[U-Boot] [PATCH] nand: atmel: add drvice tree support and dm gpio APIs
In order to use the driver model gpio APIs, add the device tree support.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
drivers/mtd/nand/atmel_nand.c | 143 ++++++++++++++++++++++++++++++++++-------- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 3 files changed, 119 insertions(+), 26 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 8669432deb..87ff5c2eb4 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -14,29 +14,34 @@ #include <common.h> #include <asm/gpio.h> #include <asm/arch/gpio.h> +#ifdef CONFIG_DM_GPIO +#include <asm/gpio.h> +#endif
+#include <fdtdec.h> #include <malloc.h> #include <nand.h> #include <watchdog.h> #include <linux/mtd/nand_ecc.h>
-#ifdef CONFIG_ATMEL_NAND_HWECC - -/* Register access macros */ -#define ecc_readl(add, reg) \ - readl(add + ATMEL_ECC_##reg) -#define ecc_writel(add, reg, value) \ - writel((value), add + ATMEL_ECC_##reg) +DECLARE_GLOBAL_DATA_PTR; + +struct atmel_nand_data { + struct gpio_desc enable_pin; /* chip enable */ + struct gpio_desc det_pin; /* card detect */ + struct gpio_desc rdy_pin; /* ready/busy */ + u8 ale; /* address line number connected to ALE */ + u8 cle; /* address line number connected to CLE */ + u8 bus_width_16; /* buswidth is 16 bit */ + u8 ecc_mode; /* ecc mode */ + u8 on_flash_bbt; /* bbt on flash */ +};
-#include "atmel_nand_ecc.h" /* Hardware ECC registers */ +struct atmel_nand_host { + void __iomem *io_base; + struct atmel_nand_data board;
#ifdef CONFIG_ATMEL_NAND_HW_PMECC - -#ifdef CONFIG_SPL_BUILD -#undef CONFIG_SYS_NAND_ONFI_DETECTION -#endif - -struct atmel_nand_host { struct pmecc_regs __iomem *pmecc; struct pmecc_errloc_regs __iomem *pmerrloc; void __iomem *pmecc_rom_base; @@ -63,9 +68,26 @@ struct atmel_nand_host { int *pmecc_mu; int *pmecc_dmu; int *pmecc_delta; +#endif };
-static struct atmel_nand_host pmecc_host; +static struct atmel_nand_host nand_host; +#ifdef CONFIG_ATMEL_NAND_HWECC + +/* Register access macros */ +#define ecc_readl(add, reg) \ + readl(add + ATMEL_ECC_##reg) +#define ecc_writel(add, reg, value) \ + writel((value), add + ATMEL_ECC_##reg) + +#include "atmel_nand_ecc.h" /* Hardware ECC registers */ + +#ifdef CONFIG_ATMEL_NAND_HW_PMECC + +#ifdef CONFIG_SPL_BUILD +#undef CONFIG_SYS_NAND_ONFI_DETECTION +#endif + static struct nand_ecclayout atmel_pmecc_oobinfo;
/* @@ -805,12 +827,9 @@ static uint16_t *create_lookup_table(int sector_size) static int atmel_pmecc_nand_init_params(struct nand_chip *nand, struct mtd_info *mtd) { - struct atmel_nand_host *host; + struct atmel_nand_host *host = nand_get_controller_data(nand); int cap, sector_size;
- host = &pmecc_host; - nand_set_controller_data(nand, host); - nand->ecc.mode = NAND_ECC_HW; nand->ecc.calculate = NULL; nand->ecc.correct = NULL; @@ -1207,12 +1226,24 @@ int atmel_hwecc_nand_init_param(struct nand_chip *nand, struct mtd_info *mtd) #endif /* CONFIG_ATMEL_NAND_HWECC */
static void at91_nand_hwcontrol(struct mtd_info *mtd, - int cmd, unsigned int ctrl) + int cmd, unsigned int ctrl) { struct nand_chip *this = mtd_to_nand(mtd); +#if CONFIG_IS_ENABLED(OF_CONTROL) + struct atmel_nand_host *host = nand_get_controller_data(this); +#endif
