[U-Boot-Users] [PATCH 2/5]: add AcTux-1 board support
This patch adds the AcTux-1 specific files.
cu Michael
Signed-off-by: Michael Schwingen michael@schwingen.org
diff --git a/include/configs/actux1.h b/include/configs/actux1.h new file mode 100644 index 0000000..1ecf31e --- /dev/null +++ b/include/configs/actux1.h @@ -0,0 +1,241 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * Configuration settings for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_ACTUX1_32MB 0 /* 1: development board with 32MB DRAM */ +#define CONFIG_ACTUX1_FLASH2X2 1 /* 1: 2*2MB FLASH */ +#define CONFIG_ACTUX1_FLASH1X8 0 /* 1: 1*8MB FLASH */ + + +#define CONFIG_ACTUX1_SINGLE_ETH_LED 1 + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_IXP425 1 /* This is an IXP425 CPU */ +#define CONFIG_ACTUX1 1 /* on an AcTux-1 Board */ + +#define CONFIG_DISPLAY_CPUINFO 1 /* display cpu info (and speed) */ +#define CONFIG_DISPLAY_BOARDINFO 1 /* display board info */ + +#define CFG_IXP425_CONSOLE IXP425_UART2 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ + + + +/*************************************************************** + * U-boot generic defines start here. + ***************************************************************/ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) +#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF +//#define CONFIG_CMD_PCI +//#define CONFIG_PCI + +#define CONFIG_BOOTCOMMAND "run boot_flash" +//#define CONFIG_BOOTARGS "root=/dev/mtdblock2 rootfstype=cramfs console=ttyS0,115200 mtdparts=IXP4XX-Flash.0:256k(uboot),2048k(linux),-(root)" +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ +#endif + +/* + * Miscellaneous configurable options + */ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x00400000 /* memtest works on */ +#define CFG_MEMTEST_END 0x00800000 /* 4 ... 8 MB in DRAM */ + +#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CFG_LOAD_ADDR 0x00010000 /* default load address */ + +#define CFG_HZ 3333333 /* spec says 66.666 MHz, but it appears to be 33 */ + /* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } +#define CONFIG_SERIAL_RTS_ACTIVE 1 + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * Expansion bus settings + */ +#define CFG_EXP_CS0 0xbd113842 + +/* + * SDRAM settings + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ +#define CFG_DRAM_BASE 0x00000000 + + +#if CONFIG_ACTUX1_32MB // 32MB SDRAM +# define CFG_SDR_CONFIG 0x18 +# define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ +# define CFG_SDRAM_REFRESH_CNT 0x81a +# define CFG_SDR_MODE_CONFIG 0x1 +# define CFG_DRAM_SIZE 0x02000000 +#else // 16MB SDRAM +# define CFG_SDR_CONFIG 0x3A +# define PHYS_SDRAM_1_SIZE 0x01000000 /* 16 MB */ +# define CFG_SDRAM_REFRESH_CNT 0x81a +# define CFG_SDR_MODE_CONFIG 0x1 +# define CFG_DRAM_SIZE 0x01000000 +#endif + + + +/* + * FLASH organization + */ +#if CONFIG_ACTUX1_FLASH2X2 +# define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ +# define CFG_MAX_FLASH_SECT 40 /* max number of sectors on one chip */ +# define PHYS_FLASH_1 0x50000000 /* Flash Bank #1 */ +# define PHYS_FLASH_2 0x50200000 /* Flash Bank #2 */ +# define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } +#endif +#if CONFIG_ACTUX1_FLASH1X8 +# define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +# define CFG_MAX_FLASH_SECT 140 /* max number of sectors on one chip */ +# define PHYS_FLASH_1 0x50000000 /* Flash Bank #1 */ +# define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1 } +#endif + +#define CFG_FLASH_BASE PHYS_FLASH_1 +#define CFG_MONITOR_BASE PHYS_FLASH_1 +#define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ + +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ + +#define CFG_FLASH_CFI_WIDTH FLASH_CFI_16BIT /* no byte writes on IXP4xx */ +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ + +/* + * environment organization + */ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 0x2000 /* size of one complete sector */ +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x4000) +#define CFG_USE_PPCENV 1 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtd=IXP4XX-Flash.0:256k(uboot),64k(ucode),1152k(linux),-(root)\0" \ + "kerneladdr=50050000\0" \ + "rootaddr=50170000\0" \ + "loadaddr=10000\0" \ + "updateboot_ser=mw.b 10000 ff 40000; loady ${loadaddr}; run eraseboot writeboot\0" \ + "updateboot_net=mw.b 10000 ff 40000; tftp ${loadaddr} u-boot.bin; run eraseboot writeboot\0" \ + "eraseboot=protect off 50000000 50003fff; protect off 50006000 5003ffff; erase 50000000 50003fff; erase 50006000 5003ffff\0" \ + "writeboot=cp.b 10000 50000000 4000; cp.b 16000 50006000 3a000\0" \ + "eraseenv=protect off 50004000 50005fff; erase 50004000 50005fff\0" \ + "updateroot=tftp ${loadaddr} ${rootfile};era ${rootaddr} +${filesize}; cp.b ${loadaddr} ${rootaddr} ${filesize}\0" \ + "updatekern=tftp ${loadaddr} ${kernelfile};era ${kerneladdr} +${filesize}; cp.b ${loadaddr} ${kerneladdr} ${filesize}\0" \ + "flashargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3 rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "netargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3 rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ + "addeth=setenv bootargs ${bootargs} ethaddr=${ethaddr}\0" \ + "boot_flash=run flashargs addtty addeth; bootm ${kerneladdr}\0" \ + "boot_net=run netargs addtty addeth; tftpboot ${loadaddr} ${kernelfile}; bootm\0" \ + +/* + * Ethernet + */ +#define CONFIG_IXP4XX_NPE 1 /* include IXP4xx NPE support */ +#define CONFIG_IXP4XX_NPE_EXT_UCODE_BASE 0x50040000 /* use separate flash sector with ucode images */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_PHY_ADDR 0 /* NPE0 PHY address */ +//#define CONFIG_HAS_ETH1 +//#define CONFIG_PHY1_ADDR 1 /* NPE1 PHY address */ +#define CONFIG_MII 1 /* MII PHY management */ +#define CFG_RX_ETH_BUFFER 16 /* Number of ethernet rx buffers & descriptors */ +#define CONFIG_RESET_PHY_R 1 + + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#undef CONFIG_CMD_NFS /* NFS support */ + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* + * Cache Configuration + */ +#define CFG_CACHELINE_SIZE 32 + + +#endif /* __CONFIG_H */ diff --git a/board/actux1/Makefile b/board/actux1/Makefile new file mode 100644 index 0000000..a7e8322 --- /dev/null +++ b/board/actux1/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := actux1.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/actux1/actux1.c b/board/actux1/actux1.c new file mode 100644 index 0000000..9fd5f1c --- /dev/null +++ b/board/actux1/actux1.c @@ -0,0 +1,169 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * (C) Copyright 2006 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2002 + * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <asm/arch/ixp425.h> + +#include <miiphy.h> + +#include "actux1_hw.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ +int board_post_init (void) +{ + return (0); +} + +int board_init (void) +{ + gd->bd->bi_arch_number = MACH_TYPE_ACTUX1; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0x00000100; + + GPIO_OUTPUT_CLEAR (CFG_GPIO_IORST); + GPIO_OUTPUT_ENABLE(CFG_GPIO_IORST); + + /* + * Setup GPIO's for PCI INTA + */ + GPIO_OUTPUT_DISABLE(CFG_GPIO_PCI1_INTA); + GPIO_INT_ACT_LOW_SET(CFG_GPIO_PCI1_INTA); + + /* + * Setup GPIO's for 33MHz clock output + */ + GPIO_OUTPUT_ENABLE(CFG_GPIO_PCI_CLK); + GPIO_OUTPUT_ENABLE(CFG_GPIO_EXTBUS_CLK); + *IXP425_GPIO_GPCLKR = 0x011001FF; + + *IXP425_EXP_CS5 = 0x9d520003; // CS5: Debug port + *IXP425_EXP_CS6 = 0x81860001; // CS6: HwRel + *IXP425_EXP_CS7 = 0x80900003; // CS7: LED + + udelay (533); + GPIO_OUTPUT_SET(CFG_GPIO_IORST); + + ACTUX1_LED1(2); + ACTUX1_LED2(2); + ACTUX1_LED3(0); + ACTUX1_LED4(0); + ACTUX1_LED5(0); + ACTUX1_LED6(0); + ACTUX1_LED7(0); + + ACTUX1_HS(ACTUX1_HS_DCD); + + return 0; +} + +/* + * Check Board Identity + */ +int checkboard(void) +{ + char revision; + char *s = getenv("serial#"); + + puts("Board: AcTux-1 rev."); + putc(ACTUX1_BOARDREL + 'A' - 1); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + putc('\n'); + + return (0); +} + +/************************************************************************* + * get_board_rev() - setup to pass kernel board revision information + * 0 = reserved + * 1 = Rev. A + * 2 = Rev. B + *************************************************************************/ +u32 get_board_rev(void) +{ + return ACTUX1_BOARDREL; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return (0); +} + +#if (CONFIG_COMMANDS & CFG_CMD_PCI) || defined(CONFIG_PCI) +extern struct pci_controller hose; +extern void pci_ixp_init(struct pci_controller * hose); + +void pci_init_board(void) +{ + extern void pci_ixp_init (struct pci_controller *hose); + + pci_ixp_init(&hose); +} +#endif + +void reset_phy(void) +{ + u16 id1, id2; + + /* initialize the PHY */ + miiphy_reset("NPE0", CONFIG_PHY_ADDR); + + miiphy_read ("NPE0", CONFIG_PHY_ADDR, PHY_PHYIDR1, &id1); + miiphy_read ("NPE0", CONFIG_PHY_ADDR, PHY_PHYIDR2, &id2); + + id2 &= 0xFFF0; /* mask out revision bits */ + + if (id1 == 0x13 && id2 == 0x78e0) { /* LXT971/LXT972 */ + /* set LED outputs: LED1(green) = Link/ACT, LED2 (unused) = LINK, LED3(red) = Coll */ + miiphy_write("NPE0", CONFIG_PHY_ADDR, 20, 0xD432); + } + else if (id1 == 0x143 && id2 == 0xbc30) { /* BCM5241 */ + /* default values are OK */ + } + else + printf("unknown ethernet PHY ID: %x %x\n", id1, id2); +} + diff --git a/board/actux1/actux1_hw.h b/board/actux1/actux1_hw.h new file mode 100644 index 0000000..34cef2f --- /dev/null +++ b/board/actux1/actux1_hw.h @@ -0,0 +1,64 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * hardware register definitions for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ACTUX1_HW_H +#define _ACTUX1_HW_H + +// 0 = LED off,1 = green, 2 = red, 3 = orange +#define ACTUX1_LED1(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 0)) = (a) +#define ACTUX1_LED2(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 1)) = (a) +#define ACTUX1_LED3(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 2)) = (a) +#define ACTUX1_LED4(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 3)) = ((a)^3) +#define ACTUX1_LED5(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 4)) = ((a)^3) +#define ACTUX1_LED6(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 5)) = ((a)^3) +#define ACTUX1_LED7(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 6)) = ((a)^3) +#define ACTUX1_HS(a) (*(volatile u8 *)(IXP425_EXP_BUS_CS7_BASE_PHYS + 7)) = (a) +#define ACTUX1_HS_DCD 0x01 +#define ACTUX1_HS_DSR 0x02 + +#define ACTUX1_DBG_PORT ((volatile u8 *)(IXP425_EXP_BUS_CS5_BASE_PHYS + 0x10)) +#define ACTUX1_BOARDREL ((*(volatile u8 *)IXP425_EXP_BUS_CS6_BASE_PHYS) & 0x0F) + + +/* + * GPIO settings + */ +#define CFG_GPIO_PCI1_INTA 2 +#define CFG_GPIO_PCI2_INTA 3 +#define CFG_GPIO_I2C_SDA 4 +#define CFG_GPIO_I2C_SCL 5 +#define CFG_GPIO_DBGJUMPER 9 +#define CFG_GPIO_BUTTON1 10 +#define CFG_GPIO_DBGSENSE 11 +#define CFG_GPIO_DTR 12 +#define CFG_GPIO_IORST 13 // Out +#define CFG_GPIO_PCI_CLK 14 // Out +#define CFG_GPIO_EXTBUS_CLK 15 // Out + + + + +#endif + diff --git a/board/actux1/config.mk b/board/actux1/config.mk new file mode 100644 index 0000000..9a634cd --- /dev/null +++ b/board/actux1/config.mk @@ -0,0 +1,4 @@ +TEXT_BASE = 0x00e00000 + +# include NPE ethernet driver +BOARDLIBS = cpu/ixp/npe/libnpe.a diff --git a/board/actux1/u-boot.lds b/board/actux1/u-boot.lds new file mode 100644 index 0000000..4dbdb2c --- /dev/null +++ b/board/actux1/u-boot.lds @@ -0,0 +1,70 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-bigarm", "elf32-bigarm", "elf32-bigarm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/ixp/start.o (.text) + /* WARNING - the following is hand-optimized to fit within + the sector before the environment sector. If it throws an + error during compilation remove an object here to get it + linked after the configuration sector. */ + lib_generic/string.o (.text) + lib_generic/vsprintf.o (.text) + lib_arm/board.o (.text) + common/dlmalloc.o (.text) + drivers/mtd/cfi_flash.o (.text) + cpu/ixp/cpu.o (.text) + + . = env_offset; + common/environment.o (.ppcenv) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) } + _end = .; +}
diff --git a/board/actux1/Makefile b/board/actux1/Makefile new file mode 100644 index 0000000..a7e8322 --- /dev/null +++ b/board/actux1/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := actux1.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/actux1/actux1.c b/board/actux1/actux1.c new file mode 100644 index 0000000..eac85dc --- /dev/null +++ b/board/actux1/actux1.c @@ -0,0 +1,170 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * (C) Copyright 2006 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2002 + * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <asm/arch/ixp425.h> +#include <asm/io.h> +#include <miiphy.h> + +#include "actux1_hw.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ +int board_post_init (void) +{ + return (0); +} + +int board_init (void) +{ + gd->bd->bi_arch_number = MACH_TYPE_ACTUX1; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0x00000100; + + GPIO_OUTPUT_CLEAR (CFG_GPIO_IORST); + GPIO_OUTPUT_ENABLE (CFG_GPIO_IORST); + + /* Setup GPIO's for PCI INTA */ + GPIO_OUTPUT_DISABLE (CFG_GPIO_PCI1_INTA); + GPIO_INT_ACT_LOW_SET (CFG_GPIO_PCI1_INTA); + + /* Setup GPIO's for 33MHz clock output */ + GPIO_OUTPUT_ENABLE (CFG_GPIO_PCI_CLK); + GPIO_OUTPUT_ENABLE (CFG_GPIO_EXTBUS_CLK); + *IXP425_GPIO_GPCLKR = 0x011001FF; + + /* CS5: Debug port */ + *IXP425_EXP_CS5 = 0x9d520003; + /* CS6: HwRel */ + *IXP425_EXP_CS6 = 0x81860001; + /* CS7: LEDs */ + *IXP425_EXP_CS7 = 0x80900003; + + udelay (533); + GPIO_OUTPUT_SET (CFG_GPIO_IORST); + + ACTUX1_LED1 (2); + ACTUX1_LED2 (2); + ACTUX1_LED3 (0); + ACTUX1_LED4 (0); + ACTUX1_LED5 (0); + ACTUX1_LED6 (0); + ACTUX1_LED7 (0); + + ACTUX1_HS (ACTUX1_HS_DCD); + + return 0; +} + +/* + * Check Board Identity + */ +int checkboard (void) +{ + char revision; + char *s = getenv ("serial#"); + + puts ("Board: AcTux-1 rev."); + putc (ACTUX1_BOARDREL + 'A' - 1); + + if (s != NULL) { + puts (", serial# "); + puts (s); + } + putc ('\n'); + + return (0); +} + +/************************************************************************* + * get_board_rev() - setup to pass kernel board revision information + * 0 = reserved + * 1 = Rev. A + * 2 = Rev. B + *************************************************************************/ +u32 get_board_rev (void) +{ + return ACTUX1_BOARDREL; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return (0); +} + +#if (CONFIG_COMMANDS & CFG_CMD_PCI) || defined(CONFIG_PCI) +extern struct