_G04, + EXYNOS5_GPIO_G05, + EXYNOS5_GPIO_G06, + EXYNOS5_GPIO_G07, + EXYNOS5_GPIO_G10, + EXYNOS5_GPIO_G11, + EXYNOS5_GPIO_G12, + EXYNOS5_GPIO_G13, + EXYNOS5_GPIO_G14, + EXYNOS5_GPIO_G15, + EXYNOS5_GPIO_G16, + EXYNOS5_GPIO_G17, + EXYNOS5_GPIO_G20, + EXYNOS5_GPIO_G21, + EXYNOS5_GPIO_G22, + EXYNOS5_GPIO_G23, + EXYNOS5_GPIO_G24, + EXYNOS5_GPIO_G25, + EXYNOS5_GPIO_G26, + EXYNOS5_GPIO_G27, + EXYNOS5_GPIO_H00, + EXYNOS5_GPIO_H01, + EXYNOS5_GPIO_H02, + EXYNOS5_GPIO_H03, + EXYNOS5_GPIO_H04, + EXYNOS5_GPIO_H05, + EXYNOS5_GPIO_H06, + EXYNOS5_GPIO_H07, + EXYNOS5_GPIO_H10, + EXYNOS5_GPIO_H11, + EXYNOS5_GPIO_H12, + EXYNOS5_GPIO_H13, + EXYNOS5_GPIO_H14, + EXYNOS5_GPIO_H15, + EXYNOS5_GPIO_H16, + EXYNOS5_GPIO_H17, + + /* GPIO_PART4_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_4, + EXYNOS5_GPIO_V00 = EXYNOS5_GPIO_MAX_PORT_PART_4, + EXYNOS5_GPIO_V01, + EXYNOS5_GPIO_V02, + EXYNOS5_GPIO_V03, + EXYNOS5_GPIO_V04, + EXYNOS5_GPIO_V05, + EXYNOS5_GPIO_V06, + EXYNOS5_GPIO_V07, + EXYNOS5_GPIO_V10, + EXYNOS5_GPIO_V11, + EXYNOS5_GPIO_V12, + EXYNOS5_GPIO_V13, + EXYNOS5_GPIO_V14, + EXYNOS5_GPIO_V15, + EXYNOS5_GPIO_V16, + EXYNOS5_GPIO_V17, + + /* GPIO_PART5_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_5, + EXYNOS5_GPIO_V20 = EXYNOS5_GPIO_MAX_PORT_PART_5, + EXYNOS5_GPIO_V21, + EXYNOS5_GPIO_V22, + EXYNOS5_GPIO_V23, + EXYNOS5_GPIO_V24, + EXYNOS5_GPIO_V25, + EXYNOS5_GPIO_V26, + EXYNOS5_GPIO_V27, + EXYNOS5_GPIO_V30, + EXYNOS5_GPIO_V31, + EXYNOS5_GPIO_V32, + EXYNOS5_GPIO_V33, + EXYNOS5_GPIO_V34, + EXYNOS5_GPIO_V35, + EXYNOS5_GPIO_V36, + EXYNOS5_GPIO_V37, + + /* GPIO_PART6_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_6, + EXYNOS5_GPIO_V40 = EXYNOS5_GPIO_MAX_PORT_PART_6, + EXYNOS5_GPIO_V41, + EXYNOS5_GPIO_V42, + EXYNOS5_GPIO_V43, + EXYNOS5_GPIO_V44, + EXYNOS5_GPIO_V45, + EXYNOS5_GPIO_V46, + EXYNOS5_GPIO_V47, + + /* GPIO_PART6_STARTS */ + EXYNOS5_GPIO_MAX_PORT_PART_7, + EXYNOS5_GPIO_Z0 = EXYNOS5_GPIO_MAX_PORT_PART_7, + EXYNOS5_GPIO_Z1, + EXYNOS5_GPIO_Z2, + EXYNOS5_GPIO_Z3, + EXYNOS5_GPIO_Z4, + EXYNOS5_GPIO_Z5, + EXYNOS5_GPIO_Z6, + EXYNOS5_GPIO_MAX_PORT +}; + static inline unsigned int s5p_gpio_base(int nr) { if (cpu_is_exynos5()) { @@ -311,6 +667,12 @@ static inline unsigned int s5p_gpio_part_max(int nr)
return 0; } + +void gpio_cfg_pin(int gpio, int cfg); +void gpio_set_pull(int gpio, int mode); +void gpio_set_drv(int gpio, int mode); +int gpio_direction_output(unsigned gpio, int value); +int gpio_set_value(unsigned gpio, int value); #endif
/* Pin configurations */ diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index 217c6df..f58237f 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -73,11 +73,8 @@ static void boot_temp_check(void) #ifdef CONFIG_USB_EHCI_EXYNOS int board_usb_vbus_init(void) { - struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) - samsung_get_base_gpio_part1(); - /* Enable VBUS power switch */ - s5p_gpio_direction_output(&gpio1->x2, 6, 1); + gpio_direction_output(EXYNOS5_GPIO_X26, 1);
/* VBUS turn ON time */ mdelay(3); @@ -89,12 +86,9 @@ int board_usb_vbus_init(void) #ifdef CONFIG_SOUND_MAX98095 static void board_enable_audio_codec(void) { - struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) - samsung_get_base_gpio_part1(); - /* Enable MAX98095 Codec */ - s5p_gpio_direction_output(&gpio1->x1, 7, 1); - s5p_gpio_set_pull(&gpio1->x1, 7, GPIO_PULL_NONE); + gpio_direction_output(EXYNOS5_GPIO_X17, 1); + gpio_set_pull(EXYNOS5_GPIO_X17, GPIO_PULL_NONE); } #endif
@@ -456,19 +450,17 @@ int board_early_init_f(void) #ifdef CONFIG_LCD void cfg_lcd_gpio(void) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1();
/* For Backlight */ - s5p_gpio_cfg_pin(&gpio1->b2, 0, GPIO_OUTPUT); - s5p_gpio_set_value(&gpio1->b2, 0, 1); + gpio_cfg_pin(EXYNOS5_GPIO_B20, GPIO_OUTPUT); + gpio_set_value(EXYNOS5_GPIO_B20, 1);
