[PATCH v1] board: toradex: colibri-imx8x: Remove board_gpio_init
On Colibri iMX8X, the gpio initialization and usage should be handled by the device tree, not by the colibri-imx8x.c code. Therefore, remove it.
Signed-off-by: Hiago De Franco hiago.franco@toradex.com --- board/toradex/colibri-imx8x/colibri-imx8x.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/board/toradex/colibri-imx8x/colibri-imx8x.c b/board/toradex/colibri-imx8x/colibri-imx8x.c index 6fc8076163c6..1474297e1814 100644 --- a/board/toradex/colibri-imx8x/colibri-imx8x.c +++ b/board/toradex/colibri-imx8x/colibri-imx8x.c @@ -93,15 +93,6 @@ int board_early_init_f(void) return 0; }
-#if IS_ENABLED(CONFIG_DM_GPIO) -static void board_gpio_init(void) -{ - /* TODO */ -} -#else -static inline void board_gpio_init(void) {} -#endif - #if IS_ENABLED(CONFIG_FEC_MXC) #include <miiphy.h>
@@ -128,8 +119,6 @@ static void select_dt_from_module_version(void)
int board_init(void) { - board_gpio_init(); - if (IS_ENABLED(CONFIG_IMX_SNVS_SEC_SC_AUTO)) { int ret = snvs_security_sc_init();
Applied to u-boot-imx/next, thanks.
Fabio Estevam
Hiago De Franco