pci_controller hose; +extern void pci_ixp_init (struct pci_controller *hose); + +void pci_init_board (void) +{ + extern void pci_ixp_init (struct pci_controller *hose); + pci_ixp_init (&hose); +} +#endif + +void reset_phy (void) +{ + u16 id1, id2; + + /* initialize the PHY */ + miiphy_reset ("NPE0", CONFIG_PHY_ADDR); + + miiphy_read ("NPE0", CONFIG_PHY_ADDR, PHY_PHYIDR1, &id1); + miiphy_read ("NPE0", CONFIG_PHY_ADDR, PHY_PHYIDR2, &id2); + + id2 &= 0xFFF0; /* mask out revision bits */ + + if (id1 == 0x13 && id2 == 0x78e0) { + /* + LXT971/LXT972 PHY: + set LED outputs: + LED1(green) = Link/ACT, + LED2 (unused) = LINK, + LED3(red) = Coll + */ + miiphy_write ("NPE0", CONFIG_PHY_ADDR, 20, 0xD432); + } else if (id1 == 0x143 && id2 == 0xbc30) { + /* BCM5241: default values are OK */ + } else + printf ("unknown ethernet PHY ID: %x %x\n", id1, id2); +} diff --git a/board/actux1/actux1_hw.h b/board/actux1/actux1_hw.h new file mode 100644 index 0000000..91d4a6f --- /dev/null +++ b/board/actux1/actux1_hw.h @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * hardware register definitions for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ACTUX1_HW_H +#define _ACTUX1_HW_H + +/* 0 = LED off,1 = green, 2 = red, 3 = orange */ +#define ACTUX1_LED1(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 0) +#define ACTUX1_LED2(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 1) +#define ACTUX1_LED3(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 2) +#define ACTUX1_LED4(a) writeb((a)^3, IXP425_EXP_BUS_CS7_BASE_PHYS + 3) +#define ACTUX1_LED5(a) writeb((a)^3, IXP425_EXP_BUS_CS7_BASE_PHYS + 4) +#define ACTUX1_LED6(a) writeb((a)^3, IXP425_EXP_BUS_CS7_BASE_PHYS + 5) +#define ACTUX1_LED7(a) writeb((a)^3, IXP425_EXP_BUS_CS7_BASE_PHYS + 6) +#define ACTUX1_HS(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 7) +#define ACTUX1_HS_DCD 0x01 +#define ACTUX1_HS_DSR 0x02 + +#define ACTUX1_DBG_PORT IXP425_EXP_BUS_CS5_BASE_PHYS +#define ACTUX1_BOARDREL (readb(IXP425_EXP_BUS_CS6_BASE_PHYS) & 0x0F) + +/* GPIO settings */ +#define CFG_GPIO_PCI1_INTA 2 +#define CFG_GPIO_PCI2_INTA 3 +#define CFG_GPIO_I2C_SDA 4 +#define CFG_GPIO_I2C_SCL 5 +#define CFG_GPIO_DBGJUMPER 9 +#define CFG_GPIO_BUTTON1 10 +#define CFG_GPIO_DBGSENSE 11 +#define CFG_GPIO_DTR 12 +#define CFG_GPIO_IORST 13 /* Out */ +#define CFG_GPIO_PCI_CLK 14 /* Out */ +#define CFG_GPIO_EXTBUS_CLK 15 /* Out */ + +#endif diff --git a/board/actux1/config.mk b/board/actux1/config.mk new file mode 100644 index 0000000..9a634cd --- /dev/null +++ b/board/actux1/config.mk @@ -0,0 +1,4 @@ +TEXT_BASE = 0x00e00000 + +# include NPE ethernet driver +BOARDLIBS = cpu/ixp/npe/libnpe.a diff --git a/board/actux1/u-boot.lds b/board/actux1/u-boot.lds new file mode 100644 index 0000000..e1651f3 --- /dev/null +++ b/board/actux1/u-boot.lds @@ -0,0 +1,69 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-bigarm", "elf32-bigarm", "elf32-bigarm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/ixp/start.o (.text) + /* WARNING - the following is hand-optimized to fit within + the sector before the environment sector. If it throws an + error during compilation remove an object here to get it + linked after the configuration sector. */ + lib_generic/string.o (.text) + lib_generic/vsprintf.o (.text) + lib_arm/board.o (.text) + common/dlmalloc.o (.text) + cpu/ixp/cpu.o (.text) + + . = env_offset; + common/environment.o (.ppcenv) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) } + _end = .; +} diff --git a/include/configs/actux1.h b/include/configs/actux1.h new file mode 100644 index 0000000..48c5f0f --- /dev/null +++ b/include/configs/actux1.h @@ -0,0 +1,247 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * Configuration settings for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* 1: modified board with 32MB DRAM */ +#define CONFIG_ACTUX1_32MB 0 +/* 1: 2*2MB FLASH (standard) */ +#define CONFIG_ACTUX1_FLASH2X2 1 +/* 1: 1*8MB FLASH (upgraded boards) */ +#define CONFIG_ACTUX1_FLASH1X8 0 + +#define CONFIG_IXP425 1 +#define CONFIG_ACTUX1 1 + +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +#define CFG_IXP425_CONSOLE IXP425_UART2 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ + +/*************************************************************** + * U-boot generic defines start here. + ***************************************************************/ +#undef CONFIG_USE_IRQ + +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) +/* size in bytes reserved for initial data */ +#define CFG_GBL_DATA_SIZE 128 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command line configuration. */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF +#undef CONFIG_CMD_PCI +#undef CONFIG_PCI + +#define CONFIG_BOOTCOMMAND "run boot_flash" +/* enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_KGDB_BAUDRATE 230400 +/* which serial port to