/* LCD power on */ - s5p_gpio_cfg_pin(&gpio1->x1, 5, GPIO_OUTPUT); - s5p_gpio_set_value(&gpio1->x1, 5, 1); + gpio_cfg_pin(EXYNOS5_GPIO_X15, GPIO_OUTPUT); + gpio_set_value(EXYNOS5_GPIO_X15, 1);
/* Set Hotplug detect for DP */ - s5p_gpio_cfg_pin(&gpio1->x0, 7, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_X07, GPIO_FUNC(0x3)); }
vidinfo_t panel_info = { diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 656bf4a..1b882cb 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -36,6 +36,27 @@ #define RATE_MASK(x) (0x1 << (x + 16)) #define RATE_SET(x) (0x1 << (x + 16))
+ +struct gpio_info { + unsigned int reg_addr; /* Address of register for this part */ + unsigned int max_gpio; /* Maximum GPIO in this part */ +}; + +#ifdef CONFIG_EXYNOS5 +static const struct gpio_info gpio_data[EXYNOS5_GPIO_NUM_PARTS] = { + { EXYNOS5_GPIO_PART1_BASE, EXYNOS5_GPIO_MAX_PORT_PART_1 }, + { EXYNOS5_GPIO_PART2_BASE, EXYNOS5_GPIO_MAX_PORT_PART_2 }, + { EXYNOS5_GPIO_PART3_BASE, EXYNOS5_GPIO_MAX_PORT_PART_3 }, + { EXYNOS5_GPIO_PART4_BASE, EXYNOS5_GPIO_MAX_PORT_PART_4 }, + { EXYNOS5_GPIO_PART5_BASE, EXYNOS5_GPIO_MAX_PORT_PART_5 }, + { EXYNOS5_GPIO_PART6_BASE, EXYNOS5_GPIO_MAX_PORT_PART_6 }, + { EXYNOS5_GPIO_PART7_BASE, EXYNOS5_GPIO_MAX_PORT_PART_7 }, + { EXYNOS5_GPIO_PART8_BASE, EXYNOS5_GPIO_MAX_PORT }, +}; + +#define HAVE_GENERIC_GPIO +#endif + void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) { unsigned int value; @@ -141,7 +162,30 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode)
writel(value, &bank->drv); } - +#ifdef HAVE_GENERIC_GPIO +static struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned int gpio) +{ + const struct gpio_info *data; + unsigned int upto; + int i; + + for (i = upto = 0, data = gpio_data; i < EXYNOS5_GPIO_NUM_PARTS; + i++, upto = data->max_gpio, data++) { + debug("i=%d, upto=%d\n", i, upto); + if (gpio < data->max_gpio) { + struct s5p_gpio_bank *bank; + bank = (struct s5p_gpio_bank *)data->reg_addr; + bank += (gpio - upto) / GPIO_PER_BANK; + debug(" gpio=%d, bank=%p\n", gpio, bank); + return bank; + } + } +#ifndef CONFIG_SPL_BUILD + assert(gpio < EXYNOS5_GPIO_MAX_PORT); /* ...which it will not be */ +#endif + return NULL; +} +#else struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned gpio) { int bank; @@ -151,6 +195,7 @@ struct s5p_gpio_bank *s5p_gpio_get_bank(unsigned gpio) bank *= sizeof(struct s5p_gpio_bank); return (struct s5p_gpio_bank *) (s5p_gpio_base(gpio) + bank); } +#endif
int s5p_gpio_get_pin(unsigned gpio) { @@ -196,3 +241,21 @@ int gpio_set_value(unsigned gpio, int value)
return 0; } + +void gpio_set_pull(int gpio, int mode) +{ + s5p_gpio_set_pull(s5p_gpio_get_bank(gpio), + s5p_gpio_get_pin(gpio), mode); +} + +void gpio_set_drv(int gpio, int mode) +{ + s5p_gpio_set_drv(s5p_gpio_get_bank(gpio), + s5p_gpio_get_pin(gpio), mode); +} + +void gpio_cfg_pin(int gpio, int cfg) +{ + s5p_gpio_cfg_pin(s5p_gpio_get_bank(gpio), + s5p_gpio_get_pin(gpio), cfg); +}
+struct gpio_info {
- unsigned int reg_addr; /* Address of register for this part */
- unsigned int max_gpio; /* Maximum GPIO in this part */
I think, this ifdef is unnecessary.
maybe it should be exynos5_gpio_data?
- { EXYNOS5_GPIO_PART1_BASE, EXYNOS5_GPIO_MAX_PORT_PART_1 },
- { EXYNOS5_GPIO_PART2_BASE, EXYNOS5_GPIO_MAX_PORT_PART_2 },
- { EXYNOS5_GPIO_PART3_BASE, EXYNOS5_GPIO_MAX_PORT_PART_3 },
- { EXYNOS5_GPIO_PART4_BASE, EXYNOS5_GPIO_MAX_PORT_PART_4 },
- { EXYNOS5_GPIO_PART5_BASE, EXYNOS5_GPIO_MAX_PORT_PART_5 },
- { EXYNOS5_GPIO_PART6_BASE, EXYNOS5_GPIO_MAX_PORT_PART_6 },
- { EXYNOS5_GPIO_PART7_BASE, EXYNOS5_GPIO_MAX_PORT_PART_7 },
- { EXYNOS5_GPIO_PART8_BASE, EXYNOS5_GPIO_MAX_PORT },
please consider exynos4 also.