if (ctrl & NAND_CTRL_CHANGE) { - ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; + ulong IO_ADDR_W = (ulong)this->IO_ADDR_W; +#if CONFIG_IS_ENABLED(OF_CONTROL) + IO_ADDR_W &= ~((1 << host->board.ale) + | (1 << host->board.cle)); + + if (ctrl & NAND_CLE) + IO_ADDR_W |= (1 << host->board.cle); + if (ctrl & NAND_ALE) + IO_ADDR_W |= (1 << host->board.ale); +#else IO_ADDR_W &= ~(CONFIG_SYS_NAND_MASK_ALE | CONFIG_SYS_NAND_MASK_CLE);
@@ -1220,10 +1251,18 @@ static void at91_nand_hwcontrol(struct mtd_info *mtd, IO_ADDR_W |= CONFIG_SYS_NAND_MASK_CLE; if (ctrl & NAND_ALE) IO_ADDR_W |= CONFIG_SYS_NAND_MASK_ALE; +#endif
+#ifdef CONFIG_DM_GPIO + if (dm_gpio_is_valid(&host->board.enable_pin)) + dm_gpio_set_value(&host->board.enable_pin, + !(ctrl & NAND_NCE)); +#else #ifdef CONFIG_SYS_NAND_ENABLE_PIN gpio_set_value(CONFIG_SYS_NAND_ENABLE_PIN, !(ctrl & NAND_NCE)); #endif +#endif + this->IO_ADDR_W = (void *) IO_ADDR_W; }
@@ -1231,12 +1270,24 @@ static void at91_nand_hwcontrol(struct mtd_info *mtd, writeb(cmd, this->IO_ADDR_W); }
-#ifdef CONFIG_SYS_NAND_READY_PIN static int at91_nand_ready(struct mtd_info *mtd) { +#ifdef CONFIG_DM_GPIO + struct nand_chip *nand_chip = mtd_to_nand(mtd); + struct atmel_nand_host *host = nand_get_controller_data(nand_chip); + + if (dm_gpio_is_valid(&host->board.rdy_pin)) + return dm_gpio_get_value(&host->board.rdy_pin); + + return 0; +#else +#ifdef CONFIG_SYS_NAND_READY_PIN return gpio_get_value(CONFIG_SYS_NAND_READY_PIN); -} +#else + return 0; #endif +#endif +}
#ifdef CONFIG_SPL_BUILD /* The following code is for SPL */ @@ -1419,6 +1470,10 @@ int at91_nand_wait_ready(struct mtd_info *mtd) int board_nand_init(struct nand_chip *nand) { int ret = 0; + struct atmel_nand_host *host; + + host = &nand_host; + nand_set_controller_data(nand, host);
nand->ecc.mode = NAND_ECC_SOFT; #ifdef CONFIG_SYS_NAND_DBW_16 @@ -1486,9 +1541,45 @@ int atmel_nand_chip_init(int devnum, ulong base_addr) int ret; struct nand_chip *nand = &nand_chip[devnum]; struct mtd_info *mtd = nand_to_mtd(nand); + struct atmel_nand_host *host; + + host = &nand_host; + nand_set_controller_data(nand, host); + +#if CONFIG_IS_ENABLED(OF_CONTROL) + struct atmel_nand_data *board; + int node; + + board = &host->board; + node = fdtdec_next_compatible(gd->fdt_blob, 0, + COMPAT_ATMEL_NAND); + if (node < 0) + return -1; + + nand->IO_ADDR_R = (void __iomem *) + fdtdec_get_addr_size_auto_noparent(gd->fdt_blob, + node, "reg", + 0, NULL, true); + nand->IO_ADDR_W = nand->IO_ADDR_R;
- nand->IO_ADDR_R = nand->IO_ADDR_W = (void __iomem *)base_addr; + board->ale = fdtdec_get_uint(gd->fdt_blob, node, + "atmel,nand-addr-offset", 21);
+ board->cle = fdtdec_get_uint(gd->fdt_blob, node, + "atmel,nand-cmd-offset", 22); + + gpio_request_by_name_nodev(gd->fdt_blob, node, "gpios", 0, + &board->rdy_pin, GPIOD_IS_IN); + + gpio_request_by_name_nodev(gd->fdt_blob, node, "gpios", 1, + &board->enable_pin, GPIOD_IS_OUT); + + gpio_request_by_name_nodev(gd->fdt_blob, node, "gpios", 2, + &board->det_pin, GPIOD_IS_IN); +#else + nand->IO_ADDR_R = (void __iomem *)base_addr; + nand->IO_ADDR_W = (void __iomem *)base_addr; +#endif #ifdef CONFIG_NAND_ECC_BCH nand->ecc.mode = NAND_ECC_SOFT_BCH; #else @@ -1498,9 +1589,9 @@ int atmel_nand_chip_init(int