use */ +# define CONFIG_KGDB_SER_INDEX 1 +#endif + +/* Miscellaneous configurable options */ +#define CFG_LONGHELP +#define CFG_PROMPT "=> " +/* Console I/O Buffer Size */ +#define CFG_CBSIZE 256 +/* Print Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) +/* max number of command args */ +#define CFG_MAXARGS 16 +/* Boot Argument Buffer Size */ +#define CFG_BARGSIZE CFG_CBSIZE + +#define CFG_MEMTEST_START 0x00400000 +#define CFG_MEMTEST_END 0x00800000 + +/* everything, incl board info, in Hz */ +#undef CFG_CLKS_IN_HZ +/* spec says 66.666 MHz, but it appears to be 33 */ +#define CFG_HZ 3333333 + +/* default load address */ +#define CFG_LOAD_ADDR 0x00010000 + +/* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ + 115200, 230400 } +#define CONFIG_SERIAL_RTS_ACTIVE 1 + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +# define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +# define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* Expansion bus settings */ +#define CFG_EXP_CS0 0xbd113842 + +/* SDRAM settings */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x00000000 +#define CFG_DRAM_BASE 0x00000000 + +#if CONFIG_ACTUX1_32MB +# define CFG_SDR_CONFIG 0x18 +# define PHYS_SDRAM_1_SIZE 0x02000000 +# define CFG_SDRAM_REFRESH_CNT 0x81a +# define CFG_SDR_MODE_CONFIG 0x1 +# define CFG_DRAM_SIZE 0x02000000 +#else /* 16MB SDRAM */ +# define CFG_SDR_CONFIG 0x3A +# define PHYS_SDRAM_1_SIZE 0x01000000 +# define CFG_SDRAM_REFRESH_CNT 0x81a +# define CFG_SDR_MODE_CONFIG 0x1 +# define CFG_DRAM_SIZE 0x01000000 +#endif + +/* FLASH organization */ +#if CONFIG_ACTUX1_FLASH2X2 +# define CFG_MAX_FLASH_BANKS 2 +/* max number of sectors on one chip */ +# define CFG_MAX_FLASH_SECT 40 +# define PHYS_FLASH_1 0x50000000 +# define PHYS_FLASH_2 0x50200000 +# define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } +#endif +#if CONFIG_ACTUX1_FLASH1X8 +# define CFG_MAX_FLASH_BANKS 1 +/* max number of sectors on one chip */ +# define CFG_MAX_FLASH_SECT 140 +# define PHYS_FLASH_1 0x50000000 +# define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1 } +#endif + +#define CFG_FLASH_BASE PHYS_FLASH_1 +#define CFG_MONITOR_BASE PHYS_FLASH_1 +#define CFG_MONITOR_LEN (256 << 10) + +/* Use common CFI driver */ +#define CFG_FLASH_CFI +#define CFG_FLASH_CFI_DRIVER +/* no byte writes on IXP4xx */ +#define CFG_FLASH_CFI_WIDTH FLASH_CFI_16BIT +/* print 'E' for empty sector on flinfo */ +#define CFG_FLASH_EMPTY_INFO + +/* Ethernet */ + +/* include IXP4xx NPE support */ +#define CONFIG_IXP4XX_NPE 1 +/* use separate flash sector with ucode images */ +#define CONFIG_IXP4XX_NPE_EXT_UCODE_BASE 0x50040000 +#define CONFIG_NET_MULTI 1 +/* NPE0 PHY address */ +#define CONFIG_PHY_ADDR 0 +/* MII PHY management */ +#define CONFIG_MII 1 +/* Number of ethernet rx buffers & descriptors */ +#define CFG_RX_ETH_BUFFER 16 +#define CONFIG_RESET_PHY_R 1 + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#undef CONFIG_CMD_NFS + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* Cache Configuration */ +#define CFG_CACHELINE_SIZE 32 + +/* + environment organization: + one flash sector, embedded in uboot area (bottom bootblock flash) +*/ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 0x2000 +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x4000) +#define CFG_USE_PPCENV 1 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtd=IXP4XX-Flash.0:256k(uboot),64k(ucode),1152k(linux),-(root)\0" \ + "kerneladdr=50050000\0" \ + "rootaddr=50170000\0" \ + "loadaddr=10000\0" \ + "updateboot_ser=mw.b 10000 ff 40000;" \ + " loady ${loadaddr};" \ + " run eraseboot writeboot\0" \ + "updateboot_net=mw.b 10000 ff 40000;" \ + " tftp ${loadaddr} u-boot.bin;" \ + " run eraseboot writeboot\0" \ + "eraseboot=protect off 50000000 50003fff;" \ + " protect off 50006000 5003ffff;" \ + " erase 50000000 50003fff;" \ + " erase 50006000 5003ffff\0" \ + "writeboot=cp.b 10000 50000000 4000;" \ + " cp.b 16000 50006000 3a000\0" \ + "eraseenv=protect off 50004000 50005fff;" \ + " erase 50004000 50005fff\0" \ + "updateroot=tftp ${loadaddr} ${rootfile};" \ + " era ${rootaddr} +${filesize};" \ + " cp.b ${loadaddr} ${rootaddr} ${filesize}\0" \ + "updatekern=tftp ${loadaddr} ${kernelfile};" \ + " era ${kerneladdr} +${filesize};" \ + " cp.b ${loadaddr} ${kerneladdr} ${filesize}\0" \ + "flashargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3" \ + " rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "netargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3" \ + " rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ + "addeth=setenv bootargs ${bootargs} ethaddr=${ethaddr}\0" \ + "boot_flash=run flashargs addtty addeth;" \ + " bootm ${kerneladdr}\0" \ + "boot_net=run netargs addtty addeth;" \ + " tftpboot ${loadaddr} ${kernelfile};" \ + " bootm\0" + +#endif /* __CONFIG_H */
You are still not consequently indenting by TAB's.
