[U-Boot] [PATH] ARM:OMAP3 Add OTG host support
Hi guys,
There is source code:
git clone git://gitorious.org/u-boot-omap3/mainline.git u-boot-omap3-usbhttp://gitorious.org/u-boot-omap3/mainline.gitu-boot-omap3-usb
cd u-boot-omap3-usb
git checkout -b omap3-dev-usb origin/omap3-dev-usb This patch is adding usb(otg) host support for beagleboard.
Signed-off-by: yanfeng qin connieqin1975@gmail.com Signed-off-by: garylu312 garylu312@gmail.com Signed-off-by: shaofeng wang wsf064@gmail.com --- Patch against omap3-dev-usb
drivers/usb/Makefile | 12 +++--------- include/configs/omap3_beagle.h | 9 +++++---- include/usb.h | 6 +----- 3 files changed, 9 insertions(+), 18 deletions(-)
Index: u-boot-steve-omap3/drivers/usb/Makefile =================================================================== --- u-boot-steve-omap3.orig/drivers/usb/Makefile +++ u-boot-steve-omap3/drivers/usb/Makefile @@ -31,17 +31,11 @@ COBJS-$(CONFIG_USB_OHCI_NEW) += usb_ohci COBJS-$(CONFIG_USB_EHCI) += usb_ehci_core.o
# host -COBJS-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o -COBJS-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o -COBJS-$(CONFIG_USB_SL811HS) += sl811_usb.o -COBJS-$(CONFIG_USB_EHCI_FSL) += usb_ehci_fsl.o -COBJS-$(CONFIG_USB_EHCI_PCI) += usb_ehci_pci.o -COBJS-$(CONFIG_USB_EHCI_IXP4XX) += usb_ehci_ixp.o +ifdef CONFIG_USB_HOST COBJS-$(CONFIG_MUSB_HCD) += musb_hcd.o musb_core.o -COBJS-$(CONFIG_USB_DAVINCI) += davinci_usb.o -COBJS-$(CONFIG_USB_EHCI_VCT) += usb_ehci_vct.o COBJS-$(CONFIG_USB_OMAP3530) += omap3530_usb.o - +COBJS-$(CONFIG_TWL4030_USB) += twl4030_usb.o +endif # device ifdef CONFIG_USB_DEVICE COBJS-y += usbdcore_ep0.o Index: u-boot-steve-omap3/include/configs/omap3_beagle.h =================================================================== --- u-boot-steve-omap3.orig/include/configs/omap3_beagle.h +++ u-boot-steve-omap3/include/configs/omap3_beagle.h @@ -103,11 +103,12 @@ /* * USB Configuration */ -#define CONFIG_USB_DEVICE 1 -#define CONFIG_USB_TTY 1 -#define CONFIG_MUSB 1 /* Enable USB driver*/ +#define CONFIG_MUSB_HCD 1 /* Enable USB driver*/ #define CONFIG_TWL4030_USB 1 /* Enable TWL4030 USB */ - +#define CONFIG_USB_STORAGE +#define CONFIG_USB_OMAP3530 +#define CONFIG_USB_HOST +#define CONFIG_CMD_USB /* Allow console in serial and USB at the same time */ #define CONFIG_CONSOLE_MUX 1 #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 Index: u-boot-steve-omap3/include/usb.h =================================================================== --- u-boot-steve-omap3.orig/include/usb.h +++ u-boot-steve-omap3/include/usb.h @@ -180,11 +180,7 @@ struct usb_device { * this is how the lowlevel part communicate with the outer world */
-#if defined(CONFIG_USB_UHCI) || defined(CONFIG_USB_OHCI) || \ - defined(CONFIG_USB_EHCI) || defined(CONFIG_USB_OHCI_NEW) || \ - defined(CONFIG_USB_SL811HS) || defined(CONFIG_USB_ISP116X_HCD) || \ - defined(CONFIG_USB_R8A66597_HCD) || defined(CONFIG_USB_DAVINCI) || \ - defined(CONFIG_USB_OMAP3530) +#if defined(CONFIG_MUSB_HCD)
int usb_lowlevel_init(void); int usb_lowlevel_stop(void);
Hi guys,
cd u-boot-omap3-usb
yanfeng qin