- const struct gpio_info *data;
- unsigned int upto;
- int i;
- for (i = upto = 0, data = gpio_data; i < EXYNOS5_GPIO_NUM_PARTS;
return bank;
- assert(gpio < EXYNOS5_GPIO_MAX_PORT); /* ...which it will not be */
- return NULL;
return 0; }
- s5p_gpio_set_pull(s5p_gpio_get_bank(gpio),
- s5p_gpio_set_drv(s5p_gpio_get_bank(gpio),
- s5p_gpio_cfg_pin(s5p_gpio_get_bank(gpio),
Thanks, Minkyu Kang.
Hi Minkyu Kang,
Thank you for comments.
+struct gpio_info {
I had put this #ifdef as EXYNOS4 will also have a gpio_data structure.
No kept it as gpio_data as it would b easy to call the same from s5p_gpio_get_bank function and exynos4 will also have a separate structure.
Yes will update the same for exynos4 and send as soon as possible.
unsigned int upto;
int i;
return bank;
return NULL;
Thanks, Minkyu Kang. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Rajeshwari Birje,
On 02/04/13 14:08, Rajeshwari Birje wrote:
Hi Minkyu Kang,
+struct gpio_info {
Exynos doesn't allow ifdefs on own drivers. Please don't use it.
I suggest that make two structure exynos5_gpio_data and exynos4_gpio_data, and please remove ifdef.
So, please modify this function and resend.
unsigned int upto;
int i;
here. EXYNOS5 stuff.
return bank;
return NULL;
This patch rename GPIO definitions from GPIO_... to S5P_GPIO_... This changes was done to enable cmd_gpio for EXYNOS and cmd_gpio has GPIO_INPUT same as s5p_gpio driver and hence getting a error during compilation.
Build tested for s5p_goni, origen, smdk5250, s5pc210_universal, trats, smdkc100, smdkv310 config files.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Chnages in V3: - New Patch Changes in V4: - None arch/arm/cpu/armv7/exynos/pinmux.c | 134 +++++++++++++++--------------- arch/arm/include/asm/arch-exynos/gpio.h | 26 +++--- arch/arm/include/asm/arch-s5pc1xx/gpio.h | 26 +++--- board/samsung/goni/goni.c | 4 +- board/samsung/origen/origen.c | 8 +- board/samsung/smdk5250/smdk5250.c | 8 +- board/samsung/smdkc100/smdkc100.c | 2 +- board/samsung/smdkv310/smdkv310.c | 10 +- board/samsung/trats/trats.c | 16 ++-- board/samsung/universal_c210/universal.c | 36 ++++---- drivers/gpio/s5p_gpio.c | 20 ++-- 11 files changed, 145 insertions(+), 145 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 02a4d88..1e7d14c 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -50,8 +50,8 @@ static void exynos5_uart_config(int peripheral) break; } for (i = start; i < start + count; i++) { - gpio_set_pull(i, GPIO_PULL_NONE); - gpio_cfg_pin(i, GPIO_FUNC(0x2)); + gpio_set_pull(i, S5P_GPIO_PULL_NONE); + gpio_cfg_pin(i, S5P_GPIO_FUNC(0x2)); } }
@@ -63,7 +63,7 @@ static int exynos5_mmc_config(int peripheral, int flags) case PERIPH_ID_SDMMC0: start = EXYNOS5_GPIO_C00; start_ext = EXYNOS5_GPIO_C10; - gpio_func = GPIO_FUNC(0x2); + gpio_func = S5P_GPIO_FUNC(0x2); break; case PERIPH_ID_SDMMC1: start = EXYNOS5_GPIO_C20; @@ -72,7 +72,7 @@ static int exynos5_mmc_config(int peripheral, int flags) case PERIPH_ID_SDMMC2: start = EXYNOS5_GPIO_C30; start_ext = EXYNOS5_GPIO_C43; - gpio_func = GPIO_FUNC(0x3); + gpio_func = S5P_GPIO_FUNC(0x3); break; case PERIPH_ID_SDMMC3: start = EXYNOS5_GPIO_C40; @@ -87,19 +87,19 @@ static int exynos5_mmc_config(int peripheral, int flags) if (flags & PINMUX_FLAG_8BIT_MODE) { for (i = start_ext; i <= (start_ext + 3); i++) { gpio_cfg_pin(i, gpio_func); - gpio_set_pull(i, GPIO_PULL_UP); - gpio_set_drv(i, GPIO_DRV_4X); + gpio_set_pull(i, S5P_GPIO_PULL_UP); + gpio_set_drv(i, S5P_GPIO_DRV_4X); } } for (i = 0; i < 2; i++) { - gpio_cfg_pin(start + i, GPIO_FUNC(0x2)); - gpio_set_pull(start + i, GPIO_PULL_NONE); - gpio_set_drv(start + i, GPIO_DRV_4X); + gpio_cfg_pin(start + i, S5P_GPIO_FUNC(0x2)); + gpio_set_pull(start + i, S5P_GPIO_PULL_NONE); + gpio_set_drv(start + i, S5P_GPIO_DRV_4X); } for (i = 3; i <= 6; i++) { - gpio_cfg_pin(start + i, GPIO_FUNC(0x2)); - gpio_set_pull(start + i, GPIO_PULL_UP); - gpio_set_drv(start + i, GPIO_DRV_4X); + gpio_cfg_pin(start + i, S5P_GPIO_FUNC(0x2)); + gpio_set_pull(start + i, S5P_GPIO_PULL_UP); + gpio_set_drv(start + i, S5P_GPIO_DRV_4X); }
return 0; @@ -125,12 +125,12 @@ static void exynos5_sromc_config(int flags) * GPY1[3] EBI_DATA_RDn(2) */ gpio_cfg_pin(EXYNOS5_GPIO_Y00 + (flags & PINMUX_FLAG_BANK), - GPIO_FUNC(2)); - gpio_cfg_pin(EXYNOS5_GPIO_Y04, GPIO_FUNC(2)); - gpio_cfg_pin(EXYNOS5_GPIO_Y05, GPIO_FUNC(2)); + S5P_GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y04, S5P_GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y05, S5P_GPIO_FUNC(2));