- get_board_rev() - setup to pass kernel board revision information
0 = reserved
1 = Rev. A
2 = Rev. B
-----^^^^^^^^^^ Spaces instead TAB in all these lines.
--------------------------------^^^^^^^^ Spaces, bad alignment.
---^^^^^^^^^^ Spaces.
---^^^^^^^^^^--------------------^^^^^^^^^^ Spaces.
---^^^^^^^^^^----------------------^^^^^^^^ Spaces.
etc. etc.
Ditto in the other patches.
diff --git a/board/actux1/Makefile b/board/actux1/Makefile new file mode 100644 index 0000000..a7e8322 --- /dev/null +++ b/board/actux1/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := actux1.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/actux1/actux1.c b/board/actux1/actux1.c new file mode 100644 index 0000000..0ac9e41 --- /dev/null +++ b/board/actux1/actux1.c @@ -0,0 +1,169 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * (C) Copyright 2006 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * (C) Copyright 2002 + * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <asm/arch/ixp425.h> +#include <asm/io.h> +#include <miiphy.h> + +#include "actux1_hw.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ +int board_post_init (void) +{ + return (0); +} + +int board_init (void) +{ + gd->bd->bi_arch_number = MACH_TYPE_ACTUX1; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0x00000100; + + GPIO_OUTPUT_CLEAR (CFG_GPIO_IORST); + GPIO_OUTPUT_ENABLE (CFG_GPIO_IORST); + + /* Setup GPIO's for PCI INTA */ + GPIO_OUTPUT_DISABLE (CFG_GPIO_PCI1_INTA); + GPIO_INT_ACT_LOW_SET (CFG_GPIO_PCI1_INTA); + + /* Setup GPIO's for 33MHz clock output */ + GPIO_OUTPUT_ENABLE (CFG_GPIO_PCI_CLK); + GPIO_OUTPUT_ENABLE (CFG_GPIO_EXTBUS_CLK); + *IXP425_GPIO_GPCLKR = 0x011001FF; + + /* CS5: Debug port */ + *IXP425_EXP_CS5 = 0x9d520003; + /* CS6: HwRel */ + *IXP425_EXP_CS6 = 0x81860001; + /* CS7: LEDs */ + *IXP425_EXP_CS7 = 0x80900003; + + udelay (533); + GPIO_OUTPUT_SET (CFG_GPIO_IORST); + + ACTUX1_LED1 (2); + ACTUX1_LED2 (2); + ACTUX1_LED3 (0); + ACTUX1_LED4 (0); + ACTUX1_LED5 (0); + ACTUX1_LED6 (0); + ACTUX1_LED7 (0); + + ACTUX1_HS (ACTUX1_HS_DCD); + + return 0; +} + +/* + * Check Board Identity + */ +int checkboard (void) +{ + char revision; + char *s = getenv ("serial#"); + + puts ("Board: AcTux-1 rev."); + putc (ACTUX1_BOARDREL + 'A' - 1); + + if (s != NULL) { + puts (", serial# "); + puts (s); + } + putc ('\n'); + + return (0); +} + +/************************************************************************* + * get_board_rev() - setup to pass kernel board revision information + * 0 = reserved + * 1 = Rev. A + * 2 = Rev. B + *************************************************************************/ +u32 get_board_rev (void) +{ + return ACTUX1_BOARDREL; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return (0); +} + +#if (CONFIG_COMMANDS & CFG_CMD_PCI) || defined(CONFIG_PCI) +extern struct pci_controller hose; +extern void pci_ixp_init (struct pci_controller *hose); + +void pci_init_board (void) +{ + extern void pci_ixp_init (struct pci_controller *hose); + pci_ixp_init (&hose); +} +#endif + +void reset_phy (void) +{ + u16 id1, id2; + + /* initialize the PHY */ + miiphy_reset ("NPE0", CONFIG_PHY_ADDR); + + miiphy_read ("NPE0", CONFIG_PHY_ADDR, PHY_PHYIDR1, &id1); + miiphy_read ("NPE0", CONFIG_PHY_ADDR, PHY_PHYIDR2, &id2); + + id2 &= 0xFFF0; /* mask out revision bits */ + + if (id1 == 0x13 && id2 == 0x78e0) { + /* + * LXT971/LXT972 PHY: set LED outputs: + * LED1(green) = Link/ACT, + * LED2 (unused) = LINK, + * LED3(red) = Coll + */ + miiphy_write ("NPE0", CONFIG_PHY_ADDR, 20, 0xD432); + } else if (id1 == 0x143 && id2 == 0xbc30) { + /* BCM5241: default values are OK */ + } else + printf ("unknown ethernet PHY ID: %x %x\n", id1, id2); +} diff --git a/board/actux1/actux1_hw.h b/board/actux1/actux1_hw.h new file mode 100644 index 0000000..91d4a6f --- /dev/null +++ b/board/actux1/actux1_hw.h @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * hardware register definitions for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ACTUX1_HW_H +#define _ACTUX1_HW_H + +/* 0 = LED off,1 = green, 2 = red, 3 = orange */ +#define ACTUX1_LED1(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 0) +#define ACTUX1_LED2(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 1) +#define