[U-Boot] [PATCH] configs: sama5d27_wlsom1_ek: add CONFIG_SPL_AT91_MCK_BYPASS
This board has an external oscillator as MCK that does not need driving. Bypass the driving for the main oscillator in SPL.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 + configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index 5584c9c..50a8a8e 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +CONFIG_SPL_AT91_MCK_BYPASS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index 56cca3e..ec05af1 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_AT91_MCK_BYPASS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set
On 04.09.2019 11:19, Eugen Hristev - M18282 wrote:
Applied to u-boot-atmel/next
Eugen.Hristev@microchip.com