for (i = 0; i < 4; i++) - gpio_cfg_pin(EXYNOS5_GPIO_Y10 + i, GPIO_FUNC(2)); + gpio_cfg_pin(EXYNOS5_GPIO_Y10 + i, S5P_GPIO_FUNC(2));
/* * EBI: 8 Addrss Lines @@ -165,14 +165,14 @@ static void exynos5_sromc_config(int flags) * GPY6[7] EBI_DATA[15](2) */ for (i = 0; i < 8; i++) { - gpio_cfg_pin(EXYNOS5_GPIO_Y30 + i, GPIO_FUNC(2)); - gpio_set_pull(EXYNOS5_GPIO_Y30 + i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y30 + i, S5P_GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y30 + i, S5P_GPIO_PULL_UP);
- gpio_cfg_pin(EXYNOS5_GPIO_Y50 + i, GPIO_FUNC(2)); - gpio_set_pull(EXYNOS5_GPIO_Y50 + i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y50 + i, S5P_GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y50 + i, S5P_GPIO_PULL_UP);
- gpio_cfg_pin(EXYNOS5_GPIO_Y60 + i, GPIO_FUNC(2)); - gpio_set_pull(EXYNOS5_GPIO_Y60 + i, GPIO_PULL_UP); + gpio_cfg_pin(EXYNOS5_GPIO_Y60 + i, S5P_GPIO_FUNC(2)); + gpio_set_pull(EXYNOS5_GPIO_Y60 + i, S5P_GPIO_PULL_UP); } }
@@ -181,36 +181,36 @@ static void exynos5_i2c_config(int peripheral, int flags)
switch (peripheral) { case PERIPH_ID_I2C0: - gpio_cfg_pin(EXYNOS5_GPIO_B30, GPIO_FUNC(0x2)); - gpio_cfg_pin(EXYNOS5_GPIO_B31, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B30, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B31, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C1: - gpio_cfg_pin(EXYNOS5_GPIO_B32, GPIO_FUNC(0x2)); - gpio_cfg_pin(EXYNOS5_GPIO_B33, GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B32, S5P_GPIO_FUNC(0x2)); + gpio_cfg_pin(EXYNOS5_GPIO_B33, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C2: - gpio_cfg_pin(EXYNOS5_GPIO_A06, GPIO_FUNC(0x3)); - gpio_cfg_pin(EXYNOS5_GPIO_A07, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A06, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A07, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C3: - gpio_cfg_pin(EXYNOS5_GPIO_A12, GPIO_FUNC(0x3)); - gpio_cfg_pin(EXYNOS5_GPIO_A13, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A12, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A13, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C4: - gpio_cfg_pin(EXYNOS5_GPIO_A20, GPIO_FUNC(0x3)); - gpio_cfg_pin(EXYNOS5_GPIO_A21, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A20, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A21, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C5: - gpio_cfg_pin(EXYNOS5_GPIO_A22, GPIO_FUNC(0x3)); - gpio_cfg_pin(EXYNOS5_GPIO_A23, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A22, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_A23, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C6: - gpio_cfg_pin(EXYNOS5_GPIO_B13, GPIO_FUNC(0x4)); - gpio_cfg_pin(EXYNOS5_GPIO_B14, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_B13, S5P_GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_B14, S5P_GPIO_FUNC(0x4)); break; case PERIPH_ID_I2C7: - gpio_cfg_pin(EXYNOS5_GPIO_B22, GPIO_FUNC(0x3)); - gpio_cfg_pin(EXYNOS5_GPIO_B23, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_B22, S5P_GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_B23, S5P_GPIO_FUNC(0x3)); break; } } @@ -220,7 +220,7 @@ static void exynos5_i2s_config(int peripheral) int i;
for (i = 0; i < 5; i++) - gpio_cfg_pin(EXYNOS5_GPIO_B00+i, GPIO_FUNC(0x02)); + gpio_cfg_pin(EXYNOS5_GPIO_B00+i, S5P_GPIO_FUNC(0x02)); }
void exynos5_spi_config(int peripheral) @@ -229,25 +229,25 @@ void exynos5_spi_config(int peripheral)
switch (peripheral) { case PERIPH_ID_SPI0: - cfg = GPIO_FUNC(0x2); + cfg = S5P_GPIO_FUNC(0x2); pin = EXYNOS5_GPIO_A20; break; case PERIPH_ID_SPI1: - cfg = GPIO_FUNC(0x2); + cfg = S5P_GPIO_FUNC(0x2); pin = EXYNOS5_GPIO_A24; break; case PERIPH_ID_SPI2: - cfg = GPIO_FUNC(0x5); + cfg = S5P_GPIO_FUNC(0x5); pin = EXYNOS5_GPIO_B11; break; case PERIPH_ID_SPI3: - cfg = GPIO_FUNC(0x2); + cfg = S5P_GPIO_FUNC(0x2); pin = EXYNOS5_GPIO_F10; break; case PERIPH_ID_SPI4: for (i = 0; i < 2; i++) { - gpio_cfg_pin(EXYNOS5_GPIO_F02 + i, GPIO_FUNC(0x4)); - gpio_cfg_pin(EXYNOS5_GPIO_E04 + i, GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_F02 + i, S5P_GPIO_FUNC(0x4)); + gpio_cfg_pin(EXYNOS5_GPIO_E04 + i, S5P_GPIO_FUNC(0x4)); } break; } @@ -309,36 +309,36 @@ static void exynos4_i2c_config(int peripheral, int flags)
