[ANN] U-Boot v2023.01-rc4 released
Hey all,
Here's -rc4, on schedule. I believe this should resolve the case Fedora showed where some binaries are allowed to be missing, IF a flag is also passed to make. We've got one more patch to make external optional binaries be more clearly supported, to pull in still.
In terms of a changelog, git log --merges v2023.01-rc3..v2023.01-rc4 contains what I've pulled but as always, better PR messages and tags will provide better results here.
Looking forward, the schedule is for now rcs every other Monday, and with final release on January 9th, 2023. Thanks all!
On Mon, 19 Dec 2022 at 19:16, Tom Rini trini@konsulko.com wrote:
Hey all,
Any chance to pick rv1126 series for this rc so-that it will include in the release? It's been there for a while.
https://patchwork.ozlabs.org/project/uboot/cover/20221214175111.477134-1-jag...
Jagan.
Hi Jagan,
Hey all,
This patch set is on my for-next list, I will send the PR once ready.
But seems something wrong on board which is not rockchip soc:
https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/14468
Thanks,
- Kever
Jagan.
Hi Kever,
On Tue, 20 Dec 2022 at 12:37, Kever Yang kever.yang@rock-chips.com wrote:
Hi Jagan,
Hey all,
This link not opening for me.
Jagan.
Hi Kever,
On Tue, 20 Dec 2022 at 12:47, Jagan Teki jagan@edgeble.ai wrote:
Hi Kever,
Hi Jagan,
Hey all,
Ping!
On Thu, Dec 22, 2022 at 02:32:23PM +0530, Jagan Teki wrote:
Hi Kever,
Hi Kever,
Hi Jagan,
Hey all,
Ping!
I've changed the setting to be public visible, but that won't help as it's failing to build in the strange way that buildman doesn't catch the output. It's likely broken on the CONFIG_SYS_TEXT_BASE -> CONFIG_TEXT_BASE change, and perhaps some other Kconfig migrations. At this point I'd really just like to see this rebased on next, sometime next week (after I finishing pushing all of the migrations through).
Hi Jagan,
Could you help to rebase on top of next?
I met two issues:
- CFG_SYS_TEXT_BASE as Tom mentioned;
- CONFIG_SYS_HZ_CLOCK could not use report by buildman.
+Error: You must add new CONFIG options using Kconfig +The following new ad-hoc CONFIG options were detected: +CONFIG_SYS_HZ_CLOCK
Thanks,
- Kever
On 2022/12/22 17:02, Jagan Teki wrote:
Hi Kever,
Hi Kever,
Hi Jagan,
Hey all,
Ping!
On Mon, 26 Dec 2022 at 10:23, Kever Yang kever.yang@rock-chips.com wrote:
Hi Jagan,
is it u-boot/next or u-boot-rockchip/for-next?
Jagan.
Hi Jagan,
I have fix all the CFG/CONFIG_ related change, so no need to rebase from your side.
But I still get build error, seems because bl31 support on imx8 platform?
https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/jobs/546342
Tom, could you help to have a check?
Thanks,
- Kever
Hi Jagan,
Jagan.
On Mon, 26 Dec 2022 at 16:14, Kever Yang kever.yang@rock-chips.com wrote:
Hi Jagan,
from your side.
platform?
I have rebased on u-boot/next - all are passed.
https://source.denx.de/u-boot/custodians/u-boot-spi/-/pipelines/14520
If you are okay, I will send V5 or you pick my tree. let me know.
Jagan.
Jagan Teki
Kever Yang
