Re: [U-Boot] [PATCH v3 5/5] New board support: Nokia RX-51 aka N900
Hi Marek,
as part of the code is written by me I will answer to a couple of the questions
Dear Pali Rohár,
Based on previous work by: Alistair Buxton
Signed-off-by: Pali Rohár Cc: Ивайло Димитров
Can we please stick to ASCII instead of UTF8?
Cc: Ivaylo Dimitrov (if I'm not mistaken)
You are not :). And if it comes to me, it does not matter whether cyrillic or latin will be used.
+static void omap3_emu_romcode_call(u32 service_id, u32 *parameters) +{
- u32 i, num_params = *parameters;
- u32 *sram_scratch_space = (u32 *)OMAP3_PUBLIC_SRAM_SCRATCH_AREA;
* copy the parameters to an un-cached area to avoid coherency
* issues
_WHAT_ ?!
Use dcache_flush(). The Omap3 rom won't cope with cache memory? Actually -- why do you even do call into ROM ?
- for (i = 0; i < num_params; i++) {
__raw_writel(*parameters, sram_scratch_space);
parameters++;
sram_scratch_space++;
- /* Now make the PPA call */
- do_omap3_emu_romcode_call(service_id, OMAP3_PUBLIC_SRAM_SCRATCH_AREA);
That part of the code is ported from existing code in u-boot: http://git.denx.de/?p=u-boot.git;a=blob;f=arch/arm/cpu/armv7/omap3/board.c;h...
So I can't think of a reason to do it in a different way.
The ROM call is needed to enable workaround for ARM errata 430973. RX-51 being a high secure device does not allow writes to AUX control register outside of the secure world. So, this call is needed to enable IBE bit in AUXCR. I can elaborate more if needed.
* Cortex-A8(r1p0..r1p2) errata 430973 workaround
* Set IBE bit in Auxiliary Control Register
- omap3_update_aux_cr_secure_rx51(1 << 6, 0);
And here is the code where IBE bit (bit 6) set.
Have in mind there is a difference re how parameters are passed compared to beagleboard for example, RX-51 ROM expects first parameter to be the number of remaining parameters+1, while beagleboard(again, just an example) ROM expects only the number of the remaining parameters, so existing function in arch/arm/cpu/armv7/omap3/board.c cannot be called (even if it is not declared static).
Ивайло Димитров