switch (peripheral) { case PERIPH_ID_I2C0: - s5p_gpio_cfg_pin(&gpio1->d1, 0, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->d1, 1, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->d1, 0, S5P_GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->d1, 1, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C1: - s5p_gpio_cfg_pin(&gpio1->d1, 2, GPIO_FUNC(0x2)); - s5p_gpio_cfg_pin(&gpio1->d1, 3, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->d1, 2, S5P_GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio1->d1, 3, S5P_GPIO_FUNC(0x2)); break; case PERIPH_ID_I2C2: - s5p_gpio_cfg_pin(&gpio1->a0, 6, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a0, 7, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a0, 6, S5P_GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a0, 7, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C3: - s5p_gpio_cfg_pin(&gpio1->a1, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->a1, 3, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a1, 2, S5P_GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->a1, 3, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C4: - s5p_gpio_cfg_pin(&gpio1->b, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->b, 3, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->b, 2, S5P_GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->b, 3, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C5: - s5p_gpio_cfg_pin(&gpio1->b, 6, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->b, 7, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->b, 6, S5P_GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->b, 7, S5P_GPIO_FUNC(0x3)); break; case PERIPH_ID_I2C6: - s5p_gpio_cfg_pin(&gpio1->c1, 3, GPIO_FUNC(0x4)); - s5p_gpio_cfg_pin(&gpio1->c1, 4, GPIO_FUNC(0x4)); + s5p_gpio_cfg_pin(&gpio1->c1, 3, S5P_GPIO_FUNC(0x4)); + s5p_gpio_cfg_pin(&gpio1->c1, 4, S5P_GPIO_FUNC(0x4)); break; case PERIPH_ID_I2C7: - s5p_gpio_cfg_pin(&gpio1->d0, 2, GPIO_FUNC(0x3)); - s5p_gpio_cfg_pin(&gpio1->d0, 3, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->d0, 2, S5P_GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(&gpio1->d0, 3, S5P_GPIO_FUNC(0x3)); break; } } @@ -365,15 +365,15 @@ static int exynos4_mmc_config(int peripheral, int flags) for (i = 0; i < 7; i++) { if (i == 2) continue; - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); - s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); - s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); + s5p_gpio_cfg_pin(bank, i, S5P_GPIO_FUNC(0x2)); + s5p_gpio_set_pull(bank, i, S5P_GPIO_PULL_NONE); + s5p_gpio_set_drv(bank, i, S5P_GPIO_DRV_4X); } if (flags & PINMUX_FLAG_8BIT_MODE) { for (i = 3; i < 7; i++) { - s5p_gpio_cfg_pin(bank_ext, i, GPIO_FUNC(0x3)); - s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_NONE); - s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); + s5p_gpio_cfg_pin(bank_ext, i, S5P_GPIO_FUNC(0x3)); + s5p_gpio_set_pull(bank_ext, i, S5P_GPIO_PULL_NONE); + s5p_gpio_set_drv(bank_ext, i, S5P_GPIO_DRV_4X); } }
diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index e1e59f1..0b8e35e 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -676,21 +676,21 @@ int gpio_set_value(unsigned gpio, int value); #endif
/* Pin configurations */ -#define GPIO_INPUT 0x0 -#define GPIO_OUTPUT 0x1 -#define GPIO_IRQ 0xf -#define GPIO_FUNC(x) (x) +#define S5P_GPIO_INPUT 0x0 +#define S5P_GPIO_OUTPUT 0x1 +#define S5P_GPIO_IRQ 0xf +#define S5P_GPIO_FUNC(x) (x)
/* Pull mode */ -#define GPIO_PULL_NONE 0x0 -#define GPIO_PULL_DOWN 0x1 -#define GPIO_PULL_UP 0x3 +#define S5P_GPIO_PULL_NONE 0x0 +#define S5P_GPIO_PULL_DOWN 0x1 +#define S5P_GPIO_PULL_UP 0x3
/* Drive Strength level */ -#define GPIO_DRV_1X 0x0 -#define GPIO_DRV_3X 0x1 -#define GPIO_DRV_2X 0x2 -#define GPIO_DRV_4X 0x3 -#define GPIO_DRV_FAST 0x0 -#define GPIO_DRV_SLOW 0x1 +#define S5P_GPIO_DRV_1X 0x0 +#define S5P_GPIO_DRV_3X 0x1 +#define S5P_GPIO_DRV_2X 0x2 +#define S5P_GPIO_DRV_4X 0x3 +#define S5P_GPIO_DRV_FAST 0x0 +#define S5P_GPIO_DRV_SLOW 0x1 #endif diff --git a/arch/arm/include/asm/arch-s5pc1xx/gpio.h b/arch/arm/include/asm/arch-s5pc1xx/gpio.h index 00e498d..e0605a2 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/gpio.h +++ b/arch/arm/include/asm/arch-s5pc1xx/gpio.h @@ -155,22 +155,22 @@ static inline unsigned int s5p_gpio_part_max(int nr) #endif
/* Pull mode */ -#define GPIO_PULL_NONE 0x0 -#define GPIO_PULL_DOWN 0x1 -#define GPIO_PULL_UP 0x2 +#define S5P_GPIO_PULL_NONE 0x0 +#define S5P_GPIO_PULL_DOWN 0x1 +#define S5P_GPIO_PULL_UP 0x2