ACTUX1_LED3(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 2) +#define ACTUX1_LED4(a) writeb((a)^3, IXP425_EXP_BUS_CS7_BASE_PHYS + 3) +#define ACTUX1_LED5(a) writeb((a)^3, IXP425_EXP_BUS_CS7_BASE_PHYS + 4) +#define ACTUX1_LED6(a) writeb((a)^3, IXP425_EXP_BUS_CS7_BASE_PHYS + 5) +#define ACTUX1_LED7(a) writeb((a)^3, IXP425_EXP_BUS_CS7_BASE_PHYS + 6) +#define ACTUX1_HS(a) writeb((a), IXP425_EXP_BUS_CS7_BASE_PHYS + 7) +#define ACTUX1_HS_DCD 0x01 +#define ACTUX1_HS_DSR 0x02 + +#define ACTUX1_DBG_PORT IXP425_EXP_BUS_CS5_BASE_PHYS +#define ACTUX1_BOARDREL (readb(IXP425_EXP_BUS_CS6_BASE_PHYS) & 0x0F) + +/* GPIO settings */ +#define CFG_GPIO_PCI1_INTA 2 +#define CFG_GPIO_PCI2_INTA 3 +#define CFG_GPIO_I2C_SDA 4 +#define CFG_GPIO_I2C_SCL 5 +#define CFG_GPIO_DBGJUMPER 9 +#define CFG_GPIO_BUTTON1 10 +#define CFG_GPIO_DBGSENSE 11 +#define CFG_GPIO_DTR 12 +#define CFG_GPIO_IORST 13 /* Out */ +#define CFG_GPIO_PCI_CLK 14 /* Out */ +#define CFG_GPIO_EXTBUS_CLK 15 /* Out */ + +#endif diff --git a/board/actux1/config.mk b/board/actux1/config.mk new file mode 100644 index 0000000..9a634cd --- /dev/null +++ b/board/actux1/config.mk @@ -0,0 +1,4 @@ +TEXT_BASE = 0x00e00000 + +# include NPE ethernet driver +BOARDLIBS = cpu/ixp/npe/libnpe.a diff --git a/board/actux1/u-boot.lds b/board/actux1/u-boot.lds new file mode 100644 index 0000000..2496cc7 --- /dev/null +++ b/board/actux1/u-boot.lds @@ -0,0 +1,69 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT ("elf32-bigarm", "elf32-bigarm", "elf32-bigarm") +OUTPUT_ARCH (arm) +ENTRY (_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN (4); + .text : { + cpu/ixp/start.o(.text) + lib_generic/string.o(.text) + lib_generic/vsprintf.o(.text) + lib_arm/board.o(.text) + common/dlmalloc.o(.text) + cpu/ixp/cpu.o(.text) + . = env_offset; + common/environment.o(.ppcenv) + * (.text) + } + + . = ALIGN (4); + .rodata : { + *(.rodata) + } + . = ALIGN (4); + .data : { + *(.data) + } + . = ALIGN (4); + .got : { + *(.got) + } + . =.; + __u_boot_cmd_start =.; + .u_boot_cmd : { + *(.u_boot_cmd) + } + __u_boot_cmd_end =.; + + . = ALIGN (4); + __bss_start =.; + .bss (NOLOAD): { + *(.bss) + } + _end =.; +} diff --git a/include/configs/actux1.h b/include/configs/actux1.h new file mode 100644 index 0000000..d443787 --- /dev/null +++ b/include/configs/actux1.h @@ -0,0 +1,247 @@ +/* + * (C) Copyright 2007 + * Michael Schwingen, michael@schwingen.org + * + * Configuration settings for the AcTux-1 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* 1: modified board with 32MB DRAM */ +#define CONFIG_ACTUX1_32MB 0 +/* 1: 2*2MB FLASH (standard) */ +#define CONFIG_ACTUX1_FLASH2X2 1 +/* 1: 1*8MB FLASH (upgraded boards) */ +#define CONFIG_ACTUX1_FLASH1X8 0 + +#define CONFIG_IXP425 1 +#define CONFIG_ACTUX1 1 + +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +#define CFG_IXP425_CONSOLE IXP425_UART2 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ + +/*************************************************************** + * U-boot generic defines start here. + ***************************************************************/ +#undef CONFIG_USE_IRQ + +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) +/* size in bytes reserved for initial data */ +#define CFG_GBL_DATA_SIZE 128 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command line configuration. */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF +#undef CONFIG_CMD_PCI +#undef CONFIG_PCI + +#define CONFIG_BOOTCOMMAND "run boot_flash" +/* enable passing of ATAGs */ +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +#if defined(CONFIG_CMD_KGDB) +# define CONFIG_KGDB_BAUDRATE 230400 +/* which serial port to use */ +# define CONFIG_KGDB_SER_INDEX 1 +#endif + +/* Miscellaneous configurable options */ +#define CFG_LONGHELP +#define CFG_PROMPT "=> " +/* Console I/O Buffer Size */ +#define CFG_CBSIZE 256 +/* Print Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) +/* max number of command args */ +#define CFG_MAXARGS 16 +/* Boot Argument Buffer Size */ +#define CFG_BARGSIZE CFG_CBSIZE + +#define CFG_MEMTEST_START 0x00400000 +#define CFG_MEMTEST_END 0x00800000 + +/* everything, incl board info, in Hz */ +#undef CFG_CLKS_IN_HZ +/* spec says 66.666 MHz, but it appears to be 33 */ +#define CFG_HZ 3333333 + +/* default