[PATCH] firmware: scmi: use protocol node name to bind the scmi regulator driver
In scmi firmware driver, it is better to bind the scmi protocol driver "scmi_voltage_domain" with the node name of the protocol 17 and not the sub-node named "regulator", because is a fixed string which doesn't provide information and because it is not aligned with the other scmi protocol nodes.
For example on stm32mp135f-dk board with device tree in stm32mp131.dtsi
scmi: scmi { compatible = "linaro,scmi-optee"; #address-cells = <1>; #size-cells = <0>; linaro,optee-channel-id = <0>; shmem = <&scmi_shm>; scmi_clk: protocol@14 { reg = <0x14>; #clock-cells = <1>; }; scmi_reset: protocol@16 { reg = <0x16>; #reset-cells = <1>; }; scmi_voltd: protocol@17 { reg = <0x17>; scmi_regu: regulators { #address-cells = <1>; #size-cells = <0>; scmi_reg11: voltd-reg11 { reg = <VOLTD_SCMI_REG11>; regulator-name = "reg11"; }; scmi_reg18: voltd-reg18 { reg = <VOLTD_SCMI_REG18>; regulator-name = "reg18"; }; scmi_usb33: voltd-usb33 { reg = <VOLTD_SCMI_USB33>; regulator-name = "usb33"; }; }; }; };
Before the patch:
dm tree
scmi_agent 0 [ + ] scmi-over-optee |-- scmi clk 1 [ + ] scmi_clk | |-- protocol@14 ... reset 1 [ ] scmi_reset_domain | |-- protocol@16 nop 2 [ + ] scmi_voltage_domain | `-- regulators regulator 0 [ + ] scmi_regulator | |-- voltd-reg11 regulator 1 [ + ] scmi_regulator | |-- voltd-reg18 regulator 2 [ + ] scmi_regulator | |-- voltd-usb33 ...
after the patch:
dm tree
scmi_agent 0 [ + ] scmi-over-optee |-- scmi clk 1 [ + ] scmi_clk | |-- protocol@14 ... reset 1 [ ] scmi_reset_domain | |-- protocol@16 nop 2 [ + ] scmi_voltage_domain | `-- protocol@17 regulator 0 [ + ] scmi_regulator | |-- voltd-reg11 regulator 1 [ + ] scmi_regulator | |-- voltd-reg18 regulator 2 [ + ] scmi_regulator | |-- voltd-usb33 ...
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
drivers/firmware/scmi/scmi_agent-uclass.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index 8f48de30c8cc..9a32678617d7 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -60,6 +60,7 @@ static int scmi_bind_protocols(struct udevice *dev) { int ret = 0; ofnode node; + const char *name;
dev_for_each_subnode(node, dev) { struct driver *drv = NULL; @@ -71,6 +72,7 @@ static int scmi_bind_protocols(struct udevice *dev) if (ofnode_read_u32(node, "reg", &protocol_id)) continue;
+ name = ofnode_get_name(node); switch (protocol_id) { case SCMI_PROTOCOL_ID_CLOCK: if (IS_ENABLED(CONFIG_CLK_SCMI)) @@ -100,8 +102,7 @@ static int scmi_bind_protocols(struct udevice *dev) continue; }
- ret = device_bind(dev, drv, ofnode_get_name(node), NULL, node, - NULL); + ret = device_bind(dev, drv, name, NULL, node, NULL); if (ret) break; }
Before the patch:
dm tree
after the patch:
dm tree
Patrick Delaunay