#endif diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index ff76963..daa0faa 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -102,9 +102,9 @@ int board_mmc_init(bd_t *bis) /* GPG0[0:6] special function 2 */ s5p_gpio_cfg_pin(&s5pc110_gpio->g0, i, 0x2); /* GPG0[0:6] pull disable */ - s5p_gpio_set_pull(&s5pc110_gpio->g0, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&s5pc110_gpio->g0, i, S5P_GPIO_PULL_NONE); /* GPG0[0:6] drv 4x */ - s5p_gpio_set_drv(&s5pc110_gpio->g0, i, GPIO_DRV_4X); + s5p_gpio_set_drv(&s5pc110_gpio->g0, i, S5P_GPIO_DRV_4X); }
return s5p_mmc_init(0, 4); diff --git a/board/samsung/origen/origen.c b/board/samsung/origen/origen.c index 638e7b1..1c82ac6 100644 --- a/board/samsung/origen/origen.c +++ b/board/samsung/origen/origen.c @@ -88,19 +88,19 @@ int board_mmc_init(bd_t *bis) */ for (i = 0; i < 7; i++) { /* GPK2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio2->k2, i, S5P_GPIO_FUNC(0x2));
/* GPK2[0:6] drv 4x */ - s5p_gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); + s5p_gpio_set_drv(&gpio2->k2, i, S5P_GPIO_DRV_4X);
/* GPK2[0:1] pull disable */ if (i == 0 || i == 1) { - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio2->k2, i, S5P_GPIO_PULL_NONE); continue; }
/* GPK2[2:6] pull up */ - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); + s5p_gpio_set_pull(&gpio2->k2, i, S5P_GPIO_PULL_UP); }
err = s5p_mmc_init(2, 4); diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index f58237f..61e721b 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -88,7 +88,7 @@ static void board_enable_audio_codec(void) { /* Enable MAX98095 Codec */ gpio_direction_output(EXYNOS5_GPIO_X17, 1); - gpio_set_pull(EXYNOS5_GPIO_X17, GPIO_PULL_NONE); + gpio_set_pull(EXYNOS5_GPIO_X17, S5P_GPIO_PULL_NONE); } #endif
@@ -452,15 +452,15 @@ void cfg_lcd_gpio(void) {
/* For Backlight */ - gpio_cfg_pin(EXYNOS5_GPIO_B20, GPIO_OUTPUT); + gpio_cfg_pin(EXYNOS5_GPIO_B20, S5P_GPIO_OUTPUT); gpio_set_value(EXYNOS5_GPIO_B20, 1);
/* LCD power on */ - gpio_cfg_pin(EXYNOS5_GPIO_X15, GPIO_OUTPUT); + gpio_cfg_pin(EXYNOS5_GPIO_X15, S5P_GPIO_OUTPUT); gpio_set_value(EXYNOS5_GPIO_X15, 1);
/* Set Hotplug detect for DP */ - gpio_cfg_pin(EXYNOS5_GPIO_X07, GPIO_FUNC(0x3)); + gpio_cfg_pin(EXYNOS5_GPIO_X07, S5P_GPIO_FUNC(0x3)); }
vidinfo_t panel_info = { diff --git a/board/samsung/smdkc100/smdkc100.c b/board/samsung/smdkc100/smdkc100.c index c41e610..87a8f5a 100644 --- a/board/samsung/smdkc100/smdkc100.c +++ b/board/samsung/smdkc100/smdkc100.c @@ -41,7 +41,7 @@ static void smc9115_pre_init(void) (struct s5pc100_gpio *)samsung_get_base_gpio();
/* gpio configuration GPK0CON */ - s5p_gpio_cfg_pin(&gpio->k0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio->k0, CONFIG_ENV_SROM_BANK, S5P_GPIO_FUNC(2));
/* Ethernet needs bus width of 16 bits */ smc_bw_conf = SMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK); diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index 81ac8f6..24e8f18 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -37,7 +37,7 @@ static void smc9115_pre_init(void) u32 smc_bw_conf, smc_bc_conf;
/* gpio configuration GPK0CON */ - s5p_gpio_cfg_pin(&gpio2->y0, CONFIG_ENV_SROM_BANK, GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio2->y0, CONFIG_ENV_SROM_BANK, S5P_GPIO_FUNC(2));
/* Ethernet needs bus width of 16 bits */ smc_bw_conf = SROMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK); @@ -119,19 +119,19 @@ int board_mmc_init(bd_t *bis) */ for (i = 0; i < 7; i++) { /* GPK2[0:6] special function 2 */ - s5p_gpio_cfg_pin(&gpio2->k2, i, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(&gpio2->k2, i, S5P_GPIO_FUNC(0x2));
/* GPK2[2:6] pull up */ - s5p_gpio_set_pull(&gpio2->k2, i, GPIO_PULL_UP); + s5p_gpio_set_pull(&gpio2->k2, i, S5P_GPIO_PULL_UP); } err = s5p_mmc_init(2, 4); return err; diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 88d193d..13f4930 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -390,8 +390,8 @@ static unsigned int get_hw_revision(void)
/* hw_rev[3:0] == GPE1[3:0] */ for (i = 0; i < 4; i++) { - s5p_gpio_cfg_pin(&gpio->e1, i, GPIO_INPUT); - s5p_gpio_set_pull(&gpio->e1, i, GPIO_PULL_NONE); + s5p_gpio_cfg_pin(&gpio->e1, i, S5P_GPIO_INPUT); + s5p_gpio_set_pull(&gpio->e1, i, S5P_GPIO_PULL_NONE); }
udelay(1); @@ -430,7 +430,7 @@ int board_mmc_init(bd_t *bis)
/* eMMC_EN: SD_0_CDn: GPK0[2] Output High */ s5p_gpio_direction_output(&gpio->k0, 2, 1); - s5p_gpio_set_pull(&gpio->k0, 2, GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio->k0, 2, S5P_GPIO_PULL_NONE);
/* * MMC device init @@ -445,7 +445,7 @@ int board_mmc_init(bd_t *bis)