load address */ +#define CFG_LOAD_ADDR 0x00010000 + +/* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ + 115200, 230400 } +#define CONFIG_SERIAL_RTS_ACTIVE 1 + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +# define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +# define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* Expansion bus settings */ +#define CFG_EXP_CS0 0xbd113842 + +/* SDRAM settings */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x00000000 +#define CFG_DRAM_BASE 0x00000000 + +#if CONFIG_ACTUX1_32MB +# define CFG_SDR_CONFIG 0x18 +# define PHYS_SDRAM_1_SIZE 0x02000000 +# define CFG_SDRAM_REFRESH_CNT 0x81a +# define CFG_SDR_MODE_CONFIG 0x1 +# define CFG_DRAM_SIZE 0x02000000 +#else /* 16MB SDRAM */ +# define CFG_SDR_CONFIG 0x3A +# define PHYS_SDRAM_1_SIZE 0x01000000 +# define CFG_SDRAM_REFRESH_CNT 0x81a +# define CFG_SDR_MODE_CONFIG 0x1 +# define CFG_DRAM_SIZE 0x01000000 +#endif + +/* FLASH organization */ +#if CONFIG_ACTUX1_FLASH2X2 +# define CFG_MAX_FLASH_BANKS 2 +/* max number of sectors on one chip */ +# define CFG_MAX_FLASH_SECT 40 +# define PHYS_FLASH_1 0x50000000 +# define PHYS_FLASH_2 0x50200000 +# define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } +#endif +#if CONFIG_ACTUX1_FLASH1X8 +# define CFG_MAX_FLASH_BANKS 1 +/* max number of sectors on one chip */ +# define CFG_MAX_FLASH_SECT 140 +# define PHYS_FLASH_1 0x50000000 +# define CFG_FLASH_BANKS_LIST { PHYS_FLASH_1 } +#endif + +#define CFG_FLASH_BASE PHYS_FLASH_1 +#define CFG_MONITOR_BASE PHYS_FLASH_1 +#define CFG_MONITOR_LEN (256 << 10) + +/* Use common CFI driver */ +#define CFG_FLASH_CFI +#define CFG_FLASH_CFI_DRIVER +/* no byte writes on IXP4xx */ +#define CFG_FLASH_CFI_WIDTH FLASH_CFI_16BIT +/* print 'E' for empty sector on flinfo */ +#define CFG_FLASH_EMPTY_INFO + +/* Ethernet */ + +/* include IXP4xx NPE support */ +#define CONFIG_IXP4XX_NPE 1 +/* use separate flash sector with ucode images */ +#define CONFIG_IXP4XX_NPE_EXT_UCODE_BASE 0x50040000 +#define CONFIG_NET_MULTI 1 +/* NPE0 PHY address */ +#define CONFIG_PHY_ADDR 0 +/* MII PHY management */ +#define CONFIG_MII 1 +/* Number of ethernet rx buffers & descriptors */ +#define CFG_RX_ETH_BUFFER 16 +#define CONFIG_RESET_PHY_R 1 + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#undef CONFIG_CMD_NFS + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* Cache Configuration */ +#define CFG_CACHELINE_SIZE 32 + +/* + * environment organization: + * one flash sector, embedded in uboot area (bottom bootblock flash) + */ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_SIZE 0x2000 +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x4000) +#define CFG_USE_PPCENV 1 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtd=IXP4XX-Flash.0:256k(uboot),64k(ucode),1152k(linux),-(root)\0" \ + "kerneladdr=50050000\0" \ + "rootaddr=50170000\0" \ + "loadaddr=10000\0" \ + "updateboot_ser=mw.b 10000 ff 40000;" \ + " loady ${loadaddr};" \ + " run eraseboot writeboot\0" \ + "updateboot_net=mw.b 10000 ff 40000;" \ + " tftp ${loadaddr} u-boot.bin;" \ + " run eraseboot writeboot\0" \ + "eraseboot=protect off 50000000 50003fff;" \ + " protect off 50006000 5003ffff;" \ + " erase 50000000 50003fff;" \ + " erase 50006000 5003ffff\0" \ + "writeboot=cp.b 10000 50000000 4000;" \ + " cp.b 16000 50006000 3a000\0" \ + "eraseenv=protect off 50004000 50005fff;" \ + " erase 50004000 50005fff\0" \ + "updateroot=tftp ${loadaddr} ${rootfile};" \ + " era ${rootaddr} +${filesize};" \ + " cp.b ${loadaddr} ${rootaddr} ${filesize}\0" \ + "updatekern=tftp ${loadaddr} ${kernelfile};" \ + " era ${kerneladdr} +${filesize};" \ + " cp.b ${loadaddr} ${kerneladdr} ${filesize}\0" \ + "flashargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3" \ + " rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "netargs=setenv bootargs mtdparts=${mtd} root=/dev/mtdblock3" \ + " rootfstype=squashfs,jffs2 init=/etc/preinit\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ + "addeth=setenv bootargs ${bootargs} ethaddr=${ethaddr}\0" \ + "boot_flash=run flashargs addtty addeth;" \ + " bootm ${kerneladdr}\0" \ + "boot_net=run netargs addtty addeth;" \ + " tftpboot ${loadaddr} ${kernelfile};" \ + " bootm\0" + +#endif /* __CONFIG_H */
Michael Schwingen
