[PATCH] cmd: fdt: Add support for reading stringlist property values
The fdt command currently handles stringlists as strings in 'fdt get value' subcommand. Since strings in FDT stringlists are separated by '\0', only the first value gets inserted into the environment variable passed to the 'fdt get value' command.
Example, consider the following DT snippet:
/ { compatible = "foo", "bar" };
The following command only reports the first string in stringlist: => fdt get value var / compatible ; print var foo
It is not possible to assign list of null-terminated strings into U-Boot environment variable. Add optional 'index' parameter to the subcommand 'fdt get value <var> <path> <prop> [<index>]' which lets user specify which string within the stringlist should be assigned into the 'var' variable. The default value of 'index' is 0 in case it is not present. This way the 'fdt' command API does not change and existing scripts are not broken.
The following command now reports the Nth string in stringlist, counting from zero: => fdt get value var / compatible 1 ; print var bar
Signed-off-by: Marek Vasut marex@denx.de Cc: Heinrich Schuchardt heinrich.schuchardt@canonical.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- cmd/fdt.c | 34 ++++++++++++++++++++++++++++------ 1 file changed, 28 insertions(+), 6 deletions(-)
diff --git a/cmd/fdt.c b/cmd/fdt.c index 842e6cb634b..6fbd9205d38 100644 --- a/cmd/fdt.c +++ b/cmd/fdt.c @@ -48,11 +48,27 @@ void set_working_fdt_addr(ulong addr) /* * Get a value from the fdt and format it to be set in the environment */ -static int fdt_value_env_set(const void *nodep, int len, const char *var) +static int fdt_value_env_set(const void *nodep, int len, + const char *var, int index) { - if (is_printable_string(nodep, len)) - env_set(var, (void *)nodep); - else if (len == 4) { + if (is_printable_string(nodep, len)) { + const char *nodec = (const char *)nodep; + int i; + + /* + * Iterate over all members in stringlist and find the one at + * offset $index. If no such index exists, indicate failure. + */ + for (i = 0; i < len; i += strlen(nodec) + 1) { + if (index-- > 0) + continue; + + env_set(var, nodec + i); + return 0; + } + + return 1; + } else if (len == 4) { char buf[11];
sprintf(buf, "0x%08X", fdt32_to_cpu(*(fdt32_t *)nodep)); @@ -426,10 +442,14 @@ static int do_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return 0; } else if (nodep && len > 0) { if (subcmd[0] == 'v') { + int index = 0; int ret;
+ if (argc == 7) + index = simple_strtoul(argv[6], NULL, 10); + ret = fdt_value_env_set(nodep, len, - var); + var, index); if (ret != 0) return ret; } else if (subcmd[0] == 'a') { @@ -1085,7 +1105,9 @@ static char fdt_help_text[] = "fdt resize [<extrasize>] - Resize fdt to size + padding to 4k addr + some optional <extrasize> if needed\n" "fdt print <path> [<prop>] - Recursive print starting at <path>\n" "fdt list <path> [<prop>] - Print one level starting at <path>\n" - "fdt get value <var> <path> <prop> - Get <property> and store in <var>\n" + "fdt get value <var> <path> <prop> [<index>] - Get <property> and store in <var>\n" + " In case of stringlist property, use optional <index>\n" + " to select string within the stringlist. Default is 0.\n" "fdt get name <var> <path> <index> - Get name of node <index> and store in <var>\n" "fdt get addr <var> <path> <prop> - Get start address of <property> and store in <var>\n" "fdt get size <var> <path> [<prop>] - Get size of [<property>] or num nodes and store in <var>\n"
Hi Marek,
Can you please add docs and a test?
I am happy to do a starting point for a test if you like.
On 7/12/22 12:58, Simon Glass wrote:
Hi Marek,
I was expecting this kind of question ... there is no test for the FDT command.
You can implement the test for this while at it.
Hi Marek,
Hi Marek,
I sent a starting point for you, both docs and test.
On 7/13/22 17:28, Simon Glass wrote:
Hi Marek,
Hi Marek,
Thank you.
Do I understand your remark correctly that you're blocking this particular patch from going in until there is a test ?
Hi Marek,
Hi Marek,
Hi Marek,
Thank you.
I'm not blocking anything, but turning it around the other way, how about having a crack at a test? You can try out 'ut fdt' to see the current tests (using the patches I sent).
Hi Marek,
Hi Marek,
Hi Marek,
Thank you.
Applied to u-boot-dm, thanks!
On 9/21/22 11:50, Simon Glass wrote:
On 7/17/22 10:12, Simon Glass wrote:
Hi Marek,
This patch is still not in u-boot/master ?
Applied to u-boot-dm, thanks! Applied to u-boot-dm, thanks!
Can you point me to this patch in the u-boot-dm repository ? I am getting these emails, but I don't see the patch applied.
Hi Marek,
Hi Marek,
Oh it is gone now as I pushed something new to dm/master.
But see this one in master:
13982ced2cc cmd: fdt: Add support for reading stringlist property values