/* T-flash detect */ s5p_gpio_cfg_pin(&gpio->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio->x3, 4, GPIO_PULL_UP); + s5p_gpio_set_pull(&gpio->x3, 4, S5P_GPIO_PULL_UP);
/* * Check the T-flash detect pin @@ -522,7 +522,7 @@ static void pmic_reset(void) (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2();
s5p_gpio_direction_output(&gpio->x0, 7, 1); - s5p_gpio_set_pull(&gpio->x2, 7, GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio->x2, 7, S5P_GPIO_PULL_NONE); }
static void board_clock_init(void) @@ -614,12 +614,12 @@ static void board_uart_init(void) */
for (i = 0; i < 4; i++) { - s5p_gpio_set_pull(&gpio1->a1, i, GPIO_PULL_NONE); - s5p_gpio_cfg_pin(&gpio1->a1, i, GPIO_FUNC((i > 1) ? 0x3 : 0x2)); + s5p_gpio_set_pull(&gpio1->a1, i, S5P_GPIO_PULL_NONE); + s5p_gpio_cfg_pin(&gpio1->a1, i, S5P_GPIO_FUNC((i > 1) ? 0x3 : 0x2)); }
/* UART_SEL GPY4[7] (part2) at EXYNOS4 */ - s5p_gpio_set_pull(&gpio2->y4, 7, GPIO_PULL_UP); + s5p_gpio_set_pull(&gpio2->y4, 7, S5P_GPIO_PULL_UP); s5p_gpio_direction_output(&gpio2->y4, 7, 1); }
diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index e742707..6ade3f2 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -216,7 +216,7 @@ int board_mmc_init(bd_t *bis)
/* T-flash detect */ s5p_gpio_cfg_pin(&gpio2->x3, 4, 0xf); - s5p_gpio_set_pull(&gpio2->x3, 4, GPIO_PULL_UP); + s5p_gpio_set_pull(&gpio2->x3, 4, S5P_GPIO_PULL_UP);
/* * Check the T-flash detect pin @@ -390,35 +390,35 @@ static void lcd_cfg_gpio(void)
for (i = 0; i < 8; i++) { /* set GPF0,1,2[0:7] for RGB Interface and Data lines (32bit) */ - s5p_gpio_cfg_pin(&gpio1->f0, i, GPIO_FUNC(2)); - s5p_gpio_cfg_pin(&gpio1->f1, i, GPIO_FUNC(2)); - s5p_gpio_cfg_pin(&gpio1->f2, i, GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio1->f0, i, S5P_GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio1->f1, i, S5P_GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio1->f2, i, S5P_GPIO_FUNC(2)); /* pull-up/down disable */ - s5p_gpio_set_pull(&gpio1->f0, i, GPIO_PULL_NONE); - s5p_gpio_set_pull(&gpio1->f1, i, GPIO_PULL_NONE); - s5p_gpio_set_pull(&gpio1->f2, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio1->f0, i, S5P_GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio1->f1, i, S5P_GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio1->f2, i, S5P_GPIO_PULL_NONE);
/* drive strength to max (24bit) */ - s5p_gpio_set_drv(&gpio1->f0, i, GPIO_DRV_4X); - s5p_gpio_set_rate(&gpio1->f0, i, GPIO_DRV_SLOW); - s5p_gpio_set_drv(&gpio1->f1, i, GPIO_DRV_4X); - s5p_gpio_set_rate(&gpio1->f1, i, GPIO_DRV_SLOW); - s5p_gpio_set_drv(&gpio1->f2, i, GPIO_DRV_4X); - s5p_gpio_set_rate(&gpio1->f0, i, GPIO_DRV_SLOW); + s5p_gpio_set_drv(&gpio1->f0, i, S5P_GPIO_DRV_4X); + s5p_gpio_set_rate(&gpio1->f0, i, S5P_GPIO_DRV_SLOW); + s5p_gpio_set_drv(&gpio1->f1, i, S5P_GPIO_DRV_4X); + s5p_gpio_set_rate(&gpio1->f1, i, S5P_GPIO_DRV_SLOW); + s5p_gpio_set_drv(&gpio1->f2, i, S5P_GPIO_DRV_4X); + s5p_gpio_set_rate(&gpio1->f0, i, S5P_GPIO_DRV_SLOW); }
for (i = 0; i < f3_end; i++) { /* set GPF3[0:3] for RGB Interface and Data lines (32bit) */ - s5p_gpio_cfg_pin(&gpio1->f3, i, GPIO_FUNC(2)); + s5p_gpio_cfg_pin(&gpio1->f3, i, S5P_GPIO_FUNC(2)); /* pull-up/down disable */ - s5p_gpio_set_pull(&gpio1->f3, i, GPIO_PULL_NONE); + s5p_gpio_set_pull(&gpio1->f3, i, S5P_GPIO_PULL_NONE); /* drive strength to max (24bit) */ - s5p_gpio_set_drv(&gpio1->f3, i, GPIO_DRV_4X); - s5p_gpio_set_rate(&gpio1->f3, i, GPIO_DRV_SLOW); + + s5p_gpio_set_rate(&gpio1->f3, i, S5P_GPIO_DRV_SLOW); }
/* gpio pad configuration for LCD reset. */ - s5p_gpio_cfg_pin(&gpio2->y4, 5, GPIO_OUTPUT); + s5p_gpio_cfg_pin(&gpio2->y4, 5, S5P_GPIO_OUTPUT);
spi_init(); } diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 1b882cb..a503137 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -71,7 +71,7 @@ void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en) { unsigned int value;
- s5p_gpio_cfg_pin(bank, gpio, GPIO_OUTPUT); + s5p_gpio_cfg_pin(bank, gpio, S5P_GPIO_OUTPUT);
value = readl(&bank->dat); value &= ~DAT_MASK(gpio); @@ -82,7 +82,7 @@ void s5p_gpio_direction_output(struct s5p_gpio_bank *bank, int gpio, int en)
void s5p_gpio_direction_input(struct s5p_gpio_bank *bank, int gpio) { - s5p_gpio_cfg_pin(bank, gpio, GPIO_INPUT); + s5p_gpio_cfg_pin(bank, gpio, S5P_GPIO_INPUT); }
void s5p_gpio_set_value(struct s5p_gpio_bank *bank, int gpio, int en) @@ -112,8 +112,8 @@ void s5p_gpio_set_pull(struct s5p_gpio_bank *bank, int gpio, int mode) value &= ~PULL_MASK(gpio);