devnum, ulong base_addr) nand->options = NAND_BUSWIDTH_16; #endif nand->cmd_ctrl = at91_nand_hwcontrol; -#ifdef CONFIG_SYS_NAND_READY_PIN + nand->dev_ready = at91_nand_ready; -#endif + nand->chip_delay = 75; #ifdef CONFIG_SYS_NAND_USE_FLASH_BBT nand->bbt_options |= NAND_BBT_USE_FLASH; diff --git a/include/fdtdec.h b/include/fdtdec.h index d074478f14..eacf251d63 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -155,6 +155,7 @@ enum fdt_compat_id { COMPAT_INTEL_BAYTRAIL_FSP_MDP, /* Intel FSP memory-down params */ COMPAT_INTEL_IVYBRIDGE_FSP, /* Intel Ivy Bridge FSP */ COMPAT_SUNXI_NAND, /* SUNXI NAND controller */ + COMPAT_ATMEL_NAND, /* Atmel NAND controller */
COMPAT_COUNT, }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 81f47ef2c7..a89e8272e1 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -66,6 +66,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(INTEL_BAYTRAIL_FSP_MDP, "intel,baytrail-fsp-mdp"), COMPAT(INTEL_IVYBRIDGE_FSP, "intel,ivybridge-fsp"), COMPAT(COMPAT_SUNXI_NAND, "allwinner,sun4i-a10-nand"), + COMPAT(COMPAT_ATMEL_NAND, "atmel,at91rm9200-nand"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
Hi Wenyou,
What is happening here? Seems like it should be a separate patch.
host = &pmecc_host;
You could adjust it so that CONFIG_SYS_NAND_MASK_CLE is assigned to host->board.cle in the init function, and then avoid this #ifdef here.
#endif +#endif +}
host = &nand_host;
nand_set_controller_data(nand, host); nand->ecc.mode = NAND_ECC_SOFT;
host = &nand_host;
int node;
COMPAT_ATMEL_NAND);
Can you instead use a proper driver? Then you can avoid adding a COMPAT string. I think you have a nand uclass.
if (node < 0)
return -1;
This is -EPERM. Perhaps use -EINVAL ?
node, "reg",
0, NULL, true);
+#else
-#endif
COMPAT_ATMEL_NAND, /* Atmel NAND controller */ COMPAT_COUNT,
2.11.0
Hi Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: 2017年2月8日 13:09 To: Wenyou Yang - A41535 Wenyou.Yang@microchip.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Andreas Bießmann andreas@biessmann.org; Scott Wood scottwood@freescale.com; Wenyou Yang - A41535 Wenyou.Yang@microchip.com Subject: Re: [PATCH] nand: atmel: add drvice tree support and dm gpio APIs
Hi Wenyou,
-static struct atmel_nand_host pmecc_host; +static struct atmel_nand_host nand_host; #ifdef +CONFIG_ATMEL_NAND_HWECC
+#ifdef CONFIG_SPL_BUILD +#undef CONFIG_SYS_NAND_ONFI_DETECTION #endif
host = &pmecc_host;
ulong IO_ADDR_W = (ulong)this->IO_ADDR_W; #if
+CONFIG_IS_ENABLED(OF_CONTROL)
IO_ADDR_W |= (1 << host->board.ale); #else IO_ADDR_W &= ~(CONFIG_SYS_NAND_MASK_ALE | CONFIG_SYS_NAND_MASK_CLE);
Accepted
*mtd,
!(ctrl & NAND_NCE)); #else
*mtd,
+nand_get_controller_data(nand_chip);
#endif +#endif +}
host = &nand_host;
nand_set_controller_data(nand, host); nand->ecc.mode = NAND_ECC_SOFT; #ifdef
base_addr)
host = &nand_host;
int node;
COMPAT_ATMEL_NAND);
You mean the patch: http://lists.denx.de/pipermail/u-boot/2017-January/279904.html
If so, that would be very nice. I will convert the nand driver to support driver model, and device tree as well.
if (node < 0)
return -1;
node, "reg",
0, NULL, true);
+#else
nand->IO_ADDR_W = (void __iomem *)base_addr; #endif
params */
2.11.0
Thank you
Best Regards, Wenyou Yang
Wenyou Yang
