[U-Boot] [PATCH v3] mmc: atmel_sdhci: Convert to the driver model support
Convert the driver to the driver model while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v3: - Remove the redundant log print.
Changes in v2: - Add clock support, include enabling peripheral clock and generated clock. - Retain the existing legacy code to support boards which have not converted to driver model.
drivers/mmc/Kconfig | 10 ++++++ drivers/mmc/atmel_sdhci.c | 92 +++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 102 insertions(+)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index dc8532f..7f6b2e1 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -16,6 +16,16 @@ config DM_MMC appear as block devices in U-Boot and can support filesystems such as EXT4 and FAT.
+config ATMEL_SDHCI + bool "Atmel SDHCI controller support" + depends on DM_MMC && ARCH_AT91 + help + This enables support for the Atmel SDHCI controller, which supports + the embedded MultiMedia Card (e.MMC) Specification V4.51, the SD + Memory Card Specification V3.0, and the SDIO V3.0 specification. + It is compliant with the SD Host Controller Standard V3.0 + specification. + config ROCKCHIP_DWMMC bool "Rockchip SD/MMC controller support" depends on DM_MMC && OF_CONTROL diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index 24b68b6..dc74704 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -6,12 +6,16 @@ */
#include <common.h> +#include <clk.h> +#include <dm.h> #include <malloc.h> #include <sdhci.h> #include <asm/arch/clk.h>
#define ATMEL_SDHC_MIN_FREQ 400000
+#ifndef CONFIG_DM_MMC + int atmel_sdhci_init(void *regbase, u32 id) { struct sdhci_host *host; @@ -38,3 +42,91 @@ int atmel_sdhci_init(void *regbase, u32 id)
return 0; } + +#else + +DECLARE_GLOBAL_DATA_PTR; + +static int atmel_sdhci_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct sdhci_host *host = dev_get_priv(dev); + u32 max_clk, min_clk = ATMEL_SDHC_MIN_FREQ; + u32 caps0, caps1; + u32 clk_base, clk_mul; + u32 gck_rate; + struct udevice *clkdev; + int periph, ret; + + ret = clk_get_by_index(dev, 0, &clkdev); + if (ret) + return ret; + + periph = fdtdec_get_uint(gd->fdt_blob, clkdev->of_offset, "reg", -1); + if (periph < 0) + return -EINVAL; + + clkdev = dev_get_parent(clkdev); + if (!clkdev) + return -ENODEV; + + ret = clk_enable(clkdev, periph); + if (ret) + return ret; + + host->name = (char *)dev->name; + host->ioaddr = (void *)dev_get_addr(dev); + + host->quirks = 0; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->bus_width = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "bus-width", 4); + + caps0 = readl(host->ioaddr + SDHCI_CAPABILITIES); + caps1 = readl(host->ioaddr + SDHCI_CAPABILITIES_1); + clk_base = (caps0 & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; + clk_mul = (caps1 & SDHCI_CLOCK_MUL_MASK) >> SDHCI_CLOCK_MUL_SHIFT; + gck_rate = clk_base * 1000000 * (clk_mul + 1); + + ret = clk_get_by_index(dev, 1, &clkdev); + if (ret) + return ret; + + periph = fdtdec_get_uint(gd->fdt_blob, clkdev->of_offset, "reg", -1); + if (periph < 0) + return -EINVAL; + + clkdev = dev_get_parent(clkdev); + if (!clkdev) + return -ENODEV; + + ret = clk_set_periph_rate(clkdev, periph, gck_rate); + if (ret) + return -ENODEV; + + max_clk = clk_get_periph_rate(clkdev, periph); + if (!max_clk) + return -ENODEV; + + add_sdhci(host, max_clk, min_clk); + + upriv->mmc = host->mmc; + + return 0; +} + +static const struct udevice_id atmel_sdhci_ids[] = { + { .compatible = "atmel,sama5d2-sdhci" }, + { } +}; + +U_BOOT_DRIVER(atmel_sdhci_drv) = { + .name = "atmel_sdhci", + .id = UCLASS_MMC, + .of_match = atmel_sdhci_ids, + .probe = atmel_sdhci_probe, + .priv_auto_alloc_size = sizeof(struct sdhci_host), +}; + +#endif
Hi Wenyou,
Changes in v3:
Changes in v2:
+config ATMEL_SDHCI
help
specification.
+#else
u32 caps0, caps1;
u32 gck_rate;
int periph, ret;
if (ret)
return ret;
if (periph < 0)
return -EINVAL;
if (!clkdev)
return -ENODEV;
This cannot happen, there is always a parent. Even if your device tree has this as a root node, there is still the root device.
if (ret)
return ret;
host->quirks = 0;
"bus-width", 4);
if (ret)
return ret;
if (periph < 0)
return -EINVAL;
if (!clkdev)
return -ENODEV;
-EINVAL
if (ret)
return -ENODEV;
return ret
if (!max_clk)
return -ENODEV;
-EINVAL
.id = UCLASS_MMC,
2.7.4
Wenyou Yang