switch (mode) { - case GPIO_PULL_DOWN: - case GPIO_PULL_UP: + case S5P_GPIO_PULL_DOWN: + case S5P_GPIO_PULL_UP: value |= PULL_MODE(gpio, mode); break; default: @@ -131,10 +131,10 @@ void s5p_gpio_set_drv(struct s5p_gpio_bank *bank, int gpio, int mode) value &= ~DRV_MASK(gpio);
switch (mode) { - case GPIO_DRV_1X: - case GPIO_DRV_2X: - case GPIO_DRV_3X: - case GPIO_DRV_4X: + case S5P_GPIO_DRV_1X: + case S5P_GPIO_DRV_2X: + case S5P_GPIO_DRV_3X: + case S5P_GPIO_DRV_4X: value |= DRV_SET(gpio, mode); break; default: @@ -152,8 +152,8 @@ void s5p_gpio_set_rate(struct s5p_gpio_bank *bank, int gpio, int mode) value &= ~RATE_MASK(gpio);
switch (mode) { - case GPIO_DRV_FAST: - case GPIO_DRV_SLOW: + case S5P_GPIO_DRV_FAST: + case S5P_GPIO_DRV_SLOW: value |= RATE_SET(gpio); break; default:
This patch enables GPIO Command for EXYNOS5. Function has been added to asm/gpio.h to decode the input gpio name to gpio number. example: gpio set gpa00
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - New patch Changes in V3: - Created a table to know the base address of input bank. Changes in V4: - Moved the function name_to_gpio to s5p gpio driver and renamed to s5p_name_to_gpio. arch/arm/include/asm/arch-exynos/gpio.h | 8 +++++ drivers/gpio/s5p_gpio.c | 49 +++++++++++++++++++++++++++++++ include/configs/exynos5250-dt.h | 1 + 3 files changed, 58 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/gpio.h b/arch/arm/include/asm/arch-exynos/gpio.h index 0b8e35e..7c0df0b 100644 --- a/arch/arm/include/asm/arch-exynos/gpio.h +++ b/arch/arm/include/asm/arch-exynos/gpio.h @@ -668,6 +668,14 @@ static inline unsigned int s5p_gpio_part_max(int nr) return 0; }
+struct gpio_name_num_table { + char bank; + unsigned int base; +}; + +int s5p_name_to_gpio(const char *name); +#define name_to_gpio(n) s5p_name_to_gpio(n) + void gpio_cfg_pin(int gpio, int cfg); void gpio_set_pull(int gpio, int mode); void gpio_set_drv(int gpio, int mode); diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index a503137..312d352 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -57,6 +57,21 @@ static const struct gpio_info gpio_data[EXYNOS5_GPIO_NUM_PARTS] = { #define HAVE_GENERIC_GPIO #endif
+struct gpio_name_num_table exynos5_gpio_table[] = { + { 'a', EXYNOS5_GPIO_A00 }, + { 'b', EXYNOS5_GPIO_B00 }, + { 'c', EXYNOS5_GPIO_C00 }, + { 'd', EXYNOS5_GPIO_D00 }, + { 'y', EXYNOS5_GPIO_Y00 }, + { 'x', EXYNOS5_GPIO_X00 }, + { 'e', EXYNOS5_GPIO_E00 }, + { 'f', EXYNOS5_GPIO_F00 }, + { 'g', EXYNOS5_GPIO_G00 }, + { 'h', EXYNOS5_GPIO_H00 }, + { 'v', EXYNOS5_GPIO_V00 }, + { 'z', EXYNOS5_GPIO_Z0 }, +}; + void s5p_gpio_cfg_pin(struct s5p_gpio_bank *bank, int gpio, int cfg) { unsigned int value; @@ -259,3 +274,37 @@ void gpio_cfg_pin(int gpio, int cfg) s5p_gpio_cfg_pin(s5p_gpio_get_bank(gpio), s5p_gpio_get_pin(gpio), cfg); } + +int s5p_name_to_gpio(const char *name) +{ + unsigned int num, i; + + name++; + + if (*name == 'p') + ++name; + + for (i = 0; i < ARRAY_SIZE(exynos5_gpio_table); i++) { + if (*name == exynos5_gpio_table[i].bank) { + if (*name == 'c') { + name++; + num = simple_strtoul(name, NULL, 10); + if (num >= 40) { + num = EXYNOS5_GPIO_C40 + (num - 40); + } else { + num = simple_strtoul(name, NULL, 8); + num = exynos5_gpio_table[i].base + num; + } + } else { + name++; + num = simple_strtoul(name, NULL, 8); + num = exynos5_gpio_table[i].base + num; + } + break; + } + } + + if (i == ARRAY_SIZE(exynos5_gpio_table)) + return -1; + return num; +} diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 9fab0fb..5a8a2fb 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -115,6 +115,7 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_NET +#define CONFIG_CMD_GPIO
#define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK
Hi Rajeshwari,
On Thu, Mar 21, 2013 at 4:33 AM, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
I tested this on snow, using:
# turn on backlight i2c dev 4; i2c mw 48 f 1; i2c mw 48 15 1; i2c md 48 0 20 gpio set gpx30 gpio set gpb20
This seems to work fine.
I also tested that the cros_ec keyboard works, using interrupt 182 instead of 174) in the FDT:
ec-interrupt = <&gpio 182 1>;
So it all looks good to me, thank you.
Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
-- 1.7.4.4
Hi Minkyu Kang,
Please do review the patch set and do let me know if any comments.
Regards, Rajeshwari Shinde
On Fri, Mar 22, 2013 at 3:43 AM, Simon Glass sjg@chromium.org wrote:
Hi Rajeshwari,
-- 1.7.4.4
Regards, Simon _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
