[PATCH] board: turris: Find atsha device by atsha driver
It does not matter what is DT node name of atsha device. So find it via atsha driver and not by DT node name.
Signed-off-by: Pali Rohár pali@kernel.org --- board/CZ.NIC/turris_atsha_otp.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/board/CZ.NIC/turris_atsha_otp.c b/board/CZ.NIC/turris_atsha_otp.c index 8c39f5e52414..e62b7ee2a49a 100644 --- a/board/CZ.NIC/turris_atsha_otp.c +++ b/board/CZ.NIC/turris_atsha_otp.c @@ -6,6 +6,7 @@
#include <env.h> #include <net.h> +#include <dm/device.h> #include <dm/uclass.h> #include <atsha204a-i2c.h>
@@ -16,12 +17,14 @@ #define TURRIS_ATSHA_OTP_MAC0 3 #define TURRIS_ATSHA_OTP_MAC1 4
+extern U_BOOT_DRIVER(atsha204); + static struct udevice *get_atsha204a_dev(void) { /* Cannot be static because BSS does not have to be ready at this early stage */ struct udevice *dev;
- if (uclass_get_device_by_name(UCLASS_MISC, "crypto@64", &dev)) { + if (uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(atsha204), &dev)) { puts("Cannot find ATSHA204A on I2C bus!\n"); dev = NULL; }
Just curious: What exactly does this patch fix? Is there a turris board with a differently named atsha DT entry?
Still:
Thanks, Stefan
- static struct udevice *get_atsha204a_dev(void) { /* Cannot be static because BSS does not have to be ready at this early stage */ struct udevice *dev;
- if (uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(atsha204), &dev)) { puts("Cannot find ATSHA204A on I2C bus!\n"); dev = NULL; }
Viele Grüße, Stefan Roese
Currently is not. In patch for Turris 1.x support I use same "crypto@64" node name, so code would work correctly: https://lore.kernel.org/u-boot/20220516090119.20217-1-pali@kernel.org/#Z31ar...
But I think that U-Boot code should be independent of the node names and this file calls functions exported from atsha204 driver. So it is better to find udevice based on driver which export those functions than DTS node name.
Still:
Thanks, Stefan
diff --git a/board/CZ.NIC/turris_atsha_otp.c b/board/CZ.NIC/turris_atsha_otp.c index 8c39f5e52414..e62b7ee2a49a 100644 --- a/board/CZ.NIC/turris_atsha_otp.c +++ b/board/CZ.NIC/turris_atsha_otp.c @@ -6,6 +6,7 @@ #include <env.h> #include <net.h> +#include <dm/device.h> #include <dm/uclass.h> #include <atsha204a-i2c.h> @@ -16,12 +17,14 @@ #define TURRIS_ATSHA_OTP_MAC0 3 #define TURRIS_ATSHA_OTP_MAC1 4 +extern U_BOOT_DRIVER(atsha204);
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Applied to u-boot-marvell/master
Thanks, Stefan
Pali Rohár
Stefan Roese
